IS31LT3952-GRLS4-TR
IS31LT3952-GRLS4-TR
    LUMISSIL
    ESOP-8
    IC LED DRIVER LIN DIM
IS31LT3952-GRLS4-TR 数据手册
IS31LT3952 CONSTANT-CURRENT 1.5-AMPERE PWM DIMMABLE BUCK REGULATOR LED DRIVER WITH FAULT PROTECTION August 2021 GENERAL DESCRIPTION FEATURES The IS31LT3952 is a DC-to-DC switching converter that integrates an N-channel MOSFET to operate in a buck configuration. The device can operate from a wide input voltage between 4.5V and 38V and provides a constant current of up to 1.5A for driving a single LED or multiple series connected LEDs.  The external resistor, RISET, is used to set a constant LED output current, while allowing the output voltage to be automatically adjusted for a variety of LED configurations. The IS31LT3952 operates in a fixed frequency mode during switching. There is an external resistor connected between the VCC and TON pins used to configure the on-time (switching frequency). The switching frequency is dithered for spread spectrum operation which will spread the electromagnetic energy into a wider frequency band. This function is helpful for optimizing EMI performance. A logic input PWM signal applied to the enable (EN) pin will adjust the average LED current. The LED brightness is proportional to the duty cycle of the PWM signal. True average output current operation is achieved with fast transient response by using cycle-by-cycle, controlled on-time method. The IS31LT3952 is available in an SOP-8-EP package with an exposed pad for enhanced thermal dissipation. It operates from 4.5V to 38V over the temperature range of -40°C to +125°C.           Wide input voltage supply from 4.5V to 38V - Withstand 40V load dump True average output current control 1.5A maximum output over operating temperature range Cycle-by-cycle current limit Integrated high-side MOSFET switch Dimming via direct logic input or power supply voltage Internal control loop compensation Under-voltage lockout (UVLO) and thermal shutdown protection 2μA low power shutdown Spread spectrum to optimize EMI Robust fault protection: - Pin-to-GND short - Component open/short faults - Adjacent pin-to-pin short - LED open/short - Thermal shutdown APPLICATIONS     General high brightness LED lighting Architecture lighting Dimmable lights Pool lighting TYPICAL APPLICATION CIRCUIT Figure 1 Lumissil Microsystems – www.lumissil.com Rev. F, 08/05/2021 Typical Application Circuit 1 IS31LT3952 PIN CONFIGURATION Package Pin Configuration (Top View) SOP-8-EP PIN DESCRIPTION No. Pin Description 1 VCC Power supply input. Connect a bypass capacitor CIN to ground. The path from CIN to GND and VCC pins should be as short as possible. 2 TON On-time setting. Connect a resister from this pin to VCC pin to set the regulator controlled on-time. 3 EN/PWM Logic input for enable and PWM dimming. Pull up above 1.4V to enable and below 0.4V to disable. Input a 100Hz~20kHz PWM signal to dim the LED brightness. 4 FB Drive output current sense feedback. Set the output current by connecting a resister from this pin to the ground. 5, 6 GND Ground. Both pins must be grounded. 7 BOOT Internal MOSFET gate driver bootstrap. Connect a 0.1µF X7R ceramic capacitor from this pin to LX pin. 8 LX Internal high-side MOSFET switch output. Connect this pin to the inductor and Schottky diode. Thermal Pad Connect to GND. Lumissil Microsystems – www.lumissil.com Rev. F, 08/05/2021 2 IS31LT3952 ORDERING INFORMATION Industrial Range: -40°C to +125°C Order Part No. Package QTY/Reel IS31LT3952-GRLS4-TR SOP-8-EP, Lead-free 2500 Copyright  ©  2021  Lumissil  Microsystems.  All  rights  reserved.  Lumissil  Microsystems  reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use in  such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances Lumissil Microsystems – www.lumissil.com Rev. F, 08/05/2021 3 IS31LT3952 ABSOLUTE MAXIMUM RATINGS (Note 1) Input voltage, VCC (Note 2) Bootstrap to switching voltage, (VBOOT - VLX) Switching voltage, VLX (Steady state) Switching voltage, VLX (Transient< 10ns) EN/PWM and TON voltage, VEN/PWM, and VTON Current sense voltage, VFB Power dissipation, PD(MAX) Operating temperature, TA=TJ Storage temperature, TSTG Junction temperature, TJMAX Package thermal resistance, junction to ambient (4 layer standard test PCB based on JESD 51-2A), θJA Package thermal resistance, junction to thermal PAD (4 layer standard test PCB based on JESD 51-8), θJP ESD (HBM) ESD (CDM) -0.3V ~ +42V -0.3V ~ +6.0V -0.6V ~ VCC +0.3V -3.0V -0.3V ~ VCC +0.3V -0.3V ~ 6.0V 2.29W -40°C ~ +125°C -65°C ~ +150°C +150°C 43.7°C/W 1.41 °C/W ±2kV ±750V Note 1: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Note 2: A maximum of 44V can be sustained at this pin for a duration of ≤ 2s. ELECTRICAL CHARACTERISTICS VCC= 24V, TJ= TA= 25°C, unless otherwise noted. (Note 3) Symbol VCC VUVLO Parameter Conditions Input supply voltage VCC undervoltage lockout threshold VUVLO_HY VCC undervoltage lockout hysteresis Min. Typ. 4.5 VCC increasing 4.05 4.25 VCC decreasing 250 Max. Unit 38 V 4.45 V mV ICC VCC pin supply current VFB = 0.5V, VEN/PWM = high 1.2 2 mA ISD VCC pin shutdown current EN/PWM shorted to GND 2 10 µA 3.0 4.0 A ISWLIM tOCP Buck switch current limit threshold 2.0 Over Current Protection (OCP) hiccup (Note 4) time 1 ms RDS_ON Buck switch on-resistance VBOOT= VCC+4.3V, ILX= 1A 0.2 VBTUV BOOT undervoltage lockout threshold VBOOT to VLX increasing 3.3 V VBTUV_HY BOOT undervoltage lockout hysteresis VBOOT to VLX decreasing 400 mV tOFF_MIN Switching minimum off-time VFB = 0V 110 150 ns tON_MIN Switching minimum on-time 120 150 ns tON Selected on-time 0.4 Ω VCC= 24V, VOUT= 12V, RTON= 420kΩ 800 1000 1200 ns VFB decreasing, LX turns on 195 200 205 mV Regulation Comparator and Error Amplifier VFB Load current sense regulation threshold Lumissil Microsystems – www.lumissil.com Rev. F, 08/05/2021 4 IS31LT3952 ELECTRICAL CHARACTERISTICS (CONTINUE) VCC= 24V, TA= TJ= 25°C, unless otherwise noted. (Note 3) Symbol Parameter Conditions Min. Typ. Max. Unit 0.4 V Enable Input VIH Logic high voltage VEN/PWM increasing VIL Logic low voltage VEN/PWM decreasing RPWMPD EN/PWM pin pull-down resistance VEN/PWM= 5V tPWML Duration EN/PWM pin kept low to shutdown the device tPWMH tPWMSW 1.4 V 100 200 300 kΩ 55 65 80 ms Duration EN/PWM pin kept high to quit (Note 4) from shutdown mode 16 25 µs The latency of EN/PWM pull high to IC (Note 4) starts switching 120 150 µs Thermal Shutdown TSD Thermal shutdown threshold (Note 4) 165 °C TSDHYS Thermal shutdown hysteresis (Note 4) 25 °C Note 3: Production testing of the device is performed at 25°C. Functional operation of the device specified over -40°C to +125°C temperature range, is guaranteed by design, characterization and process control. Note 4: Guaranteed by design. Lumissil Microsystems – www.lumissil.com Rev. F, 08/05/2021 5 IS31LT3952 TYPICAL PERFORMANCE CHARACTERISTICS 2 2 1.8 Supply Current (mA) Supply Current (mA) RTON = 200kΩ TJ = 25°C EN/PWM = High 1.5 1 1.6 VCC = 12V RTON = 200kΩ EN/PWM = High 1.4 1.2 1 0.8 0.6 0.5 0.4 0.2 0 0 10 20 30 0 -40 40 -25 -10 5 Figure 3 ICC vs. VCC 3 50 65 80 95 110 125 80 95 110 125 80 95 110 125 ICC vs. Temperature 2 RTON = 200kΩ TJ = 25°C EN/PWM = Low 2.5 1.8 Shutdown Current (µA) Shutdown Current (µA) 35 Temperature (°C) Supply Voltage (V) Figure 2 20 2 1.5 1 1.6 VCC = 12V RTON = 200kΩ EN/PWM = Low 1.4 1.2 1 0.8 0.6 0.4 0.5 0.2 0 0 10 20 30 0 -40 40 -25 -10 5 35 50 65 Temperature (°C) Supply Voltage (V) Figure 4 20 Figure 5 ISD vs. VCC ISD vs. Temperature 0.4 0.3 TJ = 25°C VCC = 12V 0.35 0.25 0.3 RDS_ON (Ω) RDS_ON (Ω) 0.2 0.15 0.25 0.2 0.15 0.1 0.1 0.05 0 0.05 0 10 20 30 40 0 -40 -25 -10 RDS_ON vs. VCC Lumissil Microsystems – www.lumissil.com Rev. F, 08/05/2021 20 35 50 65 Temperature (°C) Supply Voltage (V) Figure 6 5 Figure 7 RDS_ON vs. Temperature 6 IS31LT3952 100 800 5LED 6LED 7LED 8LED 4LED 3LED 2LED 95 10LED 90 740 720 700 680 660 620 RISET = 0.26Ω RTON = 200kΩ L1 = 10µH TJ = 25°C 1LED ~ 10LED 600 5 10 640 1LED 85 80 75 RISET = 0.26Ω RTON = 200kΩ L1 = 10µH TJ = 25°C 1LED ~ 10LED 70 65 15 20 25 30 35 60 40 5 10 15 Figure 8 Figure 9 IOUT vs. VCC 100 1600 3LED 1580 95 1560 25 30 35 40 Efficiency vs. VCC 4LED 5LED 6LED 7LED 8LED 9LED 10LED 2LED 90 Efficiency (%) 1540 1520 1500 1480 1460 RISET = 0.13Ω RTON = 200kΩ L1 = 10µH TJ = 25°C 1LED ~ 10LED 1440 1420 1400 20 Supply Voltage (V) Supply Voltage (V) Output Current (mA) 9LED 760 Efficiency (%) Output Current (mA) 780 5 10 1LED 85 80 75 70 RISET = 0.13Ω RTON = 200kΩ L1 = 10µH TJ = 25°C 65 15 20 25 30 35 60 40 5 10 15 25 30 35 40 Supply Voltage (V) Supply Voltage (V) Figure 10 20 IOUT vs. VCC Figure 11 4.5 Efficiency vs. VCC 220 4.4 VCC = 12V UVLO_H 4.3 210 UVLO_L 4.1 VFB (mV) VUVLO (V) 4.2 4 3.9 3.8 200 190 3.7 3.6 3.5 -40 -25 -10 5 20 35 50 65 80 95 110 125 180 -40 10 Temperature (°C) Figure 12 VUVLO vs. Temperature Lumissil Microsystems – www.lumissil.com Rev. F, 08/05/2021 60 110 160 Temperature (°C) Figure 13 VFB vs. Temperature 7 IS31LT3952 1800 1400 1400 Output Current (mA) Output Current (mA) 1600 1600 VCC = 12V RISET = 0.13Ω TJ = -40°C PWM = 500Hz, 1kHz, 5kHz, 10kHz 1200 1000 800 600 1000 800 600 400 400 200 200 0 0 1200 VCC = 12V RISET = 0.13Ω TJ = 25°C PWM = 500Hz, 1kHz, 5kHz, 10kHz 10 20 30 40 50 60 70 80 90 100 0 0 10 20 30 Duty Cycle (%) Figure 14 Output Current (mA) 1200 50 60 70 80 90 100 Duty Cycle (%) IOUT vs. Duty Cycle Figure 15 1600 1400 40 IOUT vs. Duty Cycle VCC = 12V RTON = 200kΩ TJ = -40°C VCC = 12V RISET = 0.13Ω TJ = 125°C PWM = 500Hz, 1kHz, 5kHz, 10kHz VCC 10V/Div 1000 800 600 VEN/PWM 10V/Div 400 200 0 0 10 20 30 40 50 60 70 80 90 100 IL1 1A/Div Duty Cycle (%) Figure 16 Time (100µs/Div) IOUT vs. Duty Cycle Figure 17 VCC = 12V RTON = 200kΩ TJ = 25°C VCC = 12V RTON = 200kΩ TJ = 125°C VCC 10V/Div VCC 10V/Div VEN/PWM 10V/Div VEN/PWM 10V/Div IL1 1A/Div IL1 1A/Div Time (100µs/Div) Figure 18 EN/PWM Enable Time Time (100µs/Div) EN/PWM Enable Time Lumissil Microsystems – www.lumissil.com Rev. F, 08/05/2021 Figure 19 EN/PWM Enable Time 8 IS31LT3952 VCC = 12V PWM = 5V, 1kHz RTON = 200kΩ TJ = -40°C VCC = 12V PWM = 5V, 1kHz RTON = 200kΩ TJ = -40°C VCC 10V/Div VCC 10V/Div VEN/PWM 5V/Div VEN/PWM 5V/Div IL1 500mA/Div IL1 500mA/Div Time (4µs/Div) Figure 20 Time (4µs/Div) PWM Off Figure 21 VCC = 12V PWM = 5V, 1kHz RTON = 200kΩ TJ = 25°C VCC = 12V PWM = 5V, 1kHz RTON = 200kΩ TJ = 25°C VCC 10V/Div VCC 10V/Div VEN/PWM 5V/Div VEN/PWM 5V/Div IL1 500mA/Div IL1 500mA/Div Time (4µs/Div) Figure 22 Time (4µs/Div) PWM Off Figure 23 VCC = 12V PWM = 5V, 1kHz RTON = 200kΩ TJ = 125°C PWM On VCC = 12V PWM = 5V, 1kHz RTON = 200kΩ TJ = 125°C VCC 10V/Div VCC 10V/Div VEN/PWM 5V/Div VEN/PWM 5V/Div IL1 500mA/Div IL1 500mA/Div Time (4µs/Div) Figure 24 PWM On Time (4µs/Div) PWM Off Lumissil Microsystems – www.lumissil.com Rev. F, 08/05/2021 Figure 25 PWM On 9 IS31LT3952 FUNCTIONAL BLOCK DIAGRAM BOOT VCC VREG 5.3V VDD UVLO Average On-Time Current Generator TON On-Time Timer Off-Time Timer Gate Drive UVLO SD Level Shift EN/PWM VIL=0.4V VIH=1.4V LX IC and Driver Control Logic FB Current Limit Off-time Timer VDD UVLO 0.2V CCOMP Lumissil Microsystems – www.lumissil.com Rev. F, 08/05/2021 Thermal Shutdown Buck Switch Current Sense ILIM Fault Detection GND 10 IS31LT3952 APPLICATION INFORMATION DESCRIPTION OUTPUT CURRENT SETTING The IS31LT3952 is a buck regulator with wide input voltage, low reference voltage, quick output response and excellent PWM dimming performance, which is ideal for driving a high-current LED string. It uses average current mode control to maintain constant LED current and consistent brightness. The LED current is configured by an external sense resistor, RISET, with a value determined as follows Equation (1): UNDER VOLTAGE LOCKOUT (UVLO) The device features an under voltage lockout (UVLO) function on VCC pin. This is a fixed value which cannot be adjusted. The device is enabled when the VCC voltage rises to exceed VUVLO (Typ. 4.25V), and disabled when the VCC voltage falls below (VUVLO VUVLO_HY) (Typ. 4V). BOOTSTRAP CIRCUIT The gate driver of the integrated high-side MOSFET requires a voltage above VCC as power supply. As below circuit diagram, there is an internal 5.3V LDO which is the power supply of the gate driver. The BOOT pin is internally connected to the output of the 5.3V LDO. Connect a ceramic capacitor between BOOT and SW pins. The VCC supplies the power to the 5.3V LDO which charges the CBOOT capacitor during high-side MOSFET off cycles. Then in high-side MOSFET on cycles, the CBOOT charge voltage is used to boost the BOOT pin to 5.3V higher than LX pin. VCC Bootstrap Circuit 5.3V LDO BOOT Gate Drive UVLO SD Level Shift Gate Drive CBOOT 0.1µF Internal MOSFET LX Figure 26 Bootstrap Circuit A 0.1µF X7R ceramic capacitor will work well in most applications. The gate driver also has an under voltage lockout detection. The gate driver is enabled when the voltage on the CBOOT rises to above VBTUV (Typ. 3.3V), and disabled when the voltage on the CBOOT drops below (VBTUV - VBTUV_HY) (Typ. 2.9V). Lumissil Microsystems – www.lumissil.com Rev. F, 08/05/2021 I LED  VFB / RISET (1) Where VFB = 0.2V (Typ.). Note that RISET= 0.133Ω is the minimum allowed value for the sense resistor in order to maintain the switch current below the specified maximum value. Table 1 RISET Resistance Versus Output Current RISET (Ω) Nominal Average Output Current (mA) 0.4 500 0.2 1000 0.133 1500 The resistor RISET should be a 1% resistor with enough power tolerance and good temperature characteristic to ensure accurate and stable output current. ENABLE AND PWM DIMMING A high logic signal on the EN/PWM pin will enable the IC. The buck converter ramps up the LED current to a target level which is set by external resistor, RISET. When the EN/PWM pin goes from high to low, the buck converter will turn off, but the IC remains in standby mode for up to tPWML. When the EN/PWM pin goes high within this period, the LED current will turn on immediately. Sending a PWM (pulse-width modulation) signal to the EN/PWM pin will result in dimming of the LED. The resulting LED brightness is proportional to the duty cycle (tON /T) of the PWM signal. A practical range for PWM dimming frequency is between 100Hz and 20kHz. There is an inherent PWM turn on delay time of about 1µs during continuous PWM dimming. A high frequency PWM signal has a shorter period time that will degrade the PWM dimming linearity. Therefore a low frequency PWM signal is good for achieving better dimming contrast ratio. At a 200Hz PWM frequency, the dimming duty cycle can be varied from 100% down to 1% or lower. If the EN/PWM pin is kept low for at least tPWML, the IC enters shutdown mode to reduce power consumption. The next high signal on EN/PWM will initialize a full startup sequence, which includes a shutdown quit time, tPWMH, and a startup latency, tPWMSW. This startup sequence does not exist in a typical PWM operation. 11 IS31LT3952 and capacitance of the capacitor contribute to the output current ripple. Therefore, a low-ESR X7R type capacitor should be used. tPWMSW tPWML tPWMH VEN/PWM IC shutdown IC enabled IC starts switching IL Figure 27 Device Shutdown and Enable INPUT CAPACITOR The input capacitor provides the transient pulse current, which is approximately equal to ILED, to the inductor of the converter when the high-side MOSFET is on. An X7R type ceramic capacitor is a good choice for the input bypass capacitor to handle the ripple current since it has a very low equivalent series resistance (ESR) and low equivalent series inductance (ESL). Use the following equation to estimate the approximate capacitance: C IN _ MIN I t  LED ON VCC (2) Where, ∆VCC is the acceptable input voltage ripple, generally choose 5%-10% of input voltage. tON is on-time of the high-side MOSFET in µs. A minimum input capacitance of 2X CIN_MIN is recommended for most applications. OUTPUT CAPACITOR The IS31LT3952 control loop can accept a voltage ripple on the FB pin, this means it can operate without an output capacitor to save cost. The FB pin needs a certain amount of voltage ripple to keep control loop stability. A capacitor can be added across the LEDs but excluding the FB resistor. This capacitor will reduce the LED current ripple while keep the same average current in some application cases. The reduction of the LED current ripple by the capacitor depends on several factors: capacitor value, inductor current ripple, operating frequency, output voltage, etc. A several µF capacitor is sufficient for most applications. However, the output capacitor brings in more delay time of LED current during PWM dimming that will degrade the dimming contrast. The output capacitor is used to filter the LED current ripple to an acceptable level. The equivalent series resistance (ESR), equivalent series inductance (ESL) Lumissil Microsystems – www.lumissil.com Rev. F, 08/05/2021 Figure 28 Adding Output Capacitor FREQUENCY SELECTION During switching the IS31LT3952 operates in a constant on-time mode. The on-time is adjusted by the external resistor, RTON, which is connected between the VCC and TON pins. 2.2 2 1.8 1.6 fSW (MHz) The EN/PWM pin is high-voltage tolerant and can be connected directly to a power supply. However, a series resistor (10kΩ) is required to limit the current flowing into the EN pin if PWM is higher than the VCC voltage at any time. If PWM is driven from a logic input, this series resistor is not necessary. 1.4 1.2 1 0.8 0.6 0.4 0.2 0 0 100 200 300 400 500 600 700 800 900 1000 1100 RTON (kΩ) Figure 29 Operating Frequency vs. RTON Resistance The approximate operating frequency calculated by below Equation (3) and (4): tON  k  RTON  RINT   VOUT VCC f SW  1 k  RTON  RINT  can be (3) (4) Where k= 0.00458, with fSW in MHz, tON in µs, and RTON and RINT (internal resistance, 20kΩ) in kΩ. Higher frequency operation results in smaller component size but increases the switching losses. It may also increase the high-side MOSFET gate driving current and may not allow sufficient high or low duty cycle. Lower frequency gives better performance but results in larger component size. 12 IS31LT3952 SPREAD SPECTRUM A switch mode controller can be troublesome when the EMI is concerned. To optimize the EMI performance, the IS31LT3952 includes a spread spectrum feature, which is a 500Hz with ±10% operating frequency jitter. The spread spectrum can spread the total electromagnetic emitting energy into a wider range that significantly degrades the peak energy of EMI. With spread spectrum, the EMI test can be passed with smaller size and lower cost filter circuit. MINIMUM AND MAXIMUM OUTPUT VOLTAGE The output voltage of a approximately given as below: buck VOUT  VCC  D converter is (5) Assume the forward voltage of each LED is 3.2V, the device can drive up to 3 LEDs in series. The minimum output voltage is limited by the switching minimum on-time, about 150ns, since frequency is set. For example, if the input voltage is 12V and the operating frequency fSW=1MHz, the minimum output voltage is: VOUT  12V  150ns  1MHz  1.8V (9) This means the device can drive a low forward voltage LED, such as a RED color LED. So under the condition of VCC=12V and fSW=1MHz, the output voltage range is 1.8V~10.2V. Exceeding this range, the operation will be clamped and the output current cannot reach the set value. In a typical application, the output voltage is affected by other operating parameters, such as output current, RDS_ON of the high-side MOSFET, DRC of the inductor, parasitic resistance of the PCB traces, and the forward voltage of the diode. Therefore, the output voltage range could vary from the calculation. The more precision equation is given by: Where D is the operating duty cycle. VOUT  (VCC  I LED  RDS _ ON )  D  RL  I LED VD  (1 D) (10) Where, RDS_ON is the static drain-source on resistance of the high-side MOSFET, and RL is the inductor DC resistance. Figure 30 D So, VOUT  VCC  Operating Waveform t ON t ON  t OFF (6) tON  VCC  tON  f SW t ON  tOFF (7) Where tON and tOFF are the turn-on and turn off time of high-side MOSFET. Note that due to the spread spectrum, the fSW should use the maximum of the operating frequency, 110%×fSW. According to above equation, the output voltage depends on the operating frequency and the high-side MOSFET turn on time. When the frequency is set, the maximum output voltage is limited by the switching minimum off-time tOFF_MIN, about 150ns. For example, if the input voltage is 12V and the operating frequency fSW=1MHz, the maximum output voltage is: VOUT  12V  (1s  150ns )  1MHz  10.2V Lumissil Microsystems – www.lumissil.com Rev. F, 08/05/2021 Figure 31 shows how the minimum and maximum output voltages vary with the operating frequency at 12V and 24V input. Figure 32 shows how the minimum and maximum output voltages vary with the LED current at 9V input (assuming RDS_ON = 0.4Ω, inductor DCR RL= 0.1Ω, and diode VD = 0.6V). Note that due to the spread spectrum, the fSW should use the maximum of the operating frequency, 110%×fSW. When the output voltage is lower than the minimum tON time of the device, the device will automatically extend the operating tOFF time to maintain the set output LED current all the time. However, the operating frequency will decrease accordingly to lower level to keep the duty cycle in correct regulating. To achieve wider output voltage range and flexible output configuration, a lower operating frequency could be considered. (8) 13 IS31LT3952 24 L 22 ILED= 1A RL= 0.1Ω RDSON= 0.4Ω VD= 0.6V 20 18 VOUT (V) 16 VCC= 24V (Max. VOUT) VCC= 12V (Max. VOUT) 10 8 VCC= 24V (Min. VOUT) 6 4 VCC= 12V (Min. VOUT) 2 0 0 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 2 fSW (MHz) Since the IS31LT3952 is a Continuous Conduction Mode (CCM) buck driver which means the valley of the inductor current, IMIN, should not drop to zero at any time, the ∆IL must be smaller than 200% of the average output current. I MIN  I LED  Figure 31 Minimum and Maximum Output Voltage versus Operating Frequency (minimum tON and tOFF = 150ns) 8 7 VCC= 9V fSW= 1MHz RL= 0.1Ω RDSON= 0.4Ω VD= 0.6V 5 Max. I MAX  I LED  4 (12) I L  I SWLIM 2 (13) To ensure system stability, the ∆IL must be higher than 10% of the average output current. For the better performance, choose an inductor current ripple ∆IL between 10% and 50% of the average output current. 3 2 Min. 1 0 I L 0 2 Besides, the peak current of the inductor, IMAX, must be smaller than ISWLIM to prevent the IS31LT3952 from triggering OCP, especially when the output current is set to a high level. 0.1  I LED  I L  0.5  I LED 0 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 ILED (A) Figure 32 Minimum and Maximum Output Voltage versus LED Current (minimum tON and tOFF= 150ns) PEAK CURRENT LIMIT To protect itself, the IS31LT3952 integrates an Over Current Protection (OCP) detection circuit to monitor the current through the high-side MOSFET during switching on. Whenever the current exceeds the OCP current threshold, ISWLIM, the device will immediately turn off the high-side MOSFET for tOCP and restart again. The device will remain in this hiccup mode until the current drops below ISWLIM. 2 1.8 VCC= 12V VOUT= 6.4V L= 10µH 1.6 L= 15µH 1.4 1.2 1 L= 22µH 0.8 INDUCTOR 0.6 Inductor value involves trade-offs in performance. A larger inductance reduces inductor current ripple, however it also brings in unwanted parasitic resistance that degrades the efficiency. A smaller inductance has compact size and lower cost, but introduces higher ripple in the LED string. Use the following equation to estimate the approximate inductor value: 0.4 Lumissil Microsystems – www.lumissil.com Rev. F, 08/05/2021 (14) Figure 33 shows inductor selection based on the operating frequency and LED current at 30% inductor current ripple. If a lower operating frequency is used, either a larger inductance or current ripple should be used. fSW (MHz) VOUT (V) 6 (11) Where VCC is the minimum input voltage in volts, VLED is the total forward voltage of LED string in volts, fSW is the operation frequency in hertz and ∆IL is the current ripple in the inductor. Select an inductor with a rated current greater than the output average current and the saturation current over the Over Current Protection (OCP) current threshold ISWLIM. 14 12 (VCC  VLED )  VLED f SW  I L  VCC L= 33µH 0.2 0 L= 47µH 0 0.3 0.6 0.9 1.2 1.5 ILED (A) Figure 33 Inductance Selection Based On 30% Current Ripple 14 IS31LT3952 DIODE THERMAL SHUTDOWN PROTECTION The IS31LT3952 is a non-synchronous buck driver that requires a recirculating diode to conduct the current during the high-side MOSFET off time. The best choice is a Schottky diode due to its low forward voltage, low reverse leakage current and fast reverse recovery time. The diode should be selected with a peak current rating above the inductor peak current and a continuous current rating higher than the maximum output load current. It is very important to consider the reverse leakage of the diode when operating at high temperature. Excess leakage will increase the power dissipation on the device. To protect the IC from damage due to high power dissipation, the temperature of the die is monitored. If the die temperature exceeds the thermal shutdown temperature of 165°C (Typ.) then the device will shut down, and the output current is shut off. After a thermal shutdown event, the IS31LT3952 will not try to restart until its temperature has reduced to less than 140°C (Typ.). The higher input voltage and the voltage ringing due to the reverse recovery time of the Schottky diode will increase the peak voltage on the LX output. If a Schottky diode is chosen, care should be taken to ensure that the total voltage appearing on the LX pin including supply ripple, does not exceed its specified maximum value.       FAULT HANDLING The IS31LT3952 is designed to detect the following faults: Pin open Pin-to-ground short (except LX pin) Pin-to-neighboring pin short Output LED string open and short External component open or short (except diode) Thermal shutdown Please check Table 2 for the details of the fault actions. Table 2 Fault Actions Fault Type LED String Inductor shorted Dim RISET short Dim RISET open LED string shorted to GND BOOT capacitor open BOOT capacitor shorted RTON resistor open RTON resistor shorted EN short to RISET Thermal Shutdown Detect Condition Fault Recovering Trigger OCP. Turn off high-side MOSFET immediately. Retry after 1ms. Trigger OCP. Turn off high-side MOSFET immediately. Retry after 1ms. Inductor shorted removed. No OCP triggered. RISET shorted removed. No OCP triggered. Off The FB pin voltage exceeds 2V. Turn off high-side MOSFET immediately. Retry after 1ms. RISET open removed. The FB pin voltage drops below 1.55V. Off Trigger OCP. Turn off high-side MOSFET immediately. Retry after 1ms. Shorted removed. No OCP triggered. Dim VCC-VSW>1.8V at high-side MOSFET ON (High-side can’t fully turn on). Turn off high-side MOSFET immediately. Retry after 1ms. BOOT capacitor open removed Off Bootstrap circuit UVLO and turn off high-side MOSFET immediately. BOOT capacitor shorted removed. Release from UVLO. Dim On-time exceeds 20µs or trigger OCP, then turn off high-side MOSFET immediately. Retry after 1ms. RTON resistor open removed. No over 20µs on-time or OCP triggered. Dim The device operating at minimum on/off time, maybe trigger the other fault conditions. RTON resistor shorted removed. Off EN/PWM will be pulled low by RISET resistor. EN short to RISET removed. Off The die temperature exceeds 165°C The die temperature cools down below 140°C. Lumissil Microsystems – www.lumissil.com Rev. F, 08/05/2021 15 IS31LT3952 As for all switching power supplies, especially those providing high current and using high switching frequencies, layout is an important design step. If layout is not carefully done, the operation could show instability as well as EMI problems. The high dV/dt surface and dI/dt loops are big noise emission source. To optimize the EMI performance, keep the area size of all high switching frequency points with high voltage compact. Meantime, keep all traces carrying high current as short as possible to minimize the loops. (1) Wide traces should be used for connection of the high current paths that helps to achieve better efficiency and EMI performance. Such as the traces of power supply, inductor L1, current recirculating diode D1, LED load and ground. (2) Keep the traces of the switching points shorter. The inductor L1, LX and current recirculating diode D1 should be placed as close to each other as possible and the traces of connection between them should be as short and wide as possible. (3) To avoid the ground jitter, the components of parameter setting, RISET, should be placed close to the device and keep the traces length to the device pins as short as possible. On the other side, to prevent the noise coupling, the traces of RISET should either be far away or be isolated from high-current paths and high-speed switching nodes. These practices are essential for better accuracy and stability. (4) The capacitor CIN should be placed as close as possible to VCC pin for good filtering. (5) Place the bootstrap capacitor CBOOT close to BOOT pin and LX pin to ensure the traces as short as possible. (6) The connection to the LED string should be kept short to minimize radiated emission. In practice, if the LED string is far away from the driver board, an output capacitor is recommended to be used and placed on driver board to reduce the current ripple in the connecting wire. When operating the chip at high ambient temperatures, or when driving maximum load current, care must be taken to avoid exceeding the package power dissipation limits. The maximum power dissipation can be calculated using the following Equation (15): PD ( MAX )  PD ( MAX )  So, TJ ( MAX )  TA (15)  JA 125C  25C  2.29W 43.7C / W Figure 34, shows the power derating of the IS31LT3952 on a JEDEC boards (in accordance with JESD 51-5 and JESD 51-7) standing in still air. 3 SOP-8-EP Power Dissipation (W) LAYOUT CONSIDERATIONS 2.5 2 1.5 1 0.5 0 -40 -25 -10 5 20 35 50 65 80 95 110 125 Temperature (°C) Figure 34 Dissipation Curve The thermal resistance is achieved by mounting the IS31LT3952 on a standard FR4 double-sided printed circuit board (PCB) with a copper area of a few square inches on each side of the board under the IS31LT3952. Multiple thermal vias, as shown in Figure 35, help to conduct the heat from the exposed pad of the IS31LT3952 to the copper on each side of the board. The thermal resistance can be reduced by using a metal substrate or by adding a heatsink. (7) The thermal pad on the back of device package must be soldered to a sufficient size of copper ground plane with sufficient vias to conduct the heat to opposite side PCB for adequate cooling. THERMAL CONSIDERATIONS The package thermal resistance, θJA, determines the amount of heat that can pass from the silicon die to the surrounding ambient environment. The θJA is a measure of the temperature rise created by power dissipation and is usually measured in degree Celsius per watt (°C/W). Lumissil Microsystems – www.lumissil.com Rev. F, 08/05/2021 Figure 35 Board Via Layout For Thermal Dissipation 16 IS31LT3952 CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) 150°C 200°C 60-120 seconds Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) Time at liquidous (tL) 217°C 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified classification temperature (Tc) Max 30 seconds Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature Figure 36 8 minutes max. Classification Profile Lumissil Microsystems – www.lumissil.com Rev. F, 08/05/2021 17 IS31LT3952 PACKAGE INFORMATION SOP-8-EP Lumissil Microsystems – www.lumissil.com Rev. F, 08/05/2021 18 IS31LT3952 RECOMMENDED LAND PATTERN SOP-8-EP Note: 1. Land pattern complies to IPC-7351. 2. All dimensions in MM. 3. This document (including dimensions, notes & specs) is a recommendation based on typical circuit board manufacturing parameters. Since land pattern design depends on many factors unknown (eg. User’s board manufacturing specs), user must determine suitability for use. Lumissil Microsystems – www.lumissil.com Rev. F, 08/05/2021 19 IS31LT3952 REVISION HISTORY Revision Detail Information Date A Initial release 2018.04.09 B 1. Update EC table 2. Revise Applications 2018.08.03 C 1. Update fault function information 2. Update VLX ABSOLUTE MAXIMUM RATINGS 3. Update POD 2018.10.24 D 1. Add tPWMH and tPWMSW in EC table 2. Add Figure 27 2018.12.25 E 1. Update RPWMPD and tPWML in EC table 2019.07.25 F Update Land Pattern and POD 2021.08.05 Lumissil Microsystems – www.lumissil.com Rev. F, 08/05/2021 20
IS31LT3952-GRLS4-TR 价格&库存
很抱歉,暂时无法提供与“IS31LT3952-GRLS4-TR”相匹配的价格&库存,您可以联系我们找货
IS31LT3952-GRLS4-TR
  • 2500+5.112272500+0.63943
  • 5000+4.990405000+0.62419
  • 7500+4.929387500+0.61656
  • 12500+4.8617512500+0.60810
  • 17500+4.8222617500+0.60316
