ASNT5113-KMC
ASNT5113-KMC
    ADSANTEC(先进科技)
    CQFlatPack24
    32G DIFF. D FLIP-FLOP, CM ADJ.
ASNT5113-KMC 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT5113-KMC DC-32Gbps High Sensitivity D-Type Flip-Flop  High speed broadband D-Type Flip-Flop for data retiming with full rate clock  Additional input buffer / level shifter for improved protection  Sensitive input data buffer with increased CM range that is ideal for sampling applications  Input data single-ended common mode controls  Exhibits low jitter and limited temperature variation over industrial temperature range  4ps set-up/hold time capability  88% clock phase margin for retiming of data input eye  Fully differential CML input interfaces  Fully differential CML output interface with 400mV single-ended swing  Single +3.3V or -3.3V power supply  Power consumption: 510mW  Fabricated in SiGe for high performance, yield, and reliability  Custom CQFP 24-pin package Rev. 1.4.2 1 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION vcc vcc dcinp 83 125 50 DFF core dp dn 125 dcinn qp qn 83 50 vcc 50 vcc 50 vcc cp cn vcc Fig. 1. Functional Block Diagram The temperature stable ASNT5113-KMC SiGe IC provides broadband data retiming functionality and is intended for use in high-speed measurement / test equipment. The IC shown in Fig. 1 can sample a highspeed data signal dp/dn with a full-rate external clock cp/cn to create a full-rate retimed NRZ data output qp/qn. The data input buffer is designed to have increased input signal sensitivity, and is able to operate over a wider range of input common mode (CM) voltages. The actual common mode voltage levels at data inputs dp/dn can be adjusted by applying voltages between vee and vcc to the corresponding control inputs dcinp/dcinn. The part’s I/O’s support the CML logic interface with on chip 50Ohm termination to vcc and may be used differentially, AC/DC coupled, single-ended, or in any combination (see also POWER SUPPLY CONFIGURATION). In the DC-coupling mode, the input signal’s common mode voltage should comply with the specifications shown in ELECTRICAL CHARACTERISTICS. In the AC-coupling mode, the input termination provides the required common mode voltage automatically. The differential DC signaling mode is recommended for optimal performance. It should be noted that the control inputs dcinp/dcinn should be always connected to voltage sources to ensure correct 50Ohm terminations for the data inputs. POWER SUPPLY CONFIGURATION The part can operate with either a negative supply (vcc = 0.0V = ground and vee = −3.3V), or a positive supply (vcc = +3.3V and vee = 0.0V = ground). In case of a positive supply, all I/Os need AC termination when connected to any devices with 50Ohm termination to ground. Different PCB layouts will be needed for each different power supply combination. All the characteristics detailed below assume vcc = 0.0V and vee = -3.3V. Rev. 1.4.2 2 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings shown in Table 1 may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground (assumed vcc). Table 1. Absolute Maximum Ratings Parameter Supply Voltage (vee) Power Consumption Input Data Voltage Swing (SE) Input Clk Voltage Swing (SE) Case Temperature Storage Temperature Operational Humidity Storage Humidity Min -40 10 10 Max -3.6 0.56 1.7 1.7 +90 +100 98 98 Units V W V V ºC ºC % % TERMINAL FUNCTIONS TERMINAL Name No. Type dp dn cp cn qp qn dcinp dcinn Name vcc vee Rev. 1.4.2 DESCRIPTION High-Speed I/Os 21 CML Differential data inputs with internal SE 50Ohm termination Input to vcc 23 3 CML Differential clock inputs with internal SE 50Ohm termination Input to vcc 5 11 CML Differential data outputs with internal SE 50Ohm termination Output to vcc. Require external SE 50Ohm termination to vcc 9 DC Controls 15 Input Input data DC common mode voltage level controls. Should be always connected to voltage sources! 17 Supply and Termination Voltages Description Pin Number Positive power supply 2, 4, 6, 8, 10, 12, 14, 16, 18, 20, 22, 24 (+3.3V or 0V) Negative power supply 1, 7, 13, 19 (0V or -3.3V) 3 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER MIN TYP MAX UNIT COMMENTS General Parameters 0.0 V External ground vcc -3.1 -3.3 -3.5 V ±6% vee Ivcc 155 165 mA Power consumption 510 545 mW Junction temperature -25 50 125 °C HS Input Data (dp/dn) Data rate DC 32 40 Gbps Swing 0.01 1.3 V Differential or SE, p-p CM Voltage Level vcc-0.7+sw/2 vcc+0.6-sw/2 V Must match for both inputs HS Input Clock (cp/cn) Frequency DC 32 40 GHz Swing 0.05 1.3 V Differential or SE, p-p CM Voltage Level vcc-0.7+sw/2 vcc+0.6-sw/2 V Must match for both inputs Duty Cycle 40 50 60 % Clock Phase Margin 86 88 90 % For reliable data latching at full rate Setup/Hold Times 2.75/1.0 ps For reliable data latching HS Output Data (qp/qn) Data rate DC 32 40 Gbps Logic “1” level vcc-0.05 vcc-0.03 vcc-0.01 V Logic “0” level vcc-0.46 vcc-0.44 vcc-0.42 V With external 50Ohm DC termination Jitter 0.15 ps Peak-to-peak at 32Gbps DC Input Controls (dcinp/dcinn) Max level vcc + 1.0 V Min level vcc - 1.0 V PACKAGE INFORMATION The chip die is housed in a custom 24-pin CQFP package shown in Fig. 2. The package provides a center heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this section to be soldered to the vcc plain, which is ground for a negative supply, or power for a positive supply. The part’s identification label is ASNT5113-KMC. The first 8 characters of the name before the underscore identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 characters after the underscore represent the package’s manufacturer, type, and pin out count. This device complies with the Restriction of Hazardous Substances (RoHS) per 2011/65/EU for all ten substances. Rev. 1.4.2 4 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Fig. 2. CQFP 24-Pin Package Drawing (All Dimensions in mm) Rev. 1.4.2 5 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com REVISION HISTORY Revision 1.4.2 1.3.2 1.3.1 1.2.1 1.1.1 Date 02-2020 07-2019 07-2015 07-2015 06-2013 1.0.1 02-2013 Rev. 1.4.2 Changes Updated Package Information Updated Letterhead Revised package information section Inserted setup and hold times (identical to clock phase margin) Corrected pin out diagram Removed data duty cycle specification First release 6 February 2020
ASNT5113-KMC 价格&库存
很抱歉,暂时无法提供与“ASNT5113-KMC”相匹配的价格&库存,您可以联系我们找货
