ASNT5190B-KMC
ASNT5190B-KMC
    ADSANTEC(先进科技)
    CLQFP24
    2:1 BROADBAND DIG. DEMULTIPLEXER
ASNT5190B-KMC 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT5190B-KMC DC-64Gbps Broadband Digital 1:2 Demultiplexer  Ideal for high speed proof-of-concept prototyping  Fully differential CML input interfaces  Fully differential CML output interface with 400mV single-ended swing  Single +3.3V or -3.3V power supply  Power consumption: 600mW  Fabricated in SiGe for high performance, yield, and reliability  Custom CQFP 24-pin package vee Exhibits low jitter and limited temperature variation over industrial temperature range vcc  q1n External control of internal clock’s duty cycle vcc  q1p High speed broadband 1:2 Demultiplexer vcc  dcinp vcc vcc dp q2p ASNT5190B vcc vcc dn q2n vcc vcc Rev. 0.1.2 1 vcc cn vcc cp vcc vee dcinn May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION q1p q1n 50 50 50 50 dp q2p 1:2 DMX Core dn 50 q2n 50 50 50 dcinp dcinn 1K cp cn 1K Fig. 1. Functional Block Diagram The temperature stable ASNT5190B-KMC SiGe IC can be utilized as a high speed 1:2 demultiplexer, and is intended for use in high-speed measurement / test equipment. The IC shown in Fig. 1 can receive a high speed differential data input signal dp/dn and effectively demultiplex it into two high speed differential data output signals q1p/q1n and q2p/q2n by using a high speed differential clock input signal cp/cn. The duty cycle of the internal clock can be adjusted through ports dcinp/dcinn. The part’s I/O’s support the CML logic interface with on chip 50Ohm termination to vcc and may be used differentially, AC/DC coupled, single-ended, or in any combination (see also POWER SUPPLY CONFIGURATION). In the DC-coupling mode, the input signal’s common mode voltage should comply with the specifications shown in ELECTRICAL CHARACTERISTICS. In the AC-coupling mode, the input termination provides the required common mode voltage automatically. The differential DC signaling mode is recommended for optimal performance. POWER SUPPLY CONFIGURATION The part can operate with either a negative supply (vcc = 0.0V = ground and vee = −3.3V), or a positive supply (vcc = +3.3V and vee = 0.0V = ground). In case of a positive supply, all I/Os need AC termination when connected to any devices with 50Ohm termination to ground. Different PCB layouts will be needed for each different power supply combination. All the characteristics detailed below assume vcc = 0.0V and vee = -3.3V. Rev. 0.1.2 2 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground. Table 1. Absolute Maximum Ratings Parameter Supply Voltage (vee) Power Consumption RF Input Voltage Swing (SE) Case Temperature Storage Temperature Operational Humidity Storage Humidity Min -40 10 10 Max -3.6 0.65 1.0 +90 +100 98 98 Units V W V ºC ºC % % TERMINAL FUNCTIONS TERMINAL Name No. Type dp dn q1p q1n q2p q2n cp cn dcinp dcinn Name vcc vee Rev. 0.1.2 DESCRIPTION High-Speed I/Os 21 CML Differential data input signals with internal 50Ohm termination input to vcc 23 17 CML Differential data output signals with internal 50Ohm output termination to vcc 15 11 CML Differential data output signals with internal 50Ohm output termination to vcc 9 3 CML Differential clock input signals with internal 50Ohm input termination to vcc 5 Control Ports 19 Analog cp common mode control voltage inputs cn common mode control voltage 7 Supply and Termination Voltages Description Pin Number Positive power supply 2, 4, 6, 8, 10, 12, 14, 16, 18, 20, 22, 24 (+3.3V or 0) Negative power supply 1, 13 (0V or -3.3V) 3 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER vee vcc Ivee Power consumption Junction temperature Data rate Swing CM Voltage Level Frequency Swing CM Voltage Level Duty cycle Data rate Logic “1” level Logic “0” level Rise/Fall times Output Jitter Input signal range MIN TYP MAX UNIT COMMENTS General Parameters -3.1 -3.3 -3.5 V ±6% 0.0 V External ground 180 mA 600 mW -40 25 125 °C HS Input Data (dp/dn) DC 64 Gbps 0.05 1.0 V Differential or SE, p-p vcc-0.8 vcc V Must match for both inputs HS Input Clock (cp/cn) DC 32 GHz 0.05 1.0 V Differential or SE, p-p vcc-0.8 vcc V Must match for both inputs 45 50 55 % HS Output Data (q1p/q1n, q2p/q2n) DC 32 Gbps V vcc vcc-0.4 V With external 50Ohm DC termination 6 8 10 ps 20%-80% 1 ps Peak-to-peak Common Mode Control Ports (dcinp/dcinn) -3.3 0 V PACKAGE INFORMATION The chip die is housed in a custom 24-pin CQFP package shown in Fig. 2. The package provides a center heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this section to be soldered to the vcc plain, which is ground for a negative supply, or power for a positive supply. The part’s identification label is ASNT5190B-KMC. The first 9 characters of the name before the dash identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 characters after the dash represent the package’s manufacturer, type, and pin out count. This device complies with the Restriction of Hazardous Substances (RoHS) per 2011/65/EU for all ten substances. Rev. 0.1.2 4 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Fig. 2. CQFP 24-Pin Package Drawing (All Dimensions in mm) Rev. 0.1.2 5 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com REVISION HISTORY Revision 0.1.2 0.0.2 0.0.1 Rev. 0.1.2 Date 05-2020 07-2019 09-2014 Changes Updated Package Information Updated Letterhead Preliminary release 6 May 2020
ASNT5190B-KMC 价格&库存
很抱歉,暂时无法提供与“ASNT5190B-KMC”相匹配的价格&库存,您可以联系我们找货
