ASNT5014-KMC
ASNT5014-KMC
    ADSANTEC(先进科技)
    CQFlatPack24
    25G DIFF. D FLIP-FLOP, AMP. CTRL
ASNT5014-KMC 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT5014-KMC DC-25Gbps D-Type Flip-Flop  87% clock phase margin for retiming of data input eye  Fully differential CML input interfaces  Fully differential CML output interface with amplitude control  Single +3.3V or -3.3V power supply  Power consumption: 725mW  Fabricated in SiGe for high performance, yield, and reliability  Custom CQFP 24-pin package vee 6.5ps set-up/hold time capability vcc  gc Exhibits low jitter and limited temperature variation over industrial temperature range vcc  vcc High speed broadband D-Type Flip-Flip for data retiming with full rate clock and single-ended output amplitude control vcc  vee vcc vcc dp outp ASNT5014 ASNT5111 vcc vcc dn outn vcc vcc Rev. 3.1.2 1 vcc cn vcc cp vcc vee vee May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION 2K gc 50 50 dp DFF core dn outp outn 50 50 50 50 cp cn Fig. 1. Functional Block Diagram The temperature stable ASNT5014-KMC SiGe IC provides broadband data retiming functionality and is intended for use in high-speed measurement / test equipment. The IC shown in Fig. 1 can sample a highspeed data signal dp/dn with a full-rate external clock cp/cn to create a full-rate retimed NRZ data output outp/outn with its output signal amplitude controlled by gc. The part’s I/O’s support the CML logic interface with on chip 50Ohm termination to vcc and may be used differentially, AC/DC coupled, single-ended, or in any combination (see also POWER SUPPLY CONFIGURATION). In the DC-coupling mode, the input signal’s common mode voltage should comply with the specifications shown in ELECTRICAL CHARACTERISTICS. In the AC-coupling mode, the input termination provides the required common mode voltage automatically. The differential DC signaling mode is recommended for optimal performance. POWER SUPPLY CONFIGURATION The part can operate with either negative supply (vcc = 0.0V = ground and vee = −3.3V), or positive supply (vcc = +3.3V and vee = 0.0V = ground). In case of the positive supply, all I/Os need AC termination when connected to any devices with 50Ohm termination to ground. Different PCB layouts will be needed for each different power supply combination. Rev. 3.1.2 2 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com All the characteristics detailed below assume vcc = 0.0V and vee = -3.3V. ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings shown in Table 1 may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground. Table 1. Absolute Maximum Ratings Parameter Supply Voltage (vee) Power Consumption RF Input Voltage Swing (SE) Case Temperature Storage Temperature Operational Humidity Storage Humidity Min -40 10 10 Max -3.6 0.80 1.0 +90 +100 98 98 Units V W V ºC ºC % % TERMINAL FUNCTIONS TERMINAL Name No. Type dp dn cp cp outp outn gc Name vcc vee Rev. 3.1.2 DESCRIPTION High-Speed I/Os Differential data inputs with internal SE 50Ohm termination to vcc. Differential clock inputs with internal SE 50Ohm termination to vcc. Differential data outputs with internal SE 50Ohm termination to vcc. Require external SE 50Ohm termination to vcc. Single-ended output amplitude control signal with internal 2KOhm termination to vcc. Supply and Termination Voltages Description Pin Number Positive power supply. 2, 4, 6, 8, 10, 12, 14, 16, 17, 18, 20, 22, 24 (+3.3V or 0) Negative power supply. 1, 7, 13, 19 (0V or -3.3V) 21 23 3 5 11 9 15 CML input CML input CML output CML input 3 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER MIN TYP MAX UNIT COMMENTS General Parameters -3.1 -3.3 -3.5 V ±6% vee 0.0 V External ground vcc Ivee 220 mA Power consumption 725 mW Junction temperature -40 25 125 °C HS Input Data (dp/dn) Frequency DC 25 Gbps Swing 0.05 0.8 V Differential or SE, p-p CM Voltage Level vcc-0.8 vcc V Must match for both inputs HS Input Clock (cp/cn) Frequency DC 25 GHz Swing 0.05 0.8 V Differential or SE, p-p CM Voltage Level vcc-0.8 vcc V Must match for both inputs Clock Phase Margin 85 87 89 % HS Output Data (outp/outn) Frequency DC 25 Gbps Logic “1” level V vcc Logic “0” level vcc-1.0 vcc V With external 50Ohm DC termination. Controlled by gc signal Rise/Fall times 18 ps 20%-80% Output Jitter 5 ps Peak-to-peak Gain Control (gc) Control voltage vcc-1.0 vcc V Single-ended PACKAGE INFORMATION The chip die is housed in a custom 24-pin CQFP package shown in Fig. 2. The package provides a center heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this section to be soldered to the vcc plain, which is ground for a negative supply, or power for a positive supply. The part’s identification label is ASNT5014-KMC. The first 8 characters of the name before the dash identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 characters after the dash represent the package’s manufacturer, type, and pin out count. This device complies with the Restriction of Hazardous Substances (RoHS) per 2011/65/EU for all ten substances. Rev. 3.1.2 4 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Fig. 2. CQFP 24-Pin Package Drawing (All Dimensions in mm) Rev. 3.1.2 5 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com REVISION HISTORY Revision Date Changes 3.1.2 05-2020 Updated Package Information 3.0.2 07-2019 Updated Letterhead 3.0.1 02-2013 Revised title Added package pin out drawing Revised functional block diagram Revised description Added power supply configuration Added absolute maximum ratings Revised terminal functions Revised electrical characteristics Added package information and mechanical drawing Format correction 2.0 03-2009 Revised electrical characteristics 1.0 02-2008 First release Rev. 3.1.2 6 May 2020
ASNT5014-KMC 价格&库存
很抱歉,暂时无法提供与“ASNT5014-KMC”相匹配的价格&库存,您可以联系我们找货
