ASNT6164-KMM
ASNT6164-KMM
    ADSANTEC(先进科技)
    CLQFP44
    LINEAR NO-BLOCK CROSS-SWITCH 2X2
ASNT6164-KMM 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Dr., Ste #112, Torrance, CA 90505 Office: (310) 530-9400 Fax: (310) 530-9402 www.adsantec.com ASNT6164-KMM DC-32GHz Linear Non-Blocking Cross-Switch 2x2 DC-to-1GHz broadband channel selector ports  Optional two-channel mixer/adder setting available  Low jitter and limited temperature variation over industrial temperature range  Single +3.6V or -3.6V power supply  Power consumption: 1400mW  Fabricated in SiGe for high performance, yield, and reliability  Custom CQFP 44-pin package vcc  vcc vee 1dB compression point of 0dBm vcc 1n d0p  d0n Temperature-stabilized differential gain of approximately 0dB vcc  n/c Two differential CML-type input ports and two differential CML-type output ports vcc  n/c DC to 32GHz broadband operation vcc  vcc vee vcc vcc on2 q0p vcc vcc sel1 q0n ASNT6164 vcc vcc sel0 q1p vcc vcc ief1c q1n vcc vcc vee Rev. 1.2.2 1 vcc d1n vcc d1p vcc n/c vcc ief3c vcc vee vcc vcc January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Dr., Ste #112, Torrance, CA 90505 Office: (310) 530-9400 Fax: (310) 530-9402 www.adsantec.com DESCRIPTION on2 50 d0p d0n 50 50 q0p q0n 50 ief1c/ief3c 50 d1p d1n 50 50 q1p q1n 50 sel0 sel1 Fig. 1. Functional Block Diagram The temperature stable ASNT6164-KMM linear non-blocking cross-switch 2x2 is intended for use in high-speed systems. The IC shown in Fig. 1 can deliver two different broad-band analog differential signals d0p/d0n and d1p/d1n to two differential outputs q0p/q0n and q1p/q1n with a nominal gain of 0dB. It can also be used as a two-channel analog mixer/adder of signals d0p/d0n and d1p/d1n. Two lowspeed analog current controls Ief1c and Ief3c are available for bandwidth and peaking adjustments. Both controls are very similar and change peaking of the part’s frequency response at high frequencies (above 20GHz). Ief1c has a higher impact on the frequency response and also improves linearity at low control voltages. A relatively flat frequency response can be achieved at lower control voltages but it may be not the best setting for the signal eye. The assignment of inputs to outputs is performed through the external high-speed ports sel1 and sel2 that can be referenced to either vcc or vee. The assignment logic is shown in Table 1. When the low-speed single-ended control port on2 is set to vcc, it switches the circuit into mixer/adder mode with both inputs active at the same time. Table 1. Channel Selection on2 sel1 sel0 Input connected to q0 Input connected to q1 Comments 0 0 0 d0 d0 0 0 1 d1 d0 0 1 0 d0 d1 0 1 1 d1 d1 default state 1 * * d0+d1 d0+d1 Rev. 1.2.2 2 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Dr., Ste #112, Torrance, CA 90505 Office: (310) 530-9400 Fax: (310) 530-9402 www.adsantec.com The part’s I/O’s support the CML logic interface with on chip 50Ohm termination to vcc and may be used differentially, AC/DC coupled, single-ended, or in any combination. In DC-coupling mode, the input signal’s common mode voltage should comply with the specifications shown in the ELECTRICAL CHARACTERISTICS. In AC-coupling mode, the input termination provides the required common mode voltage automatically. POWER SUPPLY CONFIGURATION The part can operate with either negative supply (vcc = 0.0V = ground and vee = −3.6V), or positive supply (vcc = +3.6V and vee = 0.0V = ground). In case of the positive supply, all I/Os need AC termination when connected to any devices with 50Ohm termination to ground. Different PCB layouts will be needed for each different power supply combination. All the characteristics detailed below assume vcc = 0.0V = ground. ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings shown in Table 2 may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground (assumed vcc). Table 2. Absolute Maximum Ratings Parameter Supply Voltage (vee) Power supply current Input Voltage RF Input Voltage Swing (SE) Analog control voltages Case Temperature Storage Temperature Operational Humidity Storage Humidity Rev. 1.2.2 Min vcc-1.2 vee -40 10 10 3 Max -4 320 vcc-0.6 0.6 vcc +90 +100 98 98 Units V mA V V V ºC ºC % % January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Dr., Ste #112, Torrance, CA 90505 Office: (310) 530-9400 Fax: (310) 530-9402 www.adsantec.com TERMINAL FUNCTION TERMINAL Name No. Type d0p d0n d1p d1n q0p q0n q1p q1n 26 28 8 10 21 19 17 15 sel0 sel1 ief1c ief3c 41 39 43 4 on2 Name vcc vee n/c Rev. 1.2.2 CML type CML type CML type CML type DESCRIPTION High-speed Signals Differential high speed data inputs with internal SE 67Ohm termination to vcc and SE 50Ohm termination to virtual ground Differential high speed data outputs with internal SE 50Ohm termination to vcc. Require external SE 50Ohm termination to vcc Control Signals High-speed input with selectable logic levels, (active: high; default: low). For the selection logic see Table 1 Analog current control with internal 64KOhm termination to vcc and 72KOhm termination to vee. Low-speed high-impedance input (active: high, mixer/adder mode; 37 default: low, 1-of-2 selector mode;) Supply and Termination Voltages Description Pin Number Positive power supply rail 1, 3, 5, 7, 9, 11, 12, 14, 16, 18, 20, 22, 23, 25, 27, 29, 31, 33, 34, 36, 38, 40, 42, 44 Negative power supply rail 2, 13, 24, 35 SE SE Analog Control CMOS Not connected pins 6, 30, 32 4 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Dr., Ste #112, Torrance, CA 90505 Office: (310) 530-9400 Fax: (310) 530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER TYP MAX UNIT COMMENTS General Parameters -3.4 -3.6 -3.8 V ±5.5% vee 0.0 V External ground vcc 400 mA In Selector Mode Ivee 600 mA In Mixer/Adder Mode 1400 mW In Selector Mode Power consumption 2100 mW In Mixer/Adder Mode Junction temperature -25 50 125 °C Input Analog (d0p/d0n, d1p/d1n) Bandwidth DC 32 GHz -3dB Common mode level mV vcc Single-ended, with unused input not 0 400 mV connected or AC terminated Voltage swing, pk-pk 0 800 mV Differential -35 dB at 3GHz -16 dB at 10GHz S11 -11 dB at 20GHz -9 dB at 25GHz Current Control Signals (ief1c/ief3c) Control range vee+0.95 vee+1.95 V Default voltage level vee+1.9 V at ±3.6V supply Output Analog (q0p/q0n, q1p/q1n) Bandwidth DC 32 GHz -3dB With external 50Ohm Common mode level vcc-0.55 V DC termination to vcc Small Signal Differential Gain -1.5 0.0 +1.5 dB up to 25GHz Output referred 1dB 1 dBm Single-Ended, 20GHz Compression Point 0.6 % at 1GHz 0.7 % at 10GHz THD 2 % at 25GHz 3.5 % at 35GHz Low-Speed Control (on2) High logic level V Mixer/Adder Mode vcc Low logic level V 1-of-2 Selector Mode vee High-Speed Control (sel0, sel1) Bandwidth 1 GHz High logic level V See Table 1 vcc Low logic level V See Table 1 vee Input current 20 uA sink or source Rev. 1.2.2 MIN 5 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Dr., Ste #112, Torrance, CA 90505 Office: (310) 530-9400 Fax: (310) 530-9402 www.adsantec.com PACKAGE INFORMATION The chip die is housed in a custom 44-pin CQFP package shown in Fig. 2. The package provides a center heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this section to be soldered to the vcc plain, which is ground for a negative supply, or power for a positive supply. Fig. 2. CQFP 44-Pin Package Drawing (All Dimensions in mm) The part’s identification label is ASNT6164-KMM. The first 8 characters of the name before the dash identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 digits after the underscore represent the package’s manufacturer, type, and pin out count. This device complies with the Restriction of Hazardous Substances (RoHS) per 2011/65/EU for all ten substances. Rev. 1.2.2 6 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Dr., Ste #112, Torrance, CA 90505 Office: (310) 530-9400 Fax: (310) 530-9402 www.adsantec.com REVISION HISTORY Revision 1.2.2 1.1.2 Date 01-2020 11-2019 1.0.2 0.2.2 10-2019 08-2019 0.1.2 08-2019 0.0.2 0.0.1 08-2019 01-2019 Rev. 1.2.2 Changes Updated Package Information Corrected range of analog controls Added description of analog controls Added maximum values of analog control voltages Corrected default states in Table 1 Corrected Terminal Functions table Corrected bandwidth Corrected pinout drawing Updated letterhead Preliminary release 7 January 2020
ASNT6164-KMM 价格&库存
很抱歉,暂时无法提供与“ASNT6164-KMM”相匹配的价格&库存,您可以联系我们找货
