ASNT5190-PQC
ASNT5190-PQC
    ADSANTEC(先进科技)
    VFQFN24
    2:1 BROADBAND DIG. DEMULTIPLEXER
ASNT5190-PQC 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT5190-PQC DC-36Gbps Broadband Digital 1:2 Demultiplexer  High speed broadband 1:2 Demultiplexer  Exhibits low jitter and limited temperature variation over industrial temperature range  Ideal for high speed proof-of-concept prototyping  Fully differential CML input interfaces  Fully differential CML output interface with 400mV single-ended swing  Single +3.3V or -3.3V power supply  Power consumption: 495mW  Fabricated in SiGe for high performance, yield, and reliability  Standard MLF/QFN 24-pin package ASNT5190 Rev. 1.1.2 1 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION q0p q0n 50 50 50 50 dp q1p 1:2 DMX Core dn 50 q1n 50 50 50 cp cn Fig. 1. Functional Block Diagram The temperature stable ASNT5190-PQC SiGe IC can be utilized as a high speed 1:2 demultiplexer, and is intended for use in high-speed measurement / test equipment. The IC shown in Fig. 1 can receive a high speed differential data input signal dp/dn and effectively demultiplex it into two high speed differential data output signals q0p/q0n and q1p/q1n by using a high speed differential clock input signal cp/cn. The part’s I/O’s support the CML logic interface with on chip 50Ohm termination to vcc and may be used differentially, AC/DC coupled, single-ended, or in any combination (see also POWER SUPPLY CONFIGURATION). In the DC-coupling mode, the input signal’s common mode voltage should comply with the specifications shown in ELECTRICAL CHARACTERISTICS. In the AC-coupling mode, the input termination provides the required common mode voltage automatically. The differential DC signaling mode is recommended for optimal performance. POWER SUPPLY CONFIGURATION The part can operate with either negative supply (vcc = 0.0V = ground and vee = −3.3V), or positive supply (vcc = +3.3V and vee = 0.0V = ground). In case of the positive supply, all I/Os need AC termination when connected to any devices with 50Ohm termination to ground. Different PCB layouts will be needed for each different power supply combination. Rev. 1.1.2 2 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com All the characteristics detailed below assume vcc = 0.0V and vee = -3.3V. ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground (assumed vcc). Table 1. Absolute Maximum Ratings Parameter Supply Voltage (vee) Power Consumption RF Input Voltage Swing (SE) Case Temperature Storage Temperature Operational Humidity Storage Humidity Min -40 10 10 Max -3.6 0.65 1.0 +90 +100 98 98 Units V W V ºC ºC % % TERMINAL FUNCTIONS TERMINAL Name No. Type dp dn q0p q0n q1p q1n cp cn Name vcc vee Rev. 1.1.2 DESCRIPTION High-Speed I/Os Differential data input signals with internal 50Ohm termination to vcc Differential data output signals with internal 50Ohm termination to vcc Differential data output signals with internal 50Ohm termination to vcc Differential clock input signals with internal 50Ohm termination to vcc Supply and Termination Voltages Description Pin Number Positive power supply 1, 3, 5, 7, 9, 11, 13, 15, 17, 19, 21, 23 (+3.3V or 0) Negative power supply 6, 12, 18, 24 (0V or -3.3V) 20 22 16 14 10 8 2 4 CML input CML output CML output CML input 3 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER vee vcc Ivee Power consumption Junction temperature Data rate Swing CM Voltage Level Frequency Swing CM Voltage Level Duty cycle Data rate Logic “1” level Logic “0” level Rise/Fall times Output Jitter MIN TYP MAX UNIT COMMENTS General Parameters -3.1 -3.3 -3.5 V ±6% 0.0 V External ground 120 150 180 mA 370 495 630 mW -40 25 125 °C HS Input Data (dp/dn) DC 36 Gbps 0.05 1.0 V Differential or SE, p-p vcc-0.8 vcc V Must match for both inputs HS Input Clock (cp/cn) DC 18 GHz 0.05 1.0 V Differential or SE, p-p vcc-0.8 vcc V Must match for both inputs 45 50 55 % HS Output Data (q0p/q0n, q1p/q1n) DC 18 Gbps V vcc vcc-0.4 V With external 50Ohm DC termination 14 18 22 ps 20%-80% 1 ps Peak-to-peak PACKAGE INFORMATION The chip die is housed in a standard 24-pin QFN package shown in Fig. 2. It is recommended that the center heat slug located on the back side of the package is soldered to the vee plain that is ground for the positive supply or power for the negative supply. The part’s identification label is ASNT5190-PQC. The first 8 characters of the name before the dash identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 characters after the dash represent the package’s manufacturer, type, and pin out count. This device complies with the Restriction of Hazardous Substances (RoHS) per 2011/65/EU for all ten substances. Rev. 1.1.2 4 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Fig. 2. QFN 24-Pin Package Drawing (All Dimensions in mm) Rev. 1.1.2 5 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com REVISION HISTORY Revision Date 1.1.2 01-2020 Updated Package Information 1.0.2 07-2019 Updated Letterhead 1.0.1 11-2017 First release Rev. 1.1.2 6 Changes January 2020
ASNT5190-PQC 价格&库存
很抱歉,暂时无法提供与“ASNT5190-PQC”相匹配的价格&库存,您可以联系我们找货
