IW3689-11
IW3689-11
    DIALOGSEMICONDUCTOR(戴乐格)
    SOIC-8
    AC/DC DIGITAL POWER CONTROLLER F
IW3689-11 数据手册
iW3689 AC/DC Digital Power Controller for Single-Stage High Power Factor Dimmable LED Drivers 1 Description The iW3689 is a single-stage, high-performance AC/DC off-line power supply controller for dimmable LED luminaires. It applies advanced digital control technology to detect the dimmer type, enabling it to provide dynamic impedance to interface with the dimmer and to control the LED brightness at the same time. With advanced dimmer detection technology, the iW3689 can operate with most wall dimmers including leading-edge dimmers (R-type or R-L type), trailing-edge dimmers (R-C type), and smart dimmers. In addition, the iW3689’s cycleby-cycle waveform analysis technology allows for fast dimmer transient response. In no-dimmer mode, the iW3689 operates the main power converter that delivers current to the LED load in quasiresonant mode to provide high power efficiency and low electro-magnetic interference (EMI). When there is no dimmer on the line, the iW3689 optimizes the power factor and minimizes the current harmonic distortion to the AC line. The commonly utilized converter topologies for iW3689 are buck-boost and flyback. The iW3689 uses patented PrimAccurate™ primary-side sensing technology to achieve excellent LED current regulation under different AC line and LED load voltages, without using a secondary-side feedback circuit and thus eliminating the need for an opto-coupler. The iW3689 minimizes the external components count by simplifying the EMI filter with Dialog’s EZ-EMI® technology, and by integrating current sink, switching, and VCC charging circuit. Additionally, the iW3689 does not require an auxiliary winding, which eliminates the need for a custom inductor. The digital control loop of the iW3689 maintains stability over all operating conditions without the need for loop compensation components. The iW3689 maintains high performance wide-range dimming and achieves excellent dimmer compatibility with a simple application circuit. 2 Features ●● Isolated/non-isolated off-line 120VAC/230VAC LED driver up to 25W (Note 1) ●● Resonant control to achieve high efficiency (typical >85% without dimmer) ●● Wide line frequency range (from 45Hz to 66Hz) ●● Excellent AC line distortion immunity ensures quality of product under real-life circumstances ●● Meets IEC61000-3-2 current harmonic requirement ●● Over-temperature LED current foldback and shutdown ●● Total harmonic distortion < 20% with PF > 0.92 ●● Excellent dimmer compatibility ●● Tight LED current regulation (±5%) xx Leading-edge dimmer ●● Fast start-up (< 0.5s without dimmer) xx Trailing-edge dimmer ●● Multiple protection features that include: xx Digital smart dimmer xx LED open-circuit and short-circuit protection ●● Wide dimming range of 1% to 100% ●● Intelligent digital control integrates current sink and VCC maintenance function into power switching circuit ●● Advanced IC power management and voltage sensing enables the use of off-the-shelf inductor xx Current sensing resistor open circuit and shortcircuit protection xx Over-current protection 3 Applications ●● Dimmable LED retrofit lamps up to 25W (Note 1) ●● Dimmable LED luminaires up to 25W (Note 1) Product Summary www.dialog-semiconductor.com Rev. 1.11 1 of 6 18-Dec-2018 © 2018 Dialog Semiconductor iW3689 AC/DC Digital Power Controller for Single-Stage High Power Factor Dimmable LED Drivers - N + + L iW3689 1 VIN 2 CFG 3 VCC 4 GND VCB 8 VD 7 VS 6 ISENSE 5 + Figure 3.1 : iW3689 Typical Application Circuit Note 1 : For output power above 12W designs, care should be taken to verify the thermal and reliability constrains on the IC. IC temperature below 120°C is recommended for proper IC operation. Product Summary www.dialog-semiconductor.com Rev. 1.11 2 of 6 18-Dec-2018 © 2018 Dialog Semiconductor iW3689 AC/DC Digital Power Controller for Single-Stage High Power Factor Dimmable LED Drivers 4 Pinout Description iW3689 VCB 8 1 VIN 2 CFG VD 7 3 VCC VS 6 4 GND ISENSE 5 Figure 4.1 : 8-Lead SOIC-8 Package Pin Number Pin Name Type 1 VIN Analog Input Rectified AC line voltage input. 2 CFG Analog Input OTP threshold and dimmer mode configuration on start-up. 3 VCC Power Power supply for control logic. 4 GND Ground Ground. 5 ISENSE Analog Input Current sense. 6 VS Analog Input Source voltage of MOSFET. 7 VD Analog Input Drain voltage of MOSFET. 8 VCB Analog Input Input capacitor voltage after EMI filter. Product Summary www.dialog-semiconductor.com Pin Description Rev. 1.11 3 of 6 18-Dec-2018 © 2018 Dialog Semiconductor iW3689 AC/DC Digital Power Controller for Single-Stage High Power Factor Dimmable LED Drivers 5 Absolute Maximum Ratings Absolute maximum ratings are the parameter values or ranges which can cause permanent damage if exceeded. Parameter Symbol Value Unit VCC -0.3 to 6 V VIN input (pin 1) -0.3 to 6 V CFG input (pin 2) -0.3 to 6 V ISENSE input (pin 5) -0.3 to 6 V VS input (pin 6) -0.3 to 24 V VD input voltage (pin 7) -0.3 to 6 V VCB input voltage (pin 8) -0.3 to 6 V VD input current (pin 7) 750 μA VCB input current (pin 8) 750 μA DC supply voltage range (pin 3) Maximum junction temperature TJMAX 150 °C Operating junction temperature TJOPT -40 to 150 °C Storage temperature TSTG -65 to 150 °C Thermal resistance junction-to-PCB [gnd lead] ψJB 75 °C/W ±2,000 V ±100 mA ESD rating per JEDEC JS-001-2017 Latch-up test per JESD78E Product Summary www.dialog-semiconductor.com Rev. 1.11 4 of 6 18-Dec-2018 © 2018 Dialog Semiconductor iW3689 AC/DC Digital Power Controller for Single-Stage High Power Factor Dimmable LED Drivers 6 Physical Dimensions 8-Lead Small Outline (SOIC) Package D 5 1 4 H e TOP VIEW MIN MAX MIN MAX A 0.053 0.069 1.35 1.75 A1 0.0040 0.010 0.10 0.25 B 0.014 0.019 0.35 0.49 C 0.007 0.010 0.19 0.25 D 0.189 0.197 4.80 5.00 E 0.150 0.157 3.80 4.00 e A1 COPLANARITY 0.10 (0.004) Symbol E 8 Inches A B SEATING PLANE α Millimeters 0.050 BSC 1.27 BSC H 0.228 0.244 5.80 6.20 L 0.016 0.049 0.40 1.25 α 0° 8° L C SIDE VIEWS Compliant to JEDEC Standard MS12F Controlling dimensions are in inches; millimeter dimensions are for reference only This product is RoHS compliant and Halide free. Soldering Temperature Resistance: [a] Package is IPC/JEDEC Std 020D moisture sensitivity level 1 [b] Package exceeds JEDEC Std No. 22-A111 for solder immersion resistance; package can withstand 10 s immersion < 260˚C Dimension D does not include mold flash, protrusions or gate burrs. Mold flash, protrusions or gate burrs shall not exceed 0.15 mm per end. Dimension E1 does not include interlead flash or protrusion. Interlead flash or protrusion shall not exceed 0.25 mm per side. The package top may be smaller than the package bottom. Dimensions D and E1 are determined at the outermost extremes of the plastic body exclusive of mold flash, tie bar burrs, gate burrs and interlead flash, but including any mismatch between the top and bottom of the plastic body. 7 Ordering Information Part Number Options Package Description iW3689-00 120VAC Input SOIC-8 Tape & Reel2 iW3689-01 230VAC Input, Optimized for Higher Power Applications SOIC-8 Tape & Reel2 iW3689-11 230VAC Input, Optimized for Lower Power Applications SOIC-8 Tape & Reel2 iW3689-21 230VAC Input, Optimized for External LED Driver Applications SOIC-8 Tape & Reel2 iW3689-31 230VAC Input, Optimized for Compact Size Applications SOIC-8 Tape & Reel2 Note 2: Tape and reel packing quantity is 2,500/reel. Minimum packing quantity is 2,500. Product Summary www.dialog-semiconductor.com Rev. 1.11 5 of 6 18-Dec-2018 © 2018 Dialog Semiconductor iW3689 AC/DC Digital Power Controller for Single-Stage High Power Factor Dimmable LED Drivers Disclaimer Information in this document is believed to be accurate and reliable. However, Dialog Semiconductor does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information. Dialog Semiconductor furthermore takes no responsibility whatsoever for the content in this document if provided by any information source outside of Dialog Semiconductor. Dialog Semiconductor reserves the right to change without notice the information published in this document, including without limitation the specification and the design of the related semiconductor products, software and applications. Applications, software, and semiconductor products described in this document are for illustrative purposes only. Dialog Semiconductor makes no representation or warranty that such applications, software and semiconductor products will be suitable for the specified use without further testing or modification. Unless otherwise agreed in writing, such testing or modification is the sole responsibility of the customer and Dialog Semiconductor excludes all liability in this respect. Customer notes that nothing in this document may be construed as a license for customer to use the Dialog Semiconductor products, software and applications referred to in this document. Such license must be separately sought by customer with Dialog Semiconductor. All use of Dialog Semiconductor products, software and applications referred to in this document are subject to Dialog Semiconductor’s Standard Terms and Conditions of Sale, available on the company website (www.dialog-semiconductor.com) unless otherwise stated. Dialog and the Dialog logo are trademarks of Dialog Semiconductor plc or its subsidiaries. All other product or service names are the property of their respective owners. © 2018 Dialog Semiconductor. All rights reserved. RoHS Compliance Dialog Semiconductor’s suppliers certify that its products are in compliance with the requirements of Directive 2011/65/EU of the European Parliament on the restriction of the use of certain hazardous substances in electrical and electronic equipment. RoHS certificates from our suppliers are available on request. Contacting Dialog Semiconductor United Kingdom (Headquarters) Dialog Semiconductor (UK) LTD Phone: +44 1793 757700 North America Dialog Semiconductor Inc. Phone: +1 408 845 8500 Hong Kong Dialog Semiconductor Hong Kong Phone: +852 2607 4271 China (Shenzhen) Dialog Semiconductor China Phone: +86 755 2981 3669 Germany Dialog Semiconductor GmbH Phone: +49 7021 805-0 Japan Dialog Semiconductor K. K. Phone: +81 3 5769 5100 Korea Dialog Semiconductor Korea Phone: +82 2 3469 8200 China (Shanghai) Dialog Semiconductor China Phone: +86 21 5424 9058 The Netherlands Dialog Semiconductor B.V. Phone: +31 73 640 8822 Taiwan Dialog Semiconductor Taiwan Phone: +886 281 786 222 Email info_pcbg@diasemi.com Web site: www.dialog-semiconductor.com Product Summary www.dialog-semiconductor.com Rev. 1.11 6 of 6 18-Dec-2018 © 2018 Dialog Semiconductor
IW3689-11 价格&库存
很抱歉,暂时无法提供与“IW3689-11”相匹配的价格&库存,您可以联系我们找货
