IW338-10
IW338-10
    DIALOGSEMICONDUCTOR(戴乐格)
    SOIC-8
    PWM GENERATOR
IW338-10 数据手册
iW338 PWM Generator 1 Description The iW338 is a generic PWM signal generator IC to convert a 0-0.6V analog voltage to an inverted 0%-100% PWM duty cycle. The PWM frequency range is set by an external capacitor and is programmable from 100Hz to 50kHz. The output of the iW338 is a 5V PWM driver capable of driving an external optocoupler for isolated applications or a MOSFET for non-isolated applications. 2 Features ●● 8V to 60V DC input voltage ●● Shutdown pin to minimize standby power ●● 1% PWM duty cycle tolerance ●● SOIC-8 package ●● Programmable PWM frequency range: 100Hz to 50kHz 3 Applications ●● Generic PWM duty cycle generator ●● Signal feedback across isolation barrier 8-60V iW338 PWM Output VCC VIN DRV DIM FLT SD GND CF 0-0.6V Figure 3.1 : iW338 Typical Application Circuit Product Summary www.dialog-semiconductor.com Rev. 1.0 1 of 5 23-Feb-2019 © 2019 Dialog Semiconductor iW338 PWM Generator 4 Pinout Description iW338 1 VIN SD 8 2 GND CF 7 3 VCC FLT 6 4 DRV DIM 5 Figure 4.1 : 8-Lead SOIC Package Pin Number Pin Name Type Pin Description 1 VIN Analog Input 2 GND Ground Ground. 3 VCC Power Power supply for control logic. PWM driver. The DRV output changes duty cycle linearly and inversely proportional to the input of the DIM pin. 100% duty cycle output on the DRV pin corresponds to 0V on the DIM pin and 0% duty cycle corresponds to > 0.6V on the DIM pin. Power supply up to 60V. 4 DRV Output 5 DIM Analog Input Dimming interface connection. 6 FLT Analog Input Dimming signal filter capacitor connection. 7 CF Analog Input Sets the PWM output frequency: 100Hz to 50kHz. 8 SD Analog Input Shuts down the IC if voltage is over 2V. Product Summary www.dialog-semiconductor.com Rev. 1.0 2 of 5 23-Feb-2019 © 2019 Dialog Semiconductor iW338 PWM Generator 5 Absolute Maximum Ratings Absolute maximum ratings are the parameter values or ranges which can cause permanent damage if exceeded. Parameter Symbol Value Units VIN to GND VCC -0.3 to 65 V DIM to GND -0.3 to 5 V DRV, FLT, CF, SD to GND -0.3 to 5 V ±2000 V ESD rating per JEDEC JESD22-A114 Storage temperature range Maximum junction temperature Product Summary www.dialog-semiconductor.com Rev. 1.0 3 of 5 -65 to +150 o C 150 o C 23-Feb-2019 © 2019 Dialog Semiconductor iW338 PWM Generator 6 Physical Dimensions Figure 6.1 : Physical Dimensions of 8-Pin SOIC Package 7 Ordering Information Part Number Options iW338-10 Package Description SOIC-8 Tape & Reel1 Note 1: Tape and reel packing quantity is 2,500/reel. Minimum packing quantity is 2,500. Product Summary www.dialog-semiconductor.com Rev. 1.0 4 of 5 23-Feb-2019 © 2019 Dialog Semiconductor iW338 PWM Generator Disclaimer Information in this document is believed to be accurate and reliable. However, Dialog Semiconductor does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information. Dialog Semiconductor furthermore takes no responsibility whatsoever for the content in this document if provided by any information source outside of Dialog Semiconductor. Dialog Semiconductor reserves the right to change without notice the information published in this document, including without limitation the specification and the design of the related semiconductor products, software and applications. Applications, software, and semiconductor products described in this document are for illustrative purposes only. Dialog Semiconductor makes no representation or warranty that such applications, software and semiconductor products will be suitable for the specified use without further testing or modification. Unless otherwise agreed in writing, such testing or modification is the sole responsibility of the customer and Dialog Semiconductor excludes all liability in this respect. Customer notes that nothing in this document may be construed as a license for customer to use the Dialog Semiconductor products, software and applications referred to in this document. Such license must be separately sought by customer with Dialog Semiconductor. All use of Dialog Semiconductor products, software and applications referred to in this document are subject to Dialog Semiconductor’s Standard Terms and Conditions of Sale, available on the company website (www.dialog-semiconductor.com) unless otherwise stated. Dialog and the Dialog logo are trademarks of Dialog Semiconductor plc or its subsidiaries. All other product or service names are the property of their respective owners. © 2019 Dialog Semiconductor. All rights reserved. RoHS Compliance Dialog Semiconductor’s suppliers certify that its products are in compliance with the requirements of Directive 2011/65/EU of the European Parliament on the restriction of the use of certain hazardous substances in electrical and electronic equipment. RoHS certificates from our suppliers are available on request. Contacting Dialog Semiconductor United Kingdom (Headquarters) Dialog Semiconductor (UK) LTD Phone: +44 1793 757700 North America Dialog Semiconductor Inc. Phone: +1 408 845 8500 Hong Kong Dialog Semiconductor Hong Kong Phone: +852 2607 4271 China (Shenzhen) Dialog Semiconductor China Phone: +86 755 2981 3669 Germany Dialog Semiconductor GmbH Phone: +49 7021 805-0 Japan Dialog Semiconductor K. K. Phone: +81 3 5769 5100 Korea Dialog Semiconductor Korea Phone: +82 2 3469 8200 China (Shanghai) Dialog Semiconductor China Phone: +86 21 5424 9058 The Netherlands Dialog Semiconductor B.V. Phone: +31 73 640 8822 Taiwan Dialog Semiconductor Taiwan Phone: +886 281 786 222 Email info_pcbg@diasemi.com Web site: www.dialog-semiconductor.com Product Summary www.dialog-semiconductor.com Rev. 1.0 5 of 5 23-Feb-2019 © 2019 Dialog Semiconductor
IW338-10 价格&库存
很抱歉,暂时无法提供与“IW338-10”相匹配的价格&库存,您可以联系我们找货
