SPX29150/51/52/53
1.5A Low Dropout Voltage Regulator
FEATURES
■ Adjustable Output Down to 1.25V
■ 1% Output Accuracy
■ Output Current of 1.5A
■ Low Dropout Voltage of 390mV @ 1.5A
■ Extremely Tight Load and Line
Regulation
■ Extremely Fast Transient Response
■ Reverse-Battery Protection
■ Zero Current Shutdown (5 pin version)
■ Error Flag Signal Output for Out of
Regulation State (5 pin version)
■ Standard TO-220 and TO-263
Packages
APPLICATIONS
■ Powering VGA and Sound Cards
■ LCD Monitors
■ USB Power Supplies
■ PowerPC™ Supplies
■ SMPS Post Regulators
■ High-efficiency “Green” Computer
Systems
■ High-efficiency Linear Power Supplies
■ Portable Instrumentation
■ Constant Current Regulators
■ Adjustable Power Supplies
■ Battery Chargers
DESCRIPTION
The SPX29150/51/52/53 are 1.5A, highly accurate voltage regulators with a low dropout
voltage of 390mV (typical) @ 1.5A. These regulators are specifically designed for low voltage applications that require a low dropout voltage and a fast transient response. They are
fully fault protected against over-current, reverse battery, and positive and negative voltage
transients. On-chip trimming adjusts the reference voltage to 1% initial accuracy. Other
features in the 5 pin versions include Enable and Error Flag.
The SPX29150/51/52/53 is offered in 3-pin and 5-pin TO-220 & TO-263 packages. For a 3A
version, refer to the SPX29300 data sheet.
TYPICAL APPLICATION CIRCUITs
VIN
6.8µ F
1 SPX29150 3
2
VOUT
VIN
6.8µ F
10µ F
1 SPX29152 4
2
3
5
ADJ
VOUT
R1 10µ F
GND
R2
Figure 1. Fixed Output Linear Regulator
REV B 06/05/08
Figure 2. Adjustable Output Linear Regulator
SP29150/51/52/53 1.5A Low Dropout Voltage Regulator
1
© Copyright 2008 Exar Corporation
ABSOLUTE MAXIMUM RATINGS
Storage Temperature Range ........................-65°C to +150°C
Operating Junction Temperature Range...... -40°C to +125°C
Input Voltage (Note 7)......................................................16V
ELECTRICAL CHARACTERISTICS
at VIN=VOUT + 1V and IOUT = 10mA, CIN = 6.8µF, COUT = 10µF, TA = 25°C, unless otherwise specified. The Boldface
applies over the junction temperature range. Adjustable versions are set to 5.0V.
SPX29150/51
PARAMETER
CONDITIONS
Typ
Units
Min
Max
1.8V Version
IOUT = 10mA
1.8
1.782
1.818
Output Voltage
V
10mA ≤ IOUT ≤ 1.5A, 2.5V ≤ VIN ≤ 16V
1.8
1.764
1.836
2.5V Version
IOUT = 10mA
2.5
2.475
2.525
Output Voltage
V
10mA ≤�
��IOUT≤�������������
1.5A, 3.5V��
VIN ≤���
16V
2.5
2.450
2.550
3.3V Version
IOUT = 10mA
3.3
3.267
3.333
Output Voltage
V
10mA ≤�
1.5A, 4.3V��
VIN ≤���
16V
3.3
3.234
3.366
5.0V Version
IOUT = 10mA
5.0
4.950
5.050
Output Voltage
V
10mA ≤�
1.5A, 6.0V��
VIN ≤���
16V
5.0
4.900
5.100
All Voltage Options
SPX29150/51/52/53
Line Regulation
IO = 10mA, (VOUT + 1V) ≤��
VIN ≤����
16V
0.1
0.5
VIN = VOUT + 1V, 10mA ≤ IOUT≤ IFULLLoad Regulation
0.2
1
LOAD
∆V
∆T
Dropout Voltage (Note 1)
(except 1.8V version)
Ground Current (Note 3)
IGNDDO Ground Pin Current at Dropout
Current Limit
Output Noise Voltage
(10Hz to 100kHz)
IL = 100mA
Reference Voltage
Output Voltage
Temperature Coefficient
13
100
IO = 100mA
IO = 750mA
IO = 1.5A
IO = 750mA, VIN = VOUT, +1V
IO = 1.5A
VIN = 0.1V less than specified VOUT
IOUT = 10mA
VOUT = 0.0V (Note 2)
CL = 10µF
70
230
390
12
45
200
CL = 33µF
Adjustable version only
260
25
mA
mA
1.7
A
µVRMS
1.240
Reference Voltage
Adjustable version only (Note 8)
Adjust Pin
Bias Current
Reference Voltage Temperature
(Note 4)
Coefficient
Adjust Pin Bias
Current Temperature
Coefficient
Flag Output (Error Comparator) SPX29151/53
40
1.252
1.265
1.277
80
120
V
nA
ppm/°C
0.1
nA/°C
VOH=16V
0.1
Output Low Voltage
Device set for 5V, VIN=4.5V,
IOL=250µA
200
1.228
1.215
1.203
13
Output Leakage Current
Rev B 06/05/08
mV
600
0.9
2.2
400
ppm/°C
1.00
2.00
300
400
UA
mV
ELECTRICAL CHARACTERISTICS cont'd
PARAMETER
CONDITIONS
Typ
SPX29150/51
Min
Max
40
25
Upper Threshold
Voltage
Device set for 5V (Note 5)
60
Lower Threshold
Voltage
75
Hysteresis
15
Units
mV
95
140
mV
mV
ENABLE input
SPX29151/52
Input Logic Voltage
Low (OFF)
High (ON)
Enable Input Pin Input
Current
VIN < 10V
2.4V
VEN=16V
100
VEN=0.8V
Regulator Output Current in Shutdown
Thermal Resistance
(Note 6)
10
TO-220 Junction to Case, at Tab
TO-220 Junction to Ambient
3
30
TO-263 Junction to Case, at Tab
TO-263 Junction to Ambient
3
32
0.8
V
600
750
µA
1
2
µA
500
µA
°C/W
NOTES:
Note 1: Dropout voltage is defined as the input to output differential when the output voltage drops to 99% of its nominal value.
Note 2: VIN = VOUT (NOMINAL) +1V. For example, use VIN = 4.3V for a 3.3V regulator. Employ pulse-testing procedures to minimize temperature rise.
Note 3: Ground pin current is the regulator quiescent current. The total current drawn from the source is the sum of the load current to the ground
current.
Note 4: Thermal regulation is defined as the change in the output voltage at a time T after a change in power dissipation is applied, excluding load or line
regulation effects.
Note 5: Comparator threshold is expressed in terms of a voltage differential at the Adjust terminal below the nominal reference voltage measured 6V
input. To express these thresholds in terms of output voltage change, multiply the error amplifier gain = VOUT/VREF = (R1 + R2)/R2. For example, at
a programmable output voltage of 5V, the Error output is guaranteed to go low when the output drops by 95mVx 5V/ 1.240V = 38mV. Thresholds
remain constant as a percent of VOUT as VOUT is varied, with the dropout warning occurring at typically 5% below nominal, 7.7% guaranteed.
Note 6: VEN ≤ 0.8V and VIN ≤ 16V, VOUT = 0.
Note 7: Maximum positive supply voltage of 20V must be of limited duration (
很抱歉,暂时无法提供与“SPX29151U5-L-3-3”相匹配的价格&库存,您可以联系我们找货
