Advance Information
MCF5485EC/D
Rev. 1.2, 3/2004
MCF548x Integrated
Microprocessor
Hardware Specifications
The MCF548x is a highly-integrated implementation of the ColdFire® family of reduced
instruction set computing (RISC) microprocessors. This document describes pertinent
electrical and physical characteristics of the MCF548x family: the MCF5480, MCF5481,
MCF5482, MCF5483, MCF5484, and MCF5485.
This document contains the following topics:
Topic
Section 1.1, “MCF548x Family Overview”
Section 1.2, “MCF548x Block Diagram”
Section 1.3, “MCF548x Family Products”
Section 1.4, “MCF548x Family Features”
Section 1.5, “Signal Description”
Section 1.6, “Chip Configuration”
Section 1.7, “Design Recommendations”
Section 1.8, “MCF5485/5484 Pinout”
Section 1.9, “MCF5483/5482 Pinout”
Section 1.10, “MCF5481/5480 Pinout”
Section 1.11, “Mechanicals”
Section 1.12, “Ordering Information”
Section 1.13, “Device/Family Documentation List”
Section 1.14, “Document Revision History”
Appendix A, “Preliminary Electrical Characteristics”
Page
1
3
4
5
14
43
45
54
58
62
67
68
68
68
69
To locate any published errata or updates for this document, refer to the web site at
http://motorola.com/semiconductors.
1.1
The MCF548x family is based on the ColdFire V4e core, a complex which comprises the
ColdFire V4 central processor unit (CPU), an enhanced multiply-accumulate unit (EMAC), a
memory management unit (MMU), a double-precision floating point unit (FPU) conforming
to standard IEEE-754, and controllers for caches and local data memories. The MCF548x
family is capable of performing at an operating frequency of up to 200 MHz or 308 MIPS
(Dhrystone 2.1).
PRELIMINARY—SUBJECT TO CHANGE WITHOUT NOTICE
To maximize throughput, the MCF548x family incorporates three independent external bus interfaces:
1. The general-purpose local bus (FlexBus) is used for system boot memories and simple peripherals
and has up to six chip selects.
2. Program code and data can be stored in SDRAM connected to a dedicated 32-bit double data rate
(DDR) bus that can run at up to one half of the CPU core frequency. The glueless DDR SDRAM
controller handles all address multiplexing, input and output strobe timing, and memory bus clock
generation.
3. A 32-bit PCI bus compliant with the version 2.2 specification and running at a typical frequency of
33 MHz or 66 MHz supports peripherals that require high bandwidth, the ability to arbitrate for
bus mastership, and access to internal MCF548x memory resources.
The MCF548x family provides substantial communications functionality by integrating the following
connectivity peripherals:
Up to two 10/100 Mbps fast Ethernet controllers (FECs)
An optional USB 2.0 device (slave) module with seven endpoints and an integrated transceiver
Up to four UART/USART/IRDA/modem programmable serial controllers (PSCs)
A DMA serial peripheral interface (DSPI)
An inter-integrated circuit (I2C™) bus controller
Two controller area network 2.0B (FlexCAN) interfaces with 16 message buffers each
Additionally, the MCF548x provides hardware support for a range of Internet security standards with an
optional bus-mastering cryptography accelerator. This module incorporates units to speed DES/3DES and
AES block ciphers, the RC4 stream cipher, bulk data hashing (MD5/SHA-1/SHA-256/HMAC), and random
number generation. Hardware acceleration of these functions is critical to avoiding the throughput
bottlenecks associated with software-only implementations of SSH, SSL/TLS, IPsec, SRTP, WEP, and other
security standards. The incorporation of cryptography acceleration makes the MCF548x family a
compelling solution for a wide range of office automation, industrial control, and SOHO networking
devices that must have the ability to securely transmit critical equipment control information across
typically insecure Ethernet data networks.
Additional features of MCF548x products include a watchdog timer, two 32-bit slice timers for RTOS
scheduling and alarm functionality, up to four 32-bit general-purpose timers with capture, compare, and
pulse width modulation capability, a multisource vectored interrupt controller, a phase-locked loop (PLL)
to generate the system clock, 32 Kbytes of SRAM for high-speed local data storage, and multiple
general-purpose I/O ports. To manage current consumption, MCF548x products provide chip-wide internal
clock gating control on a per module basis under software control.
With on-chip support for multiple common communications interfaces, MCF548x products require only the
addition of memories and certain physical layer transceivers to be cost-effective system solutions for many
applications, such as industrial routers, high-end POS terminals, building automation systems, and process
control equipment.
MCF548x products require four supply voltages: 1.5V for the high-performance, low power, internal core
logic, 2.5V for the DDR SDRAM bus interface, 1.25V for the DDR SDRAM VREF, and 3.3V for all other
I/O functionality, including the PCI and FlexBus interfaces.
2
MCF548x Integrated Microprocessor Hardware Specifications
MOTOROLA
1.2
Figure 1 shows a top-level block diagram of the MCF548x products.
ColdFire V4e Core
FPU, MMU
EMAC
32K D-cache
32K I-cache
PLL
DDR SDRAM
Interface
FlexBus
Interface
XL Bus
Arbiter
Memory
Controller
FlexBus
Controller
Cryptography
Accelerator***
XL Bus
Read/Write
Write
DMA
DMA
Bus
Read
32K System
SRAM
GP
Timers x 4
PCI 2.2
Controller
Multi-Channel DMA
Master Bus Interface and FIFOs
FlexCAN
x2
PCI Interface
& FIFOs
CommBus
DSPI
I2 C
PSC x 4
FEC1
FEC2**
USB 2.0
DEVICE*
Perpheral Communications I/O Interface & Ports
Communications
I/O Subsystem
Slice
Timers x 2
PCI I/O Interface and Ports
Watchdog
Timer
R/W
Master/Slave
Interface
Crypto
Interrupt
Controller
Slave
Perpheral I/O Interface & Ports
System
Integration Unit
XL Bus
USB 2.0
PHY*
*Available in MCF5485, MCF5484, MCF5483, and MCF5482 devices.
**Available in MCF5485, MCF5484, MCF5481, and MCF5480 devices.
***Available in MCF5485, MCF5483, and MCF5481 devices.
Figure 1. MCF548x Block Diagram
MOTOROLA
3
1.3
Table 1 summarizes the products available within the MCF548x product family. All products are available
in pin-compatible, 388 pin PBGA packaging allowing for ease of mirgration between products within the
family. A printed circuit board designed using the MCF5485/4 footprint is compatible with any of the
MCF548x family devices.
Table 1. MCF548x Family Products
4
Product
Performance
Features
Temperature Range
MCF5485
308 MIPS
200 MHz
Two 10/100 Ethernet Controllers
Two CAN Controllers
USB 2.0 Device with Integrated PHY
v2.2 PCI Controller
DDR Memory Controller
Encryption Accelerator
-40 to 85 ° C
MCF5484
308 MIPS
200 MHz
Two CAN Controllers
v2.2 PCI Controller
-40 to 85 ° C
MCF5483
255 MIPS
166 MHz
One 10/100 Ethernet Controller
Two CAN Controllers
v2.2 PCI Controller
-40 to 85 ° C
MCF5482
255 MIPS
166 MHz
Two CAN Controllers
v2.2 PCI Controller
-40 to 85 ° C
MCF5481
255 MIPS
166 MHz
Two CAN Controllers
v2.2 PCI Controller
-40 to 85 ° C
MCF5480
255 MIPS
166 MHz
Two CAN Controllers
v2.2 PCI Controller
-40 to 85 ° C
MOTOROLA
1.4
ColdFire V4e core
— Limited superscalar V4 ColdFire processor core
— Up to 200 MHz peak internal core frequency (308 Dhrystone 2.1 MIPS)
— Harvard architecture
– 32-Kbyte instruction cache
– 32-Kbyte data cache
— Memory management unit (MMU)
– Separate, 32-entry, fully-associative instruction and data translation lookahead buffers
— Floating point unit (FPU)
– Double-precision support that conforms to IEEE-754 standard
– Eight floating point registers
Internal master bus (XLB) arbiter
— High performance split address and data transactions
— Support for various parking modes
32-bit double data rate (DDR) synchronous DRAM (SDRAM) controller
— 66–133 MHz operation
— Supports both DDR and SDR DRAM
— Built-in initialization and refresh
— Up to four chip selects enabling up to 1 GB of external memory
Version 2.2 peripheral component interconnect (PCI) bus
— 32-bit target and initiator operation
— Support for up to five external PCI masters
— 33–66 MHz operation with PCI bus to XLB divider ratios of 1:1, 1:2, and 1:4
Flexible multifunction external bus (FlexBus)
— Supports operation with the following:
– Non-multiplexed 32-bit address and 32-bit data (32-bit address muxed over
PCI bus–PCI not usable)
– Multiplexed 32-bit address and 32-bit data (PCI usable)
– Multiplexed 32-bit address and 16-bit data
– Multiplexed 32-bit address and 8-bit data
— Provides a glueless interface to boot Flash/ROM, SRAM, and peripheral devices
— Up to six chip selects
Communications I/O subsystem
— Intelligent 16-channel DMA controller
— Dedicated DMA channels for receive and transmit on all subsystem peripheral interfaces
MOTOROLA
5
— Up to two 10/100 Mbps fast Ethernet controllers (FECs), each with separate 2-Kbyte receive
and transmit FIFOs
— Universal serial bus (USB) version 2.0 device controller
– Support for one control and six programmable endpoints — interrupt, bulk, or isochronous
– 4 Kbytes of shared endpoint FIFO RAM and 1 Kbyte of endpoint descriptor RAM
– Integrated physical layer interface
— Up to four programmable serial controllers (PSCs) each with separate 512-byte receive and
transmit FIFOs for UART, USART, modem, codec, and IrDA 1.1 interfaces
— I2C peripheral interface
— Two FlexCAN controller area network 2.0B controllers each with 16 message buffers
— DMA serial peripheral interface (DSPI)
Optional security encryption controller (SEC) module
— Execution units for the following:
DES/3DES block cipher
AES block cipher
RC4 stream cipher
MD5/SHA-1/SHA-256/HMAC hashing
Random number generator compliant with FIPS 140-1 standards for randomness and
non-determinism
— Dual-channel architecture permits single-pass encryption and authentication
32-Kbyte system SRAM
— Arbitration mechanism shares bandwidth between internal bus masters (CPU, cryptography
accelerator, PCI, and DMA)
System integration unit (SIU)
— Interrupt controller
— Watchdog timer
— Two 32-bit slice timers for periodic alarm and interrupt generation
— Up to four 32-bit general-purpose timers with capture, compare, and PWM capability
— General-purpose I/O ports multiplexed with peripheral pins
Debug and test features
— Core debug support via ColdFire background debug mode (BDM) port
— Chip debug support via JTAG/ IEEE 1149.1 test access port
PLL and clock generator
— 30–66.67 MHz input frequency range
Operating Voltages
— 1.5V internal logic
— 2.5V DDR SDRAM bus I/O (1.25V VREF)
— 3.3V PCI, FlexBus, and all other I/O
Estimated power consumption
— DQ) Relative to
DQS (DDR Write Mode) (tQH)
1.0
DD9
Input Data Skew Relative to DQS (Input Setup) (tIS)
DD10
Input Data Hold Relative to DQS (tIH)
DD11
5
6
ns
7
1
ns
8
0.25*SDCLK
+0.5ns
ns
9
DQS falling edge to SDCLK rising (output setup time)
(tDSS)
0.5
ns
DD12
DQS falling edge from SDCLK rising (output hold time)
(tDSH)
0.5
ns
DD13
DQS input read preamble width (tRPRE)
0.9
1.1
SDCLK
DD14
DQS input read postamble width (tRPST)
0.4
0.6
SDCLK
DD15
DQS output write preamble width (tWPRE)
0.25
SDCLK
DD16
DQS output write postamble width (tWPST)
0.4
0.6
SDCLK
1
2
3
4
5
82
The frequency of operation is either 2x or 4x the CLKIN frequency of operation. The MCF548X supports a single
external reference clock (CLKIN). This signal defines the frequency of operation for both FlexBus and PCI, but
SDRAM clock operates at the same frequency as the internal bus clock. Please see the PLL chapter for more
information on setting the SDRAM clock rate.
SDCLK is one memory clock in (ns).
Pulse width high plus pulse width low cannot exceed max clock period.
This specification relates to the required input setup time of today’s DDR memories. SDDATA[31:24] is relative to
SDDQS3, SDDATA[23:16] is relative to SDDQS2, SDDATA[15:8] is relative to SDDQS1, and SDDATA[7:0] is
relative SDDQS0.
MOTOROLA
6
The first data beat will be valid before the first rising edge of SDDQS and after the SDDQS write preamble. The
remaining data beats will be valid for each subsequent SDDQS edge.
7
This specification relates to the required hold time of today’s DDR memories. SDDATA[31:24] is relative to
relative SDDQS0.
8
Data input skew is derived from each SDDQS clock edge. It begins with a SDDQS transition and ends when the last
data line becomes valid. This input skew must include DDR memory output skew and system level board skew (due
to routing or other factors).
9
Data input hold is derived from each SDDQS clock edge. It begins with a SDDQS transition and ends when the first
data line becomes invalid.
DD1
DD2
SDCLK0
DD3
SDCLK1
SDCLK0
SDCLK1
DD5
SDCSn,SDWE,
RAS, CAS
CMD
DD4
SDADDR,
SDBA[1:0]
DD6
ROW
COL
DD7
SDDM
DD8
SDDQS
DD7
SDDATA
WD1 WD2 WD3 WD4
DD8
Figure 33. DDR Write Timing
MOTOROLA
83
DD1
DD2
SDCLK0
DD3
SDCLK1
SDCLK0
SDCLK1
CL=2
DD5
SDCSn,SDWE,
RAS, CAS
CMD
CL=2.5
DD4
SDADDR,
SDBA[1:0]
ROW
COL
DQS Read
Preamble
SDDQS
DD9
DQS Read
Postamble
DD10
SDDATA
WD1 WD2 WD3 WD4
DQS Read
DQS Read
Preamble
Postamble
SDDQS
WD1 WD2 WD3 WD4
SDDATA
Figure 34. DDR Read Timing
A.10 PCI Bus
The PCI bus on the MCF548X is PCI 2.2 compliant. The following timing numbers are mostly from the PCI
2.2 spec. Please refer to the PCI 2.2 spec for a more detailed timing analysis.
Table 32. PCI Timing Specifications
Num
Characteristic
Frequency of Operation
84
Min
Max
Unit
Notes
30
66
Mhz
1
15.15
33.33
ns
2
P1
Clock Period (tCK)
P2
Address, Data, and Command (33< PCI
