HI3-0507A-5
HI3-0507A-5
    L3HARRIS
    DIP28
    DIFFERENTIAL MULTIPLEXER, 1 FUNC
HI3-0507A-5 数据手册
HI-506A, HI-507A, HI-508A, HI-509A ® Data Sheet October 30, 2007 FN3143.6 16-Channel, 8-Channel, Differential 8-Channel and Differential 4-Channel, CMOS Analog MUXs with Active Overvoltage Protection Features The HI-506A, HI-507A, HI-508A and HI-509A are analog multiplexers with active overvoltage protection. Analog input levels may greatly exceed either power supply without damaging the device or disturbing the signal path of other channels. Active protection circuitry assures that signal fidelity is maintained even under fault conditions that would destroy other multiplexers. Analog inputs can withstand constant 70VP-P levels with ±15V supplies. Digital inputs will also sustain continuous faults up to 4V greater than either supply. In addition, signal sources are protected from short circuiting should multiplexer supply loss occur. Each input presents 1kΩ of resistance under this condition. These features make the HI-506A, HI-507A, HI-508A and HI-509A ideal for use in systems where the analog inputs originate from external equipment, or separately powered circuitry. All devices are fabricated with 44V dielectrically isolated CMOS technology. The HI-506A is a single 16-channel multiplexer, the HI-507A is an 8-channel differential multiplexer, the HI-508A is a single 8-channel multiplexer and the HI-509A is a differential 4-channel multiplexer. If input overvoltage protection is not needed the HI-506/507/508/509 multiplexers are recommended. For further information see Application Note AN520. • Maximum Power Supply . . . . . . . . . . . . . . . . . . . . . . 44V 1 • Analog Overvoltage . . . . . . . . . . . . . . . . . . . . . . . . 70VP-P • No Channel Interaction During Overvoltage • Fail Safe with Power Loss (No Latch-Up) • Break-Before-Make Switching • Analog Signal Range . . . . . . . . . . . . . . . . . . . . . . . . ±15V • Access Time. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 500ns • Power Dissipation . . . . . . . . . . . . . . . . . . . . . . . . . 7.5mW • Pb-Free Available (RoHS Compliant) Applications • Data Acquisition Systems • Industrial Controls • Telemetry CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. 1-888-INTERSIL or 1-888-468-3774 | Intersil (and design) is a trademark of Intersil Americas Inc. Copyright © Intersil Americas Inc. 2003, 2004, 2007. All Rights Reserved HI-506A, HI-507A, HI-508A, HI-509A Ordering Information PART NUMBER PART MARKING TEMP. RANGE (°C) PACKAGE PKG. DWG. # HI1-0506A-2 HI1-506A-2 -55 to +125 28 Ld CERDIP F28.6 HI1-0506A-5 HI1-506A-5 0 to +75 28 Ld CERDIP F28.6 HI1-0506A-8 HI1-506A-8 -55 to +125 + 160 Hour Burn-In 28 Ld CERDIP F28.6 HI3-0506A-5 HI3-506A-5 0 to +75 28 Ld PDIP E28.6 HI3-0506A-5Z (Note 1) HI3-506A-5Z 0 to +75 28 Ld PDIP (Note 2) (Pb-free) E28.6 HI3-0507A-5 HI3-507A-5 0 to +75 28 Ld PDIP E28.6 HI3-0507A-5Z (Note 1) HI3-507A-5Z 0 to +75 28 Ld PDIP (Note 2) (Pb-free) E28.6 HI1-0508A-8 HI1-508A-8 -55 to +125 + 160 Hour Burn-In 16 Ld CERDIP F16.3 HI3-0508A-5 HI3-508A-5 0 to +75 16 Ld PDIP E16.3 HI3-0508A-5Z (Note 1) HI3-508A-5Z 0 to +75 16 Ld PDIP (Note 2) (Pb-free) E16.3 HI1-0509A-2 HI1-509A-2 -55 to +125 16 Ld CERDIP F16.3 HI1-0509A-5 HI1-509A-5 0 to +75 16 Ld CERDIP F16.3 HI1-0509A-8 HI1-509A-8 -55 to +125 + 160 Hour Burn-In 16 Ld CERDIP F16.3 HI3-0509A-5 HI3-509A-5 0 to +75 16 Ld PDIP E16.3 HI3-0509A-5Z (Note 1) HI3-509A-5Z 0 to +75 16 Ld PDIP (Note 2) (Pb-free) E16.3 NOTES: 1. These Intersil Pb-free plastic packaged products employ special Pb-free material sets; molding compounds/die attach materials and 100% matte tin plate PLUS ANNEAL - e3 termination finish, which is RoHS compliant and compatible with both SnPb and Pb-free soldering operations. Intersil Pb-free products are MSL classified at Pb-free peak reflow temperatures that meet or exceed the Pb-free requirements of IPC/JEDEC J STD-020. 2. Pb-free PDIPs can be used for through hole wave solder processing only. They are not intended for use in Reflow solder processing applications. 2 FN3143.6 October 30, 2007 HI-506A, HI-507A, HI-508A, HI-509A Pinouts HI-506A (CERDIP, PDIP) TOP VIEW 28 OUT +VSUPPLY 1 HI-507A (PDIP) TOP VIEW +VSUPPLY 1 27 -VSUPPLY NC 3 26 IN 8 NC 3 26 IN 8A IN 16 4 25 IN 7 IN 8B 4 25 IN 7A IN 15 5 24 IN 6 IN 7B 5 24 IN 6A IN 14 6 23 IN 5 IN 6B 6 23 IN 5A IN 13 7 22 IN 4 IN 5B 7 22 IN 4A IN 12 8 21 IN 3 IN 4B 8 21 IN 3A IN 11 9 20 IN 2 IN 3B 9 20 IN 2A IN 10 10 19 IN 1 IN 2B 10 19 IN 1A 18 ENABLE IN 1B 11 18 ENABLE IN 9 11 OUT B 2 28 OUT A NC 2 27 -VSUPPLY GND 12 17 ADDRESS A0 GND 12 17 ADDRESS A0 VREF 13 16 ADDRESS A1 VREF 13 16 ADDRESS A1 ADDRESS A3 14 15 ADDRESS A2 NC 14 15 ADDRESS A2 HI-508A (CERDIP, PDIP) TOP VIEW A0 1 16 A1 ENABLE 2 15 A2 14 GND -VSUPPLY 3 HI-509A (CERDIP, PDIP) TOP VIEW A0 1 ENABLE 2 -VSUPPLY 3 16 A1 15 GND 14 +VSUPPLY IN 1 4 13 +VSUPPLY IN 1A 4 13 IN 1B IN 2 5 12 IN 5 IN 2A 5 12 IN 2B IN 3 6 11 IN 6 IN 3A 6 11 IN 3B IN 4 7 10 IN 7 IN 4A 7 10 IN 4B OUT 8 9 IN 8 OUT A 8 3 9 OUT B FN3143.6 October 30, 2007 HI-506A, HI-507A, HI-508A, HI-509A Truth Tables HI-506A HI-508A A3 A2 A1 A0 EN “ON” CHANNEL A2 A1 A0 EN “ON” CHANNEL X X X X L None X X X L None L L L L H 1 L L L H 1 L L L H H 2 L L H H 2 L L H L H 3 L H L H 3 L L H H H 4 L H H H 4 L H L L H 5 H L L H 5 L H L H H 6 H L H H 6 L H H L H 7 H H L H 7 L H H H H 8 H H H H 8 H L L L H 9 H L L H H 10 H L H L H 11 A1 A0 EN “ON” CHANNEL PAIR H L H H H 12 X X L None H H L L H 13 L L H 1 H H L H H 14 L H H 2 H H H L H 15 H L H 3 H H H H H 16 H H H 4 HI-509A HI-507A A2 A1 A0 EN “ON” CHANNEL PAIR X X X L None L L L H 1 L L H H 2 L H L H 3 L H H H 4 H L L H 5 H L H H 6 H H L H 7 H H H H 8 4 FN3143.6 October 30, 2007 HI-506A, HI-507A, HI-508A, HI-509A Functional Diagrams HI-506A IN 1 HI-507A OUT 1k IN 1A 1k IN 2 IN 8A OUT A 1k 1k OUT B 1k DECODER/ DRIVER IN 1B 1k IN 16 1k DECODER/ DRIVER IN 8B OVERVOLTAGE CLAMP AND SIGNAL ISOLATION 5V REF LEVEL SHIFT OVERVOLTAGE CLAMP AND SIGNAL ISOLATION † † † † † 5V REF † DIGITAL INPUT PROTECTION † VREF A0 A1 A2 A3 EN † DIGITAL INPUT VREF A0 PROTECTION HI-508A IN 1 LEVEL SHIFT † † † A1 A2 EN HI-509A OUT 1k IN 1A 1k IN 2 IN 4A OUT A 1k 1k OUT B 1k DECODER/ DRIVER IN 1B 1k IN 8 1k DECODER/ DRIVER IN 4B OVERVOLTAGE CLAMP AND SIGNAL ISOLATION 5V REF LEVEL SHIFT † † † † A0 A1 A2 EN OVERVOLTAGE CLAMP AND SIGNAL ISOLATION † DIGITAL INPUT PROTECTION † DIGITAL INPUT PROTECTION 5 5V REF LEVEL SHIFT † † † A0 A1 EN FN3143.6 October 30, 2007 HI-506A, HI-507A, HI-508A, HI-509A Schematic Diagrams ADDRESS INPUT BUFFER AND LEVEL SHIFTER TTL REFERENCE CIRCUIT V+ R10 R9 Q1 VREF Q4 D3 GND LEVEL SHIFTER V+ OVERVOLTAGE PROTECTION P P P N R2 P P P P R5 V+ P LEVEL SHIFTED ADDRESS TO DECODE R7 R6 N D1 P R4 R3 D2 R1 200 Ω P N N R8 N N N N N N V- V- GND ADD IN ADDRESS DECODER V+ P P P P A0 OR A0 A1 OR A1 A2 OR A2 A3 OR A3 P P P N N N TO P-CHANNEL DEVICE OF THE SWITCH N N TO N-CHANNEL DEVICE OF THE SWITCH N N ENABLE DELETE A3 OR A3 INPUT FOR HI-507A, HI-508A, HI-509A DELETE A2 OR A2 INPUT FOR HI-509A 6 V- FN3143.6 October 30, 2007 HI-506A, HI-507A, HI-508A, HI-509A Schematic Diagrams (Continued) MULTIPLEX SWITCH FROM DECODE OVERVOLTAGE PROTECTION N V+ Q5 P R11 1k D7 D6 D4 D5 N IN OUT N Q6 VP FROM DECODE 7 FN3143.6 October 30, 2007 HI-506A, HI-507A, HI-508A, HI-509A Absolute Maximum Ratings Thermal Information V+ to V- . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .+44V V+ to GND . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .+22V V- to GND. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -25V Digital Input Voltage (VEN , VA) . . . . . . . . . . . . . (V-) -4V to (V+) +4V or 20mA, Whichever Occurs First Analog Signal (VIN, VOUT) . . . . . . . . . . . . . . (V-) -20V to (V+) +20V Continuous Current, IN or OUT . . . . . . . . . . . . . . . . . . . . . . . . 20mA Peak Current, IN or OUT, Pulsed 1ms, 10% Duty Cycle (Max) . . 40mA Thermal Resistance (Typical, Note 3) θJA (°C/W) θJC (°C/W) 28 Ld CERDIP Package. . . . . . . . . . . . 55 18 16 Ld CERDIP Package. . . . . . . . . . . . 75 22 28 Ld PDIP Package . . . . . . . . . . . . . . 60 N/A 16 Ld PDIP Package . . . . . . . . . . . . . . 90 N/A Maximum Junction Temperature CERDIP Packages. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . +175°C PDIP Packages . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . +150°C Maximum Storage Temperature Range . . . . . . . . . .-65°C to +150°C Pb-free reflow profile . . . . . . . . . . . . . . . . . . . . . . . . . .see link below http://www.intersil.com/pbfree/Pb-FreeReflow.asp Operating Conditions Temperature Ranges HI-506A/507A/508A/509A-2, -8 . . . . . . . . . . . . . .-55°C to +125°C HI-506A/507A/508A/509A-5. . . . . . . . . . . . . . . . . . . 0°C to +75°C CAUTION: Do not operate at or near the maximum ratings listed for extended periods of time. Exposure to such conditions may adversely impact product reliability and result in failures not covered by warranty. NOTE: 3. θJA is measured with the component mounted on an evaluation PC board in free air. Electrical Specifications Supplies = +15V, -15V; VREF Pin = Open; VAH (Logic Level High) = 4V; VAL (Logic Level Low) = 0.8V, Unless Otherwise Specified. For Test Conditions, Consult Test Circuits Section. -2, -8 TEST CONDITIONS PARAMETER TEMP (°C) -5 MIN MAX MIN MAX (Note 12) TYP (Note 12) (Note 12) TYP (Note 12) UNITS DYNAMIC CHARACTERISTICS Access Time, tA Note 4 Break-Before-Make Delay, tOPEN Note 4 Enable Delay (ON), tON(EN) Note 4 25 - 0.5 - - 0.5 - μs Full - - 1.0 - - 1.0 μs 25 25 80 - 25 80 - ns 25 - 300 500 - 300 - ns Full - - 1000 - - 1000 ns 25 - 300 500 - 300 - ns Full - - 1000 - - 1000 ns To 0.1% 25 - 1.2 - - 1.2 - μs To 0.01% 25 - 3.5 - - 3.5 - μs To 0.1% 25 - 1.2 - - 1.2 - μs To 0.01% 25 - 3.5 - - 3.5 - μs Note 9 25 - 68 - - 68 - dB 25 - 10 - - 10 - pF HI-506A 25 - 52 - - 52 - pF HI-507A 25 - 30 - - 30 - pF HI-508A 25 - 25 - - 25 - pF Note 4 Enable Delay (OFF), tOFF(EN) Settling Time, tS HI-506A and HI-507A HI-508A and HI-509A Off Isolation Channel Input Capacitance, CS(OFF) Channel Output Capacitance, CD(OFF) HI-509A 25 - 12 - - 12 - pF Digital Input Capacitance, CA 25 - 10 - - 10 - pF Input to Output Capacitance, CDS(OFF) 25 - 0.1 - - 0.1 - pF DIGITAL INPUT CHARACTERISTICS Input Low Threshold, TTL Drive, VAL Note 4 Full - - 0.8 - - 0.8 V Input High Threshold, VAH (Note 11) Note 4 Full 4.0 - - 4.0 - - V 8 FN3143.6 October 30, 2007 HI-506A, HI-507A, HI-508A, HI-509A Electrical Specifications Supplies = +15V, -15V; VREF Pin = Open; VAH (Logic Level High) = 4V; VAL (Logic Level Low) = 0.8V, Unless Otherwise Specified. For Test Conditions, Consult Test Circuits Section. (Continued) -2, -8 TEST CONDITIONS PARAMETER TEMP (°C) -5 MIN MAX MIN MAX (Note 12) TYP (Note 12) (Note 12) TYP (Note 12) UNITS Input Leakage Current (High or Low), IA Notes 4, 8 Full - - 1.0 - - 1.0 μA MOS Drive, VAL , HI-506A/HI-507A VREF = +10V 25 - - 0.8 - - 0.8 V MOS Drive, VAH , HI-506A/HI-507A VREF = +10V 25 6.0 - - 6.0 - - V Analog Signal Range, VIN Note 4 Full -15 - +15 -15 - +15 V On Resistance, rON Notes 4, 5 25 - 1.2 1.5 - 1.5 1.8 kΩ Full - 1.5 1.8 - 1.8 2.0 kΩ 25 - 0.03 - - 0.03 - nA Full - - 50 - - 50 nA 25 - 0.1 - - 0.1 - nA HI-506A Full - - 300 - - 300 nA HI-507A Full - - 200 - - 200 nA HI-508A Full - - 200 - - 200 nA HI-509A Full - - 100 - - 100 nA 25 - 4.0 - - 4.0 - nA ANALOG CHANNEL CHARACTERISTICS Off Input Leakage Current, IS(OFF) Off Output Leakage Current, ID(OFF) Notes 4, 6 Notes 4, 6 ID(OFF) With Input Overvoltage Applied Note 7 On Channel Leakage Current, ID(ON) Notes 4, 6 Full - - 2.0 - - - μA 25 - 0.1 - - 0.1 - nA HI-506A Full - - 300 - - 300 nA HI-507A Full - - 200 - - 200 nA HI-508A Full - - 200 - - 200 nA Full - - 100 - - 100 nA Full - - 50 - - 50 nA HI-509A Differential Off Output Leakage Current, IDIFF, (HI-507A, HI-509A Only) POWER SUPPLY CHARACTERISTICS Current, I+ Notes 4, 10 Full - 0.5 2.0 - 0.5 2.0 mA Current, I- Notes 4, 10 Full - 0.02 1.0 - 0.02 1.0 mA Full - 7.5 - - 7.5 - mW Power Dissipation, PD NOTES: 4. 100% tested for Dash 8. Leakage currents not tested at -55°C. 5. VOUT = ±10V, IOUT = +100μA. 6. 10nA is the practical lower limit for high speed measurement in the production test environment. 7. Analog Overvoltage = ±33V. 8. Digital input leakage is primarily due to the clamp diodes (see Schematic). Typical leakage is less than 1nA at +25°C. 9. VEN = 0.8V, RL = 1k, CL = 15pF, VS = 7VRMS , f = 100kHz. 10. VEN , VA = 0V or 4V. 11. To drive from DTL/TTL Circuits, 1kΩ pull-up resistors to +5V supply are recommended. 12. Parts are 100% tested at +25°C. Over-temperature limits established by characterization and are not production tested. 9 FN3143.6 October 30, 2007 HI-506A, HI-507A, HI-508A, HI-509A Test Circuits and Waveforms TA = +25°C, VSUPPLY = ±15V, VAH = 4V, VAL = 0.8V, VREF = Open, Unless Otherwise Specified 100μA V2 IN OUT VIN rON = V2 100μA FIGURE 1A. TEST CIRCUIT +125°C 1.2 1.1 +25°C 1.0 -55°C 0.9 0.8 0.7 0.6 -10 -55°C TO +125°C VIN = +5V 1.5 1.4 1.3 1.2 1.1 1.0 0.9 0.8 -8 -6 -4 -2 0 2 4 ANALOG INPUT (V) 6 8 10 5 6 7 8 9 10 11 12 13 14 15 SUPPLY VOLTAGE (±V) FIGURE 1B. ON RESISTANCE vs ANALOG INPUT VOLTAGE FIGURE 1C. NORMALIZED ON RESISTANCE vs SUPPLY VOLTAGE FIGURE 1. ON RESISTANCE 100nA LEAKAGE CURRENT 10nA ON LEAKAGE CURRENT ID(ON) OFF OUTPUT CURRENT ID(OFF) +0.8V EN OUT 1nA A 10pA ±10V OFF INPUT LEAKAGE CURRENT IS(OFF) 100pA 25 50 75 100 ID(OFF) ± ON RESISTANCE (kΩ) 1.3 NORMALIZED RESISTANCE (REFERRED TO VALUE AT ±15V) 1.4 10V 125 TEMPERATURE (°C) FIGURE 2A. LEAKAGE CURRENT vs TEMPERATURE 10 FIGURE 2B. ID(OFF) TEST CIRCUIT (NOTE 13) FN3143.6 October 30, 2007 HI-506A, HI-507A, HI-508A, HI-509A Test Circuits and Waveforms TA = +25°C, VSUPPLY = ±15V, VAH = 4V, VAL = 0.8V, VREF = Open, Unless Otherwise Specified (Continued) OUT OUT A IS(OFF) A +0.8V EN A0 ± ±10V A1 ID(ON) EN ±10V 10V 10V ± 4V FIGURE 2C. IS(OFF) TEST CIRCUIT (NOTE 13) FIGURE 2D. ID(On) TEST CIRCUIT (NOTE 13) NOTE: 13. Two measurements per channel: ±10V and +10V. (Two measurements per device for ID(OFF) ±10V and +10V.) FIGURE 2. LEAKAGE CURRENTS ANALOG INPUT CURRENT (mA) 18 6 ANALOG INPUT CURRENT (IIN) 15 5 12 4 9 3 6 2 OUTPUT OFF LEAKAGE CURRENT ID(OFF) 3 1 0 OUTPUT OFF LEAKAGE CURRENT (nA) 7 A A IIN ID(OFF) ±VIN 0 15 18 21 24 27 30 33 36 ANALOG INPUT OVERVOLTAGE (±V) FIGURE 3A. ANALOG INPUT OVERVOLTAGE CHARACTERISTICS FIGURE 3B. TEST CIRCUIT FIGURE 3. ANALOG INPUT OVERVOLTAGE CHARACTERISTICS ±14 -55°C +25°C SWITCH CURRENT (mA) ±12 ±10 +125°C ±8 ±6 ±VIN ±4 A ±2 0 0 2 4 6 8 10 12 14 VOLTAGE ACROSS SWITCH (±V) FIGURE 4A. ON CHANNEL CURRENT vs VOLTAGE FIGURE 4B. TEST CIRCUIT FIGURE 4. ON CHANNEL CURRENT 11 FN3143.6 October 30, 2007 HI-506A, HI-507A, HI-508A, HI-509A Test Circuits and Waveforms TA = +25°C, VSUPPLY = ±15V, VAH = 4V, VAL = 0.8V, VREF = Open, Unless Otherwise Specified (Continued) +15V/+10V 8 +ISUPPLY V+ 6 VA 50Ω VSUPPLY = ±10V 2 HI-506A† A1 IN 2 THRU IN 7/IN 15 A0 IN 8/IN 16 EN +4V GND 0 1k 10k 100k TOGGLE FREQUENCY (Hz) 1M ± A2 VSUPPLY = ±15V 4 ±10V/±5V IN 1 A3 OUT V- 10V/ 10 MΩ ± SUPPLY CURRENT (mA) A 5V 14 pF A -ISUPPLY 10M -15V/-10V FIGURE 5A. SUPPLY CURRENT vs TOGGLE FREQUENCY † Similar connection for HI-507A/HI-508A/HI-509A FIGURE 5B. TEST CIRCUIT FIGURE 5. DYNAMIC SUPPLY CURRENT +15V 900 ACCESS TIME (ns) VREF A3 700 A2 VA 600 50Ω A1 HI-506A† 10V IN 16 EN +4V GND 400 ±10V IN 2 THRU IN 7/IN 15 A0 500 V+ IN 1 ± VREF = OPEN FOR LOGIC HIGH LEVEL ≤ 6V VREF = LOGIC HIGH FOR LOGIC HIGH LEVELS > 6V 800 OUT V- 10 kΩ 50 pF 300 3 4 5 6 7 8 9 10 11 12 LOGIC LEVEL (HIGH) (V) 13 14 FIGURE 6A. ACCESS TIME vs LOGIC LEVEL (HIGH) 15 -15V † Similar connection for HI-507A/HI-580A/HI-509A FIGURE 6B. TEST CIRCUIT VAH = 4.0V VA INPUT 2V/DIV. ADDRESS DRIVE (VA) S1 ON 1/ V 2 AH 0V +10V OUTPUT 5V/DIV. OUTPUT 10% -10V S16 ON tA 200ns/DIV. FIGURE 6C. MEASUREMENT POINTS FIGURE 6D. WAVEFORMS FIGURE 6. ACCESS TIME 12 FN3143.6 October 30, 2007 HI-506A, HI-507A, HI-508A, HI-509A Test Circuits and Waveforms A3 TA = +25°C, VSUPPLY = ±15V, VAH = 4V, VAL = 0.8V, VREF = Open, Unless Otherwise Specified (Continued) HI-506A † A2 +5V IN 1 VAH = 4.0V IN 2 THRU VA 50Ω +4.0V A1 IN 7/IN 15 A0 IN 8/IN 16 EN OUT GND ADDRESS DRIVE (VA) 0V VOUT OUTPUT 1kΩ 50pF 50% 50% tOPEN † Similar connection for HI-507A/HI-508A/HI-509A FIGURE 7B. MEASUREMENT POINTS FIGURE 7A. TEST CIRCUIT VA INPUT 2V/DIV. S1 ON S16 ON OUTPUT 0.5V/DIV. 100ns/DIV. FIGURE 7C. WAVEFORMS FIGURE 7. BREAK-BEFORE-MAKE DELAY 13 FN3143.6 October 30, 2007 HI-506A, HI-507A, HI-508A, HI-509A Test Circuits and Waveforms A3 TA = +25°C, VSUPPLY = ±15V, VAH = 4V, VAL = 0.8V, VREF = Open, Unless Otherwise Specified (Continued) HI-506A † A2 IN 1 A1 IN 2 THRU IN 7/IN 15 IN 8 /IN 16 +10V VAH = 4.0V 50% 50% ENABLE DRIVE (VA) 0V A0 EN VA 50Ω VOUT OUT GND 1kΩ 90% OUTPUT 10% 0V 50pF tON(EN) tOFF(EN) † Similar connection for HI-507A//HI-508A/HI-509A FIGURE 8B. MEASUREMENT POINTS FIGURE 8A. TEST CIRCUIT ENABLE DRIVE 2V/DIV. DISABLED ENABLED (S1 ON) OUTPUT 2V/DIV. 100ns/DIV. FIGURE 8C. WAVEFORMS FIGURE 8. ENABLE DELAYS 14 FN3143.6 October 30, 2007 HI-506A, HI-507A, HI-508A, HI-509A Die Characteristics DIE DIMENSIONS: WORST CASE CURRENT DENSITY: 1.4 x 105 A/cm2 159 mils x 83.9 mils TRANSISTOR COUNT: METALLIZATION: 485 Type: CuAl Thickness: 16kÅ ±2kÅ PROCESS: SUBSTRATE POTENTIAL (NOTE): CMOS-DI -VSUPPLY PASSIVATION: Silox: 12kÅ ±2kÅ Nitride: 3.5kÅ ±1kÅ NOTE: The substrate appears resistive to the -VSUPPLY terminal, therefore it may be left floating (Insulating Die Mount) or it may be mounted on a conductor at -VSUPPLY potential. Metallization Mask Layouts HI-506A EN (18) A0 (17) A1 A2 (16) (15) HI-507A A3 VREF (14) (13) GND (12) EN (18) A0 (17) A1 A2 (16) (15) NC VREF (14) (13) GND (12) IN 1 (19) IN 9 (11) IN 1A (19) IN 2 (20) IN 10 (10) IN 2A (20) IN 3 (21) IN 11 (9) IN 3A (21) IN 3B (9) IN 4 (22) IN 12 (8) IN 4A (22) IN 4B (8) IN 5 (23) IN 6 (24) IN 13 (7) IN 14 (6) IN 5A (23) IN 6A (24) IN 5B (7) IN 6B (6) IN 7 (25) IN 15 (5) IN 7A (25) IN 7B (5) IN 8 (26) IN 16 (4) IN 8A (26) IN 8B (4) V- (27) OUT (28) +V (1) 15 NC (2) V- (27) IN 1B (11) IN 2B (10) OUT A (28) +V (1) OUT B(2) FN3143.6 October 30, 2007 HI-506A, HI-507A, HI-508A, HI-509A Die Characteristics DIE DIMENSIONS: WORST CASE CURRENT DENSITY: 1.4 x 105 A/cm2 108 mils x 83 mils TRANSISTOR COUNT: METALLIZATION: 253 Type: CuAl Thickness: 16kÅ ±2kÅ PROCESS: SUBSTRATE POTENTIAL (NOTE): CMOS-DI -VSUPPLY PASSIVATION: Silox: 12kÅ ±2kÅ Nitride: 3.5kÅ ±1kÅ NOTE: The substrate appears resistive to the -VSUPPLY terminal, therefore it may be left floating (Insulating Die Mount) or it may be mounted on a conductor at -VSUPPLY potential. Metallization Mask Layouts HI-508A IN 6 (11) IN 7 IN 8 (10) (9) HI-509A OUT (8) IN 4 IN 3 (7) (6) IN 3B IN 4B OUT B (11) (10) (9) OUT A (8) IN 4A IN 3A (7) (6) IN 5 (12) IN 2 (5) IN 2B (12) IN 2A (5) +V (13) IN 1 (4) IN 1B (13) IN 1A (4) GND (14) -V (3) +V (14) -V (3) A2 (15) A1 (16) A0 (1) 16 EN (2) GND (15) A1 (16) A0 (1) EN (2) FN3143.6 October 30, 2007 HI-506A, HI-507A, HI-508A, HI-509A Ceramic Dual-In-Line Frit Seal Packages (CERDIP) F28.6 MIL-STD-1835 GDIP1-T28 (D-10, CONFIGURATION A) 28 LEAD CERAMIC DUAL-IN-LINE FRIT SEAL PACKAGE LEAD FINISH c1 -D- -A- BASE METAL E M -Bbbb S C A-B S -C- S1 0.232 - 5.92 - 0.026 0.36 0.66 2 b1 0.014 0.023 0.36 0.58 3 b2 0.045 0.065 1.14 1.65 - b3 0.023 0.045 0.58 1.14 4 c 0.008 0.018 0.20 0.46 2 c1 0.008 0.015 0.20 0.38 3 D - 1.490 - 37.85 5 E 0.500 0.610 15.49 5 eA ccc M C A-B S e eA/2 c aaa M C A - B S D S D S NOTES - b2 b MAX 0.014 α A A MIN b A L MILLIMETERS MAX A Q SEATING PLANE MIN M (b) D BASE PLANE SYMBOL b1 SECTION A-A D S INCHES (c) NOTES: 1. Index area: A notch or a pin one identification mark shall be located adjacent to pin one and shall be located within the shaded area shown. The manufacturer’s identification shall not be used as a pin one identification mark. e 12.70 0.100 BSC 2.54 BSC - eA 0.600 BSC 15.24 BSC - eA/2 0.300 BSC 7.62 BSC - L 0.125 0.200 3.18 5.08 - Q 0.015 0.060 0.38 1.52 6 S1 0.005 - 0.13 - 7 105o 90o 105o - 2. The maximum limits of lead dimensions b and c or M shall be measured at the centroid of the finished lead surfaces, when solder dip or tin plate lead finish is applied. α 90o aaa - 0.015 - 0.38 - bbb - 0.030 - 0.76 - 3. Dimensions b1 and c1 apply to lead base metal only. Dimension M applies to lead plating and finish thickness. ccc - 0.010 - 0.25 - M - 0.0015 - 0.038 2, 3 4. Corner leads (1, N, N/2, and N/2+1) may be configured with a partial lead paddle. For this configuration dimension b3 replaces dimension b2. 5. This dimension allows for off-center lid, meniscus, and glass overrun. N 28 28 8 Rev. 0 4/94 6. Dimension Q shall be measured from the seating plane to the base plane. 7. Measure dimension S1 at all four corners. 8. N is the maximum number of terminal positions. 9. Dimensioning and tolerancing per ANSI Y14.5M - 1982. 10. Controlling dimension: INCH. 17 FN3143.6 October 30, 2007 HI-506A, HI-507A, HI-508A, HI-509A Dual-In-Line Plastic Packages (PDIP) E28.6 (JEDEC MS-011-AB ISSUE B) N 28 LEAD DUAL-IN-LINE PLASTIC PACKAGE E1 INDEX AREA 1 2 3 INCHES N/2 SYMBOL -B- -C- A2 SEATING PLANE e B1 D1 A1 eC B 0.010 (0.25) M C A B S MAX NOTES - 0.250 - 6.35 4 0.015 - 0.39 - 4 A2 0.125 0.195 3.18 4.95 - B 0.014 0.022 0.356 0.558 - C L B1 0.030 0.070 0.77 1.77 8 eA C 0.008 0.015 0.204 0.381 - A L D1 MIN A E BASE PLANE MAX A1 -AD MILLIMETERS MIN C eB NOTES: 1. Controlling Dimensions: INCH. In case of conflict between English and Metric dimensions, the inch dimensions control. 2. Dimensioning and tolerancing per ANSI Y14.5M-1982. D 1.380 1.565 D1 0.005 - 35.1 0.13 39.7 5 - 5 E 0.600 0.625 15.24 15.87 6 E1 0.485 0.580 12.32 14.73 5 e 0.100 BSC 2.54 BSC - eA 0.600 BSC 15.24 BSC 6 3. Symbols are defined in the “MO Series Symbol List” in Section 2.2 of Publication No. 95. eB - 0.700 - 17.78 7 L 0.115 0.200 2.93 5.08 4 4. Dimensions A, A1 and L are measured with the package seated in JEDEC seating plane gauge GS-3. N 5. D, D1, and E1 dimensions do not include mold flash or protrusions. Mold flash or protrusions shall not exceed 0.010 inch (0.25mm). 6. E and eA are measured with the leads constrained to be perpendicular to datum -C- . 28 28 9 Rev. 1 12/00 7. eB and eC are measured at the lead tips with the leads unconstrained. eC must be zero or greater. 8. B1 maximum dimensions do not include dambar protrusions. Dambar protrusions shall not exceed 0.010 inch (0.25mm). 9. N is the maximum number of terminal positions. 10. Corner leads (1, N, N/2 and N/2 + 1) for E8.3, E16.3, E18.3, E28.3, E42.6 will have a B1 dimension of 0.030 - 0.045 inch (0.76 - 1.14mm). 18 FN3143.6 October 30, 2007 HI-506A, HI-507A, HI-508A, HI-509A Ceramic Dual-In-Line Frit Seal Packages (CERDIP) F16.3 MIL-STD-1835 GDIP1-T16 (D-2, CONFIGURATION A) 16 LEAD CERAMIC DUAL-IN-LINE FRIT SEAL PACKAGE LEAD FINISH c1 -D- -A- BASE METAL E M -Bbbb S C A-B S -C- S1 0.200 - 5.08 - 0.026 0.36 0.66 2 b1 0.014 0.023 0.36 0.58 3 b2 0.045 0.065 1.14 1.65 - b3 0.023 0.045 0.58 1.14 4 c 0.008 0.018 0.20 0.46 2 c1 0.008 0.015 0.20 0.38 3 D - 0.840 - 21.34 5 E 0.220 0.310 5.59 7.87 5 eA ccc M C A-B S e eA/2 c aaa M C A - B S D S D S NOTES - b2 b MAX 0.014 α A A MIN b A L MILLIMETERS MAX A Q SEATING PLANE MIN M (b) D BASE PLANE SYMBOL b1 SECTION A-A D S INCHES (c) NOTES: 1. Index area: A notch or a pin one identification mark shall be located adjacent to pin one and shall be located within the shaded area shown. The manufacturer’s identification shall not be used as a pin one identification mark. e 0.100 BSC 2.54 BSC - eA 0.300 BSC 7.62 BSC - eA/2 0.150 BSC 3.81 BSC - L 0.125 0.200 3.18 5.08 - Q 0.015 0.060 0.38 1.52 6 S1 0.005 - 0.13 - 7 105o 90o 105o - 2. The maximum limits of lead dimensions b and c or M shall be measured at the centroid of the finished lead surfaces, when solder dip or tin plate lead finish is applied. α 90o aaa - 0.015 - 0.38 - 3. Dimensions b1 and c1 apply to lead base metal only. Dimension M applies to lead plating and finish thickness. bbb - 0.030 - 0.76 - ccc - 0.010 - 0.25 - M - 0.0015 - 0.038 2, 3 4. Corner leads (1, N, N/2, and N/2+1) may be configured with a partial lead paddle. For this configuration dimension b3 replaces dimension b2. 5. This dimension allows for off-center lid, meniscus, and glass overrun. N 16 16 8 Rev. 0 4/94 6. Dimension Q shall be measured from the seating plane to the base plane. 7. Measure dimension S1 at all four corners. 8. N is the maximum number of terminal positions. 9. Dimensioning and tolerancing per ANSI Y14.5M - 1982. 10. Controlling dimension: INCH. 19 FN3143.6 October 30, 2007 HI-506A, HI-507A, HI-508A, HI-509A Dual-In-Line Plastic Packages (PDIP) E16.3 (JEDEC MS-001-BB ISSUE D) N 16 LEAD DUAL-IN-LINE PLASTIC PACKAGE E1 INDEX AREA 1 2 3 INCHES N/2 -B- -AE D BASE PLANE -C- SEATING PLANE A2 A L D1 e B1 D1 A1 eC B 0.010 (0.25) M C A B S MILLIMETERS SYMBOL MIN MAX MIN MAX NOTES A - 0.210 - 5.33 4 A1 0.015 - 0.39 - 4 A2 0.115 0.195 2.93 4.95 - B 0.014 0.022 0.356 0.558 - C L B1 0.045 0.070 1.15 1.77 8, 10 eA C 0.008 0.014 C D 0.735 0.775 eB NOTES: 1. Controlling Dimensions: INCH. In case of conflict between English and Metric dimensions, the inch dimensions control. 0.204 0.355 18.66 19.68 5 D1 0.005 - 0.13 - 5 E 0.300 0.325 7.62 8.25 6 E1 0.240 0.280 6.10 7.11 5 e 0.100 BSC 2. Dimensioning and tolerancing per ANSI Y14.5M-1982. eA 0.300 BSC 3. Symbols are defined in the “MO Series Symbol List” in Section 2.2 of Publication No. 95. eB - 4. Dimensions A, A1 and L are measured with the package seated in JEDEC seating plane gauge GS-3. L 0.115 N 2.54 BSC - 7.62 BSC 0.430 - 0.150 2.93 16 6 10.92 7 3.81 4 16 5. D, D1, and E1 dimensions do not include mold flash or protrusions. Mold flash or protrusions shall not exceed 0.010 inch (0.25mm). 6. E and eA are measured with the leads constrained to be perpendicular to datum -C- . 9 Rev. 0 12/93 7. eB and eC are measured at the lead tips with the leads unconstrained. eC must be zero or greater. 8. B1 maximum dimensions do not include dambar protrusions. Dambar protrusions shall not exceed 0.010 inch (0.25mm). 9. N is the maximum number of terminal positions. 10. Corner leads (1, N, N/2 and N/2 + 1) for E8.3, E16.3, E18.3, E28.3, E42.6 will have a B1 dimension of 0.030 - 0.045 inch (0.76 - 1.14mm). All Intersil U.S. products are manufactured, assembled and tested utilizing ISO9000 quality systems. Intersil Corporation’s quality certifications can be viewed at www.intersil.com/design/quality Intersil products are sold by description only. Intersil Corporation reserves the right to make changes in circuit design, software and/or specifications at any time without notice. Accordingly, the reader is cautioned to verify that data sheets are current before placing orders. Information furnished by Intersil is believed to be accurate and reliable. However, no responsibility is assumed by Intersil or its subsidiaries for its use; nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of Intersil or its subsidiaries. For information regarding Intersil Corporation and its products, see www.intersil.com 20 FN3143.6 October 30, 2007
HI3-0507A-5 价格&库存
很抱歉,暂时无法提供与“HI3-0507A-5”相匹配的价格&库存,您可以联系我们找货
