SP1086
Solved by
TM
1.5A Low Dropout Linear Regulator
TO-220
Features
g
g
g
g
g
g
g
g
Low Dropout Voltage: Typical 1.3V at 1.5A
Current Limiting and Thermal Protection
Output Current: 1.5A
Current Limit: 2.3A
Operating Junction Temperature: 0 to 125oC
Line Regulation: 0.015% (Typical)
Load Regulation: 0.1% (Typical)
Available in RoHS Compliant, Lead Free
Packaging
3
INPUT
2
OUTPUT
1
ADJ/GND
Applications
g
g
g
g
g
g
g
g
g
High Efficiency Linear Regulators
Battery Charger
Post Regulation for Switching Supply
Microprocessor Supply
Motherboard Power Supply
Cable and ADSL Modem
DVD-Video Player
Telecom Equipment
Set Top Boxes and Web Boxes Modules' Supply
general Description
The SP1086 is a series of low dropout positive voltage regulators with a maximum dropout of 1.5V at 1.5A of load
current. The series features on-chip thermal shutdown. It also includes a bandgap reference and a current limiting
circuit. The SP1086 is available in 1.5V, 1.8V, 2.5V, 3V, 3.3V, and 5.0V versions. The fixed versions integrate the
adjust resistors. It is also available in an adjustable version, which can set the output voltage with only two external
resistors. The SP1086 series is available in standard packages of TO-263-3, TO-220 , and TO-252.
TO-263-3
TO-220
TO-252
Figure . Package Types of SP086
Date: 12/5/06 Rev H
SP1086 1.5A Low Dropout Linear Regulator
© 2006 Sipex Corporation
Pin configuration
V Package
V1 Package
(TO-263-3)
(TO-220)
3
INPUT
3
INPUT
OUTPUT
ADJ/GND
2
OUTPUT
2
1
ADJ/GND
1
V2 Package
(TO-252)
3
INPUT
2
OUTPUT
1
ADJ/GND
Figure 2. Pin Configuration of SP086 (Top View)
Functional Block Diagram
Thermal
Protection
2
A
A2
INPUT
OUTPUT
For Adjustable Output, disconnect A and A2, connect B
For Fixed Output, connect A and A2, disconnect B
B
ADJ/
GND
Figure . Functional Block Diagram of SP086
Date: 12/5/06 Rev H
Absolute Maximum Ratings (note 1)
Parameter
Symbol
Operating Junction Temperature Range
TJ
Storage Temperature Range
TS
Min
-65
Max
Unit
150
o
150
oC
C
Lead Temperature (Soldering, 10sec)
TLEAD
300
oC
ESD (Human Body Model)
ESD
2000
V
Note 1:Stresses greater than those listed under "Absolute Maximum Ratings" may cause permanent damage to the
device. These are stress ratings only, and functional operation of the device at these or any other conditions
beyond those indicated under "Recommended Operating Conditions" is not implied. Exposure to "Absolute Maximum Ratings" for extended periods may affect device reliability.
Recommended Operating conditions
Parameter
Symbol
Input Voltage
VIN
TJ
Date: 12/5/06 Rev H
Min
Max
Unit
15
V
125
o
C
1.5A LOW DROPOUT LINEAR REGULATOR
electrical characteristics
Typicals and limits appearing in normal type apply for TJ = 25oC. Limits appearing in Boldface type apply over
the entire junction temperature range for operation, 0oC to 125oC. (PD d maximum power dissipation, see Note 2.)
Parameter
Reference Voltage
Output Voltage
Line Regulation
Date: 12/5/06 Rev H
Symbol
VREF
VOUT
'VOUT
Conditions
Min
Typ
Max
Unit
SP1086-ADJ,
IOUT = 10mA, VIN -VOUT = 2V, TJ = 25oC,
10mA d IOUT d 1.5A, 1.4V d VIN - VOUT d6V
1.238
1.225
1.250
1.250
1.262
1.270
V
SP1086-1.5,
IOUT =10mA, VIN = 3.5V, TJ = 25oC,
10mA d IOUT d 1.5A, 3V d VIN d 10V
1.485
1.47
1.5
1.5
1.515
1.53
V
SP1086-1.8,
IOUT = 10mA, VIN = 3.8V, TJ = 25oC,
10mA d IOUT d 5A, 3.2V d VIN d 10V
1.782
1.746
1.8
1.8
1.818
1.854
V
SP1086-2.5,
IOUT = 10mA, VIN = 4.5V, TJ = 25oC,
10mA d IOUT d 1.5A, 3.9V d VIN d 10V
2.475
2.45
2.5
2.5
2.525
2.55
V
SP1086-3.0,
10mA d IOUT d 1.5A, 4.9V d VIN d 10V
2.97
2.94
3.0
3.0
3.03
3.06
V
SP1086-3.3,
IOUT = 10mA, VIN = 5V, TJ = 25oC,
10mA d IOUT d 1.5A, 4.75V d VIN d 10V
3.267
3.235
3.3
3.3
3.333
3.365
V
SP1086-5.0,
IOUT = 10mA, VIN = 7V, TJ = 25oC,
10mA d IOUT d 1.5A, 6.5V d VIN d 10V
4.95
4.9
5
5
5.05
5.1
V
SP1086-ADJ,
IOUT = 10mA,
1.5V d VIN - VOUT d 10V
0.015
0.035
0.2
0.2
SP1086-1.5,
IOUT = 10mA,
0.3
0.6
6
6
mV
SP1086-1.8,
IOUT = 10mA,
0.3
0.6
6
6
mV
SP1086-2.5,
IOUT = 10mA,
0.3
0.6
6
6
mV
SP1086-3.0,
IOUT = 10mA,
0.3
0.6
6
6
mV
SP1086-3.3,
IOUT = 10mA,
0.5
1
10
10
mV
SP1086-5.0,
IOUT = 10mA,
0.5
1
10
10
mV
electrical characteristics (continued)
Parameter
Load Regulation
Symbol
'VOUT
Dropout Voltage
Current Limit
Typ
Max
Unit
SP1086-ADJ,
Conditions
10mA d IOUT d 1.5A,
VIN - VOUT = 2V
Min
0.1
0.2
0.3
0.4
SP1086-1.5,
10mA d IOUT d 1.5A,
VIN - VOUT = 2V
3
6
12
mV
SP1086-1.8,
10mA d IOUT d 1.5A,
VIN - VOUT = 2V
3
6
12
mV
SP1086-2.5,
10mA d IOUT d 1.5A,
VIN - VOUT = 2V
3
6
12
mV
SP1086-3.0,
10mA d IOUT d 1.5A,
VIN - VOUT = 2V
3
7
15
mV
SP1086-3.3,
10mA d IOUT d 1.5A,
VIN - VOUT = 2V
3
7
15
mV
SP1086-5.0,
10mA d IOUT d 1.5A,
VIN - VOUT = 2V
5
10
mV
1.3
1.5
V
IO = 1.5A, 'VREF = 1%
ILIMIT
VIN - VOUT = 2V,
1.5
A
2.3
Minimum
Load Current
1.4V d VIN - VOUT d 10V (For ADJ)
2
5
mA
Quiescent Current
VIN = VOUT + 1.3V
5
10
mA
Ripple Rejection
fRIPPLE = 120Hz, COUT = 25PF Tantalum,
IOUT = 1.5A, VIN - VOUT = 3V
Adjust Pin Current
Adjust Pin Current
Change
10mA dIOUT d5A,
1.4V d VIN -VOUT d 10V
Temperature
Stability
60
dB
75
60
120
PA
0.2
5
PA
0.5
RMS Noise
(% of VOUT)
TA = 25oC, 10Hz d f d 10kHz
0.003
Thermal Shutdown
165
o
C
30
o
C
Thermal Shutdown
Hysteresis
Thermal Resistance
Junction-to-Case
TJC
TO - 252
TO - 263
TO - 220
4
4
4
o
C/W
Note 2: Maximum power dissipation see Figure 5.
Date: 12/5/06 Rev H
Typical Performance characteristics
0.0
.0
.5
.0
Power (W)
Output Voltage (V)
.5
.25
5.0
.20
2.5
.5
.0
50
5
00
0.0
25
25
5
00
25
o
Figure . Output Voltage vs. Temperature
Figure 5. Maximum Power Dissipation
.260
.255
.2
.250
o
Dropout Voltage (V)
Reference Voltage (V)
50
Case Temperature ( C)
o
Ambient Temperature ( C)
.25
.20
0.
.25
.20
.0
o
TA=25 C
0.8
0.
0.6
.225
.220
TA=0 C
50
5
00
0.5
0. 0.2 0. 0. 0.5 0.6 0. 0.8 0. .0 . .2 . . .5
25
Output Current (A)
o
Figure . Dropout Voltage vs. Output Current
Figure 6. Reference Voltage vs. Temperature
Date: 12/5/06 Rev H
Typical Performance characteristics (continued)
00
2.25
Short Circuit Current (A)
Adjust Pin Current (uA)
2.00
.5
.50
80
50
50
5
00
o
00
25
Figure . Adjust Pin Current vs. Temperature
80
5
Ripple Rejection (dB)
Minimum Load Current (mA)
5
o
Figure 8. Short Circuit Current vs. Temperature
2
60
50
50
5
00
Figure 0. Minimum Load Current vs. Temperature
Date: 12/5/06 Rev H
00
k
0k
00k
Frequency (Hz)
o
Figure . Ripple Rejection vs. Frequency
VOUT
VOUT
iO=0.75A
Vin
iO=0.1A
SP1086V Load transient response
SP1086V Line transient response
Vin=4.8V, VOUT=3.3V, iO=0.1A to
0.75A, cin=cOUT=10P(tan)
Vin=4.8V, VOUT=3.3V, iO=0.1A, cin=1P(tan), cOUT=10P(tan)
Figure . Line Transient Response
Figure 2. Load Transient Response
Typical Application
VIN
10PF
Tantalum
VOUT
SP1086-ADJ
VOUT
VIN
ADJ
22PF
Tantalum
R1
120:
VOUT=VREF* (+R2/R) + IADJ * R2
R2
SP1086-5.0
VIN
10PF
Tantalum
VIN
GND
VOUT
VOUT
22PF
Tantalum
Figure . Typical Applications of SP086
Date: 12/5/06 Rev H
Package:3 pin TO-263
Mechanical Dimensions
TO-263-3
.00(0.60)
.820(0.0)
Unit: mm(inch)
e
.650(0.80)
0.20(0.05)
8.80(0.8)
0e
.20(0.22)
.50(0.05)
.0(0.055)
.20(0.050)
.0(0.055)
.60(0.58)
5.0(0.620)
.50(0.05)
.0(0.055)
0.50(0.020)
0.0(0.0)
2.50(0.00)
2.50(0.00)
e
2.60(0.0)
2.00(0.06)
0.60(0.0)
0.00(0.06)
e
2.200(0.08)
.80(0.)
2e
8e
0.80(0.05)
0e
6e
Date: 12/5/06 Rev H
5.600(0.220)
0.020(0.00)
0.250(0.00)
2.0(0.0)
2.60(0.06)
8.60(0.0)
.650(0.80)
e
2.50(0.00)
2.50(0.00)
Package: 3 pin TO-220
Mechanical Dimensions (continued)
TO-220
2.580(0.02)
.80(0.)
0.550(0.022)
.50(0.05)
.60(0.06)
.60(0.06)
.20(0.560)
6.50(0.650)
¶.500(0.05)
2.880(.08)
0.280(.2)
8.520(0.5)
.520(0.5)
.850(0.0)
.660(0.80)
0.660(0.20)
¶.560(0.0)
.060(0.60)
Unit: mm(inch)
e
0.200(0.008)
e
.560(0.0)
.820(0.0)
2.080(0.082)
2.880(0.)
e
0.8(0.05)
60e
0.8(0.02)
8.6(0.5)
60e
0.8(0.05)
2.50(0.00)
Date: 12/5/06 Rev H
2.50(0.00)
10
0.56(0.0)
0.06(0.06)
Package: 3 pin TO-252
TO-252
6.80(0.25)
6.680(0.26)
2.80(0.086)
2.80(0.0)
0.60(0.08)
0.580(0.02)
.080(0.0)
.20(0.052)
2.0e
.0e
Date: 12/5/06 Rev H
2.20(0.088)
2.0(0.02)
5e
0.600(0.02)
.00(0.055)
.60(0.06)
0.60(0.025)
0.80(0.0)
8e
5.60(0.2)
5.560(0.2)
0.80(0.0)
0.50(0.02)
0.020(0.00)
0.20(0.005)
5e
0.50(0.00)
0.850(0.0)
2.20(0.088)
2.0(0.02)
0.00(0.06)h5e
e
e
0.50(0.020)
2.600(0.02)
.000(0.8)
.500(0.)
0.00(0.8)
0.650(0.026)
0.50(0.0)
5.20(0.206)
5.0(0.2)
Unit: mm(inch)
2.0e
.0e
11
ORDERING INFORMATION
SP1086
/TR: Tape and Reel
Blank: Tube
Part Number
ADJ: Adjustable Output
1.5: Fixed Output 1.5V
1.8: Fixed Output 1.8V
2.5: Fixed Output 2.5V
3.0: Fixed Output 3.0V
3.3: Fixed Output 3.3V
5.0: Fixed Output 5.0V
Package
V2: TO-252
V: TO-220
V1: TO-263-3
-L: Lead Free and
RoHS Compliant
Part Number
SP1086V2-L/TR
Voltage Temperature
Pin
Package
Pack Qty
Range
Range
Count
Adj
0ºC to +125ºC
TO-252
3
2,500/TR
SP1086V2-L-1-5/TR
1.5V
0ºC to +125ºC
TO-252
3
2,500/TR
SP1086V2-L-1-8/TR
1.8V
0ºC to +125ºC
TO-252
3
2,500/TR
SP1086V2-L-2-5/TR
2.5V
0ºC to +125ºC
TO-252
3
2,500/TR
SP1086V2-L-3-0/TR
3V
0ºC to +125ºC
TO-252
3
2,500/TR
SP1086V2-L-3-3/TR
3.3V
0ºC to +125ºC
TO-252
3
2,500/TR
SP1086V2-L-5-0/TR
5V
0ºC to +125ºC
TO-252
3
2,500/TR
SP1086V1-L/TR
Adj
0ºC to +125ºC
TO-263
3
800/TR
SP1086V1-L-1-5/TR
1.5V
0ºC to +125ºC
TO-263
3
800/TR
SP1086V1-L-1-8/TR
1.8V
0ºC to +125ºC
TO-263
3
800/TR
SP1086V1-L-2-5/TR
2.5V
0ºC to +125ºC
TO-263
3
800/TR
SP1086V1-L-3-0/TR
3V
0ºC to +125ºC
TO-263
3
800/TR
SP1086V1-L-3-3/TR
3.3V
0ºC to +125ºC
TO-263
3
800/TR
SP1086V1-L-5-0T/R
5V
0ºC to +125ºC
TO-263
3
800/TR
SP1086V-L
Adj
0ºC to +125ºC
TO-220
3
50/TUBE
SP1086V-L-1-5
1.5V
0ºC to +125ºC
TO-220
3
50/TUBE
SP1086V-L-1-8
1.8V
0ºC to +125ºC
TO-220
3
50/TUBE
SP1086V-L-2-5
2.5V
0ºC to +125ºC
TO-220
3
50/TUBE
SP1086V-L-3-0
3V
0ºC to +125ºC
TO-220
3
50/TUBE
SP1086V-L-3-3
3.3V
0ºC to +125ºC
TO-220
3
50/TUBE
SP1086V-L-5-0
5V
0ºC to +125ºC
TO-220
3
50/TUBE
Solved by
Sipex Corporation
TM
Headquarters and
Sales Office
233 South Hillview Drive
Milpitas, CA 95035
TEL: (408) 934-7500
FAX: (408) 935-7600
Sipex Corporation reserves the right to make changes to any products described herein. Sipex does not assume
any liability arising out of the application or use of any product or circuit described herein; neither does it convey
any license under its patent rights nor the rights of others.
Date: 12/5/06 Rev H
12
