IS31LT3354
40V LED DRIVER WITH EXTERNAL SWITCH
September 2011
GENERAL DESCRIPTION
FEATURES
The IS31LT3354 is a continuous mode inductive
step-down converter, designed for driving a single LED
or multiple series connected LEDs efficiently from a
voltage source higher than the required LED voltage.
The device operates from an input supply between 6V
and 40V and provides an externally adjustable output
current of up to 2A or even higher, which is determined
by the external MOSFET and inductor.
The IS31LT3354 includes a high-side output current
sensing circuit, which uses an external resistor to set
the nominal average output current. Output current can
be adjusted linearly by applying an external control
signal to the ADJ pin. The ADJ pin will accept either a
DC voltage or a PWM waveform. This will provide either
a continuous or a gated output current.
Applying a voltage of 0.2V or lower to the ADJ pin turns
the output off and switches the chip into a low current
standby state.
The chip is assembled in SOT23-5 package.
Simple low parts count
Wide input voltage range: 6V to 40V
Output Current only limited by external
component selection
High efficiency (up to 98% )
Typical 1200:1 dimming ratio
Typical 3% output current accuracy
Single pin on/off and brightness control using
DC voltage or PWM
Up to 1MHz switching frequency
Inherent open-circuit LED protection
Thermal shutdown protection circuitry
APPLICATIONS
Low voltage halogen replacement LEDs
Automotive lighting
Low voltage industrial lighting
LED back-up lighting
Illuminated sign
TYPICAL APPLICATION CIRCUIT
Figure 1
Lumissil Microsystems – www.lumissil.com
Rev. A, 09/01/2011
Typical Application Circuit
1
IS31LT3354
PIN CONFIGURATION
Package
Pin Configuration
SOT23-5
PIN DESCRIPTION
No.
Pin
Description
1
GATE
Output gate driver for an external NMOSFET.
2
GND
Ground (0V).
3
ADJ
Multi-function On/Off and brightness control pin:
* Leave floating for normal operation.(VADJ = VREF = 1.2V giving
nominal average output current IOUT nom =0.1/RS )
* Drive to voltage below 0.2V to turn off output current
* Drive with DC voltage (0.3V
IS31LT3354-STLS2-TR 价格&库存
很抱歉,暂时无法提供与“IS31LT3354-STLS2-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+3.219523000+0.40269
- 6000+3.140196000+0.39277
- 9000+3.100469000+0.38780
- 15000+3.0564315000+0.38229
- 21000+3.0307221000+0.37908
- 30000+3.0059830000+0.37598
- 国内价格 香港价格
- 1+7.000031+0.87555
- 10+4.9977510+0.62511
- 25+4.4927725+0.56195
- 100+3.93648100+0.49237
- 250+3.67222250+0.45931
- 500+3.51285500+0.43938
- 1000+3.381631000+0.42297
