IS31FL3731
AUDIO MODULATED MATRIX LED DRIVER
November 2019
GENERAL DESCRIPTION
FEATURES
The IS31FL3731 is a compact LED driver for 144
single LEDs. The device can be programmed via an
I2C compatible interface. The IS31FL3731 offers two
blocks each driving 72 LEDs with 1/9 cycle rate. The
required lines to drive all 144 LEDs are reduced to 18
by using the cross-plexing feature optimizing space on
the PCB. Additionally each of the 144 LEDs can be
dimmed individually with 8-bit allowing 256 steps of
linear dimming.
To reduce CPU usage up to 8 frames can be stored
with individual time delays between frames to play
small animations automatically. LED frames can be
modulated with audio signal.
IS31FL3731 is available in QFN-28 (4mm × 4mm) and
SSOP-28 package. It operates from 2.7V to 5.5V over
the temperature range of -40°C to +85°C.
Supply voltage range: 2.7V to 5.5V
400kHz I2C-compatible interface
144 LEDs in dot matrix
Individual blink control
8 frames memory for animations
Picture mode and animation mode
Auto intensity breathing during the switching of
different frames
LED frames displayed can be modulated with
audio signal intensity
LED light intensity can be modulated with audio
signal intensity
QFN-28 (4mm × 4mm) and SSOP-28 package
APPLICATIONS
Mobile phones and other hand-held devices for
LED display
LED in home appliances
TYPICAL APPLICATION CIRCUIT
Figure 1 Typical Application Circuit
Note 1: The IC should be placed far away from the mobile antenna in order to prevent the EMI.
Note 2: The average current of each LED is 3.2mA when REXT = 20kΩ. The LED current can be modulated by the REXT. Please refer to the
detail information in Page 18.
Lumissil Microsystems – www.lumissil.com
Rev. F, 11/04/2019
1
IS31FL3731
PIN CONFIGURATION
Package
Pin Configuration (Top View)
QFN-28
SSOP-28
Rev. F, 11/04/2019
2
IS31FL3731
PIN DESCRIPTION
No.
Pin
Description
1
CA9
LED matrix A current output/input port.
2
VCC
Power supply.
3
SDB
Shutdown the chip when pull to low.
4
INTB
Interrupt output. Active low.
5
GND
Ground.
6
R_EXT
20kΩ resistance to confirm the LED current.
7 ~ 15
CB1 ~ CB9
LED matrix B current output/input port.
16
C_FILT
Capacitor used for audio.
17
IN
Audio input.
18
AD
I2C address setting.
19
SDA
I2C compatible serial data.
SCL
I2C compatible serial clock.
21 ~ 28
CA1 ~ CA8
Thermal Pad
Connect to GND.
Rev. F, 11/04/2019
3
IS31FL3731
ORDERING INFORMATION
Industrial Range: -40°C To +85°C
Order Part No.
Package
QTY
IS31FL3731-QFLS2-TR
IS31FL3731-SALS2-TR
IS31FL3731-SALS2
QFN-28, Lead-free
SSOP-28, Lead-free
SSOP-28, Lead-free
2500/Reel
2000/Reel
48/Tube
Copyright © 2019 Lumissil Microsystems. All rights reserved. Lumissil Microsystems reserves the right to make changes to this specification and its
products at any time without notice. Lumissil Microsystems assumes no liability arising out of the application or use of any information, products or
services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and
before placing orders for products.
Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can
reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use
in such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:
a.) the risk of injury or damage has been minimized;
b.) the user assume all such risks; and
c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances
Rev. F, 11/04/2019
4
IS31FL3731
ABSOLUTE MAXIMUM RATINGS
Supply voltage, VCC
Voltage at any input pin
Maximum junction temperature, TJMAX
Storage temperature range, TSTG
Operating temperature range, TA=TJ
-0.3V ~ +6V
-0.3V ~ VCC+0.3V
+150°C
-65°C ~ +150°C
-40°C ~ +85°C
51.4°C/W (QFN)
72°C/W (SSOP)
±8kV
±1kV
Thermal resistance, junction to ambient, still air, θJA
ESD (HBM)
ESD (CDM)
Note 3: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress
ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the
specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
ELECTRICAL CHARACTERISTICS
TA = -40°C ~ +85°C, VCC = 2.7V ~ 5.5V, unless otherwise noted. Typical value is TA = 25°C, VCC = 3.6V.
Symbol
Parameter
Conditions
VCC
Supply voltage
ICC
Quiescent power supply current
ISD
Shutdown current
IOUT
VHR
tSCAN
tSCANOL
ILED
Min.
Typ.
2.7
VIN = 0V, without audio input,
all LEDs off
2.17
VSDB = 0V
0.5
VSDB = VCC, software shutdown
230
Output current of C1~C9
Matrix display mode without audio
modulation (Note 4)
34
Current sink headroom voltage
C1~C9
ISink = 270mA (Note 5)
400
Current source headroom
voltage C1~C9
ISource = 34mA
400
Max.
Unit
5.5
V
mA
5
μA
mA
mV
Period of scanning (Figure 2)
106
µs
Non-overlap blanking time
during scan (Figure 2)
15
µs
3.2
mA
REXT = 20kΩ, PWM in 255 step
(Note 6)
Average current of each LED
Logic Electrical Characteristics (SDA, SCL, AD)
VIL
Logic “0” input voltage
VCC = 2.7V
VIH
Logic “1” input voltage
VCC = 5.5V
IIL
Logic “0” input current
VINPUT = 0V (Note 7)
5
nA
IIH
Logic “1” input current
VINPUT = VCC (Note 7)
5
nA
Rev. F, 11/04/2019
0.4
1.4
V
V
5
IS31FL3731
DIGITAL INPUT SWITCHING CHARACTERISTICS (NOTE 7)
Symbol
Parameter
Condition
Min.
Typ.
Max.
Units
400
kHz
fSCL
Serial-Clock frequency
tBUF
Bus free time between a STOP and a START
condition
1.3
μs
tHD, STA
Hold time (repeated) START condition
0.6
μs
tSU, STA
Repeated START condition setup time
0.6
μs
tSU, STO
STOP condition setup time
0.6
μs
tHD, DAT
Data hold time
tSU, DAT
Data setup time
100
ns
tLOW
SCL clock low period
1.3
μs
tHIGH
SCL clock high period
0.7
μs
0.9
μs
tR
Rise time of both SDA and SCL signals,
receiving
(Note 8)
20+0.1Cb
300
ns
tF
Fall time of both SDA and SCL signals, receiving
(Note 8)
20+0.1Cb
300
ns
Note 4: The average current of each LED is IOUT/10.5.
Note 5: All LEDs are on.
Note 6: ILED = 64.7/REXT, REXT = 20kΩ is recommended. The recommended minimum value of REXT is 18kΩ, or it may cause a large current.
Note 7: Guaranteed by design.
Note 8: Cb = total capacitance of one bus line in pF. ISINK ≤ 6mA. tR and tF measured between 0.3 × VCC and 0.7 × VCC.
Figure 2 Scanning Timing
Rev. F, 11/04/2019
6
IS31FL3731
DETAILED DESCRIPTION
I2C INTERFACE
The IS31FL3731 uses a serial bus, which conforms to
the I2C protocol, to control the chip’s functions with
two wires: SCL and SDA. The IS31FL3731 has a 7-bit
slave address (A7:A1), followed by the R/W bit, A0.
Set A0 to “0” for a write command and set A0 to “1” for
a read command. The value of bits A1 and A2 are
decided by the connection of the AD pin.
The complete slave address is:
Following acknowledge of IS31FL3731, the register
address byte is sent, most significant bit first.
IS31FL3731 must generate another acknowledge
indicating that the register address has been received.
Then 8-bit of data byte are sent next, most significant
bit first. Each data bit should be valid while the SCL
level is stable high. After the data byte is sent, the
IS31FL3731 must generate another acknowledge to
indicate that the data was received.
Bit
A7:A3
A2:A1
A0
The “STOP” signal ends the transfer. To signal
“STOP”, the SDA signal goes high while the SCL
signal is high.
Value
11101
AD
0/1
ADDRESS AUTO INCREMENT
Table 1 Slave Address
AD connected to GND, AD=00;
AD connected to VCC, AD=11;
AD connected to SCL, AD=01;
AD connected to SDA, AD=10;
The SCL line is uni-directional. The SDA line is bidirectional (open-collector) with a pull-up resistor
(typically 4.7kΩ). The maximum clock frequency
specified by the I2C standard is 400kHz. In this
discussion, the master is the microcontroller and the
slave is the IS31FL3731.
The timing diagram for the I2C is shown in Figure 3.
The SDA is latched in on the stable high level of the
SCL. When there is no interface activity, the SDA line
should be held high.
The “START” signal is generated by lowering the SDA
signal while the SCL signal is high. The start signal will
alert all devices attached to the I2C bus to check the
incoming address against their own chip address.
The 8-bit chip address is sent next, most significant bit
first. Each address bit must be stable while the SCL
level is high.
After the last bit of the chip address is sent, the master
checks for the IS31FL3731’s acknowledge. The
master releases the SDA line high (through a pull-up
resistor). Then the master sends an SCL pulse. If the
IS31FL3731 has received the address correctly, then it
holds the SDA line low during the SCL pulse. If the
SDA line is not low, then the master should send a
“STOP” signal (discussed later) and abort the transfer.
Rev. F, 11/04/2019
To write multiple bytes of data into IS31FL3731, load
the address of the data register that the first data byte
is intended for. During the IS31FL3731 acknowledge
of receiving the data byte, the internal address pointer
will increment by one. The next data byte sent to
IS31FL3731 will be placed in the new address, and so
on. The auto increment of the address will continue as
long as data continues to be written to IS31FL3731
(Figure 6).
READING PORT REGISTERS
All of registers in IS31FL3731 can be read. But Frame
Registers can only be read in software shutdown
mode as SDB pin is high. The Function Register can
be read in software shutdown mode or operating
mode.
To read the device data, the bus master must first
____
send the IS31FL3731 address with the R/W bit set to
“0”, followed by the Command Register address, FDh,
then send command data which determines which
response register is accessed. After a restart, the bus
master must send the IS31FL3731 address with the
____
R/ W bit set to “0” again, followed by the register
address which determines which register is accessed.
Then restart I2C, the bus master should send the
____
IS31FL3731 address with the R/W bit set to “1”. Data
from the register defined by the command byte is then
sent from the IS31FL3731 to the master (Figure 7).
7
IS31FL3731
SDA
tSU,DAT
tLOW
SCL
tHD,DAT
S
tHIGH
tSU,STA
tHD,STA
R
tSU,STO
tBUF
P
tHD,STA
tR
tF
Restart Condition
Start Condition
Stop Condition
Start Condition
Figure 3 Interface Timing
Figure 4 Bit Transfer
Figure 5 Writing to IS31FL3731 (Typical)
Figure 6 Writing to IS31FL3731 (Automatic address increment)
Figure 7 Reading from IS31FL3731
Rev. F, 11/04/2019
8
IS31FL3731
REGISTER DEFINITION
Table 2 FDh Command Register
Data
Function
Data
Function
0000 0000 Point to Page One (Frame 1 Register is available)
0000 0001 Point to Page Two (Frame 2 Register is available)
0000 0010 Point to Page Three (Frame 3 Register is available)
0000 0011 Point to Page Four (Frame 4 Register is available)
0000 0100 Point to Page Five (Frame 5 Register is available)
0000 0101 Point to Page Six (Frame 6 Register is available)
0000 0110 Point to Page Seven (Frame 7 Register is available)
0000 0111 Point to Page Eight (Frame 8 Register is available)
0000 1011 Point to Page Nine (Function Register is available)
Others
Reserved
Note 9: The Command Register should be configured first after writing in the slave address to choose the available register (Frame Registers
and Function Registers). Then write data in the choosing register.
For example, when write “0000 0011” in the Command Register (FDh), the data which writing after will be stored in the Frame 4 Register. Write
new data can configure other registers.
Table 3 Response Register Function
(The address of each Page is starting from 00h. Frame Registers have the same format.)
Address
Name
Function
Table
R/W
Default
Frame Register (Page One to Page Eight) (Note 10)
00h ~ 11h
LED Control Register
Store on or off state for each LED
4
R/W
12h ~ 23h
Blink Control Register
Control the blink function for each LED
5
R/W
24h ~ B3h
PWM Register
144 LEDs PWM duty cycle data
register
6
R/W
xxxx
xxxx
Function Register (Page Nine)
00h
Configuration Register
Configure the operation mode
8
R/W
01h
Picture Display Register
Set the display frame in Picture Mode
9
R/W
02h
Auto Play Control Register 1
Set the way of display in Auto Frame
Play Mode
10
R/W
03h
Auto Play Control Register 2
Set the delay time in Auto Frame Play
Mode
11
R/W
04h
Reserved (Note 11)
Reserved
R/W
05h
Display Option Register
Set the display option
12
R/W
06h
Audio Synchronization
Register
Set audio synchronization function
13
R/W
07h
Frame State Register
Store the frame display information
14
R
08h
Breath Control Register 1
Set fade in and fade out time for breath
function
15
R/W
09h
Breath Control Register 2
Set the breath function
16
R/W
0Ah
Shutdown Register
Set software shutdown mode
17
R/W
0Bh
AGC Control Register
Set the AGC function and the audio
gain.
18
R/W
0Ch
Audio ADC Rate Register
Set the ADC sample rate of the input
signal
19
R/W
0000
0000
Note 10: The data of Frame Registers is not assured when power on. Please initialize the Frame Registers first to ensure operate normally.
Note 11: The 04h register has no function although it can be written. It also can be read but the data is not assured.
Rev. F, 11/04/2019
9
IS31FL3731
REGISTER CONTROL
Configure
Command Register
(FDh)
Select
Response Register
0x00
0x01
0x07
0x0B
Page One
Frame 1 Register
Page Two
Frame 2 Register
Page Eight
Frame 8 Register
Page Nine
Function Register
Configure
Frame Register
Configure
Frame Register
Configure
Frame Register
Configure
Function Register
(00h~11h)
(00h~11h)
(00h~11h)
(00h)
(12h~23h)
(12h~23h)
(12h~23h)
PWM Register (24h~B3h)
FRAME REGISTER
Table 4 00h ~ 11h LED Control Register
(0Ch)
Table 6 24h ~ B3h PWM Register
Bit
D7:D0
Bit
D7:D0
Name
CX-8 : CX-1 or CX-16 : CX-9
Name
PWM
Default
xxxx xxxx
Default
xxxx xxxx
The LED Control Registers store the on or off state of
each LED in the Matrix A and B. Please refer to the
detail information in Table 7.
LED State Bit
LED off
LED on
CX-Y
PWM Registers modulate the 144 LEDs in 256 steps.
The value of the PWM Registers decides the output
current of each LED. The output current may be
computed using the Formula (1):
I PWM
Figure 8 in Page 11 shows the ordering of CX-Y.
Table 5 12h ~ 23h Blink Control Register
Bit
D7:D0
Name
Default
xxxx xxxx
I LED 7
D[n] 2 n
256 n0
(1)
Where D[n] stands for the individual bit value, 1 or 0,
in location n.
For example: if D7:D0 = 10110101,
IPWM = ILED (20+22+24+25+27)/256
ILED is set by the external resistor, REXT, ILED =
64.7/REXT.
For example, when REXT = 20kΩ, ILED = 64.7/20 =
3.2mA.
The Blink Control Registers configure the blink
function of each LED in the Matrix A and B. Please
refer to the detail information in Table 7.
CX-Y
Blink Control Bit
Disable
Enable
Table 7 Address of Frame Register
LED Location
Rev. F, 11/04/2019
PWM Register
10
IS31FL3731
Matrix A
Matrix B
Matrix A
Matrix B
Matrix A
Matrix B
Matrix A
Matrix B
CA1(C1-1~C1-8)
CB1(C1-9~C1-16)
00h
01h
12h
13h
24h ~ 2Bh
2Ch ~ 33h
CA2(C2-1~C2-8)
CB2(C2-9~C2-16)
02h
03h
14h
15h
34h ~ 3Bh
3Ch ~ 43h
CA3(C3-1~C3-8)
CB3(C3-9~C3-16)
04h
05h
16h
17h
44h ~ 4Bh
4Ch ~ 53h
CA4(C4-1~C4-8)
CB4(C4-9~C4-16)
06h
07h
18h
19h
54h ~ 5Bh
5Ch ~ 63h
CA5(C5-1~C5-8)
CB5(C5-9~C5-16)
08h
09h
1Ah
1Bh
64h ~ 6Bh
6Ch ~ 73h
CA6(C6-1~C6-8)
CB6(C6-9~C6-16)
0Ah
0Bh
1Ch
1Dh
74h ~ 7Bh
7Ch ~ 83h
CA7(C7-1~C7-8)
CB7(C7-9~C7-16)
0Ch
0Dh
1Eh
1Fh
84h ~ 8Bh
8Ch ~ 93h
CA8(C8-1~C8-8)
CB8(C8-9~C8-16)
0Eh
0Fh
20h
21h
94h ~ 9Bh
9Ch ~ A3h
CA9(C9-1~C9-8)
CB9(C9-9~C9-16)
10h
11h
22h
23h
A4h ~ ABh
ACh ~ B3h
Figure 8 LED Array
Rev. F, 11/04/2019
11
IS31FL3731
FUNCTION REGISTER
Table 8 00h Configuration Register
Table 10 02h Auto Play Control Register 1
Bit
D7:D5
D4:D3
D2:D0
Bit
D7
D6:D4
D3
D2:D0
Name
MODE
FS
Name
CNS
FNS
Default
000
00
000
Default
The Configuration Register sets operating mode of
IS31FL3731.
MODE
00
01
1x
The Auto Play Control Register 1 sets the way of
display in Auto Frame Play Mode.
CNS
Number of Loops Playing Selection
(Available in Auto Frame Play Mode)
000
Play endless
001
1 loop
010
2 loops
011
3 loops
100
4 loops
101
5 loops
110
6 loops
111
7 loops
Display Mode
Picture Mode
Audio Frame Play Mode
FS
Frame Start
000
Frame 1
001
Frame 2
010
Frame 3
011
Frame 4
100
Frame 5
101
Frame 6
110
Frame 7
111
Frame 8
FS bit sets the start frame in Auto Frame Play Mode.
Movie starts from Frame 4 when the FS bit is set to
“011”. The FS bit is only available in Auto Frame Play
Mode.
Table 9 01h Picture Display Register
Bit
D7:D3
D2:D0
Name
PFS
Default
00000
000
The Picture Display Register sets display frame in
Picture Mode.
PFS
Picture Frame Selection
(Available in Picture Mode)
000
Frame 1
001
Frame 2
010
Frame 3
011
Frame 4
100
Frame 5
101
Frame 6
110
Frame 7
111
Frame 8
Rev. F, 11/04/2019
FNS
Number of Frames Playing Selection
000
All Frame
001
1 frame
010
2 frames
011
3 frames
100
4 frames
101
5 frames
110
6 frames
111
7 frames
Movie will be stop in the next frame of the cycle. For
example, FS bit is set to “011”, CNS bit is set to “011”
and FNS bit is set to “011”. Then the movie will play
from frame 4 to frame 6 and play three times it stops
in frame 7.
Table 11 03h Auto Play Control Register 2
Bit
D7:D6
D5:D0
Name
A
Default
00
000000
The Auto Play Control Register 2 sets the delay time
in Auto Frame Play Mode (Figure 12).
FDT
Frame Delay Time
If A = 0, FDT = τ×64;
If A = 1~63, FDT = τ×A;
A = 0~63 and τ = 11ms (Typ.);
For example, when A = 23, FDT is 11ms×23 = 253ms
12
IS31FL3731
Table 12 05h Display Option Register
Table 14 07h Frame State Register (Read Only)
Bit
D7:D6
D5
D4
D3
D2:D0
Bit
D7:D5
D4
D3
D2:D0
Name
IC
BE
A
Name
INT
CFD
Default
00
Default
The Display Option Register sets display option of
IS31FL3731.
The Frame State Register stores the frame display
information.
Intensity Control
Set the intensity of each frame
independently
Use intensity setting of frame 1 for all
other frames
IC
Blink Enable
Disable
Enable
BE
BPT
Blink Period Time
BPT = τ×A;
A = 0~7, τ = 0.27s (Typ.);
For example, when A = 5, BPT is 0.27s×5 = 1.35s.
INT
Interrupt Bit
Movie does not finish
1
Movie has finished
Current Frame Display
Frame 1
Frame 2
Frame 3
Frame 4
Frame 5
Frame 6
Frame 7
Frame 8
CFD
000
001
010
011
100
101
110
111
The duty cycle for blink function is 50%.
The INT bit will be set to “1” automatically when movie
is end in Auto Frame Play Mode. The INT bit can be
cleared up by reading the Frame State Register.
Table 13 06h Audio Synchronization Register
Bit
D7:D1
D0
Name
AE
Default
0000000
The Audio Synchronization Register sets audio
synchronization function.
AE
Audio Synchronization Enable
Audio synchronization disable
1
Enable audio signal to modulate the
intensity of the matrix
The intensity of matrix can be modulated by the audio
input signal basing on each LED’s current is set by
PWM when the AE bit is set to “1”.
Rev. F, 11/04/2019
Table 15 08h Breath Control Register 1
Bit
D7
D6:D4
D3
D2:D0
Name
A
B
Default
The Breath Control Register 1 sets fade in and fade
out time for breath function.
FOT
Fade Out Time
FOT = τ×2A
A = 0~7, τ = 26ms (Typ.)
For example, when A = 4, FOT is 26ms×24 = 416ms
FIT
Fade In Time
FIT = τ×2B
B = 0~7, τ = 26ms (Typ.)
For example, when A = 4, FIT is 26ms×24 = 416ms
13
IS31FL3731
Table 16 09h Breath Control Register 2
AGS
Bit
D7:D5
D4
D3
D2:D0
Name
B_EN
A
Default
000
The Breath Control Register 2 sets the breath function.
B_EN
Breath Enable
(Available in Picture Mode and Auto Frame Play Mode)
Disable
1
Enable
ET
Extinguish Time
A
ET = τ×2
A = 0~7, τ = 3.5ms (Typ.)
For example, when A = 4, ET is 3.5ms×24 = 56ms
D7:D1
D0
Name
SSD
Default
0000000
The Shutdown Register sets software shutdown mode.
SSD
Audio Gain Selection
0dB
3dB
6dB
9dB
12dB
15dB
18dB
21dB
The AGS bit is available in Audio Frame Play Mode
and audio synchronization mode.
Table 19 0Ch Audio ADC Rate Register
Bit
D7:D0
Name
A
Default
0000 0000
The Audio ADC Rate Register sets the ADC sample
rate of the input signal in Audio Frame Play Mode.
Table 17 0Ah Shutdown Register
Bit
000
001
010
011
100
101
110
111
Shutdown Control
Shutdown Mode
Normal Operation
AAR Audio ADC Rate
(Available in Audio Frame Play Mode)
If A = 0, AAR = τ×256
If A = 1~255, AAR = τ×A
τ = 46μs (Typ.)
For example, when A = 14, AAR is 46μs×14 = 644μs
Table 18 0Bh AGC Control Register
Bit
D7:D5
D4
D3
D2:D0
Name
AGCM
AGC
AGS
Default
000
The AGC Control Register sets the AGC function and
the audio gain.
AGCM
AGC Mode
Slow Mode
Fast Mode
AGC
AGC Enable
Disable
Enable
Rev. F, 11/04/2019
14
IS31FL3731
FUNCTIONAL BLOCK DIAGRAM
VCC
SDA
SCL
SRAM
I2C
Interface
AD
INTB
Registers
Digital Control
Logic
SDB
IN
C_FILT
Audio Signal
Process
Current
Sink
Current
Source
CA1~CA9
CB1~CB9
GND
R_EXT
Rev. F, 11/04/2019
15
IS31FL3731
APPLICATION INFORMATION (The description below is for the Function Register unless otherwise noted.)
Writing new data continuously to the registers can
modulate the brightness of the LEDs to achieve a
breathing effect.
Choosing more gamma steps provides for a more
continuous looking breathing effect. This is useful for
very long breathing cycles. The recommended
configuration is defined by the breath cycle T. When
T=1s, choose 32 gamma steps, when T=2s, choose
64 gamma steps. The user must decide the final
number of gamma steps not only by the LED itself,
but also based on the visual performance of the
finished product.
GAMMA CORRECTION
Table 18 64 Gamma Steps With 256 PWM Steps
PWM CONTROL
The brightness of 144 LEDs can be modulated with
256 steps by PWM Register. For example, if the data
in PWM Register is “0000 0100”, then the PWM is the
fourth step.
In order to perform a better visual LED breathing effect
we recommend using a gamma corrected PWM value
to set the LED intensity. This results in a reduced
number of steps for the LED intensity setting, but
causes the change in intensity to appear more linear to
the human eye.
Gamma correction, also known as gamma
compression or encoding, is used to encode linear
luminance to match the non-linear characteristics of
display. Since the IS31FL3731 can modulate the
brightness of the LEDs with 256 steps, a gamma
correction function can be applied when computing
each subsequent LED intensity setting such that the
changes in brightness matches the human eye's
brightness curve.
Table 17 32 Gamma Steps With 256 PWM Steps
C(0)
C(1)
C(2)
C(3)
C(4)
C(5)
C(6)
C(7)
2
4
6
10
13
18
C(0)
C(1)
C(2)
C(3)
C(4)
C(5)
C(6)
C(7)
2
3
4
5
6
7
C(8)
C(9)
C(10)
C(11)
C(12)
C(13)
C(14)
C(15)
8
10
12
14
16
18
C(16)
C(17)
C(18)
C(19)
C(20)
C(21)
C(22)
C(23)
24
26
29
32
35
38
41
44
C(24)
C(25)
C(26)
C(27)
C(28)
C(29)
C(30)
C(31)
47
50
53
57
61
65
69
73
C(32)
C(33)
C(34)
C(35)
C(36)
C(37)
C(38)
C(39)
77
81
85
89
94
99
104
109
C(40)
C(41)
C(42)
C(43)
C(44)
C(45)
C(46)
C(47)
114
119
124
129
134
140
146
152
C(48)
C(49)
C(50)
C(51)
C(52)
C(53)
C(54)
C(55)
158
164
170
176
182
188
195
202
C(56)
C(57)
C(58)
C(59)
C(60)
C(61)
C(62)
C(63)
209
216
223
230
237
244
251
255
C(8)
C(9)
C(10)
C(11)
C(12)
C(13)
C(14)
C(15)
256
22
28
33
39
46
53
61
69
224
C(16)
C(17)
C(18)
C(19)
C(20)
C(21)
C(22)
C(23)
78
86
96
106
116
126
138
149
C(24)
C(25)
C(26)
C(27)
C(28)
C(29)
C(30)
C(31)
161
173
186
199
212
226
240
255
160
128
96
224
64
192
PWM Data
PWM Data
256
192
32
160
16
24
32
40
48
56
64
128
Intensity Steps
96
Figure 10 Gamma Correction (64 Steps)
Note: The data of 32 gamma steps is the standard value and the
data of 64 gamma steps is the recommended value.
64
32
OPERATING MODE
8
12
16
Intensity Steps
28
32
IS31FL3731 has three operating modes, Picture
Mode, Auto Frame Play Mode and Audio Frame Play
Mode.
Figure 9 Gamma Correction (32 Steps)
Rev. F, 11/04/2019
16
IS31FL3731
PICTURE MODE
BREATHING FUNCTION SETTING
By setting the MODE bit of the Configuration Register
(00h) to “00”, the IS31FL3731 operates in Picture
Mode. Set the PFS bit of Picture Display Register (01h)
to choose the display frame. The Picture Mode can be
operating with breath function by configuring Breath
Control Register 2 (09h).
When IS31FL3731 switches playing frame, breath
function is available. By setting the B_EN bit of the
Breath Control Register 2 (09h) to “1”, breath function
enable. When set the B_EN bit to “0”, breath function
disable.
AUTO FRAME PLAY MODE
(00h) to “01”, the IS31FL3731 operates in Auto Frame
Play Mode. It stores data of 8 frames and
automatically plays in order. Customers can configure
the delay time between each two frames and the first
playing frame by setting the FS bit of Configuration
Register (00h). The Auto Play Control Register 1 (02h)
can configure the display cycle and display frames.
Configure the Auto Play Control Register 2 (03h),
Breath Control Register 1 (08h) and Breath Control
Register 2 (09h) can set the breath time between two
frames switching.
AUDIO FRAME PLAY MODE
(00h) to “1x”, the IS31FL3731 operates in Audio Frame
Play Mode. It stores data of 8 frames and the 8 frames
playing follow the input signal. 0Ch register is used to
set the ADC sample rate for the input signal to control
frames playing. It plays the first frame when the value
is the smallest and plays the eighth frame when the
value is the biggest.
Figure 12 Breathing Function
INTERRUPT CONTROL
When IS31FL3731 is playing frame in the Auto Frame
Play Mode, the INTB pin is high and the INT bit of
Frame State Register (07h) is “0”. It will be pulled low
as movie end and the INT bit will be set to “1” at the
same time.
The INTB pin will come back to high level
automatically if it stays low at least 7ms. The INT bit
will reset to “0” only when reading the Frame State
Register (07h).
LED MATRIX CIRCUIT
The IS31FL3731 can drive 144 LEDs totally. Part of
LEDs can if there is no need to use all 144 LEDs
(Figure 13). But the LEDs which are no connected
must be off by LED Control Register (Frame Registers)
or it will affect other LEDs.
AUDIO MODULATED AND GAIN SETTING
By setting the AE bit of the Audio Synchronization
Register (06h) to “1”, IS31FL3731 operates with audio
synchronization. The intensity of LEDs is adjusted by
the input signal. The audio input gain can be set by the
AGC Control Register (0Bh).
BLINK FUNCTION SETTING
By setting the BE bit of the Display Option Register
(05h) to “1”, blink function enable. If the BE bit is set to
“1”, each LED can be controlled by the Blink Control
Registers (12h~23h in Page One to Page Eight). The
Display Option Register (05h) is used to set the blink
period time, BPT, and the duty cycle is 50% (Figure
11).
Figure 13 No C9-3~C9-5, C5-8~C9-8
Figure 11 Blink Function
Rev. F, 11/04/2019
17
IS31FL3731
MORE FRAMES DISPLAY
SHUTDOWN MODE
The IS31FL3731 can store 8 frames data at best.
Each 4 frames writing in Frame Registers is
recommended if there are more frames to play (Figure
14). First, store 8 frames data and play 4 frames in
front. Then play last 4 frames and writing new data in
the Frame Registers (1~4) at the same time. Play the
new 4 frames (1~4) and write new data in the Frame
Registers (5~8).
Shutdown mode can be used as a means of reducing
power consumption. During shutdown mode all
registers retain their data.
8 frames data write
into Frame Registers
Software Shutdown
By setting SSD bit of the Shutdown Register (0Ah) to
“0”, the IS31FL3731 will operate in software shutdown
mode. When the IS31FL3731 is in software shutdown
mode, all current sources and digital drivers are
switched off, so that the matrix is blanked. All registers
can be writing or read when the SDB pin is pulled high
in software shutdown mode.
Hardware Shutdown
Play 1~4 frames
The chip enters hardware shutdown mode when the
SDB pin is pulled low. All registers are forbidden
writing and reading.
Play end
Interrupt sign
Play 5~8 frames
New data write into 1~4
Frame Registers
Play end
Interrupt sign
Play end
Interrupt sign
Play 1~4 frames
New data write into 5~8
Frame Registers
All data
play end
All data
play end
Play end
Figure 14 More Frame Data Writing In
REXT
The average output current of each LED can be
adjusted by the external resistor, REXT, as described in
Formula (2).
I LED 64.7 / REXT
(2)
For example, in Figure 1, REXT = 20kΩ,
Figure 15 Shutdown Control
So I LED 64.7 / 20 3.2mA
Rev. F, 11/04/2019
18
IS31FL3731
APPLICATION DESIGN
Rev. F, 11/04/2019
19
IS31FL3731
CLASSIFICATION REFLOW PROFILES
Profile Feature
Pb-Free Assembly
Preheat & Soak
Temperature min (Tsmin)
Temperature max (Tsmax)
Time (Tsmin to Tsmax) (ts)
150°C
200°C
60-120 seconds
Average ramp-up rate (Tsmax to Tp)
3°C/second max.
Liquidous temperature (TL)
Time at liquidous (tL)
217°C
60-150 seconds
Peak package body temperature (Tp)*
Max 260°C
Time (tp)** within 5°C of the specified
classification temperature (Tc)
Max 30 seconds
Average ramp-down rate (Tp to Tsmax)
6°C/second max.
Time 25°C to peak temperature
8 minutes max.
Figure 16 Classification Profile
Rev. F, 11/04/2019
IS31FL3731
PACKAGE INFORMATION
QFN-28
Rev. F, 11/04/2019
21
IS31FL3731
SSOP-28
Rev. F, 11/04/2019
22
IS31FL3731
RECOMMENDED LAND PATTERN
QFN-28
SSOP-28
Note:
1. Land pattern complies to IPC-7351.
2. All dimensions in MM.
3. This document (including dimensions, notes & specs) is a recommendation based on typical circuit board manufacturing parameters. Since
land pattern design depends on many factors unknown (eg. user’s board manufacturing specs), user must determine suitability for use.
Rev. F, 11/04/2019
23
IS31FL3731
REVISION HISTORY
Revision
A
B
Detail Information
Initial release
1. Add detailed information about SSOP-28 package
2. P.5 delete max software shutdown current
3. Update the copyright
4. Update POD
Date
2012.03.14
2012.09.09
1.P.12 Add CNS bit information for Table 10
2.P.4 Modify the ordering information for SSOP-28 package
2013.04.11
D
Modify the I2C reading figure
2013.04.26
E
1. Add tape packing for SSOP-28 package
2. Add ESD and θJA
3. Add land pattern and update POD
4. Add Revision History
2017.08.17
F
1.Correct ESD (CDM)
2.Update logo to AMS
2019.11.04
C
Rev. F, 11/04/2019
24
