MC74AC257, MC74ACT257
Quad 2-Input Multiplexer
with 3-State Outputs
The MC74AC257/74ACT257 is a quad 2−input multiplexer with
3−state outputs. Four bits of data from two sources can be selected
using a Common Data Select input. The four outputs present the
selected data in true (noninverted) form. The outputs may be switched
to a high impedance state by placing a logic HIGH on the common
Output Enable (OE) input, allowing the outputs to interface directly
with bus−oriented systems.
OE
I0c
I1c
Zc
I0d
I1d
Zd
16
15
14
13
12
11
10
9
MARKING
DIAGRAMS
16
Multiplexer Expansion by Tying Outputs Together
Noninverting 3−State Outputs
Outputs Source/Sink 24 mA
′ACT257 Has TTL Compatible Inputs
These are Pb−Free Devices
VCC
www.onsemi.com
SOIC−16
D SUFFIX
CASE 751B
16
1
xxx257G
AWLYWW
1
16
16
1
xxx
257
ALYWG
G
TSSOP−16
DT SUFFIX
CASE 948F
1
1
2
3
4
5
6
7
S
I0a
I1a
Za
I0b
I1b
Zb
xxx
= AC or ACT
A
= Assembly Location
WL or L = Wafer Lot
Y
= Year
WW or W = Work Week
G or G
= Pb−Free Package
8
GND
(Note: Microdot may be in either location)
Figure 1. Pinout: 16−Lead Packages Conductors
(Top View)
ORDERING INFORMATION
See detailed ordering and shipping information in the package
dimensions section on page 7 of this data sheet.
© Semiconductor Components Industries, LLC, 2015
March, 2015 − Rev. 8
1
Publication Order Number:
MC74AC257/D
FUNCTIONAL DESCRIPTION
PIN NAME
PIN
FUNCTION
S
Common Data Select Input
OE
3−State Output Enable Input
I0a−I0d
Data Inputs from Source 0
I1a−I1d
Data Inputs from Source 1
Za−Zd
3−State Multiplexer Outputs
multiplexer with 3−state outputs. It selects four bits of data
from two sources under control of a Common Data Select
input. When the Select input is LOW, the I0x inputs are
selected and when Select is HIGH, the I1x inputs are
selected. The data on the selected inputs appears at the
outputs in true (noninverted) form. The device is the logic
implementation of a 4−pole, 2−position switch where the
position of the switch is determined by the logic levels
supplied to the Select input. The logic equations for the
outputs are shown below:
Za = OE•(I1a•S+I0a•S)
Zb = OE•(I1b•S+I0b•S)
Zc = OE•(I1c•S+I0c•S)
Zd = OE•(I1d•S+I0d•S)
When the Output Enable input (OE) is HIGH, the outputs
are forced to a high impedance state. If the outputs are tied
together, all but one device must be in the high impedance
state to avoid high currents that would exceed the maximum
ratings. Designers should ensure the Output Enable signals
to 3−state devices whose outputs are tied together are
designed so there is no overlap.
TRUTH TABLE
Output
Enable
Select
Input
Data
Inputs
OE
S
I0
I1
Z
H
L
L
L
L
X
H
H
L
L
X
X
X
L
H
X
L
H
X
X
Z
L
H
L
H
Outputs
H = HIGH Voltage Level
L = LOW Voltage Level
X = Immaterial
Z = High Impedance
OE I0a I1a I0b I1b I0c I1c I0d I1d
S
Za
Zb
Zc
Zd
Figure 2. Logic Symbol
OE
I0a
I1a
Za
NOTE:
I0b
I1b
I0c
Zb
I1c
Zc
I0d
I1d
Zd
This diagram is provided only for the understanding of logic operations
and should not be used to estimate propagation delays.
Figure 3. Logic Diagram
www.onsemi.com
2
S
MAXIMUM RATINGS
Symbol
Parameter
Value
Unit
−0.5 to +7.0
V
DC Input Voltage
*0.5 ≤ VCC +0.5
V
VO
DC Output Voltage (Note 1)
*0.5 ≤ VCC +0.5
V
IIK
DC Input Diode Current
±20
mA
IOK
DC Output Diode Current
±50
mA
IO
DC Output Sink/Source Current
±50
mA
ICC
DC Supply Current per Output Pin
±50
mA
IGND
DC Ground Current per Output Pin
±50
mA
TSTG
Storage Temperature Range
−65 to +150
°C
TL
Lead temperature, 1 mm from Case for 10 Seconds
260
°C
TJ
Junction temperature under Bias
+150
°C
qJA
Thermal Resistance (Note 2)
SOIC
TSSOP
69.1
103.8
°C/W
PD
Power Dissipation in Still Air at 65°C (Note 3)
SOIC
TSSOP
500
500
mW
MSL
Moisture Sensitivity
FR
Flammability Rating
VESD
ESD Withstand Voltage
Human Body Model (Note 4)
Machine Model (Note 5)
Charged Device Model (Note 6)
ILatch−Up
Latch−Up Performance
Above VCC and Below GND at 85°C (Note 7)
VCC
DC Supply Voltage
VI
Level 1
Oxygen Index: 30% − 35%
UL 94 V−0 @ 0.125 in
> 2000
> 200
> 1000
V
±100
mA
Stresses exceeding those listed in the Maximum Ratings table may damage the device. If any of these limits are exceeded, device functionality
should not be assumed, damage may occur and reliability may be affected.
1. IO absolute maximum rating must be observed.
2. The package thermal impedance is calculated in accordance with JESD51−7.
3. 500 mW at 65°C; derate to 300 mW by 10 mW/ from 65°C to 85°C.
4. Tested to EIA/JESD22−A114−A.
5. Tested to EIA/JESD22−A115−A.
6. Tested to JESD22−C101−A.
7. Tested to EIA/JESD78.
RECOMMENDED OPERATING CONDITIONS
Symbol
Parameter
VCC
Supply Voltage
VIN, VOUT
DC Input Voltage, Output Voltage (Ref. to GND)
tr, tf
Input Rise and Fall Time (Note 1)
′AC Devices except Schmitt Inputs
Min
Typ
Max
Unit
′AC
2.0
5.0
6.0
′ACT
4.5
5.0
5.5
VCC
VCC @ 3.0 V
150
VCC @ 4.5 V
40
VCC @ 5.5 V
25
VCC @ 4.5 V
10
VCC @ 5.5 V
8.0
−40
25
85
°C
V
V
ns/V
tr, tf
Input Rise and Fall Time (Note 2)
′ACT Devices except Schmitt Inputs
TA
Operating Ambient Temperature Range
IOH
Output Current − High
−24
mA
IOL
Output Current − Low
24
mA
ns/V
Functional operation above the stresses listed in the Recommended Operating Ranges is not implied. Extended exposure to stresses beyond
the Recommended Operating Ranges limits may affect device reliability.
1. 1. Vin from 30% to 70% VCC; see individual Data Sheets for devices that differ from the typical input rise and fall times.
2. 2. Vin from 0.8 V to 2.0 V; see individual Data Sheets for devices that differ from the typical input rise and fall times.
www.onsemi.com
3
DC CHARACTERISTICS
Symbol
Parameter
VCC
(V)
74AC
74AC
TA = +25°C
TA =
−40°C to
+85°C
Typ
VIH
VIL
VOH
VOL
Unit
Conditions
Guaranteed Limits
Minimum High Level
Input Voltage
3.0
4.5
5.5
1.5
2.25
2.75
2.1
3.15
3.85
2.1
3.15
3.85
V
VOUT = 0.1 V
or VCC − 0.1 V
Maximum Low Level
Input Voltage
3.0
4.5
5.5
1.5
2.25
2.75
0.9
1.35
1.65
0.9
1.35
1.65
V
VOUT = 0.1 V
or VCC − 0.1 V
Minimum High Level
Output Voltage
3.0
4.5
5.5
2.99
4.49
5.49
2.9
4.4
5.4
2.9
4.4
5.4
V
3.0
4.5
5.5
2.56
3.86
4.86
2.46
3.76
4.76
3.0
4.5
5.5
0.002
0.001
0.001
0.1
0.1
0.1
0.1
0.1
0.1
3.0
4.5
5.5
0.36
0.36
0.36
0.44
0.44
0.44
Maximum Low Level
Output Voltage
IOUT = −50 mA
V
*VIN = VIL or VIH
−12 mA
IOH
−24 mA
−24 mA
IOUT = 50 mA
V
V
*VIN = VIL or VIH
12 mA
IOL
24 mA
24 mA
IIN
Maximum Input
Leakage Current
5.5
±0.1
±1.0
mA
VI = VCC, GND
IOZ
Maximum
3−State
Current
5.5
±0.5
±5.0
mA
VI (OE) = VIL, VIH
VI = VCC, GND
VO = VCC, GND
5.5
75
mA
VOLD = 1.65 V Max
5.5
−75
mA
VOHD = 3.85 V Min
5.5
8.0
80
mA
VIN = VCC or GND
IOLD
IOHD
ICC
†Minimum Dynamic
Output Current
Maximum Quiescent
Supply Current
*All outputs loaded; thresholds on input associated with output under test.
†Maximum test duration 2.0 ms, one output loaded at a time.
NOTE: IIN and ICC @ 3.0 V are guaranteed to be less than or equal to the respective limit @ 5.5 V VCC.
www.onsemi.com
4
AC CHARACTERISTICS (For Figures and Waveforms − See Section 3 of the ON Semiconductor FACT Data Book, DL138/D)
VCC*
(V)
Parameter
Symbol
74AC
74AC
TA = +25°C
CL = 50 pF
TA = −40°C
to +85°C
CL = 50 pF
Min
Typ
Max
Min
Max
Unit
Fig.
No.
tPLH
Propagation Delay
In to Zn
3.3
5.0
1.5
1.5
5.0
4.0
8.5
6.0
1.0
1.0
9.0
7.0
ns
3−5
tPHL
Propagation Delay
In to Zn
3.3
5.0
1.5
1.5
6.0
4.5
8.5
6.0
1.0
1.0
9.0
7.0
ns
3−5
tPLH
Propagation Delay
S to Zn
3.3
5.0
1.5
1.5
7.0
5.0
10.5
7.5
1.5
1.0
11.5
8.5
ns
3−6
tPHL
Propagation Delay
S to Zn
3.3
5.0
1.5
1.5
7.5
5.5
10.5
7.5
1.5
1.0
11.5
8.5
ns
3−6
tPZH
Output Enable Time
3.3
5.0
1.5
1.5
6.5
5.0
9.5
7.5
1.0
1.0
10.5
8.5
ns
3−7
tPZL
Output Enable Time
3.3
5.0
1.5
1.5
5.5
5.0
9.0
8.5
1.0
1.0
10.0
9.5
ns
3−8
tPHZ
Output Disable Time
3.3
5.0
1.5
1.5
5.5
5.0
10.0
9.0
1.0
1.0
11.0
10.0
ns
3−7
tPLZ
Output Disable Time
3.3
5.0
1.5
1.5
5.5
5.0
9.0
8.0
1.0
1.0
10.0
9.0
ns
3−8
*Voltage Range 3.3 V is 3.3 V ±0.3 V.
*Voltage Range 5.0 V is 5.0 V ±0.5 V.
www.onsemi.com
5
DC CHARACTERISTICS
Symbol
Parameter
VCC
(V)
74ACT
74ACT
TA = +25°C
TA =
−40°C to
+85°C
Typ
Guaranteed Limits
Unit
Conditions
VIH
Minimum High Level
Input Voltage
4.5
5.5
1.5
1.5
2.0
2.0
2.0
2.0
V
VOUT = 0.1 V
or VCC − 0.1 V
VIL
Maximum Low Level
Input Voltage
4.5
5.5
1.5
1.5
0.8
0.8
0.8
0.8
V
VOUT = 0.1 V
or VCC − 0.1 V
VOH
Minimum High Level
Output Voltage
4.5
5.5
4.49
5.49
4.4
5.4
4.4
5.4
V
4.5
5.5
3.86
4.86
3.76
4.76
4.5
5.5
0.001
0.001
0.1
0.1
0.1
0.1
4.5
5.5
0.36
0.36
0.44
0.44
V
*VIN = VIL or VIH
24 mA
IOL
24 mA
VOL
Maximum Low Level
Output Voltage
V
V
IOUT = −50 mA
*VIN = VIL or VIH
−24 mA
IOH
−24 mA
IOUT = 50 mA
IIN
Maximum Input
Leakage Current
5.5
±0.1
±1.0
mA
VI = VCC, GND
DICCT
Additional Max. ICC/Input
5.5
0.6
1.5
mA
VI = VCC − 2.1 V
IOZ
Maximum
3−State
Current
5.5
±0.5
±5.0
mA
VI (OE) = VIL, VIH
VI = VCC, GND
VO = VCC, GND
5.5
75
mA
VOLD = 1.65 V Max
5.5
−75
mA
VOHD = 3.85 V Min
5.5
8.0
80
mA
VIN = VCC or GND
IOLD
IOHD
ICC
†Minimum Dynamic
Output Current
Maximum Quiescent
Supply Current
www.onsemi.com
6
VCC*
(V)
Parameter
Symbol
74ACT
74ACT
TA = +25°C
CL = 50 pF
TA = −40°C
to +85°C
CL = 50 pF
Min
Typ
Max
Min
Max
Unit
Fig.
No.
tPLH
Propagation Delay
In to Zn
5.0
1.5
5.0
7.0
1.0
7.5
ns
3−6
tPHL
Propagation Delay
In to Zn
5.0
2.0
6.0
7.5
1.5
8.5
ns
3−6
tPLH
Propagation Delay
S to Zn
5.0
2.0
7.0
9.5
1.5
10.5
ns
3−6
tPHL
Propagation Delay
S to Zn
5.0
2.5
7.0
10.5
2.0
11.5
ns
3−6
tPZH
Output Enable Time
5.0
2.0
6.0
8.0
1.5
9.0
ns
3−7
tPZL
Output Enable Time
5.0
2.0
6.0
8.0
1.5
9.0
ns
3−8
tPHZ
Output Disable Time
5.0
2.5
6.5
9.0
1.5
10.0
ns
3−7
tPLZ
Output Disable Time
5.0
2.0
6.0
7.5
1.5
8.5
ns
3−8
CAPACITANCE
Symbol
Parameter
Value
Typ
Unit
Test Conditions
CIN
Input Capacitance
4.5
pF
VCC = 5.0 V
CPD
Power Dissipation Capacitance
50
pF
VCC = 5.0 V
Package
Shipping†
MC74AC257DG
SOIC−16
(Pb−Free)
48 Units / Rail
MC74AC257DR2G
SOIC−16
(Pb−Free)
2500 / Tape & Reel
MC74AC257DTR2G
TSSOP−16
(Pb−Free)
2500 / Tape & Reel
MC74ACT257DG
SOIC−16
(Pb−Free)
48 Units / Rail
MC74ACT257DR2G
SOIC−16
(Pb−Free)
2500 / Tape & Reel
MC74ACT257DTR2G
TSSOP−16
(Pb−Free)
2500 / Tape & Reel
Device Order Number
†For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specifications Brochure, BRD8011/D.
www.onsemi.com
7
PACKAGE DIMENSIONS
TSSOP−16
DT SUFFIX
CASE 948F
ISSUE B
16X K REF
0.10 (0.004)
0.15 (0.006) T U
M
T U
S
V
S
S
K
ÉÉÉ
ÇÇÇ
ÇÇÇ
ÉÉÉ
K1
2X
L/2
16
9
J1
B
−U−
L
SECTION N−N
J
PIN 1
IDENT.
N
0.25 (0.010)
8
1
M
0.15 (0.006) T U
S
A
−V−
NOTES:
1. DIMENSIONING AND TOLERANCING PER
ANSI Y14.5M, 1982.
2. CONTROLLING DIMENSION: MILLIMETER.
3. DIMENSION A DOES NOT INCLUDE MOLD
FLASH. PROTRUSIONS OR GATE BURRS.
MOLD FLASH OR GATE BURRS SHALL NOT
EXCEED 0.15 (0.006) PER SIDE.
4. DIMENSION B DOES NOT INCLUDE
INTERLEAD FLASH OR PROTRUSION.
INTERLEAD FLASH OR PROTRUSION SHALL
NOT EXCEED 0.25 (0.010) PER SIDE.
5. DIMENSION K DOES NOT INCLUDE DAMBAR
PROTRUSION. ALLOWABLE DAMBAR
PROTRUSION SHALL BE 0.08 (0.003) TOTAL
IN EXCESS OF THE K DIMENSION AT
MAXIMUM MATERIAL CONDITION.
6. TERMINAL NUMBERS ARE SHOWN FOR
REFERENCE ONLY.
7. DIMENSION A AND B ARE TO BE
DETERMINED AT DATUM PLANE −W−.
N
F
DETAIL E
−W−
C
0.10 (0.004)
−T− SEATING
PLANE
H
D
DETAIL E
G
DIM
A
B
C
D
F
G
H
J
J1
K
K1
L
M
MILLIMETERS
MIN
MAX
4.90
5.10
4.30
4.50
1.20
0.05
0.15
0.50
0.75
0.65 BSC
0.18
0.28
0.09
0.20
0.09
0.16
0.19
0.30
0.19
0.25
6.40 BSC
0_
8_
SOLDERING FOOTPRINT*
7.06
1
0.65
PITCH
16X
0.36
16X
1.26
DIMENSIONS: MILLIMETERS
*For additional information on our Pb−Free strategy and soldering
details, please download the ON Semiconductor Soldering and
Mounting Techniques Reference Manual, SOLDERRM/D.
www.onsemi.com
8
INCHES
MIN
MAX
0.193 0.200
0.169 0.177
−−− 0.047
0.002 0.006
0.020 0.030
0.026 BSC
0.007
0.011
0.004 0.008
0.004 0.006
0.007 0.012
0.007 0.010
0.252 BSC
0_
8_
PACKAGE DIMENSIONS
SOIC−16
D SUFFIX
CASE 751B−05
ISSUE K
−A−
16
NOTES:
1. DIMENSIONING AND TOLERANCING PER ANSI
Y14.5M, 1982.
3. DIMENSIONS A AND B DO NOT INCLUDE MOLD
PROTRUSION.
4. MAXIMUM MOLD PROTRUSION 0.15 (0.006) PER SIDE.
5. DIMENSION D DOES NOT INCLUDE DAMBAR
PROTRUSION. ALLOWABLE DAMBAR PROTRUSION
SHALL BE 0.127 (0.005) TOTAL IN EXCESS OF THE D
DIMENSION AT MAXIMUM MATERIAL CONDITION.
9
−B−
1
P
8 PL
0.25 (0.010)
8
B
M
S
G
R
K
F
X 45 _
C
−T−
SEATING
PLANE
J
M
D
DIM
A
B
C
D
F
G
J
K
M
P
R
MILLIMETERS
MIN
MAX
9.80
10.00
3.80
4.00
1.35
1.75
0.35
0.49
0.40
1.25
1.27 BSC
0.19
0.25
0.10
0.25
0_
7_
5.80
6.20
0.25
0.50
INCHES
MIN
MAX
0.386
0.393
0.150
0.157
0.054
0.068
0.014
0.019
0.016
0.049
0.050 BSC
0.008
0.009
0.004
0.009
0_
7_
0.229
0.244
0.010
0.019
16 PL
0.25 (0.010)
M
T B
S
A
S
8X
6.40
16X
1
1.12
16
16X
0.58
1.27
PITCH
8
9
ON Semiconductor and the
are registered trademarks of Semiconductor Components Industries, LLC (SCILLC) or its subsidiaries in the United States and/or other countries.
SCILLC owns the rights to a number of patents, trademarks, copyrights, trade secrets, and other intellectual property. A listing of SCILLC’s product/patent coverage may be accessed
at www.onsemi.com/site/pdf/Patent−Marking.pdf. SCILLC reserves the right to make changes without further notice to any products herein. SCILLC makes no warranty, representation
or guarantee regarding the suitability of its products for any particular purpose, nor does SCILLC assume any liability arising out of the application or use of any product or circuit, and
specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in SCILLC data sheets
and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each
customer application by customer’s technical experts. SCILLC does not convey any license under its patent rights nor the rights of others. SCILLC products are not designed, intended,
or authorized for use as components in systems intended for surgical implant into the body, or other applications intended to support or sustain life, or for any other application in which
the failure of the SCILLC product could create a situation where personal injury or death may occur. Should Buyer purchase or use SCILLC products for any such unintended or
unauthorized application, Buyer shall indemnify and hold SCILLC and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and
expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim
alleges that SCILLC was negligent regarding the design or manufacture of the part. SCILLC is an Equal Opportunity/Affirmative Action Employer. This literature is subject to all applicable
copyright laws and is not for resale in any manner.
PUBLICATION ORDERING INFORMATION
LITERATURE FULFILLMENT:
Literature Distribution Center for ON Semiconductor
P.O. Box 5163, Denver, Colorado 80217 USA
Phone: 303−675−2175 or 800−344−3860 Toll Free USA/Canada
Fax: 303−675−2176 or 800−344−3867 Toll Free USA/Canada
Email: orderlit@onsemi.com
N. American Technical Support: 800−282−9855 Toll Free
USA/Canada
Europe, Middle East and Africa Technical Support:
Phone: 421 33 790 2910
Japan Customer Focus Center
Phone: 81−3−5817−1050
www.onsemi.com
9
ON Semiconductor Website: www.onsemi.com
Order Literature: http://www.onsemi.com/orderlit
For additional information, please contact your local
Sales Representative
MC74AC257/D
