IS31FL3730-QFLS2-TR
IS31FL3730-QFLS2-TR
    LUMISSIL
    VFQFN24
    IC MATRIX LED DRIVER AUDIO 24QFN
IS31FL3730-QFLS2-TR 数据手册
IS31FL3730 AUDIO MODULATED MATRIX LED DRIVER May 2018 GENERAL DESCRIPTION FEATURES IS31FL3730 is a LED matrix driver which features an audio modulation display mode and a general LED dot matrix display mode. The default configuration of IS31FL3730 is to drive a single 8×8 LED matrix. However, IS31FL3730 may be configured to drive either one or two 8×8, 7×9, 6×10, or 5×11 dot matrix display(s). The intensity of any matrix picture can be modulated by an audio signal.   In matrix display mode, the rows and columns of the matrix are internally scanned, requiring only one time programming of the individual LED on or off state, thus eliminating the need for real time system resource utilization to perform the row and column scanning function. In the general purpose mode, the ON or OFF condition of each individual LED in the display matrix is programmed via an I2C interface. IS31FL3730 is available in QFN-24 (4mm × 4mm). It operates from 2.7V to 5.5V over the temperature range of -40°C to +85°C.           2.7V to 5.5V supply I2C interface, automatic address increment function Rising edge of SDB reset I2C module Internal reset register Programmable single or dual 8×8, 7×9, 6×10, or 5×11 LED matrix display mode One-time programming, internal scan Audio modulated display intensity with digitally programmable input gain Internal registers to digitally adjust display intensity Modulate LED brightness with 128 different items in PWM One address pin with 4 options to allow four I2C slave addresses Over-temperature protection QFN-24 (4mm × 4mm) package APPLICATIONS   Mobile phones and other hand-held devices for LED display LED in home appliances TYPICAL APPLICATION CIRCUIT Figure 1 Typical Application Circuit Dual 8×8 Note 1: The IC should be placed far away from the mobile antenna in order to prevent the EMI. Lumissil Microsystems – www.lumissil.com Rev. C, 04/02/2018 1 IS31FL3730 Figure 2 Typical Application Circuit Dual 7×9 Figure 3 Typical Application Circuit Dual 6×10 Figure 4 Typical Application Circuit Dual 5×11 Lumissil Microsystems – www.lumissil.com Rev. C, 04/02/2018 2 IS31FL3730 PIN CONFIGURATION Package Pin Configuration (Top View) QFN-24 PIN DESCRIPTION No. Pin Description 1 SDA I2C serial data. 2 SCL I2C serial clock. 3 SDB Shutdown the chip when pull to low. 4 IN Audio input. 5 C_FILT Filter cap for audio control. 6 AD I2C address setting. 7~10, 12 R1~R5 Row control. 11 VCC Power supply. 13~15 R6/C11, R7/C10, R8/C9 Row/column control. 16~19, 21~24 C8~C5, C4~C1 Column control. 20 GND Ground. Thermal Pad Connect to GND. Lumissil Microsystems – www.lumissil.com Rev. C, 04/02/2018 3 IS31FL3730 ORDERING INFORMATION Industrial Range: -40°C to +85°C Order Part No. Package QTY/Reel IS31FL3730-QFLS2-TR QFN-24, Lead-free 2500 Copyright  ©  2018  Lumissil  Microsystems.  All  rights  reserved.  Lumissil Microsystems reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use in  such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances Lumissil Microsystems – www.lumissil.com Rev. C, 04/02/2018 4 IS31FL3730 ABSOLUTE MAXIMUM RATINGS Supply voltage, VCC Voltage at any input pin Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TA=TJ Package thermal resistance, junction to ambient (4 layer standard test PCB based on JEDEC standard), θJA ESD (HBM) ESD (CDM) -0.3V ~ +6.0V -0.3V ~ VCC+0.3V +150°C -65°C ~ +150°C -40°C ~ +85°C 29.5°C/W ±1kV ±1kV Note 2: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS TA= -40°C ~ +85°C, VCC= 2.7V ~ 5.5V, unless otherwise noted. Typical value are TA= 25°C, VCC= 3.6V. Symbol Parameter VCC Supply voltage ICC Quiescent power supply current ISD Shutdown current IOUT VHR tSCAN tSCANOL Condition Min. Typ. 2.7 Max. Unit 5.5 V VIN= 0V, without audio input, all LEDs off 7.0 VSDB= 0V 1.7 3.0 VSDB= VCC, software shutdown 1.7 3.0 Matrix display mode without audio modulation, Lighting Effect Register(0Dh) = 0xxx 0000 (Note 3) 40 Matrix display mode with audio modulation, VIN= 2.5VP-P, 1kHz square wave Audio Gain= 0dB (Note 3) 40 Current sink headroom voltage R1~R8,C1~C8 ISINK= 320mA 300 Current source headroom voltage R1~R8,C1~C8 ISOURCE= 40mA 200 Output current of R1~R8, C1~C8 mA μA mA mV Period of row and column scanning (Figure 10) 32 µs Non-overlap blanking time during row and column (Note 4) scan (Figure 10) 1 µs Logic Electrical Characteristics (SDA, SCL, AD) VIL Logic “0” input voltage VCC = 2.7V~5.5V VIH Logic “1” input voltage VCC = 2.7V~5.5V IIL Logic “0” input current VIN = 0V (Note 4) 5 nA IIH Logic “1” input current VIN = VCC (Note 4) 5 nA Lumissil Microsystems – www.lumissil.com Rev. C, 04/02/2018 0.4 1.4 V V 5 IS31FL3730 DIGITAL INPUT SWITCHING CHARACTERISTICS (Note 4) Symbol Parameter Condition Min. Typ. Max. Units 400 kHz fSCL Serial-Clock frequency tBUF Bus free time between a STOP and a START condition 1.3 μs tHD, STA Hold time (repeated) START condition 0.6 μs tSU, STA Repeated START condition setup time 0.6 μs tSU, STO STOP condition setup time 0.6 μs tHD, DAT Data hold time tSU, DAT Data setup time 100 ns tLOW SCL clock low period 1.3 μs tHIGH SCL clock high period 0.7 μs (Note 5) 0 0.9 μs tR Rise time of both SDA and SCL signals, receiving (Note 6) 20+0.1Cb 300 ns tF Fall time of both SDA and SCL signals, receiving (Note 6) 20+0.1Cb 300 ns Note 3: Due to the row and column scanning sequence, the average current of an individual LED in the display is IOUT/8 when configured to drive a single matrix. When configured to drive two matrices, the average current of an individual LED in the display is IOUT/16. Note 4: Guaranteed by design. Note 5: The minimum tHD, DAT measured start from VIL(max) of SCL signal. The maximum tHD,DAT has only to be met if the device does not stretch the LOW period (tLOW) of the SCL signal. VIL(max) Note 6: Cb = total capacitance of one bus line in pF. ISINK ≤ 6mA. tR and tF measured between 0.3×VCC and 0.7×VCC. Lumissil Microsystems – www.lumissil.com Rev. C, 04/02/2018 6 IS31FL3730 FUNCTIONAL BLOCK DIAGRAM C_FILT IN VCC SDB Audio Modulation SCL SDA I2C Interface Register OSC Sequence Control Current Control AD Current Source Current Switch Current Source Current Switch C1~C8 R1~R8 GND Lumissil Microsystems – www.lumissil.com Rev. C, 04/02/2018 7 IS31FL3730 DETAILED DESCRIPTION After the last bit of the chip address is sent, the master checks for the IS31FL3730’s acknowledge. The master releases the SDA line high (through a pull-up resistor). Then the master sends an SCL pulse. If the IS31FL3730 has received the address correctly, then it holds the SDA line low during the SCL pulse. If the SDA line is not low, then the master should send a “STOP” signal (discussed later) and abort the transfer. I2C INTERFACE The IS31FL3730 uses a serial bus, which conforms to the I2C protocol, to control the chip’s functions with two wires: SCL and SDA. The IS31FL3730 has a 7-bit slave address (A7:A1), followed by the R/W bit, A0. Since IS31FL3730 only supports write operations, A0 must always be 0. The value of bits A1 and A2 are decided by the connection of the AD pin. Following acknowledge of IS31FL3730, the register address byte is sent, most significant bit first. IS31FL3730 must generate another acknowledge indicating that the register address has been received. The complete slave address is: Table 1 Slave Address (Write Only): Bit A7:A3 A2:A1 A0 Value 11000 AD 0 Then 8-bit of data byte are sent next, most significant bit first. Each data bit should be valid while the SCL level is stable high. After the data byte is sent, the IS31FL3730 must generate another acknowledge to indicate that the data was received. AD connected to GND, AD=00; AD connected to VCC, AD=11; AD connected to SCL, AD=01; AD connected to SDA, AD=10; The “STOP” signal ends the transfer. To signal “STOP”, the SDA signal goes high while the SCL signal is high. The SCL line is uni-directional. The SDA line is bi-directional (open-collector) with a pull-up resistor (typically 4.7kΩ). The maximum clock frequency specified by the I2C standard is 400kHz. In this discussion, the master is the microcontroller and the slave is the IS31FL3730. Address Auto Increment The timing diagram for the I2C is shown in Figure 5. The SDA is latched in on the stable high level of the SCL. When there is no interface activity, the SDA line should be held high. The “START” signal is generated by lowering the SDA signal while the SCL signal is high. The start signal will alert all devices attached to the I2C bus to check the incoming address against their own chip address. To write multiple bytes of data into IS31FL3730, load the address of the data register that the first data byte is intended for. During the IS31FL3730 acknowledge of receiving the data byte, the internal address pointer will increment by one. The next data byte sent to IS31FL3730 will be placed in the new address, and so on. The auto increment of the address will continue as long as data continues to be written to IS31FL3730. This feature is useful for loading the LED on/off condition for each of the display matrices as a burst of data. Pay careful attention when loading data for dual LED matrix displays since the register addressing is not continuous. The 8-bit chip address is sent next, most significant bit first. Each address bit must be stable while the SCL level is high. Figure 5 Interface Timing Figure 6 Lumissil Microsystems – www.lumissil.com Rev. C, 04/02/2018 Bit Transfer 8 IS31FL3730 Figure 7 Writing to IS31FL3730(Typical) Writing to IS31FL3730(Automatic Address Increment) Figure 8 REGISTER DEFINITION Table 2 Register Function Address Name Function Table Default 0000 0000 00h Configuration Register Set operation mode of IS31FL3730 3 01h~0Bh Matrix 1 Data Register Store the on or off state of each LED 4 0Eh~18h Matrix 2 Data Register Store the on or off state of each LED 5 0Ch Update Column Register Make the Data Register update the data - xxxx xxxx 0Dh Lighting Effect Register Store the intensity control settings 6 0000 0000 19h PWM Register Modulate LED light with 128 different items 7 1000 0000 FFh Reset Register Reset all registers to default value - xxxx xxxx Table 3 00h Configuration Register Bit D7 D6:D5 D4:D3 D2 D1:D0 Name SSD - DM A_EN ADM Default 0 00 00 0 00 The Configuration Register sets operation mode of IS31FL3730. SSD 0 1 Software Shutdown Enable Normal operation Software shutdown mode DM 00 01 11 Display Mode Matrix 1 only Matrix 2 only Matrix 1 and Matrix 2 Lumissil Microsystems – www.lumissil.com Rev. C, 04/02/2018 0000 0000 A_EN Audio Input Enable 0 Matrix intensity is controlled by the current setting in the Lighting Effect Register (0Dh) 1 Enable audio signal to modulate the intensity of the matrix ADM 00 01 10 11 Matrix Mode Selection 8×8 dot matrix display mode 7×9 dot matrix display mode 6×10 dot matrix display mode 5×11 dot matrix display mode 9 IS31FL3730 Table 4 01h~0Bh Matrix 1 Data Register(C1~C11) Bit D7:D0 Name R8:R1 Default 00000000 Table 5 0Eh~18h Matrix 2 Data Register(C1~C11) Bit D7:D0 Name R8:R1 Default 00000000 Full Current Setting for Each Row Output 40mA 45mA 75mA 5mA 10mA 35mA Not Available Table 7 19h PWM Register The Data Registers (Matrix 1/Matrix 2) store the on or off state of each LED in the Matrix. LED State LED off LED on Rx 0 1 CS 0000 0001 ... ... 0111 1000 1001 ... ... 1110 Others 11×2 registers are assigned to C1~C11 columns respectively; the LED at a particular (row, column) location will be turned on when the respective data is set to “1”. When configured for more than 8 column operation, only the required numbers of LSBs are used in each data register. For example, in 5×11 dot matrix mode, only bits R1 thru R5 are used, and bits R6 thru R8 are ignored. Bit D7 D6:D0 Default 1 0000000 The PWM Register can modulate LED light with 128 different items. When the D7 set to “1”, the PWM is the 128 item. When the D7 set to “0”, D6:D0 set the PWM from the 0 item to the 127 item. For example, if the data in PWM Register is 0000 0100, then the PWM is the 4 item. 0Ch Update Column Register The data sent to the Data Registers will be stored in temporary registers. A write operation of “0000 0000” value to the Update Column Register is required to update the Data Registers (01h~0Bh, 0Eh~18h). Table 6 0Dh Lighting Effect Register Bit D7 D6:D4 D3:D0 Name - AGS CS Default 0 000 0000 The Lighting Effect Register stores the intensity control settings for all of the LEDs in the Matrix. AGS 000 001 010 011 100 101 110 111 Figure 9 PWM Timing Diagram Software shutdown and hardware shutdown operation will reset the PWM Register. When restart the IC, the register value will reset to 0x80 and if previous setting is not this value, need to rewrite the PWM Register. FFh Reset Register Once user writes “0000 0000” to the Reset Register, IS31FL3730 will reset all registers to default value. On initial power-up, the IS31FL3730 registers are reset to their default values for a blank display. Audio Input Gain Selection Gain= 0dB Gain= +3dB Gain= +6dB Gain= +9dB Gain= +12dB Gain= +15dB Gain= +18dB Gain= -6dB Lumissil Microsystems – www.lumissil.com Rev. C, 04/02/2018 10 IS31FL3730 APPLICATION INFORMATION GENERAL PURPOSE DOT MATRIX DISPLAY MODE DUAL 5×11 DOT MATRIX DISPLAY MODE The general purpose dot matrix display timing diagram is shown in Figure 10. IS31FL3730 may be configured to drive displays of different dimensions from 8×8 to 5×11. Furthermore, IS31FL3730 may be configured to drive one or two LED matrices of the same dimension. Therefore, the overall row and column scan time can vary based on the final LED matrix configuration. By setting the ADM bits of the Configuration Register (00h) to “11” and the DM bits to “11”, the IS31FL3730 will operate in the dual 5×11 LED dot matrix display mode. In any LED matrix configuration, a single line (column or row) of LEDs is illuminated for 32µs before IS31FL3730 moves on to the next line of LEDs (Figure 10). Example 1: When the IS31FL3730 is configured in the general purpose dual 8×8 dot matrix display mode, column controls C8:C1 scans the eight columns of Matrix 1 then row controls R8:R1 scans the eight rows of Matrix 2 at a rate of 1.89kHz, or 528µs per frame. Each line is active for 32µs. The non-overlap interval between adjacent lines is 1µs. Example 2: When configured to drive a single 7×9 dot matrix display (Matrix 1), the column controls C9:C1 scan the nine columns every 297µs. Also note that in this case, the Data Registers’ MSB will be ignored. The Matrix 1 LED columns have common cathodes and are connected to the C1:C11 outputs. The rows are connected to the row drivers. The Matrix 2 LED rows have common cathodes and are connected to the R1:R5 outputs. The columns are connected to the column drivers. Each of the 110 LEDs can be addressed separately. The three MSBs (D7:D5) of each Data Register (01h~0Bh, 0Eh~18h) are ignored. DOT MATRIX MODULATION DISPLAY MODE WITH AUDIO When the IS31FL3730 operates in any of the dot matrix modes, if the bit A_EN in Configuration Register (00h) is set to “1”, the brightness of LED image can be modulated by audio signal not controlled by the CS bit in Lighting Effect Register (0Dh). An external capacitor, C_FILT is required to control the rate at which the display intensity will change. The rate of change is computed using the formula: ∆T = C×500kΩ. A value of 0.1µF provides a good effect by allowing the display to fade from full intensity to off in approximately 50ms. Smaller capacitance will cause the intensity to change more quickly, and, conversely, a larger capacitance will cause the display intensity to change at a slower rate. SHUTDOWN MODE Figure 10 Dot Matrix Display Timing Diagram DUAL 8×8 DOT MATRIX DISPLAY MODE The application example in Figure 1 shows the IS31FL3730 in the dual 8×8 LED dot matrix display mode. The Matrix 1 LED columns have common cathodes and are connected to the C1:C8 outputs. The rows are connected to the row drivers. The Matrix 2 LED rows have common cathodes and connected to the R1:R8. The columns are connected to the C1:C8. Each of the 128 LEDs can be addressed separately. Lumissil Microsystems – www.lumissil.com Rev. C, 04/02/2018 Shutdown mode can either be used as a means of reducing power consumption or generating a flashing display (repeatedly entering and leaving shutdown mode). During shutdown mode all registers retain their data. Software Shutdown By setting SSD bit of the Configuration Register (00h) to “1”, the IS31FL3730 will operate in software shutdown mode, wherein they consume only 1.7μA (Typ.) current. When the IS31FL3730 is in software shutdown mode, all current sources and digital drivers are switched off, so that the matrix is blanked. Hardware Shutdown The chip enters hardware shutdown mode when the SDB pin is pulled low. 11 IS31FL3730 CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) 150°C 200°C 60-120 seconds Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) Time at liquidous (tL) 217°C 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified classification temperature (Tc) Max 30 seconds Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature 8 minutes max. Figure 11 Classification Profile Lumissil Microsystems – www.lumissil.com Rev. C, 04/02/2018 12 IS31FL3730 PACKAGE INFORMATION QFN-24 Lumissil Microsystems – www.lumissil.com Rev. C, 04/02/2018 13 IS31FL3730 RECOMMENDED LAND PATTERN QFN-24 Note: 1. Land pattern complies to IPC-7351. 2. All dimensions in MM. 3. This document (including dimensions, notes & specs) is a recommendation based on typical circuit board manufacturing parameters. Since land pattern design depends on many factors unknown (eg. user’s board manufacturing specs), user must determine suitability for use. Lumissil Microsystems – www.lumissil.com Rev. C, 04/02/2018 14 IS31FL3730 REVISION HISTORY Revision Detail Information Date A Initial release 2011.12.19 B 1. Add land pattern 2. Add ESD and θJA value 3. Update POD 4. Add functional block 5. Add description for 19h register 6. EC table VIH and VIL test condition has been changed to 2.7V~5.5V 2017.12.13 C 1. Update ISD hardware shutdown value 2. Add Note 4 for tSCANOL 3. Add SDB rise edge reset I2C function 4. Update function block 5. Update note number 2018.04.02 Lumissil Microsystems – www.lumissil.com Rev. C, 04/02/2018 15
IS31FL3730-QFLS2-TR 价格&库存
很抱歉,暂时无法提供与“IS31FL3730-QFLS2-TR”相匹配的价格&库存,您可以联系我们找货
IS31FL3730-QFLS2-TR
  • 2500+4.495552500+0.56257
  • 5000+4.386325000+0.54891
  • 7500+4.331687500+0.54207
  • 12500+4.2710812500+0.53448
  • 17500+4.2356517500+0.53005
库存:4067
IS31FL3730-QFLS2-TR
  • 1+9.450791+1.18267
  • 10+6.7854510+0.84913
  • 25+6.1262425+0.76664
  • 100+5.40235100+0.67605
  • 250+5.05696250+0.63283
  • 500+4.84838500+0.60673
  • 1000+4.676781000+0.58525
库存:4067
