74HC367; 74HCT367
Hex buffer/line driver; 3-state
Rev. 4 — 24 February 2021
Product data sheet
1. General description
The 74HC367; 74HCT367 is a hex buffer/line driver with 3-state outputs controlled by the output
enable inputs (nOE). A HIGH on nOE causes the outputs to assume a high impedance OFF-state.
Inputs include clamp diodes. It enables the use of current limiting resistors to interface inputs to
voltages in excess of VCC.
2. Features and benefits
Wide supply voltage range from 2.0 V to 6.0 V
CMOS low power dissipation
High noise immunity
Latch-up performance exceeds 100 mA per JESD 78 Class II Level B
Complies with JEDEC standards:
• JESD8C (2.7 V to 3.6 V)
• JESD7A (2.0 V to 6.0 V)
3-state outputs
Input levels:
• For 74HC367: CMOS level
• For 74HCT367: TTL level
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
Specified from -40 °C to +85 °C and -40 °C to +125 °C
3. Ordering information
Table 1. Ordering information
Type number Package
74HC367D
Temperature range
Name
Description
-40 °C to +125 °C
SO16
plastic small outline package; 16 leads; body width 3.9 mm SOT109-1
Version
-40 °C to +125 °C
TSSOP16 plastic thin shrink small outline package; 16 leads;
body width 4.4 mm
74HCT367D
74HC367PW
74HCT367PW
SOT403-1
74HC367; 74HCT367
Nexperia
4. Functional diagram
2
4
6
10
1
12
1A
1Y
2A
2Y
3A
3Y
4A
4Y
3
5
1
7
9
1OE
5A
5Y
6A
6Y
2
3
4
5
6
7
10
9
11
15
14
15
EN
EN
13
2OE
12
11
14
13
aaa-024816
aaa-024815
Fig. 1.
Logic symbol
Fig. 2.
IEC logic symbol
one buffer/line driver
1A
VCC
1Y
1OE
GND
2A
2Y
3A
3Y
4A
4Y
5A
5Y
2OE
6A
6Y
aaa-024817
Fig. 3.
Logic diagram
74HC_HCT367
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 14
74HC367; 74HCT367
Nexperia
5. Pinning information
5.1. Pinning
74HC367
74HCT367
1OE
1
16 VCC
1A
2
15 2OE
1Y
3
14 6A
2A
4
13 6Y
2Y
5
12 5A
3A
6
11 5Y
3Y
7
10 4A
GND
8
9
74HC367
74HCT367
4Y
1OE
1
16 VCC
1A
2
15 2OE
1Y
3
14 6A
2A
4
13 6Y
2Y
5
12 5A
3A
6
11 5Y
3Y
7
10 4A
GND
8
9
aaa-024819
aaa-024818
Fig. 4.
4Y
Pin configuration for SOT109-1 (SO16)
Fig. 5.
Pin configuration for SOT403-1 (TSSOP16)
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1OE, 2OE
1, 15
output enable input (active LOW)
1A, 2A, 3A, 4A, 5A, 6A
2, 4, 6, 10, 12, 14
data input
1Y, 2Y, 3Y, 4Y, 5Y, 6Y
3, 5, 7, 9, 11, 13
bus output
GND
8
ground (0 V)
VCC
16
supply voltage
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
Output
Input
nOE
nA
nY
L
L
L
L
H
H
H
X
Z
74HC_HCT367
Product data sheet
3 / 14
74HC367; 74HCT367
Nexperia
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
IOK
IO
ICC
Min
Max
-0.5
+7
V
VI < -0.5 V or VI > VCC + 0.5 V
±20
mA
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
±20
mA
output current
-0.5 V < VO < VCC + 0.5 V
±35
mA
supply current
70
mA
IGND
ground current
-70
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
Conditions
[1]
Unit
For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C.
For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C.
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
74HC_HCT367
Product data sheet
Conditions
74HC367
74HCT367
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
VCC
V
VCC
VCC
V
-40
+25
+125
-40
+25
+125
°C
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
4 / 14
74HC367; 74HCT367
Nexperia
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C -40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
VCC = 4.5 V
3.15
2.4
1.5
3.15
1.5
V
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
74HC367
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
VI = VIH or VIL
HIGH-level
output voltage
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = -6.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = -7.8 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
VI = VIH or VIL
LOW-level
output voltage
IO = 20 μA; VCC = 2.0 V
0.1
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
0.1
V
IO = 6.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 7.8 mA; VCC = 6.0 V
0.16
0.26
0.33
0.4
V
±0.1
±1.0
±1.0
μA
II
input leakage
current
IOZ
OFF-state
VI = VIH or VIL; VCC = 6.0 V;
output current VO = VCC or GND
±0.5
±5.0
±10
μA
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
8.0
80
160
μA
CI
input
capacitance
3.5
pF
74HC_HCT367
Product data sheet
VI = VCC or GND; VCC = 6.0 V
5 / 14
74HC367; 74HCT367
Nexperia
Symbol Parameter
Conditions
25 °C
Min
Typ
Max
Min
Max
Min
Max
74HCT367
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
VI = VIH or VIL; VCC = 4.5 V
HIGH-level
output voltage
IO = -20 μA
4.4
4.5
4.4
4.4
V
3.98
4.32
3.84
3.7
V
0.1
0.1
V
0.16
0.26
0.33
0.4
V
±0.1
±1.0
±1.0
μA
IO = -6 mA
VOL
LOW-level
output voltage
IO = 20 μA
IO = 6.0 mA
II
input leakage
current
IOZ
OFF-state
VI = VIH or VIL; VCC = 5.5 V;
±0.5
±5.0
±10
μA
ICC
supply current VI = VCC or GND; VCC = 5.5 V;
IO = 0 A
8.0
80
160
μA
ΔICC
per input pin; VI = VCC - 2.1 V;
additional
supply current other inputs at VCC or GND;
VCC = 4.5 V to 5.5 V; IO = 0 A
1OE, nA inputs
100
360
450
490
μA
2OE input
90
324
405
441
μA
3.5
pF
CI
input
capacitance
74HC_HCT367
Product data sheet
6 / 14
74HC367; 74HCT367
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Fig. 8.
Symbol Parameter
Conditions
25 °C
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
28
95
120
145
ns
VCC = 4.5 V
10
19
24
29
ns
VCC = 5.0 V; CL = 15 pF
8
ns
VCC = 6.0 V
8
16
ns
VCC = 2.0 V
44
150
190
225
ns
VCC = 4.5 V
16
30
38
45
ns
VCC = 6.0 V
13
26
33
38
ns
VCC = 2.0 V
55
150
190
225
ns
VCC = 4.5 V
38
45
ns
VCC = 6.0 V
16
26
33
38
ns
VCC = 2.0 V
14
60
75
90
ns
VCC = 4.5 V
5
12
15
18
ns
VCC = 6.0 V
4
10
13
15
ns
30
pF
VCC = 4.5 V
14
25
31
38
ns
11
ns
74HC367
tpd
propagation
delay
ten
enable time
tdis
disable time
nA to nY; see Fig. 6
[1]
nOE to nY; see Fig. 7
[1]
[1]
transition time see Fig. 6
tt
CPD
power
dissipation
capacitance
[1]
per buffer; VI = GND to VCC [2]
74HCT367
tpd
propagation
delay
[1]
ten
enable time
nOE to nY; VCC = 4.5 V;
see Fig. 7
[1]
16
35
44
53
ns
tdis
disable time
see Fig. 7
[1]
21
35
44
53
ns
tt
transition time VCC = 4.5 V; see Fig. 6
[1]
5
12
15
18
ns
CPD
power
dissipation
capacitance
[2]
32
pF
[1]
[2]
per buffer;
VI = GND to VCC - 1.5 V
tpd is the same as tPHL and tPLH; ten is the same as tPZH and tPZL; tdis is the same as tPHZ and tPLZ; tt is the same as tTHL and tTLH.
CPD is used to determine the dynamic power dissipation (PD in μW):
2
2
PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL x VCC x fo) = sum of outputs.
74HC_HCT367
Product data sheet
7 / 14
74HC367; 74HCT367
Nexperia
10.1. Waveforms and test circuit
VI
VM
nA input
VM
GND
tPHL
VOH
tPLH
90 %
VM
nY output
VM
10 %
VOL
tTHL
tTLH
aaa-024820
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 6.
Input (nA) to output (nY) propagation delays and output transition times
VI
nOE input
VM
GND
tPLZ
nY output
LOW-to-OFF
OFF-to-LOW
tPZL
VCC
VM
VX
VOL
tPHZ
nY output
HIGH-to-OFF
OFF-to-HIGH
VOH
tPZH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
aaa-024821
Fig. 7.
3-state enable and disable times
Table 8. Measurement points
Input
Type
Output
VM
VM
VX
VY
74HC367
0.5 × VCC
0.5 × VCC
0.1 × VCC
0.9 × VCC
74HCT367
1.3 V
1.3 V
0.1 × VCC
0.9 × VCC
74HC_HCT367
Product data sheet
8 / 14
74HC367; 74HCT367
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
VCC
VO
DUT
RT
RL
S1
open
CL
001aad983
Test data is given in Table 9.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
S1 = Test selection switch.
Fig. 8.
Test circuit for measuring switching times
Table 9. Test data
Type
Input
Load
S1 position
VI
tr, tf
CL
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
74HC367
VCC
6 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74HCT367
3V
6 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74HC_HCT367
Product data sheet
9 / 14
74HC367; 74HCT367
Nexperia
11. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
w M
bp
detail X
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.16
0.15
0.05
0.039
0.016
0.028
0.020
0.01
0.01
0.004
0.028
0.012
0.244
0.041
0.228
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig. 9.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Package outline SOT109-1 (SO16)
74HC_HCT367
Product data sheet
10 / 14
74HC367; 74HCT367
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 10. Package outline SOT403-1 (TSSOP16)
74HC_HCT367
Product data sheet
11 / 14
74HC367; 74HCT367
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT367 v.4
20210224
Product data sheet
74HC_HCT367 v.3
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Section 2 updated.
Section 7: Derating values for Ptot total power dissipation updated.
Type numbers 74HC367DB and 74HCT367DB (SOT338-1 / SSOP16) removed.
74HC_HCT367 v.3
20161017
Modifications:
74HC_HCT367_CNV v.2
74HC_HCT367
Product data sheet
Product data sheet
74HC_HCT367_CNV v.2
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Type numbers 74HC367N and 74HCT367N removed.
19901201
Product specification
12 / 14
74HC367; 74HCT367
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74HC_HCT367
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
13 / 14
74HC367; 74HCT367
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 3
6. Functional description................................................. 3
7. Limiting values............................................................. 4
8. Recommended operating conditions..........................4
9. Static characteristics....................................................5
10. Dynamic characteristics............................................ 7
10.1. Waveforms and test circuit........................................ 8
11. Package outline........................................................ 10
12. Abbreviations............................................................ 12
13. Revision history........................................................12
14. Legal information......................................................13
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 24 February 2021
74HC_HCT367
Product data sheet
14 / 14
