74HC73D-Q100J
74HC73D-Q100J
    NEXPERIA(安世)
    SOIC-14
    IC FF JK TYPE DUAL 1BIT 14SO
74HC73D-Q100J 数据手册
74HC73-Q100 Dual JK flip-flop with reset; negative-edge trigger Rev. 1 — 4 December 2020 Product data sheet 1. General description The 74HC73-Q100 is a dual negative edge triggered JK flip-flop with individual J, K, clock (nCP) and reset (nR) inputs and complementary nQ and nQ outputs. The J and K inputs must be stable one set-up time prior to the HIGH-to-LOW clock transition for predictable operation. (nR) is asynchronous, when LOW it overrides the clock and data inputs, forcing the nQ output LOW and the nQ output HIGH. Schmitt-trigger action in the clock input makes the circuit highly tolerant to slower clock rise and fall times. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits • • • • • • • Automotive product qualification in accordance with AEC-Q100 (Grade 1) • Specified from -40 °C to +85 °C and from -40 °C to +125 °C CMOS low-power dissipation Wide supply voltage range from 2.0 to 6.0 V High noise immunity Latch-up performance exceeds 100 mA per JESD 78 Class II Level B Complies with JEDEC standards • JESD8C (2.7 V to 3.6 V) • JESD7A (2.0 V to 6.0 V) ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V 3. Ordering information Table 1. Ordering information Type number Package 74HC73D-Q100 Temperature range Name Description Version -40 °C to +125 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74HC73-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger 4. Functional diagram 14 1J 1 1CP 3 1K J Q 1Q 12 FF1 CP K Q 1Q 13 R 2 1R 14 1 7 2J 5 2CP 10 2K J Q 14 7 2Q 9 FF2 1 1CP 5 2CP CP K 1J 2J Q 3 10 2Q 8 1K 2K J CP Q R 6 2R 1R 2R 2 6 001aab981 Functional diagram Fig. 2. C 3 1Q 12 2Q 9 2 FF K R Fig. 1. Q 5 10 6 12 C1 1K 13 R 1J 9 C1 1K 8 R 001aab980 001aab979 Logic symbol C 7 1Q 13 2Q 8 1J Fig. 3. C IEC logic symbol C K Q J C C C C R CP Q C C Fig. 4. 001aab982 Logic diagram (one flip-flop) 74HC73_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 December 2020 © Nexperia B.V. 2020. All rights reserved 2 / 12 74HC73-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger 5. Pinning information 5.1. Pinning 74HC73 1CP 1 14 1J 1R 2 13 1Q 1K 3 12 1Q VCC 4 11 GND 2CP 5 10 2K 2R 6 9 2Q 2J 7 8 2Q 001aab978 Fig. 5. Pin configuration SOT108-1 (SO14) 5.2. Pin description Table 2. Pin description Symbol Pin Description 1CP, 2CP 1, 5 clock input (HIGH-to-LOW edge-triggered); also referred to as nCP 1R, 2R 2, 6 asynchronous reset input (active LOW); also referred to as nR 1K, 2K 3, 10 synchronous K input; also referred to as nK VCC 4 positive supply voltage GND 11 ground (0 V) 1Q, 2Q 12, 9 true output; also referred to as nQ 1Q, 2Q 13, 8 complement output; also referred to as nQ 1J, 2J 14, 7 synchronous J input; also referred to as nJ 6. Functional description Table 3. Function table H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the HIGH-to-LOW clock transition; L = LOW voltage level; I = LOW voltage level one set-up time prior to the HIGH-to-LOW clock transition; q = state of referenced output one set-up time prior to the HIGH-to-LOW clock transition; X = don’t care; ↓ = HIGH-to-LOW clock transition. Input Output Operating mode nR nCP nJ nK nQ nQ L X X X L H asynchronous reset H ↓ h h q q toggle H ↓ l h L H load 0 (reset) H ↓ h l H L load 1 (set) H ↓ l l q q hold (no change) 74HC73_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 December 2020 © Nexperia B.V. 2020. All rights reserved 3 / 12 74HC73-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +7.0 V VCC supply voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V [1] - ±20 mA IO output current VO = -0.5 V to VCC + 0.5 V - ±25 mA ICC supply current - 50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] Tamb = -40 °C to +125 °C [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SOT108-1 (SO14) package: Ptot derates linearly with 10.1 mW/K above 100 °C. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit 2.0 5.0 6.0 V VCC supply voltage VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature -40 - +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 ns/V VCC = 4.5 V - 1.67 139 ns/V VCC = 6.0 V - - 83 ns/V -40 °C to +85 °C -40 °C to +125 °C Unit 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Min Max Min Max VIH VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V VIL HIGH-level input voltage LOW-level input voltage 74HC73_Q100 Product data sheet 25 °C All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 December 2020 © Nexperia B.V. 2020. All rights reserved 4 / 12 74HC73-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger Symbol Parameter VOH VOL Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VI = VIH or VIL HIGH-level output voltage IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V VI = VIH or VIL LOW-level output voltage IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V - - ±0.1 - ±1.0 - ±1.0 μA II input leakage current VI = VCC or GND; VCC = 6.0 V ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 4.0 - 40.0 - 80.0 μA CI input capacitance - 3.5 - - - - - pF 10. Dynamic characteristics Table 7. Dynamic characteristics GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Fig. 8 Symbol Parameter Conditions tpd nCP to nQ; see Fig. 6 propagation delay 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 52 160 - 200 - 240 ns VCC = 4.5 V - 19 32 - 40 - 48 ns VCC = 6.0 V - 15 27 - 34 - 41 ns VCC = 5.0 V; CL = 15 pF - 16 - - - - - ns VCC = 2.0 V - 52 160 - 200 - 240 ns VCC = 4.5 V - 19 32 - 40 - 48 ns VCC = 6.0 V - 15 27 34 - 41 ns VCC = 5.0 V; CL = 15 pF - 16 - - VCC = 2.0 V - 50 145 - 180 - 220 ns VCC = 4.5 V - 18 29 - 36 - 44 ns VCC = 6.0 V - 14 25 31 - 38 ns VCC = 5.0 V; CL = 15 pF - 15 - - - - ns [1] nCP to nQ; see Fig. 6 ns nR to nQ, nQ; see Fig. 7 74HC73_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 December 2020 - © Nexperia B.V. 2020. All rights reserved 5 / 12 74HC73-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger Symbol Parameter tt transition time tW pulse width Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 16 - 19 ns VCC = 2.0 V 80 22 - 100 120 - ns VCC = 4.5 V 16 8 - 20 - 24 - ns VCC = 6.0 V 14 6 - 17 - 20 VCC = 2.0 V 80 22 - 100 VCC = 4.5 V 16 8 - 20 VCC = 6.0 V 14 6 - 17 VCC = 2.0 V 80 22 - 100 VCC = 4.5 V 16 8 - 20 VCC = 6.0 V 14 6 - 17 VCC = 2.0 V 80 22 - 100 120 - ns VCC = 4.5 V 16 8 - 20 - 24 - ns VCC = 6.0 V 14 6 - 17 - 20 VCC = 2.0 V 3 -8 - 3 VCC = 4.5 V 3 -3 - 3 VCC = 6.0 V 3 -2 - 3 VCC = 2.0 V 6.0 23 - 4.8 VCC = 4.5 V 30 70 - 24 VCC = 6.0 V 35 83 - 28 - 77 - - 30 - nQ, nQ; see Fig. 6 [2] nCP input, HIGH or LOW; see Fig. 6 ns nR input, HIGH or LOW; see Fig. 7 - ns - 24 - ns - 20 ns recovery time nR to nCP; see Fig. 7 trec tsu set-up time th hold time fmax maximum frequency CPD power dissipation capacitance 120 - ns - 24 - ns - 20 ns nJ, nK to nCP; see Fig. 6 ns nJ, nK to nCP; see Fig. 6 3 - ns - 3 - ns - 3 ns nCP input; see Fig. 6 VCC = 5.0 V; CL = 15 pF [1] [2] [3] 120 per flip-flop; VI = GND to VCC [3] 4.0 - MHz - 20 - MHz - 24 - MHz - MHz - pF - - - tpd is the same as tPHL, tPLH. tt is the same as tTHL, tTLH. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + ∑(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 ∑(CL × VCC × fo) = sum of outputs. 74HC73_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 December 2020 © Nexperia B.V. 2020. All rights reserved 6 / 12 74HC73-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger 10.1. Waveforms and test circuit VI nJ, nK input GND VM th tsu VI th tsu 1/f max VM nCP input GND tW tPHL VOH tPLH 90 % nQ output 90 % VM 10 % VOL 10 % tTHL VOH tTLH 90 % 90 % nQ output VM 10 % VOL tPLH 10 % tTLH tPHL tTHL 001aab983 Measurement points are given in Table 8. The shaded areas indicate when the input is permitted to change for predictable output performance. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 6. Waveforms showing the clock (nCP) to output (nQ, nQ) propagation delays, the clock pulse width, the J and K to nCP set-up and hold times, the output transition times and the maximum clock frequency VI VM nCP input GND tW VI trec VM nR input GND tPHL VOH nQ output VOL VOH tPLH nQ output 001aab984 VOL Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 7. Waveforms showing the reset (nR) input to output (nQ, nQ) propagation delays and the reset pulse width and the nR to nCP removal time Table 8. Measurement points Input Output VI VM VM VCC 0.5VCC 0.5VCC 74HC73_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 December 2020 © Nexperia B.V. 2020. All rights reserved 7 / 12 74HC73-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger VI negative pulse VM VI GND VM 10 % GND positive pulse tW 90 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VO RT CL 001aah768 Test data is given in Table 9. Definitions for test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. Fig. 8. Test circuit for measuring switching times Table 9. Test data Input Load VI tr, tf CL VCC 6 ns 15 pF, 50 pF 74HC73_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 December 2020 © Nexperia B.V. 2020. All rights reserved 8 / 12 74HC73-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger 11. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 A2 Q A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 9. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT108-1 (SO14) 74HC73_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 December 2020 © Nexperia B.V. 2020. All rights reserved 9 / 12 74HC73-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger 12. Abbreviations Table 10. Abbreviations Acronym Description DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC73_Q100 v.1 20201204 Product data sheet - 74HC73_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 December 2020 - © Nexperia B.V. 2020. All rights reserved 10 / 12 74HC73-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 14. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or 74HC73_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 December 2020 © Nexperia B.V. 2020. All rights reserved 11 / 12 74HC73-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 3 6. Functional description................................................. 3 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................4 9. Static characteristics....................................................4 10. Dynamic characteristics............................................ 5 10.1. Waveforms and test circuit........................................ 7 11. Package outline.......................................................... 9 12. Abbreviations............................................................ 10 13. Revision history........................................................10 14. Legal information......................................................11 © Nexperia B.V. 2020. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 4 December 2020 74HC73_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 December 2020 © Nexperia B.V. 2020. All rights reserved 12 / 12
74HC73D-Q100J
物料型号:74HC73-Q100
器件简介:74HC73-Q100是一个双负边沿触发的JK触发器,具有独立的J、K、时钟(nCP)和复位(nR)输入,以及互补的nQ和nQ输出。J和K输入必须在高到低的时钟转换前一个设定时间保持稳定以获得可预测的操作。(nR)是异步的,当为低电平时,它覆盖时钟和数据输入,强制nQ输出为低,nQ输出为高。时钟输入的施密特触发器动作使电路对时钟上升和下降时间的变化非常宽容。输入包括钳位二极管,这使得可以使用限流电阻将输入接口到超过VCC的电压。
引脚分配:文档提供了详尽的引脚配置图和引脚描述表,例如1CP和2CP是时钟输入端,1R和2R是异步复位输入端,1K和2K是同步K输入端,Vcc是正电源电压,GND是地线,1Q和2Q是真输出端,1Q和2Q是互补输出端,1J和2J是同步J输入端。
参数特性:该产品符合汽车电子委员会(AEC)标准Q100(1级),适用于汽车应用。产品特性包括CMOS低功耗、宽电源电压范围从2.0到6.0伏、高噪声容限、超过100毫安的防锁存性能,并符合JEDEC标准。
功能详解:功能表详细描述了在不同输入条件下输出nQ和nQ的状态,包括异步复位、切换、装载0(复位)、装载1(置位)和保持(无变化)的操作模式。
应用信息:该产品已通过汽车电子产品认证,适用于汽车应用。
封装信息:74HC73D-Q100的封装类型为SO14,是一种塑料小型轮廓封装,有14个引脚,体宽3.9毫米。另外还有SOT108-1封装。
74HC73D-Q100J 价格&库存
很抱歉,暂时无法提供与“74HC73D-Q100J”相匹配的价格&库存,您可以联系我们找货
74HC73D-Q100J
  • 1+6.24099
  • 10+4.31886
  • 100+3.36966
  • 500+2.96625
  • 1000+2.85947
  • 2500+2.69336
  • 5000+2.62217
库存:2258
74HC73D-Q100J
  • 1+4.669321+0.60473
  • 10+3.2706610+0.42359
  • 25+2.9269625+0.37907
  • 100+2.54691100+0.32985
  • 250+2.36511250+0.30631
  • 500+2.25579500+0.29215
  • 1000+2.189861000+0.28361
库存:9540
74HC73D-Q100J
  • 1+6.24099
  • 10+4.31886
  • 100+3.36966
  • 500+2.96625
  • 1000+2.85947
  • 2500+2.69336
  • 5000+2.62217
库存:2258
74HC73D-Q100J
  • 2500+2.070282500+0.26813
  • 5000+2.012875000+0.26069
  • 7500+1.984137500+0.25697
  • 12500+1.9522912500+0.25284
  • 17500+1.9336617500+0.25043
  • 25000+1.9157725000+0.24811
库存:9540
