IS31BL3506B-STLS2-TR
    LUMISSIL
    SOT23-6
    IS31BL3506B STLS2 TR
IS31BL3506B-STLS2-TR 数据手册
IS31BL3506B 1.0MHZ BOOST CONVERTER WITH 35V INTERNAL MOSFET SWITCH April 2013 GENERAL DESCRIPTION FEATURES IS31BL3506B is a boost converter featuring an integrated MOSFET switch designed for driving series strings of LED or other device. Input operating voltage range is 2.7V~5.5V. The device regulates the LED load current is set using an external, low value sensing resistor. The device adjusts the PWM duty cycle of the switch to maintain the voltage at the FB pin at a value of 0.2V. The IS31BL3506B operates at a constant switching frequency of 1.0MHz to allow for small component size. IS31BL3506B features an over voltage shutdown pin which prevents the output voltage from exceeding 35V (typ.) in the case of an open circuit condition. The device is offered in a tiny TSOT-23-6 and SOT-23-6 package and a temperature rating from -40°C ~ +85°C.            Supply voltage: 2.7V~5.5V Built-in soft start Drive series strings of 8 LEDs PWM or DC voltage dimming Frequency of PWM is 500Hz ~ 500kHz 1.0MHz high speed switching frequency 200mV feedback voltage Integrated high power MOSFET Over voltage protection -40°C ~ +85°C working temperature range TSOT-23-6 and SOT-23-6 package APPLICATIONS    Small LCD Backlights Notebook PC GPS TYPICAL APPLICATION CIRCUIT Figure 1 Constant current white LED driver using PWM at the EN pin to control intensity Note 1: COUT must be rated for 50V. Smaller values of output capacitance will cause the LED current ripple to increase. Note 2: The resistor REST should be placed as close as possible to the FB pin to prevent the EMI. Note 3: The high level of PWM signal for EN pin should last at least 200ns when power on, or the IC won’t start up. Lumissil Microsystems – www.lumissil.com Rev. A, 04/15/2013 1 IS31BL3506B   VBattery 2.7~5.5V L1 10 H D1 0.1 F 2.2 F 6 VCC LX PWM Signal OUT 4 Micro Controller 100k 2 1 COUT 1 F (50V) 5 (4~6)×2 LEDs EN IS31BL3506B FB 3 RSET 5 GND   Figure 2 Constant current white LED driver using PWM at the EN pin to control intensity (4~6)×2 LEDs  VBattery 2.7~5.5V 2.2 F L1 10 H D1 VOUT =VFB× (R1 +RSET)/RSET 0.1 F 6 VCC LX OUT 4 Micro Controller 2 5 COUT 1 F (50V) R1 Load EN IS31BL3506B FB 100k 1 3 RSET GND Figure 3 Figure 4 Constant output voltage for general purpose use Constant output current with DC dimming input Lumissil Microsystems – www.lumissil.com Rev. A, 04/15/2013 2 IS31BL3506B Figure 5 Constant output current with PWM dimming control Lumissil Microsystems – www.lumissil.com Rev. A, 04/15/2013 3 IS31BL3506B PIN CONFIGURATION Package Pin Configurations (Top View) TSOT-23-6 SOT-23-6 LX 1 6 VCC GND 2 5 OUT FB 3 4 EN PIN DESCRIPTION No. Pin Description 1 LX Switch input, connect to the inductor. 2 GND Ground. 3 FB Feedback input pin. 4 EN Device enable pin, active high. 5 OUT Output voltage sense pin for over voltage protection. 6 VCC Supply voltage input pin. Lumissil Microsystems – www.lumissil.com Rev. A, 04/15/2013 4 IS31BL3506B ORDERING INFORMATION Industrial Range: -40°C to +85°C Order Part No. Package IS31BL3506B-TTLS2-TR TSOT-23-6, Lead-free IS31BL3506B-STLS2-TR SOT-23-6, Lead-free QTY/Reel 3000 Copyright  ©  2013  Lumissil  Microsystems.  All  rights  reserved.  Lumissil Microsystems reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use in  such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances Lumissil Microsystems – www.lumissil.com Rev. A, 04/15/2013 5 IS31BL3506B ABSOLUTE MAXIMUM RATINGS Supply voltage, VCC LX pin voltage Voltage at any input pin Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TA -0.3V ~ +6.0V -0.3V ~ +40V -0.3V ~ +6.0V +150°C -65°C ~ +150°C -40°C ~ +85°C Note: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS Test conditions:TA = -40°C ~ +85°C, VCC = 3.6V, unless otherwise noted. Typical values at TA = 25°C. Symbol Parameter Condition Min Typ 2.7 Max Unit 5.5 V VCC Supply voltage ICC Quiescent current Switching 1.2 mA ISD Shutdown current VEN = 0V 5.5 μA VEN_ON EN Input logic High VEN rising VEN_OFF EN Input logic Low VEN falling 1.4 V 0.4 V FOSC Operating frequency 1 MHz DMAX Maximum duty cycle 90 % RDS_ON LX Switch On resistance 0.8 Ω ISW_LK LS Switch Leakage current VSW = 35V Switch over current limit Duty = 90% ISW_LIMIT 1.8 2.2 1 μA 2.6 A VOVP OUT over voltage protection 35 V VFB Feedback voltage 0.2 V TST Over temperature protection (Note 1) 160 °C tPWM_H EN pin PWM high level time (Note 1) (when power on) 200 ns Note 1: Guaranteed by design. Lumissil Microsystems – www.lumissil.com Rev. A, 04/15/2013 6 IS31BL3506B TYPICAL PERFORMANCE CHARACTERISTIC 0.3 100 8 WLEDs ILED = 20mA 90 0.25 Reference Voltage(V) 80 Efficiency(%) 70 60 50 40 30 0.2 0.15 0.1 20 0 2.5 0.05 8 WLEDs ILED = 20mA 10 3 3.5 4 4.5 5 0 2.5 5.5 3 3.5 Figure 8 Efficiency vs. VCC Power On from EN Figure 9 14 5.5 PWM Dimming from EN 25 EN Pin Dimming VEN = 2.8V VCC = 3.6V f = 20kHz 8WLEDs Output Current(mA) Output Current(mA) 16 5 VFB vs. VCC Figure 7 20 18 4.5 Power Supply(V) Power Supply(V) Figure 6 4 12 10 8 6 FB Pin PWM Dimming VPWM = 2.8V VCC = 3.6V f = 20kHz 8WLEDs 20 15 10 5 4 2 0 0 20 40 60 80 100 0 0 20 Enable Pin Dimming Lumissil Microsystems – www.lumissil.com Rev. A, 04/15/2013 60 80 100 Duty Cycle(%) Duty Cycle(%) Figure 10 40 Figure 11 FB pin PWM Dimming 7 IS31BL3506B Figure 12 Ripple Voltage Lumissil Microsystems – www.lumissil.com Rev. A, 04/15/2013 8 IS31BL3506B FUNCTIONAL BLOCK DIAGRAM LX VCC Band Gap Bias&Ref FB Vref R Slope Compensation OSC S Q Σ Ramp Generater GND Current Limite Thermal Shutdown Block OVP OUT EN Lumissil Microsystems – www.lumissil.com Rev. A, 04/15/2013 9 IS31BL3506B APPLICATION INFORMATION INPUT AND OUTPUT CAPACITOR FB PIN DC VOLTAGE DIMMING A 2.2μF input capacitor is used to reduce input ripple and noise, where the input ripple amplitude is inversely proportional to the value of the input capacitance. The input and output capacitors should be placed as close to the device as possible, so as to reduce the effect of voltage ripple. The value of the output capacitor is dependent upon the output ripple. A 1μF or 0.22μF ceramic capacitor with a 50V rating is sufficient for the majority of applications. The schematic of Figure 4 show an example of using a DC input voltage at the FB pin to implement LED dimming. When the DC input voltage increases, the current through R2 and R3 increases producing an offset voltage across R2, thereby causing the LED current to be reduced. The LED current may be computed using the following equation, (3). VFB is 0.2V (typ.). VFB  INDUCTOR VALUE The choice of the inductor value will affect the performance of the device. Large value inductors will reduce the current ripple in the inductor, thus reducing output voltage ripple. However large value inductors of the same current rating, typically also have larger DC resistance, thus reducing the system efficiency. For the majority of applications 4.7μH or 10μH is sufficient. LED CURRENT SETPOINT When the IS31BL3506B is used for LED driving applications (Figure 1), the LED current flows through the external feedback resistor RSET to regulate the LED current. The internal feedback regulation point is 0.2V. The maximum LED current may be calculated by the following equation, (1). I MAX  VFB / RSET (1) For accurate LED current, resistors should be 1% or better tolerance. LED INTENSITY CONTROL I LED  FB PIN PWM DIMMING A PWM signal connected to the FB pin can also be used to directly control the LED current (Figure 5). A low pass filter converts the PWM duty cycle to a DC level, which is in turn summed together with the feedback voltage of RSET to effectively reduce the LED current proportionally. Due to the filtering of the PWM signal, the frequency of the PWM signal can have an affect on the output voltage ripple. For a PWM signal input signal of 2.8V, the recommended frequency is greater than 2kHz. Using a fixed frequency PWM signal and adjusting the PWM duty cycle effectively adjusts the LED intensity. LED current may be computed using the following equation, (4). VFB is 0.2V (typ.). VFB  I LED  I MAX  DPWM (2) IMAX is computed using equation (1). Recommended PWM frequency is in the range of 500Hz ~ 500kHz. So as to guarantee a reasonably good dimming effect, the minimum duty cycle should be about 1%. Driving the EN pin with a PWM signal can effectively adjust the LED intensity. The PWM signal voltage levels must meet the EN pin input voltage levels, VEN_ON and VEN_OFF. IS31BL3506B can also use a DC voltage or PWM signal to directly control the LED current, and thus provide fine adjustment for the LED intensity. Lumissil Microsystems – www.lumissil.com Rev. A, 04/15/2013 (3) When the DC voltage range is 0V~1.8V, a good value for R2 is 56kΩ, and for R3 is 400kΩ. EN PIN DIMMING The EN pin of the IS31BL3506B can accept a PWM signal to implement LED dimming (Figure 1). LED current may be computed using the following equation, (2). R2  (VDC  VFB ) R3 RSET I LED  R2  (VPWM  Duty  VFB ) R4  R3 RSET (4) For a PWM signal range of 0V~1.8V, a suitable value for R2 is 56kΩ, R3 is 200kΩ, R4 is 200kΩ. To ensure good dimming effect, the minimum duty cycle is about 10%. SETTING THE OUTPUT VOLTAGE The IS31BL3506B can be configured to provide a constant output voltage (Figure 3). The output voltage level can be computed using the following equation, (5). The device internal VFB is 0.2V (typ). VOUT  VFB  R1  RSET  / RSET (5) OVERVOLTAGE THRESHOLD Device open circuit protection is realized using the overvoltage protection function (OVP). If the output voltage surpasses the overvoltage threshold, the overvoltage protection circuit is activated and the device will stop working. 10 IS31BL3506B CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) 150°C 200°C 60-120 seconds Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) Time at liquidous (tL) 217°C 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified classification temperature (Tc) Max 30 seconds Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature 8 minutes max. Figure 13 Classification Profile Lumissil Microsystems – www.lumissil.com Rev. A, 04/15/2013 11 IS31BL3506B PACKAGE OUTLINE DRAWING TSOT-23-6 Lumissil Microsystems – www.lumissil.com Rev. A, 04/15/2013 12 IS31BL3506B SOT-23-6 Note: All dimensions in millimeters unless otherwise stated. Lumissil Microsystems – www.lumissil.com Rev. A, 04/15/2013 13
IS31BL3506B-STLS2-TR 价格&库存
很抱歉,暂时无法提供与“IS31BL3506B-STLS2-TR”相匹配的价格&库存,您可以联系我们找货
  • 1+4.755201+0.61804
  • 10+3.3254510+0.43221
  • 25+2.9701425+0.38603
  • 100+2.58196100+0.33558
  • 250+2.39777250+0.31164
  • 500+2.28639500+0.29717
  • 1000+2.194821000+0.28526
库存:1
