IS32FL3265A-ZLA3-TR
IS32FL3265A-ZLA3-TR
    LUMISSIL
    TSSOP28
    18 HIGH VOLTAGE(40V) CONSTANT CU
IS32FL3265A-ZLA3-TR 数据手册
IS32FL3265A HIGH-VOLTAGE, 18-CHANNEL LED DRIVER March 2020 GENERAL DESCRIPTION FEATURES The IS32FL3265A is an LED driver with 18 high voltage (40V) constant current channels. Each channel can be pulse width modulated (PWM) by 8 bits for smooth LED brightness control. In addition, each channel has an 8-bit output current control register which allows fine tuning of the channel current for rich RGB color mixing, e.g., a pure white color LED application. The maximum output current of each channel is designed to be 60mA, which can be adjusted by one 32 steps global control register. Proprietary algorithms are used in the IS32FL3265A to minimize audible noise caused by the MLCC decoupling capacitors. All registers can be programmed via 1MHz I2C compatible interface.   The IS32FL3265A can be configured to a minimum current consumption mode by either pulling the SDB pin low or by using the software shutdown feature. The IS32FL3265A is available in eTSSOP-28 package. It operates from 2.7V to 5.5V over the temperature range of -40°C to +125°C.           APPLICATIONS     Car display panel Ambient lighting Roof lighting Functional lighting Lumissil Microsystems – www.lumissil.com Rev.A, 01/02/2020     3V to 5.5V operating supply Output current capability and number of outputs: 60mA × 18 outputs, tolerance voltage 40V 1MHz I2C with automatic address increment Programmable H/L logic: 1.4V/0.4V, 2.4V/0.6V Accurate color rendition - 32 steps global current adjust - 8-bit dot correction for each channel - 8-bit PWM for each channel Selectable PWM method (200Hz or 25kHz) 256-Step group blink with frequency programmable from 24Hz to 10.66s and duty cycle from 0% to 99.6% Clock IO pin for multi-chip synchronization Fault report (open detect/thermal roll off /thermal shutdown) Thermal roll-off programmable set point SDB rising edge resets I2C interface EMI reduction technology - Spread spectrum - Selectable 9 phase delay Operating temperature range, -40°C ~ +125°C Package: eTSSOP-28 AEC-Q100 Qualified Current accuracy (All output on) - Bit to bit: < ±6% - Device to device: < ±6% 1 IS32FL3265A TYPICAL APPLICATION CIRCUIT Figure 1 Typical Application Circuit Note 1: VCC pin should not be higher than 5.5V, VLED+ can be higher than VCC. Note 2: VIH is the high level voltage for IS32FL3265A’s SDA, SCL and INTB, which is usually same as VCC pin and VCC of Micro Controller, e.g. if VCC of Micro Controller is 3.3V, VCC(IS32FL3265A)=VIH=3.3V,if VCC of Micro Controller is 5V, VCC(IS32FL3265A)=VIH=5V, but VCC(IS32FL3265A) should not be lower than 3V. 2 Note 3: These resistors are for offloading the thermal dissipation (I R) away from the IS32FL3265A. Note 4: The maximum global output current is set by external resistor, RISET. Please refer to the application information in RISET section. Note 5: The IC and LED string should be placed far away from any local antenna in order to prevent EMI contamination. Lumissil Microsystems – www.lumissil.com Rev.A, 01/02/2020 2 IS32FL3265A TYPICAL APPLICATION CIRCUIT (CONTINUED) VCC VIO 100kΩ 2kΩ ADDR1 ADDR2 ADDR2 SDA ADDR1 SCL ADDR2 ADDR1 ADDR2 2kΩ SDA SCL Micro Controller ADDR1 INTB SDB SDA SDA SDA SDA SDA SDA SDA SCL SCL SCL SCL SCL SCL SCL INTB INTB INTB INTB INTB INTB INTB SDB SDB SDB SDB SDB SDB SDB 100kΩ CLKIO VCC CLKIO Master VCC CLKIO CLKIO Slave 1 VCC CLKIO ADDR2 ADDR2 ADDR1 ADDR1 CLKIO Slave 2 VCC CLKIO ADDR2 SDA CLKIO ADDR2 ADDR1 SCL ADDR1 SDA SDA SDA SDA SDA SDA SDA SDA SCL SCL SCL SCL SCL SCL SCL SCL INTB INTB INTB INTB INTB INTB INTB INTB SDB SDB SDB SDB SDB SDB SDB SDB Slave 4 Figure 2 Slave 5 Slave 3 Slave 6 Slave 7 Typical Application Circuit (Eight Device Synchronization) Note 6: One system should contain only one master, all slave parts should be configured as slave mode before the master is configured as master mode. Master or slave mode is specified by the Configuration Register. The master will output a master clock (CLKIO), and all the other devices configured as slaves will synchronize their CLKIO inputs to the master clock. Lumissil Microsystems – www.lumissil.com Rev.A, 01/02/2020 3 IS32FL3265A PIN CONFIGURATION Package Pin Configuration (Top View) eTSSOP-28 ADDR1 1 28 VCC ADDR2 2 27 CLKIO SDA 3 26 SDB SCL 4 25 ISET INTB 5 24 GND OUT1 6 23 OUT18 OUT2 7 22 OUT17 OUT3 8 21 OUT16 OUT4 9 20 OUT15 OUT5 10 19 OUT14 OUT6 11 18 OUT13 OUT7 12 17 OUT12 OUT8 13 16 OUT11 OUT9 14 15 OUT10 PIN DESCRIPTION No. Pin Description 1 ADDR1 I2C address setting pin. 2 ADDR2 I2C address setting pin. 3 SDA I2C serial data. 4 SCL I2C serial clock. 5 INTB Interrupt output pin. Register 14h can set the function of the INTB pin and active low when the interrupt event happens. Can be NC (float) if interrupt function is not used. 6~23 OUT1~OUT18 Output LED current sink channels 1~18. 24 GND GND pin for control logic. 25 ISET Input terminal used to connect an external resistor. This regulates the global output current. 26 SDB Shutdown the chip when pulled low. 27 CLKIO Cascade connection pin. 28 VCC Power supply. Thermal Pad Need to connect to GND. Lumissil Microsystems – www.lumissil.com Rev.A, 01/02/2020 4 IS32FL3265A ORDERING INFORMATION Automotive Range: -40°C to +125°C Order Part No. Package QTY IS32FL3265A-ZLA3-TR eTSSOP-28, Lead-free 2500 Copyright  ©  2020  Lumissil  Microsystems.  All  rights  reserved.  Lumissil  Microsystems  reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use  in such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances Lumissil Microsystems – www.lumissil.com Rev.A, 01/02/2020 5 IS32FL3265A ABSOLUTE MAXIMUM RATINGS Supply voltage, VCC Voltage at SCL, SDA, SDB, INTB, CLKIO, ADDR1, ADDR2 Voltage at OUT1 to OUT36 Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TA=TJ Package thermal resistance, junction to ambient (4 layer standard test PCB based on JESD 51-2A), θJA -0.3V ~ +6.0V -0.3V ~ VCC+0.3V 40V +150°C -65°C ~ +150°C -40°C ~ +150°C 33.8°C/W Package thermal resistance, junction to thermal PAD (4 layer standard test PCB based on JESD 51-2A), θJP 11.08°C/W ESD (HBM) ESD (CDM) ±2kV ±750V Note 7: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS VCC= 5V, TA= TJ = -40°C ~ +125°C, Typical values are at TJ = 25°C, unless otherwise noted. Symbol VCC Parameter Condition Supply voltage RISET= 6.8kΩ, GCC= 0x20, Scaling= 0xFF, PWM= 0xFF, VOUT= 0.8V (Note 8) Output current RISET= 20kΩ, GCC= 0x20, Scaling= 0xFF, PWM= 0xFF ∆IMAT IOUT mismatch (bit to bit) ∆IOUT VHR ICC ISD Typ. 3 Maximum output current IOUT Min. Max. Unit 5.5 V 60 20.4 21.8 mA RISET= 20kΩ, GCC= 0x20, Scaling= 0xFF, PWM= 0xFF (Note 9) ±2 ±6 % IOUT accuracy (device to device) RISET= 20kΩ, GCC= 0x20, Scaling= 0xFF, PWM= 0xFF (Note 10) ±2 ±6 % Headroom voltage RISET= 20kΩ, GCC= 0x20, Scaling= 0xFF, PWM= 0xFF 0.3 0.5 V RISET= 20kΩ, GCC= 0xFF, Scaling= 0xFF, PWM= 0 7.5 9 mA VCC= 3.6V, RISET= 20kΩ, GCC= 0xFF, Scaling= 0xFF, PWM= 0 7.2 8.5 mA RISET= 20kΩ, VSDB= 0V or software shutdown 4 20 μA VCC= 3.6V, RISET= 20kΩ, VSDB= 0V or software shutdown 1 12 μA 1.02 V Quiescent power supply current Shutdown current 19 mA VISET ISET voltage RISET= 20kΩ, GCC= 0x20, Scaling= 0xFF, PWM= 0xFF 0.98 1.0 VOD OUTx pin open detect threshold RISET=20kΩ, GCC= 0x20, Scaling= 0xFF, PWM=0xFF, measured at OUTx 100 150 IOZ Output leakage current VSDB= 0V or software shutdown, VOUT= 40V fOUT PWM frequency of output Frequency setting=25kHz TSD Thermal shutdown 165 °C TSD_HYS Thermal shutdown hysteresis 20 °C Lumissil Microsystems – www.lumissil.com Rev.A, 01/02/2020 22 25 mV 1 μA 28 kHz 6 IS32FL3265A ELECTRICAL CHARACTERISTICS (CONTINUED) VCC= 5V, TA= TJ = -40°C ~ +125°C, Typical values are at TJ = 25°C, unless otherwise noted. Symbol Parameter Condition Min. Typ. Max. Unit 0.4 V Logic Electrical Characteristics (SDA, SCL, ADDR1, ADDR2, SDB, CLKIO) VIL Logic “0” input voltage VCC= 2.7V~5.5V, LGC=0 VIH Logic “1” input voltage VCC= 2.7V~5.5V, LGC=0 VIL Logic “0” input voltage VCC= 2.7V~5.5V, LGC=1 VIH Logic “1” input voltage VCC= 2.7V~5.5V, LGC=1 VOH H level of CLKIO pin output IOH= -8mA voltage VCC-0.4V VCC V VOL L level of CLKIO pin output IOL= 8mA voltage 0 0.4 V 1.4 V 0.6 2.4 V V IIL Logic “0” input current VINPUT= 0V (Note 11) 5 nA IIH Logic “1” input current VINPUT= VCC (Note 11) 5 nA DIGITAL INPUT SWITCHING CHARACTERISTICS (NOTE 11) Symbol Parameter fSCL Serial-clock frequency tBUF Bus free time between a STOP and a START condition Fast Mode Min. Typ. Fast Mode Plus Max. Min. Typ. Max. Units - 400 - 1000 kHz 1.3 - 0.5 - μs tHD, STA Hold time (repeated) START condition 0.6 - 0.26 - μs tSU, STA Repeated START condition setup time 0.6 - 0.26 - μs tSU, STO STOP condition setup time 0.6 - 0.26 - μs tHD, DAT Data hold time - - - - μs tSU, DAT Data setup time 100 - 50 - ns tLOW SCL clock low period 1.3 - 0.5 - μs tHIGH SCL clock high period 0.7 - 0.26 - μs tR Rise time of both SDA and SCL signals, receiving - 300 - 120 ns tF Fall time of both SDA and SCL signals, receiving - 300 - 120 ns Note 8: The recommended minimum value of RISET is 6.8kΩ. Note 9: IOUT mismatch (bit to bit) is calculated: I MAT     (  1 ~ 18 ) I n OUTn   1  100%   I OUT1  I OUT 2  ...  I OUT18      18    Note 10: IOUT accuracy (device to device) is calculated: IOUT  IOUT1  IOUT 2  ...  I OUT18   IOUT ( IDEAL) )  ( 18   100%  IOUT ( IDEAL)       Where IOUT(IDEAL)= 20.4mA (RISET= 20kΩ, GCC= 0x20, Scaling= 0xFF, PWM= 0xFF). Note 11: Guaranteed by design. Lumissil Microsystems – www.lumissil.com Rev.A, 01/02/2020 7 IS32FL3265A DETAILED DESCRIPTION I2C INTERFACE The IS32FL3265A uses a serial bus, which conforms to the I2C protocol, to control the chip’s functions with two wires: SCL and SDA. The IS32FL3265A has a 7-bit slave address (A7:A1), followed by the R/W bit, A0. Set A0 to “0” for a write command and set A0 to “1” for a read command. The value of bits A1 and A2 are decided by the connection of the ADDR1/2 pins. The complete slave address is: Table 1 Slave Address: ADDR2 ADDR1 GND GND GND GND SCL SCL SCL SCL SDA SDA SDA SDA VCC VCC VCC VCC GND SCL SDA VCC GND SCL SDA VCC GND SCL SDA VCC GND SCL SDA VCC A7:A5 A4:A3 A2:A1 100 00 00 00 00 01 01 01 01 10 10 10 10 11 11 11 11 00 01 10 11 00 01 10 11 00 01 10 11 00 01 10 11 A0 The 8-bit chip address is sent next, most significant bit first. Each address bit must be stable while the SCL level is high. After the last bit of the chip address is sent, the master checks for the IS32FL3265A’s acknowledge. The master releases the SDA line high (through a pull-up resistor). Then the master sends an SCL pulse. If the IS32FL3265A has received the address correctly, then it holds the SDA line low during the SCL pulse. If the SDA line is not low, then the master should send a “STOP” signal (discussed later) and abort the transfer. Following acknowledge of IS32FL3265A, the register address byte is sent, most significant bit first. IS32FL3265A must generate another acknowledge indicating that the register address has been received. 0/1 ADDR1/2 connected to GND, (A2:A1)/(A4:A3)=00; ADDR1/2 connected to VCC, (A2:A1)/(A4:A3)=11; ADDR1/2 connected to SCL, (A2:A1)/(A4:A3)=01; ADDR1/2 connected to SDA, (A2:A1)/(A4:A3)=10; The SCL line is uni-directional. The SDA line is bi-directional (open-drain) with a pull-up resistor (typically 2kΩ). The maximum clock frequency specified by the I2C standard is 1MHz (Fast-mode plus). In this discussion, the master is the microcontroller and the slave is the IS32FL3265A. The timing diagram for the I2C is shown in Figure 3. The SDA is latched in on the stable high level of the SCL. When there is no interface activity, the SDA line should be held high. The “START” signal is generated by lowering the SDA signal while the SCL signal is high. The start signal will Lumissil Microsystems – www.lumissil.com Rev.A, 01/02/2020 alert all devices attached to the I2C bus to check the incoming address against their own chip address. Then 8-bit of data byte are sent next, most significant bit first. Each data bit should be valid while the SCL level is stable high. After the data byte is sent, the IS32FL3265A must generate another acknowledge to indicate that the data was received. The “STOP” signal ends the transfer. To signal “STOP”, the SDA signal goes high while the SCL signal is high. ADDRESS AUTO INCREMENT To write multiple bytes of data into IS32FL3265A, load the address of the data register that the first data byte is intended for. During the IS32FL3265A acknowledge of receiving the data byte, the internal address pointer will increment by one. The next data byte sent to IS32FL3265A will be placed in the new address, and so on. The auto increment of the address will continue as long as data continues to be written to IS32FL3265A (Figure 6). READING OPERATION All of the registers can be read (Table 2). To read the register, after I2C start condition, the bus master must send the IS32FL3265A device address ____ with the R/W bit set to “0”, followed by the register address which determines which register is accessed. Then restart I2C, the bus master should send the ____ IS32FL3265A device address with the R/W bit set to “1”. Data from the register defined by the command byte is then sent from the IS32FL3265A to the master (Figure 7). 8 IS32FL3265A Figure 3 Interface Timing Figure 4 Figure 5 Figure 6 Bit Transfer Writing to IS32FL3265A (Typical) Writing to IS32FL3265A (Automatic Address Increment) Figure 7 Lumissil Microsystems – www.lumissil.com Rev.A, 01/02/2020 Reading from IS32FL3265A 9 IS32FL3265A REGISTER DEFINITIONS Table 2 Register Function Address Name Function Table Default R/W 00h Configuration Register Power control register 3 0000 0000 R/W 01h Global Current Control Register Control Global DC current 4 0011 1111 R/W Scaling Register Control each channel’s DC current 5 1111 1111 R/W Open Detect Enable Register Open detect enable 6 0000 0011 R/W LED Open Status Register (Read Only) Open information 7 0000 0000 R 18h Temperature Sensor Register Temperature information 8 0000 0000 R/W 19h Spread Spectrum Register Spread spectrum control register 9 0000 0000 R/W 1Ah~1Ch DC PWM Register Disable PWM function 10 0000 0000 R/W 1Dh~1Eh Phase Delay and Clock Phase Register Phase Delay and Clock Phase 11 0000 0000 R/W 1Fh~30h PWM Register Channel [18:1] PWM register byte 12 0000 0000 R/W 31h~33h Blinking Enable Register Enable Blinking state for each LED 13 0000 0000 R/W 34h Blinking Frequency Register Blinking frequency setting 14 0000 0000 R/W 35h Blinking Duty Cycle Register Blinking duty cycle setting 15 0000 0000 R/W 36h Scaling Update Register Update the scaling registers - 0000 0000 R/W 37h Update Register Update the PWM and blinking registers - 0000 0000 W 3Fh Reset Register Reset all registers - 0000 0000 R/W 02h~13h 14h 15h~17h Table 3 00h Configuration Register Bit D7 Name - Default 0 D6 D5 D4 D3 LGC CM PFS 0 0 0 D2:D1 D0 - SYNC SSD 0 00 0 The Configuration Register sets high/low logic, current multiplier, PWM frequency, synchronization mode and software shutdown mode for the IS32FL3265A. When SSD bit is “0”, the IS32FL3265A is in software shutdown mode. For normal operation the SSD bit should be set to “1”. SYNC bits configure the device into Master or Slave mode. The CLKIO pin has an internal weak pulldown resistor. When the SYNC bits are “10”, the CLKIO pin is configured as the master and will output a clock signal for distribution to the slave configured devices. To be configured as a slave device and accept an external clock input the slave device’s SYNC bits must be set to “11”. The CLKIO clock is only used synchronizing the blink function, and CLKIO frequency is same as blinking setting from 24Hz to 10.66s. There Lumissil Microsystems – www.lumissil.com Rev.A, 01/02/2020 should only be one master and all other CLKIO connected devices should first be configured in slave mode before the master is configured as master mode. The PFS bit sets the operating PWM frequency, default PWM frequency is 25kHz, when PFS is set to “1”, the PWM frequency will change to 200Hz. CM bit is a current multiplier of all output’s current. When CM= “0”, IOUT(MAX) follow the formula below or refer to RISET section in Application Information. I OUT ( MAX )  x V ISET R ISET (1) x = 408, VISET = 1V. When CM= “1”, the output current will become 1/8 of above setting, which is: I OUT ( MAX )  x V ISET  8 R ISET (1) x = 408, VISET = 1V. For applications of IOUT(MAX)=6mA~60mA, CM should be set to “0”. 10 IS32FL3265A For applications of IOUT(MAX)=0~7.5mA, recommend to set CM to “1” to ensure good ∆IMAT and ∆IOUT. When LGC bit is set to “1”, the high/low logic will change to 2.4V/0.6V. SSD 0 1 Software Shutdown Control Software shutdown Normal operation SYNC 00/11 10 11 Master or slave no function, CLKIO pull-low Master and CLKIO has square wave output, CLKIO frequency is same as blinking frequency Slave and CLKIO is clock input PFS 0 1 PWM frequency setting 25kHz 200Hz CM 0 1 Current multiplier 6~60mA 1~10mA LGC 0 1 H/L logic 1.4V/0.4V 2.4V/0.6V Bit D7:D6 D5:D0 Name - GCC Default 00 11 1111 GCC and SL control the IOUT as shown in Formula (2). ( MAX )  GCC SL  32 256 (2) If GCC ≤ 31(’01 1111’), GCC  5  D [n ]  2 n (3) n0 If GCC ≥ 32 (’10 0000’), GCC=32. Where IOUT(MAX) is the maximum output current decided by RISET (Check RISET section for more information) The IOUT of each channel is set by the SL bits of LED Scaling Register (02h~13h). Please refer to the detail information in Table 5. If GCC=0x05, SL=0xFF, GCC ≤ 31 so GCC=5, I OUT  I OUT Bit D7:D0 Name SL[7:0] Default 1111 1111 Each output has 8 bits to modulate DC current in 256 steps. The value of the SL Registers scales the IOUT current of each output channel. IOUT computed by Formula (2): I OUT  I OUT ( MAX )  GCC SL  32 256 (2) Where IOUT(MAX) is the maximum output current set by RISET. GCC (D5~D0) are the global current setting bits. SL D7~D0=0xFF is the default value, resulting in no LED current, for LEDs to function need to program these bits to a value from 0x01 to 0xFF. Scaling Registers 02h~13h must be updated by writing to the Scaling Update Register 36h. For DC mode (PWM disabled), each register will be updated immediately when it is written. For PWM mode, each register will be updated at the PWM falling edge, except not on the first PWM cycle. Table 6 14h Open Detect Enable Register Table 4 01h Global Current Control Register I OUT  I OUT Table 5 02h~13h Scaling Register ( MAX )  5 255  32 256 Bit D7:D2 D1 D0 Name - ODF ODE Default 00000 0 0 ODE enables Open LED detection and stores this open information in LED Open status registers 15h~17h. The open information will continue updating until detection is disabled by writing “0” to ODE. Writing a “1” to ODF bit enables reporting of the open information on the INTB pin. When ODF is “1”, any detected open LED condition on OUT1~OUT18 will cause the INTB pin to go logic low. ODE 0 1 Open Detect Enable Detect disable Detect enable ODF 0 1 Open Report Enable Report disable Report enable (2) If GCC=0x2F, SL=0xFF, GCC ≥ 32 so GCC=32, I OUT  I OUT ( MAX )  255 256 Lumissil Microsystems – www.lumissil.com Rev.A, 01/02/2020 (2) 11 IS32FL3265A Table 7-1 15h LED Open Status Register 1 Bit D7 D6:D4 D3 D2:D0 Name - OP[6:4] - OP[3:1] Default 0 000 0 000 Table 7-2 16h LED Open Status Register 2 Bit D7 D6:D4 D3 D2:D0 Name - OP[12:10] - OP[9:7] Default 0 000 0 000 Table 7-2 17h LED Open Status Register 3 Bit D7 D6:D4 D3 D2:D0 Name - OP[18:16] - OP[15:13] Default 0 000 0 000 Open status registers 15h~17h are updated if there is an open LED condition and if bit ODE of register 14h was set to “1”. Register 15h~17h will be cleared upon reading the register. Open Information of OUT18:OUT1 No LED open detected LED open detected OPx 0 1 D7 D6 D5 Name TSDDE TRDE TSDF Default 0 0 0 D4 D3:D2 D1:D0 TF TROF 0 TS 00 00 01 10 11 TS 00 01 10 11 TSDF 0 1 Thermal Shutdown Flag No thermal shutdown happens Thermal shutdown happens TRDE 0 Thermal roll off Detect Enable Disable the thermal roll off detect, thermal roll off information will not store in TF Enable the thermal roll off detect, thermal roll off information stored in TF 1 TSDDE 0 1 Thermal Shutdown Detect Enable Disable thermal shutdown detect, thermal shutdown information will not be stored in TSDF Enable thermal shutdown detect thermal shutdown information will be stored in TSDF Bit D7:D5 D4 D3:D2 D1:D0 Name - SSP RNG CLT Default 000 0 00 00 This register enable the spread spectrum function, adjust the cycle time and range. 00 This register stores the temperature point of the IC. When TF=1, the IC die temperature has exceeded the temperature point. When thermal shutdown happens, the TSDF will set to “1” to flag the thermal shutdown has occurred. Write 18h with C0h to enable read back if die temperature has or has not exceeded the set point. TROF Temperature Flag Set point not reached Reached the set point Table 9 19h Spread Spectrum Register Table 8 18h Temperature Status Register Bit TF 0 1 Percentage of output current before thermal shutdown happens 100% 75% 55% 30% SSP 0 1 Spread Spectrum Enable Disable Enable CLT 00 01 10 11 Spread Spectrum Cycle Time 1980μs 1200μs 820μs 660μs RNG 00 01 10 11 Spread Spectrum Range ±5% ±15% ±24% ±34% Temperature Point, Thermal roll-off start point 140°C 120°C 100°C 90°C Lumissil Microsystems – www.lumissil.com Rev.A, 01/02/2020 12 IS32FL3265A Table 10-1 1Ah DC PWM Register(PWM=256/256) Table 12 1Fh-30h PWM Register Bit D7 D6:D4 D3 D2:D0 Bit D7:D0 Name - DP[6:4] - DP[3:1] Name PWM Default 0 000 0 000 Default 0000 0000 Table 10-2 1Bh DC PWM Register(PWM=256/256) Bit D7 D6:D4 D3 D2:D0 Name - DP[12:10] - DP[9:7] Default 0 000 0 000 Each OUTx has 1 byte to modulate the PWM duty cycle in 256 steps. The value of the PWM Registers decides the average current of each OUTx LED noted ILED. ILED computed by Formula (4): Table 10-3 1Ch DC PWM Register(PWM=256/256) Bit D7 D6:D4 D3 D2:D0 Name - DP[18:16] - DP[15:13] Default 0 000 0 000 I LED  PWM  I OUT 256 (4) 7 When DPx bit is set to 1, the associated OUTx PWM will become 256/256, the OUTx current is a DC value, not PWM controlled. DPx 0 1 DC PWM command of OUT18:OUT1 PWM decided by Registers 1Fh-30h no PWM, DC output Table 11-1 1Dh Phase Delay and Clock Phase Register n 0 I OUT  I OUT ( MAX )  (5) GCC SL  32 256 (2) Where IOUT(MAX) is the maximum output current decided by RISET, GCC is the global current setting (GCC), and SL is the 8-bit scaling of each output. For example, if the data in OUT1 PWM register is “0000 0100”, then the associated PWM is the fourth step (4/256). Table 13-1 31h Blinking Enable Register Bit D7 D6:D4 D3:D1 D0 Bit D7 D6:D4 D3 D2:D0 Name - PS[3:1] - PDE Name - BP[6:4] - BP[3:1] Default 0 000 000 0 Default 0 000 0 000 Table 11-2 1Eh Phase Delay and Clock Phase Register Bit D7 D6:D4 D3 D2:D0 Name - PS[9:7] - PS[6:4] Default 0 000 0 000 IS32FL3265A features a 9 phase delay function enabled by PDE bit. PDE 0 1 Phase Delay Enable Phase delay disable Phase delay enable PSx 0 Phase select OUTx x2 Phase delay 0 degree, PS1 is for OUT1 &OUT2, PS2 is for OUT3 & OUT4… OUTx x2 Phase delay 180 degree, PS1 is for OUT1 &OUT2, PS2 is for OUT3 & OUT4… 1 PWM   D[n]  2 n Lumissil Microsystems – www.lumissil.com Rev.A, 01/02/2020 Table 13-2 32h Blinking Enable Register Bit D7 D6:D4 D3 D2:D0 Name - BP[12:10] - BP[9:7] Default 0 000 0 000 Table 13-3 33h Blinking Enable Register Bit D7 D6:D4 D3 D2:D0 Name - BP[18:16] - BP[15:13] Default 0 000 0 000 The Blinking Enable Registers store the Blinking mode enable bit of each OUTx channel. The data sent to the registers will be stored in temporary registers only, a write operation of “0000 0000” value to the Update Blinking Register (37h) is required to update it. BPx 0 1 Blinking Enable Bit PWM Mode Blinking Mode 13 IS32FL3265A Table 14 34h Blinking Frequency Register Bit D7:D0 Name BLF Default 0000 0000 The Blinking Frequency Register stores the blinking frequency of the outputs. The blinking period is controlled through 256 linear steps from 00h (41ms, frequency 24Hz) to FFh (10.66s). Blinking frequency is computed by: Blinking frequency (Hz) = 24/(BLF[7:0] + 1) The data sent to the Blinking Frequency Register will be stored in temporary bits, a write operation of “0000 0000” value to the Update Register (37h) is required to update it. Table 15 35h Blinking Duty Cycle Register Bit D7:D0 Name BLD Default 0000 0000 36h Scaling Update Register A Write of 00h to the Scaling Update Register is required to update the Scaling Registers (02h~13h) values. 37h Update Register A Write of 00h to Update Register is required to update the PWM Registers and Blinking Frequency Register/ Blinking Duty Cycle Register (1Fh~30h, 34h~35h) values. 3Fh Reset Register A write of 0xAE to the Reset Register will reset all the IS32FL3265A registers to their default values. On initial power-up, the IS32FL3265A registers are reset to their default values for a blank display. A write of “1” to the SSD bit in the Configuration Register 00h is required to enable the IS32FL3265A since the SSD default value is “0” or software shutdown. The Blinking Duty Cycle Register stores blinking duty cycle information (ON/OFF ratio in %). The blinking duty cycle can be linearly programmed from 0% (BLD=0x00) to 99.6% (BLD=0xFF). Blinking duty cycle computed by: Blinking duty cycle = BLD[7:0] / 256 The data sent to the Blinking Duty Cycle Register will be stored in temporary bits, a write operation of “0000 0000” value to the Update Register (37h) is required to update it. Lumissil Microsystems – www.lumissil.com Rev.A, 01/02/2020 14 IS32FL3265A APPLICATION INFORMATION RISET The maximum output current IOUT(MAX) of OUT1~OUT18 can be adjusted by external resistor, RISET, as described in Formula (1). I OUT ( MAX )  x V ISET R ISET (1) x = 408, VISET = 1V. Registers can also be referred to as white balance registers. PWM CONTROL The 18 PWM Registers (1Fh~30h) can modulate the average LED brightness of each 18 channels with 256 steps. For example, if the data in OUT1 PWM register is “0000 0100”, then the associated PWM is the fourth step (4/256). The max IOUT result is based on register setting as below (CM is D5 of Configuration Register (00h)): Continuously updating new values to the PWM registers will modulate the brightness of the LEDs to achieve a breathing effect. When CM= “0”, GCC= 0x20, Scaling= 0xFF, PWM= 0xFF PWM FREQUENCY SELECT The recommended minimum value of RISET is 6.8kΩ. When RISET=20kΩ, IOUT(MAX)=20.4mA. When RISET=6.8kΩ, IOUT(MAX)=60mA. When CM= “1”, GCC= 0x20, Scaling= 0xFF, PWM= 0xFF The output current will become 1/8 of above setting, which is: I OUT ( MAX )  x V ISET  8 R ISET (1) x = 408, VISET = 1V. When RISET=20kΩ, IOUT(MAX)=2.55mA. The IS32FL3265A output channels operate with a default 8 bit PWM resolution and a PWM frequency of 200Hz or 25kHz (register selectable). Because all the OUTx channels are synchronized, the DC power supply mau experience large instantaneous current surges when the OUTx channels turn ON. These current surges will generate an AC ripple on the power supply which cause stress to the decoupling capacitors. When the AC ripple is applied to a monolithic ceramic capacitor chip (MLCC) it will expand and contract causing the PCB to flex and generate audible hum in the PWM frequency range. To avoid this hum, there are many countermeasures, such as selecting the capacitor type and value which will not cause the PCB to flex and contract. RISET should be close to pin 25 and the ground side should connected to a nearby GND plane. An additional option for avoiding audible hum is to set the IS32FL3265A’s output PWM frequency above/below the audible range. The Control Register (00h) can be used to set the switching frequency to 200Hz or 25kHz, to avoid the audible range. CURRENT SETTING OPEN DETECT FUNCTION The maximum output current is set by the external resistor RISET. The current of each output can be adjusted with the SL 8 bits of LED Scaling Register (02h~13h). IS32FL3265A has open detect bit for each LED. When RISET=6.8kΩ, IOUT(MAX)=7.5mA. Some applications may require the IOUT of each channel to be adjusted independently. For example, if OUT1 drives 1 LED and OUT2 drives 2 parallel LEDs, and they should have the same average current of 10mA, we can set RISET=20kΩ for IOUT of 20.4mA, and configure the following registers 01h=0x20 (GCC= 32), 02h=0x80 (Scaling OUT1), and 03h=0xFF (Scaling OUT2). The result is OUT1 sinks 10mA and OUT2 sinks 20.4mA which will be shared by the two LEDs in parallel (10mA each). Another example, for an RGB LED, OUT1 is Red, OUT2 is Green and OUT 3 is Blue, with the same GCC (01h) SL (02h~13h) bits and PWM value, the LED may looks a pinkish, or not so white. In this case, the SL bits can be used to adjust the current of the RGB IOUTx to create a pure white color. These Scaling Lumissil Microsystems – www.lumissil.com Rev.A, 01/02/2020 By setting the ODE bit of Open Detect Enable Register (14h) from “0” to “1” (store open information), the LED Open Register will store the open LED information so the MCU can read LED status from registers 95h~97h. The open information will continue updating until ODE is set to “0”. The ODF bit can be set to “1” to enable reporting of open LED information on the INTB pin. When ODF is “0”, the open LED information will not be reported on the INTB pin. When ODF is “1”, any OUTx with a detected open LED will cause the INTB pin to go logic LOW. The Global Current Control Register (01h) needs to set to a value in the range of 0x10~0x48 in order to correctly detect an open LED. SPREAD SPECTRUM FUNCTION PWM current switching of LED outputs can be particularly troublesome Electromagnetic Interference (EMI) is of concern. To optimize EMI performance, the 15 IS32FL3265A IS32FL3265A spread spectrum function can be enabled. By setting the RNG bit of the Spread Spectrum Register (19h), a Spread Spectrum range can be selected from ±5% /±15% /±24% /±34%. Spread spectrum can spread the total electromagnetic emitting energy into a wider frequency range that significantly lowers the peak radiated energy. With spread spectrum enabled and proper PCB layout, it is possible to pass EMI tests which were previously difficult to pass. chip and the capacitor ground should be well connected to the GND plane. Thermal Consideration The over temperature of the chip may result in deterioration of the properties of the chip. The maximum IC junction temperature should be restricted to 150°C under normal operating conditions. The maximum power dissipation can be calculated using the following equation: SHUTDOWN MODE Shutdown mode can be used as a means of reducing power consumption. During shutdown mode all registers retain their data. Software Shutdown By setting the SSD bit of the Control Register (00h) to “0”, the IS32FL3265A will operate in software shutdown mode. When the IS32FL3265A is in software shutdown, all current sources are switched off, so the LEDs are OFF but all registers remain accessible. Typical current consumption is 3μA (VCC=5V). The default SSD value on power up is “0”, for normal operation the SSD needs to be written with a “1”. p D ( MAX If the VCC supply drops below 1.75V but remains above 0.1V while the SDB pin is pulled low, all Function Registers must be re-initialized before the SDB pin is pulled high. LAYOUT The IS32FL3265A consumes lots of power so proper PCB layout will help improve itsreliability. Below are basic PCB layout factors to consider. Power Supply Lines When designing the PCB layout, the first step to consider is the power supply traces and GND connection. High current traces, digital and analog supply traces and GND traces should be separated to avoid noise contamination from the switching digital block from affecting the analog block. At least one 0.1μF capacitor, if possible in parallel with a 1μF capacitor is recommended to connect from the power supply pin of the chip directly to ground. To be effective, these capacitors must be placed close to the Lumissil Microsystems – www.lumissil.com Rev.A, 01/02/2020 T J (max)  T A  JA For example, when TA=25°C PD ( MAX )  150 C  25 C  3.7W 33 .8C / W Figure 8, shows the power derating of the IS32FL3265A on a JEDEC boards (in accordance with JESD 51-5 and JESD 51-7) standing in still air. 4 3.5 Power Dissipation (W) The IS32FL3265A exits shutdown when the SDB pin is pulled high. The rising edge of SDB pin will reset the I2C module, but all the register information is retained. During hardware shutdown the registers are accessible.  Where PD(MAX) is the maximum allowable power dissipation, TJ(MAX) is the maximum allowable junction temperature, TA is ambient temperature of the device Hardware Shutdown The IS32FL3265A enters hardware shutdown when the SDB pin is pulled low. All current sources are disabled during hardware shutdown, typical the current consumption is 3μA (VCC=5V). ) eTSSOP-28 3 2.5 2 1.5 1 0.5 0 -40 -20 0 20 40 60 80 100 120 140 150 Temperature (°C) Figure 8 Dissipation Curve The thermal pad of IS32FL3265A should connect to a large copper GND net (preferably double sided PCB). Use 9 or 16 vias to connect the GND copper area directly under the IC thermal pad with a copper pad on the opposite layer (2 layer PCB). The grounded copper area should be as large area as possible to help distribute the thermal energy from the IS32FL3265A. Current Rating Example For RISET=20kΩ (IOUT(MAX)=20.4mA), the current rating for each net is as follows: • VCC pin maximum current (ICC) is 10mA when VCC=5V, the total OUTx current can as much as 20.4mA×18=367.2mA, the recommended trace width for VCC pin: 0.20mm~0.3mm, recommend trace width for VLED+ net: 0.30mm~0.5mm, 16 IS32FL3265A • Output pins=20.4mA, recommend trace width is 0.2mm~0.254mm • All other pins
IS32FL3265A-ZLA3-TR
物料型号:IS32FL3265A 器件简介:IS32FL3265A 是一款具有 18 个高压(40V)恒流通道的 LED 驱动器。
每个通道可以通过 8 位脉宽调制(PWM)实现平滑的 LED 亮度控制。
此外,每个通道都有一个 8 位的输出电流控制寄存器,允许微调通道电流,以实现丰富的 RGB 颜色混合,例如纯白色 LED 应用。
引脚分配:IS32FL3265A 采用 eTSSOP-28 封装,具体引脚分配详见文档中的 PIN CONFIGURATION 部分。
参数特性: - 工作电压范围 2.7V 至 5.5V - 输出电流能力:每个输出 60mA,共 18 个输出,耐压 40V - 1MHz I2C 接口与自动地址增量 - 可编程 H/L 逻辑:1.4V/0.4V,2.4V/0.6V - 全局电流调整 32 步 - 每个通道 8 位点校正 - 每个通道 8 位 PWM - 可选择的 PWM 方法(200Hz 或 25kHz) - 256 步群闪烁,频率可编程从 24Hz 至 10.66s,占空比从 0% 至 99.6% - 时钟 IO 引脚用于多芯片同步 - 故障报告(开路检测/热滚降/热关闭) - 热滚降可编程设定点 - SDB 上升沿重置 I2C 接口 - EMI 降低技术 - 工作温度范围 -40°C ~ +125°C 封装信息:eTSSOP-28 功能详解:IS32FL3265A 可以配置为通过拉低 SDB 引脚或使用软件关闭功能来实现最低电流消耗模式。
IS32FL3265A 采用专有算法最小化由 MLCC 去耦电容引起的可听噪声。
所有寄存器都可以通过 1MHz I2C 兼容接口进行编程。
应用信息:汽车显示屏、环境照明、屋顶照明、功能照明等。
IS32FL3265A-ZLA3-TR 价格&库存
很抱歉,暂时无法提供与“IS32FL3265A-ZLA3-TR”相匹配的价格&库存,您可以联系我们找货
IS32FL3265A-ZLA3-TR
  • 1+23.910281+3.10721
  • 10+17.8137510+2.31495
  • 25+16.2910025+2.11706
  • 100+14.61109100+1.89875
  • 250+13.81137250+1.79483
  • 500+13.49940500+1.75428
IS32FL3265A-ZLA3-TR
  • 2500+12.512972500+1.62610
  • 5000+12.260465000+1.59328
