IS31FL3745-CLS4-TR
IS31FL3745-CLS4-TR
    LUMISSIL
    XFBGA36
    IC LED DRIVER LIN DIM
IS31FL3745-CLS4-TR 数据手册
IS31FL3745 18×8 DOTS MATRIX LED DRIVER October 2018 GENERAL DESCRIPTION FEATURES The IS31FL3745 is a general purpose 18×n (n=1~8) LED Matrix programmed via 1MHz I2C compatible interface. Each LED can be dimmed individually with 8-bit PWM data and 8-bit DC scaling data which allowing 256 steps of linear PWM dimming and 256 steps of DC current adjustable level.              Additionally each LED open and short state can be detected, IS31FL3745 store the open or short information in Open-Short Registers. The Open-Short Registers allowing MCU to read out via I2C compatible interface. Inform MCU whether there are LEDs open or short and the locations of open or short LEDs. The IS31FL3745 operates from 2.7V to 5.5V and features a very low shutdown and operational current. IS31FL3745 is available in WLCSP-36 (2.93mm×2.93mm, 0.5mm ball pitch, 0.25mm ball diameter) package. It operates from 2.7V to 5.5V over the temperature range of -40°C to +125°C.    Supply voltage range: 2.7V to 5.5V 18 Current sink (Maximum) Support 18 × n (n=1~8) LED matrix configurations Individual 256 PWM control steps Individual 256 DC current steps Global 256 current setting SDB rising edge reset I2C module Programmable H/L logic:1.4/0.4, 2.4/0.6 29kHz PWM frequency 1MHz I2C-compatible interface State lookup registers Individual open and short error detect function 180 degree phase delay operation to reduce power noise De-Ghost Cascade for synchronization of chips WLCSP-36 (2.93mm×2.93mm, 0.5mm ball pitch, 0.25mm ball diameter) package APPLICATIONS   AI-speakers and smart home devices LED display for hand-held devices TYPICAL APPLICATION CIRCUIT Figure 1 Typical Application Circuit: 48 RGBs Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 1 IS31FL3745 Figure 2 Typical Application Circuit (Eight Parts Synchronization-Work) Note 1: IC should be placed far away from the antenna in order to prevent the EMI. Note 2: The 20R between LED and IC is only for thermal reduction, for mono red LED, if PVCC=VCC=3.3V, don’t need these resistors. Note 3: The VIH of I2C bus should be smaller than VCC. And if VIH is lower than 3.0V, it is recommended add a level shift circuit to avoid extra shutdown current. Note 4: One system should contain only one master, all slave parts should be configured as slave mode before the master is configured as master mode. Work as master mode or slave mode specified by Configuration Register (SYNC bits, register 25h, Page 2). Master part output master clock, and all the other parts which work as slave input this master clock. Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 2 IS31FL3745 PIN CONFIGURATION Package Pin Configuration (Top View) A1 SW3 A2 SW1 A3 PVCC A4 SW2 A5 SW4 A6 SW6 B1 SW5 B2 CS1 B3 CS2 B4 CS17 B5 CS18 B6 SW8 C1 SW7 C2 CS4 C3 CS3 C4 CS14 C5 CS16 C6 CS15 D1 CS6 D2 CS5 D3 SDA D4 ADDR1 D5 CS12 D6 CS13 E1 CS8 E2 CS7 E3 SCL E4 ADDR2 E5 SDB E6 CS11 F1 CS9 F2 SYNC F3 ISET F4 GND F5 VCC F6 CS10 WLCSP-36 PIN DESCRIPTION No. Pin Description A1, A2 SW3,SW1 Power SW. A3 PVCC Power for current source. A4~A6,B1 SW2,SW4,SW6,SW5 Power SW. B2~B5 CS1,CS2,CS17,CS18 Current sink pin for LED matrix. B6, C1 SW8,SW7 Power SW. C2~C6,D1,D2 CS4,CS3,CS14,CS16, CS15,CS6,CS5 Current sink pin for LED matrix. D3 SDA I2C compatible serial data. D4, E4 ADDR1, ADDR2 I2C address select pin. D5,D6,E1,E2 CS12,CS13,CS8,CS7 Current sink pin for LED matrix. E3 SCL I2C compatible serial clock. E5 SDB Shutdown pin. E6,F1 CS11,CS9 Current sink pin for LED matrix. F2 SYNC System clock output/input. F3 ISET Set the maximum IOUT current. F4 GND Power GND and analog GND. F5 VCC Power for digital circuits. F6 CS10 Current sink pin for LED matrix. Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 3 IS31FL3745 ORDERING INFORMATION Industrial Range: -40°C to +125°C Order Part No. Package QTY/Reel IS31FL3745-CLS4-TR WLCSP-36, Lead-free 2500 Copyright  ©  2018  Lumissil  Microsystems.  All  rights  reserved.  Lumissil Microsystems reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use  in such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances  Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 4 IS31FL3745 ABSOLUTE MAXIMUM RATINGS Supply voltage, VCC Voltage at any input pin Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TA=TJ Package thermal resistance, junction to ambient (4 layer standard test PCB based on JESD 51-2A), θJA ESD (HBM) ESD (CDM) -0.3V ~+6.0V -0.3V ~ VCC+0.3V +150°C -65°C ~+150°C -40°C ~ +125°C 47.49°C/W ±7kV ±1kV Note 5: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS The following specifications apply for VCC= 3.6V, TA= 25°C, unless otherwise noted. Symbol Parameter Conditions Min. Typ. VCC Supply voltage ICC Quiescent power supply current ISD Shutdown current IOUT Maximum constant current of CSx ILED Average current on each LED RISET= 10kΩ, GCC= 0xFF, ILED= IOUT(PEAK)×Duty (Duty=1/8.27) SL= 0xFF 4.21 Current switch headroom voltage ISWITCH= 306mA, RISET= 10kΩ, GCC= 0x80, SL= 0xFF SWx 250 Current sink headroom voltage CSx 300 VHR tSCAN Period of scanning tNOL1 tNOL2 2.7 Max. Unit 5.5 V mA VSDB= VCC, all LEDs off 1.9 3 VSDB= 0V 1.3 2.5 VSDB= VCC, Configuration Register written “0000 0000 (Software SD) 1.3 2.5 34.5 36.92 RISET= 10kΩ, GCC= 0xFF, SL= 0xFF 32.08 μA mA mA mV ISINK= 34mA, RISET= 10kΩ, GCC= 0xFF, SL= 0xFF (Note 6) 33 µs Non-overlap blanking time during scan, the SWx and CSy are all off during this time 0.83 µs Delay total time for CS1 to CS 18, during this time, the SWx is on but (Note 6) CSx is not all turned on 0.3 µs Logic Electrical Characteristics (SDA, SCL, ADDR1, ADDR2, SDB) VIL Logic “0” input voltage VCC=2.7V, LGC=0 VIH Logic “1” input voltage VCC=5.5V, LGC=0 Input Schmitt trigger hysteresis VCC=3.6V, LGC=0 VIL Logic “0” input voltage VCC=2.7V, LGC=1 VIH Logic “1” input voltage VCC=5.5V, LGC=1 Input Schmitt trigger hysteresis VCC=3.6V, LGC=1 0.2 V IIL Logic “0” input current VINPUT = L (Note 6) 5 nA IIH Logic “1” input current VINPUT = H (Note 6) 5 nA VHYS VHYS Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 0.4 1.4 V V 0.2 V 0.6 2.4 V V 5 IS31FL3745 DIGITAL INPUT SWITCHING CHARACTERISTICS (NOTE 6) Symbol Parameter fSCL Serial-clock frequency tBUF Bus free time between a STOP and a START condition Fast Mode Min. Typ. Fast Mode Plus Max. Min. Typ. Max. Units - 400 - 1000 kHz 1.3 - 0.5 - μs tHD, STA Hold time (repeated) START condition 0.6 - 0.26 - μs tSU, STA Repeated START condition setup time 0.6 - 0.26 - μs tSU, STO STOP condition setup time 0.6 - 0.26 - μs tHD, DAT Data hold time - - - - μs tSU, DAT Data setup time 100 - 50 - ns tLOW SCL clock low period 1.3 - 0.5 - μs tHIGH SCL clock high period 0.7 - 0.26 - μs tR Rise time of both SDA and SCL signals, receiving - 300 - 120 ns tF Fall time of both SDA and SCL signals, receiving - 300 - 120 ns Note 6: Guaranteed by design. Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 6 IS31FL3745 FUNCTIONAL BLOCK DIAGRAM Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 7 IS31FL3745 DETAILED DESCRIPTION I2C INTERFACE When I2C/SPI=H, the IS31FL3745 uses a serial bus, which conforms to the I2C protocol, to control the chip’s functions with two wires: SCL and SDA. The IS31FL3745 has a 7-bit slave address (A7:A1), followed by the R/W bit, A0. Set A0 to “0” for a write command and set A0 to “1” for a read command. The value of bits A1 and A2 are decided by the connection of the ADDRx pin. Table 1 Slave Address: ADDR2 ADDR1 GND GND GND GND SCL SCL SCL SCL SDA SDA SDA SDA VCC VCC VCC VCC GND SCL SDA VCC GND SCL SDA VCC GND SCL SDA VCC GND SCL SDA VCC A7:A5 A4:A3 A2:A1 010 00 00 00 00 01 01 01 01 10 10 10 10 11 11 11 11 00 01 10 11 00 01 10 11 00 01 10 11 00 01 10 11 A0 After the last bit of the chip address is sent, the master checks for the IS31FL3745’s acknowledge. The master releases the SDA line high (through a pull-up resistor). Then the master sends an SCL pulse. If the IS31FL3745 has received the address correctly, then it holds the SDA line low during the SCL pulse. If the SDA line is not low, then the master should send a “STOP” signal (discussed later) and abort the transfer. Following acknowledge of IS31FL3745, the register address byte is sent, most significant bit first. IS31FL3745 must generate another acknowledge indicating that the register address has been received. Then 8-bit of data byte are sent next, most significant bit first. Each data bit should be valid while the SCL level is stable high. After the data byte is sent, the IS31FL3745 must generate another acknowledge to indicate that the data was received. 0/1 ADDR1/2 connected to GND, (A2:A1)/(A4:A3)=00; ADDR1/2 connected to VCC, (A2:A1)/(A4:A3)=11; ADDR1/2 connected to SCL, (A2:A1)/(A4:A3)=01; ADDR1/2 connected to SDA, (A2:A1)/(A4:A3)=10; The SCL line is uni-directional. The SDA line is bidirectional (open-collector) with a pull-up resistor (typically 400kHz I2C with 4.7kΩ, 1MHz I2C with 1kΩ). The maximum clock frequency specified by the I2C standard is 1MHz. In this discussion, the master is the microcontroller and the slave is the IS31FL3745. The timing diagram for the I2C is shown in Figure 3. The SDA is latched in on the stable high level of the SCL. When there is no interface activity, the SDA line should be held high. The “START” signal is generated by lowering the SDA signal while the SCL signal is high. The start signal will alert all devices attached to the I2C bus to check the incoming address against their own chip address. Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 The 8-bit chip address is sent next, most significant bit first. Each address bit must be stable while the SCL level is high. The “STOP” signal ends the transfer. To signal “STOP”, the SDA signal goes high while the SCL signal is high. ADDRESS AUTO INCREMENT To write multiple bytes of data into IS31FL3745, load the address of the data register that the first data byte is intended for. During the IS31FL3745 acknowledge of receiving the data byte, the internal address pointer will increment by one. The next data byte sent to IS31FL3745 will be placed in the new address, and so on. The auto increment of the address will continue as long as data continues to be written to IS31FL3745 (Figure 7). READING OPERATION Most of the registers can be read. To read the FCh, FEh, after I2C start condition, the bus master must send the IS31FL3745 device ____ address with the R/W bit set to “0”, followed by the register address (FEh or F1h) which determines which register is accessed. Then restart I2C, the bus master should send the IS31FL3745 device address with the ____ R/W bit set to “1”. Data from the register defined by the command byte is then sent from the IS31FL3745 to the master (Figure 8). To read the registers of Page 0 thru Page 3, the FDh should write with 00h before follow the Figure 8 sequence to read the data. That means, when you want to read registers of Page 0, the FDh should point to Page 0 first and you can read the Page 0 data. 8 IS31FL3745 Figure 4 I2C Interface Timing Figure 5 I2C Bit Transfer Figure 6 I2C Writing to IS31FL3745 (Typical) Figure 7 I2C Writing to IS31FL3745 (Automatic Address Increment) Figure 8 I2C Reading From IS31FL3745 Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 9 IS31FL3745 Table 2 Command Register Definition Address Name Function Table R/W Default FEh Command Register Write lock To unlock Command Register 4 R/W 0000 0000 FDh Command Register Available Page 0 to Page 2 Registers 3 W xxxx xxxx FCh ID Register For read the product ID only Read result is the slave address - R Slave Address REGISTER CONTROL Table 3 FDh Command Register Data Function 0000 0000 Point to Page 0 (PG0, PWM Register is available) 0000 0001 Point to Page 1 (PG1, White balance Scaling Register is available) 0000 0010 Point to Page 2 (PG2, Function Register is available) Others Reserved Note: FDh is locked when power up, need to unlock this register before write command to it. See Table 4 for detail. The Command Register should be configured first after writing in the slave address to choose the available register. Then write data in the choosing register. Power up default state is “0000 0000”. For example, when write “0000 0001” in the Command Register (FDh), the data which writing after will be stored in Page1 (PG1). Table 4 FEh Command Register Write Lock (Read/Write) Bit D7:D0 Name CRWL Default 0000 0000 (FDh write disable) To select the PG0~PG2, need to unlock this register first, with the purpose to avoid mis-operation of this register. When FEh is written with 0xC5, FDh is allowed to modify once, after the FDh is modified the FEh will reset to be 0x00 at once. Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 10 IS31FL3745 Table 5 Register Definition Address Name Function Table R/W Default Set PWM for each LED 6 R/W 0000 0000 Set Scaling for each LED 7 R/W 0000 0000 PG0 (0x00): PWM Register 01h~90h PWM Register PG1 (0x01): LED Scaling 01h~90h Scaling Register PG2 (0x02): Function Register 00h Configuration Register Configure the operation mode 9 R/W 0000 0000 01h Global Current Control Register Set the global current 10 R/W 0000 0000 02h Pull Down/Up Resistor Selection Register Set the pull down resistor for SWx and pull up resistor for CSy 11 R/W 0101 0101 03h~1Ah Open/Short Register Store the open or short information 12 R 0000 0000 24h Temperature Status Store the temperature point of the IC 13 R/W 0000 0000 25h Spread Spectrum Register Spread spectrum function enable 14 R/W 0000 0000 2Fh Reset Register Reset all register to POR state - W 0000 0000 Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 11 IS31FL3745 Page 0 (PG0, FDh= 0x00): PWM Register Figure 9 PWM Register Table 6 PG0: 01h ~ 90h PWM Register Bit D7:D0 Name PWM Default 0000 0000 PWM  I OUT ( PEAK )  Duty (1) 256 PWM  33s 1 1   33s  0.83s  0.3s 8 8.27 IOUT(PEAK)  n n 0 343 GCC SL   RISET 256 256 (3) GCC is the Global Current Control register (PG2, 01h) value, SL is the Scaling Register value as Table 9 and RISET is the external resistor of ISET pin. D[n] stands for the individual bit value, 1 or 0, in location n. For example: if D7:D0=1011 0101 (0xB5, 181), GCC=1111 1111, RISET=10kΩ, SL=1111 1111: 7  D[n ]  2 (2) IOUT is the output current of CSy (y=1~18), Each dot has a byte to modulate the PWM duty in 256 steps. The value of the PWM Registers decides the average current of each LED noted ILED. ILED computed by Formula (1): I LED  Duty  I LED  343 255 255 1 181     10 k 256 256 8 .27 256 Where Duty is the duty cycle of SWx, Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 12 IS31FL3745 Page 1 (PG1, FDh= 0x01): Scaling Register Figure 10 Scaling Register IOUT is the output current of CSy (y=1~18), GCC is the Global Current Control Register (PG2, 01h) value and RISET is the external resistor of ISET pin. D[n] stands for the individual bit value, 1 or 0, in location n. Table 7 PG1: 01h ~ 90h Scaling Register Bit D7:D0 Name SL Default 0000 0000 Scaling register control the DC output current of each dot. Each dot has a byte to modulate the scaling in 256 steps. The value of the Scaling Register decides the peak current of each LED noted IOUT(PEAK). 343 GCC SL   RISET 256 256 SL  SL  (3) 7  D[ n ]  2 n  127 n0 I OUT  IOUT(PEAK) computed by Formula (3): IOUT(PEAK)  For example: if RISET=10kΩ, GCC=1111 1111, SL=0111 1111: 343 255 127    16 .8 mA 10 k  256 256 I LED  16 .8 mA  1 PWM  8 .27 256 7  D[n ]  2 n n0 Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 13 IS31FL3745 Table 8 Page 2 (PG2, FDh= 0x02): Function Register Register Name Function Table R/W Default 00h Configuration Register Configure the operation mode 10 R/W 0000 0000 01h Global Current Control Register Set the global current 11 R/W 0000 0000 02h Pull Down/Up Resistor Selection Register Set the pull down resistor for SWx and pull up resistor for CSy 12 R/W 0101 0101 03h~1Ah Open/Short Register Store the open or short information 13 R 0000 0000 24h Temperature Status Store the temperature point of the IC 14 R/W 0000 0000 25h Spread Spectrum Register Spread spectrum function enable 15 R/W 0000 0000 2Fh Reset Register Reset all register to POR state - W 0000 0000 Table 9 00h Configuration Register Bit D7:D4 D3 D2:D1 D0 Name SWS LGC OSDE SSD Default 0000 0 00 0 The Configuration Register sets operating mode of IS31FL3745. SSD 0 1 Software Shutdown Control Software shutdown Normal operation OSDE 00 01/11 10 Open Short Detection Enable Disable open/short detection Enable open detection Enable short detection LGC 0 1 H/L Logic 1.4V/0.4V 2.4V/0.6V SWS 0000 0001 0010 0011 0100 0101 0110 0111 1000 1001 1010 Others SWx Setting 1/11 (default, not recommend) SW1~SW8, 1/10, (not recommend) SW1~SW8, 1/9, (not recommend) SW1~SW8, 1/8 SW1~SW7, 1/7, SW8 no-active SW1~SW6, 1/6, SW7~SW8 no-active SW1~SW5, 1/5, SW6~SW8 no-active SW1~SW4, 1/4, SW5~SW8 no-active SW1~SW3, 1/3, SW4~SW8 no-active SW1~SW2, 1/2, SW3~SW8 no-active All CSx work as current sinks only, no scan Not allowed When OSDE set “10”, short detection will be trigger once, the user could trigger short detection again by set OSDE from “00” to “10”. When SSD is “0”, IS31FL3745 works in software shutdown mode and to normal operate the SSD bit should set to “1”. SWS control the duty cycle of the SW, default mode is 1/11. Table 10 01h Global Current Control Register Bit D7:D0 Name GCC Default 0000 0000 The Global Current Control Register modulates all CSy (x=1~18) DC current which is noted as IOUT in 256 steps. IOUT is computed by the Formula (3): IOUT(PEAK)  343 GCC SL   RISET 256 256 GCC  (3) 7  D[ n ]  2 n n0 Where D[n] stands for the individual bit value, 1 or 0, in location n. Table 11 02h Pull Down/Up Resistor Selection Register Bit D7 D6:D4 D3 D2:D0 Name PHC SWPDR - CSPUR Default 0 011 0 011 Set pull down resistor for SWx and pull up resistor for CSy. When OSDE set to “01”, open detection will be trigger once, the user could trigger open detection again by set OSDE from “00” to “01”. Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 14 IS31FL3745 PHC 0 1 Phase choice 0 degree phase delay 180 degree phase delay SWPDR SWx Pull down Resistor Selection Bit 000 No pull down resistor 001 0.5kΩ only in SWx off time 010 1.0kΩ only in SWx off time 011 2.0kΩ only in SWx off time 100 1.0kΩ all the time 101 2.0kΩ all the time 110 4.0kΩ all the time 111 8.0kΩ all the time CSPUR CSy Pull up Resistor Selection Bit 000 No pull up resistor 001 0.5kΩ only in CSx off time 010 1.0kΩ only in CSx off time 011 2.0kΩ only in CSx off time 100 1.0kΩ all the time 101 2.0kΩ all the time 110 4.0kΩ all the time 111 8.0kΩ all the time Table 12 Open/Short Register (Read Only) 03h~1Ah Open/Short Information Bit D7:D6 D5:D0 Name - CS18:CS13, CS12:CS07,CS06:CS01 Default 00 00 0000 When OSDE (PG2, 00h) is set to “01”, open detection will be trigger once, and the open information will be stored at 03h~1Ah. When OSDE (PG2, 00h) set to “10”, short detection will be trigger once, and the short information will be stored at 03h~1Ah. Before set OSDE, the GCC should set to 0x01. Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 Figure 11 Open/Short Register Table 13 24h Temperature Status Bit D7:D4 D3:D2 D1:D0 Name - TS TROF Default 0000 00 00 TS store the temperature point of the IC. If the IC temperature reaches the temperature point the IC will trigger the thermal roll off and will decrease the current as TROF set percentage. TROF 00 01 10 11 percentage of output current 100% 75% 55% 30% TS 00 01 10 11 Temperature Point, Thermal roll off start point 140°C 120°C 100°C 90°C 15 IS31FL3745 Table 14 25h Spread Spectrum Register Bit D7:D6 D4 D3:D2 D1:D0 Name SYNC SSP RNG CLT Default 00 0 00 00 When SYNC bits are set to “11”, the IS31FL3745 is configured as the master clock source and the SYNC pin will generate a clock signal distributed to the clock slave devices. To be configured as a clock slave device and accept an external clock input the slave device’s SYNC bits must be set to “10”. When SSP enable, the spread spectrum function will be enabled and the RNG & CLT bits will adjust the range and cycle time of spread spectrum function. SYNC 0x 10 11 Enable of SYNC function Disable SYNC function, about 30kΩ pull-low Slave, clock input Master, clock output Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 SSP 0 1 Spread spectrum function enable Disable Enable RNG 00 01 10 11 Spread spectrum range ±5% ±15% ±24% ±34% CLT 00 01 10 11 Spread spectrum cycle time 1980μs 1200μs 820μs 660μs 2Fh Reset Register Once user writes the Reset Register with 0xAE, IS31FL3745 will reset all the IS31FL3745 registers to their default value. On initial power-up, the IS31FL3745 registers are reset to their default values for a blank display. 16 IS31FL3745 APPLICATION INFORMATION SW01 SW02 SW03 SW04 SW05 SW06 SW07 SW08 CS18 tNOL2=0.3µs CS01 tSCAN=33µs tNOL1=0.83µs Scanning cycle T=273us((33+0.83+0.3)×8) De-Ghost time I OUT PWM Duty is variable from 0/256~255/256  343 GCC SL   R ISET 256 256 Figure 12 Scanning Timing I LED  I OUT ( PEAK )  SCANING TIMING As shown in Figure 12, the SW1~SW8 is turned on by serial, LED is driven 8 by 8 within the SWx (x=1~8) on time (SWx, x=1~8 is source and it is high when LED on) , including the non-overlap blanking time during scan, the duty cycle of SWx (active high, x=1~8) is: 33s 1 1 Duty    33s  0.83s  0.3s 8 8.27 (2) Where 33μs is tSCAN, the period of scanning, 0.83μs is tNOL1, 0.3μs is tNOL2, the non-overlap time and CSx delay time. PWM CONTROL After setting the IOUT and GCC, the brightness of each LEDs (LED average current (ILED)) can be modulated with 256 steps by PWM Register, as described in Formula (1). I LED  PWM  I OUT ( PEAK )  Duty (1) 256 PWM 1  8.27 256 Writing new data continuously to the registers can modulate the brightness of the LEDs to achieve a breathing effect. GAMMA CORRECTION In order to perform a better visual LED breathing effect we recommend using a gamma corrected PWM value to set the LED intensity. This results in a reduced number of steps for the LED intensity setting, but causes the change in intensity to appear more linear to the human eye. Gamma correction, also known as gamma compression or encoding, is used to encode linear luminance to match the non-linear characteristics of display. Since the IS31FL3745 can modulate the brightness of the LEDs with 256 steps, a gamma correction function can be applied when computing each subsequent LED intensity setting such that the changes in brightness matches the human eye's brightness curve. Where PWM is PWM Registers (PG0, 00h~B3h /PG1, 00h~AAh) data showing in Table 6. For example, in Figure 1, if RISET= 10kΩ, PWM= 255, and GCC= 255, SL= 255, then I OUT ( PEAK )  343 255 255    34 mA 10 k  256 256 Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 17 IS31FL3745 256 Table 15 32 Gamma Steps with 256 PWM Steps C(1) C(2) C(3) C(4) C(5) C(6) C(7) 0 1 2 4 6 10 13 18 C(8) C(9) C(10) C(11) C(12) C(13) C(14) C(15) 22 28 33 39 46 53 61 69 C(16) C(17) C(18) C(19) C(20) C(21) C(22) C(23) 78 86 96 106 116 126 138 149 C(24) C(25) C(26) C(27) C(28) C(29) C(30) C(31) 161 173 186 199 212 226 240 255 256 224 192 PWM Data C(0) 160 128 96 64 32 224 0 0 8 16 PWM Data 192 32 40 48 56 64 Intensity Steps 160 Figure 14 Gamma Correction (64 Steps) 128 Note: The data of 32 gamma steps is the standard value and the data of 64 gamma steps is the recommended value. 96 OPERATING MODE 64 32 0 0 4 8 12 16 20 24 28 32 Intensity Steps Figure 13 Gamma Correction (32 Steps) Choosing more gamma steps provides for a more continuous looking breathing effect. This is useful for very long breathing cycles. The recommended configuration is defined by the breath cycle T. When T=1s, choose 32 gamma steps, when T=2s, choose 64 gamma steps. The user must decide the final number of gamma steps not only by the LED itself, but also based on the visual performance of the finished product. Table 16 64 Gamma Steps with 256 PWM Steps C(0) 24 C(1) C(2) C(3) C(4) C(5) C(6) C(7) 0 1 2 3 4 5 6 7 C(8) C(9) C(10) C(11) C(12) C(13) C(14) C(15) 8 10 12 14 16 18 20 22 C(16) C(17) C(18) C(19) C(20) C(21) C(22) C(23) 24 26 29 32 35 38 41 44 C(24) C(25) C(26) C(27) C(28) C(29) C(30) C(31) 47 50 53 57 61 65 69 73 C(32) C(33) C(34) C(35) C(36) C(37) C(38) C(39) 77 81 85 89 94 99 104 109 C(40) C(41) C(42) C(43) C(44) C(45) C(46) C(47) 114 119 124 129 134 140 146 152 C(48) C(49) C(50) C(51) C(52) C(53) C(54) C(55) 158 164 170 176 182 188 195 202 C(56) C(57) C(58) C(59) C(60) C(61) C(62) C(63) 209 216 223 230 237 244 251 255 Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 IS31FL3745 can only operate in PWM Mode. The brightness of each LED can be modulated with 256 steps by PWM registers. For example, if the data in PWM Register is “0000 0100”, then the PWM is the fourth step. Writing new data continuously to the registers can modulate the brightness of the LEDs to achieve a breathing effect. OPEN/SHORT DETECT FUNCTION IS31FL3745 has open and short detect bit for each LED. By setting the OSD bits of the Configuration Register (PG2, 00h) from “00” to “01” or “10”, the LED Open/short Register will start to store the open/short information and after at least 2 scanning cycles and the MCU can get the open/short information by reading the 03h~1Ah, for those dots are turned off via LED Scaling Registers (PG1, 00h~90h), the open/short data will not get refreshed when setting the OSD bit of the Configuration Register. To get the correct open and short information, two configurations need to set before setting the OSD bits: 1 2 0x0F≤ GCC≤ 0x40 02h= 0x00 Where GCC is the Global Current Control Register (PG2, 01h) and 02h is the Pull Down/UP Resistor Selection Register and set to 0x00 is to disable the SWx pull-down and CSy pull-up function. The detect action is one-off event and each time before reading out the open/short information, the OSD bit of the Configuration Register (PG2, 00h) need to be set from “0” to “1” (clear before set operation). 18 IS31FL3745 De-Ghost Function LAYOUT The “ghost” term is used to describe the behavior of an LED that should be OFF but instead glows dimly when another LED is turned ON. A ghosting effect typically can occur when multiplexing LEDs. In matrix architecture any parasitic capacitance found in the constant-current outputs or the PCB traces to the LEDs may provide sufficient current to dimly light an LED to create a ghosting effect. The IS31FL3745 consumes lots of power so good PCB layout will help improve the reliability of the chip. Please consider below factors when layout the PCB. To prevent this LED ghost effect, the IS31FL3745 has integrated Pull down resistors for each SWx (x=1~8) and Pull up resistors for each CSy (y=1~18). Select the right SWx Pull down resistor (PG2, 02h) and CSy Pull up resistor (PG2, 02h) which eliminates the ghost LED for a particular matrix layout configuration. Typically, selecting the 2kΩ will be sufficient to eliminate the LED ghost phenomenon. The SWx Pull down resistors and CSy Pull up resistors are active only when the CSy/SWx output working the OFF state and therefore no power is lost through these resistors. When IS31FL3745 works in hardware shutdown mode, the de-ghost function should be disabled, otherwise it will be extra about 1μA shutdown current. I2C RESET The I2C will be reset if the SDB pin is pull-high from 0V to logic high, at the operating SDB rising edge, the I2C operation is not allowed. SHUTDOWN MODE Shutdown mode can be used as a means of reducing power consumption. During shutdown mode all registers retain their data. Software Shutdown By setting SSD bit of the Configuration Register (PG2, 00h) to “0”, the IS31FL3745 will operate in software shutdown mode. When the IS31FL3745 is in software shutdown, all current sources are switched off, so that the matrix is blanked. All registers can be operated. Typical current consume is 1μA. Power Supply Lines When designing the PCB layout pattern, the first step should consider about the supply line and GND connection, especially those traces with high current, also the digital and analog blocks’ supply line and GND should be separated to avoid the noise from digital block affect the analog block. At least one 0.1μF capacitor, if possible with a 1μF capacitor is recommended to connected to the ground at each power supply pins of the chip, and it needs to close to the chip and the ground net of the capacitor should be well connected to the GND plane. RISET RISET should be close to the chip and the ground side should well connect to the GND plane. Thermal Consideration The over temperature of the chip may result in deterioration of the properties of the chip. IS31FL3745 does not have thermal pad, so for thermal radiation, increase the board size and GND copper area, especially near the GND pins and the opposite layer of the chip. Current Rating Example For a RISET=20kΩ application, the current rating for each net is as follows: • PVCC and SWx pins = 17.3×18=311.4mA, recommend trace width: 0.2032mm~0.5mm • CSy pins = 17.3mA, recommend trace width: 0.0762mm~0.254mm • VCC and all other pins< 3mA, recommend trace width: 0.0762mm~0.254mm Hardware Shutdown The chip enters hardware shutdown when the SDB pin is pulled low. All analog circuits are disabled during hardware shutdown, typical the current consume is 1μA. The chip releases hardware shutdown when the SDB pin is pulled high. During hardware shutdown state Function Register can be operated. If VCC has risk drop below 1.75V but above 0.1V during SDB pulled low, please re-initialize all Function Registers before SDB pulled high. Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 Figure 15 Layout Example 19 IS31FL3745 CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) 150°C 200°C 60-120 seconds Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) Time at liquidous (tL) 217°C 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified classification temperature (Tc) Max 30 seconds Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature 8 minutes max. Figure 16 Classification Profile Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 20 IS31FL3745 PACKAGE INFORMATION WLCSP-36 Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 21 IS31FL3745 RECOMMENDED LAND PATTERN WLCSP-36 0.5mm 0.25mm 0.5mm Note: 1. Land pattern complies to IPC-7351. 2. All dimensions in MM. 3. This document (including dimensions, notes & specs) is a recommendation based on typical circuit board manufacturing parameters. Since land pattern design depends on many factors unknown (eg. User’s board manufacturing specs), user must determine suitability for use. Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 22 IS31FL3745 REVISION HISTORY Revision Detail Information Date 0A Initial release 2018.06.04 A Update EC table and add detail description 2018.10.08 Lumissil Microsystems – www.lumissil.com Rev. A, 10/08/2018 23
IS31FL3745-CLS4-TR 价格&库存
很抱歉,暂时无法提供与“IS31FL3745-CLS4-TR”相匹配的价格&库存,您可以联系我们找货
IS31FL3745-CLS4-TR
  • 2500+12.264532500+1.53402
库存:2100
IS31FL3745-CLS4-TR
  • 1+23.437871+2.93154
  • 10+17.4791110+2.18624
  • 25+15.9785425+1.99855
  • 100+14.32875100+1.79220
  • 250+13.54163250+1.69375
  • 500+13.06721500+1.63441
  • 1000+12.676741000+1.58557
库存:2100
