IS32FL3238-ZLA3-TR
IS32FL3238-ZLA3-TR
    LUMISSIL
    TSSOP28
    18 CHANNEL LED DRIVER ETSSOP-28
IS32FL3238-ZLA3-TR 数据手册
IS32FL3238 18-CHANNEL LED DRIVER March 2020 GENERAL DESCRIPTION FEATURES IS32FL3238 is an LED driver with 18 constant current channels. Each channel can be pulse width modulated (PWM) by 16 bits for smooth LED brightness control. In addition, each channel has an 8-bit output current control register which allows fine tuning the current for rich RGB color mixing, e.g., a pure white color LED application. The maximum output current of each channel is designed to be 78mA, which can be adjusted by one 8-bit global control register. Proprietary programmable algorithms are used in IS32FL3238 to minimize audible noise caused by the MLCC decoupling capacitor. All registers can be programmed via a high speed I2C (1MHz).         IS32FL3238 can be turned off with minimum current consumption by either pulling the SDB pin low or by using the software shutdown feature. IS32FL3238 is available in eTSSOP-28 package. It operates from 2.7V to 5.5V over the temperature range of -40°C to +125°C    2.7V to 5.5V VCC supply 1MHz I2C interface, automatic address increment function with readout function Four selectable I2C addresses Accurate color rendition - Selectable 8-bit/10-bit/12-bit/16-bit PWM - 8-bit dot correction - 8-bit global current adjust Open/short detect function 62kHz PWM frequency(8-bit PWM) Temperature detect function EMI/Noise reduction technology - Spread spectrum - Selectable phase delay - Selectable 180 degree clock phase -40°C to +125°C temperature range eTSSOP-28 package AEC-Q100 Qualified APPLICATIONS     Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2020 Ambient lighting Roof lighting Display backlight Functional lighting 1 IS32FL3238 TYPICAL APPLICATION CIRCUIT *Note 1 *Note 1 VCC = VBattery 27 VCC 26 OUT1 AD 1 F 0.1 F OUT2 5 VLED+ = VBattery 6 *Note 2 VIH 2k OUT3 7 2k 3 SDA 4 Micro Controller 100k IS32FL3238 SCL 25 SDB 0.1 F OUT16 2 RISET 6.8k ISET 1,14 OUT17 OUT18 GND 15,28 Figure 1 22 23 24 Typical Application Circuit *Note 1 *Note 3 VCC = 5V 27 26 1 F VCC OUT1 AD 0.1 F OUT2 5 33 6 91 7 33 22 33 23 91 24 33 *Note 2 VIH 2k OUT3 *Note 1 VLED+ = 5V 2k 3 4 Micro Controller 25 SDA SCL IS32FL3238 SDB 100k 0.1 F OUT16 2 RISET 6.8k 1,14 15,28 ISET GND Figure 2 OUT17 OUT18 Typical Application Circuit (VCC = 5V) Note 1: VLED+ should be same as VCC voltage. Note 2: VIH is the high level voltage for IS32FL3238, which is usually same as VCC of Micro Controller, e.g. if VCC of Micro Controller is 3.3V, VIH=3.3V. If VCC=5V and VIH is lower than 2.8V, recommend to add a level shift circuit. 2 Note 3: These optional resistors are for offloading the thermal dissipation (P=I R) away from the IS32FL3238. Note 4: The output current is set up to 78mA when RISET= 2kΩ. The maximum global output current can be set by external resistor, RISET. Please refer to the detail application information in RISET section. Note 5: The IC and LED should be placed far away from the antenna in order to prevent the EMI. Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2020 2 IS32FL3238 PIN CONFIGURATION Package Pin Configuration (Top View) eTSSOP-28 GND 1 28 GND ISET 2 27 VCC SDA 3 26 AD SCL 4 25 SDB OUT1 5 24 OUT18 OUT2 6 23 OUT17 OUT3 7 22 OUT16 OUT4 8 21 OUT15 OUT5 9 20 OUT14 OUT6 10 19 OUT13 OUT7 11 18 OUT12 OUT8 12 17 OUT11 OUT9 13 16 OUT10 GND 14 15 GND PIN DESCRIPTION No. Pin Description 1,14,15,28 GND Ground. 2 ISET Input terminal used to connect an external resistor. This regulates the global output current. When RISET= 6.8kΩ, IOUT= 23mA. 3 SDA I2C serial data. 4 SCL I2C serial clock. 5~7 OUT1~OUT3 Output channel 1~3 for LEDs. 8~13 OUT4~OUT9 Output channel 4~9 for LEDs. 16~21 OUT10~OUT15 Output channel 10~15 for LEDs. 22~24 OUT16~OUT18 Output channel 16~18 for LEDs. 25 SDB Shutdown the chip when pulled low. 26 AD I2C address setting. 27 VCC Power supply. Thermal Pad Connect to GND. Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2020 3 IS32FL3238 ORDERING INFORMATION Automotive Range: -40°C to +125°C Order Part No. Package QTY/Reel IS32FL3238-ZLA3-TR eTSSOP-28, Lead-free 2500 Copyright  ©  2020  Lumissil  Microsystems.  All  rights  reserved.  Lumissil  Microsystems reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use in  such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2020 4 IS32FL3238 ABSOLUTE MAXIMUM RATINGS Supply voltage, VCC Voltage at SCL, SDA, SDB, AD, OUT1 to OUT18 Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TA=TJ Package thermal resistance, junction to ambient (4 layer standard test PCB based on JESD 51-2A), θJA Package thermal resistance, junction to thermal PAD (4 layer standard test PCB based on JEDEC standard), θJP ESD (HBM) ESD (CDM) -0.3V ~ +6.0V -0.3V ~ VCC+0.3V +150°C -65°C ~ +150°C -40°C ~ +150°C 32.3°C/W 11.08°C/W ±2kV ±750V Note 6: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS Typical values are TA = 25°C, VCC = 5V. Symbol VCC Parameter Condition Supply voltage Min. Typ. 2.7 Max. Unit 5.5 V Maximum output current VCC= 5V, VOUT= 0.8V, RISET= 2kΩ, GCC= 0xFF, Scaling= 0xFF (Note 7) 78 mA Output current VCC= 5V, VOUT= 0.4V, RISET= 6.8kΩ, GCC= 0xFF, Scaling= 0xFF 23 mA ∆IMAT IOUT mismatch in chip RISET= 6.8kΩ, GCC= 0xFF, Scaling= 0xFF, IOUT= 23mA -8 8 % ∆IOUT IOUT mismatch between chip RISET= 6.8kΩ, GCC= 0xFF, Scaling= 0xFF, IOUT= 23mA -8 8 % Headroom voltage RISET= 6.8kΩ, GCC= 0xFF, Scaling= 0xFF, IOUT= 23mA 0.2 0.35 V VCC= 5V, RISET= 6.8kΩ, GCC= 0xFF, Scaling= 0xFF, IOUT= 23mA, PWM= 0x00 5 10 mA VCC= 3.6V, RISET= 6.8kΩ, GCC= 0xFF, Scaling= 0xFF, IOUT= 23mA, PWM= 0x00 4 7 mA VCC= 5V, RISET= 6.8kΩ, VSDB= 0V or software shutdown 2 3 μA VCC= 3.6V, RISET= 6.8kΩ, VSDB= 0V or software shutdown 1 2 μA 0.1 μA 34 kHz IOUT VHR ICC ISD Quiescent power supply current Shutdown current IOZ Output leakage current VSDB= 0V or software shutdown, VOUT= 5.5V fOUT PWM frequency of output OSC= 8MHz, PWM Resolution= 8bit Thermal shutdown (Note 8) 165 °C (Note 8) 20 °C TSHDN TSHDNHYST Hysteresis 29 31.5 VOD OUTx pin open detect threshold RISET=6.8kΩ, IOUT≥0.1mA, measured at OUTx 0.08 0.18 0.26 V VSD LED short detect threshold RISET=6.8kΩ, IOUT≥0.1mA, measured at (VCC-VOUTx) 0.7 1.3 1.5 V Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2020 5 IS32FL3238 ELECTRICAL CHARACTERISTICS (CONTINUE) Typical values are TA = 25°C, VCC = 5V. Symbol Parameter Condition Min. Typ. Max. Unit 0.4 V Logic Electrical Characteristics (SDA, SCL, SDB, AD) VIL Logic “0” input voltage VCC= 2.7V~5.5V VIH Logic “1” input voltage VCC= 2.7V~5.5V IIL Logic “0” input current VINPUT= 0V (Note 8) 5 nA IIH Logic “1” input current VINPUT= VCC (Note 8) 5 nA 1.4 V DIGITAL INPUT SWITCHING CHARACTERISTICS (NOTE 8) Symbol Parameter Fast Mode Min. Typ. Fast Mode Plus Typ. Max. Units Max. Min. - 400 - 1000 kHz fSCL Serial-clock frequency tBUF Bus free time between a STOP and a START condition 1.3 - 0.5 - μs tHD, STA Hold time (repeated) START condition 0.6 - 0.26 - μs tSU, STA Repeated START condition setup time 0.6 - 0.26 - μs tSU, STO STOP condition setup time 0.6 - 0.26 - μs tHD, DAT Data hold time - - - - μs tSU, DAT Data setup time 100 - 50 - ns tLOW SCL clock low period 1.3 - 0.5 - μs tHIGH SCL clock high period 0.7 - 0.26 - μs tR Rise time of both SDA and SCL signals, receiving - 300 - 120 ns tF Fall time of both SDA and SCL signals, receiving - 300 - 120 ns Note 7: The recommended minimum value of RISET is 2kΩ. Note 8: Guaranteed by design. Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2020 6 IS32FL3238 FUNCTIONAL BLOCK DIAGRAM Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2020 7 IS32FL3238 DETAILED DESCRIPTION Then the master sends an SCL pulse. If the IS32FL3238 has received the address correctly, then it holds the SDA line low during the SCL pulse. If the SDA line is not low, then the master should send a “STOP” signal (discussed later) and abort the transfer. I2C INTERFACE The IS32FL3238 uses a serial bus, which conforms to the I2C protocol, to control the chip’s functions with two wires: SCL and SDA. The IS32FL3238 has a 7-bit slave address (A7:A1), followed by the R/W bit, A0. Set A0 to “0” for a write command and set A0 to “1” for a read command. The value of bits A1 and A2 are decided by the connection of the AD pin. The complete slave address is: Following acknowledge of IS32FL3238, the register address byte is sent, most significant bit first. IS32FL3238 must generate another acknowledge indicating that the register address has been received. Then 8-bit of data byte are sent next, most significant bit first. Each data bit should be valid while the SCL level is stable high. After the data byte is sent, the IS32FL3238 must generate another acknowledge to indicate that the data was received. Table 1 Slave Address Bit A7:A3 A2:A1 A0 Value 01101 AD 0/1 AD connected to GND, AD = 00; AD connected to VCC, AD = 11; AD connected to SCL, AD = 01; AD connected to SDA, AD = 10; The “STOP” signal ends the transfer. To signal “STOP”, the SDA signal goes high while the SCL signal is high. ADDRESS AUTO INCREMENT The SCL line is uni-directional. The SDA line is bi-directional (open-drain) with a pull-up resistor (typically 2kΩ). The maximum clock frequency specified by the I2C standard is 1MHz. In this discussion, the master is the microcontroller and the slave is the IS32FL3238. To write multiple bytes of data into IS32FL3238, load the address of the data register that the first data byte is intended for. During the IS32FL3238 acknowledge of receiving the data byte, the internal address pointer will increment by one. The next data byte sent to IS32FL3238 will be placed in the new address, and so on. The auto increment of the address will continue as long as data continues to be written to IS32FL3238 (Figure 6). The timing diagram for the I2C is shown in Figure 3. The SDA is latched in on the stable high level of the SCL. When there is no interface activity, the SDA line should be held high. READING OPERATION The “START” signal is generated by lowering the SDA signal while the SCL signal is high. The start signal will alert all devices attached to the I2C bus to check the incoming address against their own chip address. The 8-bit chip address is sent next, most significant bit first. Each address bit must be stable while the SCL level is high. After the last bit of the chip address is sent, the master checks for the IS32FL3238’s acknowledge. The master releases the SDA line high (through a pull-up resistor). Figure 3 Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2020 Most of the registers can be read. To read the register, after I2C start condition, the bus master must send the IS32FL3238 device address ____ with the R/W bit set to “0”, followed by the register address which determines which register is accessed. Then restart I2C, the bus master should send the ____ IS32FL3238 device address with the R/W bit set to “1”. Data from the register defined by the command byte is then sent from the IS32FL3238 to the master (Figure 7). Interface Timing 8 IS32FL3238 Figure 4 Figure 5 Figure 6 Bit Transfer Writing to IS32FL3238 (Typical) Writing to IS32FL3238 (Automatic Address Increment) Figure 7 Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2020 Reading from IS32FL3238 9 IS32FL3238 REGISTER DEFINITIONS Table 2 Register Function Address Name Function R/W Table Control Register Power control register R/W 3 PWM Register Channel [18:1] PWM register byte R/W 5 Update Register Update the PWM and scaling data W - LED Scaling Register Control each channel’s DC current R/W 7 6Eh Global Current Control Register Control global DC current/SSD R/W 8 70h Phase Delay and Clock Phase Register Phase delay and clock phase R/W 9 71h Open Short Detect Enable Register Open short detect enable R/W 10 LED Open/Short Register Open short information R/W 11 77h Temperature Sensor Register Temperature information R/W 12 78h Spread Spectrum Register Spread spectrum control register R/W 13 7Fh Reset Register Reset all registers W - 00h 01h~48h 49h 4Ah~6Dh 72h~76h Table 3 00h Control Register Default 0000 0000 Table 4 PWM Frequency PWM 16M Resolution Bit D7 D6:D4 D3 D2:D1 D0 Name - OSC - PMS SSD 8-bit Default 0 000 0 00 0 The Control Register sets software shutdown mode, internal oscillator clock frequency and PWM resolution. The internal oscillator clock frequency and the PWM resolution will decide the output PWM frequency. Recommend using lower than 500Hz option or higher than 20kHz options to avoid the MLCC’s audible noise as shown in Table 4. SSD 0 1 Software Shutdown Enable Software shutdown mode Normal operation PMS 00 01 10 11 PWM Resolution N=256, 8-bit N=1024, 10-bit N=4096, 12-bit N=65536, 16-bit OSC 000 001 010 011 100 101 110 111 Oscillator Clock Frequency Selection 16MHz 8MHz 1MHz 500kHz 250kHz 125kHz 62kHz 31kHz Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2020 8M 1M 500k 250k 125k 62k 31k 62k 32k 4k 0.5k 244 122 10-bit 16k 8k 1k 0.5k 244 122 NA NA 12-bit 4k 2k 244 122 NA NA NA NA 16-bit 244 122 NA NA NA NA NA NA 2k 1k Table 5 01h~48h PWM Register Reg 02h (04h, 06h…) 01h (03h, 05h…) Bit D7:D0 D7:D0 Name PWMX_H PWMX_L Default 0000 0000 0000 0000 X=A or B, Each output has 2 bytes × 2, total 4 registers to modulate the PWM duty in 256/1024/4096/65536 steps. For example, OUT1 use 04h/03h (PWMB), 02h/01 (PWMA) to modulate the PWM, OUT2 use 08h/07h (PWMB), 06h/05 (PWMA) to modulate the PWM, etc., If using the 8 bit PWM resolution, only the PWM_L needs to be set. The value of the SL (LED Scaling Register) decides the peak current of each LED noted as IOUT. IOUT and the value of the PWM Registers decide the average current of each LED noted as ILED. IOUT computed by Formula (1): I OUT  I OUT ( MAX )  GCC SLB  SLA  256 512 (1) ILED computed by Formula (2): 10 IS32FL3238 I LED  PWMB  PWMA  I OUT 2N PWMA  PWMB  (2) 15  D[ n ]  2 n (3) n0 15  D[ n ]  2 n 1 (4) n0 2 Where IOUT(MAX) is the maximum output current decided by RISET (check RISET section for more information), GCC is the global current setting (6Eh), and SLB, SLA are the scaling of each output (4Ah~6Dh), N=256/1024/4096/65536(8/10/12/16 bits PWM resolution) For example: RISET=6.8kΩ, GCC=0xFF, SL=0xFF, PMS= “11” (16 bits PWM resolution), PWMA_H=0xFF, PWMA_L=0xFF, PWMB_H=0xFF, PWMB_L=0xFF, IOUT(MAX) = 23mA I OUT 255 255  255  I OUT ( MAX )    23 mA (1) 256 512 PWMA  Table 6 PWM and Scaling Register Map PWM OUT PWM_H PWM_L 15  D[ n ]  2 n  65535 3 4 5 6 7 (3) n0 PWMB  15  D[ n ]  2 n  65535 8 (3) n0 N= 65536 I LED  9 65535  65535  23 mA  23 mA 2  65536 (2) Where IOUT(MAX) is the maximum output current decided by RISET (check RISET section for more information) The IOUT of each channel is set by the SL bits of LED Scaling Register (4Ah~6Dh). Please refer to the detail information in Table 7. If RISET=6.8kΩ, GCC=0xFF, SL=0xFF, PMS= “00” (8-bit PWM resolution, only use the PWM_L, the PWM_H will be ignored), PWMA_H=0x77, PWMA_L=0xAA, PWMB_H=0x77, PWMB_L=0xAA, IOUT(MAX) = 23mA I OUT 255 255  255  I OUT ( MAX )    23 mA (1) 256 256  2 PWMA  PWMB  7  D[ n ]  2 n  D[n ]  2 n n0 7  170 (3)  170 10 11 12 13 14 15 (4) 16 n0 N=256 I LED  170  170  23 mA 256  2 (2) 17 18 Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2020 SL 02h 01h 4Ah 04h 03h 4Bh 06h 05h 4Ch 08h 07h 4Dh 0Ah 09h 4Eh 0Ch 0Bh 4Fh 0Eh 0Dh 50h 10h 0Fh 51h 12h 11h 52h 14h 13h 53h 16h 15h 54h 18h 17h 55h 1Ah 19h 56h 1Ch 1Bh 57h 1Eh 1Dh 58h 20h 1Fh 59h 22h 21h 5Ah 24h 23h 5Bh 26h 25h 5Ch 28h 27h 5Dh 2Ah 29h 5Eh 2Ch 2Bh 5Fh 2Eh 2Dh 60h 30h 2Fh 61h 32h 31h 62h 34h 33h 63h 36h 35h 64h 38h 37h 65h 3Ah 39h 66h 3Ch 3Bh 67h 3Eh 3Dh 68h 40h 3Fh 69h 42h 41h 6Ah 44h 43h 6Bh 46h 45h 6Ch 48h 47h 6Dh 11 IS32FL3238 49h Update Register When SDB = “H” and SSD = “1”, a write of “0000 0000” to 49h will update the PWM Registers (01h~48h) values. Table 7 4Ah~6Dh LED Scaling Register Bit D7:D0 Name SLx Default 0000 0000 GCC SLA  SLB  256 256  2 n (5)  D[ n ]  2 (5) n0 SLB  7 n n0 Where IOUT(MAX) is the maximum output current decided by RISET, GCC is the global current setting (6Eh) 4Ah~6Dh don’t need to be update by writing to 49h, each register will be updated immediately when it is written. Table 8 6Eh Global Current Control Register Bit D7:D0 Name GCC Default 0000 0000 GCC and SL control the IOUT as shown in Formula (1). GCC  7  D[ n ]  2 n D7 Name PDE - Default 0 0 D6 D5 D4 D3 D2 D1 D0 PS PS PS PS PS PS 0 0 0 0 0 0 PDE 0 1 Phase Delay Enable Phase delay disable Phase delay enable PS[n] 0 1 Clock Phase Select All outputs work as scheme of Clock Phase 1 Outputs OUT[2+(n-1)*6], OUT[4+(n-1)*6], OUT[6+(n-1)*6] work as scheme of Clock Phase 2 (1) 7  D[ n ]  2 SLA  Bit The PDE bit is for enabling channel group delay to minimize peak load current draw from the LED power supply rail. X=A or B, each output has 8 bits × 2 to modulate DC current in 256 steps, for example, OUT1 use 4Bh and 4Ah to set the DC output current, OUT2 use 4Dh and 4Ch to set the DC output current, etc.. The value of the SLB+SLA Registers decides the DC peak current of each LED noted by IOUT. IOUT computed by Formula (1): I OUT  I OUT ( MAX )  Table 9 70h Phase Delay and Clock Phase Register (5) Phase Delay separates 18 outputs as 6 groups, OUT1~OUT3 as group 1, OUT4~OUT7 as group 2…OUT15~OUT18 as group 6. When the is enabled, group 2 will have a 1/(6*fOUT) time delay than group 1, group 3 will also have a 1/(6*fOUT) time delay than group 2, and so on. For each group of 6 outputs there is a Clock Phase option PS[n](n=1~6), when PSn is set to “1”, half current of each output(current decided by SLA) will keep the phase, phase 1, the turning on edge of the PWM pulse is fixed from starting of PWM cycle, but another half current of each output(current decided by SLB) will change to phase 2, the turning off edge of the PWM pulse is fixed from ending of PWM cycle as below, the rising and falling edges will cancel the power ripple. Phase Delay feature and Clock Phase options can work together to minimize the voltage ripple of LED power supply(check PHASE DELAY and CLOCK PHASE section for phase 1, phase 2 definition and more information). n0 If GCC=0xFF, SLA=0xFF, SLB=0xFF, IOUT=IOUT(MAX) If GCC=0x01, SLA=0xFF, SLB=0x00, I OUT  I OUT ( MAX )  1 255  0  256 256  2 Where IOUT(MAX) is the maximum output current decided by RISET (check RISET section for more information). Table 10 71h Open Short Detect Enable Register Bit D7:D2 D1:D0 Name - OSDE Default 0000 00 00 OSDE enables the open and/or short LED channel detection with the result stored in 72h~76h, note either open or short information is saved not both. OSDE 00 01 10 11 Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2020 Open/Short Detect Enable Detect disable Detect disable Short detect enable Open detect enable 12 IS32FL3238 Table 11-1 72h~75h LED Open/Short Register Table 13 78h Spread Spectrum Register 72h D7:D0 Bit D7:D5 D4 D3:D2 D1:D0 Name OP/ST[8:1] Name DCPWM SSP RNG CLT Default x0x0 x0x0 Default 000 0 00 00 Table 11-2 76h LED Open/Short Register Bit D7:D4 D3:D0 Name - OP/ST[18:17] Default 0000 x0x0 Open or short status are stored in 72h to 76h. OP[18:1] 0 1 Open Information of OUT18:OUT1 No open happens The output opens ST[18:1] 0 1 Short Information of OUT18:OUT1 No short happens The output shorts Table 12 77h Temperature Sensor Register Bit D7:D6 D5 D4 D3:D2 D1:D0 Name TROF - T_Flag - TS Default 00 0 0 00 00 TS stores the temperature/thermal roll-off point. TROF stores percentage of output current of the thermal roll-off function. Read T_Flag=1 indicates die temperature exceeds the setting point (TS). Before each reading of 77h register, TROF and TS need to be re-written. TROF current 00 01 10 11 Thermal roll off percentage of output 100% 75% 55% 30% Temperature Point, Thermal roll off start TS point 00 01 10 11 140°C 120°C 100°C 90°C T_Flag 0 1 Temperature Flag Temperature point not exceeded Temperature point exceeded Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2020 When DCPWM is set to “0”, the PWM outputs are decided by 01h~48h, and the PWM range is 0/256~255/256(8-bit PWM, 0/1024~1023/1024 for 10 bit PWM, 0/4096~4095/4096 for 12 bit PWM, 0/65536~65535/65536 for 16 bit PWM), still the 1/256(8-bit PWM, 1/1024 for 10 bit PWM, 1/4096 for 12 bit PWM, 1/65536 for 16 bit PWM), can’t be turned on. When the DCPWM is set to “1”, PWM dimming is disabled and dimming will be done by current adjust GCC and SLX registers. Spread spectrum register enable the spread spectrum function, adjust the cycle time and range. DCPWM xx0 xx1 x0x x1x 0xx 1xx Setting the output to work in DC mode Output 1~6 PWM data set by registers 01h~18h Output 1~6 set to turn on (PWM is disabled) Output 7~12 PWM data set by registers 19h~30h Output 7~12 set to turn on (PWM is disabled) Output 13~18 PWM data set by registers 31h~48h Output 13~18 set to turn on (PWM is disabled) SSP 0 1 Spread Spectrum Enable Disable Enable CLT 00 01 10 11 Spread Spectrum Cycle Time 1980μs 1200μs 820μs 660μs RNG 00 01 10 11 Spread Spectrum Range ±5% ±15% ±24% ±34% 7Fh Reset Register When power on, all registers values are reset to 0x00 (default). A write of “0000 0000” to 7Fh will also reset all registers to their default values. 13 IS32FL3238 APPLICATION INFORMATION RISET The maximum output current IOUT(MAX) for OUT1~OUT18 can be adjusted by the external resistor, RISET, as described in Formula (6). I OUT ( MAX )  2 x  V ISET R ISET k    283  R ISET k    283 (6) x = 81.28, VOUT = 0.8V, VISET = 0.945V. The recommended minimum value of RISET is 2kΩ. When RISET=6.8kΩ, IOUT(MAX)=23mA When RISET=3.3kΩ, IOUT(MAX)=47mA When RISET=2kΩ, IOUT(MAX)=78mA RISET should be close to the chip and the ground side should well connect to the GND plane. CURRENT SETTING The maximum output current is set by the external resistor RISET. The Global Current Control register GCC can be used to set a lower current than set by RISET. The 8-bit SL registers (4Ah~6Dh) control the individual currents for each of the outputs. Some applications may require the IOUT of each channel to be adjusted independently. For example, if OUT1 drives 1 LED and OUT2 drives 2 parallel LEDs, and they should have the same average current like 18mA, we can set the IOUT(MAX) to 36mA, and GCC=0xFF, 4Ah=0x80, 4Bh=0x80, 4Ch=0xFF, 4Dh=0xFF, the OUT1 sinks about 18mA and OUT2 sinks 36mA which can have two LEDs in parallel. all the OUTx channels are synchronized, the DC power supply will experience large instantaneous current surges when the OUTx channels turn ON. These current surges will generate an AC ripple on the power supply which cause stress to the decoupling capacitors. When the AC ripple is applied to a monolithic ceramic capacitor chip (MLCC) it will expand and contract causing the PCB to flex and generate audible hum in the range of between 20Hz to 20kHz. To avoid this hum, there are many countermeasures, such as selecting the capacitor type and value which will not cause the PCB to flex and contract. An additional option for avoiding audible hum is to set the IS32FL3238’s output PWM frequency above/below the audible range. The Control Register (00h) can be used to set the switching frequency to 122Hz~62kHz as shown in Table 4, some combine setting of the OSC and PMS bits will get different output PWM frequency, and higher than 20kHz is out of the audible range. PHASE DELAY and CLOCK PHASE To reduce audible noise due to PWM switching, the IS32FL3238 features Phase Delay and Clock Phase schemes. When Phase Delay and Clock Phase are disabled (default) all of the outputs turn on simultaneously causing large current draw from the ceramic capacitors and pausible audible noise. Another example, OUT1, OUT2 and OUT3 drive an RGB LED, OUT1 is Red LED, OUT2 is Green LED and OUT 3 is Blue LED. If GCC and SL bits are the same, then the RGB LED may appear a pinkish, or not so white. The SL bits can be used to adjust the IOUTx current so the RGB LED appears closer to a pure white color. We call this SL bit adjustment by another name: white balance registers. PWM CONTROL The PWM Registers (01h~48h) can modulate LED brightness of 18 channels with 256/1024/4096/65536 steps. For example, if the data in PWM_H Register is “0000 0000” and in PWMA_L Register is “0000 0100”, then the PWM is the fourth step (total is 512 steps). Writing new data continuously to the registers can modulate the brightness of the LEDs to achieve a breathing effect. PWM FREQUENCY SELECT The IS32FL3238 output channels operate with a default 8 bits PWM resolution and the PWM frequency of 62kHz (the oscillator frequency is 16MHz). Because Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2020 Figure 8 Phase Delay and Clock Phase Disable The PDE bit of register 70h will enable the Phase Delay function so at power-on the OUTx channel will not all turn on at the same time to minimize peak load current, resulting in reduced voltage ripple on the LED power supply rail. Phase Delay separates the 18 outputs as 6 groups, OUT1~OUT3 as group 1, OUT4~OUT6 as group 2…OUT15~OUT18 as group 6, when Phase Delay is enabled, group 2 will have a 1/(6×fOUT) time delay than group 1, group 3 will also have a 1/(6×fOUT) time delay than group 2, and so on. 14 IS32FL3238 VCC Clock Phase 1 OUT[1+(n-1)×3] SLA Ton OUT[1+(n-1)×3] SLB OUT[2+(n-1)×3] SLA Ton OUT[2+(n-1)×3] SLB OUT[3+(n-1)×3] SLA Ton OUT[3+(n-1)×3] SLB Figure 11 Figure 9 PDE= “1” Phase Delay Enable Also in each group of outputs, there is a Clock Phase option PS[n](n=1~6), when PSn of 71h register is set to “0” (default), all outputs in group n keep the phase 1. Figure 10 Toff Clock Phase 2 Toff Clock Phase 1 Ton Toff Clock Phase 2 Toff Clock Phase 1 Ton Toff Clock Phase 2 Toff Ton 1/fOUT Rising & Falling edges canceled the power ripple PSn= “1” Clock Phase Enable Phase Delay feature and Clock Phase options can work together to minimize the voltage ripple of LED power supply. PSn= “0” Clock Phase Disable When PSn is set to “1”, OUT[1+(n-1)×6], OUT[2+(n-1)×6], OUT[3+(n-1)×6], half of the current (current decide by SLA) will keep the phase 1, the turning on edge of the PWM pulse is fixed from starting of PWM cycle as below, but OUT[1+(n-1)×6], OUT[2+(n-1)×6], OUT[3+(n-1)×6] another half of the current (current decide by SLB) will change to phase 2, the turning off edge of the PWM pulse is fixed from ending of PWM cycle as below, the rising and falling edges will cancel the power ripple. Figure 12 PDE= “1” Phase Delay Enable, PSn= “1” (n=1~6) Clock Phase Enable OPEN/SHORT DETECT FUNCTION IS32FL3238 has open and short detect bit for each LED. See Open (VOD) and Short (VSD) detection thresholds in the Electrical Characteristics table. By setting the OSDE bit of Open Short Detect Enable Register (71h) from “00” to “10” (store short information) or “11” (store open information), the LED Open/Short Register will store the open/short information immediately the MCU can get the open/short information by reading the 72h~76h. SPREAD SPECTRUM FUNCTION A switch mode controller can be particularly troublesome for application when the EMI is concerned. To optimize the EMI performance, the IS32FL3238 includes a spread spectrum function. By setting the RNG bit of Spread Spectrum Register (78h), Spread Spectrum range can be choose from ±5% /±15% /±24% /±34%. The spread spectrum can Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2020 15 IS32FL3238 spread the total electromagnetic emitting energy into a wider range that significantly degrades the peak energy of EMI. With the spread spectrum, the EMI test can be easy to be passed with smaller size and lower cost filter circuit. Hardware Shutdown OPERATING MODE The chip releases hardware shutdown when the SDB pin is pulled high. The rising edge of SDB pin will reset the I2C module, but the register information is retained. During hardware shutdown the registers are accessible. IS32FL3238 can operate in PWM Mode. The brightness of each LED can be modulated with 256/1024/4096/65536 steps by PWM registers. For example, if N=256, the data in PWMA Register are “0000 0100”, PWMB Register are “0000 0000”, then the PWM is the fourth step (total is 256+256=512 steps). Writing new data continuously to the registers can modulate the brightness of the LEDs to achieve a breathing effect. SHUTDOWN MODE Shutdown mode can be used as a means of reducing power consumption. During shutdown mode all registers retain their data. Software Shutdown By setting the SSD bit of the Control Register (00h) to “0”, the IS32FL3238 will operate in software shutdown mode. When the IS32FL3238 is in software shutdown, all current sources are switched off, so the LEDs are OFF but all registers remain accessible. Typical current consumption is 1μA (VCC=3.6V). Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2020 The IS32FL3238 enters hardware shutdown when the SDB pin is pulled low. All analog circuits are disabled during hardware shutdown, typical current consumption is 1μA (VCC=3.6V). If the VCC supply drops below 1.75V but remains above 0.1V while SDB is pulled low, please re-initialize all Function Registers before SDB pulled high. LAYOUT As described in external resistor (RISET), the chip consumes lots of power. Please consider below factors when layout the PCB. 1. The VCC capacitors need to close to the chip and the ground side should well connect to the GND of the chip. 2. RISET should be close to the chip and the ground side should well connect to the GND of the chip. 3. The thermal pad should connect to ground pins and the PCB should have the thermal pad too, usually this pad should have 16 or 25 via thru the PCB to other side’s ground area to help radiate the heat. About the thermal pad size, please refer to the land pattern of each package. 16 IS32FL3238 CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) 150°C 200°C 60-120 seconds Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) Time at liquidous (tL) 217°C 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified classification temperature (Tc) Max 30 seconds Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature 8 minutes max. Figure 13 Classification Profile Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2020 17 IS32FL3238 PACKAGE INFORMATION eTSSOP-28 Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2020 18 IS32FL3238 RECOMMENDED LAND PATTERN eTSSOP-28 Note: 1. Land pattern complies to IPC-7351. 2. All dimensions in MM. 3. This document (including dimensions, notes & specs) is a recommendation based on typical circuit board manufacturing parameters. Since land pattern design depends on many factors unknown (eg. User’s board manufacturing specs), user must determine suitability for use. Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2020 19 IS32FL3238 REVISION HISTORY Revision Detail Information Date 0A Initial release. 2018.01.11 0B 1. Update typical application figure 1, RJA value and correct mistakes 2. Update Equation (6) 3. Add ESD (HBM) and RJP value 2019.03.08 0C 1. Add 62kHz PWM frequency in Feature 2. Update applications in page 1 3. Update EC condition to VCC=5V 2019.06.12 A 1. Add figure 1 2. Update note 4 3. Update eTSSOP-28 land pattern 4. Update to final version 2020.01.02 Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2020 20
IS32FL3238-ZLA3-TR 价格&库存
很抱歉,暂时无法提供与“IS32FL3238-ZLA3-TR”相匹配的价格&库存,您可以联系我们找货
IS32FL3238-ZLA3-TR
  • 1+16.957811+2.12104
  • 10+12.4576310+1.55817
  • 25+11.3371425+1.41802
  • 100+10.10590100+1.26402
  • 250+9.51944250+1.19067
  • 500+9.16582500+1.14644
  • 1000+8.874871000+1.11005
库存:2831
IS32FL3238-ZLA3-TR
  • 2500+8.567492500+1.07160
  • 5000+8.382285000+1.04843
  • 7500+8.289557500+1.03684
库存:2831
