IS31FL3731-QFLS2-TR
IS31FL3731-QFLS2-TR
    LUMISSIL
    WFQFN28
    IC LED DRIVER LIN DIM 34MA 28QFN
IS31FL3731-QFLS2-TR 数据手册
IS31FL3731 AUDIO MODULATED MATRIX LED DRIVER   November 2019   GENERAL DESCRIPTION FEATURES The IS31FL3731 is a compact LED driver for 144 single LEDs. The device can be programmed via an I2C compatible interface. The IS31FL3731 offers two blocks each driving 72 LEDs with 1/9 cycle rate. The required lines to drive all 144 LEDs are reduced to 18 by using the cross-plexing feature optimizing space on the PCB. Additionally each of the 144 LEDs can be dimmed individually with 8-bit allowing 256 steps of linear dimming.        To reduce CPU usage up to 8 frames can be stored with individual time delays between frames to play small animations automatically. LED frames can be modulated with audio signal.  IS31FL3731 is available in QFN-28 (4mm × 4mm) and SSOP-28 package. It operates from 2.7V to 5.5V over the temperature range of -40°C to +85°C.   Supply voltage range: 2.7V to 5.5V 400kHz I2C-compatible interface 144 LEDs in dot matrix Individual blink control 8 frames memory for animations Picture mode and animation mode Auto intensity breathing during the switching of different frames LED frames displayed can be modulated with audio signal intensity LED light intensity can be modulated with audio signal intensity QFN-28 (4mm × 4mm) and SSOP-28 package APPLICATIONS   Mobile phones and other hand-held devices for LED display LED in home appliances   TYPICAL APPLICATION CIRCUIT Figure 1 Typical Application Circuit Note 1: The IC should be placed far away from the mobile antenna in order to prevent the EMI. Note 2: The average current of each LED is 3.2mA when REXT = 20kΩ. The LED current can be modulated by the REXT. Please refer to the detail information in Page 18. Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 1 IS31FL3731 PIN CONFIGURATION Package Pin Configuration (Top View) QFN-28 SSOP-28   Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 2 IS31FL3731 PIN DESCRIPTION No. Pin Description 1 CA9 LED matrix A current output/input port. 2 VCC Power supply. 3 SDB Shutdown the chip when pull to low. 4 INTB Interrupt output. Active low. 5 GND Ground. 6 R_EXT 20kΩ resistance to confirm the LED current. 7 ~ 15 CB1 ~ CB9 LED matrix B current output/input port. 16 C_FILT Capacitor used for audio. 17 IN Audio input. 18 AD I2C address setting. 19 SDA I2C compatible serial data. 20 SCL I2C compatible serial clock. 21 ~ 28 CA1 ~ CA8 LED matrix A current output/input port. Thermal Pad Connect to GND. Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 3 IS31FL3731 ORDERING INFORMATION Industrial Range: -40°C To +85°C Order Part No. Package QTY IS31FL3731-QFLS2-TR IS31FL3731-SALS2-TR IS31FL3731-SALS2 QFN-28, Lead-free SSOP-28, Lead-free SSOP-28, Lead-free 2500/Reel 2000/Reel 48/Tube Copyright  ©  2019  Lumissil  Microsystems.  All  rights  reserved.  Lumissil  Microsystems  reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use  in such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances  Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 4 IS31FL3731 ABSOLUTE MAXIMUM RATINGS Supply voltage, VCC Voltage at any input pin Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TA=TJ -0.3V ~ +6V -0.3V ~ VCC+0.3V +150°C -65°C ~ +150°C -40°C ~ +85°C 51.4°C/W (QFN) 72°C/W (SSOP) ±8kV ±1kV Thermal resistance, junction to ambient, still air, θJA ESD (HBM) ESD (CDM) Note 3: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS TA = -40°C ~ +85°C, VCC = 2.7V ~ 5.5V, unless otherwise noted. Typical value is TA = 25°C, VCC = 3.6V. Symbol Parameter Conditions VCC Supply voltage ICC Quiescent power supply current ISD Shutdown current IOUT VHR tSCAN tSCANOL ILED Min. Typ. 2.7 VIN = 0V, without audio input, all LEDs off 2.17 VSDB = 0V 0.5 VSDB = VCC, software shutdown 230 Output current of C1~C9 Matrix display mode without audio modulation (Note 4) 34 Current sink headroom voltage C1~C9 ISink = 270mA (Note 5) 400 Current source headroom voltage C1~C9 ISource = 34mA 400 Max. Unit 5.5 V mA 5 μA mA mV Period of scanning (Figure 2) 106 µs Non-overlap blanking time during scan (Figure 2) 15 µs 3.2 mA REXT = 20kΩ, PWM in 255 step (Note 6) Average current of each LED Logic Electrical Characteristics (SDA, SCL, AD) VIL Logic “0” input voltage VCC = 2.7V VIH Logic “1” input voltage VCC = 5.5V IIL Logic “0” input current VINPUT = 0V (Note 7) 5 nA IIH Logic “1” input current VINPUT = VCC (Note 7) 5 nA Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 0.4 1.4 V V 5 IS31FL3731 DIGITAL INPUT SWITCHING CHARACTERISTICS (NOTE 7) Symbol Parameter Condition Min. Typ. Max. Units 400 kHz fSCL Serial-Clock frequency tBUF Bus free time between a STOP and a START condition 1.3 μs tHD, STA Hold time (repeated) START condition 0.6 μs tSU, STA Repeated START condition setup time 0.6 μs tSU, STO STOP condition setup time 0.6 μs tHD, DAT Data hold time tSU, DAT Data setup time 100 ns tLOW SCL clock low period 1.3 μs tHIGH SCL clock high period 0.7 μs 0.9 μs tR Rise time of both SDA and SCL signals, receiving (Note 8) 20+0.1Cb 300 ns tF Fall time of both SDA and SCL signals, receiving (Note 8) 20+0.1Cb 300 ns Note 4: The average current of each LED is IOUT/10.5. Note 5: All LEDs are on. Note 6: ILED = 64.7/REXT, REXT = 20kΩ is recommended. The recommended minimum value of REXT is 18kΩ, or it may cause a large current. Note 7: Guaranteed by design. Note 8: Cb = total capacitance of one bus line in pF. ISINK ≤ 6mA. tR and tF measured between 0.3 × VCC and 0.7 × VCC.   Figure 2 Scanning Timing Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 6 IS31FL3731 DETAILED DESCRIPTION     I2C INTERFACE The IS31FL3731 uses a serial bus, which conforms to the I2C protocol, to control the chip’s functions with two wires: SCL and SDA. The IS31FL3731 has a 7-bit slave address (A7:A1), followed by the R/W bit, A0. Set A0 to “0” for a write command and set A0 to “1” for a read command. The value of bits A1 and A2 are decided by the connection of the AD pin. The complete slave address is: Following acknowledge of IS31FL3731, the register address byte is sent, most significant bit first. IS31FL3731 must generate another acknowledge indicating that the register address has been received. Then 8-bit of data byte are sent next, most significant bit first. Each data bit should be valid while the SCL level is stable high. After the data byte is sent, the IS31FL3731 must generate another acknowledge to indicate that the data was received. Bit A7:A3 A2:A1 A0 The “STOP” signal ends the transfer. To signal “STOP”, the SDA signal goes high while the SCL signal is high. Value 11101 AD 0/1 ADDRESS AUTO INCREMENT Table 1 Slave Address AD connected to GND, AD=00; AD connected to VCC, AD=11; AD connected to SCL, AD=01; AD connected to SDA, AD=10; The SCL line is uni-directional. The SDA line is bidirectional (open-collector) with a pull-up resistor (typically 4.7kΩ). The maximum clock frequency specified by the I2C standard is 400kHz. In this discussion, the master is the microcontroller and the slave is the IS31FL3731. The timing diagram for the I2C is shown in Figure 3. The SDA is latched in on the stable high level of the SCL. When there is no interface activity, the SDA line should be held high. The “START” signal is generated by lowering the SDA signal while the SCL signal is high. The start signal will alert all devices attached to the I2C bus to check the incoming address against their own chip address. The 8-bit chip address is sent next, most significant bit first. Each address bit must be stable while the SCL level is high. After the last bit of the chip address is sent, the master checks for the IS31FL3731’s acknowledge. The master releases the SDA line high (through a pull-up resistor). Then the master sends an SCL pulse. If the IS31FL3731 has received the address correctly, then it holds the SDA line low during the SCL pulse. If the SDA line is not low, then the master should send a “STOP” signal (discussed later) and abort the transfer. Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 To write multiple bytes of data into IS31FL3731, load the address of the data register that the first data byte is intended for. During the IS31FL3731 acknowledge of receiving the data byte, the internal address pointer will increment by one. The next data byte sent to IS31FL3731 will be placed in the new address, and so on. The auto increment of the address will continue as long as data continues to be written to IS31FL3731 (Figure 6). READING PORT REGISTERS All of registers in IS31FL3731 can be read. But Frame Registers can only be read in software shutdown mode as SDB pin is high. The Function Register can be read in software shutdown mode or operating mode. To read the device data, the bus master must first ____ send the IS31FL3731 address with the R/W bit set to “0”, followed by the Command Register address, FDh, then send command data which determines which response register is accessed. After a restart, the bus master must send the IS31FL3731 address with the ____ R/ W bit set to “0” again, followed by the register address which determines which register is accessed. Then restart I2C, the bus master should send the ____ IS31FL3731 address with the R/W bit set to “1”. Data from the register defined by the command byte is then sent from the IS31FL3731 to the master (Figure 7). 7 IS31FL3731 SDA tSU,DAT tLOW SCL tHD,DAT S tHIGH tSU,STA tHD,STA R tSU,STO tBUF P tHD,STA tR tF Restart Condition Start Condition Stop Condition Start Condition Figure 3 Interface Timing Figure 4 Bit Transfer Figure 5 Writing to IS31FL3731 (Typical) Figure 6 Writing to IS31FL3731 (Automatic address increment) Figure 7 Reading from IS31FL3731 Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 8 IS31FL3731 REGISTER DEFINITION Table 2 FDh Command Register Data Function Data Function 0000 0000 Point to Page One (Frame 1 Register is available) 0000 0001 Point to Page Two (Frame 2 Register is available) 0000 0010 Point to Page Three (Frame 3 Register is available) 0000 0011 Point to Page Four (Frame 4 Register is available) 0000 0100 Point to Page Five (Frame 5 Register is available) 0000 0101 Point to Page Six (Frame 6 Register is available) 0000 0110 Point to Page Seven (Frame 7 Register is available) 0000 0111 Point to Page Eight (Frame 8 Register is available) 0000 1011 Point to Page Nine (Function Register is available) Others Reserved Note 9: The Command Register should be configured first after writing in the slave address to choose the available register (Frame Registers and Function Registers). Then write data in the choosing register. For example, when write “0000 0011” in the Command Register (FDh), the data which writing after will be stored in the Frame 4 Register. Write new data can configure other registers. Table 3 Response Register Function (The address of each Page is starting from 00h. Frame Registers have the same format.) Address Name Function Table R/W Default Frame Register (Page One to Page Eight) (Note 10) 00h ~ 11h LED Control Register Store on or off state for each LED 4 R/W 12h ~ 23h Blink Control Register Control the blink function for each LED 5 R/W 24h ~ B3h PWM Register 144 LEDs PWM duty cycle data register 6 R/W xxxx xxxx Function Register (Page Nine) 00h Configuration Register Configure the operation mode 8 R/W 01h Picture Display Register Set the display frame in Picture Mode 9 R/W 02h Auto Play Control Register 1 Set the way of display in Auto Frame Play Mode 10 R/W 03h Auto Play Control Register 2 Set the delay time in Auto Frame Play Mode 11 R/W 04h Reserved (Note 11) Reserved - R/W 05h Display Option Register Set the display option 12 R/W 06h Audio Synchronization Register Set audio synchronization function 13 R/W 07h Frame State Register Store the frame display information 14 R 08h Breath Control Register 1 Set fade in and fade out time for breath function 15 R/W 09h Breath Control Register 2 Set the breath function 16 R/W 0Ah Shutdown Register Set software shutdown mode 17 R/W 0Bh AGC Control Register Set the AGC function and the audio gain. 18 R/W 0Ch Audio ADC Rate Register Set the ADC sample rate of the input signal 19 R/W 0000 0000 Note 10: The data of Frame Registers is not assured when power on. Please initialize the Frame Registers first to ensure operate normally. Note 11: The 04h register has no function although it can be written. It also can be read but the data is not assured. Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 9 IS31FL3731 REGISTER CONTROL Configure Command Register (FDh) Select Response Register 0x00 0x01 0x07 0x0B Page One Frame 1 Register Page Two Frame 2 Register Page Eight Frame 8 Register Page Nine Function Register Configure Frame Register Configure Frame Register Configure Frame Register Configure Function Register LED Control Register (00h~11h) LED Control Register (00h~11h) LED Control Register (00h~11h) Configuration Register (00h) Blink Control Register (12h~23h) Blink Control Register (12h~23h) Blink Control Register (12h~23h) PWM Register (24h~B3h) PWM Register (24h~B3h) PWM Register (24h~B3h) FRAME REGISTER Table 4 00h ~ 11h LED Control Register Audio ADC Rate Register (0Ch) Table 6 24h ~ B3h PWM Register Bit D7:D0 Bit D7:D0 Name CX-8 : CX-1 or CX-16 : CX-9 Name PWM Default xxxx xxxx Default xxxx xxxx The LED Control Registers store the on or off state of each LED in the Matrix A and B. Please refer to the detail information in Table 7. LED State Bit LED off LED on CX-Y 0 1 PWM Registers modulate the 144 LEDs in 256 steps. The value of the PWM Registers decides the output current of each LED. The output current may be computed using the Formula (1): I PWM  Figure 8 in Page 11 shows the ordering of CX-Y. Table 5 12h ~ 23h Blink Control Register Bit D7:D0 Name CX-8 : CX-1 or CX-16 : CX-9 Default xxxx xxxx I LED 7   D[n]  2 n 256 n0 (1) Where D[n] stands for the individual bit value, 1 or 0, in location n. For example: if D7:D0 = 10110101, IPWM = ILED (20+22+24+25+27)/256 ILED is set by the external resistor, REXT, ILED = 64.7/REXT. For example, when REXT = 20kΩ, ILED = 64.7/20 = 3.2mA. The Blink Control Registers configure the blink function of each LED in the Matrix A and B. Please refer to the detail information in Table 7. CX-Y 0 1 Blink Control Bit Disable Enable Figure 8 in Page 11 shows the ordering of CX-Y. Table 7 Address of Frame Register LED Location LED Control Register Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 Blink Control Register PWM Register 10 IS31FL3731 Matrix A Matrix B Matrix A Matrix B Matrix A Matrix B Matrix A Matrix B CA1(C1-1~C1-8) CB1(C1-9~C1-16) 00h 01h 12h 13h 24h ~ 2Bh 2Ch ~ 33h CA2(C2-1~C2-8) CB2(C2-9~C2-16) 02h 03h 14h 15h 34h ~ 3Bh 3Ch ~ 43h CA3(C3-1~C3-8) CB3(C3-9~C3-16) 04h 05h 16h 17h 44h ~ 4Bh 4Ch ~ 53h CA4(C4-1~C4-8) CB4(C4-9~C4-16) 06h 07h 18h 19h 54h ~ 5Bh 5Ch ~ 63h CA5(C5-1~C5-8) CB5(C5-9~C5-16) 08h 09h 1Ah 1Bh 64h ~ 6Bh 6Ch ~ 73h CA6(C6-1~C6-8) CB6(C6-9~C6-16) 0Ah 0Bh 1Ch 1Dh 74h ~ 7Bh 7Ch ~ 83h CA7(C7-1~C7-8) CB7(C7-9~C7-16) 0Ch 0Dh 1Eh 1Fh 84h ~ 8Bh 8Ch ~ 93h CA8(C8-1~C8-8) CB8(C8-9~C8-16) 0Eh 0Fh 20h 21h 94h ~ 9Bh 9Ch ~ A3h CA9(C9-1~C9-8) CB9(C9-9~C9-16) 10h 11h 22h 23h A4h ~ ABh ACh ~ B3h Figure 8 LED Array Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 11 IS31FL3731 FUNCTION REGISTER Table 8 00h Configuration Register Table 10 02h Auto Play Control Register 1 Bit D7:D5 D4:D3 D2:D0 Bit D7 D6:D4 D3 D2:D0 Name - MODE FS Name - CNS - FNS Default 000 00 000 Default 0 000 0 000 The Configuration Register sets operating mode of IS31FL3731. MODE 00 01 1x The Auto Play Control Register 1 sets the way of display in Auto Frame Play Mode. CNS Number of Loops Playing Selection (Available in Auto Frame Play Mode) 000 Play endless 001 1 loop 010 2 loops 011 3 loops 100 4 loops 101 5 loops 110 6 loops 111 7 loops Display Mode Picture Mode Auto Frame Play Mode Audio Frame Play Mode FS Frame Start (Available in Auto Frame Play Mode) 000 Frame 1 001 Frame 2 010 Frame 3 011 Frame 4 100 Frame 5 101 Frame 6 110 Frame 7 111 Frame 8 FS bit sets the start frame in Auto Frame Play Mode. Movie starts from Frame 4 when the FS bit is set to “011”. The FS bit is only available in Auto Frame Play Mode. Table 9 01h Picture Display Register Bit D7:D3 D2:D0 Name - PFS Default 00000 000 The Picture Display Register sets display frame in Picture Mode. PFS Picture Frame Selection (Available in Picture Mode) 000 Frame 1 001 Frame 2 010 Frame 3 011 Frame 4 100 Frame 5 101 Frame 6 110 Frame 7 111 Frame 8 Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 FNS Number of Frames Playing Selection (Available in Auto Frame Play Mode) 000 All Frame 001 1 frame 010 2 frames 011 3 frames 100 4 frames 101 5 frames 110 6 frames 111 7 frames Movie will be stop in the next frame of the cycle. For example, FS bit is set to “011”, CNS bit is set to “011” and FNS bit is set to “011”. Then the movie will play from frame 4 to frame 6 and play three times it stops in frame 7. Table 11 03h Auto Play Control Register 2 Bit D7:D6 D5:D0 Name - A Default 00 000000 The Auto Play Control Register 2 sets the delay time in Auto Frame Play Mode (Figure 12). FDT Frame Delay Time (Available in Auto Frame Play Mode) If A = 0, FDT = τ×64; If A = 1~63, FDT = τ×A; A = 0~63 and τ = 11ms (Typ.); For example, when A = 23, FDT is 11ms×23 = 253ms 12 IS31FL3731 Table 12 05h Display Option Register Table 14 07h Frame State Register (Read Only) Bit D7:D6 D5 D4 D3 D2:D0 Bit D7:D5 D4 D3 D2:D0 Name - IC - BE A Name - INT - CFD Default 00 0 0 0 000 Default - The Display Option Register sets display option of IS31FL3731. The Frame State Register stores the frame display information.     Intensity Control Set the intensity of each frame independently Use intensity setting of frame 1 for all other frames IC 0 1 Blink Enable Disable Enable BE 0 1   BPT Blink Period Time BPT = τ×A; A = 0~7, τ = 0.27s (Typ.); For example, when A = 5, BPT is 0.27s×5 = 1.35s. INT Interrupt Bit (Available in Auto Frame Play Mode) 0 Movie does not finish 1 Movie has finished Current Frame Display Frame 1 Frame 2 Frame 3 Frame 4 Frame 5 Frame 6 Frame 7 Frame 8 CFD 000 001 010 011 100 101 110 111 The duty cycle for blink function is 50%. The INT bit will be set to “1” automatically when movie is end in Auto Frame Play Mode. The INT bit can be cleared up by reading the Frame State Register. Table 13 06h Audio Synchronization Register   Bit D7:D1 D0 Name - AE Default 0000000 0 The Audio Synchronization Register sets audio synchronization function. AE Audio Synchronization Enable 0 Audio synchronization disable 1 Enable audio signal to modulate the intensity of the matrix The intensity of matrix can be modulated by the audio input signal basing on each LED’s current is set by PWM when the AE bit is set to “1”. Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 Table 15 08h Breath Control Register 1 Bit D7 D6:D4 D3 D2:D0 Name - A - B Default 0 000 0 000 The Breath Control Register 1 sets fade in and fade out time for breath function. FOT Fade Out Time FOT = τ×2A A = 0~7, τ = 26ms (Typ.) For example, when A = 4, FOT is 26ms×24 = 416ms FIT Fade In Time FIT = τ×2B B = 0~7, τ = 26ms (Typ.) For example, when A = 4, FIT is 26ms×24 = 416ms 13 IS31FL3731 Table 16 09h Breath Control Register 2 AGS  Bit D7:D5 D4 D3 D2:D0 Name - B_EN - A Default 000 0 0 000 The Breath Control Register 2 sets the breath function. B_EN Breath Enable (Available in Picture Mode and Auto Frame Play Mode) 0 Disable 1 Enable ET Extinguish Time A ET = τ×2 A = 0~7, τ = 3.5ms (Typ.) For example, when A = 4, ET is 3.5ms×24 = 56ms D7:D1 D0 Name - SSD Default 0000000 0 The Shutdown Register sets software shutdown mode. SSD 0 1 Audio Gain Selection  0dB 3dB 6dB 9dB 12dB 15dB 18dB 21dB The AGS bit is available in Audio Frame Play Mode and audio synchronization mode. Table 19 0Ch Audio ADC Rate Register Bit D7:D0 Name A Default 0000 0000 The Audio ADC Rate Register sets the ADC sample rate of the input signal in Audio Frame Play Mode. Table 17 0Ah Shutdown Register Bit   000 001 010 011 100 101 110 111 Shutdown Control Shutdown Mode Normal Operation AAR Audio ADC Rate (Available in Audio Frame Play Mode) If A = 0, AAR = τ×256 If A = 1~255, AAR = τ×A τ = 46μs (Typ.) For example, when A = 14, AAR is 46μs×14 = 644μs     Table 18 0Bh AGC Control Register Bit D7:D5 D4 D3 D2:D0 Name - AGCM AGC AGS Default 000 0 0 000 The AGC Control Register sets the AGC function and the audio gain.         AGCM 0 1 AGC Mode Slow Mode Fast Mode AGC 0 1 AGC Enable Disable Enable         Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 14 IS31FL3731 FUNCTIONAL BLOCK DIAGRAM VCC SDA SCL SRAM I2C Interface AD INTB Registers Digital Control Logic SDB IN C_FILT Audio Signal Process Current Sink Current Source CA1~CA9 CB1~CB9 GND R_EXT Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 15 IS31FL3731 APPLICATION INFORMATION (The description below is for the Function Register unless otherwise noted.)   Writing new data continuously to the registers can modulate the brightness of the LEDs to achieve a breathing effect. Choosing more gamma steps provides for a more continuous looking breathing effect. This is useful for very long breathing cycles. The recommended configuration is defined by the breath cycle T. When T=1s, choose 32 gamma steps, when T=2s, choose 64 gamma steps. The user must decide the final number of gamma steps not only by the LED itself, but also based on the visual performance of the finished product. GAMMA CORRECTION Table 18 64 Gamma Steps With 256 PWM Steps PWM CONTROL The brightness of 144 LEDs can be modulated with 256 steps by PWM Register. For example, if the data in PWM Register is “0000 0100”, then the PWM is the fourth step. In order to perform a better visual LED breathing effect we recommend using a gamma corrected PWM value to set the LED intensity. This results in a reduced number of steps for the LED intensity setting, but causes the change in intensity to appear more linear to the human eye. Gamma correction, also known as gamma compression or encoding, is used to encode linear luminance to match the non-linear characteristics of display. Since the IS31FL3731 can modulate the brightness of the LEDs with 256 steps, a gamma correction function can be applied when computing each subsequent LED intensity setting such that the changes in brightness matches the human eye's brightness curve. Table 17 32 Gamma Steps With 256 PWM Steps C(0) C(1) C(2) C(3) C(4) C(5) C(6) C(7) 0 1 2 4 6 10 13 18 C(0) C(1) C(2) C(3) C(4) C(5) C(6) C(7) 0 1 2 3 4 5 6 7 C(8) C(9) C(10) C(11) C(12) C(13) C(14) C(15) 8 10 12 14 16 18 20 22 C(16) C(17) C(18) C(19) C(20) C(21) C(22) C(23) 24 26 29 32 35 38 41 44 C(24) C(25) C(26) C(27) C(28) C(29) C(30) C(31) 47 50 53 57 61 65 69 73 C(32) C(33) C(34) C(35) C(36) C(37) C(38) C(39) 77 81 85 89 94 99 104 109 C(40) C(41) C(42) C(43) C(44) C(45) C(46) C(47) 114 119 124 129 134 140 146 152 C(48) C(49) C(50) C(51) C(52) C(53) C(54) C(55) 158 164 170 176 182 188 195 202 C(56) C(57) C(58) C(59) C(60) C(61) C(62) C(63) 209 216 223 230 237 244 251 255 C(8) C(9) C(10) C(11) C(12) C(13) C(14) C(15) 256 22 28 33 39 46 53 61 69 224 C(16) C(17) C(18) C(19) C(20) C(21) C(22) C(23) 78 86 96 106 116 126 138 149 C(24) C(25) C(26) C(27) C(28) C(29) C(30) C(31) 161 173 186 199 212 226 240 255 160 128 96 224 64 192 PWM Data PWM Data 256 192 32 160 0 0 8 16 24 32 40 48 56 64 128 Intensity Steps 96 Figure 10 Gamma Correction (64 Steps) Note: The data of 32 gamma steps is the standard value and the data of 64 gamma steps is the recommended value. 64 32 OPERATING MODE 0 0 4 8 12 16 20 24 Intensity Steps 28 32 IS31FL3731 has three operating modes, Picture Mode, Auto Frame Play Mode and Audio Frame Play Mode. Figure 9 Gamma Correction (32 Steps) Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 16 IS31FL3731 PICTURE MODE BREATHING FUNCTION SETTING By setting the MODE bit of the Configuration Register (00h) to “00”, the IS31FL3731 operates in Picture Mode. Set the PFS bit of Picture Display Register (01h) to choose the display frame. The Picture Mode can be operating with breath function by configuring Breath Control Register 2 (09h). When IS31FL3731 switches playing frame, breath function is available. By setting the B_EN bit of the Breath Control Register 2 (09h) to “1”, breath function enable. When set the B_EN bit to “0”, breath function disable. AUTO FRAME PLAY MODE By setting the MODE bit of the Configuration Register (00h) to “01”, the IS31FL3731 operates in Auto Frame Play Mode. It stores data of 8 frames and automatically plays in order. Customers can configure the delay time between each two frames and the first playing frame by setting the FS bit of Configuration Register (00h). The Auto Play Control Register 1 (02h) can configure the display cycle and display frames. Configure the Auto Play Control Register 2 (03h), Breath Control Register 1 (08h) and Breath Control Register 2 (09h) can set the breath time between two frames switching. AUDIO FRAME PLAY MODE By setting the MODE bit of the Configuration Register (00h) to “1x”, the IS31FL3731 operates in Audio Frame Play Mode. It stores data of 8 frames and the 8 frames playing follow the input signal. 0Ch register is used to set the ADC sample rate for the input signal to control frames playing. It plays the first frame when the value is the smallest and plays the eighth frame when the value is the biggest. Figure 12 Breathing Function INTERRUPT CONTROL When IS31FL3731 is playing frame in the Auto Frame Play Mode, the INTB pin is high and the INT bit of Frame State Register (07h) is “0”. It will be pulled low as movie end and the INT bit will be set to “1” at the same time. The INTB pin will come back to high level automatically if it stays low at least 7ms. The INT bit will reset to “0” only when reading the Frame State Register (07h). LED MATRIX CIRCUIT The IS31FL3731 can drive 144 LEDs totally. Part of LEDs can if there is no need to use all 144 LEDs (Figure 13). But the LEDs which are no connected must be off by LED Control Register (Frame Registers) or it will affect other LEDs. AUDIO MODULATED AND GAIN SETTING By setting the AE bit of the Audio Synchronization Register (06h) to “1”, IS31FL3731 operates with audio synchronization. The intensity of LEDs is adjusted by the input signal. The audio input gain can be set by the AGC Control Register (0Bh). BLINK FUNCTION SETTING By setting the BE bit of the Display Option Register (05h) to “1”, blink function enable. If the BE bit is set to “1”, each LED can be controlled by the Blink Control Registers (12h~23h in Page One to Page Eight). The Display Option Register (05h) is used to set the blink period time, BPT, and the duty cycle is 50% (Figure 11). Figure 13 No C9-3~C9-5, C5-8~C9-8 Figure 11 Blink Function Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 17 IS31FL3731 MORE FRAMES DISPLAY SHUTDOWN MODE The IS31FL3731 can store 8 frames data at best. Each 4 frames writing in Frame Registers is recommended if there are more frames to play (Figure 14). First, store 8 frames data and play 4 frames in front. Then play last 4 frames and writing new data in the Frame Registers (1~4) at the same time. Play the new 4 frames (1~4) and write new data in the Frame Registers (5~8). Shutdown mode can be used as a means of reducing power consumption. During shutdown mode all registers retain their data. 8 frames data write into Frame Registers Software Shutdown By setting SSD bit of the Shutdown Register (0Ah) to “0”, the IS31FL3731 will operate in software shutdown mode. When the IS31FL3731 is in software shutdown mode, all current sources and digital drivers are switched off, so that the matrix is blanked. All registers can be writing or read when the SDB pin is pulled high in software shutdown mode. Hardware Shutdown Play 1~4 frames The chip enters hardware shutdown mode when the SDB pin is pulled low. All registers are forbidden writing and reading. Play end Interrupt sign Play 5~8 frames New data write into 1~4 Frame Registers Play end Interrupt sign Play end Interrupt sign Play 1~4 frames New data write into 5~8 Frame Registers All data play end All data play end Play end Figure 14 More Frame Data Writing In REXT The average output current of each LED can be adjusted by the external resistor, REXT, as described in Formula (2). I LED  64.7 / REXT (2) For example, in Figure 1, REXT = 20kΩ, Figure 15 Shutdown Control So I LED  64.7 / 20  3.2mA The recommended minimum value of REXT is 18kΩ, or it may cause a large current. Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 18 IS31FL3731 APPLICATION DESIGN Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 19 IS31FL3731 CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) 150°C 200°C 60-120 seconds Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) Time at liquidous (tL) 217°C 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified classification temperature (Tc) Max 30 seconds Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature 8 minutes max. Figure 16 Classification Profile Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 20 IS31FL3731 PACKAGE INFORMATION QFN-28 Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 21 IS31FL3731   SSOP-28   Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 22 IS31FL3731 RECOMMENDED LAND PATTERN QFN-28 SSOP-28 Note: 1. Land pattern complies to IPC-7351. 2. All dimensions in MM. 3. This document (including dimensions, notes & specs) is a recommendation based on typical circuit board manufacturing parameters. Since land pattern design depends on many factors unknown (eg. user’s board manufacturing specs), user must determine suitability for use. Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 23 IS31FL3731 REVISION HISTORY Revision A B Detail Information Initial release 1. Add detailed information about SSOP-28 package 2. P.5 delete max software shutdown current 3. Update the copyright 4. Update POD Date 2012.03.14 2012.09.09 1.P.12 Add CNS bit information for Table 10 2.P.4 Modify the ordering information for SSOP-28 package 2013.04.11 D Modify the I2C reading figure 2013.04.26 E 1. Add tape packing for SSOP-28 package 2. Add ESD and θJA 3. Add land pattern and update POD 4. Add Revision History 2017.08.17 F 1.Correct ESD (CDM) 2.Update logo to AMS 2019.11.04 C   Lumissil Microsystems – www.lumissil.com Rev. F, 11/04/2019 24
IS31FL3731-QFLS2-TR 价格&库存
很抱歉,暂时无法提供与“IS31FL3731-QFLS2-TR”相匹配的价格&库存,您可以联系我们找货
IS31FL3731-QFLS2-TR
  • 1+13.362721+1.67137
  • 10+9.7596810+1.22072
  • 25+8.8508425+1.10704
  • 100+7.85565100+0.98256
  • 250+7.38115250+0.92322
  • 500+7.09493500+0.88742
  • 1000+6.859401000+0.85796
库存:5003
IS31FL3731-QFLS2-TR
  • 2500+6.610782500+0.82686
  • 5000+6.460955000+0.80812
  • 7500+6.385927500+0.79874
  • 12500+6.3028012500+0.78834
库存:5003
