IS31FL3195-CLS2-TR
IS31FL3195-CLS2-TR
    LUMISSIL
    XFBGA16
    IC CHARGE PUMP RGBW LED DRIVER,
IS31FL3195-CLS2-TR 数据手册
IS31FL3195 CHARGE PUMP RGBW LED DRIVER WITH PROGRAMMABLE SELF-RUNNING PATTERNS May 2019   GENERAL DESCRIPTION The IS31FL3195 is a compact and efficient 4-channel charge pump LED driver with programmable sequence operation for automated RGBW lighting effects. It is capable of driving 1 to 4 LEDs with a low drop-out and current matching so all 4 LEDs maintain consistent brightness. Each channel can support up to 20mA of current. The built−in charge pump (CP) structure will automatically toggle between 1x, 1.5x operation depending on the battery’s state of charge. This DC/DC converter operates at a high switching frequency which enables the use of small external capacitors and achieves 92% peak total efficiency. The IS31FL3195 is optimized for battery applications. To conserve battery life, the charge pump goes into high impedance mode whenever the IS31FL3195 is shutdown consuming less than 1µA. The IS31FL3195 can operate in either “Current Level” or “Programmable Sequence” mode. In Current Level mode, the average output current of each output is independently programmed and controlled in 256 PWM steps to simplify color mixing. In programmable sequence mode, the timing characteristics for each output can be individually adjusted to maintain a pre-established pattern sequence without requiring any additional MCU interaction, thus saving valuable system resources. The IS31FL3195 is available in a small QFN-16 (4mm × 4mm) and WLCSP-16 (1.88mm×2.08mm, 0.45mm ball pitch, 0.2mm ball diameter) packages. It operates from 2.7V to 5.5V over the temperature range of -40°C to +85°C. With automated lighting effects and a DC/DC charge pump, the small package IS31FL3195 is ideal for low power battery applications. FEATURES          APPLICATIONS     Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 2.7V to 5.5V supply voltage Charge pump - 1x, 1.5x operating modes - Highly efficient across battery state of charge - 1MHz constant frequency - Enter 1.5x mode if any of the four OUTx pins < 150mV (50mV~300mV selectable) Power saving operating - 1µA Shutdown current - 640µA Quiescent operating current (CP1x mode)-Two selectable sleep modes - Sleep 1 Mode: 38µA - Sleep 2 Mode: 1µA - Auto sleep mode if all OUTx outputs are off for >30s. Support four LEDs - RGBW - Resistor sets LED current up to 20mA - 8-bit dot correction LEDs can operate with pre-established lighting patterns - Run without a micro - Fixed number of iterations or non-stop operation - Each channel has its own fade registers (TS-T4) with independent start/stop 1MHz I2C bus interface - Automatic address increment function - 4 selectable I2C address locations Over-temperature protection QFN-16 (4mm×4mm) and WLCSP-16 (1.88mm×2.08mm, 0.45mm ball pitch, 0.2mm ball diameter) packages Operating temperature range is -40°C ~ +85°C Internet-of-Things (IOT) Low-power battery applications Wearable applications Hand-held devices requiring visual notifications 1 IS31FL3195 TYPICAL APPLICATION CIRCUIT  3.3V~5.5V VCC 1 F C1P C1N 0.1 F C2P 3.3V 3.3V 4.7k 1 F 1 F C2N 4.7k VOUT SDA Micro Controller SCL 1 F IS31FL3195 SDB OUT1 100k OUT2 ISET IGMAX=20mA RISET AD 12k GND Figure 1 Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 OUT3 OUT4 Typical Application Circuit 2 IS31FL3195 PIN CONFIGURATION Package Pin Configuration (Top View) QFN-16 WLCSP-16 ISET SDA OUT1 OUT2 A1 A2 A3 A4 GND SDB SCL OUT3 B1 B2 B3 B4 C2P C2N AD OUT4 C1 C2 C3 C4 C1P C1N VCC VOUT D1 D2 D3 D4 Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 3 IS31FL3195 PIN DESCRIPTION No. Pin Description 1~4 A3, A4, B4, C4 OUT1~OUT4 LED current sink pins, connect the corresponding LED cathode to this pin. The anode of the associated LED must to be connected to the VOUT pin. The unused channel can be float but need to shut down by 01h register. 5 D4 VOUT Charge pump output supplies the LED current. In shutdown mode this pin is high impedance. Connect a 1μF capacitor from VOUT to GND. 6 D3 VCC Power supply input, requires 1.0μF and 0.1μF capacitor between this pin and ground pin. 7,8 D1, D2 C1P,C1N Stage 1 charge pump flying capacitor, C1N negative terminal, C1P positive terminal. (Note 1) 9,10 C2, C1 C2N,C2P Stage 2 charge pump flying capacitor, C2N negative terminal, C2P positive terminal. (Note 1) 11 B1 GND Ground reference signal for the charge pump and the output current control. A PCB ground plane strongly recommended. 12 A1 ISET Connect external resistor RISET to ground to set global max current IGMAX. 13 B2 SDB Pull below 0.4V to activate low power shutdown mode. 14 C3 AD I2C address setting. 15 A2 SDA I2C data pin. The SDA byte is used to program the device operating mode. 16 B3 SCL I2C serial clock associated with SDA signal. Thermal Pad Connect to GND. QFN WLCSP Note 1: The flying capacitors should be placed as close as possible to the IC and the signal trace between the capacitor and CP terminals kept as short as possible. Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 4 IS31FL3195 ORDERING INFORMATION Industrial Range: -40°C to +85°C Order Part No. Package QTY/Reel IS31FL3195-QFLS2-TR IS31FL3195-CLS2-TR QFN-16, Lead-free WLCSP-16, Lead-free 2500 3000 Copyright  ©  2019  Lumissil  Microsystems.  All  rights  reserved.  Lumissil Microsystems reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use  in such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 5 IS31FL3195 ABSOLUTE MAXIMUM RATINGS Supply voltage, VCC, VOUT Voltage at any input pin Maximum junction temperature, TJMAX Operating temperature range, TA=TJ Storage temperature range, TSTG Package thermal resistance, junction to ambient (4 layer standard test PCB based on JESD 51-2A standard), θJA ESD (HBM) ESD (CDM) -0.3V ~ +6.0V -0.3V ~ VCC+0.3V +150°C -40°C ~ +85°C -65°C ~ +150°C 53.8°C/W (QFN) 71.41°C/W (WLCSP) ±8kV ±750V Note 2: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.  ELECTRICAL CHARACTERISTICS TA= -40°C ~ +85°C, VCC= 3.6V, unless otherwise noted. Typical value are TA= 25°C. Symbol VCC ICC Parameter Condition Supply voltage Quiescent operating current Min. Typ. Max. Unit 2.7 5.5 V 1x mode, all outputs disable 640 µA 1.5x mode, all outputs disable 1.2 mA Sleep 1 Mode: CP stops, Bandgap working and all OUTx are off without any bias 38 µA Sleep 2 Mode: CP, Bandgap stop and all OUTx are off without any bias 1 µA VSDB= 0V 1 µA VSDB= VCC, software shutdown 1 µA ISD Shutdown current IOUT Total output current Current Level Mode, CL Register= 0xFF Current set Register 20mA 80 mA ILED Current per channel Current Level Mode, CL Register= 0xFF Current set Register 20mA, VOUT=0.3V 20 mA IMAT Current matching IACC Current accuracy VHR Current sink headroom voltage ET Total operating efficiency VOVP Any two outputs, VCC= 3.6V, IOUT= 20mA VOUT=0.3V -5 5 % Any two outputs, VCC= 3.6V, IOUT= 5mA VOUT=0.3V -6 6 % Any outputs, VCC= 3.6V, IOUT= 20mA -8 8 % Any outputs, VCC= 3.6V, IOUT= 5mA -10 10 % IOUT= 15mA 150 mV VCC= 3.4V, VF= 3.2V, ILOAD= 20mA×4 channel 92 % VCC= 2.7V, VF= 3.2V, ILOAD= 20mA×4 channel 77 % Output voltage compliance Output voltage clamp (OVP) 4.4 5.5 V Charge Pump Characteristics tST Soft-start time fCLK Charge pump operating frequency DC/DC start time (COUT= 1µF) 3.0V< VCC< 5.5V 64 µs 900 1000 1200 kHz  Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 6 IS31FL3195 ELECTRICAL CHARACTERISTICS(CONTINUED) TA= -40°C ~ +85°C, VCC= 3.6V, unless otherwise noted. Typical value are TA= 25°C. Symbol Parameter Condition Min. Typ. Max. Unit Logic Electrical Characteristics (SDA, SCL, AD, SDB) VIL Logic “0” input voltage VCC = 2.7V~5.5V 0 0.4 V VIH Logic “1” input voltage VCC = 2.7V~5.5V 1.4 VCC V IIL Logic “0” input current VINPUT = 0V (Note 3) 5 nA IIH Logic “1” input current VINPUT = VIO (Note 3) 5 nA  DIGITAL INPUT SWITCHING CHARACTERISTICS (NOTE 3) Symbol Parameter Fast Mode Min. Typ. Fast Mode Plus Typ. Max. Units Max. Min. - 400 - 1000 kHz fSCL Serial-clock frequency tBUF Bus free time between a STOP and a START condition 1.3 - 0.5 - μs tHD, STA Hold time (repeated) START condition 0.6 - 0.26 - μs tSU, STA Repeated START condition setup time 0.6 - 0.26 - μs tSU, STO STOP condition setup time 0.6 - 0.26 - μs tHD, DAT Data hold time - - - - μs tSU, DAT Data setup time 100 - 50 - ns tLOW SCL clock low period 1.3 - 0.5 - μs tHIGH SCL clock high period 0.7 - 0.26 - μs tR Rise time of both SDA and SCL signals, receiving - 300 - 120 ns tF Fall time of both SDA and SCL signals, receiving - 300 - 120 ns Note 3: Guaranteed by design. Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 7 IS31FL3195 FUNCTION BLOCK DIAGRAM Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 8 IS31FL3195 DETAILED DESCRIPTION  I2C INTERFACE The IS31FL3195 uses a serial bus, which conforms to the I2C protocol, to control the chip’s functions with two wires: SCL and SDA. The IS31FL3195 has a constant 7-bit slave address (A7:A1), followed by the R/W bit, A0. Set A0 to “0” for a write command and set A0 to “1” for a read command. The value of bits A1 and A2 are decided by the connection of the AD pin. The complete slave address is: Table 1 Slave Address: AD A7:A3 A2:A1 GND 00 SCL 01 SDA 10101 VCC 10 A0 0/1 11 AD connected to GND, A2:A1=00; AD connected to VCC, A2:A1=11; AD connected to SCL, A2:A1=01; AD connected to SDA, A2:A1=10; Following acknowledge of IS31FL3195, the register address byte is sent, most significant bit first. IS31FL3195 must generate another acknowledge indicating that the register address has been received. Then 8-bit of data byte are sent next, most significant bit first. Each data bit should be valid while the SCL level is stable high. After the data byte is sent, the IS31FL3195 must generate another acknowledge to indicate that the data was received. The “STOP” signal ends the transfer. To signal “STOP”, the SDA signal goes high while the SCL signal is high. The SCL line is uni-directional. The SDA line is bi-directional (open-collector) with a pull-up resistor (typically 4.7kΩ when SCL frequency is 400kHz). The maximum clock frequency specified by the I2C standard is 400kHz. In this discussion, the master is the microcontroller and the slave is the IS31FL3195. The timing diagram for the I2C is shown in Figure 2. The SDA is latched in on the stable high level of the SCL. When there is no interface activity, the SDA line should be held high. The “START” signal is generated by lowering the SDA signal while the SCL signal is high. The start signal will alert all devices attached to the I2C bus to check the incoming address against their own chip address. The 8-bit chip address is sent next, most significant bit first. Each address bit must be stable while the SCL level is high. Figure 2 Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 After the last bit of the chip address is sent, the master checks for the IS31FL3195’s acknowledge. The master releases the SDA line high (through a pull-up resistor). Then the master sends an SCL pulse. If the IS31FL3195 has received the address correctly, then it holds the SDA line low during the SCL pulse. If the SDA line is not low, then the master should send a “STOP” signal (discussed later) and abort the transfer. ADDRESS AUTO INCREMENT To write multiple bytes of data into IS31FL3195, load the address of the data register that the first data byte is intended for. During the IS31FL3195 acknowledge of receiving the data byte, the internal address pointer will increment by one. The next data byte sent to IS31FL3195 will be placed in the new address, and so on (Figure 5). READING PORT REGISTERS To read the device data, the bus master must first send the IS31FL3195 address with the R/W bit set to “0”, followed by the command byte, which determines which register is accessed. After a restart, the bus master must then send the IS31FL3195 address with the R/W bit set to “1”. Data from the register defined by the command byte is then sent from the IS31FL3195 to the master (Figure 6). Interface Timing 9 IS31FL3195 Figure 3 Figure 4 Figure 5 Bit Transfer Writing to IS31FL3195 (Typical) Writing to IS31FL3195 (Automatic Address Increment) Figure 6 Reading from IS31FL3195   Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 10 IS31FL3195 Table 2 Registers Definitions Address Name Function R/W Table Default 00h Product ID For read only, read result is Slave address R - - 01h Shutdown Control Register Set power down mode and outputs shutdown control W 3 1111 0000 02h Operation Mode Configure Register Set output operation mode W 4 0000 0000 03h Charge Pump Setting-1 Set change pump parameters W 5 0010 0000 04h Charge Pump Setting-2 Set change pump parameters W 6 0011 0000 05h Current Band Register Set current band of each Output W 7 0101 0101 06h Hold Function Register Set the hold function of each Output W 8 0000 0000 07h Phase Delay Register Phase delay mode setting W 9 0000 0001 For reading the pattern running state R 10 0000 0000 Output current level data register W 11 0000 0000 10h~12h/20h~22h/ Color 1 Setting Register of 30h~32h/40h~42h P1/P2/P3/P4 Output current level data register-Color 1 W 12~15 0000 0000 13h~15h/23h~25h/ Color 2 Setting Register of 33h~35h/43h~45h P1/P2/P3/P4 Output current level data register-Color 2 W 12~15 0000 0000 16h~18h/26h~28h/ Color 3 Setting Register of 36h~38h/46h~48h P1/P2/P3/P4 Output current level data register-Color 3 W 12~15 0000 0000 0Ch/0Dh/0Eh/0Fh P1/P2/P3/P4 State Register 10h/21h/32h/40h OUT1/OUT2/OUT3/OUT4 Current Level Register 19h/29h/39h/49h P1/P2/P3/P4 TS &T1 Setting Register Set the TS~T1 time W 16 0000 0000 1Ah/2Ah/3Ah/4Ah P1/P2/P3/P4 T2 &T3 Setting Register Set the T2~T3 time W 17 0000 0000 1Bh/2Bh/3Bh/4Bh P1/P2/P3/P4 TP &T4 Setting Register Set the TP~T4 time W 18 0000 0000 1Ch/2Ch/3Ch/4Ch P1/P2/P3/P4 Color Enable Register Set the color enable/disable W 19 0000 0001 1Dh/2Dh/3Dh/4Dh P1/P2/P3/P4 Color Cycle Times Register Set color repeat time W 20 0000 0000 Set next step and Gamma of each pattern W 1Eh/2Eh/3Eh/4Eh P1/P2/P3/P4 NXT Register 1Fh/2Fh/3Fh/4Fh P1/P2/P3/P4 Loop Times Register Set the loop time of P1~P4 50h 51h/52h/53h/54h 5Fh 21~24 0000 0001 W 25 0000 0000 Color Update Register Update color data W - 0000 0000 P1/P2/P3/P4 Update Register Update the time data and start to run pattern W - 0000 0000 Reset Register Reset the registers value to default W - 0000 0000 Note: When T1 or T3= 0.03s, GAM will be set to 10 (Linearity). Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 11 IS31FL3195 Table 3 01h Shutdown Control Register Bit D7:D4 D3 D2:D1 D0 Name EN4:EN1 CPPM SLE SSD Default 1111 0 00 0 The Shutdown Control Register sets software shutdown and sleep modes of IS31FL3195. The Output Enable Register enables/disables the outputs independently. The ENx is only effective when SSD= “1”. Sleep 1 (power saving standby 1) Mode: CP in 1x mode and all OUTx are off without any bias. I_SLEEP1=35µA (Typ.) Sleep 2 (power saving standby 2) Mode: CP off and all OUTx are off without any bias. I_SLEEP2=1µA (Typ.) When SLE bits are set to “01” or “10”, IS31FL3195 puts itself in Sleep 1 or Sleep 2 Modes if all OUTx outputs are off for >30s. MCU command to the IS31FL3195 will wake it up and disable the sleep mode. The CPPM bit selects the default charge pump power up mode. When CPPM= “0”, the default power up mode is 1x mode, otherwise it will run in 1.5x mode to ensure the LEDs can work with enough forward voltage. SSD 0 1 Software Shutdown Enable Software shutdown mode Normal operation SLE 00/11 01 10 Sleep Mode Enable Sleep mode disable Sleep1 mode enable Sleep2 mode enable When LM= “00/11”, the OUTx can be “0” current level mode or “1” pattern mode, when LM= “01”, the OUT4 can be “0” current level mode or “1” pattern mode, OUT1~3 are not needed to set. When LM= “10”, OUT1~4 are not needed to set. LM 00/11 01 10 OUTx 0 1 LED Mode Single mode RGB + W mode, OUT1, OUT2 and OUT3 work together, OUT4 work independent RGBY mode, OUT1, OUT2, OUT3 and OUT4 work together thru Pattern 1-3 Output Operating Mode Current Level Mode Pattern Mode Table 5 03h Charge Pump Setting-1 Bit D7:D2 D1:D0 Name - CPM Default 0010 00 00 The Charge Pump Setting Register-1 sets the charge pump working mode. CPM 00 01 10 Charge Pump Working Mode Auto mode 1x mode 1.5x mode Table 6 04h Charge Pump Setting-2 CPPM 0 1 Charge Pump Power Up Mode 1x 1.5x ENx 0 1 Output Enable Control Output disable Output enable Bit D7 D6:D4 D3:D0 Name - HRT CPDE4:CPDE1 Default 0 011 0000 The Charge Pump Setting Register-2 sets headroom detect threshold voltage and enables OUTx charge pump detection. Disable charge pump detection on OUTx if LED anode not connected to VOUT or OUTx floating. CPDEx Table 4 02h Operating Configure Register Bit D7:D4 D3:D1 D1:D0 Name OUT4:OUT1 - LM Default 0000 00 00 0 1 Charge Pump Detection Enable of OUTx Enable Disable The Operating Configure Register sets operation modes of IS31FL3195. Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 12 IS31FL3195 HRT 000 001 010 011 100 101 110 111 Table 9 07h Phase Delay Register Headroom Threshold Voltage 50mV 100mV 125mV 150mV 175mV 200mV 250mV 300mV D7:D6 D5:D4 D3:D2 D1:D0 Name CB4 CB3 CB2 CB1 Default 01 01 01 01 Current Band Setting Band 1: 0mA~IGMAX ×1/4, IBAND= IGMAX × 1/4 Band 2: 0mA~ IGMAX ×1/2, IBAND= IGMAX × 1/2 Band 3: 0mA~ IGMAX ×3/4, IBAND= IGMAX × 3/4 Band 4: 0mA~ IGMAX, IBAND= IGMAX Table 8 06h Hold Function Register D6 D5 D4 D3 D2 D1 D0 Name HF4 HT4 HF3 HT3 HF2 HT2 HF1 HT1 Default 0 0 0 0 0 0 0 1 HFx 0 1 Hold Time Selection Hold at end of T4 when pattern loop done (always off) Hold at end of T2 when pattern loop done (always on) Hold Function Enable Hold function disable Hold function enable - PD Default 0000 00 01 Phase Delay Mode Phase delay mode 1 Phase delay mode 2 Bit D7 Name PSx Default 0 D6 D5 D4 CS3x CS2x CS1x 0 0 0 D3 D2:D0 - TXx 0 000 The Pattern State Registers store the four patterns. PS is the pattern enable or not, CSX is the color enable or not, TX will show the running position of Pattern 1. ODh, OEh and 0Fh store the state of Pattern 2, 3 and 4. TXx 000 001 010 011 100 101 Time State Running at TS Running at T1 Running at T2 Running at T3 Running at TP Running at T4 CSXx 0 1 Color State Not running at Color x Running at Color x PSx 0 1 Pattern State Not running at Pattern x Running at Pattern x 0 The Hold Function Register configures hold time for each output in Pattern Mode. HTx 0 Name Table 10 0Ch/0Dh/0Eh/0Fh P1/P2/P3/P4 State Register (Read Only) The Current Band Register stores the current band of each LED output. IGMAX=20mA when RISET=12kΩ. When current level register is 0xFF and CBx is “01”, IBAND= IGMAX ×2/4=10mA, when current level register is 0x00, IOUT=0mA. D7 D1:D0 PD 01 11 Bit Bit D7:D0 IS31FL3195 features the output current phase delay function, default is mode 1 Table 7 05h Current Band Register CBx 00 01 10 11 Bit Table 11 10h/21h/32h/40h OUT1/OUT2/OUT3/OUT4 Current Level Register Bit D7:D0 Name CL Default 0000 0000 When IS31FL3195 operates in Current Level Mode, the value of Current Level Registers will decide the output current of OUTx in 256 levels. Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 13 IS31FL3195 The output current may be computed using the Formula (1): I OUT  Table 14 30h~32h 7 I BAND D[n] 2n  256 n0 (1) Where D[n] stands for the individual bit value, 1 or 0, in location n. For example: if D7:D0 = 10110101, IOUT = IBAND (27 +25 +24 +22 +20)/256 IBAND is defined in Table 7. Table 12 10h ~12h Color 1 Setting Register of P1 Color 1 Setting Register of P3 Bit D7:D0 Name P3COL1_Ox Default 0000 0000 33h~35h Color 2 Setting Register of P3 Bit D7:D0 Name P3COL2_Ox Default 0000 0000 36h~38h Color 3 Setting Register of P3 Bit D7:D0 Bit D7:D0 Name P1COL1_Ox Name P3COL3_Ox Default 0000 0000 Default 0000 0000 13h~15h Color 2 Setting Register of P1 Table 15 40h~42h P4 COL1/2/3 Setting Register of Bit D7:D0 Name P1COL2_Ox Bit D7:D0 Default 0000 0000 Name P4COL1_Ox Default 0000 0000 16h~18h Color 3 Setting Register of P1 Bit D7:D0 Name P2COL3_Ox Default 0000 0000 Table 13 20h~22h Color 1 Setting Register of P2 Bit D7:D0 Name P2COL1_Ox Default 0000 0000 23h~25h Color 2 Setting Register of P2 Bit D7:D0 Name P2COL2_Ox Default 0000 0000 26h~28h Color 3 Setting Register of P2 Bit D7:D0 Name P2COL3_Ox Default 0000 0000 Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 Color Setting Registers store the color setting for each output in Pattern Mode. Check Pattern Color Setting section for more information about the color setting registers. Need to write Color Update Register (50h) to update the data.   Table 16 19h/29h/39h/49h P1/P2/P3/P4 TS &T1 Setting Register Bit D7:D3 D4:D0 Name T1 TS Default 0000 0000 The TS & T1 Setting Registers set the TS and T1 time in Pattern Mode. TS 0000 0001 0010 0011 0100 0101 0110 0111 1000 1001 1010 Pattern Start Time Selection 0.03s 0.13s 0.26s 0.38s 0.51s 0.77s 1.04s 1.60s 2.10s 2.60s 3.10s 14 IS31FL3195 1011 1100 1101 1110 1111 4.20s 5.20s 6.20s 7.30s 8.30s T1 0000 0001 0010 0011 0100 0101 0110 0111 1000 1001 1010 1011 1100 1101 1110 1111 Rise Time Selection 0.03s 0.13s 0.26s 0.38s 0.51s 0.77s 1.04s 1.60s 2.10s 2.60s 3.10s 4.20s 5.20s 6.20s 7.30s 8.30s T3 0000 0001 0010 0011 0100 0101 0110 0111 1000 1001 1010 1011 1100 1101 1110 1111 Table 18 1Bh/3Bh/3Bh/4Bh P1/P2/P3/P4 TP &T4 Setting Register Table 17 1Ah/2Ah/3A/4Ah P1/P2/P3/P4 T2 &T3 Setting Register Bit D7:D3 D4:D0 Name T3 T2 Default 0000 0000 The T2 & T3 Setting Registers set the T2 and T3 time in Pattern Mode. T2 0000 0001 0010 0011 0100 0101 0110 0111 1000 1001 1010 1011 1100 1101 1110 1111 Fall Time Selection 0.03s 0.13s 0.26s 0.38s 0.51s 0.77s 1.04s 1.60s 2.10s 2.60s 3.10s 4.20s 5.20s 6.20s 7.30s 8.30s Hold Time Selection 0.03s 0.13s 0.26s 0.38s 0.51s 0.77s 1.04s 1.60s 2.10s 2.60s 3.10s 4.20s 5.20s 6.20s 7.30s 8.30s Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 Bit D7:D3 D4:D0 Name T4 TP Default 0000 0000 The TP & T4 Setting Registers set the TP and T4 time in Pattern Mode. TP 0000 0001 0010 0011 0100 0101 0110 0111 1000 1001 1010 1011 1100 1101 1110 1111 Time between Pulses 0.03s 0.13s 0.26s 0.38s 0.51s 0.77s 1.04s 1.60s 2.10s 2.60s 3.10s 4.20s 5.20s 6.20s 7.30s 8.30s 15 IS31FL3195 T4 0000 0001 0010 0011 0100 0101 0110 0111 1000 1001 1010 1011 1100 1101 1110 1111 Table 21 1Eh P1 NXT Register Off Time Selection 0.03s 0.13s 0.26s 0.38s 0.51s 0.77s 1.04s 1.60s 2.10s 2.60s 3.10s 4.20s 5.20s 6.20s 7.30s 8.30s D3:D2 D1:D0 Name MTPLT1 GAM1 NXT1 Default 0000 00 01 NXT1 Pattern 1 Next 00/10/11 Just stop 01 Go to Pattern 2 (Only effective in RGB & RG+W Mode Bit D7:D3 D2 D1 D0 Name - CE3 CE2 CE1 Default 00000 0 0 1 Color Enable Register enables the color function for each color in Pattern Mode. Color Enable Selection Color x disable Color x enable Table 20 1Dh/2Dh/3Dh/4Dh Cycle Times Register D7:D4 NXT1 defines next operation when Pattern 1 is done. GAM1 controls the gamma of Pattern 1. MTPLT1 controls the loop of Pattern 1. Table 19 1Ch/2Ch/3Ch/4Ch P1/P2/P3/P4 Color Enable Register CEx 0 1 Bit P1/P2/P3/P4 Color Bit D7:D6 D5:D4 D3:D2 D1:D0 Name - CCT3 CCT2 CCT1 Default 00 00 00 00 GAM1 00/11 01 10 Gamma Selection Gamma=2.4 Gamma=3.5 Linearity MTPLT1 0000 0001 … 1111 Multy-Pulse Loop Time endless 1 time Table 22 2Eh P2 NXT Register Bit D7:D4 D3:D2 D1:D0 Name MTPLT2 GAM2 NXT2 Default 0000 00 01 NXT2 defines next operation when Pattern 2 is done. GAM2 controls the gamma of Pattern 2. MTPLT2 controls the loop of Pattern 2. NXT 2 00/11 01 Color Cycle Times Register sets Color loop times for each color. 10 CCTx 00 01 10 11 GAM2 00/11 01 10 Color Cycle Times Selection Endless 1 time 2 times 3 times Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 15 times Pattern 2 Next Just stop Go to Pattern 1 (Only effective in RGB mode) Go to Pattern 3 (Only effective in RGB mode) Gamma Selection Gamma=2.4 Gamma=3.5 Linearity 16 IS31FL3195 MTPLT2 0000 0001 … 1111   Table 23 Multy-Pulse Loop Time Endless 1 time 3Eh P3 NXT Register D7:D4 D3:D2 D1:D0 Name MTPLT3 GAM3 NXT3 Default 0000 00 01 NXT3 defines next operation when Pattern 3 is done. GAM3 controls the gamma of Pattern 3. MTPLT3 controls the loop of Pattern 3. 10 Gamma Selection Gamma=2.4 Gamma=3.5 Linearity MTPLT4 0000 0001 … 1111 Multy-Pulse Loop Time Endless 1 time 15 times Bit NXT 3 00/11 01 GAM4 00/11 01 10 Pattern 3 Next Just stop Go to Pattern 1 (Only effective in RGB mode) Go to Pattern 2 (Only effective in RGB Mode) 15 times Table 25 1Fh/2Fh/3Fh/4Fh P1/P2/P3/P4 Loop Times Register Bit D7 D6:D0 Name PLTx_H PLTx_L Default 0 000 0000 If PLTx_H(D7)=0, PLTx_L!=0 Pattern loop times: 6 Looptime  D[n]  2n (3) n0 GAM3 00/11 01 10 Gamma Selection Gamma=2.4 Gamma=3.5 Linearity MTPLT3 0000 0001 … 1111 Multy-Pulse Loop Time Endless 1 time Table 24 If PLTx_H(D7)=0, PLTx_L=0, endless If PLTx_H(D7)=1, PLTx_L!=0 Pattern loop times: 6 Looptime 16  D[n]  2n (4) n0 If PLTx_H(D7)=1, PLTx_L=0, endless Where D[n] stands for the individual bit value. 15 times 4Eh P4 NXT Register Bit D7:D4 D3:D2 D1:D0 Name MTPLT4 GAM4 - Default 0000 00 01 NXT4 defines next operation when Pattern 4 is done. GAM4 controls the gamma of Pattern 4. MTPLT4 controls the loop of Pattern 4. Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 50h Color Update Register Write 0xC5 to 40h will update the data of 10h~18h/20h~28h/30h~38h   51h/52h/53h/54h P1/P2/P3/P4 Update Register Write 0xC5 to these registers will update the time parameters of Pattern x, and start to run Pattern x. 5Fh Reset Register Once user writes “0xC5” to the Reset Register, IS31FL3195 will reset all registers to their default value. On initial power-up, the IS31FL3195 registers are reset to their default values for a blank display. 17 IS31FL3195 TYPICAL APPLICATION INFORMATION GENERAL DESCRIPTION IS31FL3195 is a 4-channel LED driver which features two-dimensional auto breathing mode. It has Pattern Mode and Current Level Mode for RGB+W lighting effects. The IS31FL3195 LED driver integrates a switched capacitor charge pump to power four LEDs with a programmable regulated current, up to 20mA (max) per channel. Upon power up, the built-in charge pump converter will initialize base on CPPM bit of 01h register. To prevent a large in-rush current; the IS31FL3195 will first charge the C1P/N, C2P/N capacitors to near VIN. The 1x mode provides maximum efficiency and minimum noise. The IS31FL3195 will remain in this mode until one of the LED current source drivers begins to drop out of regulation. The current delivered through the LED load is controlled by an internal configurable low dropout (135mV Typ.) current source. The current is set by the value of the Current Setting Resistor. CHARGE PUMP The converter is based on a charge pump technique to efficiently generate a DC voltage to supply the RGBW or RGBY LED current. The system regulates the current flowing into each LED, not the DC VOUT value. The built−in OVP circuit continuously monitors the VOUT voltage and in 1.5x charge pump mode, IS31FL3195 continuously calculates the expected current sink headroom if it exits 1.5x charge pump mode and enters 1x mode. It exits the 1.5x mode if the expected headroom is sufficient. The IS31FL3195 can operate under no load conditions. low output resistance for the sake of small capacitor size. Increasing the output capacitance (COUT) reduces the output ripple voltage. Decreasing its ESR reduces both output resistance and ripple. Smaller capacitance values can be used with light loads. Use the following equation to calculate the peak-to-peak ripple: VRIPPLE  IOUT  2  IOUT  ESRCOUT fOSC  COUT (1) A bypass capacitor on the incoming supply will reduce its AC impedance and the impact of the charge pump switching noise. A 0.1µF bypass capacitor is sufficient, place this next to the VIN pin. POWER ON SEQUENCE IS31FL3195 provides a power-on reset feature that is controlled by VCC supply voltage. When the VIN supply voltage exceeds 2.6V (Typ.), the internal circuit starts to work. The reset signal will be generated to perform a power-on reset (POR) operation, which will reset all control circuits and configuration registers until the internal power voltage becomes stable. I2C operation is allowed before SDB is pulled to high, the rising edge of SDB will reset the I2C bus. The integrated capacitive charge pump is designed for VOUT= VCC × Mode, where Mode= 1, or 1.5. The charge pump converter only needs four external components: supply decoupling capacitor, output bypass capacitor and two flying capacitors. To maintain the lowest output resistance and highest efficiency, use capacitors with low ESR (Equivalent Series Resistance). The charge-pump output resistance is a function of CP and COUT’s ESR and the internal switch resistance. Minimizing the charge-pump capacitor’s ESR minimizes the total resistance. Using larger flying capacitors for the Charge Pump (CP) reduces the output impedance and improves efficiency however, above a certain point, increasing CP’s capacitance has a negligible effect because the output resistance becomes dominated by the internal switch resistance and capacitor ESR. But when space is a constraint, it may be necessary to sacrifice Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019   Figure 7 SDB Pin Sequence Note 1: I2C operation is allowed when SDB is low. Note 2: There should be no I2C operation 10µs before or after SDB rinsing edge. SET MAX CURRENT The maximum output current of OUT1~OUT4 can be adjusted by the external resistor, RISET, as described in Formula (2). IGMAX  240 RISET (2) The recommended value of RISET is 12kΩ, when RISET=12kΩ, IGMAX=20mA. 18 IS31FL3195 The minimum IOUT of each out is 2.5mA and to achieve this, when minimum CBx of 04h is “11” (IBAND=1/4 IGMAX), maximum RISET is 96kΩ, when minimum CBx of 04h is “10” (IBAND=2/4 IGMAX), maximum RISET is 72kΩ, when minimum CBx of 04h is “01” (IBAND=3/4 IGMAX), maximum RISET is 48kΩ, when minimum CBx of 04h is “00” (IBAND=4/4 IGMAX), maximum RISET is 24kΩ. If RISET is smaller than 12kΩ, the output current will increase according the Formula 2, recommend absolute minimum RISET is 10kΩ (IGMAX=25mA). Table 26, 27 shows the registers for each mode, for example, in the Current Level Mode, the current level register is 10H for OUT1, 21H for OUT2, 32H for OUT3, 40H for OUT4, in Single mode and pattern mode, Pattern 1 has 3 current level registers and enabled/disabled by CEx. Table 26 By setting the OUTx bits of the Operating Configure Register to “0”, the corresponding OUTx will operate in Current Level Mode. The Current Level Registers are active and can modulate LED brightness of each output with 256 steps independently. For example, if the data in Current Level Register is “0000 0100”, then the current level is the fourth step, with a current level of 4/256. In Current Level Mode, the user doesn’t need to turn on the CEx, a new value must be written to the Current Level registers to change the output current. Writing new data continuously to the registers can modulate the brightness of the LEDs to achieve breathing, blinking, or any other effects that the user defines. PATTERN MODE By setting the OUTx bits of the Operating Configure Register (01h) to “1”, the corresponding OUTx will operate in Pattern Mode. In Pattern Mode, the timing characteristics for output current - current rising (T1), holding (T2), falling (T3) and off time (TS, TP, T4), can be adjusted individually so that each output can independently maintain a pre-established pattern. Thus achieving mixing color breathing or a single color breathing without requiring any additional interface activity which will save valuable system resources. The IS31FL3195 will continuously cycle through the pre-programmed patterns; the system including the micro can be powered off to significantly save battery power. Color P1 P2 P3 P4 EN OUT1 OUT2 OUT3 OUT4 Mode CURRENT LEVEL MODE There are four programmed current bands which can be set by the Current Band Register (03h). It is used to set the global maximum of each output current, IGMAX. Color Register of Single Mode Single Mode Pattern Mode 10H 21H 32H 40H CE2 13H 24H 35H 41H CE3 16H 27H 38H 42H 10H 21H 32H 40h Current Level Mode Table 27 RGB Mode CE1 Color Register of RGB/RGBY Mode Color EN P1 P2 P3 P4 OUT1 OUT2 OUT3 OUT4 CE1(1Ch) Pattern CE2(1Ch) 1 CE3(1Ch) 10H 11H 12H 40h 13H 14H 15H 41h 16H 17H 18H 42h CE1(2Ch) Pattern CE2(2Ch) 2 CE3(2Ch) 20H 21H 22H 43H 23H 24H 25H 44H 26H 27H 28H 45H CE1(3Ch) Pattern CE2(3Ch) 3 CE3(3Ch) 30H 31H 32H 46H 33H 34H 35H 47H 36H 37H 38H 48H PATTERN TIME SETTING User should configure the related pattern time setting registers according to actual timing requirements via I2C interface before starting pattern. There are three groups of pattern time that can be set for P1~P4, including TS, T1~T4 and TP. And each pattern has three continue lighting cycle as Color 1~Color 3. PHASE DELAY The outputs automatically delay the phase to minimize audible ceramic hum EMI. PATTERN COLOR SETTING Phase Delay Mode 1 In Pattern Mode, the LED color is defined by PxCOLy_Oz (x,y,z= 1,2,3,4) bits in Color Setting Registers. There are 3 RGBW current combinations to generate 3 pre-defined colors for display. More than one of the 3 pre-defined colors can be chosen by setting CEx bits in Color Enable Register (1Ch/2Ch/3Ch/4Ch). When CEx is set, the color x is allow to be displayed in current pattern. By setting PD (Phase delay mode) bits to “01”, the 4 outputs work in Phase Delay mode 1, each output will have a 125µs delay compare to previous channel, for example, OUT2 has 125µs delay than OUT1, OUT3 has 125µs delay than OUT2. Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 19 IS31FL3195 T=500µs OUT1G T=500µs PWM=0x13 OUT2R OUT3B OUT4W 1/4 1/4 1/4 Figure 8 Phase Delay Mode 1 Timing Phase Delay Mode 2 By setting PD (Phase delay mode) bits to “01”, the 4 outputs work in Phase Delay mode 1, each output will have a 62.5µs delay compare to previous channel, which is half of mode 1. Figure 10 Gamma Correction SHUTDOWN MODE Shutdown mode can either be used as a means of reducing power consumption or generating a flashing display (repeatedly entering and leaving shutdown mode). During shutdown mode all registers retain their data. Software Shutdown By setting SSD bit of the Shutdown Register (01h) to “0”, the IS31FL3195 will operate in software shutdown mode, wherein it will consume only 1.0μA (Typ.) current. When the IS31FL3195 is in software shutdown mode, all current sources are switched off. Figure 9 Phase Delay Mode 2 Timing GAMMA CORRECTION In order to perform a better visual LED breathing effect, the device integrates gamma correction to the Pattern Mode. The gamma correction function causes the change in intensity to appear more linear to the human eye. Gamma correction, also known as gamma compression or encoding, is used to encode linear luminance to match the non-linear characteristics of LED brightness. Since the IS31FL3195 can modulate the brightness of the LEDs with 256 steps, a gamma correction function can be applied when computing each subsequent LED intensity setting such that the changes in brightness matches the human eye's brightness curve. The IS31FL3195 provides three gamma corrections which can be set by GAM bits of NXT Registers (1Eh/2Eh/3Eh/4Eh) for each pattern. The gamma correction is shown as below. Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 Hardware Shutdown The chip enters hardware shutdown mode when the SDB pin is pulled low, wherein it will consume only 1.0μA (Typ.) current. When set SDB high, the rising edge will reset the I2C module, but the registers retain their data. Sleep 1 Mode When SLE bits is set to “01”, the chip will enter sleep 1 mode whenever the OUTx outputs are off for >30s, wherein they consume only 38μA (Typ.) current. In sleep 1 mode, CP stops, Bandgap working and all OUTx are off without any bias. MCU command to the IS31FL3195 will wake it up and disable the sleep mode. Sleep 2 Mode When SLE bits is set to “10”, the chip will enter sleep 2 mode whenever the OUTx outputs are off for >30s, wherein they consume only 1.0μA (Typ.) current. In sleep 2 mode, CP, Bandgap stop and all OUTx are off without any bias. MCU command to the IS31FL3195 will wake it up and disable the sleep mode. 20 IS31FL3195 LED OPERATING MODE The IS31FL3195 has three operating modes which can be chosen by the RGBW bits of Operating Configure Register (01h). Pattern Mode Run Pattern 1 Current Level Mode 256 Steps Pattern Mode Run Pattern 2 Current Level Mode 256 Steps Pattern Mode Run Pattern 3 Current Level Mode 256 Steps Pattern Mode Run Pattern 4 Current Level Mode 256 Steps Pattern Mode Run Pattern 1&2&3 Pattern Mode Run Pattern 4 Current Level Mode 256 Steps Pattern Mode Run Pattern 1&2&3 OUT1 Single Mode OUT2 OUT3 OUT4 OUT1 OUT2 OUT3 Device Operation RGB+W Mode OUT4 RGBY Mode Figure 11 Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 OUT1 OUT2 OUT3 OUT4 Operating Mode Map 21 IS31FL3195 Single Mode If RGB=00/11 (Single Mode), OUTx runs Px independently in Pattern Mode or operates in Current Level Mode. Figure 12 Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 Single Mode 22 IS31FL3195 RGB+W Mode If RGB=01 (RGB+W Mode), OUT1, OUT2 and OUT3 can operate in Pattern Mode only and run in the same pattern (P1~P3). OUT4 can be both mode and run in Pattern 4 independently. OUT1, OUT2 and OUT3 bits can’t be set. RGB+W Mode OUT1 OUT2 OUT3 TS PLT1 PLT2 PLT3 Pattern1 T1 T4 Pattern2 T1 T4 Pattern3 T1 T4 TS STOP TS STOP PLT4 OUT4 TS T1 Pattern4 T4 STOP STOP Pattern3 PLT3 MTPLT3 CCT2 CCT1 Color2 Color1 TS T1 CCT3 TP T1 Color3 TP T1 TP T4 STOP Color 3 Gamma 1.0 (Linearity) Gamma 2.5 Gamma 2.8 T1 T2 T3 TP CCT3 Figure 13 Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 RGB+W Mode 23 IS31FL3195 RGBY Mode If LM=10 (RGBY Mode), OUT1, OUT2, OUT3 and OUT4 can operate in Pattern Mode only and run in the same pattern (P1~P3). OUT1, OUT2 and OUT3 bits can’t be set. RGBY Mode OUT1 OUT2 OUT3 OUT4 TS PLT1 PLT2 PLT3 Pattern1 T1 T4 Pattern2 T1 T4 Pattern3 T1 T4 TS STOP TS STOP STOP Pattern3 PLT3 MTPLT3 CCT2 CCT1 Color1 TS T1 CCT3 Color2 TP T1 Color3 TP T1 TP T4 STOP Color 3 Gamma 1.0 (Linearity) Gamma 2.5 Gamma 2.8 T1 T2 T3 TP CCT3 Figure 14 Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 RGBY Mode 24 IS31FL3195 CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) 150°C 200°C 60-120 seconds Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) Time at liquidous (tL) 217°C 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified classification temperature (Tc) Max 30 seconds Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature 8 minutes max. Figure 15 Classification Profile Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 25 IS31FL3195 PACKAGE INFORMATION  QFN-16  Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 26 IS31FL3195  WLCSP-16   Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 27 IS31FL3195 RECOMMENDED LAND PATTERN  QFN-16 WLCSP-16 Note: 1. Land pattern complies to IPC-7351. 2. All dimensions in MM. 3. This document (including dimensions, notes & specs) is a recommendation based on typical circuit board manufacturing parameters. Since land pattern design depends on many factors unknown (eg. User’s board manufacturing specs), user must determine suitability for use. Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 28 IS31FL3195 REVISION HISTORY Revision Detail Information Date 0A Initial relesae 2018.12.07 A Update to final version 2019.04.18 Lumissil Microsystems – www.lumissil.com Rev. A, 04/18/2019 29
IS31FL3195-CLS2-TR 价格&库存
很抱歉,暂时无法提供与“IS31FL3195-CLS2-TR”相匹配的价格&库存,您可以联系我们找货
IS31FL3195-CLS2-TR
  • 1+12.261841+1.53418
  • 10+8.8911610+1.11245
  • 25+8.0539625+1.00770
  • 100+7.13565100+0.89280
  • 250+6.69775250+0.83801
  • 500+6.43402500+0.80502
  • 1000+6.216781000+0.77783
库存:8960
