S-1137C35-M5T1U
S-1137C35-M5T1U
    ABLIC(艾普凌科)
    SOT23-5
    IC REG LINEAR 3.5V 300MA SOT23-5
S-1137C35-M5T1U 数据手册
S-1137 Series www.ablic.com 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 © ABLIC Inc., 2009-2018 The S-1137 Series, developed using the CMOS technology, is a positive voltage regulator IC which has the low dropout voltage, the high-accuracy output voltage and the soft-start function (300 mA output current). A 1.0 μF small ceramic capacitor can be used. It operates with low current consumption of 45 μA typ. The overcurrent protection circuit prevents the load current from exceeding the current capacity of the output transistor. The ON / OFF circuit ensures longer battery life. Compared to the conventional CMOS technology regulator ICs, various capacitors including small ceramic capacitors can be used for this IC. Furthermore, small SOT-89-5, SOT-23-5, and SNT-6A(H) packages realize high-density mounting.  Features • Output voltage: • Input voltage: • Output voltage accuracy: • Dropout voltage: • Current consumption: • Output current: • Input and output capacitors: • Ripple rejection: • Built-in soft-start circuit: • Built-in overcurrent protection circuit: • Built-in ON / OFF circuit: • Operation temperature range: • Lead-free, Sn 100%, halogen-free*2 1.2 V to 3.5 V, selectable in 0.05 V step 1.7 V to 5.5 V ±1.0% (1.2 V to 1.45 V output product : ±15 mV) 210 mV typ. (2.8 V output product, IOUT = 300 mA) During operation: 45 μA typ., 65 μA max. During power-off: 0.1 μA typ., 1.0 μA max. Possible to output 300 mA (VIN ≥ VOUT(S) + 1.0 V)*1 A ceramic capacitor of 1.0 μF or more can be used. 70 dB typ. (f = 1.0 kHz) Soft-start time : 0.7 ms typ. (CSS = 1.0 nF) Limits overcurrent of output transistor. Ensures long battery life. Discharge shunt function “available” / “unavailable” is selectable. Pull-down function “available” / “unavailable” is selectable. Ta = −40°C to +85°C *1. Attention should be paid to the power dissipation of the package when the output current is large. *2. Refer to “ Product Name Structure” for details.  Applications • Constant-voltage power supply for battery-powered device • Constant-voltage power supply for cellular phone, portable device • Constant-voltage power supply for digital still camera, TV, DVD recorder  Packages • SOT-89-5 • SOT-23-5 • SNT-6A(H) 1 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series  Block Diagrams 1. S-1137 Series A type *1 VIN VOUT Overcurrent protection circuit ON / OFF circuit ON / OFF Soft-start circuit SSC *1 Function ON / OFF logic Discharge shunt function Pull-down resistor Status Active “H” Available Available + − Reference voltage circuit *1 VSS *1. Parasitic diode Figure 1 2. S-1137 Series B type *1 VIN VOUT Overcurrent protection circuit ON / OFF circuit ON / OFF Soft-start circuit SSC *1 + − Reference voltage circuit *1 VSS *1. Parasitic diode Figure 2 2 Function ON / OFF logic Discharge shunt function Pull-down resistor Status Active “H” Available Unavailable 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series 3. S-1137 Series C type *1 VIN VOUT Overcurrent protection circuit ON / OFF circuit ON / OFF Soft-start circuit SSC *1 Function ON / OFF logic Discharge shunt function Pull-down resistor Status Active “H” Unavailable Available + − Reference voltage circuit VSS *1. Parasitic diode Figure 3 4. S-1137 Series D type *1 VIN VOUT Overcurrent protection circuit ON / OFF circuit ON / OFF Soft-start circuit SSC *1 Function ON / OFF logic Discharge shunt function Pull-down resistor Status Active “H” Unavailable Unavailable + − Reference voltage circuit VSS *1. Parasitic diode Figure 4 3 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series  Product Name Structure Users can select the product type, output voltage, and package type for the S-1137 Series. Refer to “1. Product name” regarding the contents of product name, “2. Function list of product type” regarding the product type, “3. Packages” regarding the package drawings. 1. Product name (1) SOT-89-5 S-1137 x xx - U5T1 x Environmental code U: Lead-free (Sn 100%), halogen-free G: Lead-free (for details, please contact our sales office) Package abbreviation and IC packing specifications U5T1: SOT-89-5, Tape *1 Output voltage*2 12 to 35 (e.g., when the output voltage is 1.2 V, it is expressed as 12.) Product type*3 A to D *1. *2. *3. (2) Refer to the tape drawing. If you request the product which has 0.05 V step, contact our sales office. Refer to “2. Function list of product type”. SOT-23-5 S-1137 x xx - M5T1 x Environmental code U: Lead-free (Sn 100%), halogen-free S: Lead-free, halogen-free Package abbreviation and IC packing specifications M5T1: SOT-23-5, Tape *1 Output voltage*2 12 to 35 (e.g., when the output voltage is 1.2 V, it is expressed as 12.) Product type*3 A to D *1. *2. *3. 4 Refer to the tape drawing. If you request the product which has 0.05 V step, contact our sales office. Refer to “2. Function list of product type”. 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series (3) SNT-6A(H) S-1137 x xx - I6T2 U Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications I6T2: SNT-6A(H), Tape *1 Output voltage*2 12 to 35 (e.g., when the output voltage is 1.2 V, it is expressed as 12.) Product type*3 A to D *1. *2. *3. 2. Refer to the tape drawing. If you request the product which has 0.05 V step, contact our sales office. Refer to “2. Function list of product type”. Function list of product type Table 1 Product Type A B C D 3. ON / OFF Logic Active “H” Active “H” Active “H” Active “H” Discharge Shunt Function Available Available Unavailable Unavailable Pull-down Resistor Available Unavailable Available Unavailable Packages Package Name SOT-89-5 SOT-23-5 SNT-6A(H) Drawing Code Package Tape Reel Land UP005-A-P-SD MP005-A-P-SD PI006-A-P-SD UP005-A-C-SD MP005-A-C-SD PI006-A-C-SD UP005-A-R-SD MP005-A-R-SD PI006-A-R-SD ⎯ ⎯ PI006-A-L-SD 5 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series 4. Product name list 4. 1 S-1137 Series A type ON / OFF logic: Discharge shunt function: Active “H” Available Pull-down resistor: Available Table 2 Output Voltage SOT-89-5 SOT-23-5 SNT-6A(H) 1.2 V ±15 mV S-1137A12-U5T1x S-1137A12-M5T1y S-1137A12-I6T2U 1.3 V ±15 mV S-1137A13-U5T1x S-1137A13-M5T1y S-1137A13-I6T2U 1.4 V ±15 mV S-1137A14-U5T1x S-1137A14-M5T1y S-1137A14-I6T2U 1.5 V ±1.0% S-1137A15-U5T1x S-1137A15-M5T1y S-1137A15-I6T2U 1.6 V ±1.0% S-1137A16-U5T1x S-1137A16-M5T1y S-1137A16-I6T2U 1.7 V ±1.0% S-1137A17-U5T1x S-1137A17-M5T1y S-1137A17-I6T2U 1.8 V ±1.0% S-1137A18-U5T1x S-1137A18-M5T1y S-1137A18-I6T2U 1.85 V ±1.0% S-1137A1J-U5T1x S-1137A1J-M5T1y S-1137A1J-I6T2U 1.9 V ±1.0% S-1137A19-U5T1x S-1137A19-M5T1y S-1137A19-I6T2U 2.0 V ±1.0% S-1137A20-U5T1x S-1137A20-M5T1y S-1137A20-I6T2U 2.1 V ±1.0% S-1137A21-U5T1x S-1137A21-M5T1y S-1137A21-I6T2U 2.2 V ±1.0% S-1137A22-U5T1x S-1137A22-M5T1y S-1137A22-I6T2U 2.3 V ±1.0% S-1137A23-U5T1x S-1137A23-M5T1y S-1137A23-I6T2U 2.4 V ±1.0% S-1137A24-U5T1x S-1137A24-M5T1y S-1137A24-I6T2U 2.5 V ±1.0% S-1137A25-U5T1x S-1137A25-M5T1y S-1137A25-I6T2U 2.6 V ±1.0% S-1137A26-U5T1x S-1137A26-M5T1y S-1137A26-I6T2U 2.7 V ±1.0% S-1137A27-U5T1x S-1137A27-M5T1y S-1137A27-I6T2U 2.8 V ±1.0% S-1137A28-U5T1x S-1137A28-M5T1y S-1137A28-I6T2U 2.85 V ±1.0% S-1137A2J-U5T1x S-1137A2J-M5T1y S-1137A2J-I6T2U 2.9 V ±1.0% S-1137A29-U5T1x S-1137A29-M5T1y S-1137A29-I6T2U 3.0 V ±1.0% S-1137A30-U5T1x S-1137A30-M5T1y S-1137A30-I6T2U 3.1 V ±1.0% S-1137A31-U5T1x S-1137A31-M5T1y S-1137A31-I6T2U 3.2 V ±1.0% S-1137A32-U5T1x S-1137A32-M5T1y S-1137A32-I6T2U 3.3 V ±1.0% S-1137A33-U5T1x S-1137A33-M5T1y S-1137A33-I6T2U 3.4 V ±1.0% S-1137A34-U5T1x S-1137A34-M5T1y S-1137A34-I6T2U 3.5 V ±1.0% S-1137A35-U5T1x S-1137A35-M5T1y S-1137A35-I6T2U Remark 1. Please contact our sales office for products with specifications other than the above. 2. x: G or U y: S or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 6 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series 4. 2 S-1137 Series B type ON / OFF logic: Discharge shunt function: Active “H” Available Pull-down resistor: Unavailable Table 3 Output Voltage SOT-89-5 SOT-23-5 SNT-6A(H) 1.2 V ±15 mV S-1137B12-U5T1x S-1137B12-M5T1y S-1137B12-I6T2U 1.3 V ±15 mV S-1137B13-U5T1x S-1137B13-M5T1y S-1137B13-I6T2U 1.4 V ±15 mV S-1137B14-U5T1x S-1137B14-M5T1y S-1137B14-I6T2U 1.5 V ±1.0% S-1137B15-U5T1x S-1137B15-M5T1y S-1137B15-I6T2U 1.6 V ±1.0% S-1137B16-U5T1x S-1137B16-M5T1y S-1137B16-I6T2U 1.7 V ±1.0% S-1137B17-U5T1x S-1137B17-M5T1y S-1137B17-I6T2U 1.8 V ±1.0% S-1137B18-U5T1x S-1137B18-M5T1y S-1137B18-I6T2U 1.85 V ±1.0% S-1137B1J-U5T1x S-1137B1J-M5T1y S-1137B1J-I6T2U 1.9 V ±1.0% S-1137B19-U5T1x S-1137B19-M5T1y S-1137B19-I6T2U 2.0 V ±1.0% S-1137B20-U5T1x S-1137B20-M5T1y S-1137B20-I6T2U 2.1 V ±1.0% S-1137B21-U5T1x S-1137B21-M5T1y S-1137B21-I6T2U 2.2 V ±1.0% S-1137B22-U5T1x S-1137B22-M5T1y S-1137B22-I6T2U 2.3 V ±1.0% S-1137B23-U5T1x S-1137B23-M5T1y S-1137B23-I6T2U 2.4 V ±1.0% S-1137B24-U5T1x S-1137B24-M5T1y S-1137B24-I6T2U 2.5 V ±1.0% S-1137B25-U5T1x S-1137B25-M5T1y S-1137B25-I6T2U 2.6 V ±1.0% S-1137B26-U5T1x S-1137B26-M5T1y S-1137B26-I6T2U 2.7 V ±1.0% S-1137B27-U5T1x S-1137B27-M5T1y S-1137B27-I6T2U 2.8 V ±1.0% S-1137B28-U5T1x S-1137B28-M5T1y S-1137B28-I6T2U 2.85 V ±1.0% S-1137B2J-U5T1x S-1137B2J-M5T1y S-1137B2J-I6T2U 2.9 V ±1.0% S-1137B29-U5T1x S-1137B29-M5T1y S-1137B29-I6T2U 3.0 V ±1.0% S-1137B30-U5T1x S-1137B30-M5T1y S-1137B30-I6T2U 3.1 V ±1.0% S-1137B31-U5T1x S-1137B31-M5T1y S-1137B31-I6T2U 3.2 V ±1.0% S-1137B32-U5T1x S-1137B32-M5T1y S-1137B32-I6T2U 3.3 V ±1.0% S-1137B33-U5T1x S-1137B33-M5T1y S-1137B33-I6T2U 3.4 V ±1.0% S-1137B34-U5T1x S-1137B34-M5T1y S-1137B34-I6T2U 3.5 V ±1.0% S-1137B35-U5T1x S-1137B35-M5T1y S-1137B35-I6T2U Remark 1. Please contact our sales office for products with specifications other than the above. 2. x: G or U y: S or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 7 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series 4. 3 S-1137 Series C type ON / OFF logic: Discharge shunt function: Active “H” Unavailable Pull-down resistor: Available Table 4 Output Voltage SOT-89-5 SOT-23-5 SNT-6A(H) 1.2 V ±15 mV S-1137C12-U5T1x S-1137C12-M5T1y S-1137C12-I6T2U 1.3 V ±15 mV S-1137C13-U5T1x S-1137C13-M5T1y S-1137C13-I6T2U 1.4 V ±15 mV S-1137C14-U5T1x S-1137C14-M5T1y S-1137C14-I6T2U 1.5 V ±1.0% S-1137C15-U5T1x S-1137C15-M5T1y S-1137C15-I6T2U 1.6 V ±1.0% S-1137C16-U5T1x S-1137C16-M5T1y S-1137C16-I6T2U 1.7 V ±1.0% S-1137C17-U5T1x S-1137C17-M5T1y S-1137C17-I6T2U 1.8 V ±1.0% S-1137C18-U5T1x S-1137C18-M5T1y S-1137C18-I6T2U 1.85 V ±1.0% S-1137C1J-U5T1x S-1137C1J-M5T1y S-1137C1J-I6T2U 1.9 V ±1.0% S-1137C19-U5T1x S-1137C19-M5T1y S-1137C19-I6T2U 2.0 V ±1.0% S-1137C20-U5T1x S-1137C20-M5T1y S-1137C20-I6T2U 2.1 V ±1.0% S-1137C21-U5T1x S-1137C21-M5T1y S-1137C21-I6T2U 2.2 V ±1.0% S-1137C22-U5T1x S-1137C22-M5T1y S-1137C22-I6T2U 2.3 V ±1.0% S-1137C23-U5T1x S-1137C23-M5T1y S-1137C23-I6T2U 2.4 V ±1.0% S-1137C24-U5T1x S-1137C24-M5T1y S-1137C24-I6T2U 2.5 V ±1.0% S-1137C25-U5T1x S-1137C25-M5T1y S-1137C25-I6T2U 2.6 V ±1.0% S-1137C26-U5T1x S-1137C26-M5T1y S-1137C26-I6T2U 2.7 V ±1.0% S-1137C27-U5T1x S-1137C27-M5T1y S-1137C27-I6T2U 2.8 V ±1.0% S-1137C28-U5T1x S-1137C28-M5T1y S-1137C28-I6T2U 2.85 V ±1.0% S-1137C2J-U5T1x S-1137C2J-M5T1y S-1137C2J-I6T2U 2.9 V ±1.0% S-1137C29-U5T1x S-1137C29-M5T1y S-1137C29-I6T2U 3.0 V ±1.0% S-1137C30-U5T1x S-1137C30-M5T1y S-1137C30-I6T2U 3.1 V ±1.0% S-1137C31-U5T1x S-1137C31-M5T1y S-1137C31-I6T2U 3.2 V ±1.0% S-1137C32-U5T1x S-1137C32-M5T1y S-1137C32-I6T2U 3.3 V ±1.0% S-1137C33-U5T1x S-1137C33-M5T1y S-1137C33-I6T2U 3.4 V ±1.0% S-1137C34-U5T1x S-1137C34-M5T1y S-1137C34-I6T2U 3.5 V ±1.0% S-1137C35-U5T1x S-1137C35-M5T1y S-1137C35-I6T2U Remark 1. Please contact our sales office for products with specifications other than the above. 2. x: G or U y: S or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 8 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series 4. 4 S-1137 Series D type ON / OFF logic: Discharge shunt function: Active “H” Unavailable Pull-down resistor: Unavailable Table 5 Output Voltage SOT-89-5 SOT-23-5 SNT-6A(H) 1.2 V ±15 mV S-1137D12-U5T1x S-1137D12-M5T1y S-1137D12-I6T2U 1.3 V ±15 mV S-1137D13-U5T1x S-1137D13-M5T1y S-1137D13-I6T2U 1.4 V ±15 mV S-1137D14-U5T1x S-1137D14-M5T1y S-1137D14-I6T2U 1.5 V ±1.0% S-1137D15-U5T1x S-1137D15-M5T1y S-1137D15-I6T2U 1.6 V ±1.0% S-1137D16-U5T1x S-1137D16-M5T1y S-1137D16-I6T2U 1.7 V ±1.0% S-1137D17-U5T1x S-1137D17-M5T1y S-1137D17-I6T2U 1.8 V ±1.0% S-1137D18-U5T1x S-1137D18-M5T1y S-1137D18-I6T2U 1.85 V ±1.0% S-1137D1J-U5T1x S-1137D1J-M5T1y S-1137D1J-I6T2U 1.9 V ±1.0% S-1137D19-U5T1x S-1137D19-M5T1y S-1137D19-I6T2U 2.0 V ±1.0% S-1137D20-U5T1x S-1137D20-M5T1y S-1137D20-I6T2U 2.1 V ±1.0% S-1137D21-U5T1x S-1137D21-M5T1y S-1137D21-I6T2U 2.2 V ±1.0% S-1137D22-U5T1x S-1137D22-M5T1y S-1137D22-I6T2U 2.3 V ±1.0% S-1137D23-U5T1x S-1137D23-M5T1y S-1137D23-I6T2U 2.4 V ±1.0% S-1137D24-U5T1x S-1137D24-M5T1y S-1137D24-I6T2U 2.5 V ±1.0% S-1137D25-U5T1x S-1137D25-M5T1y S-1137D25-I6T2U 2.6 V ±1.0% S-1137D26-U5T1x S-1137D26-M5T1y S-1137D26-I6T2U 2.7 V ±1.0% S-1137D27-U5T1x S-1137D27-M5T1y S-1137D27-I6T2U 2.8 V ±1.0% S-1137D28-U5T1x S-1137D28-M5T1y S-1137D28-I6T2U 2.85 V ±1.0% S-1137D2J-U5T1x S-1137D2J-M5T1y S-1137D2J-I6T2U 2.9 V ±1.0% S-1137D29-U5T1x S-1137D29-M5T1y S-1137D29-I6T2U 3.0 V ±1.0% S-1137D30-U5T1x S-1137D30-M5T1y S-1137D30-I6T2U 3.1 V ±1.0% S-1137D31-U5T1x S-1137D31-M5T1y S-1137D31-I6T2U 3.2 V ±1.0% S-1137D32-U5T1x S-1137D32-M5T1y S-1137D32-I6T2U 3.3 V ±1.0% S-1137D33-U5T1x S-1137D33-M5T1y S-1137D33-I6T2U 3.4 V ±1.0% S-1137D34-U5T1x S-1137D34-M5T1y S-1137D34-I6T2U 3.5 V ±1.0% S-1137D35-U5T1x S-1137D35-M5T1y S-1137D35-I6T2U Remark 1. Please contact our sales office for products with specifications other than the above. 2. x: G or U y: S or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 9 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series  Pin Configurations 1. SOT-89-5 Table 6 Top view 5 Pin No. 4 1 2 1 2 3 4 5 Symbol VOUT VSS SSC ON / OFF VIN Description Output voltage pin GND pin Pin for soft-start control*1 ON / OFF pin Input voltage pin 3 Figure 5 *1. 2. Connect a capacitor between the SSC pin and VSS pin. The VOUT rising speeds at power-on and at the time when the ON / OFF pin is set to ON can be adjusted according to the capacitance. For details, refer to “■ Selection of Capacitor for Soft-start (CSS)”. SOT-23-5 Table 7 Top view 5 Pin No. 1 2 3 4 5 4 1 2 3 Symbol VIN VSS ON / OFF SSC VOUT Description Input voltage pin GND pin ON / OFF pin Pin for soft-start control*1 Output voltage pin Figure 6 *1. 3. Connect a capacitor between the SSC pin and VSS pin. The VOUT rising speeds at power-on and at the time when the ON / OFF pin is set to ON can be adjusted according to the capacitance. For details, refer to “■ Selection of Capacitor for Soft-start (CSS)”. SNT-6A(H) Table 8 Top view 1 2 3 6 5 4 Figure 7 *1. 10 Pin No. 1 2 3 4 5 6 Symbol VOUT VSS SSC ON / OFF VSS VIN Description Output voltage pin GND pin Pin for soft-start control*1 ON / OFF pin GND pin Input voltage pin Connect a capacitor between the SSC pin and VSS pin. The VOUT rising speeds at power-on and at the time when the ON / OFF pin is set to ON can be adjusted according to the capacitance. For details, refer to “■ Selection of Capacitor for Soft-start (CSS)”. 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series  Absolute Maximum Ratings Table 9 Item Symbol VIN VON / OFF VSSC VOUT Input voltage Output voltage SOT-89-5 PD SOT-23-5 SNT-6A(H) Operation ambient temperature Topr Storage temperature Tstg *1. When mounted on board [Mounted board] (1) Board size : 114.3 mm × 76.2 mm × t1.6 mm (2) Name : JEDEC STANDARD51-7 Power dissipation VSS − 0.3 to VSS + 6.0 VSS − 0.3 to VIN + 0.3 VSS − 0.3 to VIN + 0.3 VSS − 0.3 to VIN + 0.3 1000*1 600*1 500*1 −40 to +85 −40 to +125 V V V V mW mW mW °C °C The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. 1200 Power Dissipation (PD) [mW] Caution (Ta = 25°C unless otherwise specified) Absolute Maximum Rating Unit 1000 SOT-89-5 800 SOT-23-5 600 400 200 SNT-6A(H) 0 0 150 100 50 Ambient Temperature (Ta) [°C] Figure 8 Power Dissipation of Package 11 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series  Electrical Characteristics Table 10 (1 / 2) Item Output voltage Output current *1 *2 Symbol VOUT(E) IOUT Condition VIN = VOUT(S) + 1.0 V, IOUT = 100 mA 1.2 V ≤ VOUT(S) < 1.5 V 1.5 V ≤ VOUT(S) ≤ 3.5 V VIN ≥ VOUT(S) + 1.0 V 1.2 V ≤ VOUT(S) < 1.3 V 1.3 V ≤ VOUT(S) < 1.4 V 1.4 V ≤ VOUT(S) < 1.5 V 1.5 V ≤ VOUT(S) < 1.7 V 1.7 V ≤ VOUT(S) < 2.0 V 2.0 V ≤ VOUT(S) < 2.4 V 2.4 V ≤ VOUT(S) < 2.8 V 2.8 V ≤ VOUT(S) ≤ 3.5 V (Ta = 25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit VOUT(S) − 0.015 VOUT(S) × 0.99 300*5 0.50 ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ 0.58 0.48 0.37 0.31 0.28 0.25 0.23 0.21 VOUT(S) + 0.015 VOUT(S) × 1.01 ⎯ 0.67 0.56 0.50 0.47 0.42 0.38 0.35 0.31 VOUT(S) VOUT(S) V 1 V 1 mA V V V V V V V V 3 1 1 1 1 1 1 1 1 Dropout voltage*3 Vdrop IOUT = 300 mA Line regulation ΔVOUT1 ΔVIN• VOUT VOUT(S) + 0.5 V ≤ VIN ≤ 5.5 V, IOUT = 100 mA ⎯ 0.05 0.2 %/V 1 Load regulation ΔVOUT2 VIN = VOUT(S) + 1.0 V, 1.0 mA ≤ IOUT ≤ 100 mA VIN = VOUT(S) + 1.0 V, 1.0 mA ≤ IOUT ≤ 300 mA VIN = VOUT(S) + 1.0 V, IOUT = 30 mA, −40°C ≤ Ta ≤ +85°C ⎯ ⎯ 15 45 40 120 mV mV 1 1 ⎯ ±130 ⎯ ppm/°C 1 ISS1 VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, no load ⎯ 45 65 μA 2 ΔVOUT ΔTa • VOUT Output voltage *4 temperature coefficient Current consumption during operation Current consumption during power-off Input voltage ON / OFF pin input voltage “H” ON / OFF pin input voltage “L” ON / OFF pin input current “H” ISS2 VIN = VOUT(S) + 1.0 V, ON / OFF pin = OFF, no load ⎯ 0.1 1.0 μA 2 VIN ⎯ VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ determined by VOUT output level VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ determined by VOUT output level B / D type VIN = 5.5 V, VON / OFF = 5.5 V A / C type 1.7 ⎯ 5.5 V ⎯ 1.0 ⎯ ⎯ V 4 ⎯ ⎯ 0.3 V 4 −0.1 1.0 ⎯ 2.5 0.1 5.0 μA μA 4 4 ON / OFF pin input current “L” ISL VIN = 5.5 V, VON / OFF = 0 V −0.1 ⎯ 0.1 μA 4 ⎯ 70 ⎯ dB 5 ⎯ 150 ⎯ mA 3 ⎯ 0.7 ⎯ ms 1 Ripple rejection VSH VSL ISH RR Short-circuit current Ishort Soft-start time tSS 12 VIN = VOUT(S) + 1.0 V, f = 1.0 kHz, ΔVrip = 0.5 Vrms, IOUT = 50 mA VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, VOUT = 0 V VIN = VOUT(S) + 1.0 V, IOUT = 100 mA, CL = 1.0 μF, CSS = 1.0 nF 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series Table 10 (2 / 2) S-1137 Series A / B type (With discharge shunt function) Item Discharge shunt resistance during power-off Symbol RLOW Condition VOUT = 0.1 V, VIN = 5.5 V Min. Typ. Max. Unit Test Circuit ⎯ 35 ⎯ Ω 3 Min. Typ. Max. Unit Test Circuit S-1137 Series A / C type (With pull-down resistor) Item Symbol Condition Power-off RPD ⎯ 1.0 2.2 5.0 MΩ 4 pull-down resistor *1. VOUT(S): Set output voltage VOUT(E): Actual output voltage Output voltage when fixing IOUT (= 100 mA) and inputting VOUT(S) +1.0 V *2. The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current. *3. Vdrop = VIN1 − (VOUT3 × 0.98) VOUT3 is the output voltage when VIN = VOUT(S) + 1.0 V and IOUT = 300 mA. VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. *4. A change in temperature of the output voltage [mV/°C] is calculated using the following equation. ΔV ΔVOUT [mV/°C]*1 = VOUT(S) [V]*2 × ΔTa •OUT [ppm/°C]*3 ÷ 1000 ΔTa VOUT *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient *5. The output current can be at least this value. Due to restrictions on the package power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation of the package when the output current is large. This specification is guaranteed by design. 13 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series  Test Circuits 1. + VOUT VIN ON / OFF SSC VSS V A + Set to ON Figure 9 2. + A VOUT VIN ON / OFF SSC VSS Set to VIN or GND Figure 10 3. VOUT VIN ON / OFF SSC VSS A V + Set to VIN or GND Figure 11 4. VOUT VIN + A ON / OFF SSC VSS V + RL Figure 12 5. VOUT VIN ON / OFF SSC VSS Set to ON Figure 13 14 V + RL 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series  Standard Circuit Input Output VOUT VIN CIN*1 ON / OFF SSC VSS Single GND *1. *2. *3. CL CSS *2 *3 GND CIN is a capacitor for stabilizing the input. A ceramic capacitor of 1.0 μF or more can be used as CL. A ceramic capacitor of 0.22 nF to 22 nF can be used for CSS. Figure 14 Caution The above connection diagram and constants will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constants.  Condition of Application Input capacitor (CIN) : 1.0 μF or more Output capacitor (CL) : 1.0 μF or more Capacitor for soft-start (CSS) : 0.22 nF to 22 nF Caution Generally a series regulator may cause oscillation, depending on the selection of external parts. Confirm that no oscillation occurs in the application for which the above capacitors are used.  Selection of Input and Output Capacitors (CIN, CL) The S-1137 Series requires an output capacitor between the VOUT pin and VSS pin for phase compensation. Operation is stabilized by a ceramic capacitor with an output capacitance of 1.0 μF or more over the entire temperature range. When using an OS capacitor, a tantalum capacitor, or an aluminum electrolytic capacitor, the capacitance must be 1.0 μF or more. The value of the output overshoot or undershoot transient response varies depending on the value of the output capacitor. The required capacitance of the input capacitor differs depending on the application. The recommended capacitance for an application is CIN ≥ 1.0 μF, CL ≥ 1.0 μF; however, when selecting the output capacitor, perform sufficient evaluation including evaluation of temperature characteristics with the actual device.  Selection of Capacitor for Soft-start (CSS) The S-1137 Series requires a capacitor for soft-start (CSS) between the SSC pin and VSS pin. Over the entire temperature range, the S-1137 Series operates stably with a ceramic capacitor of 0.22 nF or more. According to CSS capacitance, the rising speed of the output voltage is adjustable. The time that the output voltage rises to 99% is 0.7 ms typ. at CSS = 1.0 nF. The recommended value for applications is 0.22 nF ≤ CSS ≤ 22 nF, however, define the values by sufficient evaluation including the temperature characteristics under the usage condition. 15 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series  Explanation of Terms 1. Low dropout voltage regulator This voltage regulator has the low dropout voltage due to its built-in low on-resistance transistor. 2. Output voltage (VOUT) The accuracy of the output voltage is ensured at ±1.0% or ±15 mV*1 under the specified conditions of fixed input voltage*2, fixed output current, and fixed temperature. *1. *2. When VOUT < 1.5 V : ±15 mV, When 1.5 V ≤ VOUT : ±1.0% Differs depending on the product. Caution 3. If the above conditions change, the output voltage value may vary and exceed the accuracy range of the output voltage. Refer to “ Electrical Characteristics” and “ Characteristics (Typical Data)” for details. ΔVOUT1  ΔVIN • VOUT  Line regulation  Indicates the dependency of the output voltage on the input voltage. That is, the values show how much the output voltage changes due to a change in the input voltage with the output current remaining unchanged. 4. Load regulation (ΔVOUT2) Indicates the dependency of the output voltage on the output current. That is, the values show how much the output voltage changes due to a change in the output current with the input voltage remaining unchanged. 5. Dropout voltage (Vdrop) Indicates the difference between input voltage (VIN1) and the output voltage when; decreasing input voltage (VIN) gradually until the output voltage has dropped out to the value of 98% of output voltage (VOUT3), which is at VIN = VOUT(S) + 1.0 V. Vdrop = VIN1 − (VOUT3 × 0.98) 16 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series ΔVOUT  ΔTa • VOUT  6. Output voltage temperature coefficient  The shaded area in Figure 15 is the range where VOUT varies in the operation temperature range when the output voltage temperature coefficient is ±130 ppm/°C. Example of S-1137B30 typ. product VOUT [V] +0.39 mV/°C *1 VOUT(E) −0.39 mV/°C −40 *1. +25 +85 Ta [°C] VOUT(E) is the value of the output voltage measured at Ta = +25°C. Figure 15 A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. ΔV ΔVOUT [mV/°C]*1 = VOUT(S) [V]*2 × ΔTa •OUT [ppm/°C]*3 ÷ 1000 ΔTa VOUT *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient 17 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series  Operation 1. Basic operation Figure 16 shows the block diagram of the S-1137 Series. The error amplifier compares the reference voltage (Vref) with feedback voltage (Vfb), which is the output voltage resistance-divided by feedback resistors (Rs and Rf). It supplies the gate voltage necessary to maintain the constant output voltage which is not influenced by the input voltage and temperature change, to the output transistor. VIN *1 Current supply Error amplifier Vref VOUT − Rf + Vfb Reference voltage circuit Rs VSS *1. Parasitic diode Figure 16 2. Output transistor In the S-1137 Series, a low on-resistance P-channel MOS FET is used as the output transistor. Be sure that VOUT does not exceed VIN + 0.3 V to prevent the voltage regulator from being damaged due to reverse current flowing from the VOUT pin through a parasitic diode to the VIN pin, when the potential of VOUT became higher than VIN. 18 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series 3. ON / OFF pin This pin starts and stops the regulator. When the ON / OFF pin is set to OFF level, the entire internal circuit stops operating, and the built-in P-channel MOS FET output transistor between the VIN pin and VOUT pin is turned off, reducing current consumption significantly. The S-1137 Series has a discharge shunt circuit which discharges the capacitor for soft-start (CSS) so that the SSC pin is forcibly set to the VSS level. Since the S-1137 Series A / B types have a built-in discharge shunt circuit to discharge the output capacitance, the VOUT pin is forcibly set to VSS level. In the S-1137 Series C / D types, the VOUT pin is set to VSS level through several hundred kΩ internal divided resistors between the VOUT pin and VSS pin. Note that the current consumption increases when a voltage of 0.3 V to 1.0 V (Ta = 25°C) is applied to the ON / OFF pin. The ON / OFF pin is configured as shown in Figures 17 and 18. In the S-1137 Series A / C types, the ON / OFF pin is internally pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. In the S-1137 Series B / D types, the ON / OFF pin is not internally pulled down, so do not use the pin in the floating status. When not using the ON / OFF pin in the S-1137 Series B / D types, connect the pin to the VIN pin. Table 11 Product Type ON / OFF Pin Internal Circuit VOUT Pin Voltage Current Consumption A/B/C/D “H” : ON Operate Set value ISS1*1 A/B/C/D “L” : OFF Stop VSS level ISS2 *1. IC’s current consumption increases as much as current flows into the pull-down resistor when the ON / OFF pin is connected to the VIN pin and the S-1137 Series A / C types is operating (Figure 17). (1) S-1137 Series A / C Type (2) S-1137 Series B / D Type VIN ON / OFF VIN ON / OFF VSS Figure 17 VSS Figure 18 19 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series 4. Discharge shunt function (S-1137 Series A / B types) The S-1137 Series A / B types have a built-in discharge shunt circuit to discharge the output capacitance. When the ON / OFF pin is set to OFF level, turns the output transistor off, and turns the discharge shunt circuit on so that the output capacitor discharges. These types allow for the VOUT pin reach the VSS level faster than the S-1137 Series C / D types that does not have a discharge shunt circuit. S-1137 Series Output transistor : OFF *1 VOUT VIN Discharge shunt circuit : ON *1 ON / OFF ON / OFF circuit Output capacitor (CL) ON / OFF Pin: OFF Current flow GND VSS *1. Parasitic diode Figure 19 5. Overcurrent protection circuit The S-1137 Series has an overcurrent protection circuit having the characteristics shown in “(1) Output Voltage vs. Output Current (When Load Current Increases) (Ta = 25°C)” in “ Characteristics (Typical Data)”, in order to protect the output transistor against an excessive output current and short circuiting between the VOUT pin and VSS pin. The current when the output pin is short-circuited (Ishort) is internally set at approx. 150 mA typ., and the normal value is restored for the output voltage, if releasing a short circuit once. Caution This overcurrent protection circuit does not work as for thermal protection. If this IC long keeps short circuiting inside, pay attention to the conditions of input voltage and load current so that, under the usage conditions including short circuit, the loss of the IC will not exceed power dissipation of the package. 6. Pull-down resistor (S-1137 Series A / C types) In the S-1137 Series A / C types, the ON / OFF pin is internally pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. IC’s current consumption increases as much as current flows into the pull-down resistor of 2.2 MΩ typ. when the ON / OFF pin is connected to the VIN pin and the S-1137 Series A / C types is operating. 20 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series 7. Soft-start function The S-1137 Series has a soft-start circuit to suppress the rush current (IRUSH) and overshoot of the output voltage generated at power-on or at the time when the ON / OFF pin is set to ON. Immediately after power-on or after the ON / OFF pin is set to ON, the output voltage slowly rises. The time that the output voltage rises to 99% (tSS) is adjustable by a capacitor (CSS) externally connected between the SSC pin and VSS pin. When CSS = 1.0 nF, the time is 0.7 ms typ. At the time when the ON / OFF pin is set to OFF, the electric charge charged in the external capacitor (CSS) will be discharged by the discharge shunt transistor. The soft-start time (tSS) is defined by time consonants of the built-in constant current (approx. 1 μA) and the external capacitor (CSS): tSS (ms) = soft-start coefficient × CSS (nF) The soft-start coefficient (25°C) is as follows. Min. : 0.4, Typ. : 0.7, Max. : 1.2 Input voltage (VIN) approx.0.7 V SSC pin voltage (VSSC) VOUT × 0.99 Output voltage (VOUT) Soft-start time (tSS) t [ms] Figure 20 The rush current can be suppressed greatly by the soft-start function. As the value of the external capacitor is larger, the rush current decreases more. Figure 21 shows the waveform example of the rush current. Input voltage (VIN) Without soft-start : about 400 mA at the peak With soft-start : about 20 mA at the peak Rush current (IRUSH) t [ms] Figure 21 Waveform Example of Rush Current 21 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series  Precautions • Wiring patterns for the VIN pin, the VOUT pin and GND should be designed so that the impedance is low. When mounting an output capacitor between the VOUT pin and VSS pin (CL), the capacitor for stabilizing the input between the VIN pin and VSS pin (CIN), and the capacitor for soft-start between the SSC pin and VSS pin, the distance from the capacitors to these pins should be as short as possible. • Note that generally the output voltage may increase when a series regulator is used at low load current (1.0 mA or less). • Note that generally the output voltage may increase due to the leakage current from an output driver when a series regulator is used at high temperature. • Generally a series regulator may cause oscillation, depending on the selection of external parts. The following conditions are recommended for the S-1137 Series. However, be sure to perform sufficient evaluation under the actual usage conditions for selection, including evaluation of temperature characteristics. Refer to “(8) Example of Equivalent Series Resistance vs. Output Current Characteristics (Ta = 25°C)” in “ Reference Data” for the equivalent series resistance (RESR) of the output capacitor. Input capacitor (CIN) : 1.0 μF or more Output capacitor (CL) : 1.0 μF or more Capacitor for soft-start (CSS) : 0.22 nF to 22 nF • The voltage regulator may oscillate when the impedance of the power supply is high and the input capacitance is small or an input capacitor is not connected. • If the output capacitance is small, power supply’s fluctuation and the characteristics of load fluctuation become worse. Sufficiently evaluate the output voltage’s fluctuation with the actual device. • Although the S-1137 Series has a soft-start circuit, overshoot may occur in the output voltage momentarily when the capacitance of the capacitor for soft-start (CSS) is small. Perform sufficient evaluation with actual devices. • The application conditions for the input voltage, output voltage, and load current should not exceed the package power dissipation. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • In determining the output current, attention should be paid to the output current value specified in Table 10 in “ Electrical Characteristics” and footnote *5 of the table. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 22 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series  Characteristics (Typical Data) (1) Output Voltage vs. Output Current (When Load Current Increases) (Ta = 25°C) VOUT [V] VOUT = 3.5 V 4.0 3.5 3.0 VIN = 3.8 V 2.5 4.0 V 2.0 4.5 V 1.5 5.5 V 1.0 0.5 0 0 100 200 300 400 500 600 700 IOUT [mA] VOUT = 2.5 V 3.0 2.5 VOUT [V] VOUT [V] VOUT = 1.2 V 1.6 1.4 1.2 1.0 VIN = 1.5 V 0.8 1.7 V 2.2 V 0.6 3.2 V 0.4 5.5 V 0.2 0 0 100 200 300 400 500 600 700 IOUT [mA] VIN = 2.8 V 3.0 V 3.5 V 4.5 V 5.5 V 2.0 1.5 1.0 0.5 0 0 Remark 100 200 300 400 500 600 700 IOUT [mA] In determining the output current, attention should be paid to the following. 1. The minimum output current value and footnote *5 in Table 10 in the “ Electrical Characteristics” 2. The package power dissipation (2) Output Voltage vs. Input Voltage (Ta = 25°C) VOUT = 2.5 V 3.0 IOUT = 1 mA IOUT = 30 mA IOUT = 50 mA IOUT = 100 mA 2.0 1.5 IOUT = 1 mA IOUT = 30 mA IOUT = 50 mA IOUT = 100 mA 1.0 0.5 0 1.0 2.0 VOUT [V] VOUT = 3.5 V 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 0 VOUT [V] 2.5 VOUT [V] VOUT = 1.2 V 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 0 3.0 4.0 VIN [V] 5.0 6.0 5.0 6.0 0 1.0 2.0 3.0 4.0 VIN [V] 5.0 6.0 IOUT = 1 mA IOUT = 30 mA IOUT = 50 mA IOUT = 100 mA 1.0 2.0 3.0 4.0 VIN [V] 23 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series (3) Dropout Voltage vs. Output Current 150 200 IOUT [mA] 250 300 250 300 Ta = 85°C Ta = 25°C Ta = −40°C Vdrop [V] VOUT = 3.5 V 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0 0 100 50 50 100 150 200 IOUT [mA] Vdrop [V] (4) Dropout Voltage vs. Set Output Voltage 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 IOUT = 300 mA 150 mA 100 mA 50 mA 30 mA 10 mA 1 mA 0.1 mA 1.0 24 1.5 2.0 2.5 VOUT(S) [V] VOUT = 2.5 V 0.20 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0 0 Vdrop [V] Ta = 85°C Ta = 25°C Ta = −40°C Vdrop [V] VOUT = 1.2 V 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 0 3.0 3.5 Ta = 85°C Ta = 25°C Ta = −40°C 50 100 150 200 IOUT [mA] 250 300 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series (5) Output Voltage vs. Ambient Temperature VOUT = 1.2 V 1.30 VOUT [V] VOUT [V] 1.25 VOUT = 2.5 V 2.70 2.65 2.60 2.55 2.50 2.45 2.40 2.35 2.30 −40 −25 1.20 1.15 1.10 −40 −25 0 25 Ta [°C] 50 75 85 50 75 85 0 25 Ta [°C] 75 85 50 VOUT = 3.5 V 3.8 VOUT [V] 3.7 3.6 3.5 3.4 3.3 3.2 −40 −25 0 25 Ta [°C] (6) Current Consumption vs. Input Voltage 1 2 3 VIN [V] 25°C 4 Ta = 85°C 5 6 1 2 −40°C 25°C 4 5 3 VIN [V] 6 Ta = 85°C ISS1 [μA] VOUT = 3.5 V 70 60 50 40 30 20 10 0 0 −40°C VOUT = 2.5 V 70 60 50 40 30 20 10 0 0 ISS1 [μA] Ta = 85°C ISS1 [μA] VOUT = 1.2 V 70 60 50 40 30 20 10 0 0 25°C −40°C 1 2 3 VIN [V] 4 5 6 25 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series (7) Ripple Rejection (Ta = 25°C) VOUT = 1.2 V VOUT = 2.5 V 100 IOUT = 1 mA 80 60 40 IOUT = 30 mA IOUT = 50 mA IOUT = 100 mA 20 0 10 100 1k 10k 100k Frequency [Hz] 1M VOUT = 3.5 V Ripple Rejection [dB] VIN = 4.5 V, CL = 1.0 μF 100 IOUT = 1 mA IOUT = 30 mA 80 60 40 IOUT = 50 mA IOUT = 100 mA 20 0 10 26 100 1k 10k 100k Frequency [Hz] VIN = 3.5 V, CL = 1.0 μF Ripple Rejection [dB] Ripple Rejection [dB] VIN = 2.2 V, CL = 1.0 μF 1M 100 IOUT = 1 mA IOUT = 30 mA 80 60 40 IOUT = 50 mA IOUT = 100 mA 20 0 10 100 1k 10k 100k Frequency [Hz] 1M 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series  Reference Data (1) Transient Response Characteristics when Input (Ta = 25°C) 50 100 150 200 250 300 350 t [μs] 2.74 2.70 2.66 VIN 2.62 2.58 2.54 VOUT 2.50 2.46 2.42 −100 −50 0 5.0 4.5 4.0 3.5 3.0 2.5 2.0 1.5 1.0 VIN [V] 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 VOUT [V] 1.32 1.30 1.28 VIN 1.26 1.24 1.22 VOUT 1.20 1.18 1.16 −100 −50 0 VOUT = 2.5 V IOUT = 100 mA, tr = tf = 5.0 μs, CL = 1.0 μF, CSS = 1.0 nF VIN [V] VOUT [V] VOUT = 1.2 V IOUT = 100 mA, tr = tf = 5.0 μs, CL = 1.0 μF, CSS = 1.0 nF 50 100 150 200 250 300 350 t [μs] 3.74 3.70 3.66 VIN 3.62 3.58 3.54 VOUT 3.50 3.46 3.42 −100 −50 0 6.0 5.5 5.0 4.5 4.0 3.5 3.0 2.5 2.0 VIN [V] VOUT [V] VOUT = 3.5 V IOUT = 100 mA, tr = tf = 5.0 μs, CL = 1.0 μF, CSS = 1.0 nF 50 100 150 200 250 300 350 t [μs] (2) Transient Response Characteristics of Load (Ta = 25°C) 150 1.25 1.20 2.65 2.60 0 VOUT −50 1.15 1.10 −100 −50 0 100 50 VOUT [V] VOUT [V] IOUT 1.30 150 2.70 IOUT [mA] 1.40 1.35 VOUT = 2.5 V VIN = 3.5 V, CIN = CL = 1.0 μF, CSS = 1.0 nF, IOUT = 50 mA ↔ 100 mA 2.55 2.50 50 0 VOUT −100 2.45 −150 2.40 −100 −50 0 50 100 150 200 250 300 350 t [μs] 100 IOUT −50 IOUT [mA] VOUT = 1.2 V VIN = 2.2 V, CIN = CL = 1.0 μF, CSS = 1.0 nF, IOUT = 50 mA ↔ 100 mA −100 −150 50 100 150 200 250 300 350 t [μs] VOUT = 3.5 V VIN = 4.5 V, CIN = CL = 1.0 μF, CSS = 1.0 nF, IOUT = 50 mA ↔ 100 mA 150 3.70 100 IOUT 50 3.60 3.55 3.50 0 VOUT −50 −100 3.45 3.40 −100 −50 0 IOUT [mA] VOUT [V] 3.65 −150 50 100 150 200 250 300 350 t [μs] 27 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series (3) Transient Response Characteristics of ON / OFF Pin (Ta = 25°C) VOUT = 2.5 V VIN = 3.5 V, tr = 1.0 μs, CIN = CL = 1.0 μF, CSS = 1.0 nF, IOUT = 100 mA 3 6 2.0 2 5 1.6 1 0 1.2 VOUT 0.8 −1 0.4 0 −0.5 0 0.5 1.0 t [ms] 1.5 4 VON / OFF 4 VOUT [V] VON / OFF 6 2 0 3 2 −2 1 −3 0 −4 −0.5 2.0 −2 VOUT VON / OFF [V] 2.4 VON / OFF [V] VOUT [V] VOUT = 1.2 V VIN = 2.2 V, tr = 1.0 μs, CIN = CL = 1.0 μF, CSS = 1.0 nF, IOUT = 100 mA −6 0 0.5 1.0 t [ms] 1.5 2.0 VOUT = 3.5 V VIN = 4.5 V, tr = 1.0 μs, CIN = CL = 1.0 μF, CSS = 1.0 nF, IOUT = 100 mA VOUT [V] 5 VON / OFF 4 4 2 3 VOUT 0 2 −2 1 −4 −6 0 −0.5 VON / OFF [V] 6 6 0 0.5 1.0 t [ms] 1.5 2.0 (4) Soft-start Time vs. Ambient Temperature Characteristics 28 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 VIN = VOUT + 1.0 V, VON / OFF = 0 V → VOUT + 1.0 V, CIN = CL = 1.0 μF 100.0 tSS [ms] tSS [ms] VIN = VOUT + 1.0 V, VON / OFF = 0 V → VOUT + 1.0 V, CIN = CL = 1.0 μF, CSS = 1.0 nF (5) Soft-start time vs. Capacitor for Soft-start Characteristics (Ta = 25°C) VOUT = 1.2 V 2.5 V 3.5 V 40 25 VOUT = 1.2 V 2.5 V 3.5 V 10.0 1.0 0.1 0 25 Ta [C] 50 75 85 0.1 10.0 1.0 CSS [nF] 100.0 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series (6) Rush Current Characteristics (Ta = 25°C) 200 2.0 160 1.5 120 VOUT 80 1.0 0.5 0 2.5 40 IRUSH −0.2 VON/OFF, VOUT [V] VON/OFF IRUSH [mA] VON/OFF, VOUT [V] 2.5 VOUT = 1.2 V, VIN = 2.2 V, IOUT = 0 mA, CL = 1.0 μF, CSS = 1.0 nF 0.2 0.4 t [ms] 0.6 0.8 2.0 160 1.5 120 1.0 80 0.5 0 0 0 200 VON/OFF 1.0 40 VOUT IRUSH −0.2 0 0.2 0.4 t [ms] IRUSH [mA] VOUT = 1.2 V, VIN = 2.2 V, IOUT = 0 mA, CL = 1.0 μF, CSS = 0.22 nF 0 0.6 0.8 1.0 VOUT = 1.2 V, VIN = 2.2 V, IOUT = 0 mA, CL = 1.0 μF, CSS = 22.0 nF 100 VON/OFF 2.0 80 1.5 60 1.0 40 0.5 −5 20 IRUSH 0 0 5 10 t [ms] 15 20 25 VOUT = 3.5 V, VIN = 4.5 V, IOUT = 0 mA, CL = 1.0 μF, CSS = 0.22 nF VOUT = 3.5 V, VIN = 4.5 V, IOUT = 0 mA, CL = 1.0 μF, CSS = 1.0 nF 200 160 VOUT 3 120 2 80 IRUSH 1 0 −0.2 40 0.2 0.4 t [ms] 0.6 0.8 1.0 200 VON/OFF 4 160 120 3 2 80 VOUT 1 0 0 0 VON/OFF, VOUT [V] VON/OFF 4 5 IRUSH [mA] VON/OFF, VOUT [V] 5 40 IRUSH −0.2 IRUSH [mA] 0 VOUT IRUSH [mA] VON/OFF, VOUT [V] 2.5 0 0 0.2 0.4 t [ms] 0.6 0.8 1.0 VOUT = 3.5 V, VIN = 4.5 V, IOUT = 0 mA, CL = 1.0 μF, CSS = 22.0 nF 100 VON/OFF 4 VOUT 80 3 60 2 40 20 1 IRUSH 0 −5 IRUSH [mA] VON/OFF, VOUT [V] 5 0 0 5 10 t [ms] 15 20 25 29 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series (7) Output Capacitance vs. Characteristics of Discharge Time (Ta = 25°C) S-1137 Series A / B type (with discharge shunt function) VIN = VOUT + 1.0 V, IOUT = no load VON / OFF = VOUT + 1.0 V → VSS, tf = 1 μs 1 μs 2.5 tDSC [ms] 2.0 VON / OFF VOUT(s) = 1.2 V 2.5 V 3.5 V 1.5 1.0 VSS 0.5 tDSC VOUT 0 0 2 4 6 CL [μF] 8 10 12 VOUT × 10% VIN = VOUT + 1.0 V VON / OFF = VOUT + 1.0 V → VSS Figure 22 Measurement Condition of Discharge Time (8) Example of Equivalent Series Resistance vs. Output Current Characteristics (Ta = 25°C) CL : Murata Manufacturing Co., Ltd. GRM155B31A105K (1.0 μF) CSS : Murata Manufacturing Co., Ltd. GRM40B102K (1.0 nF) CIN = CL = 1.0 μF CSS = 1.0 nF 100 VIN RESR [Ω] VOUT CIN Stable ON / OFF 0 0.1 300 IOUT [mA] 30 S-1137 Series VSS CL SSC CSS RESR 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series  Marking Specifications SOT-89-5 Top view 4 1 (1) to (3) (4) to (6) : Product code (Refer to Product name vs. Product code) : Lot number (4) (5) (6) 5 (1) (2) (3) 1. 2 3 Product name vs. Product code (a) S-1137 Series A type Product Name (b) S-1137 Series B type Product code (1) (2) (3) V H C V H D V H E V H F V H G V H H V H I V H J V H K V H L V H M V H N V H O V H P V H Q V H R V H S V H T V H U V H V V H W V H X V H Y V H Z V H 2 V H 3 Product Name Product code (1) (2) (3) V I C V I D V I E V I F V I G V I H V I I V I J V I K V I L V I M V I N V I O V I P V I Q V I R V I S V I T V I U V I V V I W V I X V I Y V I Z V I 2 V I 3 S-1137A12-U5T1x S-1137B12-U5T1x S-1137A13-U5T1x S-1137B13-U5T1x S-1137A14-U5T1x S-1137B14-U5T1x S-1137A15-U5T1x S-1137B15-U5T1x S-1137A16-U5T1x S-1137B16-U5T1x S-1137A17-U5T1x S-1137B17-U5T1x S-1137A18-U5T1x S-1137B18-U5T1x S-1137A1J-U5T1x S-1137B1J-U5T1x S-1137A19-U5T1x S-1137B19-U5T1x S-1137A20-U5T1x S-1137B20-U5T1x S-1137A21-U5T1x S-1137B21-U5T1x S-1137A22-U5T1x S-1137B22-U5T1x S-1137A23-U5T1x S-1137B23-U5T1x S-1137A24-U5T1x S-1137B24-U5T1x S-1137A25-U5T1x S-1137B25-U5T1x S-1137A26-U5T1x S-1137B26-U5T1x S-1137A27-U5T1x S-1137B27-U5T1x S-1137A28-U5T1x S-1137B28-U5T1x S-1137A2J-U5T1x S-1137B2J-U5T1x S-1137A29-U5T1x S-1137B29-U5T1x S-1137A30-U5T1x S-1137B30-U5T1x S-1137A31-U5T1x S-1137B31-U5T1x S-1137A32-U5T1x S-1137B32-U5T1x S-1137A33-U5T1x S-1137B33-U5T1x S-1137A34-U5T1x S-1137B34-U5T1x S-1137A35-U5T1x S-1137B35-U5T1x Remark 1. x: G or U 2. Please select products of environmental code = U for Sn 100%, halogen-free products. 31 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series (c) S-1137 Series C type Product Name (d) S-1137 Series D type (1) V V V V V V V V V V V V V V V V V V V V V V V V V V Product code (2) (3) J C J D J E J F J G J H J I J J J K J L J M J N J O J P J Q J R J S J T J U J V J W J X J Y J Z J 2 J 3 Product Name (1) V V V V V V V V V V V V V V V V V V V V V V V V V V Product code (2) (3) K C K D K E K F K G K H K I K J K K K L K M K N K O K P K Q K R K S K T K U K V K W K X K Y K Z K 2 K 3 S-1137C12-U5T1x S-1137D12-U5T1x S-1137C13-U5T1x S-1137D13-U5T1x S-1137C14-U5T1x S-1137D14-U5T1x S-1137C15-U5T1x S-1137D15-U5T1x S-1137C16-U5T1x S-1137D16-U5T1x S-1137C17-U5T1x S-1137D17-U5T1x S-1137C18-U5T1x S-1137D18-U5T1x S-1137C1J-U5T1x S-1137D1J-U5T1x S-1137C19-U5T1x S-1137D19-U5T1x S-1137C20-U5T1x S-1137D20-U5T1x S-1137C21-U5T1x S-1137D21-U5T1x S-1137C22-U5T1x S-1137D22-U5T1x S-1137C23-U5T1x S-1137D23-U5T1x S-1137C24-U5T1x S-1137D24-U5T1x S-1137C25-U5T1x S-1137D25-U5T1x S-1137C26-U5T1x S-1137D26-U5T1x S-1137C27-U5T1x S-1137D27-U5T1x S-1137C28-U5T1x S-1137D28-U5T1x S-1137C2J-U5T1x S-1137D2J-U5T1x S-1137C29-U5T1x S-1137D29-U5T1x S-1137C30-U5T1x S-1137D30-U5T1x S-1137C31-U5T1x S-1137D31-U5T1x S-1137C32-U5T1x S-1137D32-U5T1x S-1137C33-U5T1x S-1137D33-U5T1x S-1137C34-U5T1x S-1137D34-U5T1x S-1137C35-U5T1x S-1137D35-U5T1x Remark 1. x: G or U 2. Please select products of environmental code = U for Sn 100%, halogen-free products. 32 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series 2. SOT-23-5 Top view 5 (1) to (3) (4) 4 : Product code (Refer to Product name vs. Product code) : Lot number (1) (2) (3) (4) 1 2 3 Product name vs. Product code (a) S-1137 Series A type Product Name (b) S-1137 Series B type (1) V V V V V V V V V V V V V V V V V V V V V V V V V V Product code (2) (3) H C H D H E H F H G H H H I H J H K H L H M H N H O H P H Q H R H S H T H U H V H W H X H Y H Z H 2 H 3 Product Name (1) V V V V V V V V V V V V V V V V V V V V V V V V V V Product code (2) (3) I C I D I E I F I G I H I I I J I K I L I M I N I O I P I Q I R I S I T I U I V I W I X I Y I Z I 2 I 3 S-1137A12-M5T1y S-1137B12-M5T1y S-1137A13-M5T1y S-1137B13-M5T1y S-1137A14-M5T1y S-1137B14-M5T1y S-1137A15-M5T1y S-1137B15-M5T1y S-1137A16-M5T1y S-1137B16-M5T1y S-1137A17-M5T1y S-1137B17-M5T1y S-1137A18-M5T1y S-1137B18-M5T1y S-1137A1J-M5T1y S-1137B1J-M5T1y S-1137A19-M5T1y S-1137B19-M5T1y S-1137A20-M5T1y S-1137B20-M5T1y S-1137A21-M5T1y S-1137B21-M5T1y S-1137A22-M5T1y S-1137B22-M5T1y S-1137A23-M5T1y S-1137B23-M5T1y S-1137A24-M5T1y S-1137B24-M5T1y S-1137A25-M5T1y S-1137B25-M5T1y S-1137A26-M5T1y S-1137B26-M5T1y S-1137A27-M5T1y S-1137B27-M5T1y S-1137A28-M5T1y S-1137B28-M5T1y S-1137A2J-M5T1y S-1137B2J-M5T1y S-1137A29-M5T1y S-1137B29-M5T1y S-1137A30-M5T1y S-1137B30-M5T1y S-1137A31-M5T1y S-1137B31-M5T1y S-1137A32-M5T1y S-1137B32-M5T1y S-1137A33-M5T1y S-1137B33-M5T1y S-1137A34-M5T1y S-1137B34-M5T1y S-1137A35-M5T1y S-1137B35-M5T1y Remark 1. y: S or U 2. Please select products of environmental code = U for Sn 100%, halogen-free products. 33 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series (c) S-1137 Series C type Product Name (d) S-1137 Series D type (1) V V V V V V V V V V V V V V V V V V V V V V V V V V Product code (2) (3) J C J D J E J F J G J H J I J J J K J L J M J N J O J P J Q J R J S J T J U J V J W J X J Y J Z J 2 J 3 Product Name (1) V V V V V V V V V V V V V V V V V V V V V V V V V V Product code (2) (3) K C K D K E K F K G K H K I K J K K K L K M K N K O K P K Q K R K S K T K U K V K W K X K Y K Z K 2 K 3 S-1137C12-M5T1y S-1137D12-M5T1y S-1137C13-M5T1y S-1137D13-M5T1y S-1137C14-M5T1y S-1137D14-M5T1y S-1137C15-M5T1y S-1137D15-M5T1y S-1137C16-M5T1y S-1137D16-M5T1y S-1137C17-M5T1y S-1137D17-M5T1y S-1137C18-M5T1y S-1137D18-M5T1y S-1137C1J-M5T1y S-1137D1J-M5T1y S-1137C19-M5T1y S-1137D19-M5T1y S-1137C20-M5T1y S-1137D20-M5T1y S-1137C21-M5T1y S-1137D21-M5T1y S-1137C22-M5T1y S-1137D22-M5T1y S-1137C23-M5T1y S-1137D23-M5T1y S-1137C24-M5T1y S-1137D24-M5T1y S-1137C25-M5T1y S-1137D25-M5T1y S-1137C26-M5T1y S-1137D26-M5T1y S-1137C27-M5T1y S-1137D27-M5T1y S-1137C28-M5T1y S-1137D28-M5T1y S-1137C2J-M5T1y S-1137D2J-M5T1y S-1137C29-M5T1y S-1137D29-M5T1y S-1137C30-M5T1y S-1137D30-M5T1y S-1137C31-M5T1y S-1137D31-M5T1y S-1137C32-M5T1y S-1137D32-M5T1y S-1137C33-M5T1y S-1137D33-M5T1y S-1137C34-M5T1y S-1137D34-M5T1y S-1137C35-M5T1y S-1137D35-M5T1y Remark 1. y: S or U 2. Please select products of environmental code = U for Sn 100%, halogen-free products. 34 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series 3. SNT-6A(H) Top view 6 5 (1) to (3) (4) to (6) 4 : Product code (Refer to Product name vs. Product code) : Lot number (1) (2) (3) (4) (5) (6) 1 2 3 Product name vs. Product code (a) S-1137 Series A type Product Name S-1137A12-I6T2U S-1137A13-I6T2U S-1137A14-I6T2U S-1137A15-I6T2U S-1137A16-I6T2U S-1137A17-I6T2U S-1137A18-I6T2U S-1137A1J-I6T2U S-1137A19-I6T2U S-1137A20-I6T2U S-1137A21-I6T2U S-1137A22-I6T2U S-1137A23-I6T2U S-1137A24-I6T2U S-1137A25-I6T2U S-1137A26-I6T2U S-1137A27-I6T2U S-1137A28-I6T2U S-1137A2J-I6T2U S-1137A29-I6T2U S-1137A30-I6T2U S-1137A31-I6T2U S-1137A32-I6T2U S-1137A33-I6T2U S-1137A34-I6T2U S-1137A35-I6T2U (b) S-1137 Series B type (1) V V V V V V V V V V V V V V V V V V V V V V V V V V Product code (2) (3) H C H D H E H F H G H H H I H J H K H L H M H N H O H P H Q H R H S H T H U H V H W H X H Y H Z H 2 H 3 Product Name S-1137B12-I6T2U S-1137B13-I6T2U S-1137B14-I6T2U S-1137B15-I6T2U S-1137B16-I6T2U S-1137B17-I6T2U S-1137B18-I6T2U S-1137B1J-I6T2U S-1137B19-I6T2U S-1137B20-I6T2U S-1137B21-I6T2U S-1137B22-I6T2U S-1137B23-I6T2U S-1137B24-I6T2U S-1137B25-I6T2U S-1137B26-I6T2U S-1137B27-I6T2U S-1137B28-I6T2U S-1137B2J-I6T2U S-1137B29-I6T2U S-1137B30-I6T2U S-1137B31-I6T2U S-1137B32-I6T2U S-1137B33-I6T2U S-1137B34-I6T2U S-1137B35-I6T2U (1) V V V V V V V V V V V V V V V V V V V V V V V V V V Product code (2) (3) I C I D I E I F I G I H I I I J I K I L I M I N I O I P I Q I R I S I T I U I V I W I X I Y I Z I 2 I 3 35 5.5 V INPUT, 300 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.2.2_00 S-1137 Series (c) S-1137 Series C type Product Name S-1137C12-I6T2U S-1137C13-I6T2U S-1137C14-I6T2U S-1137C15-I6T2U S-1137C16-I6T2U S-1137C17-I6T2U S-1137C18-I6T2U S-1137C1J-I6T2U S-1137C19-I6T2U S-1137C20-I6T2U S-1137C21-I6T2U S-1137C22-I6T2U S-1137C23-I6T2U S-1137C24-I6T2U S-1137C25-I6T2U S-1137C26-I6T2U S-1137C27-I6T2U S-1137C28-I6T2U S-1137C2J-I6T2U S-1137C29-I6T2U S-1137C30-I6T2U S-1137C31-I6T2U S-1137C32-I6T2U S-1137C33-I6T2U S-1137C34-I6T2U S-1137C35-I6T2U 36 (d) S-1137 Series D type (1) V V V V V V V V V V V V V V V V V V V V V V V V V V Product code (2) (3) J C J D J E J F J G J H J I J J J K J L J M J N J O J P J Q J R J S J T J U J V J W J X J Y J Z J 2 J 3 Product Name S-1137D12-I6T2U S-1137D13-I6T2U S-1137D14-I6T2U S-1137D15-I6T2U S-1137D16-I6T2U S-1137D17-I6T2U S-1137D18-I6T2U S-1137D1J-I6T2U S-1137D19-I6T2U S-1137D20-I6T2U S-1137D21-I6T2U S-1137D22-I6T2U S-1137D23-I6T2U S-1137D24-I6T2U S-1137D25-I6T2U S-1137D26-I6T2U S-1137D27-I6T2U S-1137D28-I6T2U S-1137D2J-I6T2U S-1137D29-I6T2U S-1137D30-I6T2U S-1137D31-I6T2U S-1137D32-I6T2U S-1137D33-I6T2U S-1137D34-I6T2U S-1137D35-I6T2U (1) V V V V V V V V V V V V V V V V V V V V V V V V V V Product code (2) (3) K C K D K E K F K G K H K I K J K K K L K M K N K O K P K Q K R K S K T K U K V K W K X K Y K Z K 2 K 3 4.5±0.1 1.5±0.1 1.6±0.2 5 4 0.3 45° 1 2 3 1.5±0.1 1.5±0.1 0.4±0.05 0.4±0.1 0.4±0.1 0.45±0.1 No. UP005-A-P-SD-2.0 TITLE SOT895-A-PKG Dimensions No. UP005-A-P-SD-2.0 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches : 40.0±0.2) ø1.5 +0.1 -0 2.0±0.05 +0.1 ø1.5 -0 0.3±0.05 8.0±0.1 2.0±0.1 4.75±0.1 3 2 1 4 5 Feed direction No. UP005-A-C-SD-2.0 TITLE SOT895-A-Carrier Tape UP005-A-C-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. 16.5max. 13.0±0.3 Enlarged drawing in the central part (60°) (60°) No. UP005-A-R-SD-1.1 TITLE SOT895-A-Reel No. UP005-A-R-SD-1.1 ANGLE UNIT QTY. mm ABLIC Inc. 1,000 2.9±0.2 1.9±0.2 4 5 1 2 +0.1 0.16 -0.06 3 0.95±0.1 0.4±0.1 No. MP005-A-P-SD-1.3 TITLE SOT235-A-PKG Dimensions No. MP005-A-P-SD-1.3 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 ø1.5 -0 +0.2 ø1.0 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 Feed direction No. MP005-A-C-SD-2.1 TITLE SOT235-A-Carrier Tape No. MP005-A-C-SD-2.1 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP005-A-R-SD-1.1 SOT235-A-Reel TITLE No. MP005-A-R-SD-1.1 ANGLE QTY. UNIT mm ABLIC Inc. 3,000 1.57±0.03 6 5 1 2 4 +0.05 0.08 -0.02 3 0.5 0.48±0.02 0.2±0.05 No. PI006-A-P-SD-2.1 TITLE SNT-6A(H)-A-PKG Dimensions No. PI006-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 4.0±0.1 2.0±0.05 0.25±0.05 +0.1 1.85±0.05 ø0.5 -0 4.0±0.1 0.65±0.05 3 2 1 4 5 6 Feed direction No. PI006-A-C-SD-2.0 TITLE SNT-6A(H)-A-Carrier Tape No. PI006-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PI006-A-R-SD-1.0 TITLE SNT-6A(H)-A-Reel No. PI006-A-R-SD-1.0 ANGLE UNIT QTY. mm ABLIC Inc. 5,000 0.52 1.36 2 0.52 0.2 0.3 1. 2. 1 (0.25 mm min. / 0.30 mm typ.) (1.30 mm ~ 1.40 mm) 1. 2. 3. 4. 0.03 mm SNT 1. Pay attention to the land pattern width (0.25 mm min. / 0.30 mm typ.). 2. Do not widen the land pattern to the center of the package (1.30 mm to 1.40 mm). Caution 1. Do not do silkscreen printing and solder printing under the mold resin of the package. 2. The thickness of the solder resist on the wire pattern under the package should be 0.03 mm or less from the land pattern surface. 3. Match the mask aperture size and aperture position with the land pattern. 4. Refer to "SNT Package User's Guide" for details. 1. 2. (0.25 mm min. / 0.30 mm typ.) (1.30 mm ~ 1.40 mm) No. PI006-A-L-SD-4.1 TITLE SNT-6A(H)-A -Land Recommendation No. PI006-A-L-SD-4.1 ANGLE UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-1137C35-M5T1U
物料型号:S-1137系列
器件简介: - S-1137系列是一款使用CMOS技术开发的正电压调节器集成电路。 - 它具有低 dropout 电压、高精度输出电压和软启动功能(300 mA输出电流)。 - 该器件通常消耗电流为45 μA,具有过流保护电路和ON/OFF电路,以延长电池寿命。
引脚分配: - SOT-89-5、SOT-23-5和SNT-6A(H)封装的引脚分配略有不同,但主要包括: - VOUT:输出电压引脚 - VSS:地引脚 - SSC:软启动控制引脚 - ON/OFF:开关控制引脚 - VIN:输入电压引脚
参数特性: - 输出电压:1.2 V至3.5 V,以0.05 V步进选择。 - 输入电压:1.7 V至5.5 V。 - 输出电压精度:±1.0%(1.2 V至1.45 V输出产品:±15 mV)。 - Dropout电压:典型值210 mV(2.8 V输出产品,IOUT = 300 mA)。 - 电流消耗:在操作期间典型值为45 μA,最大值为65 μA;在关闭电源时典型值为0.1 μA,最大值为1.0 μA。 - 输出电流:可达300 mA。
功能详解: - 内置软启动电路,可调整输出电压上升速度。 - 过流保护电路,限制输出晶体管的负载电流。 - ON/OFF电路,确保更长的电池寿命。 - 可选择的放电分流功能和下拉功能。
应用信息: - 适用于电池供电设备的恒压电源。 - 适用于手机、便携设备、数字相机、电视、DVD录像机的恒压电源。
封装信息: - 提供SOT-89-5、SOT-23-5和SNT-6A(H)三种封装类型。
S-1137C35-M5T1U 价格&库存
很抱歉,暂时无法提供与“S-1137C35-M5T1U”相匹配的价格&库存,您可以联系我们找货
