S-816A27AMC-BACT2U
S-816A27AMC-BACT2U
    ABLIC(艾普凌科)
    SOT23-5
    IC REG LINEAR 2.7V 1A SOT23-5
S-816A27AMC-BACT2U 数据手册
S-816 Series www.ablic.com www.ablicinc.com EXTERNAL TRANSISTOR TYPE CMOS VOLTAGE REGULATOR © ABLIC Inc., 1996-2014 Rev.6.1_02 The S-816 Series, developed using the CMOS technology, is an external transistor type positive voltage regulator which incorporates an overcurrent protection circuit and an ON/OFF circuit. A low drop-out type regulator with an output current ranging from several hundreds of mA to 1 A can be configured with the PNP transistor driven by this IC. Despite the features of the S-816 Series, which is low current consumption, the improvement in its transient response characteristics of the IC with a newly deviced phase compensation circuit made it possible to employ the products of the S-816 Series even in applications where heavy input variation or load variation is experienced. The S-816 Series regulator serves as an ideal power supply unit for portable devices when coupled with the small SOT-23-5 package, providing numerous outstanding features, including low current consumption. Since the S-816 Series can accommodate an input voltage of up to 16 V, it is also suitable when operating via an AC adapter.  Features  Output voltage:  Input voltage:  Output voltage accuracy:  Current consumption: 2.5 V to 6.0 V, selectable in 0.1 V step 16 V max.  2.0% During operation: 30 A typ., 40 A max. During power-off: 1 A max.  Built-in overcurrent (base current) protection circuit  Built-in ON/OFF circuit: Ensures long battery life.  Built-in current source (10 A): No need for a base-emitter resistance.  Operation temperature range: Ta =40C to 85C  Lead-free, Sn 100%, halogen-free*1 *1. Refer to “ Product Name Structure” for details.  Applications  Power supply for on-board such as battery device for portable telephone, electronic notebook, PDA  Constant voltage power supply for camera, video equipment and portable communication equipment  Power supply for CPU  Post-regulator for switching regulator  Main regulator in multiple-power supply system  Package  SOT-23-5 1 EXTERNAL TRANSISTOR TYPE CMOS VOLTAGE REGULATOR S-816 Series Rev.6.1_02  Block Diagram VIN EXT VOUT Current Source Pull-Up Reisitance Overcurrent Protection Circuit      Vref ON/OFF Error Amplifier  Sink Driver VSS Remark 1. To ensure you power cutoff of the external transistor when the device is powered down, the EXT output is pulled up to VIN by a pull-up resistance (approx. 0.5 M) inside the IC. 2. The diode inside the IC is a parasitic diode. Figure 1 2 EXTERNAL TRANSISTOR TYPE CMOS VOLTAGE REGULATOR S-816 Series Rev.6.1_02  Product Name Structure 1. Product Name S-816A xx A MC - xxx T2 x Environmental code U: Lead-free (Sn 100%), halogen-free G: Lead-free (for details, please contact our sales office) IC direction in tape specifications*1 Product code Package code MC : SOT-23-5 Output voltage 25 to 60 (e.g., when the output voltage is 2.5 V, it is expressed as 25.) *1. Refer to the tape drawing. 2. Package Package Name SOT-23-5 Package MP005-A-P-SD Drawing Code Tape MP005-A-C-SD Reel MP005-A-R-SD 3. Product Name List Output Voltage (V) 2.5 V2.0% 2.6 V2.0% 2.7 V2.0% 2.8 V2.0% 2.9 V2.0% 3.0 V2.0% 3.1 V2.0% 3.2 V2.0% 3.3 V2.0% 3.4 V2.0% 3.5 V2.0% 3.6 V2.0% 3.7 V2.0% 3.8 V2.0% 3.9 V2.0% 4.0 V2.0% 4.1 V2.0% 4.2 V2.0% Product Name S-816A25AMC-BAAT2x S-816A26AMC-BABT2x S-816A27AMC-BACT2x S-816A28AMC-BADT2x S-816A29AMC-BAET2x S-816A30AMC-BAFT2x S-816A31AMC-BAGT2x S-816A32AMC-BAHT2x S-816A33AMC-BAIT2x S-816A34AMC-BAJT2x S-816A35AMC-BAKT2x S-816A36AMC-BALT2x S-816A37AMC-BAMT2x S-816A38AMC-BANT2x S-816A39AMC-BAOT2x S-816A40AMC-BAPT2x S-816A41AMC-BAQT2x S-816A42AMC-BART2x Table 1 Output Voltage (V) 4.3 V2.0% 4.4 V2.0% 4.5 V2.0% 4.6 V2.0% 4.7 V2.0% 4.8 V2.0% 4.9 V2.0% 5.0 V2.0% 5.1 V2.0% 5.2 V2.0% 5.3 V2.0% 5.4 V2.0% 5.5 V2.0% 5.6 V2.0% 5.7 V2.0% 5.8 V2.0% 5.9 V2.0% 6.0 V2.0% Product Name S-816A43AMC-BAST2x S-816A44AMC-BATT2x S-816A45AMC-BAUT2x S-816A46AMC-BAVT2x S-816A47AMC-BAWT2x S-816A48AMC-BAXT2x S-816A49AMC-BAYT2x S-816A50AMC-BAZT2x S-816A51AMC-BBAT2x S-816A52AMC-BBBT2x S-816A53AMC-BBCT2x S-816A54AMC-BBDT2x S-816A55AMC-BBET2x S-816A56AMC-BBFT2x S-816A57AMC-BBGT2x S-816A58AMC-BBHT2x S-816A59AMC-BBIT2x S-816A60AMC-BBJT2x Remark 1. x: G or U 2. Please select products of environmental code = U for Sn 100%, halogen-free products. 3 EXTERNAL TRANSISTOR TYPE CMOS VOLTAGE REGULATOR S-816 Series Rev.6.1_02  Pin Configuration SOT-23-5 Top view Table 2 5 1 4 2 Figure 2 4 3 Pin No. 1 2 3 4 5 Symbol EXT VSS ON/OFF VIN VOUT Description Output Pin for Base-Current Control GND Pin ON/OFF Pin (Active "H") IC Power Supply Pin Output Voltage Monitoring Pin EXTERNAL TRANSISTOR TYPE CMOS VOLTAGE REGULATOR S-816 Series Rev.6.1_02  Absolute Maximum Ratings Table 3 Item VIN Pin Voltage VOUT Pin Voltage ON/OFF Pin Voltage EXT Pin Voltage EXT Pin Current Power Dissipation Symbol VIN VOUT VON/OFF VEXT IEXT PD (Ta25C unless otherwise specified) Absolute Maximum Ratings Unit V VSS0.3 to VSS18 V VSS0.3 to VSS18 V VSS0.3 to VSS18 V VSS0.3 to VIN0.3 50 mA 250 (When not mounted on board) mW 600*1 mW Operation Ambient Temperature Topr Range Storage Temperature Tstg *1. When mounted on board [Mounted on board] (1) Board size : 114.3 mm  76.2 mm  t1.6 mm (2) Board name : JEDEC STANDARD51-7 40 to 85 C 40 to 125 C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. (2) When not mounted on board 700 Power Dissipation (P D) [mW] Power Dissipation (PD) [mW] (1) When mounted on board 600 500 400 300 200 100 0 0 100 150 50 Ambient Temperature (Ta) [C] 300 250 200 150 100 50 0 0 100 150 50 Ambient Temperature (Ta) [C] Figure 3 Power Dissipation of Package 5 EXTERNAL TRANSISTOR TYPE CMOS VOLTAGE REGULATOR S-816 Series Rev.6.1_02  Electrical Characteristics Table 4 Item Input Voltage Output Voltage Maximum Output Current (PNP Output) *1 Drop-Out Voltage *1 Load Regulation (PNP Output) *1 Line Regulation (PNP Output) *1 Output Voltage Temperature Coefficient Current Consumption during Operation Current Consumption during Power-off EXT Output Source Constant Current EXT Output Pull-Up Resistance EXT Output Sink Current Leakage Current during EXT Output Off EXT Output Sink Overcurrent Set Value Symbol VIN VOUT  Vdrop VOUT VOUT VOUT  VIN VOUT Ta IOUT 100 mA VIN VOUT 1 V, 1 mA  IOUT  1 A IOUT 50 mA, VOUT 1 V  VIN  16 V VIN VOUT 1 V, IOUT 50 mA, VON/OFF "H", Ta40 to 85C  1  A 1   100   60 mV mV 1 1 0.15 0.01 0.15 %/V 1  0.15  mV/C 1  30 40 A 1 ISTB VIN 16 V, VON/OFF "L"   1 A 1  10  A 2 0.25 0.50 1.00 M 2  10  mA 2   0.1 A 2 12 16 20 mA 2 2.4     0.3     0.1 0.1 ISRC RUP ISINK IOFF IMAX VSL 6  VIN VOUT 1 V, VON/OFF "H" ON/OFF Pin Input Voltage *1.  VIN VOUT 1 V, IOUT 50 mA, VON/OFF "H" ISS VSH ON/OFF Pin Input Current Conditions (Ta25C unless otherwise specified) Test Min. Typ. Max. Unit circuit 16 V 1   VOUT VOUT VOUT V 1 0.98 1.02 ISH ISL VIN VOUT 1 V, VON/OFF "H", VEXT VOUT, VOUT VOUT 0.95 VIN 16 V, VON/OFF "L" VIN VOUT 1 V, VON/OFF "H", VOUT VOUT 0.95 VIN VEXT VOUT 1 V, VOUT 0 V, VON/OFF "L" VIN VEXT 7 V, VON/OFF "H", VOUT VOUT 0.95 VIN VOUT 1 V, VOUT 0 V, Check VEXT "L" VIN VOUT 1 V, VOUT 0 V, Check VEXT "H" VON/OFF VOUT 1 V VON/OFF 0 V 3 V A The characteristics vary with the associated external components. The characteristics given above are those obtained when the IC is combined with A TOSHIBA Semiconductor & Storage Products Company 2SA1213-Y for the PNP transistor and a 10 F tantalum capacitor for the output capacitor (CL). 2 EXTERNAL TRANSISTOR TYPE CMOS VOLTAGE REGULATOR S-816 Series Rev.6.1_02  Test Circuits 1. 2. A A   VIN EXT VOUT A   ON/OFF VSS V Figure 4 EXT A VIN A ON/OFF VSS VOUT A Figure 5 3. EXT A VIN A ON/OFF VSS VOUT A V Figure 6 7 EXTERNAL TRANSISTOR TYPE CMOS VOLTAGE REGULATOR S-816 Series Rev.6.1_02  Operation 1. Basic Operation Figure 7 shows the block diagram of the S-816 Series. The error amplifier compares the reference voltage (Vref) with feedback voltage (Vfb), which is the output voltage resistance-divided by feedback resistors (RA and RB). It maintains a constant output voltage that is not susceptible to an input voltage variation or temperature variation to regulate the base current of the external PNP transistor. IN OUT VIN EXT VOUT Current Source Pull-Up Reisitance Overcurrent Protection Circuit RA  Vfb  Vref ON/OFF Error Amplifier  Sink Driver  CL RB VSS Remark The diode inside the IC is a parasitic diode. Figure 7 2. Internal Circuits 2.1. ON/OFF Pin This pin starts and stops the regulator. When the ON/OFF pin is set to OFF level, the entire internal circuits stop operating, and the VIN voltage appears through the EXT pin, prodding the external PNP transistor to off, reducing current consumption significantly. In this condition, the EXT pin is pulled up to VIN by a pull-up resistance (approx. 0.5 M) inside the IC in order to ensure you power cut off of the external PNP transistor. The ON/OFF pin is configured as shown in Figure 8. Since neither pull-up or pull-down is performed internally, please avoid using the pin in a floating state. Also, be sure to refrain from applying a voltage of 0.3 V to 2.4 V to this pin lest the current consumption increase. When this ON/OFF pin is not used, leave it coupled to the VIN pin. VIN Table 5 ON/OFF Pin "H": ON "L": OFF Internal Circuit Operate Stop EXT Pin Voltage VINVBE VIN VOUT Pin Voltage Set value Hi-Z ON/OFF VSS Figure 8 8 Rev.6.1_02 EXTERNAL TRANSISTOR TYPE CMOS VOLTAGE REGULATOR S-816 Series 2.2. Overcurrent Protection Circuit The overcurrent protection function of the S-816 Series monitors the EXT pin sink current (base current of the external PNP transistor) with an overcurrent protection circuit incorporated in the IC, and limits that current (EXT pin sink current). As the load current increases, the EXT pin sink current (base current of the external PNP transistor) also grows larger to maintain the output voltage. The overcurrent protection circuit clamps and limits the EXT pin sink current to the EXT output sink overcurrent set value (IMAX) in order to prevent it from increasing beyond that value. The load current at which the overcurrent protection function works is represented by the following equation: IOUT_MAX  IMAX  hFE In this case, hFE is the DC amplification factor of the external PNP transistor. IOUT_MAX represents the maximum output current of this regulator. If it is attempted to obtain a higher load current, the output voltage will fall. Note that within the overcurrent protection function of this IC, the external PNP transistor may not be able to be protected from collector overcurrents produced by an EXT-GND short-circuiting or other phenomenon occurring outside the IC. To protect the external PNP transistor from such collector overcurrents, it will be necessary to choose a transistor with a larger power dissipation than IOUT_MAX  VIN, or to add an external overcurrent protection circuit. With regard to this external overcurrent protection circuit, refer to "1. Overcurrent Protection Circuit" in " Application Circuits". 2.3. Phase Compensation Circuit The S-816 Series performs phase compensation with a phase compensation circuit, incorporated in the IC, and the ESR (Equivalent Series Resistance) of an output capacitor, to secure stable operation even in the presence of output load variation. A uniquely devised phase compensation circuit has resulted in improved transient response characteristics of the IC, while preserving the same feature of low current consumption. This feature allows the IC to be used in applications where the input variation or load variation is heavy. Because the S-816 Series is designed to perform the phase compensation, utilizing the ESR of an output capacitor, such output capacitor (CL) should always be placed between VOUT and VSS. Since each capacitor to be employed has an optimum range of their own characteristics, be sure to choose components for the IC with your all attention. For details, refer to " Selection of Associated External Components". 9 EXTERNAL TRANSISTOR TYPE CMOS VOLTAGE REGULATOR S-816 Series Rev.6.1_02  Selection of Associated External Components 1. External PNP Transistor Select an external transistor according to the conditions of input voltage, output voltage, and output current. A low-saturation voltage PNP transistor with "hFE" ranging from 100 to 300 will be suitable for this IC. The parameters for selection of the external PNP transistor include the maximum collector-base voltage, the maximum collector-emitter voltage, the DC amplification factor (hFE), the maximum collector current and the collector dissipation. The maximum collector-base voltage and the maximum collector-emitter voltage are determined by the input voltage range in each specific application to be employed. You may select a transistor with an input voltage at least several volts higher than the expected maximum input voltage. The DC amplification factor (hFE) affects the maximum output current that can be supplied to the load. With an internal overcurrent protection circuit of this IC, the base current is clamped, and will not exceed the overcurrent set value (IMAX). Select a transistor which is capable of delivering the required maximum output current to the intended application, with hfe and maximum collector current. (Refer to " Overcurrent Protection Circuit") Likewise, select a transistor, based on the maximum output current and the difference between the input and output voltages, with due attention to the collector dissipation. 2. Output Capacitor (CL) The S-816 Series performs phase compensation by an internal phase compensation circuit of IC, and the ESR (Equivalent Series Resistance) of an output capacitor for to secure stable operation even in the presence of output load variation. Therefore, always place a capacitor (CL) of 4.7 F or more between VOUT and VSS. For stable operation of the S-816 Series, it is essential to employ a capacitor with an ESR having optimum range. Whether an ESR is larger or smaller than that optimum range (approximately 0.1  to 5 ), this could produce an unstable output, and cause a possibility of oscillations. For this reason, a tantalum electrolytic capacitor is recommended. When a ceramic capacitor or an OS capacitor having a low ESR is selected, it will be necessary to connect an additional resistance that serves for the ESR in series with the output capacitor, as illustrated in Figure 9. The resistance value that needs to be added will be from 0.1  to 5 , but this value may vary depends on the service conditions, and should be defined through careful evaluation in advance. In general, our recommendation is 0.3  or so. An aluminum electrolytic capacitor tends to produce oscillations as its ESR increases at a low temperature. Beware of this case. When this type of capacitor is employed, make thorough evaluation of it, including its temperature characteristics. IN OUT VIN EXT VOUT S-816 Series R  0.3  CL ON/OFF VSS Figure 9 Caution The above connection diagram and constant will not guarantee successful operation. Perform through evaluation using the actual application to set the constant. 10 EXTERNAL TRANSISTOR TYPE CMOS VOLTAGE REGULATOR S-816 Series Rev.6.1_02  Standard Circuit VIN EXT Current Source Pull-Up Resistance Overcurrent Protection Circuit    Vref ON/OFF Error Amplifier  VOUT   Sink Driver VSS Remark The diode inside the IC is a parasitic diode. Figure 10 Caution The above connection diagram does not guarantee correct operation. Perform sufficient evaluation using the actual application to set the constant. 11 EXTERNAL TRANSISTOR TYPE CMOS VOLTAGE REGULATOR S-816 Series Rev.6.1_02  Precautions  The overcurrent protection function of this IC detects and limits the sink current at the EXT pin inside the IC. Therefore, it does not work on collector overcurrents which are caused by an EXT-GND shortcircuiting or other phenomenon outside the IC. To protect the external PNP transistor from collector overcurrents perfectly, it is necessary to provide another external overcurrent protection circuit.  This IC performs phase compensation by using an internal phase compensator circuit and the ESR of an output capacitor. Therefore, always place a capacitor of 4.7 F or more between VOUT and VSS. A tantalum type capacitor is recommended for this purpose. Moreover, to secure stable operation of the S-816 Series, it will be necessary to employ a capacitor having an ESR (Equivalent Series Resistance) covered in a certain optimum range (0.1  to 5 ). Whether an ESR is larger or smaller than that optimum range, this could result in an unstable output, and cause a possibility of oscillations. Select a capacitor through careful evaluation made according to the actual service conditions.  Overshoot may occur in the output voltage momentarily if the voltage is rapidly raised at power-on or when the power supply fluctuates. Sufficiently evaluate the output voltage at power-on with the actual device.  Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit.  Make sure that the power dissipation inside the IC due to the EXT output sink current (especially at a high temperature) will not surpass the power dissipation of the package.  ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 12 EXTERNAL TRANSISTOR TYPE CMOS VOLTAGE REGULATOR S-816 Series Rev.6.1_02  Application Circuits 1. Overcurrent Protection Circuit Figure 11 shows a sample of overcurrent protection implemented with an external circuit connected. The internal overcurrent protection function of the S-816 Series is designed to detect the sink current (base current of the PNP transistor) at the EXT pin, therefore it may not be able to protect the external PNP transistor from collector overcurrents caused by an EXT-GND short-circuiting or other phenomenon occurring outside the IC. This sample circuit activates the regulator intermittently against collector overcurrents, thereby suppressing the heat generation of the external PNP transistor. The duty of the on-time and off-time of the intermittent operation can be regulated through an external component. RS 2SA1213Y OUT 0.5  R4 2 k Tr1 EXT VOUT VIN VIN  CIN  10 F R2 2 k R1 100 k R3 C2 2 k 0.22 F ON/OFF Tr2 S-816 Series C1 0.22 F  CL  10 F VSS Figure 11 Caution The above connection diagram and constant will not guarantee successful operation. Perform through evaluation using the actual application to set the constant. S-816A30AMC (VIN 4 V) S-816A30AMC (VIN 4 V) 1A Load Current (0.5 A/div) 0A 1A Load Current (0.5 A/div) 0A 2V VON/OFF (1 V/div) 0V 2V VON/OFF (1 V/div) 0V t (2 ms/div) t (100 s/div) Figure 12 Output Current Waveforms during Intermittent Operation Prompted by Load Short-Circuiting 13 EXTERNAL TRANSISTOR TYPE CMOS VOLTAGE REGULATOR S-816 Series Rev.6.1_02 The detection of the overcurrent is done by the sense resistance (RS) and the PNP transistor (Tr1). When Tr1 comes on, triggered by a voltage drop of RS, the NPN transistor (Tr2) also comes on, according to the time constants of the capacitor (C2) and resistance (R2). This causes the ON/OFF pin to turn to OFF level, and the regulating operation to stop, and interrupting the current to the load. When the load current is cut off, the voltage drop of RS stops. This makes Tr1 off again, and also makes the NPN transistor (Tr2) off. In this condition, the ON/OFF pin returns to ON level, according to the time constants of the capacitor (C1) and resistance (R1). This delay time in which ON/OFF pin returns to ON level from OFF level is the time in which the load current remains cut off. If an overcurrent flows again after the ON/OFF pin has assumed ON level following the delay time and the regulating operation has been restarted, the circuit will again suspend the regulating operation and resume the intermittent operation. This intermittent operation will be continued till the overcurrentt is eliminated, and once the overcurrent disappears, the normal operation will be restored. The overcurrent detection value (IOUT_MAX) is represented by the following equation: IOUT_MAX  |VBE1| / RS In this case, RS denotes the resistance value of the sense resistance, and VBE1 denotes the base-emitter saturation voltage of Tr1. For the PNP transistor (Tr1) and the NPN transistor (Tr2), try to select those of small-signal type that offer a sufficient withstand voltage against the input voltage (VIN). The on-time (tON) and the off-time (tOFF) of the intermittent operation are broadly expressed by the following equations: tON  1  C2  R2  LN ( 1  ( VBE2  ( 1  R2 / R3 ) ) / ( VIN  VBE1 ) ) tOFF  1  C1  R1  LN ( 1  VSH / VIN ) In this case, VBE2 denotes the base-emitter saturation voltage of Tr2, VIN denotes the input voltage, and VSH denotes the inversion voltage ("L""H") of the ON/ OFF pin. Set the on-time value that does not cause the overcurrent protection to be activated by a rush current to the load capacitor. Then, compute the ratio between the on-time and the off-time from the maximum input voltage of the appropriate application and the power dissipation of the external PNP transistor, and decide the off-time with reference to the on-time established earlier. Take the equation above as a rough guide, because the actual on-time (tON) and off-time (tOFF) should be defined and checked using the utilizing components. 2. External Adjustment of Output Voltage The S-816 Series allows you to adjust the output voltage or to set its value over the output voltage range (6 V) of the products of this series, when external resistances RA, RB and capacitor CC are added, as illustrated in Figure 13. Moreover, a temperature gradient can be obtained by inserting a thermistor or other element in series with external resistances RA and RB. OUT VIN  VIN  CIN CC EXT Error amplifier R1   R2 Vref ON/OFF VSS Figure 13 14 RA VOUT RB   CL Rev.6.1_02 EXTERNAL TRANSISTOR TYPE CMOS VOLTAGE REGULATOR S-816 Series The S-816 Series has an internal impedance resulting from R1 and R2 between the VOUT and the VSS pin, as shown in Figure 13. Therefore, the influence of the internal resistances (R1, R2) of the IC has to be taken into consideration in defining the output voltage (OUT). The output voltage (OUT) is expressed by the following equation: OUT  VOUT  VOUT  RA  ( RB // *1 RI ) *1. "//" denotes a combined resistance in parallel. In this case, VOUT is the output voltage value of the S-816 Series, RA and RB is the resistance values of the external resistances, and RI is the resistance value (R1R2) of the internal resistances in the IC. The accuracy of the output voltage (OUT) is determined by the absolute accuracy of external connecting resistances RA and RB, the output voltage accuracy (VOUT 2.0%) of the S-816 Series, and deviations in the absolute value of the internal resistance (RI) in the IC. The maximum value (OUTmax) and the minimum value (OUTmin) of the output voltage (OUT), including deviations, are expressed by the following equations: OUTmax  VOUT  1.02  VOUT  1.02  RAmax  ( RBmin // RImin ) OUTmin  VOUT  0.98  VOUT  0.98  RAmin  ( RBmax // RImax ) Where RAmax, RAmin, RBmax and RBmin denote the maximum and minimum of the absolute accuracy of external resistances RA and RB, and RImax and RImin denote the maximum and minimum deviations of the absolute value of the internal resistance (RI) in the IC, respectively. The deviations in the absolute value of internal resistance (RI) in the IC vary with the output voltage set value of the S-816 Series, and are broadly classified as follows:      Output voltage (VOUT) Output voltage (VOUT) Output voltage (VOUT) Output voltage (VOUT) Output voltage (VOUT) 2.5 V to 2.7 V 2.8 V to 3.1 V 3.2 V to 3.7 V 3.8 V to 5.1 V 5.2 V to 6.0 V      3.29 M to 21.78 M 3.29 M to 20.06 M 2.23 M to 18.33 M 2.23 M to 16.61 M 2.25 M to 14.18 M If a value of RI given by the equation shown below is taken in calculating the output voltage (OUT), a median voltage deviation of the output voltage (OUT) will be obtained. RI  2  ( 1  (Maximum value of internal resistance of IC)  1  (Minimum value of internal resistance of IC) ) The closer the output voltage (OUT) and the output voltage set value (VOUT) of the IC are brought to each other, the more the accuracy of the output voltage (OUT) remains immune to deviations in the absolute accuracy of external resistances (RA, RB) and the absolute value of the internal resistance (RI) of the IC. In particular, to suppress the influence of deviations in the internal resistance (RI), the resistance values of external resistances (RA, RB) need to be limited to a much smaller value than that of the internal resistance (RI). However, since reactive current flows through the external resistances (RA, RB), there is a tradeoff between the accuracy of the output voltage (OUT) and the reactive current. This should be taken into consideration, according to the requirements of the intended application. Note that when larger value (more than 1 M) is taken for the external resistances (RA, RB), IC is vulnerable to external noise. Check the influence of this value well with the actual application. Furthermore, add a capacitor CC in parallel to the external resistance RA in order to avoid output oscillations and other types of instability. (Refer to Figure 13) Make sure that the capacitance value of CC is larger than the value given by the following equation: CC[F]  1  ( 2    RA[]  6000 ) Caution The above connection diagram and constant will not guarantee successful operation. Perform through evaluation using the actual application to set the constant. 15 EXTERNAL TRANSISTOR TYPE CMOS VOLTAGE REGULATOR S-816 Series Rev.6.1_02  Characteristics (Typical Data) 1. Input Voltage (VIN) - Output Voltage (VOUT) VIN-VOUT S-816A30AMC (IOUT50 mA) VIN-VOUT S-816A50AMC (IOUT50 mA) 3.10 5.10 3.08 5.08 Ta25C Ta40C 3.06 3.04 5.04 3.02 5.02 VOUT (V) 5.00 4.98 VOUT (V) 3.00 2.98 2.96 Ta40C 4.96 Ta85C 2.94 4.94 2.92 2.90 Ta25C Ta85C 5.06 4.92 2 4 6 8 10 12 14 16 4.90 2 4 6 8 VIN (V) VIN-VOUT S-816A30AMC (Ta25C) 5.10 3.05 5.05 3.00 5.00 VOUT (V) 2.95 VOUT (V) 4.95 2.90 4.90 IOUT500 mA IOUT100 mA IOUT1 mA 2.85 2.8 2.9 3.0 12 14 16 VIN-VOUT S-816A50AMC (Ta25C) 3.10 2.80 10 VIN (V) 3.1 3.2 3.3 4.85 IOUT1 A 3.4 3.5 3.6 IOUT500 mA IOUT100 mA IOUT1 mA 3.7 3.8 4.80 4.8 4.9 5.0 5.1 VIN (V) 5.2 5.3 IOUT1 A 5.4 5.5 5.6 5.7 5.8 VIN (V) 2. Output Current (IOUT) - Output Voltage (VOUT) IOUT-VOUT S-816A30AMC (VIN4 V) IOUT-VOUT S-816A50AMC (VIN6 V) 3.10 5.10 3.08 5.08 3.06 Ta25C Ta40C 3.04 3.02 VOUT (V) 3.00 2.98 2.96 Ta85C 2.92 1 10 100 IOUT (mA) 16 Ta25C Ta85C 5.04 5.02 VOUT (V) 5.00 4.98 4.96 2.94 2.90 5.06 1000 4.94 Ta40C 4.92 4.90 1 10 100 IOUT (mA) 1000 EXTERNAL TRANSISTOR TYPE CMOS VOLTAGE REGULATOR S-816 Series Rev.6.1_02 3. Temperature (Ta) - Output Voltage (VOUT) Ta-VOUT S-816A30AMC (VIN4 V, IOUT50 mA) Ta-VOUT S-816A50AMC (VIN6 V, IOUT50 mA) 3.10 5.10 3.08 5.08 3.06 5.06 3.04 5.04 3.02 VOUT (V) 3.00 2.98 5.02 VOUT (V) 5.00 4.98 2.96 4.96 2.94 4.94 2.92 4.92 2.90 50 25 0 25 50 75 100 4.90 50 25 Ta (C) 0 25 50 75 100 Ta (C) 4. Input Voltage (VIN) - Current Consumption (ISS) VIN-ISS S-816A30AMC (VON/OFF"H") 50 Ta85C Ta25C 45 40 35 30 ISS (A) 25 20 Ta40C 15 10 5 0 0 2 4 6 8 10 12 14 16 VIN (V) 5. Input Voltage (VIN) - EXT Output Sink Overcurrent Set Value (IMAX) VIN-IMAX S-816A30AMC 22 Ta85C 20 18 IMAX (mA) 16 Ta25C 14 12 Ta40C 10 4 6 8 10 12 14 16 VIN (V) 17 EXTERNAL TRANSISTOR TYPE CMOS VOLTAGE REGULATOR S-816 Series Rev.6.1_02 6. Input Voltage (VIN) - ON/OFF Pin Input Voltage (VSH, VSL) VIN-VSH S-816A30AMC VIN-VSL S-816A30AMC 2.5 2.5 Ta85C 2.0 VSH (V) 2.0 1.5 VSL (V) Ta25C 1.0 Ta40C Ta25C 1.0 Ta40C 0.5 0.5 Ta85C 0.0 0.0 4 6 8 10 VIN (V) 18 1.5 12 14 16 4 6 8 10 VIN (V) 12 14 16 Rev.6.1_02 EXTERNAL TRANSISTOR TYPE CMOS VOLTAGE REGULATOR S-816 Series  Transient Response Characteristics (Typical Data) 1. Input Transient Response Characteristics (Power-on VIN0 V  VOUT1 V, IOUT0 A, CL10 F) S-816A30AMC (VIN 0 V  4 V) S-816A50AMC (VIN 0 V  6 V) 6V 4V VIN (2 V/div) 0V VIN (2 V/div) 0V VOUT (2 V/div) VOUT (2 V/div) 0V 0V t (100 s/div) t (100 s/div) 2. Input Transient Response Characteristics (Supply voltage variation VINVOUT1 V  VOUT2 V, CL10 F) S-816A30AMC (IOUT 10 mA) S-816A30AMC (IOUT 300 mA) 5V VIN (0.5 V/div) 4V 5V VIN (0.5 V/div) 4V VOUT (20 mV/div) VOUT (20 mV/div) 3V 3V t (100 s/div) t (100 s/div) S-816A50AMC (IOUT 10 mA) S-816A50AMC (IOUT 300 mA) 7V VIN (0.5 V/div) 6V 7V VIN (0.5 V/div) 6V VOUT (20 mV/div) VOUT (20 mV/div) 5V 5V t (100 s/div) t (100 s/div) 19 EXTERNAL TRANSISTOR TYPE CMOS VOLTAGE REGULATOR S-816 Series 3. Load Transient Response Characteristics (Power-on IOUT1 mA  100 mA, CL10 F) S-816A30AMC (VIN 4 V) S-816A30AMC (VIN 4 V) 100 mA IOUT (50 mA/div) 1 mA 100 mA IOUT (50 mA/div) 1 mA 3V VOUT (20 mV/div) 3V VOUT (20 mV/div) t (50 s/div) t (50 s/div) S-816A50AMC (VIN 6 V) S-816A50AMC (VIN 6 V) 100 mA IOUT (50 mA/div) 1 mA 100 mA IOUT (50 mA/div) 1 mA 5V VOUT (20 mV/div) 5V VOUT (20 mV/div) t (50 s/div) t (50 s/div) 4. ON/OFF Pin Transient Response Characteristics (VON/OFF0 V  VIN, IOUT0 A, CL10 F) S-816A30AMC (VIN 4 V) S-816A50AMC (VIN 6 V) 6V 4V VON/OFF (2 V/div) 0V VON/OFF (2 V/div) 0V VOUT (2 V/div) VOUT (2 V/div) 0V 0V t (100 s/div) 20 t (100 s/div) Rev.6.1_02 2.9±0.2 1.9±0.2 4 5 1 2 +0.1 0.16 -0.06 3 0.95±0.1 0.4±0.1 No. MP005-A-P-SD-1.3 TITLE SOT235-A-PKG Dimensions No. MP005-A-P-SD-1.3 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 ø1.5 -0 +0.2 ø1.0 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 Feed direction No. MP005-A-C-SD-2.1 TITLE SOT235-A-Carrier Tape No. MP005-A-C-SD-2.1 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP005-A-R-SD-1.1 SOT235-A-Reel TITLE No. MP005-A-R-SD-1.1 ANGLE QTY. UNIT mm ABLIC Inc. 3,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-816A27AMC-BACT2U 价格&库存
很抱歉,暂时无法提供与“S-816A27AMC-BACT2U”相匹配的价格&库存,您可以联系我们找货
