NJM2855
LOW DROPOUT VOLTAGE REGULATOR
GENERAL DESCRIPTION
The NJM2855 is a 3-terminal low dropout voltage regulator.
Advanced Bipolar technology achieves low noise, high ripple
rejection.
It delivers up to 5V/1A output power with the maximum input
voltage of 10V.
The NJM2855 is suitable for various applications such as
portable / consumer devices.
PACKAGE OUTLINE
NJM2855DL1
FEATURES
z High Ripple Rejection
75dB typ. (f=1kHz,Vo=3V Version)
z Output Noise Voltage
Vno=45µVrms typ.
z Output capacitor with 2.2µF ceramic capacitor (Vo≥2.7V)
z Output Current
Io (max.)=1A
z High Precision Output
Vo±1.0%
z Low Dropout Voltage
0.20V typ. (Io=600mA)
z Internal Short Circuit Current Limit
z Internal Thermal Overload Protection
z Bipolar Technology
z Package Outline
TO-252-3
PIN CONFIGURATION
2
1
PIN FUNCTION
1.VIN
2.GND
3.VOUT
3
NJM2855DL1
EQUIVALENT CIRCUIT
V IN
V OUT
Thermal
Protection
Bandgap
Reference
GND
Ver.2012-10-24
1
NJM2855
OUTPUT VOLTAGE RANK LIST
The WHITE column shows applicable Voltage Rank(s)
2
Device Name
Vout
Device Name
Vout
NJM2855DL1-15
NJM2855DL1-16
NJM2855DL1-17
NJM2855DL1-18
NJM2855DL1-19
NJM2855DL1-02
NJM2855DL1-21
NJM2855DL1-22
NJM2855DL1-23
NJM2855DL1-24
NJM2855DL1-25
NJM2855DL1-26
NJM2855DL1-27
NJM2855DL1-28
NJM2855DL1-29
NJM2855DL1-03
NJM2855DL1-31
NJM2855DL1-32
NJM2855DL1-33
NJM2855DL1-34
1.5V
1.6V
1.7V
1.8V
1.9V
2.0V
2.1V
2.2V
2.3V
2.4V
2.5V
2.6V
2.7V
2.8V
2.9V
3.0V
3.1V
3.2V
3.3V
3.4V
NJM2855DL1-35
NJM2855DL1-36
NJM2855DL1-37
NJM2855DL1-38
NJM2855DL1-39
NJM2855DL1-04
NJM2855DL1-41
NJM2855DL1-42
NJM2855DL1-43
NJM2855DL1-44
NJM2855DL1-45
NJM2855DL1-46
NJM2855DL1-47
NJM2855DL1-48
NJM2855DL1-49
NJM2855DL1-05
3.5V
3.6V
3.7V
3.8V
3.9V
4.0V
4.1V
4.2V
4.3V
4.4V
4.5V
4.6V
4.7V
4.8V
4.9V
5.0V
Ver.2012-10-24
NJM2855
ABSOLUTE MAXIMUM RATINGS
PARAMETER
SYMBOL
Input Voltage
VIN
Power Dissipation
Operating Temperature
Storage Temperature
PD
Topr
Tstg
RATINGS
+10
1190(*1)
3125(*2)
-40 ∼ +85
-40 ∼ +150
(Ta=25°C)
UNIT
V
mW
°C
°C
(*1): Mounted on glass epoxy board. (76.2×114.3×1.6mm:based on EIA/JDEC standard size, 2Layers, Cu area 100mm2)
(*2): Mounted on glass epoxy board. (76.2×114.3×1.6mm:based on EIA/JDEC standard, 4Layers)
(For 4Layers: Applying 74.2×74.2mm inner Cu area and a thermal via hole to a board based on JEDEC standard JESD51-5)
OPERATING VOLTAGE
VIN=+2.5V ~ +8V (In case of Vo2.0V : VIN=Vo+1V, Vo≤2.0V : VIN=3.0V
The above specification is a common specification for all output voltages.
Therefore, it may be different from the individual specification for a specific output voltage.
Ver.2012-10-24
3
NJM2855
POWER DISSIPATION vs. AMBIENT TEMPERATURE
NJM2855DL1 PowerDissipation
(Topr=-40~+85°C,Tj=150°C)
Power Dissipation PD(mW)
3500
3000
on 4 layers board
2500
2000
1500
on 2 layers board
1000
500
-25
50
75
100
Temperature : Ta(°C)
TEST CIRCUIT
A
IIN
VIN
VIN
0.33µF
VOUT
NJM2855
2.2µF
IOUT V VOU
*5
(ceramic)
GND
*5
1.7V
很抱歉,暂时无法提供与“NJM2855DL1-33-TE1”相匹配的价格&库存,您可以联系我们找货
