0185-46003-1-003
0185-46003-1-003
    SUCO(苏克)
    Module
    PRESSURE SWITCH, DIN CONNECTOR,
0185-46003-1-003 数据手册
M.2 Pressure switches hex 27 with integrated connector hex 27 integrated Technical data Types: 0132 – 0137 0184 / 0185 Rated working voltage: 10 … 48 VAC/DC 10 … 250 VAC/DC Rated current: (resistive load, DC12 and AC12) 10 mA … 4 A 0194 / 0195 5 … 24 VDC 10 mA … 4A 3 … 50 mA NBR (BunaN) (Overpressure safety up to 1,450 psi /100 bar) FKM (in piston pressure switch -40 °F… +212 °F (-40 °C … +100 °C) -22 °F… +248 °F (-30 °C … +120 °C) +23 °F… +248 °F (-5 °C … +120 °C) +5 °F… +248 °F (-15 °C … +120 °C) FKM (Viton®) -4 °F… +248 °F (-20 °C … +120 °C) Silicone -40 °F… +248 °F (-40 °C … +120 °C) -22 °F… +248 °F (-30 °C … +120 °C) NBR (BunaN) (Overpressure safety up to 5,801 psi /400 bar) EPDM Temperature resistance of sealing materials: FFKM (Viton®) (in diaphragm pressure switch) HNBR Burst pressure (diaphragm pressure switch, overpressure resistance 1,450psi) Burst pressure (diaphragm pressure switch, overpressure resistance 1,450psi) -22 °F… +212 °F (-30 °C … +100 °C) 2,900 psi (200 bar) 5,801 psi (400 bar) M Switching frequency: 200 / min. Mechanical life expectancy: applies for switching pressures to max. 725 psi (50 bar)) Pressure rise rate: ≤ 14.5 psi/ms (≤ 1 bar/ms) 1,000,000 cycles (for diaphragm pressure switches, life expectancy value only Adjustable average value 10 … 30 % depending on type (can only be set at factory) Vibration resistance: 10 g; 5 … 200 Hz sine wave; DIN EN 60068-2-6 Shock resistance: 294 m/s 2 ; 14 ms half sine wave; DIN EN 60068-2-27 Weight: approx. 3.52 oz (100 g) approx. 4.58 oz (130 g) approx. 4.58 oz (130 g) Overview of maximum working voltage and current and contact materials Type 0132 0133 0134 0135 0136 0137 0184 0185 0194 0195 5 … 24 VDC 10 … 48 VAC/DC 10 … 250 VAC/DC 3 … 50 mA 10 mA … 4 A Gold contacts Silver contacts (can only be set at factory) Connector type Protection class AMP M12x1 DIN EN Superseal 1.5® 61076-2-101-A IP67 IP67 Deutsch DT04-3P IP67, IP6K9K DIN EN 175301 IP65 Available as an option 33
0185-46003-1-003 价格&库存
很抱歉,暂时无法提供与“0185-46003-1-003”相匹配的价格&库存,您可以联系我们找货
