PS312-3G-2
PS312-3G-2
    SENSATA(森萨塔)
    Cylinder
    PS312-3G-2
PS312-3G-2 数据手册
| PS312 Ceramic Capacitive OEM High and Low Pressure Sensing Modules Description The ceramic capacitive sensing technology in Kavlico®’s OEM Pressure sensing modules has been field proven for more than 30 years and has been designed for high volume applications. Kavlico® sensors are installed worldwide in a variety of industrial and transportation applications. These RoHS compliant modules are equipped with a robust flush mounted ceramic sensing diaphragm compatible with most industrial fluids and gaseous media. The standard module is provided with a brass spacer as housing material and an electric connection of 3 isolated wires 0.15 mm2, 75mm long. The module facilitates easy integration and installation into final assemblies for a wide variety of applications. With a 10-year minimum shelf life and a lifetime of millions of cycles, Kavlico®’s ruggedly designed modules are made to last. Features • Media Resistant • Superior Long-Term Stability & Repeatability • High Overpressure Capability • Shock & Vibration Resistant Applications • Industrial Pumps & Compressors • Refrigeration • Heating, Ventilation and Air-conditioning (HVAC) • Steam Sterilizers, Boilers & Dryers • Test & Monitoring Equipment • Process Controls • Facility Management • Mechanical Engineering • Filter Restriction • Fuel Cells • Hydraulics Systems • Process Controls • Level Measurement • Water Management • Power Generators MAIN FEATURES Pressure Ranges Electrical Connection Housing Material Output Signal 0 to 0.07 bar up to 0 to 20 bar (gage) 0 to 1 up to 0 to 20 bar (absolute) 3 isolated color coded wires; 0.15 mm², appr. 75 mm long Silicon coat: RED – VSUPPLY; GREEN – OUTPUT; BLACK – GROUND Brass spacer 1 - 4 VDC, 0.5 - 4.5 VDC (at 0 - 100% pressure) Page 1 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com TECHNICAL SPECIFICATIONS Pressure Ranges From 0 to ... bar (gage) From 0 to ... bar (absolute) 0.07 0.20 0.35 0.50 0.75 1 2 3.50 5 7 10 20 1* 2* 3.50 5 7 10 20 Proof Pressure *1 bar 1.2 1.4 1.5 2.25 2.25 3 6 10.5 15 21 30 60 Burst Pressure *1 bar 2.4 2.7 3 4.1 4.1 5 10 17 25 35 50 100 *1. Data is calibrated in Sensata test fixtures, specifications may change depending on the customer housing. Physical Operating Life Cycle Weight Operating Temperature Media min. 10 million full pressure cycles over the full range ≤ 50 grams (without mating connector) -40°C to + 125°C All fluids and gases compatible with AU/Al2O3 Performance Linearity *1 Total Error Band *1 Stability *1 ± 0.1 % TYP. / ± 0.2 % MAX ± 1.0 % TYP. for temperature range +20°…+85°C ± 2.0 % MAX. for temperature range -40°…+125°C ± 0.1 % TYP. * / ± 0.25 % MAX. (1 YEAR) Temp. Coefficients - Zero ± 0.05 % TYP. * / ± 0.1% MAX. / 10 K within temperature range 0° to + 85°C Temp. Coefficients - Span ± 0.05 % TYP. * / ± 0.1% MAX. / 10 K within temperature range 0° to + 85°C Electrical Output Signal 1...4 VDC Supply Voltage 5.00 ±0.25 VDC Supply Current MAX. 2.2 mA at 5 VDC Output Impedance 100 kΩ Load 50 kΩ Response Time ≤ 5 ms max. to 63% of full scale pressure with step change on input Overvoltage Protection up to ± 16 V Reserve Voltage up to ± 16 V Short-Circuit Proofness Insulation Voltage EMI Protection 0.5…4.5 VDC yes (for min. 3 intervals at 5 min. each) 500 VDC > 1 MΩ Depending on customer package Page 2 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com DIMENSIONS Dimensions in mm [Inch] Pressure Sensor with Electrical Connection Page 3 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com Example: PS312-15G-1 ORDERING OPTIONS PS312 Pressure Sensing Module, 0 - 1 bar gage, 1...4 VDC at 0 - 100% pressure. PS312 Family 15G 1 PS312 Pressure Ranges 1G: 0 - 0.07 BarG 3G: 0 - 0.20 BarG 5G: 0 - 0.35 BarG 7G: 0 - 0.50 BarG 10G: 0 - 0.75 BarG 15G: 0 - 1 BarG 30G: 0 - 2 BarG 50G: 0 - 3.50 BarG 75G: 0 - 5 BarG 100G: 0 - 7 BarG 150G: 0 - 10 BarG 300G: 0 - 20 BarG 15A: 0 - 1 BarA 30A: 0 - 2 BarA 50A: 0 - 3.50 BarA 75A: 0 - 5 BarA 100A: 0 - 7 BarA 150A: 0 - 10 BarA 300A: 0 - 20 BarA Output 1: 1...4 VDC at 0 - 100 % Pressure 2: 0.5...4.5 VDC at 0 - 100% Pressure AGENCY APPROVALS & CERTIFICATIONS 2011/65/EU ROHS Directive Page 4 Revised 3/8/18 Sensata Technologies, Inc. (“Sensata”) data sheets are solely intended to assist designers (“Buyers”) who are developing systems that incorporate Sensata products (also referred to herein as “components”). Buyer understands and agrees that Buyer remains responsible for using its independent analysis, evaluation and judgment in designing Buyer’s systems and products. Sensata data sheets have been created using standard laboratory conditions and engineering practices. Sensata has not conducted any testing other than that specifically described in the published documentation for a particular data sheet. Sensata may make corrections, enhancements, improvements and other changes to its data sheets or components without notice. Buyers are authorized to use Sensata data sheets with the Sensata component(s) identified in each particular data sheet. HOWEVER, NO OTHER LICENSE, EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE TO ANY OTHER SENSATA INTELLECTUAL PROPERTY RIGHT, AND NO LICENSE TO ANY THIRD PARTY TECHNOLOGY OR INTELLECTUAL PROPERTY RIGHT, IS GRANTED HEREIN. SENSATA DATA SHEETS ARE PROVIDED “AS IS”. SENSATA MAKES NO WARRANTIES OR REPRESENTATIONS WITH REGARD TO THE DATA SHEETS OR USE OF THE DATA SHEETS, EXPRESS, IMPLIED OR STATUTORY, INCLUDING ACCURACY OR COMPLETENESS. SENSATA DISCLAIMS ANY WARRANTY OF TITLE AND ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, QUIET ENJOYMENT, QUIET POSSESSION, AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHTS WITH REGARD TO SENSATA DATA SHEETS OR USE THEREOF. All products are sold subject to Sensata’s terms and conditions of sale supplied at www.sensata.com SENSATA ASSUMES NO LIABILITY FOR APPLICATIONS ASSISTANCE OR THE DESIGN OF BUYERS’ PRODUCTS. BUYER ACKNOWLEDGES AND AGREES THAT IT IS SOLELY RESPONSIBLE FOR COMPLIANCE WITH ALL LEGAL, REGULATORY AND SAFETY-RELATED REQUIREMENTS CONCERNING ITS PRODUCTS, AND ANY USE OF SENSATA COMPONENTS IN ITS APPLICATIONS, NOTWITHSTANDING ANY APPLICATIONS-RELATED INFORMATION OR SUPPORT THAT MAY BE PROVIDED BY SENSATA. Mailing Address: Sensata Technologies, Inc., 529 Pleasant Street, Attleboro, MA 02703, USA. Copyright © 2018 Sensata Technologies, Inc. CONTACT US Americas +1 (800) 350 2727 sensors@sensata.com switches@sensata.com Europe, Middle East & Africa +359 (2) 809 1826 pressure-info.eu@sensata.com Asia Pacific sales.isasia@list.sensata.com China +86 (21) 2306 1500 Japan +81 (45) 277 7117 Korea +82 (31) 601 2004 India +91 (80) 67920890 Rest of Asia +886 (2) 27602006 ext 2808 www.sensata.com
PS312-3G-2
物料型号:Sensata Technologies的PS312,是Kavlico®品牌的陶瓷电容式OEM高压和低压传感模块。
器件简介:该传感器使用经过30多年现场验证的陶瓷电容传感技术,设计用于大量应用。这些RoHS合规模块配备了与大多数工业流体和气体介质兼容的坚固的平面安装陶瓷感应膜。标准模块提供黄铜间隔件作为外壳材料,以及3根隔离的电线,线径0.15 mm²,长度75mm。模块便于集成和安装到最终组装中,适用于各种应用。
引脚分配:3根隔离的彩色编码电线;硅涂层:红色 - VSUPPLY(电源);绿色 - OUTPUT(输出);黑色 - GROUND(地)。
参数特性: - 工作压力范围:从0到0.07 bar至0到20 bar(表压)和从0到1 bar至0到20 bar(绝对压)。 - 电气连接:3根隔离的电线,0.15 mm²,约75mm长。 - 外壳材料:黄铜间隔件。 - 输出信号:1-4 VDC,0.5-4.5 VDC(在0-100%压力时)。
功能详解:模块具有10年的最小货架寿命和数百万次循环的使用寿命,设计坚固耐用。特点包括媒体抗性、卓越的长期稳定性和重复性、高过压能力以及抗冲击和振动。
应用信息:适用于工业泵和压缩机、制冷、暖通空调(HVAC)、蒸汽灭菌器、锅炉和干燥器、测试和监测设备、过程控制、设施管理、机械工程、过滤器限制、燃料电池、液压系统、过程控制、液位测量、水管理和发电机等多种工业和交通应用。
封装信息:模块尺寸为7.40±0.10 mm,重量不超过50克(不含配对连接器),工作温度范围为-40°C至+125°C,适用于与AU/AI,0兼容的所有流体和气体。
技术规格详细列出了压力范围、电气特性、物理性能和性能参数,例如线性度、总误差带、稳定性、零点温度系数、跨度温度系数、电气输出信号、供电电压、供电电流、输出阻抗、负载、响应时间、过压保护、储备电压、短路保护和绝缘电压等。
PS312-3G-2 价格&库存
很抱歉,暂时无法提供与“PS312-3G-2”相匹配的价格&库存,您可以联系我们找货
