CD74HC4515E
CD74HC4515E
    L3HARRIS
    DIP24
    DECODER/DRIVER, HC/UH SERIES, IN
CD74HC4515E 数据手册
[ /Title (CD74 HC451 4, CD74 HC451 5) /Subject (High Speed CMOS CD54HC4514, CD74HC4514, CD74HC4515 Data sheet acquired from Harris Semiconductor SCHS280C November 1997 - Revised July 2003 High-Speed CMOS Logic 4- to 16-Line Decoder/Demultiplexer with Input Latches Features Description • Multifunction Capability - Binary to 1-of-16 Decoder - 1-to-16 Line Demultiplexer • Fanout (Over Temperature Range) The CD54HC4514, CD74HC4514, and CD74HC4515 are high-speed silicon gate devices consisting of a 4-bit strobed latch and a 4- to 16-line decoder. The selected output is enabled by a low on the enable input (E). A high on E inhibits selection of any output. Demultiplexing is accomplished by using the E input as the data input and the select inputs (A0A3) as addresses. This E input also serves as a chip select when these devices are cascaded. - Standard Outputs . . . . . . . . . . . . . . . 10 LSTTL Loads - Bus Driver Outputs . . . . . . . . . . . . . 15 LSTTL Loads • Wide Operating Temperature Range . . . -55oC to 125oC When Latch Enable (LE) is high the output follows changes in the inputs (see truth table). When LE is low the output is isolated from changes in the input and remains at the level (high for the 4514, low for the 4515) it had before the latches were enabled. These devices, enhanced versions of the equivalent CMOS types, can drive 10 LSTTL loads. • Balanced Propagation Delay and Transition Times • Significant Power Reduction Compared to LSTTL Logic ICs • HC Types - 2V to 6V Operation - High Noise Immunity: NIL = 30%, NIH = 30% of VCC at VCC = 5V Ordering Information TEMP. RANGE (oC) PACKAGE CD54HC4514F3A -55 to 125 24 Ld CERDIP CD74HC4514E -55 to 125 24 Ld PDIP CD74HC4514EN -55 to 125 24 Ld PDIP CD74HC4514M -55 to 125 24 Ld SOIC CD74HC4514M96 -55 to 125 24 Ld SOIC CD74HC4515E -55 to 125 24 Ld PDIP CD74HC4515EN -55 to 125 24 Ld PDIP PART NUMBER Pinout CD54HC4514 (CERDIP) CD74HC4514, CD74HC4515 (PDIP, SOIC) TOP VIEW LE 1 24 VCC A0 2 23 E A1 3 22 A3 Y7 4 21 A2 CD74HC4515M -55 to 125 24 Ld SOIC Y6 5 20 Y10 CD74HC4515M96 -55 to 125 24 Ld SOIC Y5 6 19 Y11 Y4 7 18 Y8 Y3 8 17 Y9 Y1 9 16 Y14 Y2 10 15 Y15 Y0 11 14 Y12 GND 12 13 Y13 NOTE: When ordering, use the entire part number. The suffix 96 denotes tape and reel. CAUTION: These devices are sensitive to electrostatic discharge. Users should follow proper IC Handling Procedures. Copyright © 2003, Texas Instruments Incorporated 1 CD54HC4514, CD74HC4514, CD74HC4515 Functional Diagram A0 A1 A2 A3 2 3 21 LATCH 4-TO-16 DECODER 22 1 LE 23 HC 4514 11 Y0 9 Y1 10 Y2 8 Y3 7 Y4 6 Y5 5 Y6 4 Y7 18 Y8 17 Y9 20 Y10 19 Y11 14 Y12 13 Y13 16 Y14 15 Y15 HC 4515 Y0 Y1 Y2 Y3 Y4 Y5 Y6 Y7 Y8 Y9 Y10 Y11 Y12 Y13 Y14 Y15 GND = 12 VCC = 24 E DECODE TRUTH TABLE (LE = 1) DECODER INPUTS ENABLE A3 A2 A1 A0 ADDRESSED OUTPUT 4514 = LOGIC 1 (HIGH) 4515 = LOGIC 0 (HIGH) 0 0 0 0 0 Y0 0 0 0 0 1 Y1 0 0 0 1 0 Y2 0 0 0 1 1 Y3 0 0 1 0 0 Y4 0 0 1 0 1 Y5 0 0 1 1 0 Y6 0 0 1 1 1 Y7 0 1 0 0 0 Y8 0 1 0 0 1 Y9 0 1 0 1 0 Y10 0 1 0 1 1 Y11 0 1 1 0 0 Y12 0 1 1 0 1 Y13 0 1 1 1 0 Y14 0 1 1 1 1 Y15 1 X X X X All Outputs = 0, 4514 All Outputs = 1, 4515 X = Don’t Care; Logic 1 = High; Logic 0 = Low 2 CD54HC4514, CD74HC4514, CD74HC4515 Absolute Maximum Ratings Thermal Information DC Supply Voltage, VCC . . . . . . . . . . . . . . . . . . . . . . . . -0.5V to 7V DC Input Diode Current, IIK For VI < -0.5V or VI > VCC + 0.5V . . . . . . . . . . . . . . . . . . . . . .±20mA DC Output Diode Current, IOK For VO < -0.5V or VO > VCC + 0.5V . . . . . . . . . . . . . . . . . . . .±20mA DC Drain Current, per Output, IO For -0.5V < VO < VCC + 0.5V. . . . . . . . . . . . . . . . . . . . . . . . . .±25mA DC Output Source or Sink Current per Output Pin, IO For VO > -0.5V or VO < VCC + 0.5V . . . . . . . . . . . . . . . . . . . .±25mA DC VCC or Ground Current, ICC . . . . . . . . . . . . . . . . . . . . . . . . .±50mA Thermal Resistance (Typical) θJA (oC/W) E (PDIP) Package (Note 1) . . . . . . . . . . . . . . . . . . . 67 EN (PDIP) Package (Note 1) . . . . . . . . . . . . . . . . . . 67 M (SOIC) Package (Note 2). . . . . . . . . . . . . . . . . . . 46 Maximum Junction Temperature . . . . . . . . . . . . . . . . . . . . . . . 150oC Maximum Storage Temperature Range . . . . . . . . . .-65oC to 150oC Maximum Lead Temperature (Soldering 10s) . . . . . . . . . . . . . 300oC (SOIC - Lead Tips Only) Operating Conditions Temperature Range (TA) . . . . . . . . . . . . . . . . . . . . . -55oC to 125oC Supply Voltage Range, VCC HC Types . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .2V to 6V DC Input or Output Voltage, VI, VO . . . . . . . . . . . . . . . . . 0V to VCC Input Rise and Fall Time 2V . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1000ns (Max) 4.5V. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 500ns (Max) 6V . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 400ns (Max) CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTES: 1. The package thermal impedance is calculated in accordance with JESD 51-3. 2. The package thermal impedance is calculated in accordance with JESD 51-7. DC Electrical Specifications TEST CONDITIONS PARAMETER 25oC -40oC TO 85oC -55oC TO 125oC SYMBOL VI (V) IO (mA) VCC (V) VIH - - 2 1.5 - - 1.5 - 1.5 - V 4.5 3.15 - - 3.15 - 3.15 - V 6 4.2 - - 4.2 - 4.2 - V 2 - - 0.5 - 0.5 - 0.5 V 4.5 - - 1.35 - 1.35 - 1.35 V 6 - - 1.8 - 1.8 - 1.8 V -0.02 2 1.9 - - 1.9 - 1.9 - V -0.02 4.5 4.4 - - 4.4 - 4.4 - V -0.02 6 5.9 - - 5.9 - 5.9 - V - - - - - - - - - V -4 4.5 3.98 - - 3.84 - 3.7 - V -5.2 6 5.48 - - 5.34 - 5.2 - V MIN TYP MAX MIN MAX MIN MAX UNITS HC TYPES High Level Input Voltage Low Level Input Voltage High Level Output Voltage CMOS Loads High Level Output Voltage TTL Loads VIL VOH - VIH or VIL - 3 CD54HC4514, CD74HC4514, CD74HC4515 DC Electrical Specifications (Continued) TEST CONDITIONS PARAMETER 25oC -40oC TO 85oC -55oC TO 125oC SYMBOL VI (V) IO (mA) VCC (V) VOL VIH or VIL 0.02 2 - - 0.1 - 0.1 - 0.1 V 0.02 4.5 - - 0.1 - 0.1 - 0.1 V 0.02 6 - - 0.1 - 0.1 - 0.1 V - - - - - - - - - V 4 4.5 - - 0.26 - 0.33 - 0.4 V 5.2 6 - - 0.26 - 0.33 - 0.4 V Low Level Output Voltage CMOS Loads Low Level Output Voltage TTL Loads Input Leakage Current Quiescent Device Current MIN TYP MAX MIN MAX MIN MAX UNITS II VCC or GND - 6 - - ±0.1 - ±1 - ±1 µA ICC VCC or GND 0 6 - - 8 - 80 - 160 µA Prerequisite For Switching Specifications PARAMETER 25oC -40oC TO 85oC -55oC TO 125oC SYMBOL TEST CONDITIONS VCC (V) MIN TYP MAX MIN MAX MIN MAX UNITS tW - 2 75 - - 95 - 110 - ns 4.5 30 - - 19 - 22 - ns 6 35 - - 16 - 19 - ns 2 100 - - 125 - 150 - ns 4.5 20 - - 25 - 30 - ns 6 17 - - 21 - 26 - ns HC TYPES LE Pulse Width Select to LE Set-Up Time Select to LE Hold Time Switching Specifications PARAMETER tSU tH - - 2 0 - - 0 - 0 - ns 4.5 0 - - 0 - 0 - ns 6 0 - - 0 - 0 - ns CL = 50pF, Input tr, tf = 6ns SYMBOL TEST CONDITIONS tPHL, tPLH CL = 50pF -40oC TO 85oC 25oC -55oC TO 125oC VCC (V) MIN TYP MAX MIN MAX MIN MAX UNITS 2 - - 275 - 345 - 415 ns 4.5 - - 55 - 69 - 83 ns CL = 15pF 5 - 23 - - - - - ns CL = 50pF 6 - - 47 - 59 - 71 ns CL = 50pF 2 - - 225 - 280 - 340 ns 4.5 - - 45 - 56 - 68 ns CL = 15pF 5 - 19 - - - - - ns CL = 50pF 6 - - 38 - 48 - 58 ns HC TYPES Propagation Delay Select to Outputs LE to Outputs tPHL, tPLH 4 CD54HC4514, CD74HC4514, CD74HC4515 Switching Specifications PARAMETER E to Outputs Output Transition Time CL = 50pF, Input tr, tf = 6ns (Continued) -40oC TO 85oC 25oC -55oC TO 125oC SYMBOL TEST CONDITIONS VCC (V) MIN TYP MAX MIN MAX MIN MAX UNITS tPHL, tPLH CL = 50pF 2 - - 175 - 220 - 265 ns 4.5 - - 35 - 44 - 53 ns CL = 15pF 5 - 14 - - - - - ns CL = 50pF 6 - - 30 - 37 - 45 ns CL = 50pF 2 - - 75 - 95 - 110 ns 4.5 - - 15 - 19 - 22 ns 6 - - 13 - 16 - 19 ns tTHL, tTLH Input Capacitance CIN CL = 50pF - 10 - 10 - 10 - 10 pF Power Dissipation Capacitance (Notes 3, 4) CPD - 5 - 70 - - - - - pF NOTES: 3. CPD is used to determine the dynamic power consumption, per package. 4. PD = VCC2 fi (CPD + CL) where fi = Input Frequency, CL = Output Load Capacitance, VCC = Supply Voltage. Test Circuits and Waveforms tr = 6ns tfCL trCL CLOCK 90% 10% I tWL + tWH = fCL tf = 6ns VCC 50% 10% tWL VCC 90% 50% 10% INPUT GND 50% 50% GND tTHL tTLH tWH 90% 50% 10% INVERTING OUTPUT NOTE: Outputs should be switching from 10% VCC to 90% VCC in accordance with device truth table. For fMAX, input duty cycle = 50%. tPHL FIGURE 1. HC CLOCK PULSE RISE AND FALL TIMES AND PULSE WIDTH tPLH FIGURE 2. HC TRANSITION TIMES AND PROPAGATION DELAY TIMES, COMBINATION LOGIC tr = 6ns tf = 6ns VCC 90% 50% 10% INPUT GND tTHL tTLH 90% 50% 10% INVERTING OUTPUT tPLH tPHL FIGURE 3. HC TRANSITION TIMES AND PROPAGATION DELAY TIMES, COMBINATION LOGIC 5 CD54HC4514, CD74HC4514, CD74HC4515 Test Circuits and Waveforms tfCL trCL CLOCK INPUT (Continued) 90% CLOCK INPUT 50% 10% GND tH(H) tfCL trCL VCC VCC 90% 50% 10% GND tH(H) tH(L) tH(L) VCC DATA INPUT GND tSU(H) tTLH OUTPUT tTHL 90% 50% 10% tSU(L) tTLH 90% tTHL 90% 50% 10% tPLH tPHL OUTPUT tPHL tPLH tREM VCC SET, RESET OR PRESET 50% GND IC 50% GND tSU(H) tSU(L) 90% tREM VCC SET, RESET OR PRESET VCC DATA INPUT 50% 50% GND IC CL 50pF FIGURE 4. HC SETUP TIMES, HOLD TIMES, REMOVAL TIME, AND PROPAGATION DELAY TIMES FOR EDGE TRIGGERED SEQUENTIAL LOGIC CIRCUITS CL 50pF FIGURE 5. HC SETUP TIMES, HOLD TIMES, REMOVAL TIME, AND PROPAGATION DELAY TIMES FOR EDGE TRIGGERED SEQUENTIAL LOGIC CIRCUITS 6 PACKAGE OPTION ADDENDUM www.ti.com 29-May-2015 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan Lead/Ball Finish MSL Peak Temp (2) (6) (3) Op Temp (°C) Device Marking (4/5) 5962-9865501QJA ACTIVE CDIP J 24 1 TBD Call TI N / A for Pkg Type -55 to 125 5962-9865501QJ A CD54HC4514F3A CD54HC4514F3A ACTIVE CDIP J 24 1 TBD Call TI N / A for Pkg Type -55 to 125 5962-9865501QJ A CD54HC4514F3A CD74HC4514E LIFEBUY PDIP N 24 15 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type -55 to 125 CD74HC4514E CD74HC4514EE4 LIFEBUY PDIP N 24 15 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type -55 to 125 CD74HC4514E CD74HC4514EN LIFEBUY PDIP NT 24 15 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type -55 to 125 CD74HC4514EN CD74HC4514ENE4 LIFEBUY PDIP NT 24 15 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type -55 to 125 CD74HC4514EN CD74HC4514M ACTIVE SOIC DW 24 25 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 HC4514M CD74HC4514M96 ACTIVE SOIC DW 24 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 HC4514M CD74HC4514ME4 ACTIVE SOIC DW 24 25 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 HC4514M CD74HC4514MG4 ACTIVE SOIC DW 24 25 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 HC4514M CD74HC4515E LIFEBUY PDIP N 24 15 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type -55 to 125 CD74HC4515E CD74HC4515EE4 LIFEBUY PDIP N 24 15 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type -55 to 125 CD74HC4515E CD74HC4515EN LIFEBUY PDIP NT 24 15 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type -55 to 125 CD74HC4515EN CD74HC4515M ACTIVE SOIC DW 24 25 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 HC4515M CD74HC4515M96 ACTIVE SOIC DW 24 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 HC4515M CD74HC4515M96E4 ACTIVE SOIC DW 24 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 HC4515M Addendum-Page 1 Samples PACKAGE OPTION ADDENDUM www.ti.com Orderable Device 29-May-2015 Status (1) CD74HC4515MG4 ACTIVE Package Type Package Pins Package Drawing Qty SOIC DW 24 25 Eco Plan Lead/Ball Finish MSL Peak Temp (2) (6) (3) Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM Op Temp (°C) Device Marking (4/5) -55 to 125 HC4515M (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) Eco Plan - The planned eco-friendly classification: Pb-Free (RoHS), Pb-Free (RoHS Exempt), or Green (RoHS & no Sb/Br) - please check http://www.ti.com/productcontent for the latest availability information and additional product content details. TBD: The Pb-Free/Green conversion plan has not been defined. Pb-Free (RoHS): TI's terms "Lead-Free" or "Pb-Free" mean semiconductor products that are compatible with the current RoHS requirements for all 6 substances, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, TI Pb-Free products are suitable for use in specified lead-free processes. Pb-Free (RoHS Exempt): This component has a RoHS exemption for either 1) lead-based flip-chip solder bumps used between the die and package, or 2) lead-based die adhesive used between the die and leadframe. The component is otherwise considered Pb-Free (RoHS compatible) as defined above. Green (RoHS & no Sb/Br): TI defines "Green" to mean Pb-Free (RoHS compatible), and free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material) (3) MSL, Peak Temp. - The Moisture Sensitivity Level rating according to the JEDEC industry standard classifications, and peak solder temperature. (4) There may be additional marking, which relates to the logo, the lot trace code information, or the environmental category on the device. (5) Multiple Device Markings will be inside parentheses. Only one Device Marking contained in parentheses and separated by a "~" will appear on a device. If a line is indented then it is a continuation of the previous line and the two combined represent the entire Device Marking for that device. (6) Lead/Ball Finish - Orderable Devices may have multiple material finish options. Finish options are separated by a vertical ruled line. Lead/Ball Finish values may wrap to two lines if the finish value exceeds the maximum column width. Important Information and Disclaimer:The information provided on this page represents TI's knowledge and belief as of the date that it is provided. TI bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. TI has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. TI and TI suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. In no event shall TI's liability arising out of such information exceed the total purchase price of the TI part(s) at issue in this document sold by TI to Customer on an annual basis. OTHER QUALIFIED VERSIONS OF CD54HC4514, CD74HC4514 : Addendum-Page 2 Samples PACKAGE OPTION ADDENDUM www.ti.com 29-May-2015 • Catalog: CD74HC4514 • Military: CD54HC4514 NOTE: Qualified Version Definitions: • Catalog - TI's standard catalog product • Military - QML certified for Military and Defense Applications Addendum-Page 3 PACKAGE MATERIALS INFORMATION www.ti.com 14-Jul-2012 TAPE AND REEL INFORMATION *All dimensions are nominal Device Package Package Pins Type Drawing SPQ Reel Reel A0 Diameter Width (mm) (mm) W1 (mm) B0 (mm) K0 (mm) P1 (mm) W Pin1 (mm) Quadrant CD74HC4514M96 SOIC DW 24 2000 330.0 24.4 10.75 15.7 2.7 12.0 24.0 Q1 CD74HC4515M96 SOIC DW 24 2000 330.0 24.4 10.75 15.7 2.7 12.0 24.0 Q1 Pack Materials-Page 1 PACKAGE MATERIALS INFORMATION www.ti.com 14-Jul-2012 *All dimensions are nominal Device Package Type Package Drawing Pins SPQ Length (mm) Width (mm) Height (mm) CD74HC4514M96 SOIC DW 24 2000 367.0 367.0 45.0 CD74HC4515M96 SOIC DW 24 2000 367.0 367.0 45.0 Pack Materials-Page 2 MECHANICAL DATA MCDI004A – JANUARY 1995 – REVISED NOVEMBER 1997 J (R-GDIP-T**) CERAMIC DUAL-IN-LINE PACKAGE 24 PINS SHOWN B 13 24 C 1 12 0.065 (1,65) 0.045 (1,14) Lens Protrusion (Lens Optional) 0.010 (0.25) MAX 0.175 (4,45) 0.140 (3,56) 0.090 (2,29) 0.060 (1,53) A Seating Plane 0.018 (0,46) MIN 24 PINS ** DIM ”A” ”B” ”C” NARR 0.125 (3,18) MIN 0.022 (0,56) 0.014 (0,36) 0.100 (2,54) 0.012 (0,30) 0.008 (0,20) 28 WIDE NARR 40 32 WIDE NARR WIDE NARR WIDE MAX 0.624(15,85) 0.624(15,85) 0.624(15,85) 0.624(15,85) 0.624(15,85) 0.624(15,85) 0.624(15,85) 0.624(15,85) MIN 0.590(14,99) 0.590(14,99) 0.590(14,99) 0.590(14,99) 0.590(14,99) 0.590(14,99) 0.590(14,99) 0.590(14,99) MAX 1.265(32,13) 1.265(32,13) 1.465(37,21) 1.465(37,21) 1.668(42,37) 1.668(42,37) 2.068(52,53) 2.068(52,53) MIN 1.235(31,37) 1.235(31,37) 1.435(36,45) 1.435(36,45) 1.632(41,45) 1.632(41,45) 2.032(51,61) 2.032(51,61) MAX 0.541(13,74) 0.598(15,19) 0.541(13,74) 0.598(15,19) 0.541(13,74) 0.598(15,19) 0.541(13,74) 0.598(15,19) MIN 0.514(13,06) 0.571(14,50) 0.514(13,06) 0.571(14,50) 0.514(13,06) 0.571(14,50) 0.514(13,06) 0.571(14,50) 4040084/C 10/97 NOTES: A. B. C. D. E. All linear dimensions are in inches (millimeters). This drawing is subject to change without notice. Window (lens) added to this group of packages (24-, 28-, 32-, 40-pin). This package can be hermetically sealed with a ceramic lid using glass frit. Index point is provided on cap for terminal identification. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 MECHANICAL DATA MPDI008 – OCTOBER 1994 N (R-PDIP-T**) PLASTIC DUAL-IN-LINE PACKAGE 24 PIN SHOWN A 24 13 0.560 (14,22) 0.520 (13,21) 1 12 0.060 (1,52) TYP 0.200 (5,08) MAX 0.610 (15,49) 0.590 (14,99) 0.020 (0,51) MIN Seating Plane 0.100 (2,54) 0.021 (0,53) 0.015 (0,38) 0.125 (3,18) MIN 0.010 (0,25) M PINS ** 0°– 15° 0.010 (0,25) NOM 24 28 32 40 48 52 A MAX 1.270 (32,26) 1.450 (36,83) 1.650 (41,91) 2.090 (53,09) 2.450 (62,23) 2.650 (67,31) A MIN 1.230 (31,24) 1.410 (35,81) 1.610 (40,89) 2.040 (51,82) 2.390 (60,71) 2.590 (65,79) DIM 4040053 / B 04/95 NOTES: A. B. C. D. All linear dimensions are in inches (millimeters). This drawing is subject to change without notice. Falls within JEDEC MS-011 Falls within JEDEC MS-015 (32 pin only) POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 IMPORTANT NOTICE Texas Instruments Incorporated and its subsidiaries (TI) reserve the right to make corrections, enhancements, improvements and other changes to its semiconductor products and services per JESD46, latest issue, and to discontinue any product or service per JESD48, latest issue. Buyers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. All semiconductor products (also referred to herein as “components”) are sold subject to TI’s terms and conditions of sale supplied at the time of order acknowledgment. TI warrants performance of its components to the specifications applicable at the time of sale, in accordance with the warranty in TI’s terms and conditions of sale of semiconductor products. Testing and other quality control techniques are used to the extent TI deems necessary to support this warranty. Except where mandated by applicable law, testing of all parameters of each component is not necessarily performed. TI assumes no liability for applications assistance or the design of Buyers’ products. Buyers are responsible for their products and applications using TI components. To minimize the risks associated with Buyers’ products and applications, Buyers should provide adequate design and operating safeguards. TI does not warrant or represent that any license, either express or implied, is granted under any patent right, copyright, mask work right, or other intellectual property right relating to any combination, machine, or process in which TI components or services are used. Information published by TI regarding third-party products or services does not constitute a license to use such products or services or a warranty or endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the third party, or a license from TI under the patents or other intellectual property of TI. Reproduction of significant portions of TI information in TI data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. TI is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. Resale of TI components or services with statements different from or beyond the parameters stated by TI for that component or service voids all express and any implied warranties for the associated TI component or service and is an unfair and deceptive business practice. TI is not responsible or liable for any such statements. Buyer acknowledges and agrees that it is solely responsible for compliance with all legal, regulatory and safety-related requirements concerning its products, and any use of TI components in its applications, notwithstanding any applications-related information or support that may be provided by TI. Buyer represents and agrees that it has all the necessary expertise to create and implement safeguards which anticipate dangerous consequences of failures, monitor failures and their consequences, lessen the likelihood of failures that might cause harm and take appropriate remedial actions. Buyer will fully indemnify TI and its representatives against any damages arising out of the use of any TI components in safety-critical applications. In some cases, TI components may be promoted specifically to facilitate safety-related applications. With such components, TI’s goal is to help enable customers to design and create their own end-product solutions that meet applicable functional safety standards and requirements. Nonetheless, such components are subject to these terms. No TI components are authorized for use in FDA Class III (or similar life-critical medical equipment) unless authorized officers of the parties have executed a special agreement specifically governing such use. Only those TI components which TI has specifically designated as military grade or “enhanced plastic” are designed and intended for use in military/aerospace applications or environments. Buyer acknowledges and agrees that any military or aerospace use of TI components which have not been so designated is solely at the Buyer's risk, and that Buyer is solely responsible for compliance with all legal and regulatory requirements in connection with such use. TI has specifically designated certain components as meeting ISO/TS16949 requirements, mainly for automotive use. In any case of use of non-designated products, TI will not be responsible for any failure to meet ISO/TS16949. Products Applications Audio www.ti.com/audio Automotive and Transportation www.ti.com/automotive Amplifiers amplifier.ti.com Communications and Telecom www.ti.com/communications Data Converters dataconverter.ti.com Computers and Peripherals www.ti.com/computers DLP® Products www.dlp.com Consumer Electronics www.ti.com/consumer-apps DSP dsp.ti.com Energy and Lighting www.ti.com/energy Clocks and Timers www.ti.com/clocks Industrial www.ti.com/industrial Interface interface.ti.com Medical www.ti.com/medical Logic logic.ti.com Security www.ti.com/security Power Mgmt power.ti.com Space, Avionics and Defense www.ti.com/space-avionics-defense Microcontrollers microcontroller.ti.com Video and Imaging www.ti.com/video RFID www.ti-rfid.com OMAP Applications Processors www.ti.com/omap TI E2E Community e2e.ti.com Wireless Connectivity www.ti.com/wirelessconnectivity Mailing Address: Texas Instruments, Post Office Box 655303, Dallas, Texas 75265 Copyright © 2015, Texas Instruments Incorporated
CD74HC4515E 价格&库存
很抱歉,暂时无法提供与“CD74HC4515E”相匹配的价格&库存,您可以联系我们找货
