P1K-2-2X16PA
P1K-2-2X16PA
    SENSATA(森萨塔)
    DIP-8
    P1K-2-2X16PA
P1K-2-2X16PA 数据手册
| P1K Pressure Sensor Description The P1K series of pressure sensors incorporates a piezo-resistive sensing element in a compact package. Using a 5 VDC supply voltage, the P1K provides a 0.25 VDC to 4.0 VDC output proportional to pressure. Internal temperature compensation provides and accurate, easy to use sensor. The industry standard terminal pins provides ease of use for your printed circuit board designs. Features • Compact Package • Amplified Temperature Compensated Linear Output • No Position Sensitivity Above 0-2” H2O • EMI/RFI and ESD Protected • Superior Output Signal Stability • Printed Circuit Board through Hole Mounting Applications • Variable Air Volume Systems • Filter Pressure Monitoring • Duct Air Flow • Modulated Furnace Controls • Combustion Airflow • Gaseous Leak Detection • Medical Applications: Oxygen Concentrators, Ventilators, Anesthesia Equipment, CPAP, Wound Therapy. MAIN FEATURES Pressure Ranges 2, 5, 10, +/-1, +/-2, +/- 5 inches of water; 2.5, 5, 12.5, 25, +/-2.5, +/- 5, +/- 12.5 mbar Electrical Connection PCB thru hole terminal pins, 2.54 mm [.100 inch] pitch Pressure Connection Barbed port, 1.9[.08] diameter Housing Material PPS, 40% glass filled, black Terminal Pin Material Phosphor bronze, tin plated Supply Voltage 5.00 Vdc ± 0.25 Vdc Output Signal Ratiometric analog; 5% to 80% of supply voltage Page 1 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com TECHNICAL SPECIFICATIONS Pressure Ranges from 0 to... 2” H2O 5” H2O 10” H2O +/- 1” H2O +/- 2” H2O +/- 5” H2O from 0 to... 5mbar 12.5mbar 20mbar +/- 2.5 mbar +/- 5mbar +/- 12.5 mbar Proof Pressure (min) 1.0 PSI/ (70mbar) 1.0 PSI/ (70mbar) 1.0 PSI/ (70mbar) 1.0 PSI/ (70mbar) 1.0 PSI/ (70mbar) 1.0 PSI/ (70mbar) Burst Pressure Factor 1.8 PSI/ (125mbar) 1.8 PSI/ (125mbar) 1.8 PSI/ (125mbar) 1.8 PSI/ (125mbar) 1.8 PSI/ (125mbar) 1.8 PSI/ (125mbar) Physical Expected Operating Life 10 million full pressure life cycles Shelf Life 10 years minimum Stability +/- 0.5% of full scale span for 1 year Vibration 10 G’s peak to peak sinusoidal (20 to 1600Hz) Shock Resistance Weight 50 G’s ½ Sinewave, 11 mSec pulse, 18 pulses (6 per axis) 3.5g max. Operating Temperature -20°C to 85°C Storage Temperature -40°C to 125°C Humidity Media Up to 92% RH in a non-condensing environment Dry air Performance Accuracy Temp. Error (0 to 60°C) Temp. Error (-20 to 0°C and 60 to 85°C 0 to 60°C) 0.25% Max (% of full scale span) (RSS of linearity, hysteresis and repeatability) 0.05%/ C [% of full scale span] 5% full scale span Electrical Output Impedance 100 Ohms max. Excitation Current 4mA max Minimum Load 25k Ohms between output and ground Response Time 5 mSec max (63% full scale) Page 2 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com DIMENSIONS Dimensions in mm [Inch] Page 3 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com Example: P1K-1-2X16PA ORDERING OPTIONS P1K Family P1K Pressure sensor 0 -1” H20, .25 to 4.0 VDC output, no internal material seal, barbed tube fitting port with PCB Terminal Pin connection, no external material seal 1 2 X 16 P A P1K Pressure Ranges 1B: 2: 2B: 5: 5B: 10: 2.5MBB: 5MB: 5MBB: 12.5MB: 12.5MBB: 25MB: +/- 1” H2O 0-2” H2O +/- 2” H2O 0-5” H2O +/- 5” H2O 0-10” H2O 0-2.5 mbar 0-5 mbar +/- 5 mbar 0-12.5 mbar +/-12.5 mbar 0-25 mbar Output Type 2: 0.25 – 4.0 VDC Seal Material X: None Pressure Connection 16: Barb or Tube Fitting Built-in Connector P: PCB Terminal Pins Seal Material A: None AGENCY APPROVALS & CERTIFICATIONS Page 4 Revised 4/10/18 Sensata Technologies, Inc. (“Sensata”) data sheets are solely intended to assist designers (“Buyers”) who are developing systems that incorporate Sensata products (also referred to herein as “components”). Buyer understands and agrees that Buyer remains responsible for using its independent analysis, evaluation and judgment in designing Buyer’s systems and products. Sensata data sheets have been created using standard laboratory conditions and engineering practices. Sensata has not conducted any testing other than that specifically described in the published documentation for a particular data sheet. Sensata may make corrections, enhancements, improvements and other changes to its data sheets or components without notice. Buyers are authorized to use Sensata data sheets with the Sensata component(s) identified in each particular data sheet. HOWEVER, NO OTHER LICENSE, EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE TO ANY OTHER SENSATA INTELLECTUAL PROPERTY RIGHT, AND NO LICENSE TO ANY THIRD PARTY TECHNOLOGY OR INTELLECTUAL PROPERTY RIGHT, IS GRANTED HEREIN. SENSATA DATA SHEETS ARE PROVIDED “AS IS”. SENSATA MAKES NO WARRANTIES OR REPRESENTATIONS WITH REGARD TO THE DATA SHEETS OR USE OF THE DATA SHEETS, EXPRESS, IMPLIED OR STATUTORY, INCLUDING ACCURACY OR COMPLETENESS. SENSATA DISCLAIMS ANY WARRANTY OF TITLE AND ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, QUIET ENJOYMENT, QUIET POSSESSION, AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHTS WITH REGARD TO SENSATA DATA SHEETS OR USE THEREOF. All products are sold subject to Sensata’s terms and conditions of sale supplied at www.sensata.com SENSATA ASSUMES NO LIABILITY FOR APPLICATIONS ASSISTANCE OR THE DESIGN OF BUYERS’ PRODUCTS. BUYER ACKNOWLEDGES AND AGREES THAT IT IS SOLELY RESPONSIBLE FOR COMPLIANCE WITH ALL LEGAL, REGULATORY AND SAFETY-RELATED REQUIREMENTS CONCERNING ITS PRODUCTS, AND ANY USE OF SENSATA COMPONENTS IN ITS APPLICATIONS, NOTWITHSTANDING ANY APPLICATIONS-RELATED INFORMATION OR SUPPORT THAT MAY BE PROVIDED BY SENSATA. Mailing Address: Sensata Technologies, Inc., 529 Pleasant Street, Attleboro, MA 02703, USA. Copyright © 2018 Sensata Technologies, Inc. CONTACT US Americas +1 (800) 350 2727 sensors@sensata.com switches@sensata.com Europe, Middle East & Africa +359 (2) 809 1826 pressure-info.eu@sensata.com Asia Pacific sales.isasia@list.sensata.com China +86 (21) 2306 1500 Japan +81 (45) 277 7117 Korea +82 (31) 601 2004 India +91 (80) 67920890 Rest of Asia +886 (2) 27602006 ext 2808 www.sensata.com
P1K-2-2X16PA 价格&库存
很抱歉,暂时无法提供与“P1K-2-2X16PA”相匹配的价格&库存,您可以联系我们找货
