TS19603CS RLG
TS19603CS RLG
    TAIWANSEMICONDUCTOR(台湾半导体)
    ESOP-8
    IC LED DRVR LINEAR 8SOP
TS19603CS RLG 数据手册
TS19603 400mA High Voltage Adjustable Current Regulator With Enable Control SOP-8EP Pin Definition: 1. GND 8. OUT 2. GND 7. OUT 3. VDD 6. NC 4. ISET 5. OE General Description The TS19603 is a high voltage, low dropout current regulator of maximum output current up to 400mA. The output current is decided by an external resistor, and the output sink current could be disabled via OE pin. TS19603 en de d internally also build-in thermal protection to prevent the chip over heat damage. Typical Application Circuit Features ● 0.28V VDROP @ 400mA ● 400mA Maximum Output Current ● Output Current Controlled by External Resistor ● 3µs Fast Response Output Stage Enable Control ● Wide Supply Voltage Range: 5~50V TS19603 mm Applications ● High Power LED Driver ● RGB Full Color Power LED Driver ● LCD Monitor/TV LED Backlight Driver eco Ordering Information Part No. Package Packing TS19603CS RLG SOP-8EP 2.5Kpcs / 13” Reel Note: “G” denotes Halogen Free Product. tR Absolute Maximum Rating Symbol Value Unit Input Voltage VIN 55 V Output Sink Current IOUT 450 mA Output Enable Voltage VEN 13.2 V Operating Junction Temperature Range TOPR -40 ~ +150 ºC Storage Temperature Range TSTG -65 ~ +150 ºC Thermal Resistance Junction to Air θJA 80 ºC/W Power Dissipation PD @ TA=25°C (Note 2) PD 1 W Thermal Resistance - Junction to Ambient θJA 36 ºC/W Thermal Resistance - Junction to Case θJC 5.5 ºC/W ESD 2 kV No Parameter ESD Rating (Human Body Model) (Note 4) Recommend Operating Conditions Parameter Symbol Min Typ Max Unit Input Voltage VIN 5 -- 50 V Output Enable Voltage VEN 0 -- 12 V Output Sink Current IOUT 200 -- 400 mA Operating Junction Temperature Range TOPR -20 -- +125 ºC Operating Free-Air Temperature Range TA -20 -- +85 ºC 1/6 Version: A13 TS19603 400mA High Voltage Adjustable Current Regulator With Enable Control Electrical Specification (VIN=24V, TA=25oC, unless otherwise specified.) Parameter Conditions Output Current Output Current Deviation Min Typ Max VOUT =0.5V, RSET=3kΩ -- 200 -- VOUT =0.5V, RSET=1.5kΩ -- 400 -- VOUT =0.5V, IOUT =200mA~400mA -- -- ±5 % 200 -- 900 µA SET Current Range Unit mA ISET=200µA -- 100 -- mA Maximum Output Current ISET=900µA -- 450 -- mA Output Dropout Voltage ISET=800µA (Note 1) Load Regulation VOUT =0.5V to 3V, IOUT =200mA Line Regulation VOUT =0.5V, IOUT =350mA, VIN=5~50V Should lower than VIN Enable Low Input Current Enable High Input Current Output Disable Delay Time EN from low to high. VOUT=0.5V, mm Output Enable Delay Time IOUT=350mA, Duty 50% EN from high to low. VOUT=0.5V, IOUT=350mA, Duty 50% Supply Current Consumption 0.28 -- V -- -- 3 mA/V -- 0.08 0.15 %/V 0 -- 0.8 V 2 -- 12 V -20 -- +20 µA -5 -- +5 µA -- 3 -- µS -- 3 -- µS -- -- 5 mA de Enable High Input Voltage -- en Enable Low Input Voltage d Minimum Output Current e co Note 1: Output Dropout Voltage: Duty 90% x IOUT @ VOUT=0.5V Note 2: Stresses listed as the above “Absolute Maximum Ratings” may cause permanent damage to the device. These are for stress ratings. Functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating tR conditions for extended periods may remain possibility to affect device reliability. Note 3: Thermal Resistance is specified with the component mounted on a low effective thermal conductivity test board in free air at TA=25°C. Note 4: 2 square inch of FR-4, double sided, 1 oz. minimum copper weight. No Note 5: Devices are ESD sensitive. Handling precaution recommended. Pin Function Description Pin Name Pin Function VIN Power Supply Pin OUT Output pin. Sink current is decided by the current on RSET connected to ISET pin. ISET=1.2V x 500/RCS GND Ground Pin OE ISET Output Stage Enable Control pin. High enable the output pin. It can be left floating for normally on. Output Current Setting pin. Connect a resistor from ISET to GND to set the LED bias current ISET=0.002 x IOUT=1.2V/RCS 2/6 Version: A13 TS19603 400mA High Voltage Adjustable Current Regulator With Enable Control Application Information TS19603 is a high voltage, low dropout current regulator for maximum output current up to 400mA with OE pin control. The current could be linearly adjusted through variable resister connected to ISET pin, or by PWM control via OE pin. Although the absolute maximum rating of OUT pin 75V, the dropout voltage between OUT pin and GND pin should not be too large when current is sinking because of the thermal dissipation capability of the package. Here are some of the typical application examples: DC Voltage Input d Any DC voltage level between 5V to 50V could be adopted as power source VDD for typical application of de TS19603 as long as VDD is larger than the total forward voltage drop of the LED string (at expecting current) by 0.35V. If 50V ~ 60V voltage level is adopted as power source to positive end of the LED string, one Zener shunt mm en regulator could be used to provide appropriate voltage to VDD pin. TS19603 No tR e co TS19603 3/6 Version: A13 TS19603 400mA High Voltage Adjustable Current Regulator With Enable Control Application Information (Continue) LED Backlight Solution TS19603 could coordinate with any type of DC-to-DC converter through feedback path to realized LED backlight module. The number of LEDs in the string is variable even with certain fixed power source since the output voltage en de d of the DC-to-DC converter could be modulated according to feedback signal. e co AC Voltage Input mm TS19603 TS19603 could work with any kind of well-known or well-developed switch-mode power supply system. Simply cut off the internal feedback path of the power supply system and then feed the signal from TS19603 back to the No tR power supply system instead. TS19603 4/6 Version: A13 TS19603 400mA High Voltage Adjustable Current Regulator With Enable Control SOP-8EP Mechanical Drawing d tR Marking Diagram e co mm en A B C D E E1 F G K M P R de DIM SOP-8EP DIMENSION MILLIMETERS INCHES MIN MAX MIN MAX. 4.80 5.00 0.189 0.196 3.80 4.00 0.150 0.157 1.35 1.75 0.054 0.068 0.35 0.49 0.014 0.019 2.05 2.41 0.081 0.095 2.82 3.30 0.111 0.130 0.40 1.25 0.016 0.049 1.27BSC 0.05BSC 0.10 0.25 0.004 0.009 0º 7º 0º 7º 5.80 6.20 0.229 0.244 0.25 0.50 0.010 0.019 No Y = Year Code M = Month Code for Halogen Free Product (O=Jan, P=Feb, Q=Mar, R=Apl, S=May, T=Jun, U=Jul, V=Aug, W=Sep, X=Oct, Y=Nov, Z=Dec) L = Lot Code 5/6 Version: A13 TS19603 No tR e co mm en de d 400mA High Voltage Adjustable Current Regulator With Enable Control Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6/6 Version: A13
TS19603CS RLG 价格&库存
很抱歉,暂时无法提供与“TS19603CS RLG”相匹配的价格&库存,您可以联系我们找货
