TS19378
Taiwan Semiconductor
2A Buck (Step-down) WLED Driver
DESCRIPTION
FEATURES
The TS19378 is a high voltage step-down converter
Input Voltage Range 8V~40V
designed for driving up to 10 series white LEDs from a
Output voltage up to 38V
40V system input. The total LED driving current up to
2A Switch Output Current
2A, which is measured through an external current
Duty ratio: 0%~100% PWM control
sense resistor. Its low 200mV feedback voltage
300kHz Switching Frequency
reduces power loss and improves efficiency. The OVP
Enable/Disable Functions
pin monitors the output voltage and turns off the
Soft Start Time Control
converter if an over-voltage condition is present due to
Current limit and Thermal Shutdown
an open circuit condition. The TS19378 includes
Short Circuit Protections
current limit, short circuit protection and thermal
Built-in Internal SW P-CH MOSFET
shutdown protection preventing damage.
TS19378 provides high power, high efficiency, and
APPLICATION
excellent transient characteristics. The PWM control
White LED Backlighting
circuit is able to the duty ratio linearly from 0 up to
High Power LED Application
100%. Since this converter can accommodate an
Multiple LED Driving
input voltage up to 40V, it is also suitable for the
LED Lighting Equipment
operation via an AC adapter.
SOP-8EP
Pin Definition:
1. EN/SS
2. GND
3. VGATE
4. VCC
8. COMP
7. FB
6. OVP
5. SW (Connected to exposed pad)
Notes: Moisture sensitivity level: level 3. Per J-STD-020
TYPICAL APPLICATION CIRCUIT
Document Number: DS_P0000199
1
COUT ESR Range
R2
C7
30~80mΩ
470R
10nF
80~300mΩ
100R
15nF
Version: B15
TS19378
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise specified) (Note 1)
PARAMETER
SYMBOL
LIMIT
UNIT
VCC Pin Voltage
VCC
VSS - 0.3 to VSS + 45
V
Feedback Pin Voltage
VFB
VSS - 0.3 to 6
V
EN/SS Pin Voltage
VEN/SS
VSS - 0.3 to 6
V
OVP Pin Voltage
VOVP
VSS - 0.3 to VCC
V
COMP Pin Voltage
VCOMP
VSS - 0.3 to 6
V
VGATE Pin Voltage
VGATE
VSS - 0.3 to VCC
V
Switch Pin Voltage
VSW
VSS - 0.3 to VCC + 0.3
V
Power Dissipation
PD
Internally limited
mW
Storage Temperature Range
TST
-65 to +150
°C
Operating Junction Temperature Range
TOJP
-40 to +125
°C
Operating Supply Voltage
VOP
8 to 40
V
Output Voltage
VOUT
38
V
SYMBOL
LIMIT
UNIT
RӨJC
15
o
40
o
THERMAL PERFORMANCE
(Note 2)
PARAMETER
Thermal Resistance from Junction to Case
Thermal Resistance from Junction to Ambient
RӨJA
C/W
C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise specified)
PARAMETER
SYMBOL
CONDITION
MIN
TYP
MAX
UNIT
0.19
0.20
0.21
V
Feedback Voltage
VFB
IOUT=0.2A
Quiescent Current
ICCQ
VFB=0.5V force driver off
3
6
mA
Feedback Bias Current
IFB
IOUT=0.1A
0.1
0.5
μA
Shutdown Supply Current
ISD
VEN =0V
150
300
μA
ISWLIMIT
2.5
A
Oscillation Frequency
fOSC
240
300
360
kHz
Short Frequency
fOSC
50
kHz
Low (regulator OFF)
0.8
V
Switch Current Limit
EN/SS Pin Shutdown Logic
input threshold voltage
VSL
EN/SS Pin Input Current
IEN/SS
VEN=0V
5
μA
Internal MOSFET RDSON
RDSON
VCC=5V, VFB=0V
130
180
mΩ
OVP Sense Voltage
VOVP
0.833
0.850
0.867
V
Thermal shutdown Temp
TSD
150
°C
Thermal shutdown Hysteresis
TSH
40
°C
Note:
1. Stresses listed as the above “Absolute Maximum Ratings” may cause permanent damage to the device. These are for
stress ratings. Functional operation of the device at these or any other conditions beyond those indicated in the operational
sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may
remain possibility to affect device reliability.
2.
RӨJA is measured with the PCB copper area(need connect to Exposed Pad) of approximately 1.5 in2(Multi-layer).
2
Version: B15
TS19378
ORDERING INFORMATION
PART NO.
TS19378CS RLG
PACKAGE
PACKING
SOP-8EP
2,500pcs / 13” Reel
Note:
1. Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC.
2. Halogen-free according to IEC 61249-2-21 definition.
FUNCTION BLOCK
PIN DESCRIPTION
PIN NO.
NAME
FUNCTION
1
EN/SS
2
GND
3
VGATE
Gate drive for external N-CH MOSFET.
4
VCC
Power supply pin for all internal circuitry.
5
SW
SW is the output of the internal driver switch. Connected for package exposed pad
6
OVP
Output voltage protection.
7
FB
8
COM
EN: Output stage enable control pin. It can be left floating for normally on.
SS: Supplied shutdown or soft start function.
Ground return for all internal circuitry.
Feedback pin. Reference voltage is VFB=0.2V.
Output pin of error amplifier.
3
Version: B15
TS19378
AC Input Application Circuit
ILED
R5
350mA
750mA
1000mA
0.570Ω
0.266Ω
0.200Ω
70mW
150mW
200mW
C1
L1
100μF
220μF
330μF
33μH
APPLICATION INFORMATION
PWM Control
The TS19378 consists of DC/DC converters that employ a pulse-width modulation (PWM) system. In converters of
the TS19378, the pulse width varies in a range from 0 to 100%, according to the load current. The ripple voltage
produced by the switching can easily be removed through a filter because the switching frequency remains constant.
Therefore, these converters provide a low-ripple power over broad ranges of input voltage and load current
Setting ILED Current
Application circuit item shows the basic application circuit with TS19378 adjustable output version. The external
resistor sets the LED output current according to the following formula:
ILED=(0.25V/R5), VFB=0.2V
Resistor select for LED output current setting
ILED
R2
350mA
0.57Ω
70mW
750mA
0.266Ω
150mW
1000mA
0.2Ω
200mW
Current Limit
The current limit threshold is setting by the internal circuit.
Compensation
In all LED driver applications. Connecting a resistor (R2) and a capacitor (C7) from COMP pin to GND. Please
refer the application circuit table to design.
4
Version: B15
TS19378
APPLICATION INFORMATION (CONTINUE)
EN/SS
This pin can be supplied shutdown or soft start function. It is inside pull high function. For normal application, the
pin must be connected a capacitor to ground. There is a 5μA current to charge this capacitor, vary the different
capacitor value to control soft start time. Allow the switching regulator circuit to be shutdown pulling this pin below
a 0.8V threshold voltage; the shutdown supply current is approximately 150μA
Inductor Selection
For most designs, the different frequency can be reducing the inductor value; The TS19378 is suggested 33μH.
Where is inductor Ripple Current. Large value inductors lower ripple current and small value inductors result in high
ripple currents. Choose inductor ripple current approximately 20% of the maximum load current 2A, ΔIL=0.4A. The
DC current rating of the inductor should be at least equal to the maximum load current plus half the ripple current to
prevent core saturation (2A+0.2A).
Input Capacitor Selection
This capacitor should be located close to the IC using short leads and the voltage rating should be approximately
1.5 times the maximum input voltage. The RMS current rating requirement for the input capacitor of a buck
regulator is approximately 1⁄2 the DC load current. A low ESR input capacitor sized for maximum RMS current
must be used. A 220µF low ESR capacitor for most applications is sufficient.
Over Voltage Protection
The OVP voltage is set by outside resistance (R1 and R4). The external resistor sets the OVP voltage according to
the following equation:
R4
R1
If VOVP >0.85V, The OVP is happened that to disable the driver until VOVP
很抱歉,暂时无法提供与“TS19378CS RLG”相匹配的价格&库存,您可以联系我们找货
