| P993
Low Range Differential Pressure PCB Mount Sensor
Description
The P993 series of pressure sensors incorporates a silicon capacitive sensing element in a compact package. Using a 5 VDC input, the sensors provide
a 0.25 to 4.0 VDC output proportional to pressure. Internal temperature compensation provides an accurate, easy to use device. The innovative design
eliminates mounting position effects found on other low pressure differential sensors currently available in the market.
Features
• Rugged PCB Mount Package
• Amplified Temperature Compensated
• Linear Output
• No Position Sensitivity
• EMI/RFI & ESD Protected
• Superior Output Signal Stability
Applications
• Variable Air Volume Systems (VAV)
• Filter Pressure Monitoring Duct Air
• Flow Modulated Furnace Controls
• Combustion Air Flow Gaseous
• Leak Detection
MAIN FEATURES
Pressure Ranges
2, 5, 10, ±1, ±2, ±5 Inches of H2O
Electrical Connection
3 solderable pins, tin plated
Pressure Connection
1/8” diameter tube fitting with barb
Housing Material
PET 30% glass reinforced, flame retardant
0.25 VDC – 4 VDC
Output Signal
TECHNICAL SPECIFICATIONS
Pressure Ranges
From 0 to …
Inch of H2O
2
5
10
±1
±2
±5
Proof Pressure
PSI
1
1
1
1
1
1
Burst pressure
PSI
1.5
1.5
1.5
1.5
1.5
1.5
Page 1
Copyright © 2018 Sensata Technologies, Inc.
www.sensata.com
TECHNICAL SPECIFICATIONS (CONTINUED)
Physical
Operating Life Cycle
min. 10 million full pressure cycles over the full range
Vibration Resistance
1 G from 20 to 1200 Hz
Shock Resistance
10 G’s at 6 ms duration
Drop Test
Weight
1m onto concrete surface
≤ 20 grams (without mating connector)
Operating Temperature
-10°C to + 60°C
Storage Temperature
- 40°C to + 95°C
Media
Air
Performance
Total Error Band
±2% of span Max. (±3% for 0 - 1” range) (10°C ≤ T ≤ 40°C)
Electrical
Output Signal
Power Consumption
0.25 to 4 VDC Ratiometric
≤ 20 mW
Operating Supply Signal
5 VDC ± 5%
Overvoltage Protection
min. 16 VDC
Short-circuit Proofness
Yes *1
Reverse Polarity Protection
Yes *2
Output Impedance
100 Ω Max
2. for min. 3 intervals at 5 minutes each
3. for min. 10 seconds on assigned pins
DIMENSIONS
Dimensions in mm [Inch]
Page 2
www.sensata.com
Example: P993-5B
ORDERING OPTIONS
P993 Pressure Sensor, ±5” H2O.
P993
Family
XX
P993
Pressure Ranges
1B: ± 1” H2O
2: 0 - 2.0” H2O
2B: ± 2” H2O
5: 0 - 5.0” H2O
5B: ± 5” H2O
10: 0 - 10” H2O
AGENCY APPROVALS & CERTIFICATIONS
2002/95/EC ROHS Directive
WARNINGS
RISK OF MATERIAL DAMAGE AND HOT ENCLOSURE
• The product’s side panels may be hot, allow the product to cool before touching
• Follow proper mounting instructions including torque values
• Do not allow liquids or foreign objects to enter this product
Failure to follow these instructions can result in serious injury, or equipment damage.
HAZARD OF ELECTRIC SHOCK, EXPLOSION OR ARC FLASH
• Disconnect all power before installing or working with this equipment
• Verify all connections and replace all covers before turning on power
Failure to follow these instructions will result in death or serious injury.
Page 3
Revised 3/30/18
Sensata Technologies, Inc. (“Sensata”) data sheets are solely intended to assist designers (“Buyers”) who are developing systems that
incorporate Sensata products (also referred to herein as “components”). Buyer understands and agrees that Buyer remains responsible
for using its independent analysis, evaluation and judgment in designing Buyer’s systems and products. Sensata data sheets have
been created using standard laboratory conditions and engineering practices. Sensata has not conducted any testing other than that
specifically described in the published documentation for a particular data sheet. Sensata may make corrections, enhancements,
improvements and other changes to its data sheets or components without notice.
Buyers are authorized to use Sensata data sheets with the Sensata component(s) identified in each particular data sheet. HOWEVER, NO
OTHER LICENSE, EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE TO ANY OTHER SENSATA INTELLECTUAL PROPERTY RIGHT, AND
NO LICENSE TO ANY THIRD PARTY TECHNOLOGY OR INTELLECTUAL PROPERTY RIGHT, IS GRANTED HEREIN. SENSATA DATA SHEETS
ARE PROVIDED “AS IS”. SENSATA MAKES NO WARRANTIES OR REPRESENTATIONS WITH REGARD TO THE DATA SHEETS OR USE
OF THE DATA SHEETS, EXPRESS, IMPLIED OR STATUTORY, INCLUDING ACCURACY OR COMPLETENESS. SENSATA DISCLAIMS
ANY WARRANTY OF TITLE AND ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, QUIET
ENJOYMENT, QUIET POSSESSION, AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHTS WITH REGARD
TO SENSATA DATA SHEETS OR USE THEREOF.
All products are sold subject to Sensata’s terms and conditions of sale supplied at www.sensata.com SENSATA ASSUMES NO LIABILITY
FOR APPLICATIONS ASSISTANCE OR THE DESIGN OF BUYERS’ PRODUCTS. BUYER ACKNOWLEDGES AND AGREES THAT IT IS SOLELY
RESPONSIBLE FOR COMPLIANCE WITH ALL LEGAL, REGULATORY AND SAFETY-RELATED REQUIREMENTS CONCERNING ITS PRODUCTS,
AND ANY USE OF SENSATA COMPONENTS IN ITS APPLICATIONS, NOTWITHSTANDING ANY APPLICATIONS-RELATED INFORMATION
OR SUPPORT THAT MAY BE PROVIDED BY SENSATA.
Mailing Address: Sensata Technologies, Inc., 529 Pleasant Street, Attleboro, MA 02703, USA.
CONTACT US
Americas
+1 (800) 350 2727
sensors@sensata.com
switches@sensata.com
Europe, Middle East & Africa
+359 (2) 809 1826
pressure-info.eu@sensata.com
Asia Pacific
sales.isasia@list.sensata.com
China +86 (21) 2306 1500
Japan +81 (45) 277 7117
Korea +82 (31) 601 2004
India +91 (80) 67920890
Rest of Asia +886 (2) 27602006
ext 2808
www.sensata.com
很抱歉,暂时无法提供与“P993-1B”相匹配的价格&库存,您可以联系我们找货
