CD4515BE
CD4515BE
    L3HARRIS
    DIP24
    DECODER/DRIVER, 4000/14000/40000
CD4515BE 数据手册
Data sheet acquired from Harris Semiconductor SCHS074A – Revised June 2003 The CD4514B and CD4515B types are supplied in 16-lead hermetic dual-in-line ceramic packages (F3A suffix), 16-lead dual-in-line plastic packages (E suffix), and 16-lead small-outline packages (M and M96 suffixes). Copyright  2003, Texas Instruments Incorporated PACKAGE OPTION ADDENDUM www.ti.com 29-May-2015 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan Lead/Ball Finish MSL Peak Temp (2) (6) (3) Op Temp (°C) Device Marking (4/5) 7703201JA ACTIVE CDIP J 24 1 TBD Call TI N / A for Pkg Type -55 to 125 7703201JA CD4515BF3A CD4514BE LIFEBUY PDIP N 24 15 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type -55 to 125 CD4514BE CD4514BEE4 LIFEBUY PDIP N 24 15 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type -55 to 125 CD4514BE CD4514BF ACTIVE CDIP J 24 1 TBD Call TI N / A for Pkg Type -55 to 125 CD4514BF CD4514BF3A ACTIVE CDIP J 24 1 TBD Call TI N / A for Pkg Type -55 to 125 CD4514BF3A CD4514BM ACTIVE SOIC DW 24 25 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4514BM CD4514BM96 ACTIVE SOIC DW 24 2000 Green (RoHS & no Sb/Br) CU NIPDAU | CU SN Level-1-260C-UNLIM -55 to 125 CD4514BM CD4514BM96E4 ACTIVE SOIC DW 24 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4514BM CD4514BM96G4 ACTIVE SOIC DW 24 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4514BM CD4514BNSR OBSOLETE SO NS 24 TBD Call TI Call TI -55 to 125 CD4514BPWR OBSOLETE TSSOP PW 24 TBD Call TI Call TI -55 to 125 CD4515BE LIFEBUY PDIP N 24 15 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type -55 to 125 CD4515BE CD4515BEE4 LIFEBUY PDIP N 24 15 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type -55 to 125 CD4515BE CD4515BF3A ACTIVE CDIP J 24 1 TBD Call TI N / A for Pkg Type -55 to 125 7703201JA CD4515BF3A CD4515BM ACTIVE SOIC DW 24 25 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4515BM CD4515BM96 ACTIVE SOIC DW 24 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4515BM CD4515BME4 ACTIVE SOIC DW 24 25 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM -55 to 125 CD4515BM (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. Addendum-Page 1 Samples PACKAGE OPTION ADDENDUM www.ti.com 29-May-2015 LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) Eco Plan - The planned eco-friendly classification: Pb-Free (RoHS), Pb-Free (RoHS Exempt), or Green (RoHS & no Sb/Br) - please check http://www.ti.com/productcontent for the latest availability information and additional product content details. TBD: The Pb-Free/Green conversion plan has not been defined. Pb-Free (RoHS): TI's terms "Lead-Free" or "Pb-Free" mean semiconductor products that are compatible with the current RoHS requirements for all 6 substances, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, TI Pb-Free products are suitable for use in specified lead-free processes. Pb-Free (RoHS Exempt): This component has a RoHS exemption for either 1) lead-based flip-chip solder bumps used between the die and package, or 2) lead-based die adhesive used between the die and leadframe. The component is otherwise considered Pb-Free (RoHS compatible) as defined above. Green (RoHS & no Sb/Br): TI defines "Green" to mean Pb-Free (RoHS compatible), and free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material) (3) MSL, Peak Temp. - The Moisture Sensitivity Level rating according to the JEDEC industry standard classifications, and peak solder temperature. (4) There may be additional marking, which relates to the logo, the lot trace code information, or the environmental category on the device. (5) Multiple Device Markings will be inside parentheses. Only one Device Marking contained in parentheses and separated by a "~" will appear on a device. If a line is indented then it is a continuation of the previous line and the two combined represent the entire Device Marking for that device. (6) Lead/Ball Finish - Orderable Devices may have multiple material finish options. Finish options are separated by a vertical ruled line. Lead/Ball Finish values may wrap to two lines if the finish value exceeds the maximum column width. Important Information and Disclaimer:The information provided on this page represents TI's knowledge and belief as of the date that it is provided. TI bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. TI has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. TI and TI suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. In no event shall TI's liability arising out of such information exceed the total purchase price of the TI part(s) at issue in this document sold by TI to Customer on an annual basis. OTHER QUALIFIED VERSIONS OF CD4514B, CD4514B-MIL, CD4515B, CD4515B-MIL : • Catalog: CD4514B, CD4515B • Military: CD4514B-MIL, CD4515B-MIL NOTE: Qualified Version Definitions: Addendum-Page 2 PACKAGE OPTION ADDENDUM www.ti.com 29-May-2015 • Catalog - TI's standard catalog product • Military - QML certified for Military and Defense Applications Addendum-Page 3 PACKAGE MATERIALS INFORMATION www.ti.com 25-Jun-2015 TAPE AND REEL INFORMATION *All dimensions are nominal Device Package Package Pins Type Drawing SPQ Reel Reel A0 Diameter Width (mm) (mm) W1 (mm) B0 (mm) K0 (mm) P1 (mm) W Pin1 (mm) Quadrant CD4514BM96 SOIC DW 24 2000 330.0 24.4 10.75 15.7 2.7 12.0 24.0 Q1 CD4514BM96 SOIC DW 24 2000 330.0 24.4 10.75 15.7 2.7 12.0 24.0 Q1 CD4514BM96G4 SOIC DW 24 2000 330.0 24.4 10.75 15.7 2.7 12.0 24.0 Q1 CD4515BM96 SOIC DW 24 2000 330.0 24.4 10.75 15.7 2.7 12.0 24.0 Q1 Pack Materials-Page 1 PACKAGE MATERIALS INFORMATION www.ti.com 25-Jun-2015 *All dimensions are nominal Device Package Type Package Drawing Pins SPQ Length (mm) Width (mm) Height (mm) CD4514BM96 SOIC DW 24 2000 364.0 361.0 36.0 CD4514BM96 SOIC DW 24 2000 367.0 367.0 45.0 CD4514BM96G4 SOIC DW 24 2000 367.0 367.0 45.0 CD4515BM96 SOIC DW 24 2000 367.0 367.0 45.0 Pack Materials-Page 2 MECHANICAL DATA MCDI004A – JANUARY 1995 – REVISED NOVEMBER 1997 J (R-GDIP-T**) CERAMIC DUAL-IN-LINE PACKAGE 24 PINS SHOWN B 13 24 C 1 12 0.065 (1,65) 0.045 (1,14) Lens Protrusion (Lens Optional) 0.010 (0.25) MAX 0.175 (4,45) 0.140 (3,56) 0.090 (2,29) 0.060 (1,53) A Seating Plane 0.018 (0,46) MIN 24 PINS ** DIM ”A” ”B” ”C” NARR 0.125 (3,18) MIN 0.022 (0,56) 0.014 (0,36) 0.100 (2,54) 0.012 (0,30) 0.008 (0,20) 28 WIDE NARR 40 32 WIDE NARR WIDE NARR WIDE MAX 0.624(15,85) 0.624(15,85) 0.624(15,85) 0.624(15,85) 0.624(15,85) 0.624(15,85) 0.624(15,85) 0.624(15,85) MIN 0.590(14,99) 0.590(14,99) 0.590(14,99) 0.590(14,99) 0.590(14,99) 0.590(14,99) 0.590(14,99) 0.590(14,99) MAX 1.265(32,13) 1.265(32,13) 1.465(37,21) 1.465(37,21) 1.668(42,37) 1.668(42,37) 2.068(52,53) 2.068(52,53) MIN 1.235(31,37) 1.235(31,37) 1.435(36,45) 1.435(36,45) 1.632(41,45) 1.632(41,45) 2.032(51,61) 2.032(51,61) MAX 0.541(13,74) 0.598(15,19) 0.541(13,74) 0.598(15,19) 0.541(13,74) 0.598(15,19) 0.541(13,74) 0.598(15,19) MIN 0.514(13,06) 0.571(14,50) 0.514(13,06) 0.571(14,50) 0.514(13,06) 0.571(14,50) 0.514(13,06) 0.571(14,50) 4040084/C 10/97 NOTES: A. B. C. D. E. All linear dimensions are in inches (millimeters). This drawing is subject to change without notice. Window (lens) added to this group of packages (24-, 28-, 32-, 40-pin). This package can be hermetically sealed with a ceramic lid using glass frit. Index point is provided on cap for terminal identification. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 MECHANICAL DATA MPDI008 – OCTOBER 1994 N (R-PDIP-T**) PLASTIC DUAL-IN-LINE PACKAGE 24 PIN SHOWN A 24 13 0.560 (14,22) 0.520 (13,21) 1 12 0.060 (1,52) TYP 0.200 (5,08) MAX 0.610 (15,49) 0.590 (14,99) 0.020 (0,51) MIN Seating Plane 0.100 (2,54) 0.021 (0,53) 0.015 (0,38) 0.125 (3,18) MIN 0.010 (0,25) M PINS ** 0°– 15° 0.010 (0,25) NOM 24 28 32 40 48 52 A MAX 1.270 (32,26) 1.450 (36,83) 1.650 (41,91) 2.090 (53,09) 2.450 (62,23) 2.650 (67,31) A MIN 1.230 (31,24) 1.410 (35,81) 1.610 (40,89) 2.040 (51,82) 2.390 (60,71) 2.590 (65,79) DIM 4040053 / B 04/95 NOTES: A. B. C. D. All linear dimensions are in inches (millimeters). This drawing is subject to change without notice. Falls within JEDEC MS-011 Falls within JEDEC MS-015 (32 pin only) POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 IMPORTANT NOTICE Texas Instruments Incorporated and its subsidiaries (TI) reserve the right to make corrections, enhancements, improvements and other changes to its semiconductor products and services per JESD46, latest issue, and to discontinue any product or service per JESD48, latest issue. Buyers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. All semiconductor products (also referred to herein as “components”) are sold subject to TI’s terms and conditions of sale supplied at the time of order acknowledgment. TI warrants performance of its components to the specifications applicable at the time of sale, in accordance with the warranty in TI’s terms and conditions of sale of semiconductor products. Testing and other quality control techniques are used to the extent TI deems necessary to support this warranty. Except where mandated by applicable law, testing of all parameters of each component is not necessarily performed. TI assumes no liability for applications assistance or the design of Buyers’ products. Buyers are responsible for their products and applications using TI components. To minimize the risks associated with Buyers’ products and applications, Buyers should provide adequate design and operating safeguards. TI does not warrant or represent that any license, either express or implied, is granted under any patent right, copyright, mask work right, or other intellectual property right relating to any combination, machine, or process in which TI components or services are used. Information published by TI regarding third-party products or services does not constitute a license to use such products or services or a warranty or endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the third party, or a license from TI under the patents or other intellectual property of TI. Reproduction of significant portions of TI information in TI data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. TI is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. Resale of TI components or services with statements different from or beyond the parameters stated by TI for that component or service voids all express and any implied warranties for the associated TI component or service and is an unfair and deceptive business practice. TI is not responsible or liable for any such statements. Buyer acknowledges and agrees that it is solely responsible for compliance with all legal, regulatory and safety-related requirements concerning its products, and any use of TI components in its applications, notwithstanding any applications-related information or support that may be provided by TI. Buyer represents and agrees that it has all the necessary expertise to create and implement safeguards which anticipate dangerous consequences of failures, monitor failures and their consequences, lessen the likelihood of failures that might cause harm and take appropriate remedial actions. Buyer will fully indemnify TI and its representatives against any damages arising out of the use of any TI components in safety-critical applications. In some cases, TI components may be promoted specifically to facilitate safety-related applications. With such components, TI’s goal is to help enable customers to design and create their own end-product solutions that meet applicable functional safety standards and requirements. Nonetheless, such components are subject to these terms. No TI components are authorized for use in FDA Class III (or similar life-critical medical equipment) unless authorized officers of the parties have executed a special agreement specifically governing such use. Only those TI components which TI has specifically designated as military grade or “enhanced plastic” are designed and intended for use in military/aerospace applications or environments. Buyer acknowledges and agrees that any military or aerospace use of TI components which have not been so designated is solely at the Buyer's risk, and that Buyer is solely responsible for compliance with all legal and regulatory requirements in connection with such use. TI has specifically designated certain components as meeting ISO/TS16949 requirements, mainly for automotive use. In any case of use of non-designated products, TI will not be responsible for any failure to meet ISO/TS16949. Products Applications Audio www.ti.com/audio Automotive and Transportation www.ti.com/automotive Amplifiers amplifier.ti.com Communications and Telecom www.ti.com/communications Data Converters dataconverter.ti.com Computers and Peripherals www.ti.com/computers DLP® Products www.dlp.com Consumer Electronics www.ti.com/consumer-apps DSP dsp.ti.com Energy and Lighting www.ti.com/energy Clocks and Timers www.ti.com/clocks Industrial www.ti.com/industrial Interface interface.ti.com Medical www.ti.com/medical Logic logic.ti.com Security www.ti.com/security Power Mgmt power.ti.com Space, Avionics and Defense www.ti.com/space-avionics-defense Microcontrollers microcontroller.ti.com Video and Imaging www.ti.com/video RFID www.ti-rfid.com OMAP Applications Processors www.ti.com/omap TI E2E Community e2e.ti.com Wireless Connectivity www.ti.com/wirelessconnectivity Mailing Address: Texas Instruments, Post Office Box 655303, Dallas, Texas 75265 Copyright © 2015, Texas Instruments Incorporated
CD4515BE
1. 物料型号:型号为STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器。
2. 器件简介:该器件是意法半导体(STMicroelectronics)生产的高性能微控制器,广泛应用于工业控制、消费电子等领域。
3. 引脚分配:该器件共有48个引脚,包括电源引脚、地引脚、I/O引脚等。
4. 参数特性:工作电压范围为2.0V至3.6V,工作频率可达72MHz,内置64KB Flash和20KB RAM。
5. 功能详解:具备多种通信接口,如I2C、SPI、UART等,支持多种外设,如ADC、DAC、定时器等。
6. 应用信息:适用于需要高性能处理能力的场合,如电机控制、工业自动化等。
CD4515BE 价格&库存
很抱歉,暂时无法提供与“CD4515BE”相匹配的价格&库存,您可以联系我们找货
