TS19452
AC/DC WLED Driver with Internal MOSFET
Universal Switch Mode
SOP-8
Pin assignment:
1. Drain
8. Ground
2. Drain
7. Ground
3. Drain
6. Ground
4. Vdd
5. Ground
General Description
The TS19452 is a PWM high efficiency LED driver control IC. It allows efficient operation of LED strings from
fixed off-time of approximately 12µS.
en
de
d
voltage source ranging up to 450VDC. It includes an internal high voltage switching MOSFET controlled with
The LED string is driven at constant current, thus providing constant light output and enhanced reliability. The
output current is internally fixed at 100mA. The peak current control scheme provides good regulation of the
output current throughout the universal AC line voltage range of 85~264VAC or DC input voltage of 20~400V
Typical Application Circuit
Features
Constant output current at 100mA(typ)
Universal 85~264VAC operation
Fixed off-time buck converter
Internal 475V power MOSFET
Low inductance value at 4.7mH (typ)
mm
Application
Decorating LED lighting
LED lamps with AC or DC operation.
eco
Ordering Information
Package
Packing
TS19452CS RLG
SOP-8
2.5Kpcs / 13” Reel
tR
Part No.
Note: “G” denote for Halogen Free Product
Absolute Maximum Rating
Symbol
Limit
Unit
VIN to GND
~ +475
V
Supply Current
IDD
400
uA
Power Dissipation @ TA=25ºC
PD
2500
mW
Operating Ambient Temperature
TOPR
-40 to +85
No
Parameter
Input Voltage Range
ºC
Storage Temperature Range
TSTG
-65 to +150
o
Junction Temperature Range
TJ
-40 to +150
o
C
C
o
Thermal Resistance – Junction to Ambient
RθJA
65
C/W
Note: Stresses beyond those listed under ”Absolute Maximum Ratings” may cause permanent damage to the
device. These are stress rating only, and functional operation of the device at these or any other conditions beyond
those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
1/7
Version: A12
TS19452
Electrical Specifications (Ta = 25oC, VDRAIN= 50V, unless otherwise noted)
Function Parameter
Symbol
Test Conditions
Min
Typ
Max
Units
VDD
7.5
V
Drain Supply Voltage
VDRAIN
V
Undervoltage Lockout Threshold
UVLO
VDD rising
5
V
Undervoltage Lockout Hysteresis
∆UVLO
VDD falling
200
mV
IDD
VDD(EXT)=8.5V, VDRAIN=40V
400
µA
VBR
Note 1
Internally Regulated Voltage
Supply Current
d
Internal Regulator
Breakdown Voltage
RDSON
IDRAIN=100mA
Output Capacitance
CDRAIN
VDRAIN=400V
MOSFET Saturation current
ISAT
Current Sense Comparator
ITH
Note 1
mm
Threshold Current
V
100
Ω
1.0
5.0
pF
120
mA
90
110
mA
200
300
400
nS
en
On Resistance
550
de
Output (Drain)
Leading edge Blanking delay
TBLANK
Minimum Turn On-Time
TON(MIN)
650
nS
TOFF
8
12
18
µS
Off-Time Generator
Turn On-Time
Note 1,2
No
tR
Block Diagram
e co
Note 1: The specification which apply over the full operating ambient temperature range of -40ºC
很抱歉,暂时无法提供与“TS19452CS RLG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.00680
- 5+4.08450
- 25+3.58142
- 79+3.49039
- 100+3.35743
- 国内价格 香港价格
- 1+5.387681+0.64410
- 5+4.404675+0.52658
- 25+3.8564525+0.46104
- 100+3.61069100+0.43166
- 国内价格
- 50+3.61019
- 100+3.60930
- 250+3.60842
- 500+3.60753
- 1000+3.60664
