2-8930-125
2-8930-125
    FREDERICK
    Module
    VAC GAUGE MX4A NW25/KF25 NPB
2-8930-125 数据手册
MX4A Convection Active Vacuum Gauge Part Number: 2-8930-1XX Operating Specifications Operating Range Display Digital Communications Analog Output Programmable Set Points Set Point 1 Set Point 2 Supply Voltage Maximum Power Calibration Medium Overpressure Digital Output Resolution Analog Output Resolution Operating Temperature Storage Temperature Bakeout Temperature Brass (PN: -110, -116, -125) Stainless (PN: All Others) Response Time Accuracy (Vertical Mount) 0.1 mTorr to 1 mTorr 1 mTorr to 10 mTorr 10 mTorr to 1000 Torr Analog Output Display Readable Distance 1x10-4 Torr to 1000 Torr OLED RS-485 Selectable 0 V DC to 10 V DC 2 Open collector Relay 22 V DC to 26 V DC 8W Dry air or nitrogen 150 PSI 2 significant digits with exponent 16-bits 0 °C to 50 °C -20 °C to 60 °C 100 °C (electronics removed) 200 °C (electronics removed) ≤2s 0.1 mTorr resolution ±1 mTorr ±10% of reading ±10 mV 3 m (10 ft) Description The Televac® MX4A Active Gauge utilizes an easily replaceable (no screws) Televac 4A convection vacuum sensor. It has a variety of features including a wide range of measurement from 10-4 Torr to 1000 Torr, RS-485 communications, two programmable set points, and a selectable analog output. The bright, color OLED display included on every unit makes it easy to read from a distance and allows settings and calibration to be adjusted at the unit without any additional equipment. Options can be set from four capacitive touch controls located on the top of the unit or through RS-485 communications. The extensive selection of fittings, simplicity of use, ease of sensor replacement, and low cost make this unit an excellent choice for a variety of vacuum applications. Physical Characteristics Housing Electrical Connections Weight with Sensor (typical) Weight without Sensor (typical) Dimensions Aluminum D-Sub 15-pin male 350 g (0.77 lbs) 200 g (0.44 lbs) See dimensional drawings Sample RS-485 Commands (assume default address 0) *0S1 *0R1 *0R2 *0W10001 *0W10002 *0W10003 Read vacuum Read units Read SP1L and SP1H Set units to Pascal Set units to Torr Set units to millibar Applications Heat treatment and vacuum furnaces Thin film deposition and coating processes Cryogenics Pharmaceutical product processes • • • • Visit the Televac website at www.frederickscompany.com for a full list of applications. Analog Output Behavior A full list of commands can be found in the MX4A manual. Benefits • • • • Simple sensor replacement - no screws to remove Low cost with a compact design and color OLED display Excellent accuracy of measurements Exceptional customer service and support Ratings and Compliance • • • • • CE certified to EN 61010-1, EN 61236-1, EN 55011 Certified to CAN/CSA C22.2 No. 61010-1-12 RoHS compliant EAC certified IP40 www.frederickscompany.com sales@frederickscompany.com +1 215 947 2500 mx4a_ds rev L page 1 of 2 MX4A Convection Active Vacuum Gauge Part Number: 2-8930-1XX Electrical Connections Pin 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 Dimensional Drawings Description Analog Out (Ground) RS-485 A (-) SP2 NC SP2 NO SP1 Open Drain Floating Floating Supply Voltage (+) Analog Out (0 to 10) V RS-485 B (+) SP2 Com SP1 Source Floating Floating Supply Voltage (-) Materials Exposed to Vacuum MX4A PN: 2-8930-110, -116, -125 Nickel Glass Gold Tophet Cupron Solder MX4A PN: All Others Nickel Glass Gold Tophet Cupron Stainless Steel Set Points The MX4A has two set points. Set point 1 is an N-Channel 60 V MOSFET open collector. It has a maximum current rating of 1 A. The data sheet can be found at www.vishay.com/docs/69958/si2308bd.pdf. Set point 2 is a relay with a maximum switching voltage of 220 V DC (250 V AC) and a maximum switching current of 2 A. The data sheet can be found at www.te.com/catalog/pn/en/1393788-3. Replacement Sensors and Related Products 4A Nickel Plated Brass Sensor 1/8” NPT NW16 (DN16 ISO-KF) NW25 (DN25 ISO-KF) Part Number 2-2119-010 2-2119-016 2-2119-025 4A Stainless Steel Sensor 1/8” NPT 1/2” Straight NW16 (DN16 ISO-KF) NW25 (DN25 ISO-KF) NW40 (DN40 ISO-KF) 1.33” CF (DN16 ISO-CF-F) 2.75” CF (DN40 ISO-CF-F) Part Number 2-2120-001 2-2120-011 2-2120-030 2-2120-031 2-2120-032 2-2120-050 2-2120-052 Ordering Information MX4A Active Gauge 1/8” NPT Stainless Steel 1/8” NPT Nickel Plated Brass 1/2” Straight Stainless Steel NW16 (DN16 ISO-KF) Nickel Plated Brass NW16 (DN16 ISO-KF) Stainless Steel NW25 (DN25 ISO-KF) Nickel Plated Brass NW25 (DN25 ISO-KF) Stainless Steel NW40 (DN40 ISO-KF) Stainless Steel 1.33” CF (DN16 ISO-CF-F) Stainless Steel 2.75” CF (DN40 ISO-CF-F) Stainless Steel VCR and VCO available upon request Part Number 2-8930-101 2-8930-110 2-8930-111 2-8930-116 2-8930-130 2-8930-125 2-8930-131 2-8930-132 2-8930-150 2-8930-152 D-Sub 6 Conductor Cable (flying leads) 20 ft (6 m) 50 ft (15 m) 100 ft (30 m) Part Number 2-9857-020 2-9857-050 2-9857-100 D-Sub 15 Conductor Cable (flying leads) 20 ft (6 m) 50 ft (15 m) 100 ft (30 m) Part Number 2-9858-020 2-9858-050 2-9858-100 Wall Power Supply 100-240 V AC/47-63 Hz, plug types A, C, G, I Part Number 2-7900-097 Contact Us Televac - The Fredericks Company 2400 Philmont Avenue Huntingdon Valley, PA 19006 MP7ER Active Gauge - This gauge measures high vacuum from 10-8 to 10-2 Torr. Combining it with the MX4A provides a full range (ATM to UHV, 10-8 to 1000 Torr) active gauge measurement solution optimal for heat treat and vacuum furnace applications. Visit the Televac website at www.frederickscompany.com for a full list of products. www.frederickscompany.com web: www.frederickscompany.com email: sales@frederickscompany.com tel: +1 215 947 2500 Disclaimer: Specifications subject to change without notice. The Fredericks Company assumes no responsibility for inaccuracies in product specifications or any liability arising from product use. © 2020 The Fredericks Company sales@frederickscompany.com +1 215 947 2500 mx4a_ds rev L page 2 of 2
2-8930-125 价格&库存
很抱歉,暂时无法提供与“2-8930-125”相匹配的价格&库存,您可以联系我们找货
