CD74HCT73M
CD74HCT73M
    L3HARRIS
    SOIC-14
    IC FF JK TYPE DUAL 1BIT 14SOIC
CD74HCT73M 数据手册
[ /Title (CD74 HC73, CD74 HCT73 ) /Subject (Dual J-K FlipFlop CD54HC73, CD74HC73, CD74HCT73 Data sheet acquired from Harris Semiconductor SCHS134E Dual J-K Flip-Flop with Reset Negative-Edge Trigger February 1998 - Revised September 2003 Features Description • Hysteresis on Clock Inputs for Improved Noise Immunity and Increased Input Rise and Fall Times The ’HC73 and CD74HCT73 utilize silicon gate CMOS technology to achieve operating speeds equivalent to LSTTL parts. They exhibit the low power consumption of standard CMOS integrated circuits, together with the ability to drive 10 LSTTL loads. • Asynchronous Reset • Complementary Outputs These flip-flops have independent J, K, Reset and Clock inputs and Q and Q outputs. They change state on the negative-going transition of the clock pulse. Reset is accomplished asynchronously by a low level input. This device is functionally identical to the HC/HCT107 but differs in terminal assignment and in some parametric limits. • Buffered Inputs • Typical fMAX = 60MHz at VCC = 5V, CL = 15pF, TA = 25oC • Fanout (Over Temperature Range) - Standard Outputs . . . . . . . . . . . . . . . 10 LSTTL Loads - Bus Driver Outputs . . . . . . . . . . . . . 15 LSTTL Loads The HCT logic family is functionally as well as pin compatible with the standard LS logic family. • Wide Operating Temperature Range . . . -55oC to 125oC Ordering Information • Balanced Propagation Delay and Transition Times • Significant Power Reduction Compared to LSTTL Logic ICs PART NUMBER • HC Types - 2V to 6V Operation - High Noise Immunity: NIL = 30%, NIH = 30% of VCC at VCC = 5V • HCT Types - 4.5V to 5.5V Operation - Direct LSTTL Input Logic Compatibility, VIL= 0.8V (Max), VIH = 2V (Min) - CMOS Input Compatibility, Il ≤ 1µA at VOL, VOH TEMP. RANGE (oC) CD54HC73F3A -55 to 125 14 Ld CERDIP CD74HC73E -55 to 125 14 Ld PDIP CD74HC73M -55 to 125 14 Ld SOIC CD74HC73MT -55 to 125 14 Ld SOIC CD74HC73M96 -55 to 125 14 Ld SOIC CD74HCT73E -55 to 125 14 Ld PDIP CD74HCT73M -55 to 125 14 Ld SOIC NOTE: When ordering, use the entire part number. The suffix 96 denotes tape and reel. The suffix T denotes a small-quantity reel of 250. Pinout CD54HC73 (CERDIP) CD74HC73, CD74HCT73 (PDIP, SOIC) TOP VIEW 1CP 1 14 1J 1R 2 13 1Q 1K 3 12 1Q VCC 4 11 GND 2CP 5 10 2K 2R 6 9 2Q 2J 7 8 2Q CAUTION: These devices are sensitive to electrostatic discharge. Users should follow proper IC Handling Procedures. Copyright © 2003, Texas Instruments Incorporated PACKAGE 1 CD54HC73, CD74HC73, CD74HCT73 Functional Diagram 14 12 1J 1Q 3 1K FF 1 13 1Q 1 1CP 2 1R 7 9 2J 10 2K 2Q FF 2 8 5 2Q 6 GND = 11 VCC = 4 2CP 2R TRUTH TABLE INPUTS R H L X ↓ OUTPUTS CP J K Q Q L X X X L H H ↓ L L H ↓ H L H L H ↓ L H L H H ↓ H H Toggle H H X X No Change No Change =High Level (Steady State) =Low Level (Steady State) = Irrelevant = High-to-Low Transition Logic Diagram 14 (7) J 3(10) K nA CL R 2 (6) R 2 12 (9) Q K CL 1 (5) CP J 13 (8) Q CD54HC73, CD74HC73, CD74HCT73 Absolute Maximum Ratings Thermal Information DC Supply Voltage, VCC . . . . . . . . . . . . . . . . . . . . . . . . -0.5V to 7V DC Input Diode Current, IIK For VI < -0.5V or VI > VCC + 0.5V . . . . . . . . . . . . . . . . . . . . . .±20mA DC Drain Current, per Output, IO For -0.5V < VO < VCC + 0.5V. . . . . . . . . . . . . . . . . . . . . . . . . .±25mA DC Output Diode Current, IOK For VO < -0.5V or VO > VCC + 0.5V . . . . . . . . . . . . . . . . . . . .±20mA DC Output Source or Sink Current per Output Pin, IO For VO > -0.5V or VO < VCC + 0.5V . . . . . . . . . . . . . . . . . . . .±25mA DC VCC or Ground Current, ICC . . . . . . . . . . . . . . . . . . . . . . . . .±50mA Thermal Resistance (Typical, Note 1) θJA (oC/W) E (PDIP) Package . . . . . . . . . . . . . . . . . . . . . . . . . . 80 M (SOIC) Package. . . . . . . . . . . . . . . . . . . . . . . . . . 86 Maximum Junction Temperature (Hermetic Package or Die) . . . 175oC Maximum Junction Temperature (Plastic Package) . . . . . . . . 150oC Maximum Storage Temperature Range . . . . . . . . . .-65oC to 150oC Maximum Lead Temperature (Soldering 10s) . . . . . . . . . . . . . 300oC (SOIC - Lead Tips Only) Operating Conditions Temperature Range (TA) . . . . . . . . . . . . . . . . . . . . . -55oC to 125oC Supply Voltage Range, VCC HC Types . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .2V to 6V HCT Types . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .4.5V to 5.5V DC Input or Output Voltage, VI, VO . . . . . . . . . . . . . . . . . 0V to VCC Input Rise and Fall Time 2V . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1000ns (Max) 4.5V. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 500ns (Max) 6V . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 400ns (Max) CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTE: 1. The package thermal impedance is calculated in accordance with JESD 51-7. DC Electrical Specifications TEST CONDITIONS PARAMETER SYMBOL VI (V) VIH - 25oC IO (mA) VCC (V) -40oC TO 85oC -55oC TO 125oC MIN TYP MAX MIN MAX MIN MAX UNITS 2 1.5 - - 1.5 - 1.5 - V 4.5 3.15 - - 3.15 - 3.15 - V 6 4.2 - - 4.2 - 4.2 - V 2 - - 0.5 - 0.5 - 0.5 V 4.5 - - 1.35 - 1.35 - 1.35 V 6 - - 1.8 - 1.8 - 1.8 V HC TYPES High Level Input Voltage Low Level Input Voltage High Level Output Voltage CMOS Loads VIL VOH - VIH or VIL High Level Output Voltage TTL Loads Low Level Output Voltage CMOS Loads VOL VIH or VIL Low Level Output Voltage TTL Loads Input Leakage Current II VCC or GND - - -0.02 2 1.9 - - 1.9 - 1.9 - V -0.02 4.5 4.4 - - 4.4 - 4.4 - V -0.02 6 5.9 - - 5.9 - 5.9 - V - - - - - - - - - V -4 4.5 3.98 - - 3.84 - 3.7 - V -5.2 6 5.48 - - 5.34 - 5.2 - V 0.02 2 - - 0.1 - 0.1 - 0.1 V 0.02 4.5 - - 0.1 - 0.1 - 0.1 V 0.02 6 - - 0.1 - 0.1 - 0.1 V - - - - - - - - - V 4 4.5 - - 0.26 - 0.33 - 0.4 V 5.2 6 - - 0.26 - 0.33 - 0.4 V - 6 - - ±0.1 - ±1 - ±1 µA 3 CD54HC73, CD74HC73, CD74HCT73 DC Electrical Specifications (Continued) TEST CONDITIONS SYMBOL VI (V) ICC VCC or GND 0 High Level Input Voltage VIH - Low Level Input Voltage VIL High Level Output Voltage CMOS Loads VOH PARAMETER Quiescent Device Current 25oC IO (mA) VCC (V) -40oC TO 85oC -55oC TO 125oC MIN TYP MAX MIN MAX MIN MAX UNITS 6 - - 4 - 40 - 80 µA - 4.5 to 5.5 2 - - 2 - 2 - V - - 4.5 to 5.5 - - 0.8 - 0.8 - 0.8 V VIH or VIL -0.02 4.5 4.4 - - 4.4 - 4.4 - V -4 4.5 3.98 - - 3.84 - 3.7 - V 0.02 4.5 - - 0.1 - 0.1 - 0.1 V 4 4.5 - - 0.26 - 0.33 - 0.4 V ±0.1 - ±1 - ±1 µA HCT TYPES High Level Output Voltage TTL Loads Low Level Output Voltage CMOS Loads VOL VIH or VIL Low Level Output Voltage TTL Loads Input Leakage Current Quiescent Device Current Additional Quiescent Device Current Per Input Pin: 1 Unit Load II VCC and GND - 5.5 - ICC VCC or GND 0 5.5 - - 4 - 40 - 80 µA ∆ICC (Note 2) VCC - 2.1 - 4.5 to 5.5 - 100 360 - 450 - 490 µA NOTE: 2. For dual-supply systems theoretical worst case (VI = 2.4V, VCC = 5.5V) specification is 1.8mA. HCT Input Loading Table INPUT UNIT LOADS All 0.3 HC TYPES NOTE: Unit Load is ∆ICC limit specified in DC Electrical Specifications table, e.g., 360µA max at 25oC. HCT TYPES Input Level VCC 3V VS 50% VCC 1.3V NOTE: Transition times and propagation delay times Prerequisite For Switching Specifications PARAMETER SYMBOL TEST CONDITIONS 25oC -40oC TO 85oC -55oC TO 125oC VCC (V) MIN TYP MAX MIN MAX MIN MAX UNITS 2 80 - - 100 - 120 - ns 4.5 16 - - 20 - 24 - ns 6 14 - - 17 - 20 - ns 2 80 - - 100 - 120 - ns 4.5 16 - - 20 - 24 - ns 6 14 - - 17 - 20 - ns HC TYPES CP Pulse Width R Pulse Width tw tw -CL = 50pF -CL = 50pF 4 CD54HC73, CD74HC73, CD74HCT73 Prerequisite For Switching Specifications PARAMETER Setup Time, J, K to CP Hold Time, J, K to CP Removal Time CP Frequency SYMBOL tSU tH (Continued) TEST CONDITIONS CL = 50pF CL = 50pF 25oC -40oC TO 85oC -55oC TO 125oC VCC (V) MIN TYP MAX MIN MAX MIN MAX UNITS 2 80 - - 100 - 120 - ns 4.5 16 - - 20 - 24 - ns 6 14 - - 17 - 20 - ns 2 3 - - 3 - 3 - ns 4.5 3 - - 3 - 3 - ns 6 3 - - 3 - 3 - ns 2 80 - - 100 - 120 - ns 4.5 16 - - 20 - 24 - ns 6 14 - - 17 - 20 - ns 2 6 - - 5 - 4 - MHz 4.5 30 - - 25 - 20 - MHz CL = 15pF 5 - 60 - - - - - MHz CL = 50pF 6 35 - - 29 - 23 - MHz tw CL = 50pF 4.5 16 - - 20 - 24 - ns tREM fMAX -CL = 50pF CL = 50pF HCT TYPES CP Pulse Width R Pulse Width tw CL = 50pF 4.5 18 - - 23 - 27 - ns Setup Time, J, K to CP tSU CL = 50pF 4.5 16 - - 20 - 24 - ns Hold Time, J, K to CP tH CL = 50pF 4.5 3 - - 3 - 3 - ns Removal Time tREM CL = 50pF 4.5 12 - - 15 - 18 - ns CP Frequency fMAX CL = 50pF 4.5 30 - - 25 - 20 - MHz CL = 15pF 5 - 60 - - - - - MHz Switching Specifications Input tr, tf = 6ns PARAMETER SYMBOL TEST CONDITIONS tPLH, tPHL CL = 50pF 25oC -40oC TO 85oC -55oC TO 125oC VCC (V) MIN TYP MAX MIN MAX MIN MAX UNITS 2 - - 160 - 200 - 240 ns 4.5 - - 32 - 40 - 48 ns CL = 15pF 5 - 13 - - - - - ns CL = 50pF 6 - - 28 - 34 - 41 ns CL = 50pF 2 - - 160 - 200 - 240 ns HC TYPES Propagation Delay, CP to Q Propagation Delay, CP to Q Propagation Delay, R to Q, Q Output Transition Time tPLH, tPHL tPLH, tPHL tTLH, tTHL 4.5 - - 32 - 40 - 48 ns CL = 15pF 5 - 13 - - - - - ns CL = 50pF 6 - - 28 - 34 - 41 ns CL = 50pF 2 - - 145 - 180 - 220 ns 4.5 - - 29 - 36 - 44 ns CL = 15pF 5 - 12 - - - - - ns CL = 50pF 6 - - 25 - 31 - 38 ns CL = 50pF 2 - - 75 - 95 18 110 ns 4.5 - - 15 - 19 - 22 ns 6 - - 13 - 16 - 19 ns 5 CD54HC73, CD74HC73, CD74HCT73 Switching Specifications Input tr, tf = 6ns PARAMETER Input Capacitance Power Dissipation Capacitance (Notes 3, 4) (Continued) 25oC -40oC TO 85oC -55oC TO 125oC SYMBOL TEST CONDITIONS VCC (V) MIN TYP MAX MIN MAX MIN MAX UNITS CI - - - - 10 - 10 - 10 pF CPD - 5 - 28 - - - - - pF HCT TYPES Propagation Delay, CP to Q tPLH, tPHL CL = 50pF 4.5 - - 38 - 48 - 57 ns Propagation Delay, CP to Q tPLH, tPHL CL = 50pF 4.5 - - 36 - 45 - 54 ns Propagation Delay, R to Q, Q tPLH, tPHL CL = 50pF 4.5 - - 34 - 43 - 51 ns Output Transition Time tTLH, tTHL CL = 50pF 4.5 - - 15 - 19 - 22 ns Input Capacitance Power Dissipation Capacitance (Notes 3, 4) CI - - - - 10 - 10 - 10 pF CPD - 5 - 28 - - - - - pF NOTES: 3. CPD is used to determine the dynamic power consumption, per flip-flop. 4. PD = CPD VCC2 fi + Σ CL VCC2 fo where fi = input frequency, fo = output frequency, CL = output load capacitance, VCC = supply voltage. Test Circuits and Waveforms tfCL trCL CLOCK tWL + tWH = 90% 10% I tr = 6ns FIGURE 3. HCT CLOCK PULSE RISE AND FALL TIMES AND PULSE WIDTH tf = 6ns tr = 6ns VCC GND tTLH GND tTHL 90% 50% 10% INVERTING OUTPUT 3V 2.7V 1.3V 0.3V INPUT tTHL GND tWH NOTE: Outputs should be switching from 10% VCC to 90% VCC in accordance with device truth table. For fMAX, input duty cycle = 50%. tf = 6ns 90% 50% 10% 1.3V 1.3V tWL FIGURE 2. HC CLOCK PULSE RISE AND FALL TIMES AND PULSE WIDTH tPHL 1.3V 0.3V tWH NOTE: Outputs should be switching from 10% VCC to 90% VCC in accordance with device truth table. For fMAX, input duty cycle = 50%. INPUT 2.7V 0.3V GND tWL I fCL 3V CLOCK 50% 50% tfCL = 6ns fCL VCC 50% 10% tWL + tWH = trCL = 6ns tTLH 90% 1.3V 10% INVERTING OUTPUT tPHL tPLH FIGURE 4. HC AND HCU TRANSITION TIMES AND PROPAGATION DELAY TIMES, COMBINATION LOGIC tPLH FIGURE 5. HCT TRANSITION TIMES AND PROPAGATION DELAY TIMES, COMBINATION LOGIC 6 CD54HC73, CD74HC73, CD74HCT73 Test Circuits and Waveforms trCL tfCL trCL CLOCK INPUT (Continued) VCC 90% GND tH(H) GND tH(H) VCC DATA INPUT 50% tH(L) 3V 1.3V 1.3V 1.3V GND tSU(H) tSU(H) tSU(L) tTLH 90% OUTPUT tTHL 90% 50% 10% tTLH 90% 1.3V OUTPUT tREM 3V SET, RESET OR PRESET GND tTHL 1.3V 10% FIGURE 6. HC SETUP TIMES, HOLD TIMES, REMOVAL TIME, AND PROPAGATION DELAY TIMES FOR EDGE TRIGGERED SEQUENTIAL LOGIC CIRCUITS tPHL 1.3V GND IC CL 50pF GND 90% tPLH 50% IC tSU(L) tPHL tPLH tREM VCC SET, RESET OR PRESET 1.3V 0.3V tH(L) DATA INPUT 3V 2.7V CLOCK INPUT 50% 10% tfCL CL 50pF FIGURE 7. HCT SETUP TIMES, HOLD TIMES, REMOVAL TIME, AND PROPAGATION DELAY TIMES FOR EDGE TRIGGERED SEQUENTIAL LOGIC CIRCUITS 7 PACKAGE OPTION ADDENDUM www.ti.com 6-Feb-2020 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan Lead/Ball Finish MSL Peak Temp (2) (6) (3) Op Temp (°C) Device Marking (4/5) 5962-8515301CA ACTIVE CDIP J 14 1 TBD Call TI N / A for Pkg Type -55 to 125 5962-8515301CA CD54HC73F3A CD54HC73F ACTIVE CDIP J 14 1 TBD Call TI N / A for Pkg Type -55 to 125 CD54HC73F CD54HC73F3A ACTIVE CDIP J 14 1 TBD Call TI N / A for Pkg Type -55 to 125 5962-8515301CA CD54HC73F3A CD74HC73E ACTIVE PDIP N 14 25 Green (RoHS & no Sb/Br) NIPDAU N / A for Pkg Type -55 to 125 CD74HC73E CD74HC73EE4 ACTIVE PDIP N 14 25 Green (RoHS & no Sb/Br) NIPDAU N / A for Pkg Type -55 to 125 CD74HC73E CD74HC73M ACTIVE SOIC D 14 50 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 HC73M CD74HC73M96 ACTIVE SOIC D 14 2500 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 HC73M CD74HC73MT ACTIVE SOIC D 14 250 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 HC73M CD74HCT73E ACTIVE PDIP N 14 25 Green (RoHS & no Sb/Br) NIPDAU N / A for Pkg Type -55 to 125 CD74HCT73E CD74HCT73EE4 ACTIVE PDIP N 14 25 Green (RoHS & no Sb/Br) NIPDAU N / A for Pkg Type -55 to 125 CD74HCT73E CD74HCT73M ACTIVE SOIC D 14 50 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 HCT73M (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
CD74HCT73M
### 物料型号: - CD54HC73F3A - CD74HC73E - CD74HC73M - CD74HC73MT - CD74HC73M96 - CD74HCT73E - CD74HCT73M
### 器件简介: CD54HC73, CD74HC73, CD74HCT73 是德州仪器生产的双J-K触发器,具有复位功能和负边沿触发。
这些触发器使用硅门CMOS技术,实现与LSTTL部件相当的操作速度,同时具有标准CMOS集成电路的低功耗特性,能够驱动10个LSTTL负载。
### 引脚分配: - HC73 和 CD74HCT73 使用硅门CMOS技术,具有独立的J、K、复位和时钟输入,以及Q和Q输出。
- 引脚分配如下: - 1J, 1Q, 1R, 1CP - 2J, 2Q, 2K, 2R, 2CP - VCC, GND
### 参数特性: - 工作温度范围:-55°C 至 125°C - 供电电压范围: - HC 类型:2V 至 6V - HCT 类型:4.5V 至 5.5V - 输入电流: - HC 类型:在5V供电时,输入电流为30% VCC - HCT 类型:在5V供电时,输入电流为1µA(或更少) - 输出电流: - 标准输出:能够驱动10个LSTTL负载 - 总线驱动输出:能够驱动15个LSTTL负载 - 最大工作频率:在5V供电、15pF负载电容下,典型值为60MHz
### 功能详解: - 这些触发器在时钟脉冲的负跳变时改变状态。
- 复位通过低电平输入异步完成。
- HC/HCT107功能上相同,但引脚分配和一些参数限制不同。
- HCT逻辑系列在功能和引脚上与标准LS逻辑系列兼容。
### 应用信息: - 适用于需要高速操作和低功耗的应用,如数字电路和微处理器系统。
### 封装信息: - CD54HC73F3A:14引脚CERDIP封装 - CD74HC73E:14引脚PDIP封装 - CD74HC73M:14引脚SOIC封装 - CD74HC73MT:14引脚SOIC封装 - CD74HC73M96:14引脚SOIC封装 - CD74HCT73E:14引脚PDIP封装 - CD74HCT73M:14引脚SOIC封装
注意:这些设备对静电放电敏感,用户应遵循适当的IC处理程序。
CD74HCT73M 价格&库存
很抱歉,暂时无法提供与“CD74HCT73M”相匹配的价格&库存,您可以联系我们找货
