IS31FL3729-QFLS4-TR
IS31FL3729-QFLS4-TR
    LUMISSIL
    QFN-32_4X4MM-EP
    IC 168/159 MATRIX LED DRIVER, 32
IS31FL3729-QFLS4-TR 数据手册
IS31FL3729 16×8/15×9 MATRIX LED DRIVER January 2021 GENERAL DESCRIPTION FEATURES The IS31FL3729 is a general purpose 16×8 or 15×9 matrix LED driver programmed via a 1MHz I2C bus compatible interface. Each LED can be dimmed individually with 8-bit PWM data, and each CSx has 8-bit DC current scaling for color calibration. The combination enables 256 steps of linear PWM dimming for each dot and 256 steps of DC current adjustment for each CSx.    Additionally, the open or short state of each LED can be detected and stored in Open-Short Registers. The MCU can then read the Open-Short Registers via the I2C bus and identify which LED in the array is open or short. The IS31FL3729 features a very low shutdown and quiescent (operational) current. It also supports selectable noise reduction features such as PWM clock spread spectrum and 180 degree phase shifting. IS31FL3729 is available in QFN-32 (4mm×4mm) and eTQFP-32 packages. It operates from 2.7V to 5.5V over the full temperature range of -40°C to +125°C.            Supply voltage range: 2.7V to 5.5V 16 current sinks Support 16×n (n=1~8), 15×9 LED matrix configurations Individual 256 PWM control steps 256 DC current steps for each CSx 64 global current steps SDB rising edge resets the I2C interface Register programmable PWM frequency: 0.25kHz to 55kHz 1MHz I2C-compatible interface Individual open and short error detect function PWM 180 degree phase shift Spread spectrum De-ghost QFN-32 (4mm×4mm) and eTQFP-32 packages APPLICATIONS   White goods LED display panel. IOT device TYPICAL APPLICATION CIRCUIT Figure 1 Typical Application Circuit (16×8) Note 1: The VIH of I2C bus should be smaller than VCC. And if VIH is lower than 3.0V, it is recommended add a level shift circuit to avoid extra shutdown current. 2 Note 2: These optional resistors are for offloading the thermal dissipation (P=I R) away from the IS31FL3729, for mono red/yellow/orange LED, if PVCC=VCC=3.3V, don’t need these resistors. Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 1 IS31FL3729 TYPICAL APPLICATION CIRCUIT (CONTINUED) Figure 2 Figure 3 Typical Application Circuit (15×9) Typical Application Circuit (45 RGBs) 2 Note 3: These optional resistors are for offloading the thermal dissipation (P=I R) away from the IS31FL3729, for red LED, it is recommended to use about 30Ohm more than blue/green LED, to offload more extra voltage due to lower forward voltage of red LED. Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 2 IS31FL3729 PIN CONFIGURATION eTQFP-32 25 ISET 26 SDA 27 SCL 28 AD 29 SDB 30 CS1 21 SW2 CS8 5 20 SW3 CS9 6 19 SW4 CS10 7 18 SW5 CS11 8 17 SW6 SW7 16 CS7 4 SW8 15 22 SW1 SW9/CS16 14 CS6 3 CS15 13 23 VCC CS14 12 CS5 2 CS13 11 24 GND CS12 10 CS4 1 GND 9 QFN-32 31 CS2 Pin Configuration (Top View) 32 CS3 Package CS4 1 24 GND CS5 2 23 VCC CS6 3 22 SW1 CS7 4 21 SW2 CS8 5 20 SW3 CS9 6 19 SW4 CS10 7 18 SW5 CS11 8 17 SW6 Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 3 IS31FL3729 PIN DESCRIPTION No. Pin Description 1~8, 10~13 CS4~CS15 Current sinks output. 9,24 GND Ground. 14 SW9/CS16 Switch power source. 15~22 SW8~SW1 Switch power source. 23 VCC Power supply. 25 ISET Current setting pin. 26 SDA Serial data. 27 SCL Serial clock. 28 AD I2C Address setting. 29 SDB Shutdown the chip when pull to low. 30~32 CS1~CS3 Current sinks output. Thermal Pad Need to connect to GND pins. Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 4 IS31FL3729 ORDERING INFORMATION Industrial Range: -40°C to +125°C Order Part No. Package QTY/Reel IS31FL3729-QFLS4-TR IS31FL3729-TQLS4-TR QFN-32, Lead-free eTQFP-32, Lead-free 2500 Copyright  ©  2020  Lumissil  Microsystems.  All  rights  reserved.  Lumissil  Microsystems  reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use in  such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 5 IS31FL3729 ABSOLUTE MAXIMUM RATINGS Supply voltage, VCC Voltage at any input pin Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TA=TJ Package thermal resistance, junction to ambient (4 layer standard test PCB based on JESD 51-2A), θJA ESD (HBM) ESD (CDM) -0.3V ~+6.0V -0.3V ~ VCC+0.3V +150°C -65°C ~+150°C -40°C ~ +125°C 52.2°C/W (QFN) 36.1°C/W (eTQFP) ±8kV ±750V Note 4: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS The following specifications apply for VCC = 5V, TA = 25°C, unless otherwise noted. Symbol Parameter VCC Supply voltage ICC Quiescent power supply current ISD Shutdown current IOUT ILED Conditions Min. Typ. 2.7 Max. Unit 5.5 V mA VSDB=VCC, all LEDs off 2 3 VSDB=0V 3 5 VSDB= VCC, Configuration Register written “0000 0000” 3 5 Maximum constant current of CSx RISET=10kΩ, GCC= “100 0000” SL=0xFF 35 mA Average current on each LED ILED = IOUT(PEAK)/Duty RISET=10kΩ, GCC= “100 0000” SL=0xFF, n=8, Duty=1/8.29 4.22 mA Current switch headroom voltage SWx ISWITCH=600mA RISET=10kΩ, GCC= “100 0000”, SL=0xFF 500 Current sink headroom voltage CSx ISINK=34mA, RISET=10kΩ, GCC= “100 0000”, SL=0xFF 400 tSCAN Period of scanning B2h= “0x01” (PWM frequency = 32kHz) 30 µs tNOL1 Non-overlap blanking time during B2h= “0x01” scan, the SWx and CSy are all off (PWM frequency = 32kHz) during this time 0.8 µs tNOL2 Delay total time for CS1 to CS16, during this time, the SWx is on but CSx is not all turned on 0.27 µs VHR μA 550 mV B2h= “0x01” (PWM frequency = 32kHz) 500 Logic Electrical Characteristics (SDA, SCL, AD, SDB) VIL Logic “0” input voltage VCC=2.7V~5.5V, LGC= “0” GND 0.4 V VIH Logic “1” input voltage VCC=2.7V~5.5V, LGC= “0” 1.4 VCC V VIL Logic “0” input voltage VCC=2.7V~5.5V, LGC= “1” GND 0.6 V VIH Logic “1” input voltage VCC=2.7V~5.5V, LGC= “1” 2.4 VCC V Input schmitt trigger hysteresis VCC=3.6V, LGC= “0”, LGC= “1” IIL Logic “0” input current IIH Logic “1” input current VHYS Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 0.2 V SDB=L, VINPUT= L (Note 5) 5 nA SDB=L, VINPUT= H (Note 5) 5 nA 6 IS31FL3729 DIGITAL INPUT I2C SWITCHING CHARACTERISTICS (NOTE 5) Fast Mode Symbol Parameter Min. Typ. Max. fSCL Serial-clock frequency tBUF Fast Mode Plus Min. Typ. Max. Units - 400 - 1000 kHz Bus free time between a STOP and a START condition 1.3 - 0.5 - μs tHD, STA Hold time (repeated) START condition 0.6 - 0.26 - μs tSU, STA Repeated START condition setup time 0.6 - 0.26 - μs tSU, STO STOP condition setup time 0.6 - 0.26 - μs tHD, DAT Data hold time - - - - μs tSU, DAT Data setup time 100 - 50 - ns tLOW SCL clock low period 1.3 - 0.5 - μs tHIGH SCL clock high period 0.7 - 0.26 - μs tR Rise time of both SDA and SCL signals, receiving - 300 - 120 ns tF Fall time of both SDA and SCL signals, receiving - 300 - 120 ns Note 5: Guaranteed by design. Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 7 IS31FL3729 FUNCTIONAL BLOCK DIAGRAM ISET VCC Global Curr ent 64 Step s Bias Trim Bandgap SDB OSC SSD Con fig SWX Seq uence SDA SCL I2C Interface PWM Cou nter 1 Pointer PWM PWM Cou nter 16 AD Scan Switch Curren t Sink CS1~CS16 SW1~SW9 Scaling Pull-down Resister Selection Ope n/Short Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 Ghost Eliminatin g GND 8 IS31FL3729 DETAILED DESCRIPTION I2C INTERFACE IS31FL3729 uses a serial bus, which conforms to the I2C protocol, to control the chip’s functions with two wires: SCL and SDA. The IS31FL3729 has a 7-bit slave address (A7:A1), followed by the R/W bit, A0. Set A0 to “0” for a write command and set A0 to “1” for a read command. The value of bits A1 and A2 are decided by the connection of the AD pin. Table 1 Slave Address AD A7:A3 A2:A1 GND SCL SDA A0 00 01101 VCC 01 10 0/1 11 AD connected to GND, A2:A1=00; AD connected to VCC, A2:A1=11; AD connected to SCL, A2:A1=01; AD connected to SDA, A2:A1=10; The SCL line is uni-directional. The SDA line is bi-directional (open-collector) with a pull-up resistor (typically 400kHz I2C with 4.7kΩ, 1MHz I2C with 2kΩ). The maximum clock frequency specified by the I2C standard is 1MHz. In this discussion, the master is the microcontroller and the slave is the IS31FL3729. The timing diagram for the I2C is shown in Figure 4. The SDA is latched in on the stable high level of the SCL. When there is no interface activity, the SDA line should be held high. The “START” signal is generated by lowering the SDA signal while the SCL signal is high. The start signal will alert all devices attached to the I2C bus to check the incoming address against their own chip address. The 8-bit chip address is sent next, most significant bit first. Each address bit must be stable while the SCL level is high. After the last bit of the chip address is sent, the master checks for the IS31FL3729’s acknowledge. The master Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 releases the SDA line high (through a pull-up resistor). Then the master sends an SCL pulse. If the IS31FL3729 has received the address correctly, then it holds the SDA line low during the SCL pulse. If the SDA line is not low, then the master should send a “STOP” signal (discussed later) and abort the transfer. Following acknowledge of IS31FL3729, the register address byte is sent, most significant bit first. IS31FL3729 must generate another acknowledge indicating that the register address has been received. Then 8-bit of data byte are sent next, most significant bit first. Each data bit should be valid while the SCL level is stable high. After the data byte is sent, the IS31FL3729 must generate another acknowledge to indicate that the data was received. The “STOP” signal ends the transfer. To signal “STOP”, the SDA signal goes high while the SCL signal is high. ADDRESS AUTO INCREMENT To write multiple bytes of data into IS31FL3729, load the address of the data register that the first data byte is intended for. During the IS31FL3729 acknowledge of receiving the data byte, the internal address pointer will increment by one. The next data byte sent to IS31FL3729 will be placed in the new address, and so on. The auto increment of the address will continue as long as data continues to be written to IS31FL3729 (Figure 7). READING OPERATION Most of the registers can be read. To read the register, after I2C start condition, the bus master must send the IS31FL3729 device address ____ with the R/W bit set to “0”, followed by the register address which determines which register is accessed. Then restart I2C, the bus master should send the ____ IS31FL3729 device address with the R/W bit set to “1”. Data from the register defined by the command byte is then sent from the IS31FL3729 to the master (Figure 8). 9 IS31FL3729 Figure 4 I2C Interface Timing Figure 5 Figure 6 Figure 7 I2C Bit Transfer I2C Writing to IS31FL3729 (Typical) I2C Writing to IS31FL3729 (Automatic Address Increment) Figure 8 Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 I2C Reading from IS31FL3729 10 IS31FL3729 Table 5 Register Definition Address Name Function Table R/W Default 01h~8Fh PWM Register Set PWM value for LED 6 R/W 0000 0000 90h~9Fh Scaling Register Control the DC output current of each CSy 7 R/W 0000 0000 A0h Configuration Register Configure the operation mode 8 R/W 0000 0000 A1h Global Current Control Register Set the global current 9 R/W 0000 0000 B0h Pull Down/Up Resistor Selection Register Set the pull down resistor for SWx and pull up resistor for CSy 10 R/W 0011 0011 B1h Spread Spectrum Register Spread spectrum function enable 11 R/W 0000 0000 B2h PWM Frequency Register Set the PWM frequency 12 R/W 0000 0001 Open/Short Register Store the open or short information 13 R/W 0000 0000 Reset Register Reset all register to POR state - W 0000 0000 B3h~C4h CFh Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 11 IS31FL3729 PWM Register T01 T02 T03 T04 T05 T06 T07 T08 T09 VCC SW1 SW2 SW3 SW4 SW5 SW6 SW7 SW8 SW9 PWM PWM PWM CS16 10 20 30 40 50 60 70 80 90 CS15 0F 1F 2F 3F 4F 5F 6F 7F 8F CS14 0E 1E 2E 3E 4E 5E 6E 7E 8E 16×8 15×9 Y X PWM PWM PWM CS3 03 13 23 33 43 53 63 73 83 CS2 02 12 22 32 42 52 62 72 82 01 11 21 31 41 51 61 71 81 CS1 Figure 9 Table 6 01h~8Fh PWM Register Duty  Bit D7:D0 Name PWM Default 0000 0000 PWM  I OUT ( PEAK )  Duty 256 PWM  (1) 7  D[n ]  2 n n 0 Where Duty is the duty cycle of SWx, when n=9, Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 30s 1 1   30s  0.8s  0.27s 9 9.32 (2) When n=8, Each dot has a byte to modulate the PWM duty in 256 steps. The PWM clock frequency is set by the PWM Frequency Register (B2h). The following calculations assume B2h is configured for 32kHz PWM, B2h= “0x01” for tSCAN=30µs, the period of scanning and 0.8μs is tNOL1, the non-overlap time and 0.27μs is the CSx delay time. The value of the PWM Registers decides the average current of each LED noted ILED. ILED computed by Formula (1): I LED  PWM Register Duty  30s 1 1   30s  0.8s  0.27s 8 8.29 (2) IOUT is the output current of CSy (y=1~16), I OUT( PEAK)  342 GCC SL   RISET 64 256 (3) GCC is the Global Current Control Register (A1h) value, SL is the Scaling Register value as Table 9 and RISET is the external resistor of ISET pin. D[n] stands for the individual bit value, 1 or 0, in location n. For example: if D7:D0=1011 0101 (0xB5, 181), GCC= 100 0000, RISET=10kΩ, SL=1111 1111: I LED  342 64 255 1 181     10 k  64 256 9 . 32 256 12 IS31FL3729 Scaling Register T01 T02 T03 T04 T05 T06 T07 T08 T09 VCC SW1 SW2 SW3 SW4 SW5 CS16 9F CS15 9E CS14 9D CS3 92 CS2 91 CS1 90 SW6 SW7 SW8 SW9 Y X Figure 10 IOUT is the output current of CSy (y=1~16), GCC is the Global Current Control Register (A1h) value and RISET is the external resistor of RISET pin. D[n] stands for the individual bit value, 1 or 0, in location n. For example: if RISET=10kΩ, GCC=100 0000, SL=0111 1111: Table 7 90h ~ 9Fh Scaling Register Bit D7:D0 Name SL Default 0000 0000 Scaling register control the DC output current of each CSy. Each CSy has a byte to modulate the scaling in 256 steps. The value of the Scaling Register decides the peak current of each LED noted IOUT(PEAK). IOUT(PEAK) computed by Formula (3): 342 GCC SL IOUT( PEAK)    RISET 64 256 SL  Scaling Register (3) SL  7  D[n]  2 n  127 n0 IOUT  342 64 127    16.9mA 10k 64 256 I LED  16 . 9 mA  1 PWM  9 . 27 256 7  D[n]  2 n n0 Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 13 IS31FL3729 Table 8 A0h Configuration Register Table 9 A1h Global Current Control Register Bit D7:D4 D3 D2:D1 D0 Bit D7 D6:D0 Name SWS LGC OSDE SSD Name - GCC Default 0001 0 00 0 Default 0 000 0000 The Configuration Register sets operating mode of IS31FL3729. SSD 0 1 Software Shutdown Control Software shutdown Normal operation OSDE 00 01/11 10 Open Short Detection Enable Disable open/short detection Enable open detection Enable short detection LGC 0 1 H/L logic 1.4V/0.4V 2.4V/0.6V SWS 0000 0001 0010 SWx Setting n=9, SW1~SW9, 9SW×15CS matrix n=8, SW1~SW8, 8SW×16CS matrix n=7, SW1~SW7, 7SW×16CS matrix, SW8 no-active n=6, SW1~SW6, 6SW×16CS matrix, SW7~SW8 no-active n=5, SW1~SW5, 5SW×16CS matrix, SW6~SW8 no-active n=4, SW1~SW4, 4SW×16CS matrix, SW5~SW8 no-active n=3, SW1~SW3, 3SW×16CS matrix, SW4~SW8 no-active n=2, SW1~SW2, 2SW×16CS matrix, SW3~SW8 no-active SW1~SW9 with same phase, all on. SW1~SW9, SW1~SW9, 9SW×15CS matrix 0011 0100 0101 0110 0111 1000 Others When OSDE set to “01”, open detection will be trigger once, the user could trigger open detection again by set OSDE from “00” to “01”. When OSDE set “10”, short detection will be trigger once, the user could trigger short detection again by set OSDE from “00” to “10”. When SSD is “0”, IS31FL3729 works in software shutdown mode and to normal operate the SSD bit should set to “1”. SWS control the duty cycle of the SWx, default mode is 1/8. Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 The Global Current Control Register modulates all CSy (y=1~16) DC current which is noted as IOUT in 65 steps, maximum GCC is “100 0000”, if GCC> “1000000”, GCC= “100 0000”. IOUT is computed by the Formula (3): IOUT( PEAK)  342 GCC SL   RISET 64 256 7 GCC   D[ n]  2 n n 0 Where D[n] stands for the individual bit value 1 or 0, in location n. Table 10 B0h Pull Down/Up Resistor Selection Register Bit D7 D6:D4 D3 D2:D0 Name PHC SWPDR - CSPUR Default 0 011 0 011 Set pull down resistor for SWx and pull up resistor for CSy. PHC 0 1 Phase choice 0 degree phase delay 180 degree phase delay SWPDR 000 001 010 011 100 101 110 111 SWx Pull down Resistor Selection Bit No pull down resistor 0.5kΩ only in SWx off time 1.0kΩ only in SWx off time 2.0kΩ only in SWx off time 1.0kΩ all the time 2.0kΩ all the time 4.0kΩ all the time 8.0kΩ all the time CSPUR 000 001 010 011 100 101 110 111 CSy Pull up Resistor Selection Bit No pull up resistor 0.5kΩ only in CSx off time 1.0kΩ only in CSx off time 2.0kΩ only in CSx off time 1.0kΩ all the time 2.0kΩ all the time 4.0kΩ all the time 8.0kΩ all the time 14 IS31FL3729 Table 11 B1h Spread Spectrum Register Bit D7:D6 D4 D3:D2 D1:D0 Name - SSP RNG CLT Default 00 0 00 00 When SSP enable, the spread spectrum function will be enabled and the RNG & CLT bits will adjust the range and cycle time of spread spectrum function. SSP 0 1 Spread spectrum function enable Disable Enable RNG 00 01 10 11 Spread spectrum range ±5% ±15% ±24% ±34% Table 13 B3h~C4h Open/Short Register (Read Only) Bit D7:D0 Name CS16:CS09, CS08:CS01 Default 0000 0000 When OSDE (A0h) is set to “01”, open detection will be trigger once, and the open information will be stored at B3h~C4h. When OSDE (A0h) set to “10”, short detection will be trigger once, and the short information will be stored at B3h~C4h. Before set OSDE, the GCC should set to 0x01. T01 T02 SW1 T03 SW2 T04 SW3 T05 SW4 T06 SW5 T07 SW6 T08 SW7 T09 SW8 SW9 VCC CS16 Spread spectrum cycle time 1980μs 1200μs 820μs 660μs CLT 00 01 10 11 CS15 CS14 CS13 CS12 CS11 Table 12 B2h PWM Frequency Bit D7:D3 D2:D0 Name - PWMF Default 00000 001 Set the PWM frequency, default is 32kHz. In order to avoid LED display flicker, it is recommended PWM frequency ÷ n is higher than 100Hz, so when PWM frequency is 0.5kHz, n cannot be more than 4, when PWM frequency is 0.25kHz, n cannot be more than 2. CS10 CS9 CS8 CS7 CS6 CS5 CS4 CS3 PWMF 000 001 010 011 100 101 110 111 PWM frequency setting 55kHz 32kHz 4kHz 2kHz 1kHz 0.5kHz, (n≤4) 0.25KHz, (n≤2) 80kHz Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 CS2 CS1 Figure 11 Open/Short Register CFh Reset Register Once the Reset Register is updated with IS31FL3729 registers will be reset to values. Upon initial power-up, the registers will also reset to their default blank display. 0xAE, all the their default IS31FL3729 values for a 15 IS31FL3729 APPLICATION INFORMATION Scanning cycle T=62.14µs((30µs+0.8µs+0.27µs)×2) (n=2) Scanning cycle T=248.56µs((30µs+0.8µs+0.27µs)×8) (n=8) SW1 SW2 SW3 SW4 SW5 SW6 SW7 SW8 SW9 CS16 CS1 tNOL2=0.27µs tSCAN=30µs tNOL1=0.8µs Scanning cycle T=279.63µs((30µs+0.8µs+0.27µs)×9) (n=9) De-Ghost time PWM Duty is variable from 0/256~255/256 I OUT  342 GCC SL   RISET 256 256 Figure 12 Scanning Timing SCANNING TIMING As shown in Figure above, the SW1~SW9 is turned on by serial, LED is driven 15 by 9 within the SWx (x=1~9) on time (SWx, x=1~9 is source and it is high when LED on) , including the non-overlap blanking time during scan, the duty cycle of SWx (active high, x=1~9) is (n=9): Duty  30s 1 1   30s  0.8s  0.27s 9 9.32 (2) ≥2.4V VCC Or (n=8): Duty  shutdown the state Function Registers can be accessed but all analog circuits are disabled to conserve power. Once VCC stabilizes > 2.4V, a rising edge of the SDB signal will reset the I2C bus and cause the chip to exit hardware shutdown mode. Since there could be I2C bus transactions prior to the rising edge of the SDB pin, it is recommended to allow 10us prior to and after the rising edge before beginning any I2C bus transaction. *Note 6 30s 1 1   30s  0.8s  0.27s 8 8.29 ≥10us *Note 7 (2) Where PWM Frequency Register B2h= “0x01” (PWM frequency = 32kHz) for tSCAN = 30μs, the period of scanning and 0.8μs is tNOL1, the non-overlap time and 0.27μs is the CSx delay time. POWER ON SEQUENCE The IS31FL3729 integrates a power-on reset (POR) feature associated with the input supply voltage VCC. The IS31FL3729 will be initialized when VCC exceeds 2.4V (typ., 2.7V max.) until then all the control circuits and configuration registers will be held in reset while the internal voltage stabilizes (≥2.4V). SDA Initial operation SCL SDB *Note 8 ≥10us ≥10us Reset IIC bus at rising edge Figure 13 SDB Pin Sequence Note 6: There should be no I2C operation 10µs before VCC remain ≥2.4V. Note 7: I2C operation is allowed while SDB is low and VCC ≥2.4V. Note 8: There should be no I2C operation 10µs before and after SDB rising edge. The IS31FL3729 enters a hardware shutdown mode when the SDB pin is pulled low. During hardware Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 16 IS31FL3729 PWM CONTROL 256 After setting the IOUT and GCC, the brightness of each LEDs (LED average current (ILED)) can be modulated with 256 steps by PWM Register, as described in Formula (1). 224 PWM  I OUT ( PEAK )  Duty 256 (1) PWM Data I LED  192 Where PWM is PWM Registers’ (01h~8Fh) data showing in Table 6. 96 32 0 0 4 8 12 16 20 24 28 32 Intensity Steps 342 GCC SL I OUT( PEAK)    RISET 64 256 Figure 14 Gamma Correction (32 Steps) 342 64 255 1 181 (n=9)      10 k  64 256 9 . 32 256 Writing new data continuously to the registers can modulate the brightness of the LEDs to achieve a breathing effect. GAMMA CORRECTION In order to perform a better visual LED breathing effect we recommend using a gamma corrected PWM value to set the LED intensity. This results in a reduced number of steps for the LED intensity setting, but causes the change in intensity to appear more linear to the human eye. Gamma correction, also known as gamma compression or encoding, is used to encode linear luminance to match the non-linear characteristics of display. Since the IS31FL3729 can modulate the brightness of the LEDs with 256 steps, a gamma correction function can be applied when computing each subsequent LED intensity setting such that the changes in brightness matches the human eye's brightness curve. Table 12 32 Gamma Steps with 256 PWM Steps C(0) C(1) C(2) C(3) C(4) C(5) C(6) C(7) 0 1 2 4 6 10 13 18 C(8) C(9) C(10) C(11) C(12) C(13) C(14) C(15) 22 28 33 39 46 53 61 69 C(16) C(17) C(18) C(19) C(20) C(21) C(22) C(23) 78 86 96 106 116 126 138 149 C(24) C(25) C(26) C(27) C(28) C(29) C(30) C(31) 161 173 186 199 212 226 240 255 Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 128 64 For example, in Figure 1, if RISET= 10kΩ, PWM= 1011 0101 (0xB5, 181), and GCC= 100 0000, SL= 1111 1111, then, I LED 160 Choosing more gamma steps provides for a more continuous looking breathing effect. This is useful for very long breathing cycles. The recommended configuration is defined by the breath cycle T. When T=1s, choose 32 gamma steps, when T=2s, choose 64 gamma steps. The user must decide the final number of gamma steps not only by the LED itself, but also based on the visual performance of the finished product. Table 13 64 Gamma Steps with 256 PWM Steps C(0) C(1) C(2) C(3) C(4) C(5) C(6) C(7) 0 1 2 3 4 5 6 7 C(8) C(9) C(10) C(11) C(12) C(13) C(14) C(15) 8 10 12 14 16 18 20 22 C(16) C(17) C(18) C(19) C(20) C(21) C(22) C(23) 24 26 29 32 35 38 41 44 C(24) C(25) C(26) C(27) C(28) C(29) C(30) C(31) 47 50 53 57 61 65 69 73 C(32) C(33) C(34) C(35) C(36) C(37) C(38) C(39) 77 81 85 89 94 99 104 109 C(40) C(41) C(42) C(43) C(44) C(45) C(46) C(47) 114 119 124 129 134 140 146 152 C(48) C(49) C(50) C(51) C(52) C(53) C(54) C(55) 158 164 170 176 182 188 195 202 C(56) C(57) C(58) C(59) C(60) C(61) C(62) C(63) 209 216 223 230 237 244 251 255 17 IS31FL3729 256 architecture any parasitic capacitance found in the constant-current outputs or the PCB traces to the LEDs may provide sufficient current to dimly light an LED to create a ghosting effect. 224 PWM Data 192 To prevent this LED ghost effect, the IS31FL3729 has integrated Pull down resistors for each SWx (x=1~9) and Pull up resistors for each CSy (y=1~16). Select the right SWx Pull down resistor (B0h) and CSy Pull up resistor (B0h) which eliminates the ghost LED for a particular matrix layout configuration. 160 128 96 64 Typically, selecting the 2kΩ will be sufficient to eliminate the LED ghost phenomenon. 32 0 0 8 16 24 32 40 48 56 64 Intensity Steps Figure 15 Gamma Correction (64 Steps) Note: The data of 32 gamma steps is the standard value and the data of 64 gamma steps is the recommended value. OPERATING MODE IS31FL3729 can only operate in PWM Mode. The brightness of each LED can be modulated with 256 steps by PWM registers. For example, if the data in PWM Register is “0000 0100”, then the PWM is the fourth step. Writing new data continuously to the registers can modulate the brightness of the LEDs to achieve a breathing effect. OPEN/SHORT DETECT FUNCTION IS31FL3729 has individual LED open and short detection capability. By setting the OSDE bits of the Configuration Register (A0h) from “00” to “01” or “10”, the LED Open/short Register will begin storing the open/short information. After 2 scan cycles, the MCU can read the open/short information stored in registers B3h~C4h. The open/short data will not get refreshed while setting the OSDE bit of the Configuration Register. There are two configurations which need to be set prior to configuring the the OSDE bits: 1) 0x0F≤A1h≤0x40 adjust LED current 2) B0h=0x00, disable pullup/pulldown resistors Where A1h is the Global Current Control Register and B0h is the Pull Down/UP Resistor Selection Register. The detect action is one-time event, so each time before reading out the open/short information, the OSDE bit of the Configuration Register (A0h) needs to be set from “0” to “1” (clear before set operation). DE-GHOST FUNCTION The “ghost” term is used to describe the behavior of an LED that should be OFF but instead glows dimly when another LED is turned ON. A ghosting effect typically can occur when multiplexing LEDs. In matrix Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 The SWx Pull down resistors and CSy Pull up resistors are active only when the CSy/SWx output working the OFF state and therefore no power is lost through these resistors. SHUTDOWN MODE Shutdown mode can be used as a means of reducing power consumption. During shutdown mode all registers retain their data. Software Shutdown By setting SSD bit of the Configuration Register (A0h) to “0”, the IS31FL3729 will operate in software shutdown mode. When the IS31FL3729 is in software shutdown, all current sources are switched off, so that the matrix is blanked. All registers can be operated. Typical current consumption is 3μA. Hardware Shutdown The chip enters hardware shutdown when the SDB pin is pulled low. When the IS31FL3729 is in hardware shutdown, all current sources are switched off, so that the matrix is blanked. All registers can be operated. Typical current consumption is 3μA. The chip releases hardware shutdown when the SDB pin is pulled high. If VCC has a risk of dropping below 1.75V but remain above 0.1V while the SDB pin is pulled low, please re-initialize all Function Registers before SDB is pulled high. LAYOUT As described previously, depending on the current set resistor (RISET) value and current register settings, the chip can consumes lots of power. Please consider the below factors during the PCB layout phase. 1. The VCC capacitors need to be close to the VCC pin 23 with their ground pins well connected to the GND of the chip. 2. RISET should be close to the chip and the ground side should well connect to the GND of the chip. 3. The thermal pad should connect to ground pins and the PCB should have the thermal pad too, usually this pad should have 9 or 16 vias thru the PCB to the other 18 IS31FL3729 side’s ground area to help radiate the heat. About the thermal pad size, please refer to the land pattern of each package. 4. The CSy pins will have a maximum current of 35mA (RISET=10kΩ). However, the SWx pins maximum current is larger since it is the combined current of the CSy pins. Therefore, the width of the SWx trace needs to be much wider than the CSy trace. Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 19 IS31FL3729 CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) 150°C 200°C 60-120 seconds Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) Time at liquidous (tL) 217°C 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified classification temperature (Tc) Max 30 seconds Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature 8 minutes max. Figure 15 Classification Profile Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 20 IS31FL3729 PACKAGE INFORMATION QFN-32 Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 21 IS31FL3729 eTQFP-32 Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 22 IS31FL3729 RECOMMENDED LAND PATTERN QFN-32 eTQFP-32 Note: 1. Land pattern complies to IPC-7351. 2. All dimensions in MM. 3. This document (including dimensions, notes & specs) is a recommendation based on typical circuit board manufacturing parameters. Since land pattern design depends on many factors unknown (eg. User’s board manufacturing specs), user must determine suitability for use. Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 23 IS31FL3729 REVISION HISTORY Revision Detail Information Date 0A Preliminary release 2019.04.25 0B Correct slave address setting in Table 1 2019.04.29 A Add APPLICATION INFORMATION and functional block 2019.06.12 B Add eTQFP-32 package 2019.11.29 C 1 Add test condition for tSCAN/ tNOL1/tNOL2 2 Add POWER ON SEQUENCE in APPLICATION INFORMATION 2012.12.23 Lumissil Microsystems – www.lumissil.com Rev. C, 12/23/2020 24
IS31FL3729-QFLS4-TR 价格&库存
很抱歉,暂时无法提供与“IS31FL3729-QFLS4-TR”相匹配的价格&库存,您可以联系我们找货
IS31FL3729-QFLS4-TR
  • 1+16.479481+2.13467
  • 10+12.1379010+1.57229
  • 25+11.0397625+1.43004
  • 100+9.83749100+1.27430
  • 250+9.26412250+1.20003
  • 500+8.91824500+1.15523
  • 1000+8.901301000+1.15303
库存:5367
IS31FL3729-QFLS4-TR
  • 2500+8.333212500+1.07945
  • 5000+8.152095000+1.05598
  • 7500+8.061387500+1.04423
库存:5367
1N4148X-TP
    • 8000+0.05152
    库存:264000
