CD74ACT139E
CD74ACT139E
    L3HARRIS
    DIP-16
    IC DECODER/DEMUX 1X2:4 16DIP
CD74ACT139E 数据手册
CD54ACT139, CD74ACT139 DUAL 2-LINE TO 4-LINE DECODERS/DEMULTIPLEXERS SCHS337 – MARCH 2003 D D D D D D D D CD54ACT139 . . . F PACKAGE CD74ACT139 . . . E OR M PACKAGE (TOP VIEW) AC Types Feature 1.5-V to 5.5-V Operation and Balanced Noise Immunity at 30% of the Supply Voltage Buffered Inputs Incorporate Two Enable Inputs to Simplify Cascading and/or Data Reception Speed of Bipolar F, AS, and S, With Significantly Reduced Power Consumption Balanced Propagation Delays ±24-mA Output Drive Current – Fanout to 15 F Devices SCR-Latchup-Resistant CMOS Process and Circuit Design Exceeds 2-kV ESD Protection Per MIL-STD-883, Method 3015 1G 1A 1B 1Y0 1Y1 1Y2 1Y3 GND 1 16 2 15 3 14 4 13 5 12 6 11 7 10 8 9 VCC 2G 2A 2B 2Y0 2Y1 2Y2 2Y3 description/ordering information The ’ACT139 devices are dual 2-line to 4-line decoders/demultiplexers designed for 4.5-V to 5.5-V VCC operation. These devices are designed to be used in high-performance memory-decoding or data-routing applications requiring very short propagation delay times. In high-performance memory systems, these decoders can be used to minimize the effects of system decoding. When used with high-speed memories utilizing a fast enable circuit, the delay times of these decoders and the enable time of the memory usually are less than the typical access time of the memory. This means that the effective system delay introduced by the decoders is negligible. The active-low enable (G) input can be used as a data line in demultiplexing applications. These decoders/demultiplexers feature fully buffered inputs, each of which represents only one normalized load to its driving circuit. ORDERING INFORMATION PDIP – E 55°C to 125°C –55°C ORDERABLE PART NUMBER PACKAGE† TA SOIC – M Tube CD74ACT139E Tube CD74ACT139M Tape and reel CD74ACT139M96 TOP-SIDE MARKING CD74ACT139E ACT139M CDIP – F Tube CD54ACT139F3A CD54ACT139F3A † Package drawings, standard packing quantities, thermal data, symbolization, and PCB design guidelines are available at www.ti.com/sc/package. Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet. Copyright  2003, Texas Instruments Incorporated PRODUCTION DATA information is current as of publication date. Products conform to specifications per the terms of Texas Instruments standard warranty. Production processing does not necessarily include testing of all parameters. On products compliant to MIL-PRF-38535, all parameters are tested unless otherwise noted. On all other products, production processing does not necessarily include testing of all parameters. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 1 CD54ACT139, CD74ACT139 DUAL 2-LINE TO 4-LINE DECODERS/DEMULTIPLEXERS SCHS337 – MARCH 2003 FUNCTION TABLE (each decoder/demultiplexer) INPUTS OUTPUTS SELECT G B A Y0 Y1 Y2 Y3 H X X H H H H L L L L H H H L L H H L H H L H L H H L H L H H H H H L logic diagram (positive logic) 4 1Y0 1 1G 5 6 1A Select Inputs 1Y1 1Y2 2 7 3 1B 1Y3 Data Outputs 12 2Y0 2G 15 11 2Y1 10 2A Select Inputs 2B 2Y2 14 9 13 2Y3 absolute maximum ratings over operating free-air temperature range† Supply voltage range, VCC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –0.5 V to 6 V Input clamp current, IIK (VI < 0 or VI > VCC) (see Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±20 mA Output clamp current, IOK (VO < 0 or VO > VCC) (see Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±50 mA Continuous output current, IO (VO = 0 to VCC) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±50 mA Continuous current through VCC or GND . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±100 mA Package thermal impedance, θJA (see Note 2): E package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 67°C/W M package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 73°C/W Storage temperature range, Tstg . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –65°C to 150°C † Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. NOTES: 1. The input and output voltage ratings may be exceeded if the input and output current ratings are observed. 2. The package thermal impedance is calculated in accordance with JESD 51-7. 2 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 CD54ACT139, CD74ACT139 DUAL 2-LINE TO 4-LINE DECODERS/DEMULTIPLEXERS SCHS337 – MARCH 2003 recommended operating conditions (see Note 3) –55°C to 125°C TA = 25°C –40°C to 85°C UNIT MIN MAX MIN MAX MIN MAX 4.5 5.5 4.5 5.5 4.5 5.5 VCC VIH Supply voltage VIL VI Low-level input voltage Input voltage 0 VO IOH Output voltage 0 High-level output current –24 IOL ∆t/∆v Low-level output current Input transition rise or fall rate High-level input voltage 2 2 0.8 2 V 0.8 V VCC VCC V –24 –24 mA 24 24 24 mA 10 10 10 ns/V VCC VCC 0.8 V 0 0 VCC VCC 0 0 V NOTE 3: All unused inputs of the device must be held at VCC or GND to ensure proper device operation. Refer to the TI application report, Implications of Slow or Floating CMOS Inputs, literature number SCBA004. electrical characteristics over recommended operating free-air temperature range (unless otherwise noted) PARAMETER TEST CONDITIONS MIN VOH VOL VI = VIH or VIL VI = VIH or VIL II ICC VI = VCC or GND VI = VCC or GND, DICC‡ VI = VCC – 2.1 V –55°C to 125°C TA = 25°C VCC MAX MIN –40°C to 85°C MAX MIN UNIT MAX IOH = –50 µA IOH = –24 mA 4.5 V 4.4 4.5 V 3.94 IOH = –50 mA† IOH = –75 mA† 5.5 V IOL = 50 µA IOL = 24 mA IOL = 50 mA† 4.5 V 0.1 0.1 0.1 4.5 V 0.36 0.5 0.44 IOL = 75 mA† 5.5 V 4.4 4.4 3.7 3.8 5.5 V 3.85 5.5 V 1.65 V 1.65 5.5 V IO = 0 V 3.85 5.5 V 4.5 V to 5.5 V ±0.1 ±1 ±1 µA 8 160 80 µA 2.4 3 2.8 mA Ci 10 10 10 pF † Test one output at a time, not exceeding 1-second duration. Measurement is made by forcing indicated current and measuring voltage to minimize power dissipation. Test verifies a minimum 50-Ω transmission-line drive capability at 85°C and 75-Ω transmission-line drive capability at 125°C. ‡ Additional quiescent supply current per input pin, TTL inputs high, 1 unit load ACT INPUT LOAD TABLE INPUT UNIT LOAD A or B 1 G 0.67 Unit Load is ∆ICC limit specified in electrical characteristics table (e.g., 2.4 mA at 25°C). POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 3 CD54ACT139, CD74ACT139 DUAL 2-LINE TO 4-LINE DECODERS/DEMULTIPLEXERS SCHS337 – MARCH 2003 switching characteristics over recommended operating free-air temperature range, VCC = 5 V ± 0.5 V, CL = 50 pF (unless otherwise noted) (see Figure 1) FROM (INPUT) TO (OUTPUT) tPLH tPHL A or B Y tPLH tPHL G Y PARAMETER –55°C to 125°C –40°C to 85°C UNIT MIN MAX MIN MAX 2.9 11.5 3.1 10.5 2.9 11.5 3.1 10.5 3 12 3.2 10.9 3 12 3.2 10.9 ns ns operating characteristics, TA = 25°C PARAMETER Cpd 4 TYP Power dissipation capacitance 83 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 UNIT pF CD54ACT139, CD74ACT139 DUAL 2-LINE TO 4-LINE DECODERS/DEMULTIPLEXERS SCHS337 – MARCH 2003 PARAMETER MEASUREMENT INFORMATION S1 R1 = 500 Ω From Output Under Test 2 × VCC Open GND CL = 50 pF (see Note A) R2 = 500 Ω TEST S1 tPLH/tPHL tPLZ/tPZL tPHZ/tPZH Open 2 × VCC GND tw 3V 1.5 V Input LOAD CIRCUIT 1.5 V 0V VOLTAGE WAVEFORMS PULSE DURATION CLR Input 3V Reference Input 3V 1.5 V 1.5 V 0V 0V trec Data Input 3V 1.5 V CLK th tsu 1.5 V 10% 90% 90% tr 0V VOLTAGE WAVEFORMS RECOVERY TIME 3V 1.5 V 10% 0 V tf VOLTAGE WAVEFORMS SETUP AND HOLD AND INPUT RISE AND FALL TIMES 3V Input 1.5 V 1.5 V 0V tPLH In-Phase Output 50% 10% 90% 90% tr 90% 1.5 V 1.5 V 0V tPHL tPHL Out-of-Phase Output 3V Output Control VOH 50% VCC 10% VOL tf tPLH 50% VCC 10% tf 50% 10% 90% VOH VOL tr VOLTAGE WAVEFORMS PROPAGATION DELAY AND OUTPUT TRANSITION TIMES Output Waveform 1 S1 at 2 × VCC (see Note B) tPLZ tPZL 20% VCC tPHZ tPZH Output Waveform 2 S1 at GND (see Note B) ≈VCC 20% VCC VOL 80% VCC VOH 80% VCC ≈0 V VOLTAGE WAVEFORMS OUTPUT ENABLE AND DISABLE TIMES NOTES: A. CL includes probe and test-fixture capacitance. B. Waveform 1 is for an output with internal conditions such that the output is low except when disabled by the output control. Waveform 2 is for an output with internal conditions such that the output is high except when disabled by the output control. C. All input pulses are supplied by generators having the following characteristics: PRR ≤ 1 MHz, ZO = 50 Ω, tr = 3 ns, tf = 3 ns. Phase relationships between waveforms are arbitrary. D. For clock inputs, fmax is measured with the input duty cycle at 50%. E. The outputs are measured one at a time with one input transition per measurement. F. tPLH and tPHL are the same as tpd. G. tPZL and tPZH are the same as ten. H. tPLZ and tPHZ are the same as tdis. I. All parameters and waveforms are not applicable to all devices. Figure 1. Load Circuit and Voltage Waveforms POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 5 PACKAGE OPTION ADDENDUM www.ti.com 6-Feb-2020 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan Lead/Ball Finish MSL Peak Temp (2) (6) (3) Op Temp (°C) Device Marking (4/5) CD54ACT139F3A ACTIVE CDIP J 16 1 TBD Call TI N / A for Pkg Type -55 to 125 CD54ACT139F3A CD74ACT139E ACTIVE PDIP N 16 25 Green (RoHS & no Sb/Br) NIPDAU N / A for Pkg Type -55 to 125 CD74ACT139E CD74ACT139M ACTIVE SOIC D 16 40 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 ACT139M CD74ACT139M96 ACTIVE SOIC D 16 2500 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 ACT139M CD74ACT139M96G4 ACTIVE SOIC D 16 2500 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 ACT139M CD74ACT139ME4 ACTIVE SOIC D 16 40 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 ACT139M CD74ACT139MG4 ACTIVE SOIC D 16 40 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 ACT139M (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
CD74ACT139E 价格&库存
很抱歉,暂时无法提供与“CD74ACT139E”相匹配的价格&库存,您可以联系我们找货
