0530-25241-B-010
0530-25241-B-010
    SUCO(苏克)
    Cylinder,Threaded
    EPS: PNP OUTPUT (HIGH SIDE), NOR
0530-25241-B-010 数据手册
0530 / 0531 / 0532 / 0533 E.5 Order matrix for electronic pressure switches hex 22 High Performance Silicon-on-Saphire Sensor with One Switching Function Type Pressure range Pressure connection Pressure unit Electrical connection Type PNP output (High Side), NO 0530 PNP output (High Side), NC 0531 NPN output (Low Side), NO 0532 NPN output (Low Side), NC 0533 Max. overpressure2) Burst pressure 40 bar 80 bar 0 – 10 bar (580 psi) (1,160 psi) (0 - 145 psi) 100 bar 200 bar 0 – 25 bar (1,450 psi) (2,900 psi) (0 - 362.5 psi) 400 bar 800 bar 0 – 100 bar (5,800 psi) (11,600 psi) (0 - 1,450 psi) 1,000 bar 2,000 bar 0 – 250 bar (14,500 psi) (29,000 psi) (0 - 3,625 psi) 1,650 bar 2,000 bar 0 – 600 bar (23,930 psi) (29,000 psi) (0 - 8,700 psi) With 1 Switching Function Adjustment range1) 101 251 102 252 602 Pressure connection 1/4 BSPP – DIN EN ISO 1179-2 (DIN 3852-11) form E 1/4 BSPP – DIN 3852-A NPT 1/8 NPT 1/4 M 10x1 cyl. DIN 3852-A 7/16-20 UNF 9/16-18 UNF M 14x1.5 – DIN EN ISO 9974-2 (DIN 3852-11) form E 41 03 04 09 30 20 21 42 Pressure unit bar E B Electrical connection DIN EN 175301-803-A (DIN 43650-A); socket device included M 12 – DIN EN 61076-2-101 A Bayonet ISO 15170-A1-4.1 (DIN 72585-A1-4.1) AMP Superseal 1.5® Deutsch DT04-4P Deutsch DT04-3P Cable connection (length of cable 6.5 ft / 2 m standard) Order number: 05XX XXX 013 002 004 007 008 010 011 XX B XXX 1) Please state switching point and differential when ordering. 2) Static pressure, dynamic pressure 30 to 50% lower. Value refers to the hydraulic or pneumatic part of the electronic pressure switch. RoHSII compliant 125 Silicon-on-Saphire Sensor with One Switching Function Technical details Type 0530 NO 0532 NO 0531 NC 0533 NC Number of transistor outputs: 1 PNP output (High Side N-channel MOSFET) 1 NPN output (Low Side N-channel MOSFET) Supply voltage: 9.6 – 32 VDC Idle power consumption: < 15 mA Standard adjustment range pnom Overpressure protection Burst pu1) pressure1): 0 – 10 bar 0 – 25 bar 0 – 100 bar 0 – 250 bar 0 – 600 bar (0 – 145 psi) (0 – 360 psi) (0 – 1,450 psi) (0 – 3,625 psi) (0 – 8,700 psi) 40 bar 100 bar 400 bar 1,000 bar 1,650 bar (580 psi) (1,450 psi) (5,800 psi) (14,500 psi) (29,930 psi) 80 bar 200 bar 800 bar 2,000 bar 2,000 bar (1,160 psi) (2,900 psi) (11,600 psi) (29,000 psi) (29,000 psi) Mechanical life expectancy: 10,000,000 pulsations at rise rates to 72.5 psi/ms (5 bar/ms) at pnom Permitted pressure change rate: ≤ 72.5 psi/ms (≤ 5 bar / ms) Switching point adjustment range: 2 … 100 % of the nominal pressure range (Full Scale, FS), programmable at factory Differential: 0.2 … 99.8 % of the nominal pressure range (FS), programmable at factory (set to 5% of the switching point as standard) Accuracy: ±0.5 % of the nominal pressure range (FS) at room temperature, ±0.25 % BFSL Resolution: 0.1 % of the nominal pressure range (FS) Switching delay: ON (0 … 0.5 s) / OFF (0 … 2 s) delay in increments of 1 ms, irrespective of switching point, programmable at factory (specify value when ordering, otherwise default value of 0 s is set) Output: 0.5 A transistor output with short-circuit and overvoltage protection Operating mode: With differential or window mode, programmable at factory Long term stability: ±0.1 % FS p. a. Repeatability1): ±0.1 % FS E error1): ±0.02 % / 1 K FS Compensated temperature range: -4 oF . . . +176 oF (-20 oC . . . +80 oC) Temperature range media: -40 oF . . . +257 oF (-40 oC . . . +125 oC) Temperature o o (-40 oC . . . +100 oC) Temperature range ambient: -40 F . . . +212 F Wetted parts material: Stainless steel AISI 303 (1.4305) and titanium Housing material: Stainless steel AISI 303 (1.4305) Insulation resistance: > 100 MΩ (500 VDC, Ri > 42 Ω) Switching time: Vibration resistance: Shock resistance: Protection class: Refer to the electrical connections EMC: EMC 2014/30/EU, EN 61000-6-2:2005, EN 61000-6-3:2007 Protection against reverse polarity, short-circuit and over voltage surges: built-in Weight: approx. 2.8 oz / 80 g (DIN 175301 approx. 3.8 oz / 110 g, cable version approx. 4.8 oz / 135 g) 1) Within the compensated temperature range. 2) Static pressure. Dynamic value is 30 to 50 % lower. Values refer to the hydraulic/pneumatic part of the electronic pressure switch. 123 E.5 0530 / 0531 / 0532 / 0533 hex 22 High Performance Electrical connectors and threads Silicon-on-Saphire Sensor with One Function Switching Function 1 switching output 1 Switching M 12 – DIN EN 61076-2-101 A DIN EN 175301-803-A PE 2 d ISO 15170-A1-4.1 2 1 4 1 2 3 AMP Superseal 1 2 3 LED 3 1 3 Assignment Uv+ nc Gnd Out IP65 IP67 x ~ 60 / 76 mm* x ~ 54 mm d ~ Ø 30 mm d ~ Ø 22 mm Order number: 002 Order number: 001 * without coupler socket x ~ 60 mm, with coupler socket x ~ 76 mm x Pin 1 2 3 PE 4 Assignment Uv+ Gnd Uout DEUTSCH DT04-4P 4 Pin 1 2 3 4 Pin Assignment 1 Uv+ Gnd 2 Uout 3 nc 4 IP67, IP6K9K x ~ 65 mm d ~ Ø 27 mm Order number: 004 DEUTSCH DT04-3P Pin 1 2 3 Assignment Out Gnd Uv+ IP67 x ~ 73 mm d ~ Ø 26 mm Order number: 007 Cable connection 1 hex 22 B A C Connection diagrams 3 2 Pin Assignment 1 Gnd 2 Uv+ 3 nc 4 Out IP67, IP6K9K Pin A B C Assignment Uv+ Gnd Out IP67, IP6K9K Cable red white black Assignment Uv+ Out Gnd IP67 x ~ 44 mm (+ 20 mm bend relief) x ~ 74 mm x ~ 74 mm d ~ Ø 23 mm d ~ Ø 23 mm d ~ Ø 22 mm Order number: 008 Order number: 010 Order number: 011 10 NPT 1/8 1/4 BSPP DIN 3852-A Thread code: 41 14.5 2 FKM(Viton®) Sealing ring 1/4 BSPP DIN EN ISO 1179-2 (DIN 3852-11) form E 12 12 2 cable length ~ 6.5 ft (2 m) Thread code: 03 NPT 1/4 Thread code: 04 Thread code: 09 RoHSII compliant Thread code: 30 7/16-20 UNF Thread code: 20 2 12 9.14 1 2 8 M 10x1 DIN 3852-A 124 9.93 2,3 Technical modifications and errors excepted. 9/16-18 UNF Thread code: 21 FKM(Viton®) Sealing ring M 14x1,5 DIN EN ISO 9974-2 (DIN 3852-11) form E Thread code: 42 E.7 Mating plugs Accessories Deutsch DT06-3S (for DT04-3P) 3 x 0.5 mm² PUR cable 6.5 ft (2 m), IP67 Suitable for connector code 010 Deutsch DT04-3P Order number: 1-1-36-653-160 TE AMP Superseal 1.5®, 3-pin 3 x 0.5 mm² Radox cable 6.5 ft (2 m), IP65 Suitable for connector code 007 AMP Superseal 1.5® Order number: 1-1-32-653-158 M12 DIN EN 61076-2-LF, 4-pin 4 x 0.34 mm² PUR cable 6.5 ft (2 m), IP65 Suitable for connector code 002 M12 DIN EN 61076-2-101 A Order number: 1-1-00-653-162 M 12x1 DIN EN 61071-2-101 D straight, 4-pin Terminals for wire diameter 0.75 mm² (AWG 18) Suitable for connector code 002 M12 DIN EN 61076-2-101 A Order number: 1-6-00-652-016 ~ 54 Accessories E Ø 20 Coupler socket M 12x1 DIN EN 61071-2-101 D Angled, 4-pin Terminals for wire diameter 0.75 mm² (AWG 18) Suitable for connector code 002 M12 DIN EN 61076-2-101 A Order number: 1-6-00-652-017 ~ 35 Ø 20 ~ 40 131 E.5 hex 22 High Performance Electronic pressure switches, High-Performance series Silicon-on-Saphire 1 switching output Sensor with One Switching Function Outstanding overpressure protection (up to 4 x) Ideal choice for mobile hydraulic applications Long service life even under high pressure change rates Wetted parts made of stainless steel and titanium ensuring excellent media compatibility All welded design, no elastomeric seal Silicon-on-sapphire technology (SoS) for highest reliability, accuracy and reliable process monitoring Very low temperature error and very good long-term stability Adjustment of switching point and differential at factory 122 For versions with 2 switching outputs, please refer to chapter E.6, page 126
0530-25241-B-010 价格&库存
很抱歉,暂时无法提供与“0530-25241-B-010”相匹配的价格&库存,您可以联系我们找货
