PRESSURE TRANSDUCERS WITH AMP.
PA-100
INTERNAL STRUCTURE
1
2
3
4
Part name
■ FEATURES
1
Pressure Port
● Covers low pressure range
● Buit-in a compact amplifier circuit
● Measures differential pressure
2
Sensor chip
3
Housing
4
Terminal pin
Material
LCP (Liquid crystal polymer)
Silicone
POM (Polyoxymethylene)
PPS (Polyphenylene sulphide)
Brass + Tin-plated
■ MODEL NUMBER DESIGNATION
PA-100-100D-S
Rated pressure range
Series name
100D-S: 0 ~ 1 kPa {102 mmH2O}
200D-S: 0 ~ 2 kPa {204 mmH2O}
500D-S: 0 ~ 5 kPa {510 mmH2O}
100D-W:− 1 ~ 1 kPa {± 102 mmH2O}
200D-W:− 2 ~ 2 kPa {± 204 mmH2O}
500D-W:− 5 ~ 5 kPa {± 510 mmH2O}
■ LIST OF MODEL NUMBERS
Pressure reference
Differential
kPa
Model number
0 ~ 1
0 ~ 2
0 ~ 5
− 1 ~ 1
− 2 ~ 2
−5~5
PA-100-100D-S PA-100-200D-S PA-100-500D-S PA-100-100D-W PA-100-200D-W PA-100-500D-W
※ Verify the above model numbers when placing orders.
PA-100
■ STANDARD SPECIFICATIONS
● Unless otherwise specified, the specs are defined at an ambient temperature of 25±5 °C and excitation voltage of 5 V DC.
Item
PA-100
Model number
100D-S 200D-S 500D-S 100D-W 200D-W 500D-W
General specifications
Pressure reference
Differential
kPa
1 2 5 ± 1
± 2
±5
Maximum pressure
kPa 5
± 10
± 25
Break-down pressure
kPa
50
Line pressure
kPa
50
Operating temp. range
°C
− 20 ~ 70
Compensated temp. range
°C
0 ~ 50
Storage temp.
± 5
− 20 ~ 80(Atmospheric pressure, humidity 65 %RH maximum)
°C
Pressure medium
Non-corrosive gases
MΩ
minimum
100 (50 V DC)
50 V AC, 60 s(Leakage current 1 mA maximum)
Pressure port
φ 2.5
mm
Net weight
Power
25
35 ~ 85(No condensation)
Dielectric strength
Supply voltage
g
Approx. 8
V DC
5 ± 10 %
maximum
Consumption current
5 mA
V
Output voltage
Analog output
10
%RH
Operating humidity
Insulation resistance
※2
※1
0.5 ~ 4.5
Zero voltage
※3
V 0.5 ± 0.08 2.5 ± 0.08
Span voltage
※3
V 4.0 ± 0.08 2.0 ± 0.08
Output current
Linearity/Hysteresis
Thermal error
(Reference temp.: 25 °C)
Response
mA
maximum
0.5(10 kΩ 以上 Load resistance 10 kΩ minimum)
± 0.5
%F.S.
ZERO
%F.S.
SPAN
%F.S.
± 5
± 3
± 2
± 5
± 3
±2
− 2
− 1
− 0.4
±2
5
ms
Gravitational effect
%F.S.
(From vertical position to horizontal position) max.
− 2
− 1
− 0.4
※ 1 PA-100- □□□ D-S pressure range Pressure A port − B port = 0 ~ Rated pressure range
PA-100- □□□ D-W pressure range Pressure A port − B port = − Rated pressure range ~ Rated pressure range
※ 2 Defined at 5 V of supply voltage.
※ 3 The zero and span voltages vary in proportion to the supply voltage.
PA-100
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Test conditions (At 25 ± 5 °C)
Permissible change
Vibration
10 ~ 500 Hz, 1.5 mm maximum/49 m/s ,
3 directions for 2 hours each
Shock
490 m/s2, 3 directions for 3 times each
Pressure cycling
0 ~ Rated pressure, 106 cycles
Moisture resistance
40 °C, 90 ~ 95 %RH, 240 hrs.
2
Zero voltage/Span voltage:
± 2 %F.S. (100D/200D) maximum
and ± 1 %F.S. (500D) each
■ OUTPUT VOLTAGE VS PRESSURE
PA-100- □□□ D-W type
0.5 V
4.5 V
–Pr
25 ± 0.4
7.6
10.5
Common
4
N.C.
5
N.C.
Label
4.9 ± 0.5
0.5
5.08
2– φ 1.0
Pressure port
φ 3.5
5– φ 0.7 ± 0.1
Terminal pin
(Tin-plated)
C0.2
3
A
POM
5.08
LCP
PPS
5
1
2
4
3
Projection A
Tolerance : 0.2 (mm)
■ INTERNAL ELECTRICAL SCHEMATICS
PressureA
Power B
Sensor
PressureB
φ 2.5
20.32
B
JAPAN
Output
3
Unless otherwise specified, tolerance : ± 0.5 (Unit: mm)
Port B
PA–100–※※※D–※
7H4
COPAL ELECTRONICS
2
Press. (Port A – Port B)
Projection A
7
Power B
Pr
■ OUTLINE DIMENSIONS
22.5 ± 0.4
1
0.5 V
Pr
Port A
Connection
2.5 V
5.7
Pin
1.7
4.5 V
Output voltage
Output voltage
PA-100- □□□ D-S type
Main circuit
Output
Common
很抱歉,暂时无法提供与“PA-100-100D-W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1935.503031+250.87805
- 5+1811.061605+234.74807
- 10+1764.6494310+228.73217
- 25+1709.0779225+221.52904
- 50+1671.0224450+216.59633
- 国内价格
- 1+2108.12760
- 200+815.82120
- 500+787.14720
- 1000+772.98840
