116CP21-M16S3-50
116CP21-M16S3-50
    SENSATA(森萨塔)
    Module
    116CP21-M16S3-50
116CP21-M16S3-50 数据手册
| 116CP SERIES PRESSURE SENSOR Introduction Utilizing Sensata’s industry leading ceramic capacitive technology, the 116CP is housed in a small and innovative plastic package ideal for boilers, pumps, and other light industrial applications. The 116CP is offered in a wide range of configurations including various pressure ports, electrical outputs and pressure ranges from 0-4 to 0-16 bar. Features • • • • • • Multiple port & Connector options High accuracy: +/-1.5%VS Small & compact size 100% automated calibration REACH/RoHS/CE compliant Drinking water safe options available (126CP and 127CP only) Applications • Boilers • Heat pumps • Residential booster pumps • Lawn & Pool pumps • Circulator pumps • Pump controllers • Food & Beverage equipment SPECIFICATIONS Electrical Supply Voltage 5VDC (ratiometric) or 8-30VDC (voltage regulated) Output Voltage Commonly 0.5 to 3.5V or 0.5 to 4.5V (Others available under ordering options) Supply Current 8.0mA Output Current 5.0mA (max) Output Load 10kOhm pull down Output Response Time
116CP21-M16S3-50 价格&库存
很抱歉,暂时无法提供与“116CP21-M16S3-50”相匹配的价格&库存,您可以联系我们找货
