S-8333CBDA-I8T1G
S-8333CBDA-I8T1G
    ABLIC(艾普凌科)
    SMD8
    IC REG CTRLR BOOST
S-8333CBDA-I8T1G 数据手册
S-8333 Series www.ablic.com www.ablicinc.com STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER © ABLIC Inc., 2004-2015 Rev.4.2_02 The S-8333 Series is a CMOS step-up switching regulator which mainly consists of a reference voltage circuit, an oscillator, an error amplifier, a PWM controller, an under voltage lockout circuit (UVLO), and a timer latch short-circuit protection circuit. Because its minimum operating voltage is as low as 1.8 V, this switching regulator is ideal for the power supply of an LCD or for portable systems that operate on a low voltage. The internal oscillation frequency can be set up to 1.08 MHz, via the resistor connected to the ROSC pin. The maximum duty ratio of PWM control can be controlled by the resistor connected to the RDuty pin. The soft-start function at power application is accomplished by combining the reference voltage control and maximum duty control methods. Even if the voltage of the FB pin is retained lower than the reference voltage due to the factor outside the IC, the output voltage is raised by controlling the maximum duty. The phase compensation and gain value can be adjusted according to the values of the resistor and capacitor connected to the CC pin. Therefore, the operation stability and transient response can be correctly set for each application. The reference voltage accuracy is as high as 1.0 V 1.5%, and any voltage can be output by using an external output voltage setting resistor. In addition, the delay time of the short-circuit protection circuit can be set by using the capacitor connected to the CSP pin. If the maximum duty condition continues because of short-circuiting, the capacitor externally connected to the CSP pin is charged, and oscillation stops after a specific time. The short-circuit protection function is cancelled when the power supply is raised to the UVLO release voltage after it has been lowered to the UVLO detection voltage. A ceramic capacitor or a tantalum capacitor is used as the output capacitor, depending on the setting. This controller IC allows various settings and selections and employs a small package, making it very easy to use.  Features  Low voltage operation:  Oscillation frequency:  Maximum duty:        1.8 V to 6.0 V 280 kHz to 1.08 MHz (selectable by external resistor) Settable up to 88.5% by external resistor 47 to 88.5% (oscillation frequency; 500 kHz or more) 47 to 80% (oscillation frequency; less than 500 kHz) Reference voltage: 1.0 V 1.5% Range of operation temperature: 40 to 85C UVLO (under-voltage lockout) function: Detection voltage can be selected from between 1.5 V and 2.3 V in 0.1 V step. Hysteresis width can be selected from between 0.1 V and 0.3 V in 0.1 V step. Timer latch short-circuit protection circuit: Delay time can be set using an external capacitor. Soft-start function: Soft-start time can be selected in three steps, 10 ms, 15 ms, and 20 ms. Both reference voltage control and maximum duty control methods are applied Phase compensation external setting: Control is possible via the resistor connected between the CC and GND pins and capacitor Lead-free, Sn 100%, halogen-free*1 *1. Refer to “ Product Name Structure” for details.  Applications  Power supplies for LCDs and CCDs  Power supplies for portable equipment  Packages  SNT-8A  8-Pin TSSOP 1 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series  Block Diagram VOUT SD L RDuty VIN UVLO M1 CIN ROSC  PWM  comparator Timer latch short-circuit protection circuit EXT VSS CSP  Error amplifier  Reference voltage (1.0 V) soft-start circuit CC RZ CZ Figure 1 Block Diagram 2 CFB RFB1 Oscillator Maximum duty soft-start circuit CL FB RFB2 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series  Product Name Structure 1. Product name (1) SNT-8A S-8333 C x x x - I8T1 U Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and packing specifications*1 I8T1: SNT-8A, tape product Soft-start time setting A: 10 ms B: 15 ms C: 20 ms UVLO setting A: 2.3 V B: 2.2 V C: 2.1 V D: 2.0 V E: 1.9 V F: 1.8 V G: 1.7 V H: 1.6 V I: 1.5 V UVLO hysteresis setting A: 0.1 V B: 0.2 V C: 0.3 V *1. Refer to the tape drawing. 3 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series (2) 8-Pin TSSOP S-8333 C x x x - T8T1 x Environmental code U: Lead-free (Sn 100%), halogen-free S: Lead-free, halogen-free Package abbreviation and packing specifications*1 T8T1: 8-Pin TSSOP, tape product Soft-start time setting A: 10 ms B: 15 ms C: 20 ms UVLO setting A: 2.3 V B: 2.2 V C: 2.1 V D: 2.0 V E: 1.9 V F: 1.8 V G: 1.7 V H: 1.6 V I: 1.5 V UVLO hysteresis setting A: 0.1 V B: 0.2 V C: 0.3 V *1. Refer to the tape drawing. 2. Packages Package Name SNT-8A 8-Pin TSSOP 4 Package PH008-A-P-SD FT008-A-P-SD Drawing Code Tape Reel PH008-A-C-SD PH008-A-R-SD FT008-E-C-SD FT008-E-R-SD Land PH008-A-L-SD  STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series  Pin Configurations 1. SNT-8A Table 1 Top view 1 2 3 4 Pin No. 8 7 6 5 Figure 2 Symbol Description 1 CC Error amplifier circuit output phase compensation pin 2 FB Output voltage feedback pin 3 CSP Short-circuit protection delay time setting pin 4 VIN Power supply input pin 5 EXT External transistor connection pin 6 VSS GND pin 7 ROSC Oscillation frequency setting resistor connection pin 8 RDuty Maximum duty setting resistor connection pin 2. 8-Pin TSSOP Table 2 Pin No. Top view 1 2 3 4 8 7 6 5 Figure 3 Symbol Description 1 CC Error amplifier circuit output phase compensation pin 2 FB Output voltage feedback pin 3 CSP Short-circuit protection delay time setting pin 4 VIN Power supply input pin 5 EXT External transistor connection pin 6 VSS GND pin 7 ROSC Oscillation frequency setting resistor connection pin 8 RDuty Maximum duty setting resistor connection pin 5 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series  Absolute Maximum Ratings Table 3 Absolute Maximum Ratings (Unless otherwise specified: Ta  25C, VSS  0 V) Parameter VIN pin voltage FB pin voltage EXT pin voltage CSP pin voltage CC pin voltage CC pin current ROSC pin voltage ROSC pin current RDuty pin voltage RDuty pin current SNT-8A Power dissipation 8-Pin TSSOP Symbol VIN VFB VEXT VCSP VCC ICC VROSC IROSC VRDuty IRDuty PD Operating ambient temperature Storage temperature Topr Tstg Ratings VSS  0.3 to VSS  6.5 VSS  0.3 to VSS  6.5 VSS  0.3 to VIN  0.3 VSS  0.3 to VIN  0.3 VSS  0.3 to VIN  0.3 10 VSS  0.3 to VIN  0.3 10 VSS  0.3 to VIN  0.3 10 *1 450 300 (When not mounted on board) *1 700 40 to 85 40 to 125 Unit V V V V V mA V mA V mA mW mW mW C C *1. When mounted on board [Mounted board] (1) Board size: (2) Name: Caution 114.3 mm  76.2 mm  t1.6 mm JEDEC STANDARD51-7 The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. Power dissipation (PD) [mW] 800 600 8-Pin TSSOP SNT-8A 400 200 0 0 50 100 150 Ambient temperature (Ta) [C] Figure 4 Power Dissipation of Package (When mounted on board) 6 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series  Electrical Characteristics Table 4 Electrical Characteristics (Unless otherwise specified: VIN  3.3 V, Ta  25C) Parameter Symbol Operating input voltage VIN FB voltage VFB Current consumption ISS1 IEXTH IEXTL FB voltage temperature VFB coefficient Ta FB pin input current IFB EXT pin output current Oscillation frequency*1 fosc Oscillation frequency fosc temperature coefficient Ta Max. duty*2 MaxDuty Soft-start time tSS Short-circuit protection tPRO *3 delay time UVLO detection voltage VUVLO UVLO hysteresis width VUVLOHYS CC pin output current ICCH ICCL VRTLT1 Timer latch reset voltage VRTLT2 Conditions Min. Typ. Max. Unit Test Circuit   1.8 0.985  1.000 6.0 1.015 V V 2 2 fosc  650 kHz VFB  0.95 V VEXT  VIN  0.4 V VEXT  0.4 V  450 700 A 1  100 100 160 60  mA mA 1 1 Ta  40 to 85C  100  ppm/C 2 0.1  0.1 A 1 fosc  0.9 fosc fosc  1.1 kHz 1  1000  ppm/C 1 % 1  When fosc  1080 kHz is set (ROSC  120 k) When fosc  650 kHz is set (ROSC  200 k) When fosc  280 kHz is set (ROSC  470 k) VFB  0.9 V Waveform on EXT pin is measured. Ta  40 to 85C fosc  650 kHz fosc  1080 kHz (ROSC  120 k) MaxDuty  88.5% (RDuty  62 k) MaxDuty  73% (RDuty  180 k) MaxDuty  47% (RDuty  390 k) fosc  650 kHz (ROSC  200 k) MaxDuty  88.5% (RDuty  100 k) tSS  10 ms, 15 ms, 20 ms Selected in three steps tPRO  50 ms (CSP  0.1 F) VUVLO  1.5 V to 2.3 V Selected in 0.1 V steps VUVLOHYS  0.1 V to 0.3 V Selected in 0.1 V steps VFB  2 V VFB  0 V Within short-circuit protection delay time After short-circuit protection circuit operated MaxDuty MaxDuty MaxDuty 5 5 tSS  0.75 tSS tSS  1.5 ms 1 37.5 50 75 ms 1 V 1 V 1 A A 1 1 VUVLO VUVLO VUVLO  0.95  1.05 VUVLOHYS VUVLOHYS VUVLOHYS  0.6  1.4 60 45 34.5 34.5 45 60 0.7 1.0 1.3 V 1 VUVLO  0.95 VUVLO VUVLO  1.05 V 1 *1. The recommended range of the resistance (Rosc) for oscillation frequency is Rosc  120 k to 470 k (fOSC  280 kHz to 1.08 MHz). This range of oscillation frequency is the typical value when an ideal resistor is connected externally. In actual use, it is necessary to take account the dispersion of an IC (10%) into this value. *2. Set max. duty; Between 47 and 88.5 % (RDuty/ROSC = 0.5 to 3.2); the oscillation frequency is 500 kHz or more Between 47 and 80 % (RDuty/ROSC = 1.0 to 3.2); the oscillation frequency is less than 500 kHz This range of max. duty is the typical value when an ideal resistor is connected externally. In actual use, it is necessary to take account the dispersion of an IC (5%) into this value. *3. The short-circuit protection time can be set by the external capacitor. Although the maximum set value by the external capacitor is unlimited under the ideal condition, set CSP  approx. 0.47 F as a target maximum value due to discharge time of the capacitor. 7 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series  External Parts When Measuring Electrical Characteristics Table 5 External Parts Element Name Inductor Diode Output capacitor Transistor Oscillation frequency setting resistor Maximum duty ratio setting resistor Short-circuit protection delay time setting capacitor Output voltage setting resistor 1 Output voltage setting resistor 2 FB pin capacitor Phase compensation resistor Phase compensation capacitor 8 Symbol L SD CL M1 ROSC RDuty Manufacturer TDK Corporation Rohm Co., Ltd.  Sanyo Electric Co., Ltd.   Part Number LDR655312T 10 H RB491D Ceramic 10 F MCH3406 200 k (when fOSC  650 kHz) 300 k (when MaxDuty  73%) CSP  0.1 F (when tPRO  50 ms) RFB1 RFB2 CFB RZ CZ      8.2 k (when VOUT  9.2 V) 1.0 k (when VOUT  9.2 V) 180 pF 200 k 0.01 F STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series  Measurement Circuits 1. RZ A CZ CSP CC RDuty FB ROSC CSP VSS VIN EXT ROSC RDuty CIN Oscilloscope Figure 5 2. RFB1 RDuty FB ROSC CFB RZ CZ CC SD RFB2 CL L M1 CIN CSP VSS VIN EXT ROSC RDuty CSP V Figure 6 9 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series  Operation 1. Switching control method 1. 1 PWM control The S-8333 Series is a DC-DC converter using a pulse width modulation method (PWM). The pulse width of the S-8333 Series varies from 0% to the maximum duty set by RDuty depending on the load current, but its switching frequency does not change. Consequently, the ripple voltage generated from switching can be removed easily via a filter. 2. Soft-start function For this IC, the built-in soft-start circuit controls the rush current and overshoot of the output voltage when powering on. Reference voltage adjustment and maximum duty control methods are adopted as the soft-start methods. The following describes the soft-start function at power application. In the circuit where the input voltage is not directly output at shutdown by inserting a switch (SW) between the diode (SD) and VOUT output, the VOUT voltage when the VIN voltage is applied with the SW OFF stays 0 V. Therefore, the voltage of the FB pin stays 0 V and the EXT output is in the step up status between the “H” and “L” levels due to the maximum duty. The maximum duty at this time is approximately 7% and the rush current at power application is controlled. The maximum duty soft start is accomplished by gradually increasing the duty width up to the maximum duty set by the external resistor RDuty (refer to Figure 8). The reference voltage of the error amplifier input also gradually increases from 0 V at the same time as the maximum duty soft start. The increasing of the output voltage is controlled by turning the SW ON. The soft-start function is realized by controlling the voltage of the FB pin so that it is the same potential as the reference voltage that is slowly raised. A Rail-to-Rail amplifier is adopted as the error amplifier, which means that the voltage is loop controlled so that it can be the same as the reference voltage. Once the reference voltage rises, the voltage cannot be reset (the reference voltage is 0 V) unless making the power supply voltage lower than the UVLO detection voltage. Conversely, when the power supply voltage rises up to the reset voltage after it is lowered to the UVLO detection voltage or lower, the output voltage is stepped up by the soft-start function. SD SW VOUT L PWM Comparator VIN M1  EXT CC FB Error amplifier  Error amplifier  reference voltage RZ Vref CZ Figure 7 10 RFB1 0.5 V 0V  CL RFB2 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series (VIN  0 V→3.3 V, VOUT  9.2 V, RFB1  8.2 k, RFB2  1.0 k) 3.3 V Input voltage (VIN) 0V tSS 9.2 V Output voltage (VOUT ) V OUT 0.95 SW : ON 0V 1.0 V Error amplifier reference voltage 0V Reference voltage soft-start period 1.0 V F B pin voltage (VFB ) 0V 3.3 V EXT pin voltage (VEXT) 0V Maximum duty soft-start period t (ms) Figure 8 11 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series 3. Timer latch short-circuit protection function This IC has a timer latch short-circuit protection circuit that stops the switching operation when the output voltage drops for a specific time due to output short-circuiting. A capacitor (CSP) that is used to set the delay time of this short-circuit protection circuit can be connected to the CSP pin. This IC operates at the maximum duty ratio if the output voltage drops due to output short-circuiting. At the maximum duty ratio, constant-current charging of CSP starts. If this status lasts for a short-circuit protection delay time and the CSP pin voltage rises above the reference voltage, the latch mode is set. Note that the latch mode is different from the shutdown status in that the switching operation is stopped but the internal circuitry operates normally. To reset the latch operation to protect the IC from short-circuiting, lower VIN than the UVLO detection voltage. The latch mode within the short-circuit protection delay time is reset by decreasing VIN to 1.0 V (Typ.) or lower. Note that the mode is not reset even if the VIN is lowered to the UVLO detection voltage (refer to Figure 9). Input voltage (VIN) UVLO release UVLO detection 1.0 V Output load CSP pin voltage (VCSP) Short-circuit status Reference voltage 50 ms (CSP  0.1 F) Latch mode Normal status Short-circuit protection time Latch period Short-circuit protection time Reset period Short-circuit protection time Reset period Figure 9 4. UVLO function This IC includes a UVLO (under-voltage lockout) circuit to prevent the IC from malfunctioning due to a transient status when power is applied or a momentary drop of the power supply voltage. When UVLO is in the detection state, switching is stopped and the external FET is held in the off status. Once UVLO enters the detection state, the soft-start function is reset. Note that the other internal circuits operate normally and that the status is different from the power-off status. 12 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series 5. Error amplifier The error amplifier outputs the PWM control signal so that the voltage of the FB pin is held at a specific value (1 V). By connecting a resistor (RZ) and capacitor (CZ) to the output pin (CC pin) of the error amplifier in series, an optional loop gain can be set, enabling stabilized phase compensation. 6. Operation The following are basic equations [(1) through (7)] of the step-up switching regulator (refer to Figure 10). L CONT VIN M1 D VOUT EXT FB CL VSS Figure 10 Step-up Switching Regulator Circuit for Basic Equations Voltage at the CONT pin at the moment M1 is turned ON (current IL flowing through L is zero), VA: *1 VA  VS ................................................................................................................................................. (1) *1. VS: Non-saturated voltage of M1 Change in IL over time: V  VS dl L V ............................................................................................................................. (2)  L  IN dt L L Integration of the above equation:  V  VS  IL   IN   t .................................................................................................................................. (3) L   IL flows while M1 is ON (ton). This time is determined by the oscillation frequency of OSC. Peak current (IPK) after tON:  V  VS  IPK   IN   t ON ........................................................................................................................... (4) L   1 2 The energy stored in L is represented by 2 L (IPK) . When M1 is turned OFF (tOFF), the energy stored in L is released via a diode, generating a reverse voltage (VL). VL:  VL  VOUT  VD *2. *2  V IN ......................................................................................................................... (5) VD: Diode forward voltage The voltage on the CONT pin rises only by VOUT  VD. 13 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series Change in current (IL) flowing through the diode into VOUT during tOFF:  VD  VIN V dI L V ................................................................................................................. (6)  L  OUT dt L L Integration of the above equation is as follows:  VD  VIN  V IL  IPK   OUT   t .................................................................................................................. (7) L   During tON, energy is stored in L and is not transmitted to VOUT. When receiving output current (IOUT) from VOUT, the energy of the capacitor (CL) is used. As a result, the pin voltage of CL is reduced, and goes to the lowest level after M1 is turned ON (tON). When M1 is turned OFF, the energy stored in L is transmitted via the diode to CL, and the pin voltage of CL rises drastically. Because VOUT is a time function indicating the maximum value (ripple voltage: Vp-p) when the current flowing through the diode into VOUT and the load current IOUT match. Next, this ripple voltage is determined as follows. IOUT vs t1 (time) from after tON, when VOUT reaches the maximum level:  VD  VIN V IOUT  IPK   OUT L     t 1 ............................................................................................................. (8)   ........................................................................................................... (9) L   VOUT  VD  VIN    t1  IPK  IOUT   When tOFF, IL = 0 (when the energy of the inductor is completely transmitted): Based on equation (7),  L  V  V D  V IN  OUT  t   OFF ............................................................................................................ (10)  I PK  When substituting equation (10) for equation (9):  IOUT    tOFF ............................................................................................................................ (11)  IPK  t1  tOFF   Electrical charge Q1 which is charged in CL during t1: Q1  t1 t1  I dt  I   dt  0 L PK 0 V OUT  V D  VIN  L t1  tdt  I 0 PK  t1  V OUT  VD  VIN 1 2  t 1 ...................... (12) L 2 When substituting equation (12) for equation (9): ∆ Q 1  IPK  1 IPK  IOUT 2   t1  IPK  IOUT  t 1 ........................................................................... (13) 2 A rise voltage (Vp-p) due to Q1: VP - P  ∆Q1 1  IPK  IOUT      t1 ............................................................................................................ (14) CL CL  2  When taking into consideration IOUT consumed during t1 and ESR*1 (RESR) of CL: VP P  *1. ∆Q1 1  IPK  IOUT  I  t1  I  IOUT  ............................................... (15)     t 1    PK   R ESR  OUT CL CL  2 2 C    L Equivalent Series Resistance When substituting equation (11) for equation (15): VP P  (I PK  IOUT ) 2 t OFF  I  IOUT      PK   R ESR ............................................................................... (16) 2 IPK CL 2   Therefore to reduce the ripple voltage, it is important that the capacitor connected to the output pin has a large capacity and a small ESR. 14 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series  External Parts Selection 1. Inductor The inductance has a strong influence on the maximum output current (IOUT) and efficiency (). The peak current (IPK) increases by decreasing L and the stability of the circuit improves and IOUT increases. If L is decreased further, the efficiency falls, and IOUT decreases if the current drive capability of the external transistor is insufficient. The loss of IPK by the switching transistor decreases by increasing L and the efficiency becomes maximum at a certain L value. Further increasing L decrease the efficiency due to the loss of the DC resistance of the inductor. IOUT also decreases. If the oscillation frequency is higher, a smaller L value can be chosen, making the inductor smaller. In the S-8333 Series, the oscillation frequency can be varied within the range of 280 kHz to 1.08 MHz by the external resistor, so select an L value best suited to the frequency. The recommended value is between 2.2 H and 22 H. When selecting an inductor, note the allowable current of the inductor. If a current exceeding this allowable current flows through the inductor, magnetic saturation occurs, substantially lowering the efficiency and increasing the current, which results in damage to the IC. Therefore, select an inductor so that IPK does not exceed the allowable current. IPK is expressed by the following equations in the discontinuous mode and continuous mode. 2 IOUT(VOUT  VD  VIN) fosc L IPK  IPK  (VOUT  VD  VIN)  VIN VOUT  VD  IOUT  VIN 2  (VOUT  VD)  fosc  L ( discontinuous mode ) ................................................. (17) (continuous mode) ....................................................... (18) fOSC  Oscillation frequency, VD  0.4 V. 2. Diode Use an external diode that meets the following requirements.  Low forward voltage  High switching speed  Reverse breakdown voltage: VOUT  [Spike voltage] or more  Rated current: IPK or more 3. Capacitors (CIN, CL) The capacitor on the input side (CIN) can lower the supply impedance and level the input current for better efficiency. Select CIN according to the impedance of the power supply to be used. The capacitor on the output side (CL) is used to smooth the output voltage. Select an appropriate capacitance value based on the I/O conditions and load conditions. A capacitance of 10 F or more is recommended. By adjusting the phase compensation of the feedback loop using the external resistor (RZ) and capacitor (CZ), a ceramic capacitor can be used as the capacitor on the output side. If a capacitor whose equivalent series resistance is between 30 m and 500 m is used as the output capacitor, the adjustable range of the phase compensation is wider; however, note that other characteristics may be affected by ripple voltage or other conditions at this time. The optimal capacitor differs depending on the L value, capacitance value, wiring, and application (output load), so select the capacitor after performing sufficient evaluation under the actual usage conditions. 15 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series 4. External transistor A bipolar (NPN) or enhancement (N-channel) MOS FET transistor can be used as the external transistor. 4. 1 Bipolar (NPN) type The driving capability when the output current is increased by using a bipolar transistor is determined by hFE and Rb of the bipolar transistor. Figure 11 shows a peripheral circuit. VIN Cb 2200 pF Pch IPK Rb EXT 1 k Nch Figure 11 External Transistor Periphery 1 k is recommended for Rb. Actually, calculate the necessary base current (Ib) from hFE of the bipolar transistor as follows and select an Rb value lower than this. Ib  IPK hFE Rb  VIN  0.7 Ib  0.4 IEXTH A small Rb increases the output current, but the efficiency decreases. Actually, a pulsating current flows and a voltage drop occurs due to the wiring capacitance. Determine the optimum value by experiment. A speed-up capacitor (Cb) connected in parallel with Rb resistance as shown in Figure 11 decreases the switching loss and improves the efficiency. Select Cb by observing the following equation. Cb  1 2   Rb  fosc 0.7 However, in practice, the optimum Cb value also varies depending on the characteristics of the bipolar transistor employed. Therefore, determine the optimum value of Cb by experiment. 4. 2 Enhancement MOS FET type Use an Nch power MOS FET. For high efficiency, using a MOS FET with a low ON resistance (RON) and small input capacitance (CISS) is ideal, however, ON resistance and input capacitance generally share a trade-off relationship. The ON resistance is efficient in a range in which the output current is relatively great during low-frequency switching, and the input capacitance is efficient in a range in which the output current is middling during high-frequency switching. Select a MOS FET whose ON resistance and input capacitance are optimal depending on the usage conditions. The input voltage (VIN) is supplied for the gate voltage of the MOS FET, so select a MOS FET with a gate withstanding voltage that is equal to the maximum usage value of the input voltage or higher and a drain withstanding voltage that is equal to the amount of the output voltage (VOUT) and diode voltage (VD) or higher. If a MOS FET with a threshold that is near the UVLO detection voltage is used, a large current may flow, stopping the output voltage from rising and possibly generating heat in the worst case. Select a MOS FET with a threshold that is sufficiently lower than the UVLO detection voltage value. 16 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series 5. Oscillation frequency and maximum duty ratio setting resistors (ROSC, RDuty) With the S-8333 Series, the oscillation frequency can be set in a range of 280 kHz to 1.08 MHz using external resistance. Connect a resistor across the ROSC and VSS pins. Select the resistor by using the following equation and referring to Figure 12. However, the following equation and figure assume that the resistance value is the desired value and show the theoretical values when the IC is in the typical conditions. Note that fluctuations of resistance and IC are not considered. 130  103 fOSC [kHz] 1400 1200 fOSC [kHz] ROSC [k]  1000 800 600 400 200 0 0 600 400 200 ROSC [k] Figure 12 ROSC vs. fOSC With the S-8333 Series, the maximum duty ratio can be set in a range of 47% to 88.5% (between 47 to 80%, if the oscillation frequency is less than 500 kHz) by an external resistor. Connect the resistor across the RDuty and VSS pins. Select the resistance by using the following equation and referring to Figure 13. The maximum duty ratio fluctuates according to the oscillation frequency. If the value of ROSC is changed, therefore, be sure to change the value of RDuty so that it is always in proportion to RDuty / ROSC. However, the following equation and figure assume that the resistance value is the desired value and show the theoretical values when the IC is in the typical conditions. Note that fluctuations of resistance and IC are not considered. Caution Set max. duty 80% or less if the oscillation frequency is less than 500 kHz. RDuty (95.5  MaxDuty) 100 15.0 90 MaxDuty [%] ROSC  80 70 60 50 40 0 1 2 3 4 RDuty / ROSC Figure 13 RDuty / ROSC vs. MaxDuty Connect resistors ROSC and RDuty as close to the IC as possible. 17 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series 6. Short-circuit protection delay time setting capacitor (CSP) With the S-8333 Series, the short-circuit protection delay time can be set to any value by an external capacitor. Connect the capacitor across the CSP and VSS pins. Select the capacitance by using the following equation and referring to Figure 14. However, the following equation and figure assume that the capacitor value is the desired value and show the theoretical values when the IC is in the typical conditions. Note that fluctuations of capacitor and IC are not considered. tPRO [ms]  2  103 120 1.0 100 tPRO [ms] CSP [F]  80 60 40 20 0 0 0.05 0.10 0.15 0.20 0.25 CSP [F] Figure 14 CSP vs. tPRO 7. Output voltage setting resistors (RFB1, RBF2) With the S-8333 Series, the output voltage can be set to any value by external divider resistors. Connect the divider resistors across the VOUT and VSS pins. Because VFB  1 V, the output voltage can be calculated by this equation. (RFB1 RFB2) VOUT  RFB2 Connect divider resistors RFB1 and RFB2 as close to the IC to minimize effects from of noise. If noise does have an effect, adjust the values of RFB1 and RFB2 so that RFB1  RFB2 < 100 k. CFB connected in parallel with RFB1 is a capacitor for phase compensation. Select the optimum value of this capacitor at which the stable operation can be ensured from the values of the inductor and output capacitor. 8. Phase compensation setting resistor and capacitor (RZ, CZ) The S-8333 Series needs appropriate compensation for the voltage feedback loop to prevent excessive output ripple and unstable operation from deteriorating the efficiency. This compensation is implemented by connecting RZ and CZ in series across the CC and VSS pins. RZ sets the high-frequency gain for a high-speed transient response. CZ sets the pole and zero of the error amplifier and keeps the loop stable. Adjust RZ and CZ, taking into consideration conditions such as the inductor, output capacitor, and load current, so that the optimum transient characteristics can be obtained. 18 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series  Standard Circuit SD L VOUT RDuty VIN UVLO M1 CIN ROSC  PWM  comparator EXT  Timer latch short-circuit protection circuit 0.1 F VSS CSP CFB RFB1 Oscillator Maximum duty soft-start circuit  Error amplifier Reference voltage (1.0 V) soft-start circuit CL ROSC RDuty FB RFB2 CC RZ CZ Ground point Figure 15 Standard Circuit Caution The above connection diagram and constant will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constant. 19 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series  Precaution  Mount external capacitors, diodes, and inductor as close as possible to the IC.  Characteristics ripple voltage and spike noise occur in IC containing switching regulators. Moreover rush current flows at the time of a power supply injection. Because these largely depend on the inductor, the capacitor and impedance of power supply used, fully check them using an actually mounted model.  Make sure the dissipation of the switching transistor (especially at a high temperature) does not exceed the allowable power dissipation of the package.  The performance of a switching regulator varies depending on the design of the PCB patterns, peripheral circuits, and external parts. Thoroughly test all settings with your device.  The capacitor, diode, inductor and others used as external parts do not assure the operation at high temperature. Evaluate fully using the actual application when designing.  This IC builds in soft start function, starts reference voltage gradually, and it is controlled so that FB pin voltage and reference voltage become this potential. Therefore, keep in mind that it will be in a maximum duty state according to the factor of IC exterior if FB pin voltage is held less than reference voltage.  Although the IC contains a static electricity protection circuit, static electricity or voltage that exceeds the limit of the protection circuit should not be applied.  ABLIC Inc. assumes no responsibility for the way in which this IC is used on products created using this IC or for the specifications of that product, nor does ABLIC Inc. assume any responsibility for any infringement of patents or copyrights by products that include this IC either in Japan or in other countries. 20 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series  Characteristics (Typical Data) 1. Example of Major Temperature Characteristics (Ta  40 to 85C)           W            W             W    -  -        ° IEXTL vs. Ta (VIN  3.3 V)   - - - -  - - - -        !"# -  $%   W, %  " W& -  -  -      °   IEXTH vs. Ta (VIN  3.3 V)            W          W          W    -  -        °    20 40 Ta [C] 60 80 100 MaxDuty vs. Ta (VIN  3.3 V) 100 90 MaxDuty = 88.5% (ROSC = 200 kRDuty = 100 k) 80 70 MaxDuty = 73% (ROSC = 200 kRDuty = 300 k) 60 50 40 MaxDuty = 47% (ROSC = 200 kRDuty = 640 k) 30 20 10 0 40 20 0 20 40 60 80 100 Ta [C] MaxDuty [%]               !  "#$   %&   W, & !  # W'  -  -      ° fOSC vs. Ta (VIN  3.3 V) IFB [A] IFB vs. Ta (VIN  3.3 V) 0.10 0.08 0.06 0.04 0.02 0 0.02 0.04 0.06 0.08 0.10 40 20 0   tSS vs. Ta (VIN  3.3 V) 25.0 tSS = 20 ms 20.0 tSS [ms] m ISS1 vs. Ta (VIN  3.3 V) 15.0 tSS = 10 ms 10.0 5.0 0 40 20 0 20 40 Ta [C] 60 80 100 21 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series VUVLO vs. Ta 2.5 VUVLOHYS vs. Ta 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 40 20 ICCH vs. Ta (VIN  3.3 V) VUVLO = 1.5 V 1.0 0 40 20 - - - - - -  -  -  - -  -  - 0 100 20 40 Ta [C] 60 80    °     60 80 m VUVLOHYS [V] VUVLOHYS = 0.1 V 0 20 40 Ta [C] 60 80 100  VRTLT1 vs. Ta (VIN  3.3 V) 1.2 1.0 VRTLT1 [V] m 22 VUVLO = 2.3 V 1.5 0.5 VUVLOHYS = 0.3 V ICCL vs. Ta (VIN  3.3 V)            -  - 2.0 VUVLO [V] tPRO [ms] tPRO vs. Ta (VIN  3.3 V) 70.0 tPRO = 50 ms (CSP = 0.1 F) 60.0 50.0 40.0 30.0 20.0 10.0 0 40 20 0 20 40 60 80 100 Ta [C] 0.8 0.6 0.4 0.2     °     0 40 20 0 20 40 Ta [C] 100 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series 2. Example of Major Power Supply Dependence Characteristics (Ta  25C) ISS1 vs. VIN  m                   W          W          W            - - - - - - - - - - IEXTL vs. VIN       !"#$  % &'   W, '!"#$   W(               !"#$%  & '(   W, ("#$%   W)             fOSC vs. VIN               9  2 3 4 VIN [V] 5 6        9       9  7       tSS vs. VIN 25.0 20.0 MaxDuty = 88.5% (ROSC = 200 kRDuty = 100 k) tSS [ms] 1 MaxDuty vs. VIN 100 90 80 70 60 50 40 30 20 10 0 1 0 MaxDuty [%]            IFB [A] IFB vs. VIN 0.10 0.08 0.06 0.04 0.02 0 0.02 0.04 0.06 0.08 0.10 0  IEXTH vs. VIN MaxDuty = 73% (ROSC = 200 kRDuty = 300 k) MaxDuty = 47% (ROSC = 200 kRDuty = 640 k) tSS = 20 ms 15.0 10.0 tSS = 10 ms 5.0 0 2 3 4 VIN [V] 5 6 7 0 1 2 3 4 VIN [V] 5 6 7 23 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series ICCH vs. VIN - - - - - - - - - - tPRO=50 ms (CSP = 0.1 F) m tPRO [ms] tPRO vs. VIN 70.0 60.0 50.0 40.0 30.0 20.0 10.0 0 0 1 2 3 4 VIN [V] 5 6 7          m ICCL vs. VIN 24                  STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series 3. Example of External Parts Dependence Characteristics fOSC vs. ROSC (VIN  3.3 V)           - °    °   °      W   MaxDuty [%] MaxDuty vs. RDuty / ROSC (ROSC  200 k, VIN  3.3 V) 100 90 Ta = 40C 80 Ta = 25C 70 Ta = 85C 60 50 40 30 20 10 0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 RDuty / ROSC tPRO [ms] tPRO vs. CSP (VIN  3.3 V) 350 300 250 200 150 100 50 0 0.1 0 0.2 0.3 CSP [F] Ta = 40C Ta = 25C Ta = 85C 0.4 0.5 25 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series 4. Examples of Transient Response Characteristics 4.1 Powering ON (VOUT  9.2 V, VIN  0 V → 3.3 V, Ta  25C) Remark The switch (SW) is inserted between the diode (SD) and VOUT output. Controlled externally to turn SW on a few ms later after the VIN voltage is applied. (1) fOSC  1080 kHz, IOUT  0 mA, tSS  10 ms (2) fOSC  1080 kHz, IOUT  100 mA, tSS  10 ms 4 0 2 0 5 10 time [ms] 15 4 2 0 5 20 (3) fOSC  650 kHz, IOUT  0 mA, tSS  10 ms 0 0 5 10 time [ms] 15 20 (4) fOSC  650 kHz, IOUT  100 mA, tSS  10 ms 12 8 4 0 2 0 5 0 5 10 time [ms] 15 8 4 VIN [V] VIN [V] 4 VOUT [V] 12 4 (5) fOSC  280 kHz, IOUT  0 mA, tSS  10 ms 0 2 0 5 20 0 5 10 time [ms] 15 20 (6) fOSC  280 kHz, IOUT  100 mA, tSS  10 ms 12 VIN [V] 4 4 26 0 2 0 0 5 10 time [ms] 15 20 8 4 VIN [V] 8 VOUT [V] 12 5 VOUT [V] 0 4 4 0 2 0 5 0 5 10 time [ms] 15 20 VOUT [V] 5 8 VIN [V] VIN [V] 4 VOUT [V] 8 VOUT [V] 12 12 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series 4.2 Load fluctuations (VOUT  9.2 V, VIN  3.3 V, Ta  25C, RZ  200 k, CZ  0.01 F) (1) fOSC  1080 kHz, IOUT  0.1 mA100 mA IOUT 100 mA (2) fOSC  1080 kHz, IOUT  100 mA0.1 mA 10.0 0.1 mA 9.8 IOUT 100 mA 9.6 0.1 mA 10.0 9.8 9.6 9.4 9.2 VOUT [0.2 V/div] 20 9.0 10 0 time [ms] 10 20 (3) fOSC  650 kHz, IOUT  0.1 mA100 mA IOUT 100 mA 8.8 9.4 9.2 VOUT [0.2 V/div] 20 9.0 10 0 time [ms] 10 20 (4) fOSC  650 kHz, IOUT  100 mA0.1 mA 10.0 0.1 mA 9.8 IOUT 100 mA 9.6 0.1 mA 10.0 9.8 9.6 9.4 9.2 VOUT [0.2 V/div] 20 9.0 10 0 time [ms] 10 20 (5) fOSC  280 kHz, IOUT  0.1 mA100 mA IOUT 100 mA 8.8 9.4 9.2 VOUT [0.2 V/div] 20 9.0 10 0 time [ms] 10 20 9.8 IOUT 100 mA 9.6 0.1 mA 10.0 9.8 9.6 9.4 9.2 VOUT [0.2 V/div] 9.0 10 0 time [ms] 10 8.8 (6) fOSC  280 kHz, IOUT  100 mA0.1 mA 10.0 0.1 mA 20 8.8 20 8.8 9.4 9.2 VOUT [0.2 V/div] 20 9.0 10 0 time [ms] 10 20 8.8 27 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series 4.3 Input voltage fluctuations (VOUT  9.2 V, IOUT  100 mA, RZ  200 k, CZ  0.01 F) (1) fOSC  1080 kHz, VIN  2.8 V3.8 V 4.0 VIN 3.5 [V] 3.0 2.5 20 10 0 time [ms] 10 (3) fOSC  650 kHz, VIN  2.8 V3.8 V 4.0 VIN 3.5 [V] 3.0 2.5 20 10 0 time [ms] 10 (5) fOSC  280 kHz, VIN  2.8 V3.8 V 4.0 VIN 3.5 [V] 3.0 2.5 20 28 10 0 time [ms] 10 9.40 9.30 VOUT 9.20 [V] 9.10 20 9.40 9.30 VOUT 9.20 [V] 9.10 20 9.40 9.30 VOUT 9.20 [V] 9.10 20 (2) fOSC  1080 kHz, VIN  3.8 V2.8 V 4.0 VIN 3.5 [V] 3.0 2.5 20 10 0 time [ms] 10 (4) fOSC  650 kHz, VIN  3.8 V2.8 V 4.0 VIN 3.5 [V] 3.0 2.5 20 10 0 time [ms] 10 (6) fOSC  280 kHz, VIN  3.8 V2.8 V 4.0 VIN 3.5 [V] 3.0 2.5 20 10 0 time [ms] 10 9.40 9.30 VOUT 9.20 [V] 9.10 20 9.40 9.30 VOUT 9.20 [V] 9.10 20 9.40 9.30 VOUT 9.20 [V] 9.10 20 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series  Reference Data 1. Reference data for external parts Table 6 Properties of External Parts Element Name Inductor Diode Output capacitor (ceramic) Transistor Product Name Manufacture LDR655312T TDK Corporation RB491D Rohm Co., Ltd.   MCH3406 Sanyo Electric Co., Ltd. Characteristics 10 H, DCR*1  307 m, IMAX*2  0.7 A, Height  1.2 mm VF*3  0.45 V, IF*4  1.0 A 16 V, 10 F VDSS*5  20 V, VGSS*6  10 V, Ciss*7  280 pF, RDS(ON)*8  82 m max. (VGS*9  2.5 V, ID*10  1 A) *1. DCR : DC resistance *2. IMAX : Maximum allowable current *3. VF : Forward voltage *4. IF : Forward current *5. VDSS : Drain to source voltage (when short circuited between the gate and source) *6. VGSS : Gate to source voltage (when short circuited between the drain and source) *7. Ciss : Input capacitance *8. RDS(ON) : Drain to source on resistance *9. VGS : Gate to source voltage *10. ID : Drain current Caution The values shown in the characteristics column of Table 6 above are based on the materials provided by each manufacturer. However, consider the characteristics of the original materials when using the above products. 29 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series 2. Reference data (1) The data of (a) output current (IOUT) vs. efficiency () characteristics and (b) output current (IOUT) vs. output voltage (VOUT) characteristics is shown below. 2. 1 VOUT  13.1 V (RFB1  7.5 k, RFB2  620 ) (1) fOSC  1080 kHz, MaxDuty  73% (ROSC  120 k, RDuty  180 k) (b) IOUT vs. VOUT 13.20 VOUT [V] 13.15  [%] (a) IOUT vs.  100 90 80 70 60 50 40 30 20 10 0 0.01 1 10 IOUT [mA] 100 13.05 13.00 12.95 VIN = 5.0 V 0.1 13.10 12.90 0.01 1000 VIN = 5.0 V 0.1 1 10 IOUT [mA] 100 1000 (2) fOSC  650 kHz, MaxDuty  73% (ROSC  200 k, RDuty  300 k) (b) IOUT vs. VOUT 13.20 VOUT [V] 13.15  [%] (a) IOUT vs.  100 90 80 70 60 50 40 30 20 10 0 0.01 1 10 IOUT [mA] 100 13.05 13.00 12.95 VIN = 5.0 V 0.1 13.10 12.90 0.01 1000 VIN = 5.0 V 0.1 1 10 IOUT [mA] 100 1000 (3) fOSC  280 kHz, MaxDuty  73% (ROSC  470 k, RDuty  750 k) (b) IOUT vs. VOUT 13.20 VOUT [V] 13.15  [%] (a) IOUT vs.  100 90 80 70 60 50 40 30 20 10 0 0.01 30 VIN = 5.0 V 0.1 1 10 IOUT [mA] 100 1000 13.10 13.05 13.00 12.95 12.90 0.01 VIN = 5.0 V 0.1 1 10 IOUT [mA] 100 1000 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series 2. 2 VOUT  9.2 V (RFB1  8.2 k, RFB2  1.0 k) (1) fOSC  1080 kHz, MaxDuty  73% (ROSC  120 k, RDuty  180 k) (b) IOUT vs. VOUT 9.30 VOUT [V] 9.25  [%] (a) IOUT vs.  100 90 80 70 60 50 40 30 20 10 0 0.01 VIN = 3.3 V VIN = 5.0 V 0.1 1 10 IOUT [mA] 100 9.20 9.15 9.10 VIN = 3.3 V VIN = 5.0 V 9.05 9.00 0.01 1000 0.1 1 10 IOUT [mA] 100 1000 (2) fOSC  650 kHz, MaxDuty  73% (ROSC  200 k, RDuty  300 k) (b) IOUT vs. VOUT 9.30 VOUT [V] 9.25  [%] (a) IOUT vs.  100 90 80 70 60 50 40 30 20 10 0 0.01 VIN = 3.3 V VIN = 5.0 V 0.1 1 10 IOUT [mA] 100 9.20 9.15 9.10 VIN = 3.3 V VIN = 5.0 V 9.05 9.00 0.01 1000 0.1 1 10 IOUT [mA] 100 1000 (3) fOSC  280 kHz, MaxDuty  73% (ROSC  470 k, RDuty  750 k) (b) IOUT vs. VOUT 9.30 VOUT [V] 9.25  [%] (a) IOUT vs.  100 90 80 70 60 50 40 30 20 10 0 0.01 VIN = 3.3 V VIN = 5.0 V 0.1 1 10 IOUT [mA] 100 1000 9.20 9.15 9.10 VIN = 3.3 V VIN = 5.0 V 9.05 9.00 0.01 0.1 1 10 IOUT [mA] 100 1000 31 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series 2. 3 VOUT  6.1 V (RFB1  5.1 k, RFB2  1.0 k) (1) fOSC  1080 kHz, MaxDuty  73% (ROSC  120 k, RDuty  180 k) (b) IOUT vs. VOUT 6.20 VOUT [V] 6.15  [%] (a) IOUT vs.  100 90 80 70 60 50 40 30 20 10 0 0.01 VIN = 2.5 V VIN = 3.3 V 0.1 1 10 IOUT [mA] 100 6.10 6.05 6.00 VIN = 2.5 V VIN = 3.3 V 5.95 5.90 0.01 1000 0.1 1 10 IOUT [mA] 100 1000 (2) fOSC  650 kHz, MaxDuty  73% (ROSC  200 k, RDuty  300 k) (b) IOUT vs. VOUT 6.20 VOUT [V] 6.15  [%] (a) IOUT vs.  100 90 80 70 60 50 40 30 20 10 0 0.01 VIN = 2.5 V VIN = 3.3 V 0.1 1 10 IOUT [mA] 100 6.10 6.05 6.00 VIN = 2.5 V VIN = 3.3 V 5.95 5.90 0.01 1000 0.1 1 10 IOUT [mA] 100 1000 (3) fOSC  280 kHz, MaxDuty  73% (ROSC  470 k, RDuty  750 k) (b) IOUT vs. VOUT 6.20 VOUT [V] 6.15  [%] (a) IOUT vs.  100 90 80 70 60 50 40 30 20 10 0 0.01 32 VIN = 2.5 V VIN = 3.3 V 0.1 1 10 IOUT [mA] 100 1000 6.10 6.05 6.00 VIN = 2.5 V VIN = 3.3 V 5.95 5.90 0.01 0.1 1 10 IOUT [mA] 100 1000 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series 3. Reference data (2) The data of output current (IOUT) vs. ripple voltage (Vr) characteristics is shown below. 3. 1 VOUT  13.1 V (RFB1  7.5 k, RFB2  620 ) 100 1000 100 1000 100 1000 100 1000 Vr [mV] (3) fOSC  280 kHz, MaxDuty  73% (ROSC  470 k, RDuty  750 k) 100 90 VIN = 5.0 V 80 70 60 50 40 30 20 10 0 0.1 0.01 1 10 IOUT [mA] (2) fOSC  650 kHz, MaxDuty  73% (ROSC  200 k, RDuty  300 k) 100 90 VIN = 5.0 V 80 70 60 50 40 30 20 10 0 0.1 0.01 1 10 IOUT [mA] Vr [mV] Vr [mV] (1) fOSC  1080 kHz, MaxDuty  73 % (ROSC  120 k, RDuty  180 k) 100 90 VIN = 5.0 V 80 70 60 50 40 30 20 10 0 0.1 0.01 1 10 IOUT [mA] 3. 2 VOUT  9.2 V (RFB1  8.2 k, RFB2  1.0 k) 100 1000 100 1000 Vr [mV] (3) fOSC  280 kHz, MaxDuty  73% (ROSC  470 k, RDuty  750 k) 100 VIN = 3.3 V 90 80 VIN = 5.0 V 70 60 50 40 30 20 10 0 0.1 0.01 1 10 IOUT [mA] (2) fOSC  650 kHz, MaxDuty  73% (ROSC  200 k, RDuty  300 k) 100 90 VIN = 3.3 V 80 VIN = 5.0 V 70 60 50 40 30 20 10 0 0.1 0.01 1 10 IOUT [mA] Vr [mV] Vr [mV] (1) fOSC  1080 kHz, MaxDuty  73% (ROSC  120 k, RDuty  180 k) 100 90 VIN = 3.3 V 80 VIN = 5.0 V 70 60 50 40 30 20 10 0 0.1 0.01 1 10 IOUT [mA] 33 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series 3. 3 VOUT  6.1 V (RFB1  5.1 k, RFB2  1.0 k) 100 1000 100 1000 Vr [mV] (3) fOSC  280 kHz, MaxDuty  73% (ROSC  470 k, RDuty  750 k) 100 VIN = 2.5 V 90 80 VIN = 3.3 V 70 60 50 40 30 20 10 0 0.1 0.01 1 10 IOUT [mA] 34 (2) fOSC  650 kHz, MaxDuty  73% (ROSC  200 k, RDuty  300 k) 100 VIN = 2.5 V 90 80 VIN = 3.3 V 70 60 50 40 30 20 10 0 0.1 0.01 1 10 IOUT [mA] Vr [mV] Vr [mV] (1) fOSC  1080 kHz, MaxDuty  73% (ROSC  120 k, RDuty  180 k) 100 90 VIN = 2.5 V 80 VIN = 3.3 V 70 60 50 40 30 20 10 0 0.1 0.01 1 10 IOUT [mA] 100 1000 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series  Marking Specifications 1. SNT-8A 8 Top view 7 6 5 (1): (2) to (4): (5), (6): (7) to (11): (1) (2) (3) (4) Blank Product code (Refer to Product name vs. Product code) Blank Lot number (5) (6) (7) (8) (9) (10) (11) 1 2 3 4 Product name vs. Product code Product name S-8333CAAA-I8T1U S-8333CAAB-I8T1U S-8333CAAC-I8T1U S-8333CABA-I8T1U S-8333CABB-I8T1U S-8333CABC-I8T1U S-8333CACA-I8T1U S-8333CACB-I8T1U S-8333CACC-I8T1U S-8333CADA-I8T1U S-8333CADB-I8T1U S-8333CADC-I8T1U S-8333CAEA-I8T1U S-8333CAEB-I8T1U S-8333CAEC-I8T1U S-8333CAFA-I8T1U S-8333CAFB-I8T1U S-8333CAFC-I8T1U S-8333CAGA-I8T1U S-8333CAGB-I8T1U S-8333CAGC-I8T1U S-8333CAHA-I8T1U S-8333CAHB-I8T1U S-8333CAHC-I8T1U S-8333CAIA-I8T1U S-8333CAIB-I8T1U S-8333CAIC-I8T1U S-8333CBAA-I8T1U S-8333CBAB-I8T1U S-8333CBAC-I8T1U S-8333CBBA-I8T1U S-8333CBBB-I8T1U S-8333CBBC-I8T1U S-8333CBCA-I8T1U S-8333CBCB-I8T1U S-8333CBCC-I8T1U S-8333CBDA-I8T1U S-8333CBDB-I8T1U S-8333CBDC-I8T1U S-8333CBEA-I8T1U S-8333CBEB-I8T1U (2) U U U U U U U U U U U U U U U U U U U U U U U U U U U U U U U U U U U U U U U U U Product code (3) (4) 2 A 2 B 2 C 2 D 2 E 2 F 2 G 2 H 2 I 2 J 2 K 2 L 2 M 2 N 2 O 2 P 2 Q 2 R 2 S 2 T 2 U 2 V 2 W 2 X 2 Y 2 Z 2 3 3 A 3 B 3 C 3 D 3 E 3 F 3 G 3 H 3 I 3 J 3 K 3 L 3 M 3 N Product name S-8333CBEC-I8T1U S-8333CBFA-I8T1U S-8333CBFB-I8T1U S-8333CBFC-I8T1U S-8333CBGA-I8T1U S-8333CBGB-I8T1U S-8333CBGC-I8T1U S-8333CBHA-I8T1U S-8333CBHB-I8T1U S-8333CBHC-I8T1U S-8333CBIA-I8T1U S-8333CBIB-I8T1U S-8333CBIC-I8T1U S-8333CCAA-I8T1U S-8333CCAB-I8T1U S-8333CCAC-I8T1U S-8333CCBA-I8T1U S-8333CCBB-I8T1U S-8333CCBC-I8T1U S-8333CCCA-I8T1U S-8333CCCB-I8T1U S-8333CCCC-I8T1U S-8333CCDA-I8T1U S-8333CCDB-I8T1U S-8333CCDC-I8T1U S-8333CCEA-I8T1U S-8333CCEB-I8T1U S-8333CCEC-I8T1U S-8333CCFA-I8T1U S-8333CCFB-I8T1U S-8333CCFC-I8T1U S-8333CCGA-I8T1U S-8333CCGB-I8T1U S-8333CCGC-I8T1U S-8333CCHA-I8T1U S-8333CCHB-I8T1U S-8333CCHC-I8T1U S-8333CCIA-I8T1U S-8333CCIB-I8T1U S-8333CCIC-I8T1U Product code (2) (3) (4) U 3 O U 3 P U 3 Q U 3 R U 3 S U 3 T U 3 U U 3 V U 3 W U 3 X U 3 Y U 3 Z U 3 3 U 4 A U 4 B U 4 C U 4 D U 4 E U 4 F U 4 G U 4 H U 4 I U 4 J U 4 K U 4 L U 4 M U 4 N U 4 O U 4 P U 4 Q U 4 R U 4 S U 4 T U 4 U U 4 V U 4 W U 4 X U 4 Y U 4 Z U 4 3 35 STEP-UP, FOR LCD BIAS SUPPLY, 1-CHANNEL, PWM CONTROL SWITCHING REGULATOR CONTROLLER Rev.4.2_02 S-8333 Series 2. 8-Pin TSSOP Top view 1 2 3 4 8 (1) (2) (3) (4) 7 (5) (6) (7) (8) (1) to (4): (5) to (8): (9) to (14): Product name: 8333 (Fixed) Function code (Refer to Product name vs. Function code) Lot number 6 (9) (10) (11) (12) (13) (14) 5 Product name vs. Function code Product name S-8333CAAA-T8T1y S-8333CAAB-T8T1y S-8333CAAC-T8T1y S-8333CABA-T8T1y S-8333CABB-T8T1y S-8333CABC-T8T1y S-8333CACA-T8T1y S-8333CACB-T8T1y S-8333CACC-T8T1y S-8333CADA-T8T1y S-8333CADB-T8T1y S-8333CADC-T8T1y S-8333CAEA-T8T1y S-8333CAEB-T8T1y S-8333CAEC-T8T1y S-8333CAFA-T8T1y S-8333CAFB-T8T1y S-8333CAFC-T8T1y S-8333CAGA-T8T1y S-8333CAGB-T8T1y S-8333CAGC-T8T1y S-8333CAHA-T8T1y S-8333CAHB-T8T1y S-8333CAHC-T8T1y S-8333CAIA-T8T1y S-8333CAIB-T8T1y S-8333CAIC-T8T1y S-8333CBAA-T8T1y S-8333CBAB-T8T1y S-8333CBAC-T8T1y S-8333CBBA-T8T1y S-8333CBBB-T8T1y S-8333CBBC-T8T1y S-8333CBCA-T8T1y S-8333CBCB-T8T1y S-8333CBCC-T8T1y S-8333CBDA-T8T1y S-8333CBDB-T8T1y S-8333CBDC-T8T1y S-8333CBEA-T8T1y S-8333CBEB-T8T1y (5) C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C Function code (6) (7) (8) A A A A A B A A C A B A A B B A B C A C A A C B A C C A D A A D B A D C A E A A E B A E C A F A A F B A F C A G A A G B A G C A H A A H B A H C A I A A I B A I C B A A B A B B A C B B A B B B B B C B C A B C B B C C B D A B D B B D C B E A B E B Product name S-8333CBEC-T8T1y S-8333CBFA-T8T1y S-8333CBFB-T8T1y S-8333CBFC-T8T1y S-8333CBGA-T8T1y S-8333CBGB-T8T1y S-8333CBGC-T8T1y S-8333CBHA-T8T1y S-8333CBHB-T8T1y S-8333CBHC-T8T1y S-8333CBIA-T8T1y S-8333CBIB-T8T1y S-8333CBIC-T8T1y S-8333CCAA-T8T1y S-8333CCAB-T8T1y S-8333CCAC-T8T1y S-8333CCBA-T8T1y S-8333CCBB-T8T1y S-8333CCBC-T8T1y S-8333CCCA-T8T1y S-8333CCCB-T8T1y S-8333CCCC-T8T1y S-8333CCDA-T8T1y S-8333CCDB-T8T1y S-8333CCDC-T8T1y S-8333CCEA-T8T1y S-8333CCEB-T8T1y S-8333CCEC-T8T1y S-8333CCFA-T8T1y S-8333CCFB-T8T1y S-8333CCFC-T8T1y S-8333CCGA-T8T1y S-8333CCGB-T8T1y S-8333CCGC-T8T1y S-8333CCHA-T8T1y S-8333CCHB-T8T1y S-8333CCHC-T8T1y S-8333CCIA-T8T1y S-8333CCIB-T8T1y S-8333CCIC-T8T1y (5) C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C Function code (6) (7) B E B F B F B F B G B G B G B H B H B H B I B I B I C A C A C A C B C B C B C C C C C C C D C D C D C E C E C E C F C F C F C G C G C G C H C H C H C I C I C I Remark 1. y: S or U 2. Please select products of environmental code = U for Sn 100%, halogen-free products. 36 (8) C A B C A B C A B C A B C A B C A B C A B C A B C A B C A B C A B C A B C A B C 1.97±0.03 8 7 6 5 3 4 +0.05 1 0.5 2 0.08 -0.02 0.48±0.02 0.2±0.05 No. PH008-A-P-SD-2.1 TITLE SNT-8A-A-PKG Dimensions No. PH008-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 2.25±0.05 4.0±0.1 2.0±0.05 ø0.5±0.1 0.25±0.05 0.65±0.05 4.0±0.1 4 321 5 6 78 Feed direction No. PH008-A-C-SD-2.0 TITLE SNT-8A-A-Carrier Tape No. PH008-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PH008-A-R-SD-1.0 TITLE SNT-8A-A-Reel No. PH008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 5,000 0.52 2.01 2 0.52 0.2 0.3 1. 2. 1 (0.25 mm min. / 0.30 mm typ.) (1.96 mm ~ 2.06 mm) 1. 2. 3. 4. 0.03 mm SNT 1. Pay attention to the land pattern width (0.25 mm min. / 0.30 mm typ.). 2. Do not widen the land pattern to the center of the package (1.96 mm to 2.06mm). Caution 1. Do not do silkscreen printing and solder printing under the mold resin of the package. 2. The thickness of the solder resist on the wire pattern under the package should be 0.03 mm or less from the land pattern surface. 3. Match the mask aperture size and aperture position with the land pattern. 4. Refer to "SNT Package User's Guide" for details. 1. 2. (0.25 mm min. / 0.30 mm typ.) (1.96 mm ~ 2.06 mm) TITLE No. PH008-A-L-SD-4.1 SNT-8A-A -Land Recommendation PH008-A-L-SD-4.1 No. ANGLE UNIT mm ABLIC Inc. +0.3 3.00 -0.2 8 5 1 4 0.17±0.05 0.2±0.1 0.65 No. FT008-A-P-SD-1.2 TITLE TSSOP8-E-PKG Dimensions No. FT008-A-P-SD-1.2 ANGLE UNIT mm ABLIC Inc. 4.0±0.1 2.0±0.05 ø1.55±0.05 0.3±0.05 +0.1 8.0±0.1 ø1.55 -0.05 (4.4) +0.4 6.6 -0.2 1 8 4 5 Feed direction No. FT008-E-C-SD-1.0 TITLE TSSOP8-E-Carrier Tape FT008-E-C-SD-1.0 No. ANGLE UNIT mm ABLIC Inc. 13.4±1.0 17.5±1.0 Enlarged drawing in the central part ø21±0.8 2±0.5 ø13±0.5 No. FT008-E-R-SD-1.0 TITLE TSSOP8-E-Reel No. FT008-E-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 3,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-8333CBDA-I8T1G 价格&库存
很抱歉,暂时无法提供与“S-8333CBDA-I8T1G”相匹配的价格&库存,您可以联系我们找货
