S-19315AAAA-U5T1U7
S-19315AAAA-U5T1U7
    ABLIC(艾普凌科)
    SOT89-5
    IC REG LINEAR 1V 40MA SOT89-5
S-19315AAAA-U5T1U7 数据手册
S-19315 Series www.ablic.com AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION Rev.1.1_01 © ABLIC Inc., 2020 The S-19315 Series, developed by using high-withstand voltage CMOS process technology, is a positive voltage regulator with the reset function, which has high-withstand voltage and low current consumption. Apart from the power supply pin, the detection voltage input pin (SENSE pin) is also prepared for the reset function, so the output is stable even if the SENSE pin falls to 0 V. The output form is Nch open-drain output. ABLIC Inc. offers a "thermal simulation service" which supports the thermal design in conditions when our power management ICs are in use by customers. Our thermal simulation service will contribute to reducing the risk in the thermal design at customers' development stage. ABLIC Inc. also offers FIT rate calculated based on actual customer usage conditions in order to support customer functional safety design. Contact our sales representatives for details. Caution This product can be used in vehicle equipment and in-vehicle equipment. Before using the product for these purposes, it is imperative to contact our sales representatives.  Features Regulator block • Output voltage: • Input voltage: • Output voltage accuracy: • Dropout voltage: • Output current: • Input and output capacitors: • Built-in overcurrent protection circuit: • Built-in thermal shutdown circuit: • Built-in discharge shunt circuit: 1.0 V to 5.3 V, selectable in 0.1 V step 3.0 V to 36.0 V ±0.03 V (1.0 V ≤ VOUT(S) < 1.5 V, Tj = −40°C to +125°C) ±2.0% (1.5 V ≤ VOUT(S) ≤ 5.3 V, Tj = −40°C to +125°C) 240 mV typ. (VOUT(S) = 5.0 V, IOUT = 30 mA) Possible to output 40 mA (1.0 V ≤ VOUT(S) < 2.0 V, VIN = 4.0 V)*1 Possible to output 40 mA (2.0 V ≤ VOUT(S) ≤ 5.3 V, VIN = VOUT(S) + 2.0 V)*1 A ceramic capacitor can be used. (1.0 μF or more) Limits overcurrent of output transistor Detection temperature 160°C typ. Discharges output capacitor electrical charge during detector detection Detector block • Detection voltage: • Operation voltage: • Detection voltage accuracy: • Hysteresis width selectable from "Available" / "Unavailable": • Output form: 3.0 V to 11.3 V, selectable in 0.1 V step 3.0 V to 36.0 V ±2.0% (Tj = −40°C to +125°C) "Available": 5.0% ≤ VHYS ≤ 30.0% (Tj = −40°C to +125°C) "Unavailable": VHYS = 0% Nch open-drain output Overall • Current consumption: • Operation temperature range: • Lead-free (Sn 100%), halogen-free • Withstand 45 V load dump • AEC-Q100 qualified*2 *1. *2. During operation: 2.0 μA typ. (Tj = −40°C to +125°C) During detector detection: 0.5 μA typ. (Tj = −40°C to +125°C) Ta = −40°C to +125°C Please make sure that the loss of the IC will not exceed the power dissipation when the output current is large. Contact our sales representatives for details.  Applications • Constant-voltage power supply and reset circuit for automotive electric component • Power supply and reset circuit for low-current battery-powered device  Packages • SOT-89-5 • HTMSOP-8 • SOT-23-5 1 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION S-19315 Series Rev.1.1_01  Block Diagram *1 VIN VOUT Overcurrent protection circuit Constantvoltage circuit *1 Thermal shutdown circuit − + Reference voltage circuit *1 SENSE ON / OFF circuit*2 + − RO Reference voltage circuit *1 *1 VSS *1. Parasitic diode *2. The ON / OFF circuit controls the internal circuit of the regulator and the output transistor. Figure 1 2 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION Rev.1.1_01 S-19315 Series  AEC-Q100 Qualified This IC supports AEC-Q100 for operation temperature grade 1. Contact our sales representatives for details of AEC-Q100 reliability specification.  Product Name Structure Users can select the output voltage, detection voltage, release voltage, and package type for the S-19315 Series. Refer to "1. Product name" regarding the contents of product name, "3. Packages" regarding the package drawings. 1. Product name S-19315 A xx A - xxxx U 7 Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 U5T1: SOT-89-5, Tape S8T1: HTMSOP-8, Tape M5T1: SOT-23-5, Tape Operation temperature A: Ta = −40°C to +125°C Output voltage, detection voltage, release voltage*2 AA to 99 (2-digit option code) Product type*3 *1. *2. *3. Refer to the tape drawing. Contact our sales representatives for details on combination of output voltage, detection voltage, and release voltage. Refer to "2. Function list of product type". 3 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION S-19315 Series Rev.1.1_01 Remark 1. The output voltage (VOUT) can be set in a range which satisfies the following conditions. • Set output voltage (VOUT(S)) is 100 mV step • 1.0 V ≤ VOUT(S) ≤ 5.3 V 2. The detection voltage (−VDET) can be set in a range which satisfies the following conditions. • Set detection voltage (−VDET(S)) is 100 mV step • 3.0 V ≤ −VDET(S) ≤ 11.3 V 3. The release voltage (+VDET) can be set in a range which satisfies the following conditions. Release voltage possible setting range is shown in Figure 2. • Set release voltage (+VDET(S)) is 100 mV step • 5.0% ≤ VHYS ≤ 30.0% 15.0 +VDET [V] 13.0 11.0 9.0 7.0 5.0 3.0 2.0 Figure 2 4.0 6.0 8.0 −VDET [V] 10.0 12.0 Release Voltage Possible Setting Area If hysteresis width "Unavailable" was selected, +VDET = −VDET. 2. Function list of product type Table 1 Product Type A 3. RO Pin Output Form Nch open-drain output Packages Table 2 Package Name SOT-89-5 HTMSOP-8 SOT-23-5 4 RO Pin Output Logic Active "L" Dimension UP005-A-P-SD FP008-A-P-SD MP005-A-P-SD Package Drawing Codes Tape UP005-A-C-SD FP008-A-C-SD MP005-A-C-SD Reel UP005-A-R-SD FP008-A-R-SD MP005-A-R-SD Land − FP008-A-L-SD − AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION Rev.1.1_01 S-19315 Series  Pin Configurations 1. SOT-89-5 Top view 5 Table 3 Pin No. 4 1 2 Symbol Description 1 SENSE Detection voltage input pin 2 VSS GND pin 3 VIN Input voltage pin 4 VOUT Output voltage pin 5 RO Reset output pin 3 Figure 3 2. HTMSOP-8 Top view 1 2 3 4 Table 4 8 7 6 5 Bottom view 1 2 3 4 8 7 6 5 Pin No. 1 Symbol NC*2 Description 2 VOUT Output voltage pin 3 RO Reset output pin 4 NC*2 5 SENSE No connection Detection voltage input pin 6 VSS GND pin 7 NC*2 No connection 8 VIN Input voltage pin No connection *1 Figure 4 *1. Connect the heat sink of backside at shadowed area to the board, and set electric potential GND. However, do not use it as the function of electrode. *2. The NC pin is electrically open. The NC pin can be connected to the VIN pin or the VSS pin. 3. SOT-23-5 Top view 5 4 1 2 3 Table 5 Pin No. Symbol Description 1 RO Reset output pin 2 VSS GND pin 3 VOUT Output voltage pin 4 VIN 5 SENSE Input voltage pin Detection voltage input pin Figure 5 5 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION S-19315 Series Rev.1.1_01  Absolute Maximum Ratings Table 6 (Ta = +25°C unless otherwise specified) Item Symbol Input voltage Absolute Maximum Rating Unit VSS − 0.3 to VSS + 45.0 V VIN VSS − 0.3 to VIN + 0.3 ≤ VSS + 7.0 VOUT VSS − 0.3 to VSS + 45.0 VRO VSS − 0.3 to VSS + 45.0 VSENSE SENSE pin voltage Output current (Regulator block) IOUT 52 Output current (Detector block) IRON 20 −40 to +150 Junction temperature Tj −40 to +125 Operation ambient temperature Topr −40 to +150 Storage temperature Tstg Caution The absolute maximum ratings are rated values exceeding which the product could physical damage. These values must therefore not be exceeded under any conditions. Output voltage RO pin voltage V V V mA mA °C °C °C suffer  Thermal Resistance Value Table 7 Item Symbol Condition SOT-89-5 Junction-to-ambient thermal resistance*1 θJA HTMSOP-8 SOT-23-5 Typ. Max. Unit Board A − 119 − °C/W Board B − 84 − °C/W Board C − − − °C/W Board D − 46 − °C/W Board E − °C/W − 35 159 − Board A − °C/W Board B − 113 − °C/W Board C − 39 − °C/W Board D − 40 − °C/W Board E − 30 − °C/W Board A − 192 − °C/W Board B − 160 − °C/W Board C − − − °C/W Board D − − − °C/W Board E *1. Test environment: compliance with JEDEC STANDARD JESD51-2A − − − °C/W Remark 6 Min. Refer to " Power Dissipation" and "Test Board" for details. AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION Rev.1.1_01 S-19315 Series  Electrical Characteristics 1. Regulator block Item Symbol Table 8 (VSENSE = 16.0 V, Tj = −40°C to +125°C unless otherwise specified) Test Condition Min. Typ. Max. Unit Circuit VOUT(S) VOUT(S) 1.0 V ≤ VOUT(S) < 1.5 V VOUT(S) V 1 − 0.03 + 0.03 VIN = VOUT(S) + 2.0 V, IOUT = 1 mA VOUT(S) VOUT(S) 1.5 V ≤ VOUT(S) ≤ 5.3 V VOUT(S) V 1 × 0.98 × 1.02 1.0 V ≤ VOUT(S) < 2.0 V − − VIN = 4.0 V 40*4 mA 2 VIN = VOUT(S) + 2.0 V 2.0 V ≤ VOUT(S) ≤ 5.3 V − − 40*4 mA 2 1.0 V ≤ VOUT(S) < 1.5 V 2.00 2.19 2.38 V 1 1.5 V ≤ VOUT(S) < 2.0 V 1.50 1.73 1.95 V 1 2.0 V ≤ VOUT(S) < 2.5 V 1.00 1.19 1.39 V 1 IOUT = 30 mA 2.5 V ≤ VOUT(S) < 3.0 V 0.50 0.66 0.82 V 1 3.0 V ≤ VOUT(S) < 4.0 V − 0.35 0.60 V 1 4.0 V ≤ VOUT(S) ≤ 5.3 V − 0.24 0.45 V 1 Output voltage*1 VOUT(E) Output current*2 IOUT Dropout voltage*3 Vdrop Line regulation ΔVOUT1 + 2.0 V ≤ VIN ≤ 36.0 V, IOUT = 1 mA V ΔVIN • VOUT OUT(S) Load regulation ΔVOUT2 Input voltage VIN Short-circuit current Ishort VIN = 4.0 V, 1 μA ≤ IOUT ≤ 30 mA VIN = VOUT(S) + 2.0 V, 1 μA ≤ IOUT ≤ 30 mA − 0.01 0.2 %/V 1 1.0 V ≤ VOUT(S) < 2.0 V − 24 45 mV 1 2.0 V ≤ VOUT(S) ≤ 5.3 V − 24 45 mV 1 3.0 − − 24 36.0 − V mA − 2 − 24 − mA 2 − VIN = 4.0 V, VOUT = 0 V 1.0 V ≤ VOUT(S) < 2.0 V VIN = VOUT(S) + 2.0 V, 2.0 V ≤ VOUT(S) ≤ 5.3 V VOUT = 0 V Thermal shutdown TSD Junction temperature − − − 160 °C detection temperature Thermal shutdown TSR Junction temperature − − °C − 135 release temperature Discharge shunt resistance RLOW − − kΩ 0.65 6 VIN = 16.0 V, VSENSE = 0.0 V, VOUT = 0.1 V during power-off *1. VOUT(S): Set output voltage VOUT(E): Actual output voltage Output voltage when fixing IOUT (= 1 mA) and inputting VOUT(S) + 2.0 V *2. The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current. *3. Vdrop = VIN1 − (VOUT3 × 0.98) VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. VOUT3 is the output voltage when VIN = 4.0 V (1.0 V ≤ VOUT(S) < 2.0 V), or VIN = VOUT(S) + 2.0 V (2.0 V ≤ VOUT(S) ≤ 5.3 V), and IOUT = 30 mA *4. Due to limitation of the power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation when the output current is large. This specification is guaranteed by design. 7 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION S-19315 Series Rev.1.1_01 2. Detector block Item Detection voltage*1 Table 9 (VIN = 16.0 V, Tj = −40°C to +125°C unless otherwise specified) Test Condition Min. Typ. Max. Unit Circuit Symbol −VDET − VHYS = 0% Release voltage*2 +VDET 5.0% ≤ VHYS ≤ 30.0% Operation voltage VOPR Output current "L" IRON Leakage current ILEAKN V 3 −VDET(S) −VDET(S) −VDET(S) × 1.02 × 0.98 V 3 V 3 V − +VDET(S) +VDET(S) +VDET(S) × 1.02 × 0.98 − 3.0 36.0 3.00 − − mA 4 − − 2.0 μA 4 VIN = 3.0 V − 65 − μs 5 VIN = 3.0 V − 80 − μs 5 Nch open-drain output Detection response time*4 tRESET Release response time*5 tDELAY − VDS*3 = 0.5 V, VIN = 3.0 V, VSENSE = 0.0 V VRO = 36.0 V, VIN = 36.0 V, VSENSE = 16.0 V −VDET(S) −VDET(S) −VDET(S) × 1.02 × 0.98 RSENSE − − MΩ − 7 13 SENSE pin resistance *1. −VDET(S): Set detection voltage, −VDET: Actual detection voltage *2. +VDET(S): Set release voltage, +VDET: Actual release voltage *3. VDS: Drain-to-source voltage of the output transistor *4. The time period from when the pulse voltage of −VDET(S) + 1.0 V → −VDET(S) − 1.0 V is applied to the SENSE pin to when VRO reaches 50% of VIN. *5. The time period from when the pulse voltage of +VDET(S) − 1.0 V → +VDET(S) + 1.0 V is applied to the SENSE pin to when VRO reaches 50% of VIN. 3. Overall Table 10 (VIN = 16.0 V, Tj = −40°C to +125°C unless otherwise specified) Item Current consumption during operation*1 Current consumption during detector detection*1 *1. 8 Symbol Condition Min. Typ. Max. Unit Test Circuit ISS1 VSENSE = +VDET(S) + 1.0 V, IOUT = 0 mA − 2.0 4.3 μA 7 ISS2 VSENSE = −VDET(S) − 1.0 V, IOUT = 0 mA − 0.5 1.4 μA 7 The current flowing through the SENSE pin resistance is not included. AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION Rev.1.1_01 S-19315 Series  Test Circuits VIN VIN + VOUT SENSE V RO + Test Circuit 1 Figure 7 100 kΩ + Figure 9 VOUT SENSE Oscilloscope RO Set to GND Test Circuit 5 + Test Circuit 4 RO Figure 10 + VIN VOUT + A V VSS 100 kΩ VSS + + Test Circuit 3 SENSE VOUT RO V VIN Test Circuit 2 SENSE RO VSS P.G. + VIN VOUT SENSE Figure 8 V VSS VIN V A RO VSS Figure 6 + VOUT SENSE A Figure 11 A + V + VSS Test Circuit 6 A VIN + A VOUT SENSE RO VSS Figure 12 Test Circuit 7 9 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION S-19315 Series Rev.1.1_01  Standard Circuit Input VOUT VIN CIN*1 Output RextR SENSE VSS *3 RO Single GND *1. *2. *3. CL*2 GND CIN is a capacitor for stabilizing the input. CL is a capacitor for stabilizing the output. RextR is the external pull-up resistor for the reset output pin. Figure 13 Caution The above connection diagram and constants will not guarantee successful operation. Perform thorough evaluation including the temperature characteristics with an actual application to set the constants. 10 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION Rev.1.1_01 S-19315 Series  Condition of Application Input capacitor (CIN): Output capacitor (CL): A ceramic capacitor with capacitance of 1.0 μF or more is recommended. A ceramic capacitor with capacitance of 1.0 μF or more is recommended. Caution Generally, in a voltage regulator, an oscillation may occur depending on the selection of the external parts. Perform thorough evaluation including the temperature characteristics with an actual application using the above capacitors to confirm no oscillation occurs.  Selection of Input Capacitor (CIN) and Output Capacitor (CL) The S-19315 Series requires CL between the VOUT pin and the VSS pin for phase compensation. The operation is stabilized by a ceramic capacitor with capacitance of 1.0 μF or more. When using an OS capacitor, a tantalum capacitor or an aluminum electrolytic capacitor, the capacitance also must be 1.0 μF or more. However, an oscillation may occur depending on the equivalent series resistance (ESR). Moreover, the S-19315 Series requires CIN between the VIN pin and the VSS pin for a stable operation. Generally, an oscillaiton may occur when a voltage regulator is used under the conditon that the impedance of the power supply is high. Note that the output voltage (VOUT) transient characteristics varies depending on the capacitance of CIN and CL and the value of ESR. Caution Perform thorough evaluation including the temperature characteristics with an actual application to select CIN and CL. 11 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION S-19315 Series Rev.1.1_01  Explanation of Terms 1. Regulator block 1. 1 Low dropout voltage regulator This is a voltage regulator which made dropout voltage small by its built-in low on-resistance output transistor. 1. 2 Output voltage (VOUT) This voltage is output at an accuracy of ±2.0% or ±0.03 V*2 when the input voltage, the output current and the temperature are in a certain condition*1. *1. Differs depending on the product. *2. When VOUT < 1.5 V: ±0.03 V, when VOUT ≥ 1.5 V: ±2.0% Caution If the certain condition is not satisfied, the output voltage may exceed the accuracy range of ±2.0% or ±0.03 V. Refer to "1. Regulator block" in " Electrical Characteristics" and "1. Regulator block" in " Characteristics (Typical Data)" for details. 1. 3 Line regulation  ΔVOUT1  ΔVIN • VOUT  Indicates the dependency of the output voltage against the input voltage. That is, the value shows how much the output voltage changes due to a change in the input voltage after fixing output current constant. 1. 4 Load regulation (ΔVOUT2) Indicates the dependency of the output voltage against the output current. That is, the value shows how much the output voltage changes due to a change in the output current after fixing input voltage constant. 1. 5 Dropout voltage (Vdrop) Indicates the difference between input voltage (VIN1) and the output voltage when the output voltage becomes 98% of the output voltage value (VOUT3) at VIN = 4.0 V (1.0 V ≤ VOUT(S) < 2.0 V) or VIN = VOUT(S) + 2.0 V (2.0 V ≤ VOUT(S) ≤ 5.3 V) after the input voltage (VIN) is decreased gradually. Vdrop = VIN1 − (VOUT3 × 0.98) 12 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION Rev.1.1_01 S-19315 Series 2. Detector block 2. 1 Detection voltage (−VDET) The detection voltage is a voltage at which the output of the RO pin turns to "L". The detection voltage varies slightly among products of the same specification. The variation of detection voltage between the specified minimum (−VDET min.) and the maximum (−VDET max.) is called the detection voltage range (Refer to Figure 14). 2. 2 Release voltage (+VDET) The release voltage is a voltage at which the output of the RO pin turns to "H". The release voltage varies slightly among products of the same specification. The variation of release voltage between the specified minimum (+VDET min.) and the maximum (+VDET max.) is called the release voltage range (Refer to Figure 15). VSENSE VSENSE Detection voltage −VDET max. Detection voltage range −VDET min. Release voltage +VDET max. Release voltage range +VDET min. VIN VIN RO pin output RO pin output Figure 14 2. 3 Detection Voltage Figure 15 Release Voltage Hysteresis width (VHYS) The hysteresis width is the voltage difference between the detection voltage and the release voltage. Setting the hysteresis width between the detection voltage and the release voltage prevents malfunction caused by noise on the SENSE pin voltage (VSENSE). 13 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION S-19315 Series Rev.1.1_01  Operation 1. Regulator block 1. 1 Basic operation Figure 16 shows the block diagram of the regulator block to describe the basic operation. The error amplifier compares the feedback voltage (Vfb) whose output voltage (VOUT) is divided by the feedback resistors (Rs and Rf) with the reference voltage (Vref). The error amplifier controls the output transistor, consequently, the regulator starts the operation that keeps VOUT constant without the influence of the input voltage (VIN). VIN *1 Current supply Error amplifier Vref VOUT − Rf + Vfb Reference voltage circuit Rs VSS *1. Parasitic diode Figure 16 1. 2 Output transistor In the S-19315 Series, a low on-resistance P-channel MOS FET is used between the VIN pin and the VOUT pin as the output transistor. In order to keep VOUT constant, the on-resistance of the output transistor varies appropriately according to the output current (IOUT). Caution Since a parasitic diode exists between the VIN pin and the VOUT pin due to the structure of the transistor, the IC may be damaged by a reverse current if VOUT becomes higher than VIN. Therefore, be sure that VOUT does not exceed VIN + 0.3 V. 14 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION Rev.1.1_01 S-19315 Series 1. 3 ON / OFF circuit The ON / OFF circuit controls the internal circuit and the output transistor in order to start and stop the regulator. When the detector becomes the detection status, the internal circuit of regulator stops operating and the output transistor between the VIN pin and the VOUT pin is turned off, reducing current consumption significantly. Table 11 Detector ON / OFF Circuit Regulator Internal Circuit VOUT Pin Voltage Current Consumption Released ON Operate Constant value*1 ISS1 Detected OFF Stop Pulled down to VSS*2 ISS2 *1. The constant value is output due to the regulating based on the set output voltage value. *2. The VOUT pin voltage is pulled down to VSS due to combined resistance (RLOW = 650 Ω typ.) of the discharge shunt circuit and the feedback resistors, and a load. 1. 4 Discharge shunt function The S-19315 Series has a built-in discharge shunt circuit to discharge the output capacitance. The output capacitance is discharged as follows so that the VOUT pin reaches the VSS level. (1) The ON / OFF circuit is turned OFF. (2) The output transistor is turned off. (3) The discharge shunt circuit is turned on. (4) The output capacitor discharges. S-19315 Series Output transistor: OFF *1 VOUT VIN Discharge shunt circuit: ON OFF *1 ON / OFF circuit Output capacitor (CL) Current flow GND VSS *1. Parasitic diode Figure 17 15 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION S-19315 Series Rev.1.1_01 1. 5 Overcurrent protection circuit The S-19315 Series has a built-in overcurrent protection circuit to limit the overcurrent of the output transistor. When the VOUT pin is shorted to the VSS pin, that is, at the time of the output short-circuit, the output current is limited to 24 mA typ. due to the overcurrent protection circuit operation. The S-19315 Series restarts regulating when the output transistor is released from the overcurrent status. Caution This overcurrent protection circuit does not work as for thermal protection. For example, when the output transistor keeps the overcurrent status long at the time of output short-circuit or due to other reasons, pay attention to the conditions of the input voltage and the load current so as not to exceed the power dissipation. 1. 6 Thermal shutdown circuit The S-19315 Series has a built-in thermal shutdown circuit to limit overheating. When the junction temperature increases to 160°C typ., the thermal shutdown circuit becomes the detection status, and the regulating is stopped. When the junction temperature decreases to 135°C typ., the thermal shutdown circuit becomes the release status, and the regulator is restarted. If the thermal shutdown circuit becomes the detection status due to self-heating, the regulating is stopped and VOUT decreases. For this reason, the self-heating is limited and the temperature of the IC decreases. The thermal shutdown circuit becomes release status when the temperature of the IC decreases, and the regulating is restarted thus the self-heating is generated again. Repeating this procedure makes the waveform of VOUT into a pulse-like form. This phenomenon continues unless decreasing either or both of the input voltage and the output current in order to reduce the internal power consumption, or decreasing the ambient temperature. Note that the product may suffer physical damage such as deterioration if the above phenomenon occurs continuously. Caution If a large load current flows during the restart process of regulating after the thermal shutdown circuit changes to the release status from the detection status, the thermal shutdown circuit becomes the detection status again due to self-heating, and a problem may happen in the restart of regulating. A large load current, for example, occurs when charging to the CL whose capacitance is large. Perform thorough evaluation including the temperature characteristics with an actual application to select CL. Table 12 Thermal Shutdown Circuit Release: 135°C typ.*1 Detection: 160°C typ.*1 *1. *2. *3. 16 VOUT Pin Voltage Constant value*2 Pulled down to VSS*3 Junction temperature The constant value is output due to the regulating based on the set output voltage value. The VOUT pin voltage is pulled down to VSS due to the feedback resistors (Rs and Rf) and a load. AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION Rev.1.1_01 S-19315 Series 2. Detector block 2. 1 Basic operation (1) When the input voltage (VIN) is the minimum operation voltage or higher, and the SENSE pin voltage (VSENSE) is the release voltage (+VDET) or higher, the Nch transistor (N1) is off, and the RO pin output is "H". (RB + RC ) • VSENSE Since the Nch transistor (N2) is off, the input voltage to the comparator is . RA + RB + RC (2) Even if VSENSE decreases to +VDET or lower, the RO pin output is "H" when VSENSE is the detection voltage (−VDET) or higher. When VSENSE is −VDET (point A in Figure 19) or lower, N1 is on, and the RO pin output is "L". RB • VSENSE . At this time, N2 is turned on, and the input voltage to the comparator is RA + RB (3) Even if VSENSE further decreases to the IC's minimum operation voltage or lower, the RO pin output is stable when VIN is the minimum operation voltage or higher. (4) Even if VSENSE exceeds −VDET, the RO pin output is "L" when VSENSE is lower than +VDET. (5) When VSENSE further increases to +VDET (point B in Figure 19) or higher, the RO pin output is "H". SENSE VIN RA VSENSE VIN VOUT Regulator block RextR + *1 RO − Reference voltage circuit CIN RC VSS *1. N1 RB *1 CL V + N2 Parasitic diode (1) Hysteresis width (VHYS) (2) Figure 18 Operation (3) (5) VSENSE (4) B A Release voltage (+VDET) Detection voltage (−VDET) Minimum operation voltage VSS VIN RO pin output VSS Figure 19 Timing Chart 17 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION S-19315 Series Rev.1.1_01 2. 2 SENSE pin 2. 2. 1 Error when detection voltage is set externally By connecting a node that was resistance-divided by the resistor (RA) and the resistor (RB) to the SENSE pin as seen in Figure 20, the detection voltage can be set externally. Although the internal resistance (RSENSE) in the S-19315 Series is large (13 MΩ min.) to make the error in the current flowing through RSENSE small, RA and RB should be selected such that the error is within the allowable limits. If the VSENSE greatly exceeds the +VDET, the current flowing through RSENSE is limited. 2. 2. 2 Selection of RA and RB In Figure 20, the relation between the external setting detection voltage (VDX) and the actual detection voltage (−VDET) is ideally calculated by the equation below. VDX = −VDET × (1 + RA RB ) ··· (1) However, in reality there is an error in the current flowing through RSENSE. When considering this error, the relation between VDX and −VDET is calculated as follows. RA RB || RSENSE ) RA  = −VDET × 1 +  RB × RSENSE   RB + RSENSE  RA RA = −VDET × (1 + R ) + R × −VDET B SENSE VDX = −VDET × (1 + ··· (2) RA By using equations (1) and (2), the error is calculated as −VDET × R . SENSE The error rate is calculated as follows by dividing the error by the right-hand side of equation (1). RA × RB RA || RB × 100 [%] = R × 100 [%] SENSE RSENSE × (RA + RB) ··· (3) As seen in equation (3), the smaller the resistance values of RA and RB compared to RSENSE, the smaller the error rate becomes. Also, the relation between the external setting hysteresis width (VHX) and the hysteresis width (VHYS) is calculated by equation below. Error due to RSENSE also occurs to the relation in a similar way to the detection voltage. RA ··· (4) VHX = VHYS × (1 + R ) B A RA VDX −VDET RB Figure 20 VIN SENSE RO RSENSE VSS Detection Voltage External Setting Circuit Caution 1. If RA and RB are large, the SENSE pin input impedance becomes higher and may cause a malfunction due to noise. In this case, connect a capacitor between the SENSE pin and the VSS pin. 2. If the parasitic resistance and parasitic inductance between VDX and point A and between point A and VIN pin are respectively larger, oscillation may occur. Perform thorough evaluation using the actual application. 18 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION Rev.1.1_01 S-19315 Series 2. 3 Power on sequence Apply power in the order, the VIN pin then the SENSE pin. As seen in Figure 21, when VSENSE ≥ +VDET, the RO pin output becomes "H", and the detector becomes the release status (normal operation). VIN +VDET VSENSE tDELAY VRO Figure 21 Caution 2. 4 If power is applied in the order the SENSE pin then the VIN pin, an erroneous release may occur even if VSENSE < +VDET. SENSE pin voltage glitch (reference) 2. 4. 1 Detection operation Pulse width [μs] Figure 22 shows the relation between pulse width and pulse voltage difference (VOD) where the release status can be maintained when a pulse equal to or lower than the detection voltage (−VDET) is input to the SENSE pin during the release status. Tj = −40°C to +150°C 200 150 100 50 0 10 100 VOD [mV] 1000 Figure 22 Pulse width VIH*1 VSENSE −VDET VOD VIL*2 *1. *2. VIH = 16.0 V VIL = −VDET − VOD Figure 23 Caution SENSE Pin Input Voltage Waveform Figure 22 shows the pulse conditions which can maintain the release status. If the pulse whose pulse width and VOD are larger than these conditions is input to the SENSE pin, the RO pin may change to a detection status. 19 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION S-19315 Series Rev.1.1_01 2. 4. 2 Release operation Pulse width [μs] Figure 24 shows the relation between pulse width and pulse voltage difference (VOD) where the detection status can be maintained when a pulse equal to or higher than the release voltage (+VDET) is input to the SENSE pin during detection status. Tj = −40°C to +150°C 200 150 100 50 0 10 100 VOD [mV] 1000 Figure 24 VIH*1 VOD VSENSE +VDET VIL*2 Pulse width *1. VIH = +VDET + VOD *2. VIL = +VDET − 1.0 V Figure 25 Caution SENSE Pin Input Voltage Waveform Figure 24 shows the pulse conditions which can maintain the detection status. If the pulse whose a pulse width and VOD are larger than these conditions is input to the SENSE pin, the RO pin may change to a release status. 20 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION Rev.1.1_01 S-19315 Series  Precautions • Generally, when a voltage regulator is used under the condition that the impedance of the power supply is high, an oscillation may occur. Perform thorough evaluation including the temperature characteristics with an actual application to select CIN. • Generally, in a voltage regulator, an oscillation may occur depending on the selection of the external parts. The following use conditions are recommended in the S-19315 Series; however, perform thorough evaluation including the temperature characteristics with an actual application to select CIN and CL. Input capacitor (CIN): Output capacitor (CL): A ceramic capacitor with capacitance of 1.0 μF or more is recommended. A ceramic capacitor with capacitance of 1.0 μF or more is recommended. • Generally, in a voltage regulator, the values of an overshoot and an undershoot in the output voltage vary depending on the variation factors of input voltage start-up, input voltage fluctuation, load fluctuation etc., or the capacitance of CIN or CL and the value of the equivalent series resistance (ESR), which may cause a problem to the stable operation. Perform thorough evaluation including the temperature characteristics with an actual application to select CIN and CL. • Generally, in a voltage regulator, an overshoot may occur in the output voltage momentarily if the input voltage steeply changes when the input voltage is started up, the input voltage fluctuates, etc. Perform thorough evaluation including the temperature characteristics with an actual application to confirm no problems happen. • Generally, in a voltage regulator, if the VOUT pin is steeply shorted with GND, a negative voltage exceeding the absolute maximum ratings may occur in the VOUT pin due to resonance phenomenon of the inductance and the capacitance including CL on the application. The resonance phenomenon is expected to be weakened by inserting a series resistor into the resonance path, and the negative voltage is expected to be limited by inserting a protection diode between the VOUT pin and the VSS pin. • If the input voltage is started up steeply under the condition that the capacitance of CL is large, the thermal shutdown circuit may be in the detection status by self-heating due to the charge current to CL. • Make sure of the conditions for the input voltage, output voltage and the load current so that the internal loss does not exceed the power dissipation. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • When considering the output current value that the IC is able to output, make sure of the output current value specified in Table 8 in " Electrical Characteristics" and footnote *4 of the table. • Wiring patterns on the application related to the VIN pin, the VOUT pin and the VSS pin should be designed so that the impedance is low. When mounting CIN between the VIN pin and the VSS pin and CL between the VOUT pin and the VSS pin, connect the capacitors as close as possible to the respective destination pins of the IC. • Because the SENSE pin has a high impedance, malfunctions may occur due to noise. Be careful of wiring adjoining SENSE pin wiring in actual applications. • In the package equipped with heat sink of backside, mount the heat sink firmly. Since the heat radiation differs according to the condition of the application, perform thorough evaluation with an actual application to confirm no problems happen. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 21 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION S-19315 Series Rev.1.1_01  Characteristics (Typical Data) Regulator block 1. 1 Output voltage vs. Output current (When load current increases) (Ta = +25°C) VOUT [V] 1. 1. 1 1. 1. 2 VOUT = 1.8 V VOUT = 3.3 V 2.5 4.0 2.0 3.0 VOUT [V] 1. 1.5 VIN = 3.0 V VIN = 4.0 V 1.0 1.0 0.5 0.0 0.0 0 1. 1. 3 VIN = 3.8 V VIN = 4.3 V VIN = 5.3 V 2.0 40 80 120 160 IOUT [mA] 200 0 240 40 80 120 160 IOUT [mA] 200 240 VOUT = 5.0 V 6.0 VOUT [V] 5.0 4.0 Remark VIN = 5.5 V VIN = 6.0 V VIN = 7.0 V 3.0 2.0 1.0 1. The minimum output current value and footnote *4 of Table 8 in " Electrical Characteristics" 2. Power dissipation 0.0 0 120 160 IOUT [mA] 200 240 Output voltage vs. Input voltage (Ta = +25°C) 1. 2. 1 VOUT [V] 80 1. 2. 2 VOUT = 1.8 V 4.0 2.4 3.6 2.0 IOUT = 0.1 mA IOUT = 10 mA IOUT = 30 mA 1.6 1.2 6 12 18 24 VIN [V] 30 36 30 36 VOUT = 5.0 V 6.0 5.6 VOUT [V] IOUT = 0.1 mA IOUT = 10 mA IOUT = 30 mA 2.8 2.0 0 1. 2. 3 3.2 2.4 0.8 5.2 IOUT = 0.1 mA IOUT = 10 mA IOUT = 30 mA 4.8 4.4 4.0 0 22 VOUT = 3.3 V 2.8 VOUT [V] 1. 2 40 In determining the output current, attention should be paid to the following. 6 12 18 24 VIN [V] 0 6 12 18 24 VIN [V] 30 36 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION Rev.1.1_01 S-19315 Series 1. 3 Dropout voltage vs. Output current 1. 3. 1 1. 3. 2 VOUT = 3.3 V 0.6 0.5 Tj = +150°C Tj = +125°C 0.3 Vdrop [V] Vdrop [V] 0.4 Tj = +25°C Tj = −40°C 0.2 0.1 0.0 1. 4 10 20 IOUT [mA] 30 40 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0.00 Tj = +150°C Tj = +125°C Tj = +25°C Tj = −40°C 0 10 20 IOUT [mA] 30 40 Dropout voltage vs. Junction temperature 1. 4. 1 1. 4. 2 VOUT = 3.3 V VOUT = 5.0 V 0.30 0.30 0.25 0.25 IOUT = 30 mA 0.20 0.15 IOUT = 10 mA 0.10 0.05 0.00 −40 −25 Vdrop [V] Vdrop [V] 0 VOUT = 5.0 V IOUT = 30 mA 0.20 0.15 IOUT = 10 mA 0.10 0.05 0 25 50 75 100 125 150 Tj [°C] 0.00 −40 −25 0 25 50 75 100 125 150 Tj [°C] 23 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION S-19315 Series Rev.1.1_01 1. 5 Output voltage vs. Junction temperature 1. 5. 2 VOUT = 1.8 V VOUT = 3.3 V 1.90 3.60 1.86 3.48 VOUT [V] VOUT [V] 1. 5. 1 1.82 1.78 1.74 3.24 3.12 1.70 −40 −25 1. 5. 3 3.36 0 25 3.00 −40 −25 50 75 100 125 150 Tj [°C] 0 25 50 75 100 125 150 Tj [°C] VOUT = 5.0 V 5.60 VOUT [V] 5.36 5.12 4.88 4.64 4.40 −40 −25 Ripple Rejection [dB] 1. 6. 2 VOUT = 1.8 V VIN = 4.0 V, CL = 1.0 μF 100 IOUT = 40 mA 80 IOUT = 1 mA 60 40 20 IOUT = 10 mA 0 10 1. 6. 3 Ripple Rejection [dB] 50 75 100 125 150 Tj [°C] Ripple rejection (Ta = +25°C) 1. 6. 1 1k 10k 100k Frequency [Hz] VOUT = 5.0 V 100 1M VIN = 7.0 V, CL = 1.0 μF 100 IOUT = 40 mA 80 60 40 IOUT = 10 mA IOUT = 1 mA 20 0 10 24 25 Ripple Rejection [dB] 1. 6 0 100 1k 10k 100k Frequency [Hz] 1M VOUT = 3.3 V VIN = 5.3 V, CL = 1.0 μF 100 80 IOUT = 1 mA 60 40 IOUT = 10 mA IOUT = 40 mA 20 0 10 100 1k 10k 100k Frequency [Hz] 1M AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION Rev.1.1_01 S-19315 Series Detector block 2. 1 Detection voltage, Release voltage vs. Junction temperature −VDET, +VDET [V] 2. 1. 1 −VDET = 3.0 V, +VDET = 3.2 V VIN = 16.0 V 3.4 3.3 3.2 3.1 3.0 2.9 2.8 2.7 −40 −25 2. 1. 3 −VDET 25 −VDET = 4.4 V, +VDET = 4.7 V VIN = 16.0 V 5.0 +VDET 0 2. 1. 2 −VDET, +VDET [V] 2. +VDET 4.8 4.6 4.4 4.2 −VDET 4.0 −40 −25 50 75 100 125 150 Tj [°C] 0 25 50 75 100 125 150 Tj [°C] −VDET = 11.3 V, +VDET = 14.6 V VIN = 16.0 V 15.0 14.0 +VDET 13.0 11.0 10.0 −40 −25 2. 2 −VDET, +VDET [V] 0 25 50 75 100 125 150 Tj [°C] Detection voltage, Release voltage vs. Input voltage 2. 2. 1 3.5 3.4 3.3 3.2 3.1 3.0 2.9 2.8 2.7 2.6 2. 2. 3 −VDET = 3.0 V, +VDET = 3.2 V +VDET −VDET 0 Tj = +25°C Tj = −40°C Tj = +125°C 6 Tj = +25°C Tj = −40°C Tj = +150°C Tj = +125°C 12 18 24 VIN [V] 30 36 −VDET = 4.4 V, +VDET = 4.7 V 5.0 4.8 +VDET 4.6 Tj = +25°C Tj = +150°C 4.4 −VDET 4.2 4.0 Tj = +25°C Tj = −40°C Tj = +125°C 0 6 Tj = −40°C Tj = +150°C Tj = +125°C 12 18 24 VIN [V] 30 36 −VDET = 11.3 V, +VDET = 14.6 V +VDET Tj = +25°C 15.0 14.0 13.0 Tj = +25°C 12.0 11.0 10.0 2. 2. 2 Tj = +150°C 16.0 −VDET, +VDET [V] −VDET 12.0 −VDET, +VDET [V] −VDET, +VDET [V] 16.0 −VDET 0 6 Tj = −40°C Tj = +125°C Tj = +150°C Tj = −40°C Tj = +150°C Tj = +125°C 12 18 24 VIN [V] 30 36 25 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION S-19315 Series Rev.1.1_01 Nch transistor output current vs. VDS IRO [mA] 2. 3. 1 IRO [mA] 2. 3. 2 VSENSE = 0.0 V, −VDET = 4.4 V, +VDET = 4.7 V 16.0 14.0 VIN = 36.0 V 12.0 10.0 VIN = 16.0 V 8.0 6.0 4.0 VIN = 3.0 V 2.0 0.0 0.2 0.4 0.6 0.8 0.0 1.0 VDS [V] 2. 3. 3 2. 4 Ta = −40°C Ta = +125°C VSENSE = 0.0 V, −VDET = 4.4 V, +VDET = 4.7 V 16.0 14.0 12.0 VIN = 36.0 V 10.0 8.0 VIN = 16.0 V 6.0 4.0 VIN = 3.0 V 2.0 0.0 0.0 1.0 0.2 0.4 0.6 0.8 VDS [V] Nch transistor output current vs. Input voltage 2. 4. 1 −VDET = 11.3 V, +VDET = 14.6 V VSENSE = 0.0 V, VDS = 0.5 V 10.0 Ta = −40°C IRO [mA] 8.0 6.0 4.0 Ta = +25°C 2.0 Ta = +125°C 0.0 0.0 6.0 12.0 18.0 24.0 VIN [V] 30.0 36.0 Remark VDS: Drain-to-source voltage of the output transistor 26 IRO [mA] 2. 3 Ta = +25°C VSENSE = 0.0 V, −VDET = 4.4 V, +VDET = 4.7 V 16.0 14.0 VIN = 36.0 V 12.0 10.0 VIN = 16.0 V 8.0 6.0 4.0 VIN = 3.0 V 2.0 0.0 0.0 1.0 0.2 0.4 0.6 0.8 VDS [V] AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION Rev.1.1_01 S-19315 Series 2. 5 Minimum operation voltage vs. SENSE pin voltage 2. 5. 1 5.0 Pull-up to VIN −VDET = 4.4 V, +VDET = 4.7 V, Pull-up resistance: 100 kΩ, VIN = 3.0 V 2. 5. 2 20.0 3.0 2.0 1.0 Response time [ms] + °C + °C + °C 2.0 3.0 VSENSE [V] 15.0 − °C 10.0 + °C 5.0 0.0 4.0 5.0 0.0 1.0 + °C + °C 2.0 3.0 VSENSE [V] 4.0 5.0 Dynamic response vs. RO pin capacitance 2. 6. 1 10 Ta = −40°C −VDET = 4.4 V, +VDET = 4.7 V 1 0.1 0.01 0.001 0.00001 2. 6. 3 Response time [ms] 1.0 °C 10 2. 6. 2 Response time [ms] 2. 6 0.0 − VRO [V] VRO [V] 4.0 0.0 Pull-up to 16.0 V −VDET = 4.4 V, +VDET = 4.7 V, Pull-up resistance: 100 kΩ, VIN = 3.0 V 0.0001 0.001 0.01 RO pin capacitance [μF] 0.1 10 Ta = +25°C −VDET = 4.4 V, +VDET = 4.7 V 1 0.1 0.01 0.001 0.00001 0.0001 0.001 0.01 RO pin capacitance [μF] 0.1 Ta = +125°C −VDET = 4.4 V, +VDET = 4.7 V 1 0.1 0.01 0.001 0.00001 0.0001 0.001 0.01 RO pin capacitance [μF] 0.1 VIN P.G. VOUT SENSE RO R 100 kΩ VPU Oscilloscope + VSS *1. *2. VIH = 36.0 V VIL = 0.0 V Figure 26 Test Condition of Response Time Caution Figure 27 Test Circuit of Response Time The above connection diagram and constants will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constants. 27 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION S-19315 Series Rev.1.1_01 3. Overall 3. 1 Current consumption during operation vs. Input voltage (When ON / OFF circuit is ON, no load) 3. 1. 1 VOUT = 1.8 V −VDET = 3.0 V, +VDET = 3.2 V 200 120 Tj = −40°C 80 Tj = +150°C 40 3. 1. 2 Tj = +125°C 6 12 30 0 6 12 18 24 VIN [V] 30 36 VOUT = 3.3 V −VDET = 3.0 V, +VDET = 3.2 V 160 Tj = +150°C Tj = +125°C 120 Tj = +25°C Tj = −40°C 80 0 −VDET = 3.0 V, +VDET = 3.2 V 10.0 Tj = +150°C 8.0 Tj = +125°C Tj = +25°C Tj = −40°C 6.0 4.0 2.0 0 6 12 18 24 VIN [V] 30 0.0 36 0 6 12 18 24 VIN [V] 30 36 VOUT = 5.0 V −VDET = 4.4 V, +VDET = 4.7 V 200 160 Tj = +150°C Tj = +125°C 120 Tj = +25°C Tj = −40°C 80 Tj = +150°C 8.0 40 0 −VDET = 4.4 V, +VDET = 4.7 V 10.0 ISS1 [μA] 3. 1. 3 ISS1 [μA] Tj = −40°C Tj = +25°C 4.0 36 40 28 Tj = +125°C 2.0 Tj = +25°C 18 24 VIN [V] Tj = +150°C 6.0 0.0 0 200 ISS1 [μA] ISS1 [μA] 8.0 ISS1 [μA] ISS1 [μA] 160 0 −VDET = 3.0 V, +VDET = 3.2 V 10.0 Tj = +125°C Tj = +25°C Tj = −40°C 6.0 4.0 2.0 0 6 12 18 24 VIN [V] 30 36 0.0 0 6 12 18 24 VIN [V] 30 36 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION Rev.1.1_01 S-19315 Series 3. 2 Current consumption during operation vs. Junction temperature 3. 2. 1 10.0 VOUT = 1.8 V 3. 2. 2 −VDET = 3.0 V, +VDET = 3.2 V, VIN = 16.0 V 10.0 6.0 4.0 6.0 4.0 2.0 2.0 0.0 −40 −25 3. 2. 3 10.0 −VDET = 3.0 V, +VDET = 3.2 V, VIN = 16.0 V 8.0 ISS1 [μA] ISS1 [μA] 8.0 VOUT = 3.3 V 0 25 0.0 −40 −25 50 75 100 125 150 Tj [°C] 0 25 50 75 100 125 150 Tj [°C] VOUT = 5.0 V −VDET = 4.4 V, +VDET = 4.7 V, VIN = 16.0 V ISS1 [μA] 8.0 6.0 4.0 2.0 0.0 −40 −25 50 75 100 125 150 Tj [°C] Current consumption during operation vs. Output current (Ta = +25°C) 3. 3. 1 120 ISS1 [μA] 25 VOUT = 1.8 V 3. 3. 2 120 100 100 80 80 ISS1 [μA] 3. 3 0 60 40 20 VOUT = 3.3 V 60 40 20 0 0 0 3. 3. 3 5 10 15 20 25 IOUT [mA] 30 35 40 15 20 25 IOUT [mA] 30 35 40 0 5 10 15 20 25 IOUT [mA] 30 35 40 VOUT = 5.0 V 120 ISS1 [μA] 100 80 60 40 20 0 0 5 10 29 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION S-19315 Series Rev.1.1_01  Reference Data 1. Transient response characteristics when input (Ta = +25°C) VOUT = 1.8 V 1. 2 IOUT = 20 mA, CL = 1.0 μF, VIN = 4.0 V ↔ 6.0 V, tr = tf = 5.0 μs 2.4 10 2.0 1.8 6 VIN 2 −2 VOUT −6 1.6 1.4 −200 1. 3 8 3.5 VIN 4 3.3 VOUT 0 −4 3.1 −10 200 400 600 800 1000 1200 t [μs] 0 IOUT = 20 mA, CL = 1.0 μF, VIN = 5.3 V ↔ 7.3 V, tr = tf = 5.0 μs 3.9 12 3.7 VIN [V] VOUT [V] VOUT [V] 2.2 VOUT = 3.3 V VIN [V] 1. 1 2.9 −200 −8 200 400 600 800 1000 1200 t [μs] 0 VOUT = 5.0 V IOUT = 20 mA, CL = 1.0 μF, VIN = 7.0 V ↔ 9.0 V, tr = tf = 5.0 μs 5.6 14 10 5.2 VIN 6 5.0 VOUT 2 VIN [V] VOUT [V] 5.4 −2 4.8 4.6 −200 −6 200 400 600 800 1000 1200 t [μs] 0 2. Transient response characteristics of load (Ta = +25°C) VOUT [V] 2.2 2. 2 VIN = 4.0 V, CIN = CL = 1.0 μF, IOUT = 0.1 mA ↔ 20 mA 40 0 IOUT −40 2.0 1.8 −80 VOUT 3.7 −120 1.6 1.4 −800 2. 3 3.9 0 800 1600 t [μs] 2400 −160 3200 −40 5.0 −80 VOUT −120 4.8 4.6 −800 30 0 800 1600 t [μs] 2400 −160 3200 IOUT [mA] VOUT [V] 0 5.2 0 IOUT −40 3.5 3.3 −80 VOUT 2.9 −800 VOUT = 5.0 V IOUT VIN = 5.3 V, CIN = CL = 1.0 μF, IOUT = 0.1 mA ↔ 20 mA 40 −120 3.1 VIN = 7.0 V, CIN = CL = 1.0 μF, IOUT = 0.1 mA ↔ 20 mA 5.6 40 5.4 VOUT = 3.3 V 0 800 1600 t [μs] 2400 −160 3200 IOUT [mA] 2.4 VOUT = 1.8 V IOUT [mA] VOUT [V] 2. 1 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION Rev.1.1_01 S-19315 Series Transient response characteristics of SENSE pin (Ta = +25°C) 3. 1 VOUT = 1.8 V 3. 2 4 12 3 6 2 1 0 −6 −12 VOUT −1 −400 3. 3 0 VSENSE VSENSE [V] VOUT [V] VOUT [V] VIN = 4.0 V, CIN = CL = 1.0 μF, IOUT = 20 mA, VSENSE = 0 V ↔ 16 V 5 18 0 400 800 1200 1600 2000 t [μs] VIN = 5.3 V, CIN = CL = 1.0 μF, IOUT = 20 mA, VSENSE = 0 V ↔ 16 V 10 18 8 12 6 6 4 2 0 −18 VOUT = 3.3 V 0 VSENSE −6 −12 VOUT −2 −400 VSENSE [V] 3. 0 400 800 1200 1600 2000 t [μs] −18 VOUT = 5.0 V 12 12 9 6 6 3 0 VSENSE −6 −12 0 VOUT −3 −400 0 4. VSENSE [V] VOUT [V] VIN = 7.0 V, CIN = CL = 1.0 μF, IOUT = 20 mA, VSENSE = 0 V ↔ 16 V 15 18 400 800 1200 1600 2000 t [μs] −18 Load dump characteristics (Ta = +25°C) 4. 1 VOUT = 5.0 V 5.8 40 5.6 30 5.4 20 VIN 5.2 5.0 4.8 10 0 VOUT −0.1 0 VIN [V] VOUT [V] IOUT = 0.1 mA, VIN = 13.5 V ↔ 45.0 V, CIN = CL = 1.0 μF 6.0 50 0.1 0.2 0.3 0.4 t [s] 0.5 0.6 0.7 −10 31 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION S-19315 Series Rev.1.1_01 5. Output capacitance vs. Discharge time characteristics (Ta = +25°C) VIN = 4.0 V / VIN = VOUT + 2.0 V, IOUT = 1 μA, VSENSE = 16 V → VSS, tf = 1.0 μs 1 μs VSENSE 200 VOUT(S) = 1.8 V VOUT(S) = 3.3 V VOUT(S) = 5.0 V tDSC [ms] 160 120 VSS tDSC 80 VOUT 40 0 0 20 40 60 80 CL [μF] 100 120 VOUT × 10% VIN = 4.0 V / VIN = VOUT + 2.0 V, VSENSE = 16 V → VSS Figure 28 6. Test conditions of discharge time Example of equivalent series resistance vs. Output current characteristics (Ta = +25°C) CIN = CL = 1.0 μF 100 VIN RESR [Ω] VOUT CIN Stable S-19315 Series VSS 0.001 CL*1 RO SENSE 0 RextR 40 RESR IOUT [mA] *1. Figure 29 32 CL: TDK Corporation CGA4J3X8R1C105K (1.0 μF) Figure 30 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 40 mA VOLTAGE REGULATOR WITH SENSE-INPUT RESET FUNCTION Rev.1.1_01 S-19315 Series  Power Dissipation SOT-89-5 HTMSOP-8 Tj = +150°C max. 5 Tj = +150°C max. 5 Power dissipation (PD) [W] Power dissipation (PD) [W] E 4 E 3 D 2 B 1 0 A 4 C 3 D 2 B 1 A 0 25 50 75 100 125 150 175 0 0 25 Ambient temperature (Ta) [°C] Board 50 75 100 125 150 175 Ambient temperature (Ta) [°C] Power Dissipation (PD) Board A 1.05 W A Power Dissipation (PD) 0.79 W B 1.49 W B 1.11 W C − 2.72 W C 3.21 W D D 3.13 W E 3.57 W E 4.17 W SOT-23-5 Tj = +150°C max. Power dissipation (PD) [W] 5 4 3 2 1 B A 0 0 25 50 75 100 125 150 175 Ambient temperature (Ta) [°C] Board A Power Dissipation (PD) 0.65 W B 0.78 W C − D − E − 33 SOT-89-5 Test Board IC Mount Area (1) Board A Item Specification Size [mm] 114.3 x 76.2 x t1.6 Material FR-4 Number of copper foil layer Copper foil layer [mm] 2 1 Land pattern and wiring for testing: t0.070 2 - 3 4 74.2 x 74.2 x t0.070 Thermal via - (2) Board B Item Specification Size [mm] 114.3 x 76.2 x t1.6 Material FR-4 Number of copper foil layer 4 Copper foil layer [mm] 1 Land pattern and wiring for testing: t0.070 2 74.2 x 74.2 x t0.035 3 74.2 x 74.2 x t0.035 4 74.2 x 74.2 x t0.070 Thermal via - (3) Board D Item Specification Size [mm] 114.3 x 76.2 x t1.6 Material FR-4 Number of copper foil layer Copper foil layer [mm] 4 2 Pattern for heat radiation: 2000mm2 t0.070 74.2 x 74.2 x t0.035 3 74.2 x 74.2 x t0.035 4 74.2 x 74.2 x t0.070 1 Thermal via - (4) Board E Item Specification Size [mm] 114.3 x 76.2 x t1.6 Material FR-4 Number of copper foil layer Copper foil layer [mm] Thermal via 4 1 Pattern for heat radiation: 2000mm2 t0.070 2 74.2 x 74.2 x t0.035 3 74.2 x 74.2 x t0.035 4 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm No. SOT895-A-Board-SD-1.0 enlarged view ABLIC Inc. HTMSOP-8 Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - (3) Board C Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm No. HTMSOP8-A-Board-SD-1.0 enlarged view ABLIC Inc. HTMSOP-8 Test Board IC Mount Area (4) Board D Item Size [mm] Material Number of copper foil layer Specification 114.3 x 76.2 x t1.6 FR-4 4 Thermal via 2 Pattern for heat radiation: 2000mm t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - Item Size [mm] Material Number of copper foil layer Specification 114.3 x 76.2 x t1.6 FR-4 4 Copper foil layer [mm] 1 2 3 4 enlarged view (5) Board E Copper foil layer [mm] Thermal via 1 2 3 4 2 Pattern for heat radiation: 2000mm t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm enlarged view No. HTMSOP8-A-Board-SD-1.0 ABLIC Inc. SOT-23-3/3S/5/6 Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. SOT23x-A-Board-SD-2.0 ABLIC Inc. 4.5±0.1 1.5±0.1 1.6±0.2 5 4 0.3 45° 1 2 3 1.5±0.1 1.5±0.1 0.4±0.05 0.4±0.1 0.4±0.1 0.45±0.1 No. UP005-A-P-SD-2.0 TITLE SOT895-A-PKG Dimensions No. UP005-A-P-SD-2.0 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches : 40.0±0.2) ø1.5 +0.1 -0 2.0±0.05 +0.1 ø1.5 -0 0.3±0.05 8.0±0.1 2.0±0.1 4.75±0.1 3 2 1 4 5 Feed direction No. UP005-A-C-SD-2.0 TITLE SOT895-A-Carrier Tape UP005-A-C-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. 16.5max. 13.0±0.3 Enlarged drawing in the central part (60°) (60°) No. UP005-A-R-SD-1.1 TITLE SOT895-A-Reel No. UP005-A-R-SD-1.1 ANGLE UNIT QTY. mm ABLIC Inc. 1,000 2.90±0.2 1.85 8 5 1 4 0.13±0.1 0.2±0.1 0.65±0.1 No. FP008-A-P-SD-2.0 TITLE HTMSOP8-A-PKG Dimensions No. FP008-A-P-SD-2.0 ANGLE UNIT mm ABLIC Inc. 2.00±0.05 4.00±0.1 4.00±0.1 1.00±0.1 +0.1 1.5 -0 1.05±0.05 0.30±0.05 3.25±0.05 4 1 5 8 Feed direction No. FP008-A-C-SD-1.0 TITLE HTMSOP8-A-Carrier Tape No. FP008-A-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. 16.5max. 13.0±0.3 Enlarged drawing in the central part 13±0.2 (60°) (60°) No. FP008-A-R-SD-1.0 TITLE HTMSOP8-A-Reel No. FP008-A-R-SD-1.0 ANGLE QTY. UNIT mm ABLIC Inc. 4,000 0.35 1.90 0.65 0.65 0.65 No. FP008-A-L-SD-2.0 TITLE No. HTMSOP8-A -Land Recommendation FP008-A-L-SD-2.0 ANGLE UNIT mm ABLIC Inc. 2.9±0.2 1.9±0.2 4 5 1 2 +0.1 0.16 -0.06 3 0.95±0.1 0.4±0.1 No. MP005-A-P-SD-1.3 TITLE SOT235-A-PKG Dimensions No. MP005-A-P-SD-1.3 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 ø1.5 -0 +0.2 ø1.0 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 Feed direction No. MP005-A-C-SD-2.1 TITLE SOT235-A-Carrier Tape No. MP005-A-C-SD-2.1 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP005-A-R-SD-1.1 SOT235-A-Reel TITLE No. MP005-A-R-SD-1.1 ANGLE QTY. UNIT mm ABLIC Inc. 3,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-19315AAAA-U5T1U7 价格&库存
很抱歉,暂时无法提供与“S-19315AAAA-U5T1U7”相匹配的价格&库存,您可以联系我们找货
