S-1212B80-U5T1U
S-1212B80-U5T1U
    ABLIC(艾普凌科)
    SOT89-5
    IC REG LINEAR 8V 250MA SOT89-5
S-1212B80-U5T1U 数据手册
S-1212B/D Series www.ablic.com 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR Rev.3.1_00 © ABLIC Inc., 2015-2018 The S-1212B/D Series, developed by using high-withstand voltage CMOS process technology, is a positive voltage regulator with a high-withstand voltage, low current consumption and high-accuracy output voltage, and has a built-in ON / OFF circuit. The S-1212B/D Series operates at the maximum operation voltage of 36 V and a low current consumption of 6.5 μA typ., and has a built-in low on-resistance output transistor which provides a very small dropout voltage and a large output current. Also, a built-in overcurrent protection circuit to limit overcurrent of the output transistor and a built-in thermal shutdown circuit to limit heat are included.  Features • Output voltage: • Input voltage: • Output voltage accuracy: • Current consumption: • Output current: • Input capacitor: • Output capacitor: • Built-in overcurrent protection circuit: • Built-in thermal shutdown circuit: • Built-in ON / OFF circuit: • Operation temperature range: • Lead-free (Sn 100%), halogen-free 2.5 V to 16.0 V, selectable in 0.1 V step 3.0 V to 36 V ±2.0% (Ta = +25°C) During operation: 6.5 μA typ. (Ta = +25°C) During power-off: 0.1 μA typ. (Ta = +25°C) Possible to output 250 mA (at VIN ≥ VOUT(S) + 2.0 V)*1 A ceramic capacitor can be used. (1.0 μF or more) A ceramic capacitor can be used. (1.0 μF to 100 μF) Limits overcurrent of output transistor. Detection temperature 165°C typ. Ensures long battery life. Discharge shunt function is available. Ta = −40°C to +105°C *1. Please make sure that the loss of the IC will not exceed the power dissipation when the output current is large.  Applications • Constant-voltage power supply for industrial equipment • Constant-voltage power supply for home electric appliance  Packages • TO-252-5S(A) • HSOP-8A • HSOP-6 • SOT-89-5 • HTMSOP-8 • SOT-23-5 1 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00  Block Diagram *1 VIN VOUT Overcurrent protection circuit Thermal shutdown circuit ON / OFF *2 ON / OFF circuit + − Reference voltage circuit *1 VSS *1. *2. Parasitic diode The ON / OFF circuit controls the internal circuit and the output transistor. Figure 1 2 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00  Product Name Structure Users can select the output voltage and package type for the S-1212B/D Series. Refer to "1. Product name" regarding the contents of product name, "2. Function list of product types" regarding the product type, "3. Packages" regarding the package drawings and "4. Product name list" for details of product names. 1. Product name S-1212 x xx - xxxx U Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications V5T2: TO-252-5S(A), Tape E8T1: HSOP-8A, Tape E6T1: HSOP-6, Tape U5T1: SOT-89-5, Tape S8T1: HTMSOP-8, Tape M5T1: SOT-23-5, Tape *1 Set output voltage 25 to G0 (e.g., when the set output voltage is 2.5 V, it is expressed as 25. when the set output voltage is 10.0 V, it is expressed as A0. when the set output voltage is 11.0 V, it is expressed as B0. when the set output voltage is 16.0 V, it is expressed as G0.) *2 Product type B, D *1. *2. Refer to the tape drawing. Refer to "2. Function list of product types" and "3. ON / OFF pin" in " Operation". 2. Function list of product types Table 1 Product Type B D ON / OFF Logic Active "H" Active "H" ON / OFF Pin Input Voltage "H" ON / OFF Pin Input Voltage "L" 1.5 V min. 0.25 V max. 2.0 V min. 0.8 V max. 3. Packages Table 2 Package Drawing Codes Package Name TO-252-5S(A) HSOP-8A HSOP-6 SOT-89-5 HTMSOP-8 SOT-23-5 Dimension VA005-A-P-SD FH008-A-P-SD FH006-A-P-SD UP005-A-P-SD FP008-A-P-SD MP005-A-P-SD Tape VA005-A-C-SD FH008-A-C-SD FH006-A-C-SD UP005-A-C-SD FP008-A-C-SD MP005-A-C-SD Reel VA005-A-R-SD FH008-A-R-SD FH006-A-R-S1 UP005-A-R-SD FP008-A-R-SD MP005-A-R-SD Land VA005-A-L-SD FH008-A-L-SD FH006-A-L-SD − FP008-A-L-SD − 3 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00 4. Product name list 4. 1 S-1212B/D Series B type ON / OFF logic: Active "H" ON / OFF pin input voltage "H" (VSH) = 1.5 V min., ON / OFF pin input voltage "L" (VSL) = 0.25 V max. . Table 3 Output Voltage TO-252-5S(A) HSOP-8A HSOP-6 SOT-89-5 HTMSOP-8 SOT-23-5 3.3 V ± 2.0% S-1212B33-V5T2U S-1212B33-E8T1U S-1212B33-E6T1U S-1212B33-U5T1U S-1212B33-S8T1U S-1212B33-M5T1U 5.0 V ± 2.0% S-1212B50-V5T2U S-1212B50-E8T1U S-1212B50-E6T1U S-1212B50-U5T1U S-1212B50-S8T1U S-1212B50-M5T1U S-1212B80-S8T1U S-1212B80-M5T1U 8.0 V ± 2.0% S-1212B80-V5T2U S-1212B80-E8T1U S-1212B80-E6T1U S-1212B80-U5T1U S-1212BC0-V5T2U S-1212BC0-E8T1U S-1212BC0-E6T1U S-1212BC0-U5T1U S-1212BC0-M5T1U S-1212BC0-S8T1U Remark Please contact our sales office for products with specifications other than the above output voltage. 12.0 V ± 2.0% 4. 2 S-1212B/D Series D type ON / OFF logic: Active "H" ON / OFF pin input voltage "H" (VSH) = 2.0 V min., ON / OFF pin input voltage "L" (VSL) = 0.8 V max. Table 4 Output Voltage TO-252-5S(A) HSOP-8A HSOP-6 SOT-89-5 HTMSOP-8 SOT-23-5 3.3 V ± 2.0% S-1212D33-V5T2U S-1212D33-E8T1U S-1212D33-E6T1U S-1212D33-U5T1U S-1212D33-S8T1U S-1212D33-M5T1U 5.0 V ± 2.0% S-1212D50-V5T2U S-1212D50-E8T1U S-1212D50-E6T1U S-1212D50-U5T1U S-1212D50-S8T1U S-1212D50-M5T1U 8.0 V ± 2.0% S-1212D80-V5T2U S-1212D80-E8T1U S-1212D80-E6T1U S-1212D80-U5T1U S-1212D80-S8T1U S-1212D80-M5T1U S-1212DC0-V5T2U 12.0 V ± 2.0% S-1212DC0-E8T1U S-1212DC0-E6T1U S-1212DC0-U5T1U S-1212DC0-S8T1U S-1212DC0-M5T1U Remark Please contact our sales office for products with specifications other than the above output voltage. 4 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00  Pin Configurations 1. TO-252-5S(A) Top view Table 5 3 Pin No. 1 1 2 4 Symbol VOUT Description Output voltage pin 2 ON / OFF ON / OFF pin 3 VSS GND pin 4 NC*1 No connection 5 VIN Input voltage pin 5 Figure 2 The NC pin is electrically open. The NC pin can be connected to the VIN pin or the VSS pin. *1. 2. HSOP-8A Top view Table 6 1 8 2 7 3 4 Pin No. Symbol Description 1 VOUT Output voltage pin 2 NC*2 No connection 6 3 NC*2 No connection 5 4 ON / OFF ON / OFF pin Bottom view 8 1 7 2 6 3 5 4 5 VSS GND pin 6 NC*2 No connection 7 NC*2 No connection 8 VIN Input voltage pin *1 Figure 3 *1. *2. Connect the heat sink of backside at shadowed area to the board, and set electric potential GND. However, do not use it as the function of electrode. The NC pin is electrically open. The NC pin can be connected to the VIN pin or the VSS pin. 5 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00 3. HSOP-6 Top view 6 Table 7 5 1 4 2 Pin No. 3 Symbol Description 1 VOUT Output voltage pin 2 VSS GND pin 3 ON / OFF ON / OFF pin *1 4 NC No connection 5 VSS GND pin 6 VIN Input voltage pin Figure 4 *1. The NC pin is electrically open. The NC pin can be connected to the VIN pin or the VSS pin. 4. SOT-89-5 Top view 5 Table 8 4 Pin No. 2 3 *1 Description NC No connection 2 VSS GND pin 3 VIN Input voltage pin 4 VOUT Output voltage pin 5 ON / OFF ON / OFF pin 1 1 Symbol Figure 5 *1. The NC pin is electrically open. The NC pin can be connected to the VIN pin or the VSS pin. 5. HTMSOP-8 Top view 1 2 3 4 Table 9 8 7 6 5 Bottom view 1 2 3 4 8 7 6 5 *1 Pin No. Symbol Description 1 VOUT Output voltage pin 2 NC*2 No connection 3 NC*2 No connection 4 ON / OFF ON / OFF pin 5 VSS GND pin 6 NC*2 No connection 7 *2 NC No connection 8 VIN Input voltage pin Figure 6 *1. *2. 6 Connect the heat sink of backside at shadowed area to the board, and set electric potential GND. However, do not use it as the function of electrode. The NC pin is electrically open. The NC pin can be connected to the VIN pin or the VSS pin. 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00 6. SOT-23-5 Top view 5 4 Table 10 Pin No. Symbol Description 1 VIN Input voltage pin 2 VSS GND pin 1 2 3 3 *1 Figure 7 NC No connection 4 ON / OFF ON / OFF pin 5 VOUT Output voltage pin *1. The NC pin is electrically open. The NC pin can be connected to the VIN pin or the VSS pin. 7 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00  Absolute Maximum Ratings Table 11 (Ta = +25°C unless otherwise specified) Item Symbol VIN Input voltage Absolute Maximum Rating VSS − 0.3 to VSS + 45 Unit V VON / OFF VSS − 0.3 to VIN + 0.3 ≤ VSS + 45 V Output voltage VOUT VSS − 0.3 to VIN + 0.3 ≤ VSS + 45 V Output current IOUT 280 mA Junction temperature Tj −40 to +150 °C Operation ambient temperature Topr −40 to +105 °C Storage temperature Tstg −40 to +150 °C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions.  Thermal Resistance Value Table 12 Item Symbol Condition Board A Board B TO-252-5S(A) Board C Board D Board E Board A Board B HSOP-8A Board C Board D Board E Board A Board B HSOP-6 Board C Board D Board E *1 Junction-to-ambient thermal resistance θJA Board A Board B SOT-89-5 Board C Board D Board E Board A Board B HTMSOP-8 Board C Board D Board E Board A Board B SOT-23-5 Board C Board D Board E *1. Test environment: compliance with JEDEC STANDARD JESD51-2A Remark 8 Refer to " Power Dissipation" and "Test Board" for details. Min. Typ. Max. Unit − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − 90 58 38 30 29 115 82 42 43 35 106 82 − 51 48 123 90 − 53 41 161 116 44 44 35 180 143 − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − − °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00  Electrical Characteristics Table 13 Item Symbol Output voltage*1 *2 Output current Dropout voltage *3 Line regulation Load regulation Current consumption during operation Current consumption during power-off Input voltage VOUT(E) VIN = VOUT(S) + 2.0 V, IOUT = 10 mA IOUT VIN ≥ VOUT(S) + 2.0 V IOUT = 125 mA IOUT = 250 mA VOUT(S) + 0.5 V ≤ VIN ≤ 36 V, IOUT = 10 mA, Tj = +25°C VIN = VOUT(S) + 2.0 V, 2.5 V ≤ VOUT(S) < 5.1 V, 0.1 mA ≤ IOUT ≤ 40 mA, Tj = +25°C VIN = VOUT(S) + 2.0 V, 5.1 V ≤ VOUT(S) < 12.1 V, 0.1 mA ≤ IOUT ≤ 40 mA, Tj = +25°C VIN = VOUT(S) + 2.0 V, 12.1 V ≤ VOUT(S) ≤ 16.0 V, 0.1 mA ≤ IOUT ≤ 40 mA, Tj = +25°C VIN = 18.0 V, VON / OFF = VIN, IOUT = 0.01 mA VIN = 18.0 V, VON / OFF = 0 V, no load − B type (ON / OFF logic active "H") VIN = 18.0 V, RL = 1.0 kΩ, determined by VOUT output level D type (ON / OFF logic active "H") B type (ON / OFF logic active "H") VIN = 18.0 V, RL = 1.0 kΩ, determined by VOUT output level D type (ON / OFF logic active "H") Vdrop ΔVOUT1 ΔVIN • VOUT ΔVOUT2 ISS1 ISS2 VIN ON / OFF pin input voltage "H" VSH ON / OFF pin input voltage "L" VSL ON / OFF pin input current "H" ON / OFF pin input current "L" Ripple rejection Short-circuit current Condition (Ta = +25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit VOUT(S) VOUT(S) VOUT(S) V 1 × 0.980 × 1.020 *4 250 − − mA 3 − 0.35 − V 1 − 0.80 − V 1 − 0.01 0.03 %/V 1 − 16 30 mV 1 − 16 35 mV 1 − 16 40 mV 1 − 6.5 8.5 μA 2 − 0.1 3.5 μA 2 3.0 − 36 V − 1.5 − − V 4 2.0 − − V 4 − − 0.25 V 4 − − 0.8 V 4 ISH VIN = 18.0 V, VON / OFF = VIN −0.1 − 0.1 μA 4 ISL VIN = 18.0 V, VON / OFF = 0 V −0.1 − 0.1 μA 4 2.5 V ≤ VOUT(S) < 3.6 V − 45 − dB 5 |RR| VIN = VOUT(S) + 2.0 V, f = 100 Hz, ΔVrip = 0.5 Vrms, IOUT = 10 mA 3.6 V ≤ VOUT(S) < 6.1 V − 40 − dB 5 6.1 V ≤ VOUT(S) < 10.1 V − 35 − dB 5 10.1 V ≤ VOUT(S) ≤ 16.0 V − 30 − dB 5 − 120 − mA 3 Ishort VIN = VOUT(S) + 2.0 V, VON / OFF = VIN, VOUT = 0 V Thermal shutdown T Junction temperature − 165 − °C − detection temperature SD Thermal shutdown TSR Junction temperature − 140 − °C − release temperature Discharge shunt resistance during RLOW VIN = 18.0 V, VON / OFF = 0 V, VOUT = 2.0 V − 70 − kΩ 6 power-off *1. VOUT(S): Set output voltage VOUT(E): Actual output voltage The output voltage when VIN = VOUT(S) + 2.0 V, IOUT = 10 mA *2. The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current. *3. Vdrop = VIN1 − (VOUT3 × 0.98) VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. VOUT3 is the output voltage when VIN = VOUT(S) + 2.0 V, and IOUT = 125 mA or 250 mA. *4. Due to limitation of the power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation when the output current is large. This specification is guaranteed by design. 9 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series  Test Circuits VIN + VOUT ON / OFF V VSS A + Set to ON Figure 8 Test Circuit 1 VIN VOUT ON / OFF VSS Set to VIN or GND A + Figure 9 Test Circuit 2 VIN VOUT + ON / OFF VSS A V + Set to ON Figure 10 Test Circuit 3 VIN + A VOUT ON / OFF VSS V + RL Figure 11 Test Circuit 4 VIN VOUT ON / OFF VSS Set to ON Figure 12 Test Circuit 5 10 V + RL Rev.3.1_00 Rev.3.1_00 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series VIN VOUT A ON / OFF VSS + V + Set to OFF Figure 13 Test Circuit 6 11 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00  Standard Circuit Input Output VOUT VIN CIN *1 ON / OFF VSS Single GND CL *2 GND *1. CIN is a capacitor for stabilizing the input. *2. CL is a capacitor for stabilizing the output. Figure 14 Caution The above connection diagram and constants will not guarantee successful operation. Perform thorough evaluation using an actual application to set the constants.  Condition of Application Input capacitor (CIN): Output capacitor (CL): A ceramic capacitor with capacitance of 1.0 μF or more is recommended. A ceramic capacitor with capacitance of 1.0 μF to 100 μF is recommended. Caution Generally, in a voltage regulator, an oscillation may occur depending on the selection of the external parts. Perform thorough evaluation including the temperature characteristics with an actual application using the above capacitors to confirm no oscillation occurs.  Selection of Input Capacitor (CIN) and Output Capacitor (CL) The S-1212B/D Series requires CL between the VOUT pin and the VSS pin for phase compensation. The operation is stabilized by a ceramic capacitor with capacitance of 1.0 μF to 100 μF. When using an OS capacitor, a tantalum capacitor or an aluminum electrolytic capacitor, the capacitance also must be 1.0 μF to 100 μF. However, an oscillation may occur depending on the equivalent series resistance (ESR). Moreover, the S-1212B/D Series requires CIN between the VIN pin and the VSS pin for a stable operation. Generally, an oscillaiton may occur when a voltage regulator is used under the conditon that the impedance of the power supply is high. Note that the output voltage transient characteristics varies depending on the capacitance of CIN and CL and the value of ESR. Caution Perform thorough evaluation including the temperature characteristics with an actual application to select CIN and CL. 12 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00  Explanation of Terms 1. Low dropout voltage regulator This is a voltage regulator which made dropout voltage small by its built-in low on-resistance output transistor. 2. Output voltage (VOUT) This voltage is output at an accuracy of ±2.0% when the input voltage, the output current and the temperature are in *1 a certain condition . *1. Differs depending on the product. Caution If the certain condition is not satisfied, the output voltage may exceed the accuracy range of ±2.0%. Refer to " Electrical Characteristics" and " Characteristics (Typical Data)" for details. ΔVOUT1  ΔVIN • VOUT  3. Line regulation  Indicates the dependency of the output voltage against the input voltage. That is, the value shows how much the output voltage changes due to a change in the input voltage after fixing output current constant. 4. Load regulation (ΔVOUT2) Indicates the dependency of the output voltage against the output current. That is, the value shows how much the output voltage changes due to a change in the output current after fixing input voltage constant. 5. Dropout voltage (Vdrop) Indicates the difference between input voltage (VIN1) and the output voltage when the output voltage becomes 98% of the output voltage value (VOUT3) at VIN = VOUT(S) + 2.0 V after the input voltage (VIN) is decreased gradually. Vdrop = VIN1 − (VOUT3 × 0.98) 13 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00  Operation 1. Basic operation Figure 15 shows the block diagram of the S-1212B/D Series to describe the basic operation. The error amplifier compares the feedback voltage (Vfb) whose output voltage (VOUT) is divided by the feedback resistors (Rs and Rf) with the reference voltage (Vref). The error amplifier controls the output transistor, consequently, the regulator starts the operation that holds VOUT constant without the influence of the input voltage (VIN). VIN *1 Current supply VOUT Error amplifier Vref − + Rf Vfb Reference voltage circuit Rs VSS *1. Parasitic diode Figure 15 2. Output transistor In the S-1212B/D Series, a low on-resistance P-channel MOS FET is used between the VIN pin and the VOUT pin as the output transistor. In order to hold VOUT constant, the on-resistance of the output transistor varies appropriately according to the output current (IOUT). Caution Since a parasitic diode exists between the VIN pin and the VOUT pin due to the structure of the transistor, the IC may be damaged by a reverse current if VOUT becomes higher than VIN. Therefore, be sure that VOUT does not exceed VIN + 0.3 V. 14 Rev.3.1_00 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series 3. ON / OFF pin The ON / OFF pin controls the internal circuit and the output transistor in order to start and stop the regulator. When the ON / OFF pin is set to OFF, the internal circuit stops operating and the output transistor between the VIN pin and the VOUT pin is turned off, reducing current consumption significantly. The internal equivalent circuit related to the ON / OFF pin is configured as shown in Figure 16. Since the ON / OFF pin is neither pulled down nor pulled up, do not use it in the floating status. When not using the ON / OFF pin, connect it to the VIN pin. Note that the current consumption increases when a voltage of VSL max.*1 to VIN0.3 V is applied to the ON / OFF pin. Table 14 Product Type ON / OFF Pin Internal Circuit VOUT Pin Voltage Current Consumption *2 Constant value B/D "H": ON Operate ISS1 Pulled down to VSS*3 B/D "L": OFF Stop ISS2 *1. Refer to Table 13 in " Electrical Characteristics". *2. The constant value is output due to the regulating based on the set output voltage value. *3. The VOUT pin voltage of the S-1212B/D Series is pulled down to VSS due to combined resistance (RLOW = 70 k typ.) of the discharge shunt circuit and the feedback resistors, and a load. VIN ON / OFF VSS Figure 16 15 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00 4. Discharge shunt function The S-1212B/D Series has a built-in discharge shunt circuit to discharge the output capacitance. The output capacitance is discharged as follows so that the VOUT pin reaches the VSS level. (1) The ON / OFF pin is set to OFF level. (2) The output transistor is turned off. (3) The discharge shunt circuit is turned on. (4) The output capacitor discharges. S-1212B/D Series Output transistor : OFF *1 VOUT VIN Discharge shunt circuit : ON *1 ON / OFF ON / OFF circuit Output capacitor (CL) ON / OFF pin : OFF Current flow GND VSS *1. Parasitic diode Figure 17 5. Overcurrent protection circuit The S-1212B/D Series has a built-in overcurrent protection circuit to limit the overcurrent of the output transistor. When the VOUT pin is shorted with the VSS pin, that is, at the time of the output short-circuit, the output current is limited to 120 mA typ. due to the overcurrent protection circuit operation. The S-1212B/D Series restarts regulating when the output transistor is released from the overcurrent status. Caution 1. This overcurrent protection circuit does not work as for thermal protection. For example, when the output transistor keeps the overcurrent status long at the time of output short-circuit or due to other reasons, pay attention to the conditions of the input voltage and the load current so as not to exceed the power dissipation. 2. Note that any interference may be caused in the output voltage start-up when a load heavier VOUT(S) than is connected. 100 mA 16 Rev.3.1_00 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series 6. Thermal shutdown circuit The S-1212B/D Series has a built-in thermal shutdown circuit to limit overheating. When the junction temperature increases to 165°C typ., the thermal shutdown circuit becomes the detection status, and the regulating is stopped. When the junction temperature decreases to 140°C typ., the thermal shutdown circuit becomes the release status, and the regulator is restarted. If the thermal shutdown circuit becomes the detection status due to self-heating, the regulating is stopped and VOUT decreases. For this reason, the self-heating is limited and the temperature of the IC decreases. The thermal shutdown circuit becomes release status when the temperature of the IC decreases, and the regulating is restarted, thus the self-heating is generated again. Repeating this procedure makes the waveform of VOUT into a pulse-like form. This phenomenon continues unless decreasing either or both of the input voltage and the output current in order to reduce the internal power consumption, or decreasing the ambient temperature. Note that the product may suffer physical damage such as deterioration if the above phenomenon occurs continuously. Caution 1. When the heat radiation of the application is not in a good condition, the self-heating cannot be limited immediately, and the IC may suffer physical damage. Perform thorough evaluation including the temperature characteristics with an actual application to confirm no problems happen. 2. If a large load current flows during the restart process of regulating after the thermal shutdown circuit changes to the release status from the detection status, the thermal shutdown circuit becomes the detection status again due to self-heating, and a problem may happen in the restart of regulating. A large load current, for example, occurs when charging to the CL whose capacitance is large. Perform thorough evaluation including the temperature characteristics with an actual application to select CL. Table 15 Thermal Shutdown Circuit VOUT Pin Voltage Release: 140°C typ.*1 Constant value*2 Detection: 165°C typ.*1 Pulled down to VSS*3 *1. Junction temperature *2. The constant value is output due to the regulating based on the set output voltage value. *3. The VOUT pin voltage is pulled down to VSS due to the feedback resistors (Rs and Rf) and a load. 17 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00  Precautions • Generally, when a voltage regulator is used under the condition that the load current value is small (0.1 mA or less), the output voltage may increase due to the leakage current of an output transistor. • Generally, when a voltage regulator is used under the condition that the temperature is high, the output voltage may increase due to the leakage current of an output transistor. • Generally, when the ON / OFF pin is used under the condition of OFF, the output voltage may increase due to the leakage current of an output transistor. • Generally, when a voltage regulator is used under the condition that the impedance of the power supply is high, an oscillation may occur. Perform thorough evaluation including the temperature characteristics with an actual application to select CIN. • Generally, in a voltage regulator, an oscillation may occur depending on the selection of the external parts. The following use conditions are recommended in the S-1212B/D Series, however, perform thorough evaluation including the temperature characteristics with an actual application to select CIN and CL. Input capacitor (CIN): Output capacitor (CL): A ceramic capacitor with capacitance of 1.0 μF or more is recommended. A ceramic capacitor with capacitance of 1.0 μF to 100 μF is recommended. • Generally, in a voltage regulator, the values of an overshoot and an undershoot in the output voltage vary depending on the variation factors of input voltage start-up, input voltage fluctuation and load fluctuation etc., or the capacitance of CIN or CL and the value of the equivalent series resistance (ESR), which may cause a problem to the stable operation. Perform thorough evaluation including the temperature characteristics with an actual application to select CIN and CL. • Generally, in a voltage regulator, an overshoot may occur in the output voltage momentarily if the input voltage steeply changes when the input voltage is started up or the input voltage fluctuates etc. Perform thorough evaluation including the temperature characteristics with an actual application to confirm no problems happen. • Generally, in a voltage regulator, if the VOUT pin is steeply shorted with GND, a negative voltage exceeding the absolute maximum ratings may occur in the VOUT pin due to resonance phenomenon of the inductance and the capacitance including CL on the application. The resonance phenomenon is expected to be weakened by inserting a series resistor into the resonance path, and the negative voltage is expected to be limited by inserting a protection diode between the VOUT pin and the VSS pin. • If the input voltage is started up steeply under the condition that the capacitance of CL is large, the thermal shutdown circuit may be in the detection status by self-heating due to the charge current to CL. • Make sure of the conditions for the input voltage, output voltage and the load current so that the internal loss does not exceed the power dissipation. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • When considering the output current value that the IC is able to output, make sure of the output current value specified in Table 13 in " Electrical Characteristics" and footnote *4 of the table. • Wiring patterns on the application related to the VIN pin, the VOUT pin and the VSS pin should be designed so that the impedance is low. When mounting CIN between the VIN pin and the VSS pin and CL between the VOUT pin and the VSS pin, connect the capacitors as close as possible to the respective destination pins of the IC. • In the package equipped with heat sink of backside, mount the heat sink firmly. Since the heat radiation differs according to the condition of the application, perform thorough evaluation with an actual application to confirm no problems happen. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 18 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00  Characteristics (Typical Data) 1. Output voltage vs. Output current (When load current increases) (Ta = +25°C) 1. 2 VOUT = 5.0 V 3.0 6.0 2.5 5.0 2.0 1.5 1.0 VOUT [V] VOUT [V] 1. 1 VOUT = 2.5 V VIN = 3.0 V VIN = 3.5 V VIN = 4.5 V VIN = 9.0 V 0.5 4.0 VIN = 5.5 V VIN = 6.0 V VIN = 7.0 V VIN = 9.0 V 3.0 2.0 1.0 0.0 0.0 0 100 200 300 400 500 600 700 800 IOUT [mA] 0 100 200 300 400 500 600 700 800 IOUT [mA] Remark In determining the output current, attention should be paid to the following. 1. The minimum output current value and footnote *4 of Table 13 in " Electrical Characteristics" 2. Power dissipation 2. Output voltage vs. Input voltage (Ta = +25°C) 2.9 5.4 2.7 5.2 2.5 5.0 2.3 VOUT [V] 2. 2 VOUT = 5.0 V VOUT [V] 2. 1 VOUT = 2.5 V IOUT = 0.1 mA IOUT = 10 mA IOUT = 40 mA 2.1 1.9 4.8 IOUT = 0.1 mA IOUT = 10 mA IOUT = 40 mA 4.6 4.4 1.7 4.2 0 6 12 18 24 VIN [V] 30 36 0 6 12 18 24 VIN [V] 30 36 2. 3 VOUT = 16.0 V 16.4 VOUT [V] 16.2 16.0 IOUT = 0.1 mA IOUT = 10 mA IOUT = 40 mA 15.8 15.6 15.4 15.2 0 6 12 18 24 VIN [V] 30 36 19 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00 3. Dropout voltage vs. Output current 3. 1 VOUT = 2.5 V 3. 2 VOUT = 5.0 V 1.2 1.2 1.0 Tj = +150C 0.8 0.6 Vdrop [V] Vdrop [V] 1.0 Tj = +25C 0.4 0.2 0 50 100 150 IOUT [mA] 200 0.6 Tj = +25C 0.4 0.2 Tj = 40C 0.0 Tj = +150C 0.8 Tj = 40C 0.0 250 0 50 100 150 IOUT [mA] 200 250 3. 3 VOUT = 16.0 V 1.2 Vdrop [V] 1.0 Tj = +150C 0.8 0.6 Tj = +25C 0.4 0.2 Tj = 40C 0.0 0 50 100 150 IOUT [mA] 200 250 4. Dropout voltage vs. Junction temperature 4. 1 VOUT = 2.5 V 4. 2 VOUT = 5.0 V 0.6 0.6 0.3 0.2 IOUT = 10 mA 0.1 0 25 50 75 100 125 150 Tj [C] 4. 3 VOUT = 16.0 V 0.6 Vdrop [V] IOUT = 125 mA 0.4 0.3 0.2 IOUT = 10 mA 0.1 0.0 −40 −25 20 IOUT = 125 mA 0.4 0.3 0.2 IOUT = 10 mA 0.1 0.0 −40 −25 0.5 0.5 IOUT = 125 mA 0.4 Vdrop [V] Vdrop [V] 0.5 0 25 50 75 100 125 150 Tj [C] 0.0 −40 −25 0 25 50 75 100 125 150 Tj [C] 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00 5. Dropout voltage vs. Set output voltage (Ta = +25°C) 1.0 Vdrop [V] 0.8 IOUT = 250 mA IOUT = 125 mA IOUT = 40 mA IOUT = 10 mA IOUT = 0.1 mA 0.6 0.4 0.2 0.0 0.0 4.0 8.0 VOUT(S) [V] 12.0 16.0 6. Output voltage vs. Junction temperature 6. 2 VOUT = 5.0 V 6. 1 VOUT = 2.5 V VIN = 7.0 V 2.55 5.10 2.53 5.06 VOUT [V] VOUT [V] VIN = 4.5 V 2.51 2.49 2.47 2.45 −40 −25 5.02 4.98 4.94 0 25 50 75 100 125 150 Tj [C] 4.90 −40 −25 0 25 50 75 100 125 150 Tj [C] 6. 3 VOUT = 16.0 V VIN = 18.0 V 5.10 VOUT [V] 5.06 5.02 4.98 4.94 4.90 −40 −25 0 25 50 75 100 125 150 Tj [C] 21 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00 7. Current consumption during operation vs. Input voltage (When ON / OFF pin is ON, no load) 7. 1 VOUT = 2.5 V 7. 2 VOUT = 5.0 V 50.0 50.0 40.0 Tj = 150C ISS1 [A] ISS1 [A] 40.0 30.0 Tj = 25C Tj = 40C 20.0 10.0 Tj = 150C 30.0 Tj = 25C Tj = 40C 20.0 10.0 0.0 0.0 0 6 12 18 VIN [V] 24 30 36 0 6 12 18 VIN [V] 24 30 36 7. 3 VOUT = 16.0 V 50.0 Tj = 40C Tj = 25C ISS1 [A] 40.0 30.0 Tj = 150C 20.0 10.0 0.0 0 6 12 18 VIN [V] 24 30 36 8. Current consumption during operation vs. Junction temperature 8. 1 VOUT = 2.5 V 8. 2 VOUT = 5.0 V 10.0 8.0 8.0 6.0 4.0 2.0 4.0 0.0 0 25 50 75 100 Tj [C] 125 150 8. 3 VOUT = 16.0 V VIN = 18.0 V 10.0 8.0 ISS1 [A] 6.0 2.0 0.0 6.0 4.0 2.0 0.0 0 22 VIN = 18.0 V 10.0 ISS1 [A] ISS1 [A] VIN = 18.0 V 25 50 75 100 Tj [C] 125 150 0 25 50 75 100 Tj [C] 125 150 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00 9. Current consumption during operation vs. Output current (Ta = +25°C) 9. 1 VOUT = 2.5 V 9. 2 VOUT = 5.0 V 50.0 50.0 40.0 VIN = 3.5 V 30.0 ISS1 [A] ISS1 [A] 40.0 VIN = 13.5 V 20.0 10.0 VIN = 6.0 V 30.0 VIN = 13.5 V 20.0 10.0 0.0 0.0 0 50 100 150 IOUT [mA] 200 250 200 250 0 50 100 150 IOUT [mA] 200 250 9. 3 VOUT = 16.0 V 50.0 ISS1 [A] 40.0 VIN = 17.0 V 30.0 VIN = 20.0 V 20.0 10.0 0.0 0 50 100 150 IOUT [mA] 10. Ripple rejection (Ta = +25°C) 10. 1 VOUT = 2.5 V 10. 2 VOUT = 5.0 V 120 100 IOUT = 0.01 mA 80 60 IOUT = 10 mA 40 20 IOUT = 250 mA 0 10 100 1k 10k Frequency [Hz] 100k VIN = 7.0 V, CL = 1.0 μF Ripple Rejection [dB] Ripple Rejection [dB] VIN = 4.5 V, CL = 1.0 μF 120 100 IOUT = 0.01 mA 80 IOUT = 10 mA 60 40 20 IOUT = 250 mA 0 10 100 1k 10k Frequency [Hz] 100k 10. 3 VOUT = 16.0 V Ripple Rejection [dB] VIN = 18.0 V, CL = 1.0 μF 120 100 IOUT = 0.01 mA 80 IOUT = 10 mA 60 40 20 0 IOUT = 250 mA 10 100 1k 10k Frequency [Hz] 100k 23 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00  Reference Data 1. Characteristics of input transient response (Ta = +25°C) VIN 2.7 2.5 CL = 10.0 F CL = 22.0 F 11 9 VOUT [V] 2.9 5.6 13 VIN [V] VOUT [V] 3.1 1. 2 VOUT = 5.0 V IOUT = 40 mA, CIN = 1.0 μF, VIN = 11.5 V ↔ 13.5 V, tr = tf = 5.0 μs 5.8 15 7 VOUT 5.4 VIN 5.2 5.0 2.3 5 0.4 0.0 0.4 0.8 1.2 1.6 2.0 2.4 2.8 t [ms] 13 CL = 10.0 F CL = 22.0 F 11 9 VIN [V] 1. 1 VOUT = 2.5 V IOUT = 40 mA, CIN = 1.0 μF, VIN = 11.5 V ↔ 13.5 V, tr = tf = 5.0 μs 3.3 15 7 VOUT 4.8 5 0.4 0.0 0.4 0.8 1.2 1.6 2.0 2.4 2.8 t [ms] 1. 3 VOUT = 16.0 V IOUT = 40 mA, CIN = 1.0 μF, VIN = 18.0 V ↔ 19.5 V, tr = tf = 5.0 μs 16.8 21 16.4 19 VIN 16.2 16.0 CL = 10.0 F CL = 22.0 F 17 15 VIN [V] VOUT [V] 16.6 13 VOUT 15.8 11 0.4 0.0 0.4 0.8 1.2 1.6 2.0 2.4 2.8 t [ms] 2. Characteristics of load transient response (Ta = +25°C) 2.6 2.5 100 5.3 50 5.2 0 VOUT 50 CL = 22.0 F CL = 10.0 F 2.4 100 100 50 16.1 16.0 15.9 0 VOUT 50 CL = 22.0 F CL = 10.0 F 100 15.8 150 0.4 0.0 0.4 0.8 1.2 1.6 2.0 2.4 2.8 t [ms] 24 IOUT [mA] VOUT [V] 16.2 50 5.0 0 VOUT 50 CL = 22.0 F CL = 10.0 F 100 4.8 150 0.4 0.0 0.4 0.8 1.2 1.6 2.0 2.4 2.8 t [ms] 2. 3 VOUT = 16.0 V VIN = 18.0 V, CIN = 1.0 μF, IOUT = 50 mA ↔ 100 mA 16.4 150 IOUT 100 IOUT 5.1 4.9 2.3 150 0.4 0.0 0.4 0.8 1.2 1.6 2.0 2.4 2.8 t [ms] 16.3 VOUT [V] 2.7 IOUT IOUT [mA] VOUT [V] 2.8 2. 2 VOUT = 5.0 V VIN = 13.5 V, CIN = 1.0 μF, IOUT = 50 mA ↔ 100 mA 5.4 150 IOUT [mA] 2. 1 VOUT = 2.5 V VIN = 13.5 V, CIN = 1.0 μF, IOUT = 50 mA ↔ 100 mA 2.9 150 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00 3. Transient response characteristics of ON / OFF pin (Ta = +25°C) 9.0 6 6.0 3.0 0.0 0 VON / OFF 6 12 VOUT 3.0 0.5 0.5 1.0 1.5 2.0 2.5 12 9.0 6 6.0 3.0 6 12 VOUT 3.0 0.5 3.0 0 VON / OFF 0.0 18 0.0 12.0 VON / OFF [V] 12 VOUT [V] 12.0 3. 2 VOUT = 5.0 V VIN = 13.5 V, CL = 10.0 μF, CIN = 1.0 μF, IOUT = 125 mA, VON / OFF = 0 V → 13.5 V 18 15.0 VON / OFF [V] VOUT [V] 3. 1 VOUT = 2.5 V VIN = 13.5 V, CL = 10.0 μF, CIN = 1.0 μF, IOUT = 125 mA, VON / OFF = 0 V → 13.5 V 18 15.0 18 0.0 0.5 1.0 1.5 2.0 2.5 3.0 t [ms] t [ms] 4. Load transient response characteristics dependent on capacitance (Ta = +25°C) VIN = 13.5 V, CIN = 1.0 μF, IOUT = 100 mA → 50 mA 0.20 Overshoot [V] Undershoot [V] 4. 1 VOUT = 5.0 V VIN = 13.5 V, CIN = 1.0 μF, IOUT = 50 mA → 100 mA 0.20 0.15 0.10 0.05 0.00 0.15 0.10 0.05 0.00 0 20 40 60 CL [F] 80 100 0 20 40 60 CL [F] 80 100 5. Input transient response characteristics dependent on capacitance (Ta = +25°C) VIN = 12.0 V → 7.0 V, tr = 5.0 μs, CIN = 1.0 μF, IOUT = 40 mA 2.0 Undershoot [V] Overshoot [V] 5. 1 VOUT = 5.0 V VIN = 7.0 V → 12.0 V, tr = 5.0 μs, CIN = 1.0 μF, IOUT = 40 mA 2.0 1.5 1.0 0.5 0.0 1.5 1.0 0.5 0.0 0 20 40 60 CL [μF] 80 100 0 20 40 60 CL [μF] 80 100 25 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00 6. Example of equivalent series resistance vs. Output current characteristics (Ta = +25°C) CIN = CL = 1.0 μF 100 RESR [Ω] VIN CIN Stable 0 S-1212B/D Series ON / OFF 0.1 VSS 250 VOUT CL *1 RESR IOUT [mA] *1. CL: TDK Corporation Figure 18 26 CGA5L3X8R1H105M (1.0 μF) Figure 19 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series Rev.3.1_00  Power Dissipation TO-252-5S(A) HSOP-8A Tj = 150C max. Tj = 150C max. 5 5 Power dissipation (PD) [W] Power dissipation (PD) [W] E 4 D 3 C 2 B 1 A 0 0 25 50 75 100 125 150 4 E D 2 B 1 0 175 C 3 A 0 25 Ambient temperature (Ta) [C] Board 75 100 Board A B C D E HSOP-6 175 Power Dissipation (PD) 1.09 W 1.52 W 2.98 W 2.91 W 3.57 W Tj = 150C max. Tj = 150C max. 5 Power dissipation (PD) [W] Power dissipation (PD) [W] 150 SOT-89-5 5 4 3 E D 2 B 1 A 0 125 Ambient temperature (Ta) [C] Power Dissipation (PD) 1.39 W 2.16 W 3.29 W 4.17 W 4.31 W A B C D E 50 0 25 50 75 100 125 150 175 4 E 3 D 2 B 1 0 A 0 25 Ambient temperature (Ta) [C] Board A B C D E Power Dissipation (PD) 1.18 W 1.52 W − 2.45 W 2.60 W 50 75 100 125 150 175 Ambient temperature (Ta) [C] Board A B C D E Power Dissipation (PD) 1.02 W 1.39 W − 2.36 W 3.05 W 27 105°C OPERATION, 36 V INPUT, 250 mA VOLTAGE REGULATOR S-1212B/D Series HTMSOP-8 Rev.3.1_00 SOT-23-5 Tj = 150C max. Tj = 150C max. 5 4 Power dissipation (PD) [W] Power dissipation (PD) [W] 5 E D 3 C 2 B 1 4 3 2 1 B A 0 0 A 25 50 75 100 125 150 175 0 0 25 Ambient temperature (Ta) [C] 28 Board Power Dissipation (PD) A B C D E 0.78 W 1.08 W 2.84 W 2.84 W 3.57 W 50 75 100 125 150 Ambient temperature (Ta) [C] Board A B C D E Power Dissipation (PD) 0.69 W 0.87 W − − − 175 TO-252-5S Test Board (1) Board A IC Mount Area Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - (3) Board C Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm No. TO252-5S-A-Board-SD-1.0 enlarged view ABLIC Inc. TO-252-5S Test Board (4) Board D IC Mount Area Item Size [mm] Material Number of copper foil layer Specification 114.3 x 76.2 x t1.6 FR-4 4 Thermal via 2 Pattern for heat radiation: 2000mm t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - Item Size [mm] Material Number of copper foil layer Specification 114.3 x 76.2 x t1.6 FR-4 4 Copper foil layer [mm] 1 2 3 4 (5) Board E Copper foil layer [mm] Thermal via 1 2 3 4 2 Pattern for heat radiation: 2000mm t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm enlarged view No. TO252-5S-A-Board-SD-1.0 ABLIC Inc. HSOP-8A Test Board (1) Board A IC Mount Area Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - (3) Board C Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm enlarged view No. HSOP8A-A-Board-SD-1.0 ABLIC Inc. HSOP-8A Test Board (4) Board D IC Mount Area Item Size [mm] Material Number of copper foil layer 1 2 Copper foil layer [mm] 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 Pattern for heat radiation: 2000mm2 t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - Item Size [mm] Material Number of copper foil layer 1 2 Copper foil layer [mm] 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Pattern for heat radiation: 2000mm2 t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm (5) Board E Thermal via enlarged view No. HSOP8A-A-Board-SD-1.0 ABLIC Inc. HSOP-6 Test Board IC Mount Area (1) Board A Item Specification Size [mm] 114.3 x 76.2 x t1.6 Material FR-4 Number of copper foil layer 2 Copper foil layer [mm] 1 Land pattern and wiring for testing: t0.070 2 3 4 74.2 x 74.2 x t0.070 Thermal via - (2) Board B Item Specification Size [mm] 114.3 x 76.2 x t1.6 Material FR-4 Number of copper foil layer 4 Land pattern and wiring for testing: t0.070 1 74.2 x 74.2 x t0.035 2 Copper foil layer [mm] 74.2 x 74.2 x t0.035 3 74.2 x 74.2 x t0.070 4 Thermal via - (3) Board D Item Specification Size [mm] 114.3 x 76.2 x t1.6 Material FR-4 Number of copper foil layer 4 Copper foil layer [mm] 1 2 3 4 Thermal via Pattern for heat radiation: 2000mm2 t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - (4) Board E Item Size [mm] Material Number of copper foil layer 1 2 Copper foil layer [mm] 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 Pattern for heat radiation: 2000mm2 t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm No. HSOP6-A-Board-SD-1.0 enlarged view ABLIC Inc. SOT-89-5 Test Board IC Mount Area (1) Board A Item Specification Size [mm] 114.3 x 76.2 x t1.6 Material FR-4 Number of copper foil layer Copper foil layer [mm] 2 1 Land pattern and wiring for testing: t0.070 2 - 3 4 74.2 x 74.2 x t0.070 Thermal via - (2) Board B Item Specification Size [mm] 114.3 x 76.2 x t1.6 Material FR-4 Number of copper foil layer 4 Copper foil layer [mm] 1 Land pattern and wiring for testing: t0.070 2 74.2 x 74.2 x t0.035 3 74.2 x 74.2 x t0.035 4 74.2 x 74.2 x t0.070 Thermal via - (3) Board D Item Specification Size [mm] 114.3 x 76.2 x t1.6 Material FR-4 Number of copper foil layer Copper foil layer [mm] 4 2 Pattern for heat radiation: 2000mm2 t0.070 74.2 x 74.2 x t0.035 3 74.2 x 74.2 x t0.035 4 74.2 x 74.2 x t0.070 1 Thermal via - (4) Board E Item Specification Size [mm] 114.3 x 76.2 x t1.6 Material FR-4 Number of copper foil layer Copper foil layer [mm] Thermal via 4 1 Pattern for heat radiation: 2000mm2 t0.070 2 74.2 x 74.2 x t0.035 3 74.2 x 74.2 x t0.035 4 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm No. SOT895-A-Board-SD-1.0 enlarged view ABLIC Inc. HTMSOP-8 Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - (3) Board C Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm No. HTMSOP8-A-Board-SD-1.0 enlarged view ABLIC Inc. HTMSOP-8 Test Board IC Mount Area (4) Board D Item Size [mm] Material Number of copper foil layer Specification 114.3 x 76.2 x t1.6 FR-4 4 Thermal via 2 Pattern for heat radiation: 2000mm t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - Item Size [mm] Material Number of copper foil layer Specification 114.3 x 76.2 x t1.6 FR-4 4 Copper foil layer [mm] 1 2 3 4 enlarged view (5) Board E Copper foil layer [mm] Thermal via 1 2 3 4 2 Pattern for heat radiation: 2000mm t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm enlarged view No. HTMSOP8-A-Board-SD-1.0 ABLIC Inc. SOT-23-3/3S/5/6 Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. SOT23x-A-Board-SD-2.0 ABLIC Inc. 6.5±0.2 5.8 1.2±0.1 (5.2) 0.80 0.6±0.1 0.22±0.05 1.27 No. VA005-A-P-SD-2.0 TITLE TO-252-5S-A-PKG Dimensions VA005-A-P-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) 2.0±0.05 +0.1 ø1.5 -0.0 0.2±0.05 ø1.7±0.1 8.0±0.1 1.5±0.1 6.9±0.1 5 1 Feed direction No. VA005-A-C-SD-1.0 TITLE TO-252-5S-A-C a r r i e r T a p e No. VA005-A-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. 60° 13.4±1.0 Enlarged drawing in the central part ø21±0.8 17.4±1.0 2±0.5 ø13±0.2 No. VA005-A-R-SD-1.0 TO-252-5S-A-Reel TITLE VA005-A-R-SD-1.0 No. ANGLE UNIT QTY. mm ABLIC Inc. 4,000 6.0 0.8 2.54 1.27 No. VA005-A-L-SD-1.0 TITLE TO-252-5S-A -Land Recommendation No. VA005-A-L-SD-1.0 ANGLE UNIT mm ABLIC Inc. 5.02±0.2 8 5 1 4 1.27 3.0 1 0.20±0.05 8 4 5 0.4±0.05 No. FH008-A-P-SD-2.0 TITLE HSOP8A-A-PKG Dimensions No. FH008-A-P-SD-2.0 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) 2.0±0.05 ø1.5 +0.1 -0.0 0.3±0.05 ø2.0±0.05 8.0±0.1 2.1±0.1 6.7±0.1 1 8 4 5 Feed direction No. FH008-A-C-SD-1.0 TITLE HSOP8A-A-Carrier Tape FH008-A-C-SD-1.0 No. ANGLE UNIT mm ABLIC Inc. 17.4±1.0 13.4±1.0 Enlarged drawing in the central part ø21±0.8 2±0.5 ø13±0.2 No. FH008-A-R-SD-1.0 TITLE HSOP8A-A-Reel No. FH008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 4,000 0.76 3.2 1.27 1.27 1.27 No. FH008-A-L-SD-1.0 TITLE HSOP8A-A -Land Recommendation No. FH008-A-L-SD-1.0 ANGLE UNIT mm ABLIC Inc. 5.02±0.2 6 1 0.4±0.05 5 4 2 3 0.20±0.05 1.67±0.05 1.91 1.91 No. FH006-A-P-SD-2.1 TITLE HSOP6-A-PKG Dimensions No. FH006-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) 2.0±0.05 ø1.55±0.05 0.3±0.05 ø2.0±0.05 8.0±0.1 2.1±0.1 6.7±0.1 1 6 3 4 Feed direction No. FH006-A-C-SD-2.0 TITLE HSOP6-A-Carrier Tape No. FH006-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 60° 2±0.5 13.5±0.5 Enlarged drawing in the central part ø21±0.8 2±0.5 ø13±0.2 No. FH006-A-R-S1-1.0 TITLE HSOP6-A-Reel No. FH006-A-R-S1-1.0 ANGLE UNIT QTY. mm ABLIC Inc. 4,000 2.03 0.76 1.91 1.91 No. FH006-A-L-SD-2.0 TITLE HSOP6-A -Land Recommendation No. FH006-A-L-SD-2.0 ANGLE UNIT mm ABLIC Inc. 4.5±0.1 1.5±0.1 1.6±0.2 5 4 0.3 45° 1 2 3 1.5±0.1 1.5±0.1 0.4±0.05 0.4±0.1 0.4±0.1 0.45±0.1 No. UP005-A-P-SD-2.0 TITLE SOT895-A-PKG Dimensions No. UP005-A-P-SD-2.0 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches : 40.0±0.2) ø1.5 +0.1 -0 2.0±0.05 +0.1 ø1.5 -0 0.3±0.05 8.0±0.1 2.0±0.1 4.75±0.1 3 2 1 4 5 Feed direction No. UP005-A-C-SD-2.0 TITLE SOT895-A-Carrier Tape UP005-A-C-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. 16.5max. 13.0±0.3 Enlarged drawing in the central part (60°) (60°) No. UP005-A-R-SD-1.1 TITLE SOT895-A-Reel No. UP005-A-R-SD-1.1 ANGLE UNIT QTY. mm ABLIC Inc. 1,000 2.90±0.2 1.85 8 5 1 4 0.13±0.1 0.2±0.1 0.65±0.1 No. FP008-A-P-SD-2.0 TITLE HTMSOP8-A-PKG Dimensions No. FP008-A-P-SD-2.0 ANGLE UNIT mm ABLIC Inc. 2.00±0.05 4.00±0.1 4.00±0.1 1.00±0.1 +0.1 1.5 -0 1.05±0.05 0.30±0.05 3.25±0.05 4 1 5 8 Feed direction No. FP008-A-C-SD-1.0 TITLE HTMSOP8-A-Carrier Tape No. FP008-A-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. 16.5max. 13.0±0.3 Enlarged drawing in the central part 13±0.2 (60°) (60°) No. FP008-A-R-SD-1.0 TITLE HTMSOP8-A-Reel No. FP008-A-R-SD-1.0 ANGLE QTY. UNIT mm ABLIC Inc. 4,000 0.35 1.90 0.65 0.65 0.65 No. FP008-A-L-SD-2.0 TITLE No. HTMSOP8-A -Land Recommendation FP008-A-L-SD-2.0 ANGLE UNIT mm ABLIC Inc. 2.9±0.2 1.9±0.2 4 5 1 2 +0.1 0.16 -0.06 3 0.95±0.1 0.4±0.1 No. MP005-A-P-SD-1.3 TITLE SOT235-A-PKG Dimensions No. MP005-A-P-SD-1.3 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 ø1.5 -0 +0.2 ø1.0 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 Feed direction No. MP005-A-C-SD-2.1 TITLE SOT235-A-Carrier Tape No. MP005-A-C-SD-2.1 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP005-A-R-SD-1.1 SOT235-A-Reel TITLE No. MP005-A-R-SD-1.1 ANGLE QTY. UNIT mm ABLIC Inc. 3,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-1212B80-U5T1U 价格&库存
很抱歉,暂时无法提供与“S-1212B80-U5T1U”相匹配的价格&库存,您可以联系我们找货
