NJM2712RB1-TE1
NJM2712RB1-TE1
    JRC(⽇本无线)
    VSSOP8
    IC OPAMP GP 2 CIRCUIT 8TVSP
NJM2712RB1-TE1 数据手册
NJM2712 ULTRA HIGH-SPEED SINGLE OPERATIONAL AMPLIFIER ■ GENERAL DESCRIPTION ■ PACKAGR OUTLINE The NJM2712 is a dual high speed wide bandwidth operational amplifier. It features high slew rate of 260V/uS and wide gain band wirth of 1GHz. It is suitable for analog front end application. ■ FEATURES • Operating Voltage • Operating Current • High Slew Rate • Gain Bandwidth Product Bandwidth • Unity Gain Bandwidth • Input Offset Voltage • Maximum Output Voltage • Supply Voltage Rejection • Open Loop Voltage Gain • Bipolar Technology • Package Outline NJM2712M NJM2712RB1 (DMP8) (MSOP8 (TVSP8)) ±2.0 to ±4.5V 3.8mA typ. (at V+/V-=±2.5V) 260V/µs typ. 1GHz typ. 10MHz typ. (at 40dB) 180MHz typ. 7mV max. ±1.5V typ. (at RL=1kΩ) 60dB typ 75dB typ. DMP8, MSOP8 (TVSP8)MEET JEDEC MO-187-DA / THIN TYPE ■ PIN CONFIGURATION NJM2712M NJM2712RB1 (Top View) PIN FUNCTION 1 8 1.OUTPUT1 2.-INPUT1 2 - + 7 3.+INPUT1 4.V - 3 4 + - 6 5 5.+INPUT2 6.-INPUT2 7.OUTPUT2 8.V+ -1- NJM2712 ■ ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL Supply Voltage V+ Differential Input Voltage VID Power Dissipation PD Operating Temperature Range Storage Temperature Range Topr Tstg RATINGS 10 ±2 300(DMP8) 320(MSOP8(TVSP8)) -40 to +85 -50 to +150 (Ta=25°C) UNIT V V mW °C °C ■RECOMMENDED OPERATING CONDITION PARAMETER Operating Voltage Range SYMBOL + V /V ( Ta=25°C) TEST CONDITION - MIN MAX ±2.0 ±2.5 ±4.5 UNIT V ( V+/V -=±2.5V, Ta=25°C) ■ DC CHARACTERISTICS PARAMETER TYP SYMBOL TEST CONDITION TYP MAX UNIT - 3.8 6.8 mA mV Operating Current ICC Input Offset Voltage Input Bias Current VIO IB - 2.0 2 7.0 7 Input Offset Current Open Loop Voltage Gain Input Common Mode Voltage Range Common Mode Rejection IIO Av 65 350 75 900 - µA nA dB ±1.3 ±1.5 - V Supply Voltage Rejection Maximum Output Voltage No Signal MIN RL=2kΩ VICM CMR +SVR -1V≤VCM≤+1V 2.5V≤V +≤5V, RL=2kΩ 50 50 60 60 - dB dB -SVR VOM -5V≤V -≤-2.5V, RL=2kΩ RL=1kΩ 50 ±1.2 60 ±1.5 - dB V ( V+/V -=±2.5V, Ta=25°C) ■ AC CHARACTERISTICS PARAMETER SYMBOL Bandwidth BW Unity Gain Bandwidth fT Phase Margin φM Equivalent Input Noise Voltage VNI TEST CONDITION Av=40dB,Rf=1.98kΩ ,RL=∞ CL=10pF Av=40dB,Rg=20Ω,Rf=1.98kΩ RL=∞,CL=10pF Av=40dB,Rg=20Ω,Rf=1.98kΩ RL=∞,CL=10pF MIN TYP MAX UNIT - 10 - MHz - 180 - MHz - 38 - deg - 6.8 - nV/√Hz ( V+/V -=±2.5V, Ta=25°C) ■ TRANSIENT CHARACTERISTICS PARAMETER Slew Rate -2- SYMBOL +SR -SR TEST CONDITION Av=6dB,Rf=1kΩ,Rg=1kΩ RL=∞,CL=10pF MIN TYP MAX UNIT - 260 260 - V/µs V/µs NJM2712 ■ Note: non-inverting amplifier 1.The closed gain should be 6dB or higher to prevent the oscillation. Unity gain follower application may cause the oscillation. 2.When the closed gain is lower than 20dB, use a compensation capacitor (CF: about 5pF), parallel with the feedback resistor RF to avoid oscillation. 3.Recommended feedback resistor is less than 2k-ohm to keep the flatness of the frequency response. 4.Minimize the load capacitor for the better performance. A large load capacitor CL reduces the frequency response and causes oscillation or ringing. inverting amplifier 1.When the closed gain is lower than 20dB, use a compensation capacitor (CF; recommended from 1pF to 5pF), parallel with the feedback resistor RF to avoid oscillation. 2.Minimize the feedback resistor to keep the frequency response and the slew rate. (recommended about 1k-ohm) The proper compensation capacitor CF can counteract oscillation even with a large feedback resistor RF. 3.Total load capacitance should be not more than 100pF. The oscillation margin may be affected by the total load capacitance. non-inverting amplifier DUT RF CL RL CL RL CF RG inverting amplifier CF RF RG DUT -3- NJM2712 ■ TYPICAL CHARACTERISTICS Operating Current vs. Operating Voltage Operating Current vs. Temperature VIN=0V, Ta=25ºC 6 5 Operating Current [mA] 5 Operating Current[mA] VIN=0V 6 4 3 2 1 V+/V-=±4.5V 4 V+/V-=±2.5V V+/V-=±2.0V 3 2 1 0 0 0 1 2 3 4 Operating Voltage [±V] 5 -50 Input Offset Voltage vs. Temperature 150 Input Offset Current vs. Temperature V+/V-=±2.5V 0.5 0 50 100 Ambient Temperature [ºC] V+/V-=±2.5V 800 Input Offset Current [nA] Input Offset Voltage [mV] 600 0 -0.5 -1 -1.5 400 200 0 -200 -400 -600 -2 -800 -50 0 50 100 Ambient Temperature [ºC] 150 -50 V+/V-=±2.5V Maximum Output Voltage Swing [V] Input Bias Current [uA] VIN=±300mV, RL=1kΩ, Ta=25ºC 5 -0.5 -1 -1.5 -2 -2.5 -3 -3.5 4 3 2 1 0 -1 -2 -3 -4 -5 -50 -4- 150 Maximum Output Voltage Swing vs. Operating Voltage Input Bias Current vs. Temperature 0 0 50 100 Ambient Temperature [ºC] 0 50 100 Ambient Temperature [ºC] 150 0 ±1 ±2 ±3 ±4 Operating Voltage V+/V- [V] ±5 NJM2712 Voltage Gain vs. Temperature Maximum Output Voltage Swing vs. Temperature V+/V-=±2.5V 80 1.5 70 1 0.5 0 -0.5 -1 60 50 40 30 20 -1.5 10 -2 0 -50 0 50 100 Ambient Temperature [ºC] 150 -50 Common Mode Rejection Ratio vs. Temperature V+Supply Voltage Rejection Ratio [dB] 60 50 40 30 20 10 0 0 50 100 Ambient Temperature [ºC] 150 V+Supply Voltage Rejection Ratio vs. Temperature V+/V-=±2.5V, -1V≤Vcm≤+1V 70 Common Mode Rejection Ratio [dB] V+/V-=±2.5V, RL=2kΩ 90 Voltage Gain [dB] Maximum Output Voltage Swing [V] 2 V-=-2.5V, +2.5V≤V+≤+5V, RL=2kΩ 80 70 60 50 40 30 20 10 0 -50 0 50 100 Ambient Temperature [ºC] 150 -50 0 50 100 Ambient Temperature [ºC] 150 V-Supply Voltage Rejection Ratio vs. Temperature V+=+2.5V, -5V≤V-≤-2.5V, RL=2kΩ V-Supply Voltage Rejection Ratio [dB] 100 90 80 70 60 50 40 30 20 10 0 -50 0 50 100 Ambient Temperature [ºC] 150 -5- NJM2712 Pulse Response Pulse Response (with capacitive load) V+/V-=±2.5V, f=5MHz, VO=2VPP, GV=6dB, RT=50Ω, RF=1kΩ, CF=5pF, RG=1kΩ, RL=2kΩ, CL=10pF, Ta=+25ºC V+/V-=±2.5V, f=5MHz, VO=2VPP, GV=6dB, RT=50Ω, RF=1kΩ, CF=5pF, RG=1kΩ, Ta=+25ºC 1.0 4.0 2.0 CL=10pF 2.0 -2.0 1.0 -3.0 0.0 -4.0 -1.0 Output Voltage [V] -1.0 -5.0 -2.0 0.0 2.0 0.0 0.1 0.1 0.1 0.1 0.1 Time [10ns/div] 0.2 1.0 0.0 CL=open -1.0 -2.0 0.2 0.0 0.1 0.1 0.1 0.1 0.1 0.2 Time 10ns/div 0.2 0.2 Pulse Response (correlation with RL) Pulse Response (correlation with Ta) V+/V-=±2.5V, f=5MHz, VO=2VPP, GV=6dB, RT=50Ω, RF=1kΩ, CF=5pF, RG=1kΩ, CL=10pF, Ta=+25ºC V+/V-=±2.5V, f=5MHz, VO=2VPP, GV=6dB, RT=50Ω, RF=1kΩ, CF=5pF, RG=1kΩ, CL=10pF, Ta=+25ºC RL=2kΩ 2.0 RL=open 1.0 Output Voltage [V] Output Voltage [V] CL=100pF 3.0 Output Voltage [V] Input Voltage [V] 0.0 RL=1kΩ 0.0 -1.0 1.0 0.0 Ta=-40ºC Ta=+85ºC -1.0 Ta=+25ºC -2.0 0.0 0.1 0.1 0.1 0.1 0.1 0.2 Time 10ns/div 0.2 0.2 0.0 0.1 0.1 0.1 0.2 Time [10ns/div] 0.2 0.2 Voltage Gain vs. Frequency Voltage Gain vs. Frequency (with Capacitive Load) V+/V-=±2.5V, VIN=0.02Vpp, GV=40dB, RT=50Ω, RF=1.98kΩ, RG=20Ω, CF=5pF, RL=2kΩ, Ta=+25ºC 225 30 50 180 40 135 30 20 90 10 45 0 0 Phase [deg] Gain Voltage Gain [dB] 40 Voltage Gain [dB] 0.1 V+/V-=±2.5V, VIN=0.02Vpp, GV=40dB, RT=50Ω, RF=1.98kΩ, RG=20Ω, CF=5pF, RL=2kΩ, CL=10pF, Ta=+25ºC 50 0 -90 -20 -135 -30 10M 100M Frequency [Hz] 90 CL=10pF 45 CL=open 0 Phase -10 -45 -90 CL=10pF -135 CL=100pF -180 1M 135 10 -20 -40 100k 180 Gain 20 -45 Phase 225 CL=open CL=100pF -10 -30 -6- 0.1 1G -40 100k -180 1M 10M 100M Frequency [Hz] 1G Phase [deg] -2.0 NJM2712 Voltage Gain vs. Frequency Voltage Gain vs. Frequency (correlation with Ta) (correlation with RL) V+/V-=±2.5V, VIN=0.02Vpp, GV=40dB, RT=50Ω, RF=1.98kΩ, RG=20Ω, CF=5pF, CL=10pF, Ta=+25ºC 135 30 RL=1kΩ 45 0 Phase -10 -45 RL=1kΩ -20 RL=2kΩ -30 -40 100k 1M 10M 100M Frequency [Hz] 0 Gain CL=50pF -30 -180 -40 100k 20 135 15 90 10 0 -45 CL=100pF -90 CL=50pF -30 -40 100k 180 45 Phase -20 1M 10M 100M Frequency [Hz] -45 -135 1G Voltage Gain [dB] CL=10pF -10 0 Ta=-40ºC -10 -20 Phase [deg] Voltage Gain [dB] 0 Phase -90 Ta=+25ºC -135 Ta=+85ºC -180 1M 10M 100M Frequency [Hz] 1G V+/V-=±2.5V, VIN=0.02Vpp, GV=6dB, RT=50Ω, RF=1kΩ, CF=5pF, RG=1kΩ, RL=open, Ta=+25ºC CL=100pF CL=10pF 45 Voltage Gain vs. Frequency (with Capacitive Load ) 40 10 90 10 (with Capacitive Load ) V+/V-=±2.5V, VIN=0.02Vpp, GV=20dB, RT=50Ω, RF=1kΩ, CF=5pF, RG=110Ω, RL=open, Ta=+25ºC 20 Ta=+85ºC 20 Voltage Gain vs. Frequency 30 135 Ta=+25ºC -90 1G 180 Gain Phase [deg] 40 90 10 0 180 5 180 CL=50pF CL=100pF 135 CL=10pF 90 CL=open Gain 0 -5 -10 -135 -15 -180 -20 100k 45 Phase 0 CL=100pF -45 CL=50pF Phase [deg] Voltage Gain [dB] 20 RL=open 225 Ta=-40ºC RL=2kΩ 30 50 Voltage Gain [dB] 40 225 RL=open Gain Phase [deg] 50 V+/V-=±2.5V, VIN=0.02Vpp, GV=40dB, RT=50Ω, RF=1.98kΩ, RG=20Ω, CF=5pF, RL=open, CL=10pF -90 CL=10pF -135 CL=open -180 1M 10M 100M Frequency [Hz] 1G -7- NJM2712 ■ MEASUREMENT CIRCUIT DUT RF CL RL CF RG [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. -8-
NJM2712RB1-TE1 价格&库存
很抱歉,暂时无法提供与“NJM2712RB1-TE1”相匹配的价格&库存,您可以联系我们找货
