P-2000 構造図
PRESSURE TRANSDUCERS
P-2000
INTERNAL STRUCTURE (BN type)
1
3
2
5
4
Part name
■ FEATURES
● Compact and light weight
● For non-corrosive gases
● Dual in line package
● Pressure range ~9.81, ~981 kPa {~0.1, ~10 kgf/cm2}
Material
1
Housing
2
Cover
3
Sensor chip
Silicone
4
Chip resistor (compensatory resistor)
Ceramic
5
Terminal pin
LCP (Liquid crystal polymer)
Aluminum
Phosphor bronze + Au-plated
■ MODEL NUMBER DESIGNATION
P-2000 - 501 G - 15 - BN
Series name
Terminal direction
AN:Same direction as the pressure port
BN:Opposite direction to the pressure port
Rated pressure range
101:0 ~ 9.81 kPa {0 ~ 0.1 kgf/cm }
501:0 ~ 49.0 kPa {0 ~ 0.5 kgf/cm2}
102:0 ~ 98.1 kPa {0 ~ 1 kgf/cm2}
352:0 ~ 343 kPa {0 ~ 3.5 kgf/cm2}
502:0 ~ 490 kPa {0 ~ 5 kgf/cm2}
702:0 ~ 686 kPa {0 ~ 7 kgf/cm2}
103:0 ~ 981 kPa {0 ~ 10 kgf/cm2}
2
Thermal error
15:± 0.15 % (± 0.12 %) F.S./°C
Pressure reference
G:Gauge
■ LIST OF MODEL NUMBERS
Terminal
direction
kPa {kgf/cm2}
0 ~ 9.81
{0 ~ 0.1}
0 ~ 49.0
{0 ~ 0.5}
0 ~ 98.1
{0 ~ 1}
0 ~ 343
{0 ~ 3.5}
0 ~ 490
{0 ~ 5}
0 ~ 686
{0 ~ 7}
0 ~ 981
{0 ~ 10}
AN
A P-2000-101G-15-AN A P-2000-501G-15-AN A P-2000-102G-15-AN A P-2000-352G-15-AN A P-2000-502G-15-AN A P-2000-702G-15-AN A P-2000-103G-15-AN
BN
P-2000-101G-15-BN P-2000-501G-15-BN P-2000-102G-15-BN P-2000-352G-15-BN P-2000-502G-15-BN P-2000-702G-15-BN P-2000-103G-15-BN
※ Verify the above model numbers when placing orders.
The AN version, marked A is manufactured upon receipt of order basis.
P-2000
■ STANDARD SPECIFICATIONS
● Unless otherwise specified, the specs are defined at an ambient temperature of 25±5 °C and excitation current of 1.5 mA DC.
Item
P-2000
Model number
101G 501G 102G 352G 502G 702G 103G
Gauge
Pressure reference
9.81 49.0 98.1 343 490 686 981
kPa {kgf/cm2}
{0.1} {0.5} {1.0} {3.5} {5} {7} {10.0}
19.6 98.1 196 686 981 1373 1471
kPa {kgf/cm2}
{0.2} {1.0} {2.0} {7.0} {10} {14} {15.0}
49.0 245 490 1030 1471 1961 1961
kPa {kgf/cm2}
{0.5} {2.5} {5} {10.5} {15} {20} {20}
Maximum pressure
General specifications
Break-down pressure
Operating temp. range
°C
− 20 ~ 80
Compensated temp. range
°C
0 ~ 50
Operating humidity
%RH
35 ~ 85(No condensation)
Storage temp.
°C
− 20 ~ 80(Atmospheric pressure, humidity 65 %RH maximum)
Bridge resistance
Ω
3300 ± 30 %
Non-corrosive gases
Pressure medium
Insulation resistance
MΩ
minimum
100 (500 V DC)
500 V AC, 60 s(Leakage current 1 mA maximum)
Dielectric strength
g
Power
Net weight
Analog output
φ 3.2
mm
Pressure port
Approx. 1
mA DC
Excitation current
1.5(Constant current)
Offset voltage
mV
Span voltage
mV 50 ± 20 90 ± 30
Linearity/Hysteresis
Thermal error
(Reference temp.: 25 °C)
Response
± 20
± 15
± 0.3
%F.S.
ZERO %F.S./°C
± 0.15
± 0.12
SPAN %F.S./°C
± 0.05
± 0.04
ms
Approx. 1
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Test conditions (At 25 ± 5 °C)
Permissible change
Vibration
10 ~ 500 Hz, 1.5 mm maximum/98.1 m/s ,
3 directions for 2 hours each
Shock
981 m/s2, 3 directions for 3 times each
Pressure cycling
0 ~ Rated pressure, 10 cycles
Moisture resistance
40 °C, 90 ~ 95 %RH, 240 hrs.
2
6
※ P-2000 series can be operated at the vacuum pressure.
Offset voltage/Span voltage:
±1 %F.S. maximum each
B 外形図
P-2000
A 外形図
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.3 (Unit: mm)
2.5
φ 3.2
7.3
5.2
3 ± 0.5
Vent hole
G
P-2000
PRESSURE
+0.1
12
COPAL JAPAN
2.5
0.5(t = 0.3)
R1
TRANSDUCER
4
Pressure port
φ 1.2
5
2
1
10
3
BN type
Pressure range marking
5.2
■ INTERNAL ELECTRICAL SCHEMATICS
4
1
R
5
2
3
Input
6
Output
R : Built-in chip resistor for
temp. compensation
7.3
4
6
5
2
1
2.5
φ 3.2
+0.1
3
Vent hole
G
P-2000
PRESSURE
TRANSDUCER
COPAL JAPAN
3.5 ± 0.5
2.5
0.5(t = 0.3)
AN type
Pressure port
φ 1.2
12
■ TERMINAL NUMBER
Pin
1
2
3
4
5
6
Connection
Output C
Input B
Input C
Output B
Input C
Input B
很抱歉,暂时无法提供与“P-2000-103G-15-BN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+145.34640
- 30+138.14280
