MC68HC908SR12
MC68HC08SR12
Technical Data
M68HC08
Microcontrollers
MC68HC908SR12/D
Rev. 4, 2/2002
WWW.MOTOROLA.COM/SEMICONDUCTORS
MC68HC908SR12
MC68HC08SR12
Technical Data
Motorola reserves the right to make changes without further notice to any products
herein. Motorola makes no warranty, representation or guarantee regarding the
suitability of its products for any particular purpose, nor does Motorola assume any
liability arising out of the application or use of any product or circuit, and specifically
disclaims any and all liability, including without limitation consequential or incidental
damages. “Typical” parameters which may be provided in Motorola data sheets and/or
specifications can and do vary in different applications and actual performance may
vary over time. All operating parameters, including “Typicals” must be validated for
each customer application by customer's technical experts. Motorola does not convey
any license under its patent rights nor the rights of others. Motorola products are not
designed, intended, or authorized for use as components in systems intended for
surgical implant into the body, or other applications intended to support or sustain life,
or for any other application in which the failure of the Motorola product could create a
situation where personal injury or death may occur. Should Buyer purchase or use
Motorola products for any such unintended or unauthorized application, Buyer shall
indemnify and hold Motorola and its officers, employees, subsidiaries, affiliates, and
distributors harmless against all claims, costs, damages, and expenses, and
reasonable attorney fees arising out of, directly or indirectly, any claim of personal
injury or death associated with such unintended or unauthorized use, even if such claim
alleges that Motorola was negligent regarding the design or manufacture of the part.
Motorola, Inc. is an Equal Opportunity/Affirmative Action Employer.
Motorola and the Stylized M logo are registered in the U.S. Patent and Trademark Office.
digital dna is a trademark of Motorola, Inc.
MC68HC908SR12•MC68HC08SR12 — Rev. 4.0
MOTOROLA
© Motorola, Inc., 2002
Technical Data
Technical Data
3
Technical Data
To provide the most up-to-date information, the revision of our
documents on the World Wide Web will be the most current. Your printed
copy may be an earlier revision. To verify you have the latest information
available, refer to:
http://www.motorola.com/semiconductors/
The following revision history table summarizes changes contained in
this document. For your convenience, the page number designators
have been linked to the appropriate location.
Revision History
Date
Revision
Level
Description
PTB0/SDA0, PTB1/SCL0, PTB2/SDA1/TxD, and
PTB3/SCL1/RxD pins — clarified these open-drain pins
throughout this document.
February,
2002
4
323, 254, 293
8.4.6 Programming the PLL — deleted redundant step in
programming the PLL.
120
Figure 10-1 . Monitor Mode Circuit — corrected connections
for PTA1 and PTA2.
167
Table 10-1 . Monitor Mode Signal Requirements and Options
— clarified clock input requirements for monitor mode entry.
169
Section 11. Timer Interface Module (TIM) — timer
discrepancies corrected throughout this section.
181
18.5.1 Port C Data Register (PTC) and 18.5.2 Data Direction
Register C (DDRC) — added notes for PTC6 and PTC7 on
42-pin package.
327, 329
Figure 19-3 . IRQ2 Block Diagram and 19.5 IRQ1 and IRQ2
Pins — corrected IRQ2 for BIH and BIL instructions.
338, 339
Table 24-4 . 5V DC Electrical Characteristics and Table 24-5 .
3V DC Electrical Characteristics — added additional IDD
measurements.
374, 376
Table 24-13 . Current Detection Electrical Characteristics —
updated trip point values.
382
Appendix A. MC68HC08SR12 — added appendix for ROM part:
MC68HC08SR12.
393
Technical Data
4
Page
Number(s)
Technical Data
MOTOROLA
Technical Data — MC68HC908SR12•MC68HC08SR12
List of Sections
Section 1. General Description . . . . . . . . . . . . . . . . . . . . 35
Section 2. Memory Map . . . . . . . . . . . . . . . . . . . . . . . . . . 45
Section 3. Random-Access Memory (RAM) . . . . . . . . . . 61
Section 4. FLASH Memory . . . . . . . . . . . . . . . . . . . . . . . . 63
Section 5. Configuration and Mask Option Registers
(CONFIG & MOR). . . . . . . . . . . . . . . . . . . . . . 73
Section 6. Central Processor Unit (CPU) . . . . . . . . . . . . 81
Section 7. Oscillator (OSC) . . . . . . . . . . . . . . . . . . . . . . 101
Section 8. Clock Generator Module (CGM) . . . . . . . . . . 111
Section 9. System Integration Module (SIM) . . . . . . . . 141
Section 10. Monitor ROM (MON) . . . . . . . . . . . . . . . . . . 165
Section 11. Timer Interface Module (TIM) . . . . . . . . . . . 181
Section 12. Timebase Module (TBM) . . . . . . . . . . . . . . . 205
Section 13. Pulse Width Modulator (PWM) . . . . . . . . . . 211
Section 14. Analog Module . . . . . . . . . . . . . . . . . . . . . . 221
Section 15. Analog-to-Digital Converter (ADC) . . . . . . 231
Section 16. Serial Communications Interface (SCI) . . . 251
Section 17. Multi-Master IIC Interface (MMIIC) . . . . . . . 291
Section 18. Input/Output (I/O) Ports . . . . . . . . . . . . . . . 317
Section 19. External Interrupt (IRQ) . . . . . . . . . . . . . . . 335
MOTOROLA
Technical Data
List of Sections
5
List of Sections
Section 20. Keyboard Interrupt Module (KBI). . . . . . . . 343
Section 21. Computer Operating Properly (COP) . . . . 351
Section 22. Low-Voltage Inhibit (LVI) . . . . . . . . . . . . . . 357
Section 23. Break Module (BRK) . . . . . . . . . . . . . . . . . . 363
Section 24. Electrical Specifications. . . . . . . . . . . . . . . 371
Section 25. Mechanical Specifications . . . . . . . . . . . . . 387
Section 26. Ordering Information . . . . . . . . . . . . . . . . . 391
Appendix A. MC68HC08SR12 . . . . . . . . . . . . . . . . . . . . 393
Technical Data
6
List of Sections
MOTOROLA
Table of Contents
1.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35
1.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 36
1.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 36
1.4
MCU Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 38
1.5
Pin Assignments . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 40
1.6
Pin Functions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 41
1.6.1
Power Supply Pins (VDD and VSS) . . . . . . . . . . . . . . . . . . . . 42
1.6.2
Oscillator Pins (OSC1 and OSC2) . . . . . . . . . . . . . . . . . . . . 42
1.6.3
External Reset Pin (RST) . . . . . . . . . . . . . . . . . . . . . . . . . . . 43
1.6.4
External Interrupt Pin (IRQ1) . . . . . . . . . . . . . . . . . . . . . . . . 43
1.6.5
Analog Power Supply Pin (VDDA) . . . . . . . . . . . . . . . . . . . . . 43
1.6.6
Analog Ground Pin (VSSA) . . . . . . . . . . . . . . . . . . . . . . . . . . 43
1.6.7
ADC Voltage Low Reference Pin (VREFL) . . . . . . . . . . . . . . 43
1.6.8
ADC Voltage High Reference Pin (VREFH). . . . . . . . . . . . . . 43
1.6.9
External Filter Capacitor Pin (CGMXFC) . . . . . . . . . . . . . . . 43
1.6.10 Analog Input Pins (OPIN1/ATD0, OPIN2/ATD1, VSSAM) . . . 44
1.6.11 Port A Input/Output (I/O) Pins (PTA7–PTA0) . . . . . . . . . . . . 44
1.6.12 Port B I/O Pins (PTB6–PTB0) . . . . . . . . . . . . . . . . . . . . . . . 44
1.6.13 Port C I/O Pins (PTC7–PTC0) . . . . . . . . . . . . . . . . . . . . . . . 44
1.6.14 Port D I/O Pins (PTD7/KBI7–PTD0/KBI0) . . . . . . . . . . . . . . 44
2.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 45
2.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 45
2.3
Unimplemented Memory Locations . . . . . . . . . . . . . . . . . . . . . 45
MOTOROLA
Table of Contents
Technical Data
7
Table of Contents
2.4
Reserved Memory Locations . . . . . . . . . . . . . . . . . . . . . . . . . . 46
2.5
Input/Output (I/O) Section. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 46
3.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 61
3.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 61
3.3
Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 61
4.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 63
4.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 63
4.3
Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 64
4.4
FLASH Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .65
4.5
FLASH Page Erase Operation . . . . . . . . . . . . . . . . . . . . . . . . . 66
4.6
FLASH Mass Erase Operation . . . . . . . . . . . . . . . . . . . . . . . . . 67
4.7
FLASH Program Operation. . . . . . . . . . . . . . . . . . . . . . . . . . . . 68
4.8
FLASH Protection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 70
4.8.1
FLASH Block Protect Register . . . . . . . . . . . . . . . . . . . . . . .70
(CONFIG & MOR)
Technical Data
8
5.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 73
5.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 73
5.3
Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 74
5.4
Configuration Register 1 (CONFIG1) . . . . . . . . . . . . . . . . . . . .75
5.5
Configuration Register 2 (CONFIG2) . . . . . . . . . . . . . . . . . . . .77
5.6
Mask Option Register (MOR) . . . . . . . . . . . . . . . . . . . . . . . . . . 79
Table of Contents
MOTOROLA
Table of Contents
6.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 81
6.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 81
6.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 82
6.4
CPU Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 82
6.4.1
Accumulator . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .83
6.4.2
Index Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 84
6.4.3
Stack Pointer . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 84
6.4.4
Program Counter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 85
6.4.5
Condition Code Register . . . . . . . . . . . . . . . . . . . . . . . . . . .85
6.5
Arithmetic/Logic Unit (ALU) . . . . . . . . . . . . . . . . . . . . . . . . . . .88
6.6
Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .88
6.6.1
Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 88
6.6.2
Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 89
6.7
CPU During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . 89
6.8
Instruction Set Summary
6.9
Opcode Map . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 89
7.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 101
7.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 102
7.3
Clock Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .103
7.3.1
CGM Reference Clock Selection . . . . . . . . . . . . . . . . . . . . 104
7.3.2
TBM Reference Clock Selection . . . . . . . . . . . . . . . . . . . . 105
7.4
Internal Oscillator . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 105
7.5
RC Oscillator. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 106
7.6
X-tal Oscillator . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 107
7.7
I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 108
7.7.1
Crystal Amplifier Input Pin (OSC1). . . . . . . . . . . . . . . . . . . 108
7.7.2
Crystal Amplifier Output Pin (OSC2) . . . . . . . . . . . . . . . . . 109
MOTOROLA
Table of Contents
Technical Data
9
Table of Contents
7.7.3
7.7.4
7.7.5
7.7.6
Oscillator Enable Signal (SIMOSCEN). . . . . . . . . . . . . . . . 109
CGM Oscillator Clock (CGMXCLK) . . . . . . . . . . . . . . . . . . 109
CGM Reference Clock (CGMRCLK) . . . . . . . . . . . . . . . . . 109
Oscillator Clock to Time Base Module (OSCCLK) . . . . . . . 109
7.8
Low Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .109
7.8.1
Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 110
7.8.2
Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 110
7.9
Oscillator During Break Mode. . . . . . . . . . . . . . . . . . . . . . . . . 110
8.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 111
8.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 112
8.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 113
8.4
Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 113
8.4.1
Oscillator Module . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 116
8.4.2
Phase-Locked Loop Circuit (PLL) . . . . . . . . . . . . . . . . . . .116
8.4.3
PLL Circuits . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 116
8.4.4
Acquisition and Tracking Modes . . . . . . . . . . . . . . . . . . . . 118
8.4.5
Manual and Automatic PLL Bandwidth Modes. . . . . . . . . . 118
8.4.6
Programming the PLL . . . . . . . . . . . . . . . . . . . . . . . . . . . . 120
8.4.7
Special Programming Exceptions . . . . . . . . . . . . . . . . . . .124
8.4.8
Base Clock Selector Circuit . . . . . . . . . . . . . . . . . . . . . . . . 124
8.4.9
CGM External Connections . . . . . . . . . . . . . . . . . . . . . . . . 125
8.5
I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 125
8.5.1
External Filter Capacitor Pin (CGMXFC) . . . . . . . . . . . . . . 126
8.5.2
PLL Analog Power Pin (VDDA) . . . . . . . . . . . . . . . . . . . . . . 126
8.5.3
PLL Analog Ground Pin (VSSA) . . . . . . . . . . . . . . . . . . . . . 126
8.5.4
Oscillator Output Frequency Signal (CGMXCLK) . . . . . . . 126
8.5.5
CGM Reference Clock (CGMRCLK) . . . . . . . . . . . . . . . . . 126
8.5.6
CGM VCO Clock Output (CGMVCLK) . . . . . . . . . . . . . . . . 127
8.5.7
CGM Base Clock Output (CGMOUT). . . . . . . . . . . . . . . . . 127
8.5.8
CGM CPU Interrupt (CGMINT) . . . . . . . . . . . . . . . . . . . . . 127
8.6
CGM Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .127
8.6.1
PLL Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 128
Technical Data
10
Table of Contents
MOTOROLA
Table of Contents
8.6.2
8.6.3
8.6.4
8.6.5
8.7
PLL Bandwidth Control Register . . . . . . . . . . . . . . . . . . . . 130
PLL Multiplier Select Registers . . . . . . . . . . . . . . . . . . . . . 132
PLL VCO Range Select Register . . . . . . . . . . . . . . . . . . . . 133
PLL Reference Divider Select Register . . . . . . . . . . . . . . . 134
Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 135
8.8
Special Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 135
8.8.1
Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 135
8.8.2
Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 136
8.8.3
CGM During Break Interrupts. . . . . . . . . . . . . . . . . . . . . . . 136
8.9
Acquisition/Lock Time Specifications . . . . . . . . . . . . . . . . . . .137
8.9.1
Acquisition/Lock Time Definitions. . . . . . . . . . . . . . . . . . . . 137
8.9.2
Parametric Influences on Reaction Time . . . . . . . . . . . . . . 137
8.9.3
Choosing a Filter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 139
9.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 141
9.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 142
9.3
SIM Bus Clock Control and Generation . . . . . . . . . . . . . . . . . 144
9.3.1
Bus Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 145
9.3.2
Clock Start-up from POR or LVI Reset. . . . . . . . . . . . . . . . 145
9.3.3
Clocks in Stop Mode and Wait Mode . . . . . . . . . . . . . . . . . 146
9.4
Reset and System Initialization. . . . . . . . . . . . . . . . . . . . . . . . 146
9.4.1
External Pin Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 147
9.4.2
Active Resets from Internal Sources . . . . . . . . . . . . . . . . . 147
9.4.2.1
Power-On Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 148
9.4.2.2
Computer Operating Properly (COP) Reset. . . . . . . . . . 149
9.4.2.3
Illegal Opcode Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . 150
9.4.2.4
Illegal Address Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . 150
9.4.2.5
Low-Voltage Inhibit (LVI) Reset . . . . . . . . . . . . . . . . . . . 150
9.4.2.6
Monitor Mode Entry Module Reset. . . . . . . . . . . . . . . . . 150
9.5
SIM Counter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 151
9.5.1
SIM Counter During Power-On Reset . . . . . . . . . . . . . . . . 151
9.5.2
SIM Counter During Stop Mode Recovery . . . . . . . . . . . . . 151
9.5.3
SIM Counter and Reset States. . . . . . . . . . . . . . . . . . . . . .151
MOTOROLA
Table of Contents
Technical Data
11
Table of Contents
9.6
Exception Control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 152
9.6.1
Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 152
9.6.1.1
Hardware Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . 154
9.6.1.2
SWI Instruction. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 155
9.6.1.3
Interrupt Status Registers . . . . . . . . . . . . . . . . . . . . . . . 155
9.6.1.4
Interrupt Status Register 1 . . . . . . . . . . . . . . . . . . . . . . . 155
9.6.1.5
Interrupt Status Register 2 . . . . . . . . . . . . . . . . . . . . . . . 157
9.6.1.6
Interrupt Status Register 3 . . . . . . . . . . . . . . . . . . . . . . . 157
9.6.2
Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 158
9.6.3
Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .158
9.6.4
Status Flag Protection in Break Mode . . . . . . . . . . . . . . . . 158
9.7
Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .159
9.7.1
Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 159
9.7.2
Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 160
9.8
SIM Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 161
9.8.1
SIM Break Status Register . . . . . . . . . . . . . . . . . . . . . . . . . 162
9.8.2
SIM Reset Status Register . . . . . . . . . . . . . . . . . . . . . . . . 163
9.8.3
SIM Break Flag Control Register . . . . . . . . . . . . . . . . . . . . 164
10.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 165
10.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 165
10.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 166
10.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 166
10.4.1 Entering Monitor Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . 168
10.4.2 Data Format . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .172
10.4.3 Break Signal . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .172
10.4.4 Baud Rate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 173
10.4.5 Commands . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 173
10.5
Technical Data
12
Security. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 178
Table of Contents
MOTOROLA
Table of Contents
11.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 181
11.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 182
11.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 182
11.4
Pin Name Conventions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 183
11.5 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 183
11.5.1 TIM Counter Prescaler . . . . . . . . . . . . . . . . . . . . . . . . . . . . 187
11.5.2 Input Capture . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 187
11.5.3 Output Compare. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 188
11.5.3.1
Unbuffered Output Compare . . . . . . . . . . . . . . . . . . . . . 188
11.5.3.2
Buffered Output Compare . . . . . . . . . . . . . . . . . . . . . . . 189
11.5.4 Pulse Width Modulation (PWM) . . . . . . . . . . . . . . . . . . . . . 189
11.5.4.1
Unbuffered PWM Signal Generation . . . . . . . . . . . . . . . 190
11.5.4.2
Buffered PWM Signal Generation . . . . . . . . . . . . . . . . . 191
11.5.4.3
PWM Initialization . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 192
11.6
Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 193
11.7 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .193
11.7.1 Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 194
11.7.2 Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 194
11.8
TIM During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . 194
11.9
I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 195
11.10 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 195
11.10.1 TIM Status and Control Register . . . . . . . . . . . . . . . . . . . . 196
11.10.2 TIM Counter Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 198
11.10.3 TIM Counter Modulo Registers . . . . . . . . . . . . . . . . . . . . . 199
11.10.4 TIM Channel Status and Control Registers . . . . . . . . . . . .200
11.10.5 TIM Channel Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . 203
12.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 205
12.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 205
MOTOROLA
Table of Contents
Technical Data
13
Table of Contents
12.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 205
12.4
Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 206
12.5
Timebase Register Description. . . . . . . . . . . . . . . . . . . . . . . . 207
12.6
Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 208
12.7 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .209
12.7.1 Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 209
12.7.2 Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 209
13.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 211
13.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 211
13.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 212
13.4
PWM Period and Resolution. . . . . . . . . . . . . . . . . . . . . . . . . . 214
13.5
PWM Automatic Phase Control . . . . . . . . . . . . . . . . . . . . . . . 215
13.6
Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .216
13.7
Wait Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 216
13.8
Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 216
13.9
I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 217
13.10 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 217
13.10.1 PWM Control Register (PWMCR) . . . . . . . . . . . . . . . . . . .217
13.10.2 PWM Clock Control Register (PWMCCR) . . . . . . . . . . . . . 218
13.10.3 PWM Data Registers (PWMDR0–PWMDR2) . . . . . . . . . . 219
13.10.4 PWM Phase Control Register . . . . . . . . . . . . . . . . . . . . . . 220
Technical Data
14
14.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 221
14.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 221
14.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 222
14.4
Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 223
Table of Contents
MOTOROLA
Table of Contents
14.4.1
14.4.2
14.4.3
14.4.4
14.4.5
14.5
On-Chip Temperature Sensor . . . . . . . . . . . . . . . . . . . . . . 223
Two-Stage Amplifier . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 224
Amplifier Response Time . . . . . . . . . . . . . . . . . . . . . . . . . . 224
Current Flow Detection Amplifier . . . . . . . . . . . . . . . . . . . . 225
Current Flow Detect Output . . . . . . . . . . . . . . . . . . . . . . . . 225
Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 225
14.6 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .225
14.6.1 Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 225
14.6.2 Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 225
14.7 Analog Module I/O Registers . . . . . . . . . . . . . . . . . . . . . . . . . 226
14.7.1 Analog Module Control Register (AMCR) . . . . . . . . . . . . . 226
14.7.2 Analog Module Gain Control Register (AMGCR) . . . . . . . .227
14.7.3 Analog Module Status and Control Register (AMSCR) . . . 228
15.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 231
15.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 232
15.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 232
15.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 234
15.4.1 ADC Port I/O Pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 234
15.4.2 Voltage Conversion . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 235
15.4.3 Conversion Time . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 236
15.4.4 Continuous Conversion . . . . . . . . . . . . . . . . . . . . . . . . . . . 237
15.4.5 Auto-scan Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 237
15.4.6 Result Justification . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 238
15.4.7 Data Register Interlocking . . . . . . . . . . . . . . . . . . . . . . . . . 239
15.4.8 Monotonicity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .239
15.5
Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 239
15.6 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .239
15.6.1 Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 239
15.6.2 Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 240
15.7 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 240
15.7.1 ADC Voltage In (VADIN) . . . . . . . . . . . . . . . . . . . . . . . . . . . 240
MOTOROLA
Table of Contents
Technical Data
15
Table of Contents
15.7.2
15.7.3
15.7.4
15.7.5
ADC Analog Power Pin (VDDA) . . . . . . . . . . . . . . . . . . . . . 240
ADC Analog Ground Pin (VSSA). . . . . . . . . . . . . . . . . . . . . 240
ADC Voltage Reference High Pin (VREFH). . . . . . . . . . . . . 241
ADC Voltage Reference Low Pin (VREFL) . . . . . . . . . . . . . 241
15.8 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 241
15.8.1 ADC Status and Control Register. . . . . . . . . . . . . . . . . . . . 242
15.8.2 ADC Clock Control Register. . . . . . . . . . . . . . . . . . . . . . . . 244
15.8.3 ADC Data Register 0 (ADRH0 and ADRL0). . . . . . . . . . . . 246
15.8.4 ADC Auto-Scan Mode Data Registers (ADRL1–ADRL3). . 248
15.8.5 ADC Auto-Scan Control Register (ADASCR). . . . . . . . . . . 248
16.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 251
16.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 252
16.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 252
16.4
Pin Name Conventions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 254
16.5 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 254
16.5.1 Data Format . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .257
16.5.2 Transmitter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 257
16.5.2.1
Character Length . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 259
16.5.2.2
Character Transmission . . . . . . . . . . . . . . . . . . . . . . . . . 259
16.5.2.3
Break Characters . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 260
16.5.2.4
Idle Characters. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 260
16.5.2.5
Inversion of Transmitted Output. . . . . . . . . . . . . . . . . . . 261
16.5.2.6
Transmitter Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . 261
16.5.3 Receiver . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 262
16.5.3.1
Character Length . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 262
16.5.3.2
Character Reception . . . . . . . . . . . . . . . . . . . . . . . . . . . 262
16.5.3.3
Data Sampling . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 264
16.5.3.4
Framing Errors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 266
16.5.3.5
Baud Rate Tolerance . . . . . . . . . . . . . . . . . . . . . . . . . . . 266
16.5.3.6
Receiver Wakeup. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 269
16.5.3.7
Receiver Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . .270
16.5.3.8
Error Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 270
Technical Data
16
Table of Contents
MOTOROLA
Table of Contents
16.6 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .271
16.6.1 Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 271
16.6.2 Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 271
16.7
SCI During Break Module Interrupts. . . . . . . . . . . . . . . . . . . . 272
16.8 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 272
16.8.1 TxD (Transmit Data). . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 272
16.8.2 RxD (Receive Data) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 273
16.9 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 273
16.9.1 SCI Control Register 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . 273
16.9.2 SCI Control Register 2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . 276
16.9.3 SCI Control Register 3 . . . . . . . . . . . . . . . . . . . . . . . . . . . 279
16.9.4 SCI Status Register 1. . . . . . . . . . . . . . . . . . . . . . . . . . . . .282
16.9.5 SCI Status Register 2. . . . . . . . . . . . . . . . . . . . . . . . . . . . .286
16.9.6 SCI Data Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 287
16.9.7 SCI Baud Rate Register . . . . . . . . . . . . . . . . . . . . . . . . . . . 288
17.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 291
17.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 292
17.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 293
17.4
I/O Pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 293
17.5
Multi-Master IIC System Configuration . . . . . . . . . . . . . . . . . . 295
17.6 Multi-Master IIC Bus Protocol . . . . . . . . . . . . . . . . . . . . . . . . . 295
17.6.1 START Signal. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 296
17.6.2 Slave Address Transmission . . . . . . . . . . . . . . . . . . . . . . . 296
17.6.3 Data Transfer . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 296
17.6.4 Repeated START Signal . . . . . . . . . . . . . . . . . . . . . . . . . .297
17.6.5 STOP Signal. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .297
17.6.6 Arbitration Procedure . . . . . . . . . . . . . . . . . . . . . . . . . . . . .297
17.6.7 Clock Synchronization . . . . . . . . . . . . . . . . . . . . . . . . . . . . 298
17.6.8 Handshaking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 298
17.6.9 Packet Error Code . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 299
17.7
MMIIC I/O Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 299
MOTOROLA
Table of Contents
Technical Data
17
Table of Contents
17.7.1
17.7.2
17.7.3
17.7.4
17.7.5
17.7.6
17.7.7
17.7.8
MMIIC Address Register (MMADR) . . . . . . . . . . . . . . . . . . 299
MMIIC Control Register 1 (MMCR1) . . . . . . . . . . . . . . . . . 301
MMIIC Control Register 2 (MMCR2) . . . . . . . . . . . . . . . . . 303
MMIIC Status Register (MMSR). . . . . . . . . . . . . . . . . . . . . 305
MMIIC Data Transmit Register (MMDTR) . . . . . . . . . . . . . 307
MMIIC Data Receive Register (MMDRR). . . . . . . . . . . . . . 308
MMIIC CRC Data Register (MMCRCDR). . . . . . . . . . . . . . 309
MMIIC Frequency Divider Register (MMFDR) . . . . . . . . . . 310
17.8 Program Algorithm. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 311
17.8.1 Data Sequence. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 312
17.9 SMBus Protocols with PEC and without PEC. . . . . . . . . . . . . 313
17.9.1 Quick Command. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 313
17.9.2 Send Byte. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 313
17.9.3 Receive Byte . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 313
17.9.4 Write Byte/Word . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 314
17.9.5 Read Byte/Word . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 314
17.9.6 Process Call . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .315
17.9.7 Block Read/Write . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 315
17.10 SMBus Protocol Implementation . . . . . . . . . . . . . . . . . . . . . . 316
18.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 317
18.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 317
18.3 Port A . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 320
18.3.1 Port A Data Register (PTA) . . . . . . . . . . . . . . . . . . . . . . . . 320
18.3.2 Data Direction Register A (DDRA) . . . . . . . . . . . . . . . . . . . 321
18.3.3 Port A LED Control Register (LEDA) . . . . . . . . . . . . . . . . . 323
18.4 Port B . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 323
18.4.1 Port B Data Register (PTB) . . . . . . . . . . . . . . . . . . . . . . . . 324
18.4.2 Data Direction Register B (DDRB) . . . . . . . . . . . . . . . . . . . 325
18.5 Port C . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 327
18.5.1 Port C Data Register (PTC) . . . . . . . . . . . . . . . . . . . . . . . . 327
18.5.2 Data Direction Register C (DDRC). . . . . . . . . . . . . . . . . . . 329
18.5.3 Port C LED Control Register (LEDC) . . . . . . . . . . . . . . . . . 330
Technical Data
18
Table of Contents
MOTOROLA
Table of Contents
18.6 Port D . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 331
18.6.1 Port D Data Register (PTD) . . . . . . . . . . . . . . . . . . . . . . . . 331
18.6.2 Data Direction Register D (DDRD). . . . . . . . . . . . . . . . . . . 332
19.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 335
19.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 335
19.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 335
19.4
Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 336
19.5
IRQ1 and IRQ2 Pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 338
19.6
IRQ Module During Break Interrupts . . . . . . . . . . . . . . . . . . .339
19.7 IRQ Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 340
19.7.1 IRQ1 Status and Control Register . . . . . . . . . . . . . . . . . . .340
19.7.2 IRQ2 Status and Control Register . . . . . . . . . . . . . . . . . . .341
20.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 343
20.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 343
20.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 344
20.4
I/O Pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 344
20.5 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 345
20.5.1 Keyboard Initialization . . . . . . . . . . . . . . . . . . . . . . . . . . . . 347
20.6 Keyboard Interrupt Registers . . . . . . . . . . . . . . . . . . . . . . . . . 347
20.6.1 Keyboard Status and Control Register. . . . . . . . . . . . . . . . 348
20.6.2 Keyboard Interrupt Enable Register . . . . . . . . . . . . . . . . . . 349
20.7
Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .349
20.8
Wait Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 349
20.9
Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 349
20.10 Keyboard Module During Break Interrupts . . . . . . . . . . . . . . .350
MOTOROLA
Table of Contents
Technical Data
19
Table of Contents
21.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 351
21.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 351
21.3
Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 352
21.4 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 353
21.4.1 ICLK . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 353
21.4.2 STOP Instruction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 353
21.4.3 COPCTL Write . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 353
21.4.4 Power-On Reset. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 353
21.4.5 Internal Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 354
21.4.6 Reset Vector Fetch. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 354
21.4.7 COPD (COP Disable). . . . . . . . . . . . . . . . . . . . . . . . . . . . .354
21.4.8 COPRS (COP Rate Select) . . . . . . . . . . . . . . . . . . . . . . . . 354
21.5
COP Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 355
21.6
Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 355
21.7
Monitor Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 355
21.8 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .355
21.8.1 Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 356
21.8.2 Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 356
21.9
COP Module During Break Mode . . . . . . . . . . . . . . . . . . . . . .356
22.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 357
22.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 357
22.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 357
22.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 358
22.4.1 Polled LVI Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 359
22.4.2 Forced Reset Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . 360
22.4.3 Voltage Hysteresis Protection . . . . . . . . . . . . . . . . . . . . . . 360
22.4.4 LVI Trip Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 360
22.5
Technical Data
LVI Status Register. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 361
Table of Contents
MOTOROLA
Table of Contents
22.6
LVI Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 361
22.7 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .361
22.7.1 Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 362
22.7.2 Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 362
23.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 363
23.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 363
23.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 364
23.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 364
23.4.1 Flag Protection During Break Interrupts . . . . . . . . . . . . . . .366
23.4.2 CPU During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . 366
23.4.3 TIM1 and TIM2 During Break Interrupts. . . . . . . . . . . . . . .366
23.4.4 COP During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . 366
23.5 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .366
23.5.1 Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 366
23.5.2 Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 367
23.6 Break Module Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . .367
23.6.1 Break Status and Control Register. . . . . . . . . . . . . . . . . . . 367
23.6.2 Break Address Registers . . . . . . . . . . . . . . . . . . . . . . . . . .368
23.6.3 SIM Break Status Register . . . . . . . . . . . . . . . . . . . . . . . . . 368
23.6.4 SIM Break Flag Control Register . . . . . . . . . . . . . . . . . . . . 370
24.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 371
24.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 372
24.3
Absolute Maximum Ratings . . . . . . . . . . . . . . . . . . . . . . . . . .372
24.4
Functional Operating Range. . . . . . . . . . . . . . . . . . . . . . . . . . 373
24.5
Thermal Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 373
24.6
5.0V DC Electrical Characteristics . . . . . . . . . . . . . . . . . . . . . 374
24.7
3.0V DC Electrical Characteristics . . . . . . . . . . . . . . . . . . . . . 376
MOTOROLA
Table of Contents
Technical Data
21
Table of Contents
24.8
5.0V Control Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 377
24.9
3.0V Control Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 377
24.10 5.0V Oscillator Characteristics . . . . . . . . . . . . . . . . . . . . . . . . 378
24.11 3.0V Oscillator Characteristics . . . . . . . . . . . . . . . . . . . . . . . . 379
24.12 5.0V ADC Electrical Characteristics . . . . . . . . . . . . . . . . . . . . 380
24.13 3.0V ADC Electrical Characteristics . . . . . . . . . . . . . . . . . . . . 381
24.14 Analog Module Electrical Characteristics . . . . . . . . . . . . . . . . 382
24.14.1 Temperature Sensor Electrical Characteristics . . . . . . . . . 382
24.14.2 Current Detection Electrical Characteristics. . . . . . . . . . . . 382
24.14.3 Two-Stage Amplifier Electrical Characteristics. . . . . . . . . . 382
24.15 Timer Interface Module Characteristics . . . . . . . . . . . . . . . . . 383
24.16 MMIIC Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 383
24.17 CGM Electrical Specifications. . . . . . . . . . . . . . . . . . . . . . . . . 385
24.18 FLASH Memory Characteristics . . . . . . . . . . . . . . . . . . . . . . . 386
25.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 387
25.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 387
25.3
48-Pin Plastic Low Quad Flat Pack (LQFP) . . . . . . . . . . . . . . 388
25.4
42-Pin Shrink Dual In-Line Package (SDIP) . . . . . . . . . . . . . . 389
Technical Data
22
26.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 391
26.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 391
26.3
MC Order Numbers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 391
Table of Contents
MOTOROLA
Table of Contents
A.1
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 393
A.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 394
A.3
MCU Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 394
A.4
Memory Map. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 394
A.5
Mask Option Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 397
A.6
Reserved Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 397
A.7
Monitor ROM . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 397
A.8
Electrical Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 397
A.8.1
Memory Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . 397
A.9
ROM Order Numbers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 398
MOTOROLA
Table of Contents
Technical Data
23
Table of Contents
Technical Data
24
Table of Contents
MOTOROLA
List of Figures
Figure
Title
1-1
1-2
1-3
1-4
MC68HC908SR12 Block Diagram . . . . . . . . . . . . . . . . . . . . . . 39
48-Pin LQFP Pin Assignments . . . . . . . . . . . . . . . . . . . . . . . . . 40
42-Pin SDIP Pin Assignment . . . . . . . . . . . . . . . . . . . . . . . . . . 41
Power Supply Bypassing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 42
2-1
2-2
Memory Map. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 47
Control, Status, and Data Registers . . . . . . . . . . . . . . . . . . . . . 48
4-1
4-2
4-3
4-4
4-5
FLASH I/O Register Summary . . . . . . . . . . . . . . . . . . . . . . . . . 64
FLASH Control Register (FLCR) . . . . . . . . . . . . . . . . . . . . . . . 65
FLASH Programming Flowchart . . . . . . . . . . . . . . . . . . . . . . . . 69
FLASH Block Protect Register (FLBPR). . . . . . . . . . . . . . . . . . 70
FLASH Block Protect Start Address . . . . . . . . . . . . . . . . . . . . . 70
5-1
5-2
5-3
5-4
CONFIG and MOR Register Summary. . . . . . . . . . . . . . . . . . . 74
6-1
6-2
6-3
6-4
6-5
6-6
CPU Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 83
Accumulator (A) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 83
Index Register (H:X) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 84
Stack Pointer (SP) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .85
Program Counter (PC) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 85
Condition Code Register (CCR) . . . . . . . . . . . . . . . . . . . . . . . . 86
7-1
7-2
7-3
7-4
Oscillator Module Block Diagram . . . . . . . . . . . . . . . . . . . . . . 103
Mask Option Register (MOR) . . . . . . . . . . . . . . . . . . . . . . . . . 104
Configuration Register 2 (CONFIG2) . . . . . . . . . . . . . . . . . . .105
Internal Oscillator . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 106
MOTOROLA
Page
Technical Data
List of Figures
25
List of Figures
Figure
Title
7-5
7-6
RC Oscillator. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 107
Crystal Oscillator. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 108
8-1
8-2
8-3
8-4
8-5
8-6
8-7
8-8
8-9
8-10
CGM Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 114
CGM I/O Register Summary. . . . . . . . . . . . . . . . . . . . . . . . . . 115
CGM External Connections . . . . . . . . . . . . . . . . . . . . . . . . . .125
PLL Control Register (PCTL) . . . . . . . . . . . . . . . . . . . . . . . . . 128
PLL Bandwidth Control Register (PBWCR) . . . . . . . . . . . . . . 131
PLL Multiplier Select Register High (PMSH) . . . . . . . . . . . . . 132
PLL Multiplier Select Register Low (PMSL) . . . . . . . . . . . . . . 132
PLL VCO Range Select Register (PMRS) . . . . . . . . . . . . . . . 133
PLL Reference Divider Select Register (PMDS) . . . . . . . . . . 134
PLL Filter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .139
9-1
9-2
9-3
9-4
9-5
9-6
9-7
9-8
9-9
9-10
9-11
9-12
9-13
9-14
9-15
9-16
9-17
9-18
9-19
9-20
9-21
9-22
SIM Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 143
SIM I/O Register Summary. . . . . . . . . . . . . . . . . . . . . . . . . . . 144
CGM Clock Signals. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 145
External Reset Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 147
Internal Reset Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 148
Sources of Internal Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . 148
POR Recovery . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 149
Interrupt Entry Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 152
Interrupt Recovery Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . 152
Interrupt Processing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 153
Interrupt Recognition Example . . . . . . . . . . . . . . . . . . . . . . . . 154
Interrupt Status Register 1 (INT1). . . . . . . . . . . . . . . . . . . . . .155
Interrupt Status Register 2 (INT2). . . . . . . . . . . . . . . . . . . . . .157
Interrupt Status Register 3 (INT3). . . . . . . . . . . . . . . . . . . . . .157
Wait Mode Entry Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . .159
Wait Recovery from Interrupt or Break . . . . . . . . . . . . . . . . . . 160
Wait Recovery from Internal Reset. . . . . . . . . . . . . . . . . . . . . 160
Stop Mode Entry Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . .161
Stop Mode Recovery from Interrupt or Break . . . . . . . . . . . . . 161
SIM Break Status Register (SBSR) . . . . . . . . . . . . . . . . . . . . 162
SIM Reset Status Register (SRSR) . . . . . . . . . . . . . . . . . . . . 163
SIM Break Flag Control Register (SBFCR) . . . . . . . . . . . . . . 164
Technical Data
26
Page
List of Figures
MOTOROLA
List of Figures
Figure
Title
10-1
10-2
10-3
10-4
10-5
10-6
10-7
10-8
Monitor Mode Circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 167
Low-Voltage Monitor Mode Entry Flowchart. . . . . . . . . . . . . . 171
Monitor Data Format. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 172
Break Transaction. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 172
Read Transaction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 174
Write Transaction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 174
Stack Pointer at Monitor Mode Entry . . . . . . . . . . . . . . . . . . .178
Monitor Mode Entry Timing. . . . . . . . . . . . . . . . . . . . . . . . . . . 179
11-1
11-2
11-3
11-4
11-5
11-6
11-7
11-8
11-9
11-10
11-11
11-12
11-13
11-14
11-15
TIM Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 184
TIM I/O Register Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . 185
PWM Period and Pulse Width . . . . . . . . . . . . . . . . . . . . . . . . 190
TIM Status and Control Register (TSC) . . . . . . . . . . . . . . . . . 196
TIM Counter Registers High (TCNTH) . . . . . . . . . . . . . . . . . . 198
TIM Counter Registers Low (TCNTL) . . . . . . . . . . . . . . . . . . . 198
TIM Counter Modulo Register High (TMODH) . . . . . . . . . . . .199
TIM Counter Modulo Register Low (TMODL) . . . . . . . . . . . . . 199
TIM Channel 0 Status and Control Register (TSC0) . . . . . . . 200
TIM Channel 1 Status and Control Register (TSC1) . . . . . . . 200
CHxMAX Latency . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 203
TIM Channel 0 Register High (TCH0H) . . . . . . . . . . . . . . . . . 204
TIM Channel 0 Register Low (TCH0L) . . . . . . . . . . . . . . . . . . 204
TIM Channel 1 Register High (TCH1H) . . . . . . . . . . . . . . . . . 204
TIM Channel 1 Register Low (TCH1L) . . . . . . . . . . . . . . . . . . 204
12-1
12-2
Timebase Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . 206
Timebase Control Register (TBCR) . . . . . . . . . . . . . . . . . . . . 207
13-1
13-2
13-3
13-4
13-5
13-6
13-7
13-8
PWM I/O Register Summary . . . . . . . . . . . . . . . . . . . . . . . . . 212
PWM Block Diagram. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 213
PWM Output Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 214
PWM Control Register (PWMCR). . . . . . . . . . . . . . . . . . . . . .217
PWM Clock Control Register (PWMCCR) . . . . . . . . . . . . . . . 218
PWM Data Register 0 (PWMDR0) . . . . . . . . . . . . . . . . . . . . . 219
PWM Data Register 1 (PWMDR1) . . . . . . . . . . . . . . . . . . . . . 219
MOTOROLA
Page
Technical Data
List of Figures
27
List of Figures
Figure
Title
Page
13-9 PWM Data Register 2 (PWMDR2) . . . . . . . . . . . . . . . . . . . . . 219
13-10 PWM Phase Control Register (PWMPCR) . . . . . . . . . . . . . . .220
14-1
14-2
14-3
14-4
14-5
Analog Module Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . 222
Analog Module I/O Register Summary . . . . . . . . . . . . . . . . . . 223
Analog Module Control Register (AMCR). . . . . . . . . . . . . . . . 226
Analog Module Gain Control Register (AMGCR) . . . . . . . . . . 227
Analog Module Status and Control Register (AMSCR) . . . . .229
15-1
15-2
15-3
15-4
15-5
15-6
15-7
15-8
15-9
15-10
ADC I/O Register Summary . . . . . . . . . . . . . . . . . . . . . . . . . .233
ADC Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 235
ADC Status and Control Register (ADSCR) . . . . . . . . . . . . . . 242
ADC Clock Control Register (ADICLK). . . . . . . . . . . . . . . . . . 244
ADRH0 and ADRL0 in 8-Bit Truncated Mode. . . . . . . . . . . . . 246
ADRH0 and ADRL0 in Right Justified Mode. . . . . . . . . . . . . . 246
ADRH0 and ADRL0 in Left Justified Mode . . . . . . . . . . . . . . .247
ADRH0 and ADRL0 in Left Justified Sign Data Mode . . . . . . 247
ADC Data Register Low 1 to 3 (ADRL1–ADRL3) . . . . . . . . . . 248
ADC Scan Control Register (ADASCR) . . . . . . . . . . . . . . . . . 248
16-1
16-2
16-3
16-4
16-5
16-6
16-7
16-8
16-9
16-10
16-11
16-12
16-13
16-14
16-15
16-16
SCI Module Block Diagram. . . . . . . . . . . . . . . . . . . . . . . . . . . 255
SCI I/O Register Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . 256
SCI Data Formats . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 257
SCI Transmitter. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .258
SCI Receiver Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . 263
Receiver Data Sampling . . . . . . . . . . . . . . . . . . . . . . . . . . . . .264
Slow Data . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 267
Fast Data . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .268
SCI Control Register 1 (SCC1). . . . . . . . . . . . . . . . . . . . . . . . 274
SCI Control Register 2 (SCC2). . . . . . . . . . . . . . . . . . . . . . . . 277
SCI Control Register 3 (SCC3). . . . . . . . . . . . . . . . . . . . . . . . 279
SCI Status Register 1 (SCS1) . . . . . . . . . . . . . . . . . . . . . . . . 282
Flag Clearing Sequence . . . . . . . . . . . . . . . . . . . . . . . . . . . . .285
SCI Status Register 2 (SCS2) . . . . . . . . . . . . . . . . . . . . . . . . 286
SCI Data Register (SCDR) . . . . . . . . . . . . . . . . . . . . . . . . . . . 287
SCI Baud Rate Register (SCBR) . . . . . . . . . . . . . . . . . . . . . . 288
Technical Data
28
List of Figures
MOTOROLA
List of Figures
Figure
17-1
17-2
17-3
17-4
17-5
17-6
17-7
17-8
17-9
17-10
17-11
17-12
Title
17-13
17-14
17-15
17-16
17-17
17-18
17-19
17-20
MMIIC I/O Register Summary. . . . . . . . . . . . . . . . . . . . . . . . . 294
Multi-Master IIC Bus Transmission Signal Diagram . . . . . . . .295
Clock Synchronization . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 298
MMIIC Address Register (MMADR) . . . . . . . . . . . . . . . . . . . . 299
MMIIC Control Register 1 (MMCR1). . . . . . . . . . . . . . . . . . . . 301
MMIIC Control Register 2 (MMCR2). . . . . . . . . . . . . . . . . . . . 303
MMIIC Status Register (MMSR) . . . . . . . . . . . . . . . . . . . . . . . 305
MMIIC Data Transmit Register (MMDTR) . . . . . . . . . . . . . . . 307
MMIIC Data Receive Register (MMDRR) . . . . . . . . . . . . . . . . 308
MMIIC CRC Data Register (MMCRCDR) . . . . . . . . . . . . . . . . 309
MMIIC Frequency Divider Register (MMFDR) . . . . . . . . . . . .310
Data Transfer Sequences for Master/Slave
Transmit/Receive Modes . . . . . . . . . . . . . . . . . . . . . . . . . . 312
Quick Command . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 313
Send Byte . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 313
Receive Byte. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 313
Write Byte/Word . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 314
Read Byte/Word . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 314
Process Call . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 315
Block Read/Write . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 315
18-1
18-2
18-3
18-4
18-5
18-6
18-7
18-8
18-9
18-10
18-11
18-12
18-13
18-14
18-15
I/O Port Register Summary. . . . . . . . . . . . . . . . . . . . . . . . . . . 318
Port A Data Register (PTA) . . . . . . . . . . . . . . . . . . . . . . . . . .320
Data Direction Register A (DDRA) . . . . . . . . . . . . . . . . . . . . . 321
Port A I/O Circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 322
Port A LED Control Register (LEDA) . . . . . . . . . . . . . . . . . . .323
Port B Data Register (PTB) . . . . . . . . . . . . . . . . . . . . . . . . . .324
Data Direction Register B (DDRB) . . . . . . . . . . . . . . . . . . . . . 325
Port B I/O Circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 326
Port C Data Register (PTC) . . . . . . . . . . . . . . . . . . . . . . . . . .327
Data Direction Register B (DDRB) . . . . . . . . . . . . . . . . . . . . . 329
Port C I/O Circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 329
Port A LED Control Register (LEDA) . . . . . . . . . . . . . . . . . . .330
Port D Data Register (PTD) . . . . . . . . . . . . . . . . . . . . . . . . . .331
Data Direction Register D (DDRD) . . . . . . . . . . . . . . . . . . . . . 332
Port D I/O Circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 332
MOTOROLA
Page
Technical Data
List of Figures
29
List of Figures
Figure
Title
19-1
19-2
19-3
19-4
19-5
External Interrupt I/O Register Summary . . . . . . . . . . . . . . . . 336
IRQ1 Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 337
IRQ2 Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 338
IRQ1 Status and Control Register (INTSCR1) . . . . . . . . . . . . 340
IRQ2 Status and Control Register (INTSCR2) . . . . . . . . . . . . 341
20-1
20-2
20-3
20-4
KBI I/O Register Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . 344
Keyboard Interrupt Block Diagram . . . . . . . . . . . . . . . . . . . . . 345
Keyboard Status and Control Register (KBSCR) . . . . . . . . . . 348
Keyboard Interrupt Enable Register (KBIER) . . . . . . . . . . . . . 349
21-1
21-2
21-3
COP Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 352
Configuration Register 1 (CONFIG1) . . . . . . . . . . . . . . . . . . .354
COP Control Register (COPCTL) . . . . . . . . . . . . . . . . . . . . . .355
22-1
22-2
22-3
LVI I/O Register Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . 358
LVI Module Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . 358
23-1
23-2
23-3
23-4
23-5
23-6
23-7
Break Module Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . 365
Break Module I/O Register Summary . . . . . . . . . . . . . . . . . . . 365
Break Status and Control Register (BRKSCR). . . . . . . . . . . . 367
Break Address Register High (BRKH) . . . . . . . . . . . . . . . . . . 368
Break Address Register Low (BRKL) . . . . . . . . . . . . . . . . . . . 368
SIM Break Status Register (SBSR) . . . . . . . . . . . . . . . . . . . . 369
SIM Break Flag Control Register (SBFCR) . . . . . . . . . . . . . . 370
24-1
24-2
24-3
RC vs. Bus Frequency (5V @25°C) . . . . . . . . . . . . . . . . . . . . 378
RC vs. Bus Frequency (3V @25°C) . . . . . . . . . . . . . . . . . . . . 379
MMIIC Signal Timings. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 383
25-1
25-2
A-1
A-2
MC68HC08SR12 Block Diagram . . . . . . . . . . . . . . . . . . . . . 395
MC68HC08SR12 Memory Map . . . . . . . . . . . . . . . . . . . . . . 396
Technical Data
30
Page
MC68HC908SR12•MC68HC08SR12 — Rev. 4.0
List of Figures
MOTOROLA
List of Tables
Table
Title
Page
2-1
Vector Addresses . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 60
5-1
CGMXCLK Clock Selection . . . . . . . . . . . . . . . . . . . . . . . . . . .80
6-1
6-2
Instruction Set Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90
Opcode Map . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 99
7-1
7-2
CGMXCLK Clock Selection . . . . . . . . . . . . . . . . . . . . . . . . . .104
Timebase Module Reference Clock Selection . . . . . . . . . . . .105
8-1
8-3
8-2
Numeric Examples . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .123
VPR1 and VPR0 Programming . . . . . . . . . . . . . . . . . . . . . . . 130
PRE1 and PRE0 Programming . . . . . . . . . . . . . . . . . . . . . . . 130
9-1
9-2
9-3
Signal Name Conventions . . . . . . . . . . . . . . . . . . . . . . . . . . . 143
PIN Bit Set Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .147
Interrupt Sources . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 156
10-1 Monitor Mode Signal Requirements and Options . . . . . . . . . . 169
10-2 Mode Differences . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 172
10-3 Monitor Baud Rate Selection . . . . . . . . . . . . . . . . . . . . . . . . . 173
10-4 READ (Read Memory) Command . . . . . . . . . . . . . . . . . . . . . 175
10-5 WRITE (Write Memory) Command. . . . . . . . . . . . . . . . . . . . . 175
10-7 IWRITE (Indexed Write) Command . . . . . . . . . . . . . . . . . . . . 176
10-6 IREAD (Indexed Read) Command . . . . . . . . . . . . . . . . . . . . . 176
10-8 READSP (Read Stack Pointer) Command . . . . . . . . . . . . . . .177
10-9 RUN (Run User Program) Command . . . . . . . . . . . . . . . . . . . 177
11-1
11-2
Prescaler Selection. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 197
MOTOROLA
Technical Data
List of Tables
31
List of Tables
Table
Title
11-3
Mode, Edge, and Level Selection . . . . . . . . . . . . . . . . . . . . . .202
12-1
Timebase Rate Selection for OSCCLK = 32.768 kHz . . . . . . 207
13-1
13-2
PTC0 Pin Configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 218
PWM Counter Clock Prescaler Selection . . . . . . . . . . . . . . . . 219
14-1
14-2
14-3
14-4
Analog Module Power Control . . . . . . . . . . . . . . . . . . . . . . . . 226
Amplifier Channel Select Control bits . . . . . . . . . . . . . . . . . . . 227
Analog Module Gain Values . . . . . . . . . . . . . . . . . . . . . . . . . . 228
Analog Module Clock Divider Select. . . . . . . . . . . . . . . . . . . . 229
15-1
15-2
15-3
15-4
MUX Channel Select . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 243
ADC Clock Divide Ratio . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 244
ADC Mode Select . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 245
Auto-scan Mode Channel Select . . . . . . . . . . . . . . . . . . . . . . 248
16-1
16-2
16-3
16-4
16-5
16-6
16-7
16-8
Start Bit Verification . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 265
Data Bit Recovery. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 265
Stop Bit Recovery . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 266
Character Format Selection . . . . . . . . . . . . . . . . . . . . . . . . . .276
SCI Baud Rate Prescaling . . . . . . . . . . . . . . . . . . . . . . . . . . . 288
SCI Baud Rate Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . 289
SCI Baud Rate Selection Examples . . . . . . . . . . . . . . . . . . . . 290
17-1
17-2
Pin Name Conventions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 294
MMIIC Baud Rate Selection . . . . . . . . . . . . . . . . . . . . . . . . . . 310
18-1
18-2
18-3
18-4
18-5
18-6
18-7
Port Control Register Bits Summary. . . . . . . . . . . . . . . . . . . . 319
Port A Pin Functions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 322
PTB2 and PTB3 Pin Configurations . . . . . . . . . . . . . . . . . . . . 325
Port B Pin Functions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 326
PTC0 Pin Configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 328
Port C Pin Functions. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 330
Port D Pin Functions. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 333
Technical Data
32
Page
List of Tables
MOTOROLA
List of Tables
Table
Title
20-1
Pin Name Conventions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 344
22-1
LVIOUT Bit Indication . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 361
24-1
24-2
24-3
24-4
24-5
24-6
24-7
24-8
24-9
24-10
24-11
24-12
24-13
24-14
24-15
24-16
24-17
Operating Range . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 373
5V DC Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 374
3V DC Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 376
5V Control Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 377
3V Control Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 377
5V Oscillator Specifications . . . . . . . . . . . . . . . . . . . . . . . . . .378
3V Oscillator Specifications . . . . . . . . . . . . . . . . . . . . . . . . . .379
5V ADC Electrical Characteristics . . . . . . . . . . . . . . . . . . . . . 380
3V ADC Electrical Characteristics . . . . . . . . . . . . . . . . . . . . . 381
Temperature Sensor Electrical Characteristics . . . . . . . . . . . 382
Current Detection Electrical Characteristics . . . . . . . . . . . . . . 382
Two-Stage Amplifier Electrical Characteristics . . . . . . . . . . . . 382
MMIIC DC Electrical Characteristics. . . . . . . . . . . . . . . . . . . . 383
MMIIC Interface Input/Output Signal Timing. . . . . . . . . . . . . . 384
FLASH Memory Electrical Characteristics . . . . . . . . . . . . . . . 386
26-1
A-1
Summary of MC68HC08SR12 and
MC68HC908SR12 Differences . . . . . . . . . . . . . . . . . . . . . 394
MC68HC08SR12 Order Numbers . . . . . . . . . . . . . . . . . . . . . 398
A-2
MOTOROLA
Page
Technical Data
List of Tables
33
List of Tables
Technical Data
34
List of Tables
MOTOROLA
Technical Data — MC68HC908SR12•MC68HC08SR12
Section 1. General Description
1.1 Contents
1.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 36
1.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 36
1.4
MCU Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 38
1.5
Pin Assignments . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 40
1.6
Pin Functions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 41
1.6.1
Power Supply Pins (VDD and VSS) . . . . . . . . . . . . . . . . . . . . 42
1.6.2
Oscillator Pins (OSC1 and OSC2) . . . . . . . . . . . . . . . . . . . . 42
1.6.3
External Reset Pin (RST) . . . . . . . . . . . . . . . . . . . . . . . . . . . 43
1.6.4
External Interrupt Pin (IRQ1) . . . . . . . . . . . . . . . . . . . . . . . . 43
1.6.5
Analog Power Supply Pin (VDDA) . . . . . . . . . . . . . . . . . . . . . 43
1.6.6
Analog Ground Pin (VSSA) . . . . . . . . . . . . . . . . . . . . . . . . . . 43
1.6.7
ADC Voltage Low Reference Pin (VREFL) . . . . . . . . . . . . . . 43
1.6.8
ADC Voltage High Reference Pin (VREFH). . . . . . . . . . . . . . 43
1.6.9
External Filter Capacitor Pin (CGMXFC) . . . . . . . . . . . . . . . 43
1.6.10 Analog Input Pins (OPIN1/ATD0, OPIN2/ATD1, VSSAM) . . . 44
1.6.11 Port A Input/Output (I/O) Pins (PTA7–PTA0) . . . . . . . . . . . . 44
1.6.12 Port B I/O Pins (PTB6–PTB0) . . . . . . . . . . . . . . . . . . . . . . . 44
1.6.13 Port C I/O Pins (PTC7–PTC0) . . . . . . . . . . . . . . . . . . . . . . . 44
1.6.14 Port D I/O Pins (PTD7/KBI7–PTD0/KBI0) . . . . . . . . . . . . . . 44
MOTOROLA
General Description
Technical Data
35
General Description
1.2 Introduction
The MC68HC908SR12 is a member of the low-cost, high-performance
M68HC08 Family of 8-bit microcontroller units (MCUs). The M68HC08
Family is based on the customer-specified integrated circuit (CSIC)
design strategy. All MCUs in the family use the enhanced M68HC08
central processor unit (CPU08) and are available with a variety of
modules, memory sizes and types, and package types.
1.3 Features
Features of the MC68HC908SR12 include the following:
High-performance M68HC08 architecture
Fully upward-compatible object code with M6805, M146805, and
M68HC05 Families
Maximum internal bus frequency:
– 8-MHz at 5V operating voltage
– 4-MHz at 3V operating voltage
Clock input options:
– RC-oscillator
– 32kHz crystal-oscillator with 32MHz internal phase-lock-loop
12k-bytes user program FLASH memory with security1 feature
512 bytes of on-chip RAM
Two 16-bit, 2-channel timer interface modules (TIM1 and TIM2)
with selectable input capture, output compare, and PWM
capability on each channel
Timebase module
3-channel, 8-bit high speed PWM (125kHz) with independent
counters and automatic phase control
Serial communications interface module (SCI)
1. No security feature is absolutely secure. However, Motorola’s strategy is to make reading or
copying the FLASH difficult for unauthorized users.
Technical Data
36
General Description
MOTOROLA
General Description
Features
System Management Bus (SMBus), version 1.0/1.1
(Multi-master IIC bus)
14-channel, 10-bit analog-to-digital converter (ADC), with
auto-scan mode for 4 channels
Current sensor with programmable amplifier
Temperature sensor (–20°C to +70°C)
IRQ1 external interrupt pin with integrated pullup
IRQ2 external interrupt pin with programmable pullup
8-bit keyboard wakeup port with integrated pullup
31 general-purpose input/output (I/O) pins and 2 dedicated pins:
– 31 shared-function I/O pins
– Two dedicated analog input pins
Low-power design (fully static with Stop and Wait modes)
Master reset pin (with integrated pullup) and power-on reset
System protection features
– Optional computer operating properly (COP) reset
– Low-voltage detection with optional reset
– Illegal opcode detection with reset
– Illegal address detection with reset
48-pin low quad flat pack (LQFP) and 42-pin shrink dual-in-line
package (SDIP)
Specific features of the MC68HC908SR12 in 42-pin SDIP are:
– 29 general-purpose l/Os only
– 11-channel ADC only
Features of the CPU08 include the following:
Enhanced HC05 programming model
Extensive loop control functions
16 addressing modes (eight more than the HC05)
MOTOROLA
General Description
Technical Data
37
General Description
16-bit Index register and stack pointer
Memory-to-memory data transfers
Fast 8 × 8 multiply instruction
Fast 16/8 divide instruction
Binary-coded decimal (BCD) instructions
Optimization for controller applications
Efficient C language support
1.4 MCU Block Diagram
Figure 1-1 shows the structure of the MC68HC908SR12.
Technical Data
38
General Description
MOTOROLA
CONTROL AND STATUS REGISTERS — 96 BYTES
2-CHANNEL TIMER INTERFACE
MODULE 1
DDRA
ARITHMETIC/LOGIC
UNIT (ALU)
PORTA
CPU
REGISTERS
PTA7/T1CH1
PTA6/T1CH0
PTA5/ATD7 – PTA0/ATD2 ‡
MODULE 2
PORTB
PTB6/IRQ2
PTB5/T2CH1
PTB4/T2CH0
PTB3//SCL1/RxD †
PTB2/SDA1/TxD †
PTB1/SCL0 †
PTB0/SDA0 †
DDRC
PORTC
PTC7/ATD12 ‡ #
PTC6/ATD11 ‡ #
PTC5/ATD10 ‡
PTC4/ATD9 ‡
PTC3/ATD8 ‡
PTC2/PWM2
PTC1/PWM1
PTC0/PWM0/CD
DDRD
USER FLASH — 12,288 BYTES
PORTD
General Description
TIMEBASE
MODULE
USER RAM — 512 BYTES
MONITOR ROM — 368 BYTES
SERIAL COMMUNICATIONS
INTERFACE MODULE
DDRB
MOTOROLA
INTERNAL BUS
M68HC08 CPU
USER FLASH VECTORS — 38 BYTES
OSCILLATORS AND
CLOCK GENERATOR MODULE
MULTI-MASTER IIC (SMBUS)
INTERFACE MODULE
INTERNAL OSCILLATOR
OSC1
OSC2
PULSE WIDTH MODULATOR
MODULE
X-TAL OSCILLATOR
CGMXFC
PHASE-LOCKED LOOP
8-BIT KEYBOARD
INTERRUPT MODULE
* RST
SYSTEM INTEGRATION
MODULE
COMPUTER OPERATING
PROPERLY MODULE
* IRQ1
** IRQ2
OPIN1/ATD0
RC OSCILLATOR
OPIN2/ATD1
VSSAM
VREFH
39
Technical Data
VDD
VSS
VDDA
VSSA
ANALOG
MODULE
10-BIT ANALOG-TO-DIGITAL
CONVERTER MODULE
POWER
PTD7/KBI7 – PTD0/KBI0 ***
LOW-VOLTAGE
INHIBIT MODULE
POWER-ON RESET
MODULE
* Pin contains integrated pullup device.
** Pin contains configurable pullup device.
*** Pin contains integrated pullup device for KBI functions.
† Pin is open-drain when configured as output.
‡ High current drive pin (for LED).
# Pin not bonded on 42-pin SDIP.
Figure 1-1. MC68HC908SR12 Block Diagram
General Description
MCU Block Diagram
VREFL
EXTERNAL IRQ
MODULE
General Description
PTC4/ATD9
PTC5/ATD10
PTC6/ATD11
VDDA
VSSA
NC
PTA4/ATD6
PTA3/ATD5
PTA2/ATD4
46
45
44
43
42
41
40
39
38
37 PTA1/ATD3
PTA5/ATD7
PTC3/ATD8 1
47
48 CGMXFC
1.5 Pin Assignments
36 VREFH
VSS
7
30
OPIN1/ATD0
PTD1/KBI1
8
29
PTB4/T2CH0
IRQ1
9
28
PTB5/T2CH1
PTD2/KBI2
10
27
PTB6/IRQ2
RST
11
26
PTA6/T1CH0
25 PTD7/KBI7
NC 24
PTB0/SDA0 13
PTD3/KBI3 12
23
VSSAM
PTA7/T1CH1
31
22
6
PTC2/PWM2
OSC2
21
PTA0/ATD2
PTC1/PWM1
32
PTC0/PWM0/CD
OSC1
19
PTC7/ATD12
PTD6/KBI6
33
18
4
PTD5/KBI5
VDD
17
OPIN2/ATD1
PTD4/KBI4
34
16
3
PTB3/SCL1/RxD
PTD0/KBI0
15
VREFL
PTB2/SDA1/TxD
35
14
2
PTB1/SCL0
NC
NC: No connection
Figure 1-2. 48-Pin LQFP Pin Assignments
Technical Data
40
General Description
MOTOROLA
General Description
Pin Functions
VDDA
1
42
VSSA
PTC5/ATD10
2
41
PTA4/ATD6
PTC4/ATD9
3
40
PTA3/ATD5
PTA5/ATD7
4
39
PTA2/ATD4
CGMXFC
5
38
PTA1/ATD3
PTC3/ATD8
6
37
VREFH
PTD0/KBI0
7
36
VREFL
VDD
8
35
PTA0/ATD2
OSC1
9
34
VSSAM
OSC2
10
33
OPIN1/ATD0
VSS
11
32
PTB4/T2CH0
PTD1/KBI1
12
31
PTB5/T2CH1
IRQ1
13
30
PTB6/IRQ2
PTD2/KBI2
14
29
PTA6/T1CH0
RST
15
28
PTD7/KBI7
PTD3/KBI3
16
27
PTA7/T1CH1
PTB0/SDA0
17
26
PTC2/PWM2
PTB1/SCL0
18
25
PTC1/PWM1
PTB2/SDA1/TxD
19
24
PTC0/PWM0/CD
PTB3/SCL1/RxD
PTD6/KBI6
PTD4/KBI4
21
22
PTD5/KBI5
Pins not available on 42-pin package
Internal connection
OPIN2/ATD1
Unconnected
PTC6/ATD11
Unconnected
PTC7/ATD12
Unconnected
Figure 1-3. 42-Pin SDIP Pin Assignment
1.6 Pin Functions
Description of pin functions are provided here.
MOTOROLA
General Description
Technical Data
41
General Description
1.6.1 Power Supply Pins (VDD and VSS)
VDD and VSS are the power supply and ground pins. The MCU operates
from a single power supply.
Fast signal transitions on MCU pins place high, short-duration current
demands on the power supply. To prevent noise problems, take special
care to provide power supply bypassing at the MCU as Figure 1-4
shows. Place the C1 bypass capacitor as close to the MCU as possible.
Use a high-frequency-response ceramic capacitor for C1. C2 is an
optional bulk current bypass capacitor for use in applications that require
the port pins to source high current levels.
MCU
VDD
VSS
C1
0.1 µF
C2
VDD
NOTE: Component values shown
represent typical applications.
Figure 1-4. Power Supply Bypassing
VSS must be grounded for proper MCU operation.
1.6.2 Oscillator Pins (OSC1 and OSC2)
The OSC1 and OSC2 pins are the connections for the on-chip oscillator
circuit. See Section 7. Oscillator (OSC) and Section 8. Clock
Generator Module (CGM).
Technical Data
42
General Description
MOTOROLA
General Description
Pin Functions
1.6.3 External Reset Pin (RST)
A logic 0 on the RST pin forces the MCU to a known start-up state. RST
is bidirectional, allowing a reset of the entire system. It is driven low when
any internal reset source is asserted. This pin contains an internal pullup
resistor. See Section 9. System Integration Module (SIM).
1.6.4 External Interrupt Pin (IRQ1)
IRQ1 is an asynchronous external interrupt pin. This pin contains an
internal pullup resistor. See Section 19. External Interrupt (IRQ).
1.6.5 Analog Power Supply Pin (VDDA)
VDDA is the power supply pin for the analog circuits of the MCU.
1.6.6 Analog Ground Pin (VSSA)
VSSA is the power supply ground pin for the analog circuits of the MCU.
It should be decoupled as per the VSS digital ground pin.
1.6.7 ADC Voltage Low Reference Pin (VREFL)
VREFL is the voltage input pin for the ADC voltage low reference. See
Section 15. Analog-to-Digital Converter (ADC).
1.6.8 ADC Voltage High Reference Pin (VREFH)
VREFH is the voltage input pin for the ADC voltage high reference. See
1.6.9 External Filter Capacitor Pin (CGMXFC)
CGMXFC is an external filter capacitor connection for the CGM. See
Section 8. Clock Generator Module (CGM).
MOTOROLA
General Description
Technical Data
43
General Description
OPIN1/ATD0 and OPIN2/ATD1 are input pins to the analog module and
ADC and VSSAM is the negative reference input. See Section 14.
Analog Module and Section 15. Analog-to-Digital Converter (ADC).
1.6.11 Port A Input/Output (I/O) Pins (PTA7±PTA0)
PTA7–PTA0 are special function, bidirectional port pins.
PTA7/T1CH1–PTA6/T1CH0 are shared with the TIM1, and
PTA5/ATD7–PTA0/ATD2 are shared with the ADC. See Section 18.
Input/Output (I/O) Ports, Section 11. Timer Interface Module (TIM),
PTB6–PTB0 are special function, bidirectional port pins. PTB6/IRQ2 is
shared with the IRQ2 input, PTB5/T2CH1–PTB4/T2CH0 are shared with
the TIM2, PTB3/SCL1/RxD–PTB2/SDA1/TxD are shared with the
MMIIC and SCI, and PTB1/SCL0–PTB0/SDA0 are shared with the
MMIIC. See Section 18. Input/Output (I/O) Ports, Section 19.
External Interrupt (IRQ), Section 11. Timer Interface Module (TIM),
Section 16. Serial Communications Interface (SCI), and Section 17.
Multi-Master IIC Interface (MMIIC).
PTC7–PTC0 are special function, bidirectional port pins.
PTC7/ATD12–PTC3/ATD8 are shared with the ADC,
PTC2/PWM2–PTC1/PWM1 are shared with the PWM, and
PTC0/PWM0/CD is shared with the PWM and analog module. See
Section 18. Input/Output (I/O) Ports, Section 15. Analog-to-Digital
Converter (ADC), Section 13. Pulse Width Modulator (PWM), and
Section 14. Analog Module.
PTD7–PTD0 are general-purpose bidirectional port pins with keyboard
wakeup function. See Section 18. Input/Output (I/O) Ports and
Section 20. Keyboard Interrupt Module (KBI).
Technical Data
44
General Description
MOTOROLA
Section 2. Memory Map
2.1 Contents
2.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 45
2.3
Unimplemented Memory Locations . . . . . . . . . . . . . . . . . . . . . 45
2.4
Reserved Memory Locations . . . . . . . . . . . . . . . . . . . . . . . . . . 46
2.5
Input/Output (I/O) Section. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 46
2.2 Introduction
The CPU08 can address 64k-bytes of memory space. The memory
map, shown in Figure 2-1, includes:
12,288 bytes of user FLASH memory
512 bytes of random-access memory (RAM)
38 bytes of user-defined vectors
368 bytes of monitor ROM
2.3 Unimplemented Memory Locations
Accessing an unimplemented location can cause an illegal address
reset. In the memory map (Figure 2-1) and in register figures in this
document, unimplemented locations are shaded.
MOTOROLA
Technical Data
Memory Map
45
Memory Map
2.4 Reserved Memory Locations
Accessing a reserved location can have unpredictable effects on MCU
operation. In the Figure 2-1 and in register figures in this document,
reserved locations are marked with the word Reserved or with the
letter R.
2.5 Input/Output (I/O) Section
Most of the control, status, and data registers are in the zero page
$0000–$005F. Additional I/O registers have the following addresses:
$FE00; SIM break status register, SBSR
$FE01; SIM reset status register, SRSR
$FE03; SIM break flag control register, SBFCR
$FE04; Interrupt status register 1, INT1
$FE05; Interrupt status register 2, INT2
$FE06; Interrupt status register 3, INT3
$FE07; Reserved
$FE08; FLASH control register, FLCR
$FE09; FLASH block protect register, FLBPR
$FE0A; Reserved
$FE0B; Reserved
$FE0C; break address register high, BRKH
$FE0D; break address register low, BRKL
$FE0E; break status and control register, BRKSCR
$FE0F; LVI status register, LVISR
$FF80; Mask option register, MOR
$FFFF; COP control register, COPCTL
Data registers are shown in Figure 2-2, Table 2-1 is a list of vector
locations.
Technical Data
46
Memory Map
MOTOROLA
Memory Map
$0000
$005F
I/O Registers
96 Bytes
$0060
$025F
RAM
512 Bytes
$0260
$BFFF
Unimplemented
48,544 Bytes
$C000
$EFFF
FLASH Memory
12,288 Bytes
$F000
$FDFF
Unimplemented
3,584 Bytes
$FE00
$FE01
$FE02
Reserved
$FE03
$FE04
$FE05
$FE06
$FE07
Reserved
$FE08
$FE09
$FE0A
Reserved
$FE0B
Reserved
$FE0C
$FE0D
$FE0E
$FE0F
LVI Status Register (LVISR)
$FE10
$FF7F
Monitor ROM
368 Bytes
$FF80
$FF81
$FFD9
Reserved
89 Bytes
$FFDA
$FFFF
FLASH Vectors
38 Bytes
Figure 2-1. Memory Map
MOTOROLA
Technical Data
Memory Map
47
Memory Map
Addr.
Register Name
$0000
Read:
Write:
(PTA)
Reset:
$0001
$0002
$0003
Read:
Write:
(PTB)
Reset:
Read:
Write:
(PTC)
Reset:
Read:
Write:
(PTD)
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
PTA7
PTA6
PTA5
PTA4
PTA3
PTA2
PTA1
PTA0
U
U
U
U
U
U
U
U
PTB6
PTB5
PTB4
PTB3
PTB2
PTB1
PTB0
U
U
U
U
U
U
U
PTC7
PTC6
PTC5
PTC4
PTC3
PTC2
PTC1
PTC0
U
U
U
U
U
U
U
U
PTD7
PTD6
PTD5
PTD4
PTD3
PTD2
PTD1
PTD0
U
U
U
U
U
U
U
U
DDRA6
DDRA5
DDRA4
DDRA3
DDRA2
DDRA1
DDRA0
DDRB6
DDRB5
DDRB4
DDRB3
DDRB2
DDRB1
DDRB0
DDRC6
DDRC5
DDRC4
DDRC3
DDRC2
DDRC1
DDRC0
DDRD6
DDRD5
DDRD4
DDRD3
DDRD2
DDRD1
DDRD0
= Unimplemented
R
Read:
DDRA7
$0004
Write:
(DDRA)
Reset:
Read:
$0005
Write:
(DDRB)
Reset:
Read:
DDRC7
$0006
Write:
(DDRC)
Reset:
Read:
DDRD7
$0007
Write:
(DDRD)
Reset:
Read:
$0008
Unimplemented Write:
Reset:
Read:
$0009
Reset:
U = Unaffected
X = Indeterminate
= Reserved
Figure 2-2. Control, Status, and Data Registers (Sheet 1 of 12)
Technical Data
48
Memory Map
MOTOROLA
Memory Map
Addr.
Register Name
Bit 7
6
5
4
3
2
1
Bit 0
LEDA5
LEDA4
LEDA3
LEDA2
LEDA1
LEDA0
LEDC7
LEDC6
LEDC5
LEDC4
LEDC3
PWR1
PWR0
OPCH1
OPCH0
AMIEN
DO2
DO1
DO0
GAINB2
GAINB1
GAINB0
GAINA3
GAINA2
GAINA1
GAINA0
OPIF
DOF
CDIF
Read:
$000A
Reset:
Read:
$000B
Reset:
Read:
Port-A LED Control
Register Write:
(LEDA)
Reset:
$000C
Read:
Port-C LED Control
Register Write:
(LEDC)
Reset:
$000D
$000E
$000F
Read:
Register Write:
(AMCR)
Reset:
Read:
Analog Module Gain
GAINB3
Control Register Write:
(AMGCR)
Reset:
Read:
AMCDIV1 AMCDIV0
$0010
(AMSCR)
Reset:
CDIFR
OPIFR
U
U
ENSCI
TXINV
M
WAKE
ILTY
PEN
PTY
= Unimplemented
R
Read:
$0011
Reset:
Read:
$0012
Reset:
$0013
Read:
LOOPS
Write:
(SCC1)
Reset:
U = Unaffected
X = Indeterminate
= Reserved
Figure 2-2. Control, Status, and Data Registers (Sheet 2 of 12)
MOTOROLA
Technical Data
Memory Map
49
Memory Map
Addr.
$0014
$0015
$0016
$0017
$0018
$0019
$001A
Register Name
Read:
Write:
(SCC2)
Reset:
$001D
6
5
4
3
2
1
Bit 0
SCTIE
TCIE
SCRIE
ILIE
TE
RE
RWU
SBK
T8
DMARE
DMATE
ORIE
NEIE
FEIE
PEIE
Read:
Write:
(SCC3)
Reset:
R8
U
U
Read:
Write:
(SCS1)
Reset:
SCTE
TC
SCRF
IDLE
OR
NF
FE
PE
1
1
Read:
Write:
(SCS2)
Reset:
BKF
RPF
Read:
SCI Data Register
Write:
(SCDR)
Reset:
R7
R6
R5
R4
R3
R2
R1
R0
T7
T6
T5
T4
T3
T2
T1
T0
U
U
U
U
U
U
U
U
Read:
Write:
(SCBR)
Reset:
SCP1
SCP0
R
SCR2
SCR1
SCR0
IMASKK
MODEK
Keyboard Status and Read:
Control Register
Write:
(KBSCR)
Reset:
Read:
$001B
Register Write:
(KBIER)
Reset:
$001C
Bit 7
Read:
Register Write:
(INTSCR2)
Reset:
ACKK
KBIE7
KBIE6
KBIE5
KBIE4
KBIE3
KBIE2
KBIE1
KBIE0
IRQ2F
IMASK2
MODE2
Read: STOP_
Write: ICLKEN
(CONFIG2)†
Reset:
U = Unaffected
KEYF
PTBPUE6
STOP_
RCLKEN
ACK2
STOP_
OSCCLK1 OSCCLK0
XCLKEN
X = Indeterminate
= Unimplemented
R
CDOEN SCIBDSRC
= Reserved
Figure 2-2. Control, Status, and Data Registers (Sheet 3 of 12)
Technical Data
50
Memory Map
MOTOROLA
Memory Map
Addr.
$001E
$001F
Register Name
Read:
Register Write:
(INTSCR1)
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
IRQ1F
IMASK1
MODE1
SSREC
STOP
COPD
PS2
PS1
PS0
ACK1
Read:
COPRS
† Write:
(CONFIG1)
Reset:
LVISTOP LVIRSTD LVIPWRD LVI5OR3
TOIE
TSTOP
† One-time writable register after each reset.
$0020
$0021
$0022
$0023
$0024
Read:
Timer 1 Status and
(T1SC)
Reset:
TOF
Read:
Timer 1 Counter
Register High Write:
(T1CNTH)
Reset:
Bit 15
14
13
12
11
10
9
Bit 8
Read:
Timer 1 Counter
Register Low Write:
(T1CNTL)
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
Bit 15
14
13
12
11
10
9
Bit 8
1
1
1
1
1
1
1
1
Bit 7
6
5
4
3
2
1
Bit 0
1
1
1
1
1
1
1
1
CH0IE
MS0B
MS0A
ELS0B
ELS0A
TOV0
CH0MAX
Bit 15
14
13
12
11
10
9
Bit 8
X
X
X
X
X
X
X
X
= Unimplemented
R
Read:
Timer 1 Counter Modulo
(T1MODH)
Reset:
Read:
Register Low Write:
(T1MODL)
Reset:
Read:
Timer 1 Channel 0 Status
$0025
and Control Register Write:
(T1SC0)
Reset:
$0026
Read:
Timer 1 Channel 0
(T1CH0H)
Reset:
U = Unaffected
CH0F
X = Indeterminate
TRST
= Reserved
Figure 2-2. Control, Status, and Data Registers (Sheet 4 of 12)
MOTOROLA
Technical Data
Memory Map
51
Memory Map
Addr.
$0027
Register Name
Read:
Timer 1 Channel 0
Register Low Write:
(T1CH0L)
Reset:
Read:
Timer 1 Channel 1 Status
$0028
(T1SC1)
Reset:
$0029
$002A
$002B
Read:
Timer 1 Channel 1
(T1CH1H)
Reset:
Read:
Timer 1 Channel 1
Register Low Write:
(T1CH1L)
Reset:
5
4
3
2
1
Bit 0
Bit 7
6
5
4
3
2
1
Bit 0
X
X
X
X
X
X
X
X
MS1A
ELS1B
ELS1A
TOV1
CH1MAX
CH1F
CH1IE
Bit 15
14
13
12
11
10
9
Bit 8
X
X
X
X
X
X
X
X
Bit 7
6
5
4
3
2
1
Bit 0
X
X
X
X
X
X
X
X
TOIE
TSTOP
PS2
PS1
PS0
TOF
Read:
Timer 2 Counter
(T2CNTH)
Reset:
Bit 15
14
13
12
11
10
9
Bit 8
Read:
Timer 2 Counter
Register Low Write:
(T2CNTL)
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
Bit 15
14
13
12
11
10
9
Bit 8
1
1
1
1
1
1
1
1
Bit 7
6
5
4
3
2
1
Bit 0
1
1
1
1
1
1
1
1
CH0IE
MS0B
MS0A
ELS0B
ELS0A
TOV0
CH0MAX
= Unimplemented
R
$002D
$002F
6
Read:
Timer 2 Status and
(T2SC)
Reset:
$002C
$002E
Bit 7
Read:
Timer 2 Counter Modulo
(T2MODH)
Reset:
Read:
Register Low Write:
(T2MODL)
Reset:
Read:
Timer 2 Channel 0 Status
$0030
(T2SC0)
Reset:
U = Unaffected
CH0F
X = Indeterminate
TRST
= Reserved
Figure 2-2. Control, Status, and Data Registers (Sheet 5 of 12)
Technical Data
52
Memory Map
MOTOROLA
Memory Map
Addr.
Register Name
Read:
Timer 2 Channel 0
(T2CH0H)
Reset:
$0031
Read:
Timer 2 Channel 0
Register Low Write:
(T2CH0L)
Reset:
$0032
Read:
Timer 2 Channel 1 Status
$0033
(T2SC1)
Reset:
Read:
Timer 2 Channel 1
(T2CH1H)
Reset:
$0034
Read:
Timer 2 Channel 1
Register Low Write:
(T2CH1L)
Reset:
$0035
$0036
$0037
$0038
$0039
$003A
Read:
Write:
(PTCL)
Reset:
Read:
Register Write:
(PBWC)
Reset:
Read:
(PMSH)
Reset:
Read:
Register Low Write:
(PMSL)
Reset:
Read:
Register Write:
(PMRS)
Reset:
U = Unaffected
Bit 7
6
5
4
3
2
1
Bit 0
Bit 15
14
13
12
11
10
9
Bit 8
X
X
X
X
X
X
X
X
Bit 7
6
5
4
3
2
1
Bit 0
X
X
X
X
X
X
X
X
MS1A
ELS1B
ELS1A
TOV1
CH1MAX
CH1F
CH1IE
Bit 15
14
13
12
11
10
9
Bit 8
X
X
X
X
X
X
X
X
Bit 7
6
5
4
3
2
1
Bit 0
X
X
X
X
X
X
X
X
PLLON
BCS
PRE1
PRE0
VPR1
VPR0
1
MUL11
MUL10
MUL9
MUL8
PLLIE
PLLF
AUTO
LOCK
ACQ
R
MUL7
MUL6
MUL5
MUL4
MUL3
MUL2
MUL1
MUL0
VRS7
VRS6
VRS5
VRS4
VRS3
VRS2
VRS1
VRS0
= Unimplemented
R
X = Indeterminate
= Reserved
Figure 2-2. Control, Status, and Data Registers (Sheet 6 of 12)
MOTOROLA
Technical Data
Memory Map
53
Memory Map
Addr.
$003B
Register Name
Read:
Select Register Write:
(PMDS)
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
RDS3
RDS2
RDS1
RDS0
= Unimplemented
R
Read:
$003C
Reset:
Read:
$003D
Reset:
Read:
$003E
Reset:
Read:
$003F
Reset:
Read:
$0040
Reset:
Read:
$0041
Reset:
Read:
$0042
Reset:
Read:
$0043
Reset:
Read:
$0044
Reset:
U = Unaffected
X = Indeterminate
= Reserved
Figure 2-2. Control, Status, and Data Registers (Sheet 7 of 12)
Technical Data
54
Memory Map
MOTOROLA
Memory Map
Addr.
Register Name
Bit 7
6
5
4
TBR2
TBR1
TBR0
MMAD6
MMAD5
2
1
Bit 0
TBIE
TBON
R
MMAD4
MMAD3
MMAD2
MMAD1
MMEXTAD
1
MMCRCBYTE
SDASCL1
Read:
$0045
Reset:
Read:
Timebase Control
Register Write:
(TBCR)
Reset:
$0046
TBIF
TACK
Read:
$0047
Reset:
$0048
Read:
MMAD7
Write:
(MMADR)
Reset:
1
Read:
$0049
Write:
(MMCR1)
Reset:
MMEN
MMIEN
Read: MMALIF MMNAKIF
$004A
Write:
(MMCR2)
Reset:
$004B
$004C
$004D
Read: MMRXIF
Write:
(MMSR)
Reset:
Read:
MMIIC Data Transmit
MMTD7
Register Write:
(MMDTR)
Reset:
Read: MMRD7
MMIIC Data Receive
Register Write:
(MDDRR)
Reset:
MMCLRBB
MMBB
MMTXAK REPSEN
MMAST
MMRW
MMCRCEF
Unaffected
MMTXIF MMATCH MMSRW MMRXAK MMCRCBF MMTXBE MMRXBF
MMTD6
MMTD5
MMTD4
MMTD3
MMTD2
MMTD1
MMTD0
MMRD6
MMRD5
MMRD4
MMRD3
MMRD2
MMRD1
MMRD0
Read: MMCRCD7 MMCRCD6 MMCRCD5 MMCRCD4 MMCRCD3 MMCRCD2 MMCRCD1 MMCRCD0
$004E
Write:
(MMCRDR)
Reset:
U = Unaffected
X = Indeterminate
= Unimplemented
R
= Reserved
Figure 2-2. Control, Status, and Data Registers (Sheet 8 of 12)
MOTOROLA
Technical Data
Memory Map
55
Memory Map
Addr.
Register Name
Bit 7
6
5
4
3
Read:
$004F
Register Write:
(MMFDR)
Reset:
R
R
R
Read:
$0050
Reserved Write:
2
1
Bit 0
MMBR2
MMBR1
MMBR0
R
R
R
R
R
PCH2
PCH1
PCH0
PCLK1
PCLK0
Reset:
$0051
$0052
Read:
PWMEN2 PWMEN1 PWMEN0
Write:
(PWMCR)
Reset:
Read:
PWM Clock Control
PCLKSEL
Register Write:
(PWMCCR)
Reset:
$0053
Read:
0PWMD7 0PWMD6 0PWMD5 0PWMD4 0PWMD3 0PWMD2 0PWMD1 0PWMD0
PWM Data Register 0
Write:
(PWMDR0)
Reset:
$0054
Read:
1PWMD7 1PWMD6 1PWMD5 1PWMD4 1PWMD3 1PWMD2 1PWMD1 1PWMD0
PWM Data Register 1
Write:
(PWMDR1)
Reset:
$0055
Read:
2PWMD7 2PWMD6 2PWMD5 2PWMD4 2PWMD3 2PWMD2 2PWMD1 2PWMD0
PWM Data Register 2
Write:
(PWMDR2)
Reset:
$0056
$0057
$0058
Read:
PWM Phase Control
Register Write:
(PWMPCR)
Reset:
Read:
Register Write:
(ADSCR)
Reset:
Read:
ADC Clock Control
Register Write:
(ADICLK)
Reset:
U = Unaffected
PHEN
PHD6
PHD5
PHD4
PHD3
PHD2
PHD1
PHD0
AIEN
ADCO
ADCH4
ADCH3
ADCH2
ADCH1
ADCH0
1
1
1
1
ADIV2
ADIV1
ADIV0
ADICLK
MODE1
MODE0
= Unimplemented
R
COCO
X = Indeterminate
R
= Reserved
Figure 2-2. Control, Status, and Data Registers (Sheet 9 of 12)
Technical Data
56
Memory Map
MOTOROLA
Memory Map
Addr.
Register Name
Bit 7
6
5
4
3
2
1
Bit 0
Read:
ADC Data Register High 0
$0059
Write:
(ADRH0)
Reset:
ADx
ADx
ADx
ADx
ADx
ADx
ADx
ADx
R
R
R
R
R
R
R
R
Read:
ADC Data Register Low 0
$005A
Write:
(ADRL0)
Reset:
ADx
ADx
ADx
ADx
ADx
ADx
ADx
ADx
R
R
R
R
R
R
R
R
Read:
$005B
Write:
(ADRL1)
Reset:
AD7
AD6
AD5
AD4
AD3
AD2
AD1
AD0
R
R
R
R
R
R
R
R
Read:
ADC Data Register Low 2
$005C
Write:
(ADRL3)
Reset:
AD7
AD6
AD5
AD4
AD3
AD2
AD1
AD0
R
R
R
R
R
R
R
R
Read:
ADC Data Register Low 3
$005D
Write:
(ADRL3)
Reset:
AD7
AD6
AD5
AD4
AD3
AD2
AD1
AD0
R
R
R
R
R
R
R
R
AUTO1
AUTO0
ASCAN
R
R
R
R
R
R
$005E
Read:
ADC Auto-scan Control
Register Write:
(ADASCR)
Reset:
Read:
$005F
Reset:
Read:
$FE00
Write:
(SBSR)
Reset:
SBSW
Note
R
Note: Writing a logic 0 clears SBSW.
Read:
$FE01
Write:
(SRSR)
POR:
U = Unaffected
POR
PIN
COP
ILOP
ILAD
LVI
= Unimplemented
R
X = Indeterminate
= Reserved
Figure 2-2. Control, Status, and Data Registers (Sheet 10 of 12)
MOTOROLA
Technical Data
Memory Map
57
Memory Map
Addr.
Register Name
Read:
$FE02
Reserved Write:
Bit 7
6
5
4
3
2
1
Bit 0
R
R
R
R
R
R
R
R
BCFE
R
R
R
R
R
R
R
Reset:
$FE03
Read:
Register Write:
(SBFCR)
Reset:
Read:
$FE04
Write:
(INT1)
Reset:
IF6
IF5
IF4
IF3
IF2
IF1
R
R
R
R
R
R
R
R
Read:
Write:
$FE05
(INT2)
Reset:
IF14
IF13
IF12
IF11
IF10
IF9
IF8
IF7
R
R
R
R
R
R
R
R
Read:
$FE06
Write:
(INT3)
Reset:
IF17
IF16
IF15
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
HVEN
MASS
ERASE
PGM
BPR7
BPR6
BPR5
BPR4
BPR3
BPR2
BPR1
BPR0
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
= Unimplemented
R
Read:
$FE07
Reserved Write:
Reset:
$FE08
$FE09
Read:
Write:
(FLCR)
Reset:
Read:
FLASH Block Protect
Write:
Register (FLBPR)
Reset:
Read:
$FE0A
Reserved Write:
Reset:
Read:
$FE0B
Reserved Write:
Reset:
U = Unaffected
X = Indeterminate
= Reserved
Figure 2-2. Control, Status, and Data Registers (Sheet 11 of 12)
Technical Data
58
Memory Map
MOTOROLA
Memory Map
Addr.
$FE0C
$FE0D
Register Name
Read:
High Write:
(BRKH)
Reset:
Read:
Low Write:
(BRKL)
Reset:
Read:
$FE0E
Register Write:
(BRKSCR)
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
Bit 15
14
13
12
11
10
9
Bit 8
Bit 7
6
5
4
3
2
1
Bit 0
BRKE
BRKA
R
R
R
R
R
R
Read: LVIOUT
Low-Voltage Inhibit Status
$FE0F
Register Write:
(LVISR)
Reset:
$FF80
Mask Option Register Read:
OSCSEL1 OSCSEL0
(MOR)* Write:
Erased:
1
1
1
1
1
1
1
1
Reset:
U
U
U
U
U
U
U
U
U
U
* MOR is a non-volatile FLASH register; write by programming.
$FFFF
Read:
Write:
(COPCTL)
Reset:
U = Unaffected
Low byte of reset vector
Writing clears COP counter (any value)
U
U
U
X = Indeterminate
U
U
U
= Unimplemented
R
= Reserved
Figure 2-2. Control, Status, and Data Registers (Sheet 12 of 12)
MOTOROLA
Technical Data
Memory Map
59
Memory Map
Table 2-1. Vector Addresses
Vector Priority
Lowest
Vector
IF17
IF16
IF15
IF14
IF13
IF12
IF11
IF10
IF9
IF8
IF7
IF6
IF5
IF4
IF3
IF2
IF1
Highest
Address
Vector
$FFDA
Timebase Module Interrupt Vector (High)
$FFDB
Timebase Module Interrupt Vector (Low)
$FFDC
Analog Module Interrupt Vector (High)
$FFDD
Analog Module Interrupt Vector (Low)
$FFDE
ADC Conversion Complete Vector (High)
$FFDF
ADC Conversion Complete Vector (Low)
$FFE0
Keyboard Vector (High)
$FFE1
Keyboard Vector (Low)
$FFE2
SCI Transmit Vector (High)
$FFE3
SCI Transmit Vector (Low)
$FFE4
SCI Receive Vector (High)
$FFE5
SCI Receive Vector (Low)
$FFE6
SCI Error Vector (High)
$FFE7
SCI Error Vector (Low)
$FFE8
MMIIC Interrupt Vector (High)
$FFE9
MMIIC Interrupt Vector (Low)
$FFEA
TIM2 Overflow Vector (High)
$FFEB
TIM2 Overflow Vector (Low)
$FFEC
TIM2 Channel 1 Vector (High)
$FFED
TIM2 Channel 1 Vector (Low)
$FFEE
TIM2 Channel 0 Vector (High)
$FFEF
TIM2 Channel 0 Vector (Low)
$FFF0
TIM1 Overflow Vector (High)
$FFF1
TIM1 Overflow Vector (Low)
$FFF2
TIM1 Channel 1 Vector (High)
$FFF3
TIM1 Channel 1 Vector (Low)
$FFF4
TIM1 Channel 0 Vector (High)
$FFF5
TIM1 Channel 0 Vector (Low)
$FFF6
PLL Vector (High)
$FFF7
PLL Vector (Low)
$FFF8
IRQ2 Vector (High)
$FFF9
IRQ2 Vector (Low)
$FFFA
IRQ1 Vector (High)
$FFFB
IRQ1 Vector (Low)
$FFFC
SWI Vector (High)
$FFFD
SWI Vector (Low)
$FFFE
Reset Vector (High)
$FFFF
Reset Vector (Low)
Technical Data
60
Memory Map
MOTOROLA
Section 3. Random-Access Memory (RAM)
3.1 Contents
3.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 61
3.3
Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 61
3.2 Introduction
This section describes the 512 bytes of RAM (random-access memory).
3.3 Functional Description
Addresses $0060 through $025F are RAM locations. The location of the
stack RAM is programmable. The 16-bit stack pointer allows the stack to
be anywhere in the 64K-byte memory space.
NOTE:
For correct operation, the stack pointer must point only to RAM
locations.
Within page zero are 160 bytes of RAM. Because the location of the
stack RAM is programmable, all page zero RAM locations can be used
for I/O control and user data or code. When the stack pointer is moved
from its reset location at $00FF out of page zero, direct addressing mode
instructions can efficiently access all page zero RAM locations. Page
zero RAM, therefore, provides ideal locations for frequently accessed
global variables.
Before processing an interrupt, the CPU uses five bytes of the stack to
save the contents of the CPU registers.
NOTE:
For M6805 compatibility, the H register is not stacked.
MOTOROLA
Technical Data
61
During a subroutine call, the CPU uses two bytes of the stack to store
the return address. The stack pointer decrements during pushes and
increments during pulls.
NOTE:
Technical Data
62
Be careful when using nested subroutines. The CPU may overwrite data
in the RAM during a subroutine or during the interrupt stacking
operation.
MOTOROLA
Section 4. FLASH Memory
4.1 Contents
4.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 63
4.3
Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 64
4.4
FLASH Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .65
4.5
FLASH Page Erase Operation . . . . . . . . . . . . . . . . . . . . . . . . . 66
4.6
FLASH Mass Erase Operation . . . . . . . . . . . . . . . . . . . . . . . . . 67
4.7
FLASH Program Operation. . . . . . . . . . . . . . . . . . . . . . . . . . . . 68
4.8
FLASH Protection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 70
4.8.1
FLASH Block Protect Register . . . . . . . . . . . . . . . . . . . . . . .70
4.2 Introduction
This section describes the operation of the embedded FLASH memory.
This memory can be read, programmed, and erased from a single
external supply. The program and erase operations are enabled through
the use of an internal charge pump.
MOTOROLA
Technical Data
FLASH Memory
63
FLASH Memory
Addr.
$FE08
$FE09
Register Name
Bit 7
6
5
4
BPR7
BPR6
Read:
Write:
(FLCR)
Reset:
Read:
FLASH Block Protect
Write:
Register (FLBPR)
Reset:
3
2
1
Bit 0
HVEN
MASS
ERASE
PGM
BPR5
BPR4
BPR3
BPR2
BPR1
BPR0
= Unimplemented
Figure 4-1. FLASH I/O Register Summary
4.3 Functional Description
The FLASH memory consists of an array of 12,288 bytes for user
memory plus a block of 38 bytes for user interrupt vectors and one byte
for the mask option register. An erased bit reads as logic 1 and a
programmed bit reads as a logic 0. The FLASH memory page size is
defined as 128 bytes, and is the minimum size that can be erased in a
page erase operation. Program and erase operations are facilitated
through control bits in FLASH control register (FLCR). The address
ranges for the FLASH memory are:
$C000–$EFFF; user memory, 12,288 bytes
$FFDA–$FFFF; user interrupt vectors, 38 bytes
$FF80; mask option register
Programming tools are available from Motorola. Contact your local
Motorola representative for more information.
NOTE:
A security feature prevents viewing of the FLASH contents.1
Technical Data
64
FLASH Memory
MOTOROLA
FLASH Memory
4.4 FLASH Control Register
The FLASH control register (FLCR) controls FLASH program and erase
operations.
Address:
Read:
$FE08
Bit 7
6
5
4
2
1
Bit 0
HVEN
MASS
ERASE
PGM
Write:
Reset:
Figure 4-2. FLASH Control Register (FLCR)
HVEN — High Voltage Enable Bit
This read/write bit enables the charge pump to drive high voltages for
program and erase operations in the array. HVEN can only be set if
either PGM = 1 or ERASE = 1 and the proper sequence for program
or erase is followed.
1 = High voltage enabled to array and charge pump on
0 = High voltage disabled to array and charge pump off
MASS — Mass Erase Control Bit
This read/write bit configures the memory for mass erase operation or
block erase operation when the ERASE bit is set.
1 = Mass Erase operation selected
0 = Block Erase operation selected
ERASE — Erase Control Bit
This read/write bit configures the memory for erase operation.
ERASE is interlocked with the PGM bit such that both bits cannot be
equal to 1 or set to 1 at the same time.
1 = Erase operation selected
0 = Erase operation not selected
PGM — Program Control Bit
This read/write bit configures the memory for program operation.
PGM is interlocked with the ERASE bit such that both bits cannot be
1 = Program operation selected
0 = Program operation not selected
MOTOROLA
Technical Data
FLASH Memory
65
FLASH Memory
4.5 FLASH Page Erase Operation
Use the following procedure to erase a page of FLASH memory. A page
consists of 128 consecutive bytes starting from addresses $xx00 or
$xx80. The 38-byte user interrupt vectors area also forms a page. The
38-byte user interrupt vectors cannot be erased by the page erase
operation because of security reasons. Mass erase is required to erase
this page.
1. Set the ERASE bit and clear the MASS bit in the FLASH control
register.
2. Write any data to any FLASH address within the page address
range desired.
3. Wait for a time, tnvs (10µs).
4. Set the HVEN bit.
5. Wait for a time, tErase (1ms).
6. Clear the ERASE bit.
7. Wait for a time, tnvh (5µs).
8. Clear the HVEN bit.
9. After time, trcv (1µs), the memory can be accessed again in read
mode.
NOTE:
Programming and erasing of FLASH locations cannot be performed by
executing code from the FLASH memory; the code must be executed
from RAM. While these operations must be performed in the order as
shown, but other unrelated operations may occur between the steps.
Technical Data
66
FLASH Memory
MOTOROLA
FLASH Memory
4.6 FLASH Mass Erase Operation
Use the following procedure to erase the entire FLASH memory to read
as logic 1:
1. Set both the ERASE bit and the MASS bit in the FLASH control
register.
2. Write any data to any FLASH address within the FLASH memory
address range.
5. Wait for a time tMErase (4ms).
7. Wait for a time, tnvhl (100µs).
mode.
NOTE:
MOTOROLA
Technical Data
FLASH Memory
67
FLASH Memory
4.7 FLASH Program Operation
Programming of the FLASH memory is done on a row basis. A row
consists of 64 consecutive bytes starting from addresses $xx00, $xx40,
$xx80, or $xxC0. The procedure for programming a row of the FLASH
memory is outlined below:
1. Set the PGM bit. This configures the memory for program
operation and enables the latching of address and data for
programming.
2. Write any data to any FLASH address within the row address
range desired.
5. Wait for a time, tpgs (5µs).
6. Write data to the FLASH address to be programmed.
7. Wait for time, tProg (30µs).
8. Repeat step 6 and 7 until all the bytes within the row are
programmed.
9. Clear the PGM bit.
10. Wait for time, tnvh (5µs).
11. Clear the HVEN bit.
12. After time, trcv (1µs), the memory can be accessed again in read
mode.
This program sequence is repeated throughout the memory until all data
is programmed.
NOTE:
shown, but other unrelated operations may occur between the steps. Do
not exceed tProg maximum. See 24.18 FLASH Memory
Characteristics.
Technical Data
68
FLASH Memory
MOTOROLA
FLASH Memory
Figure 4-3 shows a flowchart representation for programming the
FLASH memory.
1
Algorithm for programming
a row (64 bytes) of FLASH memory
Set PGM bit
2
within the row address range desired
3
4
Set HVEN bit
5
6
to be programmed
7
Wait for a time, tProg
Completed
programming
this row?
Y
N
NOTE:
The time between each FLASH address change (step 6 to step 6), or
the time between the last FLASH address programmed
to clearing PGM bit (step 6 to step 9)
must not exceed the maximum programming
time, tProg max.
9
Clear PGM bit
10
11
Clear HVEN bit
12
Wait for a time, trcv
This row program algorithm assumes the row/s
to be programmed are initially erased.
End of Programming
Figure 4-3. FLASH Programming Flowchart
MOTOROLA
Technical Data
FLASH Memory
69
FLASH Memory
4.8 FLASH Protection
Due to the ability of the on-board charge pump to erase and program the
FLASH memory in the target application, provision is made to protect
pages of memory from unintentional erase or program operations due to
system malfunction. This protection is done by use of a FLASH block
protect register (FLBPR). The FLBPR determines the range of the
FLASH memory which is to be protected. The range of the protected
area starts from a location defined by FLBPR and ends to the bottom of
the FLASH memory ($FFFF). When the memory is protected, the HVEN
bit cannot be set in either ERASE or PROGRAM operations.
NOTE:
When the FLBPR is cleared (all 0’s), the entire FLASH memory is
protected from being programmed and erased. When all the bits are set,
the entire FLASH memory is accessible for program and erase.
4.8.1 FLASH Block Protect Register
The FLASH block protect register is implemented as an 8-bit I/O register.
The content of this register determine the starting location of the
protected range within the FLASH memory.
Address:
$FE09
Bit 7
6
5
4
3
2
1
Bit 0
BPR7
BPR6
BPR5
BPR4
BPR3
BPR2
BPR1
BPR0
Read:
Write:
Reset:
Figure 4-4. FLASH Block Protect Register (FLBPR)
BPR[7:0] — FLASH Block Protect Register Bit7 to Bit 0
BPR[7:1] represent bits [13:7] of a 16-bit memory address. Bits
[15:14] are logic 1s and bits [6:0] are logic 0s.
Start address of FLASH block protect
1 1
0 0 0 0 0 0 0
BPR[7:1]
Figure 4-5. FLASH Block Protect Start Address
Technical Data
70
FLASH Memory
MOTOROLA
FLASH Memory
FLASH Protection
BPR0 is used only for BPR[7:0] = $FF, for no block protection.
The resultant 16-bit address is used for specifying the start address
of the FLASH memory for block protection. The FLASH is protected
from this start address to the end of FLASH memory, at $FFFF. With
this mechanism, the protect start address can be XX00 or XX80 (at
page boundaries) within the FLASH memory.
Examples of protect start address:
BPR[7:0]
Start of Address of Protect Range
$00 or $01
$C000 (1100 0000 0000 0000)
The entire FLASH memory is protected.
$02 or $03
$C080 (1100 0000 1000 0000)
$04 or $05
$C100 (1100 0001 0000 0000)
$06 or $07
$C180 (1100 0001 1000 0000)
$08 or $09
$C200 (1100 0010 0000 0000)
and so on...
$F8 or $F9
$FE00 (1111 1110 0000 0000)
$FA or $FB
$FE80 (1111 1110 1000 0000)
$FC or $FD
$FF00 (1111 1111 0000 0000)
$FE
$FF80 (1111 1111 1000 0000)
$FF
The entire FLASH memory is not protected.
Note:
The end address of the protected range is always $FFFF.
MOTOROLA
Technical Data
FLASH Memory
71
FLASH Memory
Technical Data
72
FLASH Memory
MOTOROLA
Section 5. Configuration and Mask Option Registers
(CONFIG & MOR)
5.1 Contents
5.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 73
5.3
Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 74
5.4
Configuration Register 1 (CONFIG1) . . . . . . . . . . . . . . . . . . . .75
5.5
Configuration Register 2 (CONFIG2) . . . . . . . . . . . . . . . . . . . .77
5.6
Mask Option Register (MOR) . . . . . . . . . . . . . . . . . . . . . . . . . . 79
5.2 Introduction
This section describes the configuration registers, CONFIG1 and
CONFIG2; and the mask option register, MOR.
The configuration registers enable or disable these options:
Computer operating properly module (COP)
COP timeout period (218 – 24 or 213 – 24 ICLK cycles)
Low-voltage inhibit (LVI) module power
LVI module reset
LVI module in stop mode
LVI module voltage trip point selection
STOP instruction
Stop mode recovery time (32 ICLK cycles or 4096 ICLK cycles)
Oscillator (internal, RC, and crystal) during stop mode
Serial communications interface clock source (CGMXCLK or fBUS)
Current detect output pin
MOTOROLA
Configuration and Mask Option Registers (CONFIG & MOR)
Technical Data
73
The mask option register selects one of the following oscillator options
as the MCU reference clock:
Addr.
$001D
$001F
$FF80
Internal oscillator
RC oscillator
Crystal oscillator
Register Name
Bit 7
Read: STOP_
Write: ICLKEN
(CONFIG2)†
Reset:
Read:
COPRS
† Write:
(CONFIG1)
Reset:
STOP_
RCLKEN
3
STOP_
OSCCLK1 OSCCLK0
XCLKEN
OSCSEL1 OSCSEL0
(MOR)* Write:
* FLASH register.
5
1
Bit 0
CDOEN SCIBDSRC
SSREC
STOP
COPD
0††
R
R
R
R
R
R
Erased:
1
1
1
1
1
1
1
1
Reset:
U
U
U
U
U
U
U
U
= Unimplemented
†† Reset by POR only.
R
= Reserved
Figure 5-1. CONFIG and MOR Register Summary
5.3 Functional Description
The configuration registers and the mask option register are used in the
initialization of various options. These two types of registers are
configured differently:
Configuration registers — Write-once registers after reset
Mask option register — FLASH register (write by programming)
The configuration registers can be written once after each reset. All of
the configuration register bits are cleared during reset. Since the various
options affect the operation of the MCU, it is recommended that these
registers be written immediately after reset. The configuration registers
are located at $001D and $001F. The configurations register may be
read at anytime.
Technical Data
74
MOTOROLA
NOTE:
The options except LVI5OR3 are one-time writable by the user after
each reset. The LVI5OR3 bit is one-time writable by the user only after
each POR (power-on reset). The CONFIG registers are not in the
FLASH memory but are special registers containing one-time writable
latches after each reset. Upon a reset, the CONFIG registers default to
predetermined settings as shown in Figure 5-2 and Figure 5-3.
The mask option register (MOR) is used for selecting one of the three
clock options for the MCU. The MOR is a byte located in FLASH
memory, and is written to by a FLASH programming routine.
5.4 Configuration Register 1 (CONFIG1)
Address:
$001F
Bit 7
6
5
4
3
2
1
Bit 0
SSREC
STOP
COPD
Read:
COPRS
Write:
Reset:
0*
* Reset by POR only.
Figure 5-2. Configuration Register 1 (CONFIG1)
COPRS — COP Rate Select
COPRS selects the COP time-out period. Reset clears COPRS. (See
Section 21. Computer Operating Properly (COP).)
1 = COP time out period = 213 – 24 ICLK cycles
0 = COP time out period = 218 – 24 ICLK cycles
LVISTOP — LVI Enable in Stop Mode
When the LVIPWRD bit is clear, setting the LVISTOP bit enables the
LVI to operate during stop mode. Reset clears LVISTOP. (See
Section 22. Low-Voltage Inhibit (LVI).)
1 = LVI enabled during stop mode
0 = LVI disabled during stop mode
MOTOROLA
Technical Data
75
LVIRSTD — LVI Reset Disable
LVIRSTD disables the reset signal from the LVI module. (See
1 = LVI module resets disabled
0 = LVI module resets enabled
LVIPWRD — LVI Power Disable Bit
LVIPWRD disables the LVI module. (See Section 22. Low-Voltage
Inhibit (LVI).)
1 = LVI module power disabled
0 = LVI module power enabled
LVI5OR3 — LVI 5V or 3V Operating Mode
LVI5OR3 selects the voltage operating mode of the LVI module. (See
Section 22. Low-Voltage Inhibit (LVI).) The voltage mode selected
for the LVI should match the operating VDD. See Section 24.
Electrical Specifications for the LVI voltage trip points for each of
the modes.
1 = LVI operates in 5V mode
0 = LVI operates in 3V mode
SSREC — Short Stop Recovery
SSREC enables the CPU to exit stop mode with a delay of 32 ICLK
cycles instead of a 4096 ICLK cycle delay.
1 = Stop mode recovery after 32 ICLK cycles
0 = Stop mode recovery after 4096 ICLK cycles
NOTE:
Exiting stop mode by pulling reset will result in the long stop recovery.
If using an external crystal oscillator, and it is disabled during stop mode
(STOP_XCLKEN=0), do not set the SSREC bit.
NOTE:
Technical Data
76
When the LVI is disabled in stop mode (LVISTOP=0), the system
stabilization time for long stop recovery (4096 ICLK cycles) gives a delay
longer than the LVI’s turn-on time. There is no period where the MCU is
not protected from a low power condition. However, when using the
short stop recovery configuration option, the 32 ICLK delay is less than
the LVI’s turn-on time and there exists a period in start-up where the LVI
is not protecting the MCU.
MOTOROLA
STOP — STOP Instruction Enable
STOP enables the STOP instruction.
1 = STOP instruction enabled
0 = STOP instruction treated as illegal opcode
COPD — COP Disable Bit
COPD disables the COP module. (See Section 21. Computer
1 = COP module disabled
0 = COP module enabled
5.5 Configuration Register 2 (CONFIG2)
Address:
$001D
Bit 7
Read:
STOP_
ICLKEN
Write:
Reset:
6
STOP_
RCLKEN
4
3
STOP_
OSCCLK1 OSCCLK0
XCLKEN
1
Bit 0
CDOEN SCIBDSRC
Figure 5-3. Configuration Register 2 (CONFIG2)
STOP_ICLKEN — Internal Oscillator Stop Mode Disable
STOP_ICLKEN disables the internal oscillator during stop mode.
Setting the STOP_ICLKEN bit disables the oscillator during stop
mode. (See 7.4 Internal Oscillator).
Reset clears this bit.
1 = Internal oscillator disabled during stop mode
0 = Internal oscillator enabled to operate during stop mode
STOP_RCLKEN — RC Oscillator Stop Mode Enable
STOP_RCLKEN enables the RC oscillator to continue operating
during stop mode. Setting the STOP_RCLKEN bit allows the
oscillator to operate continuously even during stop mode. This is
useful for driving the timebase module to allow it to generate periodic
wake up while in stop mode. (See Section 8. Clock Generator
Module (CGM) and subsection 8.8.2 Stop Mode.)
1 = RC oscillator enabled to operate during stop mode
0 = RC oscillator disabled during stop mode
MOTOROLA
Technical Data
77
STOP_XCLKEN — Crystal Oscillator Stop Mode Enable
STOP_XCLKEN enables the crystal (x-tal) oscillator to continue
operating during stop mode. Setting the STOP_XCLKEN bit allows
the x-tal oscillator to operate continuously even during stop mode.
This is useful for driving the timebase module to allow it to generate
periodic wake up while in stop mode. (See Section 8. Clock
Generator Module (CGM) and subsection 8.8.2 Stop Mode.)
1 = X-tal oscillator enabled to operate during stop mode
0 = X-tal oscillator disabled during stop mode
OSCCLK1, OSCCLK0 — Oscillator Output Control Bits
OSCCLK1 and OSCCLK0 select which oscillator output to be driven
out as OSCCLK to the timebase module (TBM). Reset clears these
two bits.
OSCCLK1
OSCCLK0
Timebase Clock Source
Internal oscillator (ICLK)
RC oscillator (RCCLK)
1
X-tal oscillator (XTAL)
1
1
Not used
CDOEN — Current-Flow Detect Output Enable
CDOEN enables the port pin PC0/PWM0/CD as the CD output pin for
the current detect flag (CDIF) from the analog module. Reset clears
the CDOEN bit.
1 = PCO/PWMO/CD pin enabled as CD output pin,
PTC0 and PWM0 functions are disabled.
0 = PTC0/PWM/CD pin disabled as CD output pin,
PTC0 or PWM0 functions are available; see 18.5.1 Port C
Data Register (PTC).
Technical Data
78
MOTOROLA
SCIBDSRC — SCI Baud Rate Clock Source
SCIBDSRC selects the clock source used for the SCI. The setting of
this bit affects the frequency at which the SCI operates.
1 = Internal data bus clock, fBUS, is used as clock source for SCI
0 = Oscillator clock, CGMXCLK, is used as clock source for SCI
5.6 Mask Option Register (MOR)
Address:
$FF80
Bit 7
6
5
4
3
2
1
Bit 0
R
R
R
R
R
R
Read:
OSCSEL1 OSCSEL0
Write:
Erased:
1
1
1
1
1
1
1
1
Reset:
U
U
U
U
U
U
U
U
R
= Reserved
Figure 5-4. Mask Option Register (MOR)
OSCSEL1, OSCSEL0 — Oscillator Selection Bits
OSCSEL1 and OSCSEL0 select which oscillator is used for the MCU
CGMXCLK clock. The erase state of these two bits is logic 1. These
bits are unaffected by reset. (See Table 5-1).
Bits 5–0 — Should be left as 1’s.
MOTOROLA
Technical Data
79
Table 5-1. CGMXCLK Clock Selection
OSCSEL1
OSCSEL0
CGMXCLK
OSC2 pin
ICLK
fBUS
Internal oscillator generates the CGMXCLK.
1
RCCLK
fBUS
RC oscillator generates the CGMXCLK.
Internal oscillator is available after each POR
or reset.
1
1
X-TAL
Inverting
output of
XTAL
X-tal oscillator generates the CGMXCLK.
or reset.
NOTE:
Technical Data
80
Comments
Not used
The internal oscillator is a free running oscillator and is available after
each POR or reset. It is turned-off in stop mode by clearing the
STOP_ICLKEN bit in CONFIG2.
MOTOROLA
Section 6. Central Processor Unit (CPU)
6.1 Contents
6.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 81
6.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 82
6.4
CPU Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 82
6.4.1
Accumulator . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .83
6.4.2
Index Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 84
6.4.3
Stack Pointer . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 84
6.4.4
Program Counter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 85
6.4.5
Condition Code Register . . . . . . . . . . . . . . . . . . . . . . . . . . .85
6.5
Arithmetic/Logic Unit (ALU) . . . . . . . . . . . . . . . . . . . . . . . . . . .88
6.6
Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .88
6.6.1
Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 88
6.6.2
Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 89
6.7
CPU During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . 89
6.8
6.9
Opcode Map . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 89
6.2 Introduction
The M68HC08 CPU (central processor unit) is an enhanced and fully
object-code-compatible version of the M68HC05 CPU. The CPU08
Reference Manual (Motorola document order number CPU08RM/AD)
contains a description of the CPU instruction set, addressing modes,
and architecture.
MOTOROLA
Technical Data
81
6.3 Features
Object code fully upward-compatible with M68HC05 Family
16-bit stack pointer with stack manipulation instructions
16-bit index register with x-register manipulation instructions
8-MHz CPU internal bus frequency
64K-byte program/data memory space
16 addressing modes
Memory-to-memory data moves without using accumulator
Fast 8-bit by 8-bit multiply and 16-bit by 8-bit divide instructions
Enhanced binary-coded decimal (BCD) data handling
Modular architecture with expandable internal bus definition for
extension of addressing range beyond 64K-bytes
Low-power stop and wait modes
6.4 CPU Registers
Figure 6-1 shows the five CPU registers. CPU registers are not part of
the memory map.
Technical Data
82
MOTOROLA
CPU Registers
7
ACCUMULATOR (A)
15
H
X
INDEX REGISTER (H:X)
STACK POINTER (SP)
PROGRAM COUNTER (PC)
7
V 1 1 H I N Z C
CONDITION CODE REGISTER (CCR)
CARRY/BORROW FLAG
ZERO FLAG
NEGATIVE FLAG
INTERRUPT MASK
HALF-CARRY FLAG
TWO’S COMPLEMENT OVERFLOW FLAG
Figure 6-1. CPU Registers
6.4.1 Accumulator
The accumulator is a general-purpose 8-bit register. The CPU uses the
accumulator to hold operands and the results of arithmetic/logic
operations.
Bit 7
6
5
4
3
2
1
Bit 0
Read:
Write:
Reset:
Unaffected by reset
Figure 6-2. Accumulator (A)
MOTOROLA
Technical Data
83
6.4.2 Index Register
The 16-bit index register allows indexed addressing of a 64K-byte
memory space. H is the upper byte of the index register, and X is the
lower byte. H:X is the concatenated 16-bit index register.
In the indexed addressing modes, the CPU uses the contents of the
index register to determine the conditional address of the operand.
The index register can serve also as a temporary data storage location.
Bit
15
14
13
12
11
10
9
8
7
6
5
4
3
2
1
Bit
X
X
X
X
X
X
X
X
Read:
Write:
Reset:
X = Indeterminate
Figure 6-3. Index Register (H:X)
6.4.3 Stack Pointer
The stack pointer is a 16-bit register that contains the address of the next
location on the stack. During a reset, the stack pointer is preset to
$00FF. The reset stack pointer (RSP) instruction sets the least
significant byte to $FF and does not affect the most significant byte. The
stack pointer decrements as data is pushed onto the stack and
increments as data is pulled from the stack.
In the stack pointer 8-bit offset and 16-bit offset addressing modes, the
stack pointer can function as an index register to access data on the
stack. The CPU uses the contents of the stack pointer to determine the
Technical Data
84
MOTOROLA
CPU Registers
Bit
15
14
13
12
11
10
9
8
7
6
5
4
3
2
1
Bit
1
1
1
1
1
1
1
Read:
Write:
Reset:
Figure 6-4. Stack Pointer (SP)
NOTE:
The location of the stack is arbitrary and may be relocated anywhere in
RAM. Moving the SP out of page 0 ($0000 to $00FF) frees direct
address (page 0) space. For correct operation, the stack pointer must
point only to RAM locations.
6.4.4 Program Counter
The program counter is a 16-bit register that contains the address of the
next instruction or operand to be fetched.
Normally, the program counter automatically increments to the next
sequential memory location every time an instruction or operand is
fetched. Jump, branch, and interrupt operations load the program
counter with an address other than that of the next sequential location.
During reset, the program counter is loaded with the reset vector
address located at $FFFE and $FFFF. The vector address is the
address of the first instruction to be executed after exiting the reset state.
Bit
15
14
13
12
11
10
9
8
7
6
5
4
3
2
1
Bit
Read:
Write:
Reset:
Loaded with Vector from $FFFE and $FFFF
Figure 6-5. Program Counter (PC)
6.4.5 Condition Code Register
The 8-bit condition code register contains the interrupt mask and five
flags that indicate the results of the instruction just executed. Bits 6 and
MOTOROLA
Technical Data
85
5 are set permanently to logic 1. The following paragraphs describe the
functions of the condition code register.
Bit 7
6
5
4
3
2
1
Bit 0
V
1
1
H
I
N
Z
C
X
1
1
X
1
X
X
X
Read:
Write:
Reset:
X = Indeterminate
Figure 6-6. Condition Code Register (CCR)
V — Overflow Flag
The CPU sets the overflow flag when a two's complement overflow
occurs. The signed branch instructions BGT, BGE, BLE, and BLT use
the overflow flag.
1 = Overflow
0 = No overflow
H — Half-Carry Flag
The CPU sets the half-carry flag when a carry occurs between
accumulator bits 3 and 4 during an add-without-carry (ADD) or addwith-carry (ADC) operation. The half-carry flag is required for binarycoded decimal (BCD) arithmetic operations. The DAA instruction uses
the states of the H and C flags to determine the appropriate correction
factor.
1 = Carry between bits 3 and 4
0 = No carry between bits 3 and 4
Technical Data
86
MC68HC908SR12•MC68HC08SR12 — Rev. 4.0
MOTOROLA
CPU Registers
I — Interrupt Mask
When the interrupt mask is set, all maskable CPU interrupts are
disabled. CPU interrupts are enabled when the interrupt mask is
cleared. When a CPU interrupt occurs, the interrupt mask is set
automatically after the CPU registers are saved on the stack, but
before the interrupt vector is fetched.
1 = Interrupts disabled
0 = Interrupts enabled
NOTE:
To maintain M6805 Family compatibility, the upper byte of the index
register (H) is not stacked automatically. If the interrupt service routine
modifies H, then the user must stack and unstack H using the PSHH and
PULH instructions.
After the I bit is cleared, the highest-priority interrupt request is
serviced first.
A return-from-interrupt (RTI) instruction pulls the CPU registers from
the stack and restores the interrupt mask from the stack. After any
reset, the interrupt mask is set and can be cleared only by the clear
interrupt mask software instruction (CLI).
N — Negative flag
The CPU sets the negative flag when an arithmetic operation, logic
operation, or data manipulation produces a negative result, setting bit
7 of the result.
1 = Negative result
0 = Non-negative result
Z — Zero flag
The CPU sets the zero flag when an arithmetic operation, logic
operation, or data manipulation produces a result of $00.
1 = Zero result
0 = Non-zero result
MOTOROLA
Technical Data
87
C — Carry/Borrow Flag
The CPU sets the carry/borrow flag when an addition operation
produces a carry out of bit 7 of the accumulator or when a subtraction
operation requires a borrow. Some instructions — such as bit test and
branch, shift, and rotate — also clear or set the carry/borrow flag.
1 = Carry out of bit 7
0 = No carry out of bit 7
6.5 Arithmetic/Logic Unit (ALU)
The ALU performs the arithmetic and logic operations defined by the
instruction set.
Refer to the CPU08 Reference Manual (Motorola document order
number CPU08RM/AD) for a description of the instructions and
addressing modes and more detail about the architecture of the CPU.
6.6 Low-Power Modes
The WAIT and STOP instructions put the MCU in low power-consumption
standby modes.
6.6.1 Wait Mode
The WAIT instruction:
Technical Data
88
Clears the interrupt mask (I bit) in the condition code register,
enabling interrupts. After exit from wait mode by interrupt, the I bit
remains clear. After exit by reset, the I bit is set.
Disables the CPU clock
MOTOROLA
6.6.2 Stop Mode
The STOP instruction:
enabling external interrupts. After exit from stop mode by external
interrupt, the I bit remains clear. After exit by reset, the I bit is set.
After exiting stop mode, the CPU clock begins running after the oscillator
stabilization delay.
6.7 CPU During Break Interrupts
If a break module is present on the MCU, the CPU starts a break
interrupt by:
Loading the instruction register with the SWI instruction
Loading the program counter with $FFFC:$FFFD or with
$FEFC:$FEFD in monitor mode
The break interrupt begins after completion of the CPU instruction in
progress. If the break address register match occurs on the last cycle of
a CPU instruction, the break interrupt begins immediately.
A return-from-interrupt instruction (RTI) in the break routine ends the
break interrupt and returns the MCU to normal operation if the break
interrupt has been deasserted.
6.8 Instruction Set Summary
6.9 Opcode Map
See Table 6-2.
MOTOROLA
Technical Data
89
V H I N Z C
ADC #opr
ADC opr
ADC opr
ADC opr,X
ADC opr,X
ADC ,X
ADC opr,SP
ADC opr,SP
A ← (A) + (M) + (C)
Add with Carry
IMM
DIR
EXT
IX2
IX1
IX
SP1
SP2
A9
B9
C9
D9
E9
F9
9EE9
9ED9
ii
dd
hh ll
ee ff
ff
IMM
DIR
EXT
IX2
IX1
IX
SP1
SP2
AB
BB
CB
DB
EB
FB
9EEB
9EDB
ii
dd
hh ll
ee ff
ff
ADD #opr
ADD opr
ADD opr
ADD opr,X
ADD opr,X
ADD ,X
ADD opr,SP
ADD opr,SP
Add without Carry
AIS #opr
Add Immediate Value (Signed) to SP
SP ← (SP) + (16 « M)
– – – – – – IMM
AIX #opr
Add Immediate Value (Signed) to H:X
H:X ← (H:X) + (16 « M)
A ← (A) & (M)
AND #opr
AND opr
AND opr
AND opr,X
AND opr,X
AND ,X
AND opr,SP
AND opr,SP
ASL opr
ASLA
ASLX
ASL opr,X
ASL ,X
ASL opr,SP
Logical AND
Arithmetic Shift Left
(Same as LSL)
ASR opr
ASRA
ASRX
ASR opr,X
ASR opr,X
ASR opr,SP
Arithmetic Shift Right
BCC rel
Branch if Carry Bit Clear
BCLR n, opr
Technical Data
90
A ← (A) + (M)
C
b7
b0
C
b7
Clear Bit n in M
b0
PC ← (PC) + 2 + rel ? (C) = 0
Mn ← 0
ff
ee ff
Cycles
Effect on
CCR
Description
Operand
Operation
Opcode
Source
Form
Address
Mode
Table 6-1. Instruction Set Summary
2
3
4
4
3
2
4
5
ff
ee ff
2
3
4
4
3
2
4
5
A7
ii
2
– – – – – – IMM
AF
ii
2
IMM
DIR
EXT
IX2
0 – – ↕ ↕ –
IX1
IX
SP1
SP2
A4
B4
C4
D4
E4
F4
9EE4
9ED4
ii
dd
hh ll
ee ff
ff
2
3
4
4
3
2
4
5
DIR
INH
INH
IX1
IX
SP1
38
48
58
68
78
9E68
dd
DIR
INH
INH
IX1
IX
SP1
37
47
57
67
77
9E67
dd
ff
4
1
1
4
3
5
– – – – – – REL
24
rr
3
DIR (b0)
DIR (b1)
DIR (b2)
DIR (b3)
DIR (b4)
DIR (b5)
DIR (b6)
DIR (b7)
11
13
15
17
19
1B
1D
1F
dd
dd
dd
dd
dd
dd
dd
dd
4
4
4
4
4
4
4
4
ff
ee ff
ff
ff
ff
4
1
1
4
3
5
MOTOROLA
Opcode Map
Effect on
CCR
V H I N Z C
Cycles
Description
Operand
Operation
Opcode
Source
Form
Address
Mode
Table 6-1. Instruction Set Summary (Continued)
BCS rel
Branch if Carry Bit Set (Same as BLO)
PC ← (PC) + 2 + rel ? (C) = 1
– – – – – – REL
25
rr
3
BEQ rel
Branch if Equal
PC ← (PC) + 2 + rel ? (Z) = 1
– – – – – – REL
27
rr
3
BGE opr
Branch if Greater Than or Equal To
(Signed Operands)
PC ← (PC) + 2 + rel ? (N ⊕ V) = 0
– – – – – – REL
90
rr
3
BGT opr
Branch if Greater Than (Signed
Operands)
PC ← (PC) + 2 +rel ? (Z) | (N ⊕ V) = 0 – – – – – – REL
92
rr
3
BHCC rel
Branch if Half Carry Bit Clear
PC ← (PC) + 2 + rel ? (H) = 0
– – – – – – REL
28
rr
3
BHCS rel
Branch if Half Carry Bit Set
PC ← (PC) + 2 + rel ? (H) = 1
– – – – – – REL
29
rr
BHI rel
Branch if Higher
PC ← (PC) + 2 + rel ? (C) | (Z) = 0
– – – – – – REL
22
rr
3
BHS rel
Branch if Higher or Same
(Same as BCC)
– – – – – – REL
24
rr
3
BIH rel
Branch if IRQ Pin High
PC ← (PC) + 2 + rel ? IRQ = 1
– – – – – – REL
2F
rr
3
BIL rel
Branch if IRQ Pin Low
PC ← (PC) + 2 + rel ? IRQ = 0
– – – – – – REL
2E
rr
3
(A) & (M)
IMM
DIR
EXT
IX2
0 – – ↕ ↕ –
IX1
IX
SP1
SP2
A5
B5
C5
D5
E5
F5
9EE5
9ED5
ii
dd
hh ll
ee ff
ff
ff
ee ff
2
3
4
4
3
2
4
5
93
rr
3
BIT #opr
BIT opr
BIT opr
BIT opr,X
BIT opr,X
BIT ,X
BIT opr,SP
BIT opr,SP
Bit Test
BLE opr
Branch if Less Than or Equal To
(Signed Operands)
BLO rel
Branch if Lower (Same as BCS)
BLS rel
PC ← (PC) + 2 +rel ? (Z) | (N ⊕ V) = 1 – – – – – – REL
3
– – – – – – REL
25
rr
3
Branch if Lower or Same
PC ← (PC) + 2 + rel ? (C) | (Z) = 1
– – – – – – REL
23
rr
3
BLT opr
Branch if Less Than (Signed Operands)
PC ← (PC) + 2 + rel ? (N ⊕ V) =1
– – – – – – REL
91
rr
3
BMC rel
Branch if Interrupt Mask Clear
PC ← (PC) + 2 + rel ? (I) = 0
– – – – – – REL
2C
rr
3
BMI rel
Branch if Minus
PC ← (PC) + 2 + rel ? (N) = 1
– – – – – – REL
2B
rr
3
BMS rel
Branch if Interrupt Mask Set
PC ← (PC) + 2 + rel ? (I) = 1
– – – – – – REL
2D
rr
3
BNE rel
Branch if Not Equal
PC ← (PC) + 2 + rel ? (Z) = 0
– – – – – – REL
26
rr
3
BPL rel
Branch if Plus
PC ← (PC) + 2 + rel ? (N) = 0
– – – – – – REL
2A
rr
3
BRA rel
Branch Always
PC ← (PC) + 2 + rel
– – – – – – REL
rr
3
MOTOROLA
Technical Data
91
DIR (b0)
DIR (b1)
DIR (b2)
DIR (b3)
DIR (b4)
DIR (b5)
DIR (b6)
DIR (b7)
01
03
05
07
09
0B
0D
0F
dd rr
dd rr
dd rr
dd rr
dd rr
dd rr
dd rr
dd rr
5
5
5
5
5
5
5
5
– – – – – – REL
21
rr
3
PC ← (PC) + 3 + rel ? (Mn) = 1
DIR (b0)
DIR (b1)
DIR (b2)
DIR (b3)
DIR (b4)
DIR (b5)
DIR (b6)
DIR (b7)
00
02
04
06
08
0A
0C
0E
dd rr
dd rr
dd rr
dd rr
dd rr
dd rr
dd rr
dd rr
5
5
5
5
5
5
5
5
Mn ← 1
DIR (b0)
DIR (b1)
DIR (b2)
DIR (b3)
DIR (b4)
DIR (b5)
DIR (b6)
DIR (b7)
10
12
14
16
18
1A
1C
1E
dd
dd
dd
dd
dd
dd
dd
dd
4
4
4
4
4
4
4
4
– – – – – – REL
AD
rr
4
dd rr
ii rr
ii rr
ff rr
rr
ff rr
5
4
4
5
4
6
Description
V H I N Z C
BRCLR n,opr,rel Branch if Bit n in M Clear
BRN rel
Branch Never
BRSET n,opr,rel Branch if Bit n in M Set
BSET n,opr
BSR rel
Set Bit n in M
Branch to Subroutine
CBEQ opr,rel
CBEQA #opr,rel
CBEQX #opr,rel
Compare and Branch if Equal
CBEQ opr,X+,rel
CBEQ X+,rel
CBEQ opr,SP,rel
PC ← (PC) + 3 + rel ? (Mn) = 0
PC ← (PC) + 2
PC ← (PC) + 2; push (PCL)
SP ← (SP) – 1; push (PCH)
SP ← (SP) – 1
PC ← (PC) + rel
DIR
PC ← (PC) + 3 + rel ? (A) – (M) = $00
IMM
IMM
PC ← (PC) + 3 + rel ? (X) – (M) = $00
IX1+
PC ← (PC) + 2 + rel ? (A) – (M) = $00
IX+
PC ← (PC) + 4 + rel ? (A) – (M) = $00
SP1
31
41
51
61
71
9E61
Cycles
Operand
Effect on
CCR
Opcode
Operation
Address
Mode
Source
Form
CLC
Clear Carry Bit
C←0
– – – – – 0 INH
98
1
CLI
Clear Interrupt Mask
I←0
– – 0 – – – INH
9A
2
M ← $00
A ← $00
X ← $00
H ← $00
M ← $00
M ← $00
M ← $00
DIR
INH
INH
0 – – 0 1 – INH
IX1
IX
SP1
3F
4F
5F
8C
6F
7F
9E6F
CLR opr
CLRA
CLRX
CLRH
CLR opr,X
CLR ,X
CLR opr,SP
Technical Data
92
Clear
dd
ff
ff
3
1
1
1
3
2
4
MOTOROLA
Opcode Map
Effect on
CCR
V H I N Z C
CMP #opr
CMP opr
CMP opr
CMP opr,X
CMP opr,X
CMP ,X
CMP opr,SP
CMP opr,SP
Compare A with M
(A) – (M)
COM opr
COMA
COMX
COM opr,X
COM ,X
COM opr,SP
Complement (One’s Complement)
CPHX #opr
CPHX opr
Compare H:X with M
CPX #opr
CPX opr
CPX opr
CPX ,X
CPX opr,X
CPX opr,X
CPX opr,SP
CPX opr,SP
Compare X with M
DAA
Decimal Adjust A
(H:X) – (M:M + 1)
(X) – (M)
(A)10
DBNZ opr,rel
DBNZA rel
DBNZX rel
Decrement and Branch if Not Zero
DBNZ opr,X,rel
DBNZ X,rel
DBNZ opr,SP,rel
DEC opr
DECA
DECX
DEC opr,X
DEC ,X
DEC opr,SP
Decrement
DIV
Divide
M ← (M) = $FF – (M)
A ← (A) = $FF – (M)
X ← (X) = $FF – (M)
M ← (M) = $FF – (M)
M ← (M) = $FF – (M)
M ← (M) = $FF – (M)
A1
B1
C1
D1
E1
F1
9EE1
9ED1
ii
dd
hh ll
ee ff
ff
DIR
INH
INH
0 – – ↕ ↕ 1
IX1
IX
SP1
33
43
53
63
73
9E63
dd
ff
65
75
ii ii+1
dd
3
4
IMM
DIR
EXT
IX2
IX1
IX
SP1
SP2
A3
B3
C3
D3
E3
F3
9EE3
9ED3
ii
dd
hh ll
ee ff
ff
2
3
4
4
3
2
4
5
U – – ↕ ↕ ↕ INH
72
IMM
DIR
ff
ff
ee ff
2
3B
4B
5B
6B
7B
9E6B
dd rr
rr
rr
ff rr
rr
ff rr
dd
M ← (M) – 1
A ← (A) – 1
X ← (X) – 1
M ← (M) – 1
M ← (M) – 1
M ← (M) – 1
DIR
INH
INH
IX1
IX
SP1
3A
4A
5A
6A
7A
9E6A
A ← (H:A)/(X)
H ← Remainder
– – – – ↕ ↕ INH
52
ff
ee ff
2
3
4
4
3
2
4
5
4
1
1
4
3
5
A ← (A) –1 or M ← (M) –1 or X← (X) –1
DIR
PC ← (PC) + 3 + rel ? (result) ≠ 0
INH
PC ← (PC) + 2 + rel ? (result) ≠ 0
– – – – – – INH
IX1
IX
PC ← (PC) + 4 + rel ? (result) ≠ 0
SP1
MOTOROLA
IMM
DIR
EXT
IX2
IX1
IX
SP1
SP2
Cycles
Description
Operand
Operation
Opcode
Source
Form
Address
Mode
ff
ff
5
3
3
5
4
6
4
1
1
4
3
5
7
Technical Data
93
V H I N Z C
EOR #opr
EOR opr
EOR opr
EOR opr,X
EOR opr,X
EOR ,X
EOR opr,SP
EOR opr,SP
INC opr
INCA
INCX
INC opr,X
INC ,X
INC opr,SP
JMP opr
JMP opr
JMP opr,X
JMP opr,X
JMP ,X
JSR opr
JSR opr
JSR opr,X
JSR opr,X
JSR ,X
LDHX #opr
LDHX opr
Load H:X from M
Technical Data
94
ii
dd
hh ll
ee ff
ff
M ← (M) + 1
A ← (A) + 1
X ← (X) + 1
M ← (M) + 1
M ← (M) + 1
M ← (M) + 1
DIR
INH
INH
IX1
IX
SP1
3C
4C
5C
6C
7C
9E6C
dd
PC ← Jump Address
DIR
EXT
– – – – – – IX2
IX1
IX
BC
CC
DC
EC
FC
dd
hh ll
ee ff
ff
2
3
4
3
2
PC ← (PC) + n (n = 1, 2, or 3)
Push (PCL); SP ← (SP) – 1
Push (PCH); SP ← (SP) – 1
PC ← Unconditional Address
DIR
EXT
– – – – – – IX2
IX1
IX
BD
CD
DD
ED
FD
dd
hh ll
ee ff
ff
4
5
6
5
4
A ← (M)
IMM
DIR
EXT
IX2
0 – – ↕ ↕ –
IX1
IX
SP1
SP2
A6
B6
C6
D6
E6
F6
9EE6
9ED6
ii
dd
hh ll
ee ff
ff
ff
ee ff
2
3
4
4
3
2
4
5
ii jj
dd
3
4
2
3
4
4
3
2
4
5
A ← (A ⊕ M)
Jump
Load A from M
LSL opr
LSLA
LSLX
LSL opr,X
LSL ,X
LSL opr,SP
A8
B8
C8
D8
E8
F8
9EE8
9ED8
Increment
LDA #opr
LDA opr
LDA opr
LDA opr,X
LDA opr,X
LDA ,X
LDA opr,SP
LDA opr,SP
LDX #opr
LDX opr
LDX opr
LDX opr,X
LDX opr,X
LDX ,X
LDX opr,SP
LDX opr,SP
IMM
DIR
EXT
IX2
0 – – ↕ ↕ –
IX1
IX
SP1
SP2
Exclusive OR M with A
Jump to Subroutine
H:X ← (M:M + 1)
0 – – ↕ ↕ –
X ← (M)
Load X from M
Logical Shift Left
(Same as ASL)
Cycles
Effect on
CCR
Description
Operand
Operation
Opcode
Source
Form
Address
Mode
C
b7
b0
IMM
DIR
45
55
ff
ee ff
ff
ff
IMM
DIR
EXT
IX2
0 – – ↕ ↕ –
IX1
IX
SP1
SP2
AE
BE
CE
DE
EE
FE
9EEE
9EDE
ii
dd
hh ll
ee ff
ff
DIR
INH
INH
IX1
IX
SP1
38
48
58
68
78
9E68
dd
ff
ee ff
ff
ff
2
3
4
4
3
2
4
5
4
1
1
4
3
5
4
1
1
4
3
5
MOTOROLA
Opcode Map
V H I N Z C
LSR opr
LSRA
LSRX
LSR opr,X
LSR ,X
LSR opr,SP
Logical Shift Right
DIR
INH
INH
↕ – – 0 ↕ ↕
IX1
IX
SP1
34
44
54
64
74
9E64
DD
DIX+
0 – – ↕ ↕ –
IMD
IX+D
4E
5E
6E
7E
X:A ← (X) × (A)
– 0 – – – 0 INH
42
M ← –(M) = $00 – (M)
A ← –(A) = $00 – (A)
X ← –(X) = $00 – (X)
DIR
INH
INH
IX1
IX
SP1
30
40
50
60
70
9E60
None
– – – – – – INH
9D
1
A ← (A[3:0]:A[7:4])
– – – – – – INH
62
3
A ← (A) | (M)
IMM
DIR
EXT
IX2
0 – – ↕ ↕ –
IX1
IX
SP1
SP2
AA
BA
CA
DA
EA
FA
9EEA
9EDA
C
b7
MOV opr,opr
MOV opr,X+
MOV #opr,opr
MOV X+,opr
Move
MUL
Unsigned multiply
b0
(M)Destination ← (M)Source
H:X ← (H:X) + 1 (IX+D, DIX+)
NEG opr
NEGA
NEGX
NEG opr,X
NEG ,X
NEG opr,SP
Negate (Two’s Complement)
NOP
No Operation
NSA
Nibble Swap A
dd
Cycles
Effect on
CCR
Description
Operand
Operation
Opcode
Source
Form
Address
Mode
ff
4
1
1
4
3
5
dd dd
dd
ii dd
dd
5
4
4
4
ff
5
dd
ff
ff
4
1
1
4
3
5
ORA #opr
ORA opr
ORA opr
ORA opr,X
ORA opr,X
ORA ,X
ORA opr,SP
ORA opr,SP
Inclusive OR A and M
PSHA
Push A onto Stack
Push (A); SP ← (SP) – 1
– – – – – – INH
87
2
PSHH
Push H onto Stack
Push (H); SP ← (SP) – 1
– – – – – – INH
8B
2
PSHX
Push X onto Stack
Push (X); SP ← (SP) – 1
– – – – – – INH
89
2
PULA
Pull A from Stack
SP ← (SP + 1); Pull (A)
– – – – – – INH
86
2
PULH
Pull H from Stack
SP ← (SP + 1); Pull (H)
– – – – – – INH
8A
2
PULX
Pull X from Stack
SP ← (SP + 1); Pull (X)
– – – – – – INH
88
2
C
DIR
INH
INH
IX1
IX
SP1
39
49
59
69
79
9E69
ROL opr
ROLA
ROLX
ROL opr,X
ROL ,X
ROL opr,SP
Rotate Left through Carry
b7
b0
MOTOROLA
ii
dd
hh ll
ee ff
ff
ff
ee ff
dd
ff
ff
2
3
4
4
3
2
4
5
4
1
1
4
3
5
Technical Data
95
V H I N Z C
ROR opr
RORA
RORX
ROR opr,X
ROR ,X
ROR opr,SP
Rotate Right through Carry
RSP
Reset Stack Pointer
RTI
Return from Interrupt
RTS
Return from Subroutine
DIR
INH
INH
IX1
IX
SP1
36
46
56
66
76
9E66
SP ← $FF
– – – – – – INH
9C
1
SP ← (SP) + 1; Pull (CCR)
SP ← (SP) + 1; Pull (A)
SP ← (SP) + 1; Pull (X)
SP ← (SP) + 1; Pull (PCH)
SP ← (SP) + 1; Pull (PCL)
↕ ↕ ↕ ↕ ↕ ↕ INH
80
7
SP ← SP + 1; Pull (PCH)
SP ← SP + 1; Pull (PCL)
– – – – – – INH
81
4
A ← (A) – (M) – (C)
IMM
DIR
EXT
IX2
IX1
IX
SP1
SP2
A2
B2
C2
D2
E2
F2
9EE2
9ED2
C
b7
b0
dd
Cycles
Effect on
CCR
Description
Operand
Operation
Opcode
Source
Form
Address
Mode
ff
ff
4
1
1
4
3
5
SBC #opr
SBC opr
SBC opr
SBC opr,X
SBC opr,X
SBC ,X
SBC opr,SP
SBC opr,SP
Subtract with Carry
SEC
Set Carry Bit
C←1
– – – – – 1 INH
99
1
SEI
Set Interrupt Mask
I←1
– – 1 – – – INH
9B
2
M ← (A)
DIR
EXT
IX2
0 – – ↕ ↕ – IX1
IX
SP1
SP2
B7
C7
D7
E7
F7
9EE7
9ED7
(M:M + 1) ← (H:X)
0 – – ↕ ↕ – DIR
35
I ← 0; Stop Oscillator
– – 0 – – – INH
8E
M ← (X)
DIR
EXT
IX2
0 – – ↕ ↕ – IX1
IX
SP1
SP2
BF
CF
DF
EF
FF
9EEF
9EDF
STA opr
STA opr
STA opr,X
STA opr,X
STA ,X
STA opr,SP
STA opr,SP
Store A in M
STHX opr
Store H:X in M
STOP
Enable IRQ Pin; Stop Oscillator
STX opr
STX opr
STX opr,X
STX opr,X
STX ,X
STX opr,SP
STX opr,SP
Technical Data
96
Store X in M
ii
dd
hh ll
ee ff
ff
ff
ee ff
dd
hh ll
ee ff
ff
2
3
4
4
3
2
4
5
ff
ee ff
3
4
4
3
2
4
5
dd
4
1
dd
hh ll
ee ff
ff
ff
ee ff
3
4
4
3
2
4
5
MOTOROLA
Opcode Map
Effect on
CCR
V H I N Z C
SUB #opr
SUB opr
SUB opr
SUB opr,X
SUB opr,X
SUB ,X
SUB opr,SP
SUB opr,SP
A ← (A) – (M)
Subtract
ii
dd
hh ll
ee ff
ff
Cycles
Description
Operand
Operation
Opcode
Source
Form
Address
Mode
IMM
DIR
EXT
IX2
IX1
IX
SP1
SP2
A0
B0
C0
D0
E0
F0
9EE0
9ED0
– – 1 – – – INH
83
9
ff
ee ff
2
3
4
4
3
2
4
5
SWI
Software Interrupt
PC ← (PC) + 1; Push (PCL)
SP ← (SP) – 1; Push (PCH)
SP ← (SP) – 1; Push (X)
SP ← (SP) – 1; Push (A)
SP ← (SP) – 1; Push (CCR)
SP ← (SP) – 1; I ← 1
PCH ← Interrupt Vector High Byte
PCL ← Interrupt Vector Low Byte
TAP
Transfer A to CCR
CCR ← (A)
↕ ↕ ↕ ↕ ↕ ↕ INH
84
2
TAX
Transfer A to X
X ← (A)
– – – – – – INH
97
1
TPA
Transfer CCR to A
A ← (CCR)
– – – – – – INH
85
1
(A) – $00 or (X) – $00 or (M) – $00
DIR
INH
INH
0 – – ↕ ↕ –
IX1
IX
SP1
3D
4D
5D
6D
7D
9E6D
H:X ← (SP) + 1
– – – – – – INH
95
2
A ← (X)
– – – – – – INH
9F
1
(SP) ← (H:X) – 1
– – – – – – INH
94
2
TST opr
TSTA
TSTX
TST opr,X
TST ,X
TST opr,SP
Test for Negative or Zero
TSX
Transfer SP to H:X
TXA
Transfer X to A
TXS
Transfer H:X to SP
MOTOROLA
dd
ff
ff
3
1
1
3
2
4
Technical Data
97
V H I N Z C
A
C
CCR
dd
dd rr
DD
DIR
DIX+
ee ff
EXT
ff
H
H
hh ll
I
ii
IMD
IMM
INH
IX
IX+
IX+D
IX1
IX1+
IX2
M
N
Accumulator
Carry/borrow bit
Condition code register
Direct address of operand
Direct address of operand and relative offset of branch instruction
Direct to direct addressing mode
Direct addressing mode
Direct to indexed with post increment addressing mode
High and low bytes of offset in indexed, 16-bit offset addressing
Extended addressing mode
Offset byte in indexed, 8-bit offset addressing
Half-carry bit
Index register high byte
High and low bytes of operand address in extended addressing
Interrupt mask
Immediate operand byte
Immediate source to direct destination addressing mode
Immediate addressing mode
Inherent addressing mode
Indexed, no offset addressing mode
Indexed, no offset, post increment addressing mode
Indexed with post increment to direct addressing mode
Indexed, 8-bit offset addressing mode
Indexed, 8-bit offset, post increment addressing mode
Indexed, 16-bit offset addressing mode
Memory location
Negative bit
Technical Data
98
n
opr
PC
PCH
PCL
REL
rel
rr
SP1
SP2
SP
U
V
X
Z
Cycles
Effect on
CCR
Description
Operand
Operation
Opcode
Source
Form
Address
Mode
Any bit
Operand (one or two bytes)
Program counter
Program counter high byte
Program counter low byte
Relative addressing mode
Relative program counter offset byte
Stack pointer, 8-bit offset addressing mode
Stack pointer 16-bit offset addressing mode
Stack pointer
Undefined
Overflow bit
Index register low byte
Zero bit
Logical AND
Logical OR
Logical EXCLUSIVE OR
Contents of
Negation (two’s complement)
Immediate value
Sign extend
Loaded with
If
Concatenated with
Set or cleared
Not affected
MOTOROLA
MOTOROLA
Table 6-2. Opcode Map
Bit Manipulation
DIR
DIR
MSB
Branch
REL
DIR
INH
3
4
2
5
BRSET0
3 DIR
5
BRCLR0
3 DIR
5
BRSET1
3 DIR
5
BRCLR1
3 DIR
5
BRSET2
3 DIR
5
BRCLR2
3 DIR
5
BRSET3
3 DIR
5
BRCLR3
3 DIR
5
BRSET4
3 DIR
5
BRCLR4
3 DIR
5
BRSET5
3 DIR
5
BRCLR5
3 DIR
5
BRSET6
3 DIR
5
BRCLR6
3 DIR
5
BRSET7
3 DIR
5
BRCLR7
3 DIR
4
BSET0
2 DIR
4
BCLR0
2 DIR
4
BSET1
2 DIR
4
BCLR1
2 DIR
4
BSET2
2 DIR
4
BCLR2
2 DIR
4
BSET3
2 DIR
4
BCLR3
2 DIR
4
BSET4
2 DIR
4
BCLR4
2 DIR
4
BSET5
2 DIR
4
BCLR5
2 DIR
4
BSET6
2 DIR
4
BCLR6
2 DIR
4
BSET7
2 DIR
4
BCLR7
2 DIR
3
BRA
2 REL
3
BRN
2 REL
3
BHI
2 REL
3
BLS
2 REL
3
BCC
2 REL
3
BCS
2 REL
3
BNE
2 REL
3
BEQ
2 REL
3
BHCC
2 REL
3
BHCS
2 REL
3
BPL
2 REL
3
BMI
2 REL
3
BMC
2 REL
3
BMS
2 REL
3
BIL
2 REL
3
BIH
2 REL
Read-Modify-Write
INH
IX1
5
6
1
NEGX
1 INH
4
CBEQX
3 IMM
7
DIV
1 INH
1
COMX
1 INH
1
LSRX
1 INH
4
LDHX
2 DIR
1
RORX
1 INH
1
ASRX
1 INH
1
LSLX
1 INH
1
ROLX
1 INH
1
DECX
1 INH
3
DBNZX
2 INH
1
INCX
1 INH
1
TSTX
1 INH
4
MOV
2 DIX+
1
CLRX
1 INH
4
NEG
2
IX1
5
CBEQ
3 IX1+
3
NSA
1 INH
4
COM
2 IX1
4
LSR
2 IX1
3
CPHX
3 IMM
4
ROR
2 IX1
4
ASR
2 IX1
4
LSL
2 IX1
4
ROL
2 IX1
4
DEC
2 IX1
5
DBNZ
3 IX1
4
INC
2 IX1
3
TST
2 IX1
4
MOV
3 IMD
3
CLR
2 IX1
SP1
IX
9E6
7
Control
INH
INH
8
9
Register/Memory
IX2
SP2
IMM
DIR
EXT
A
B
C
D
4
SUB
3 EXT
4
CMP
3 EXT
4
SBC
3 EXT
4
CPX
3 EXT
4
AND
3 EXT
4
BIT
3 EXT
4
LDA
3 EXT
4
STA
3 EXT
4
EOR
3 EXT
4
ADC
3 EXT
4
ORA
3 EXT
4
ADD
3 EXT
3
JMP
3 EXT
5
JSR
3 EXT
4
LDX
3 EXT
4
STX
3 EXT
4
SUB
IX2
4
CMP
IX2
4
SBC
IX2
4
CPX
IX2
4
AND
IX2
4
BIT
IX2
4
LDA
IX2
4
STA
IX2
4
EOR
IX2
4
ADC
IX2
4
ORA
IX2
4
ADD
IX2
4
JMP
IX2
6
JSR
IX2
4
LDX
IX2
4
STX
IX2
9ED
IX1
SP1
IX
E
9EE
F
LSB
2
3
4
5
6
7
8
9
A
B
C
E
F
Technical Data
99
INH Inherent
REL Relative
IMM Immediate
IX
Indexed, No Offset
DIR Direct
IX1 Indexed, 8-Bit Offset
EXT Extended
IX2 Indexed, 16-Bit Offset
DD Direct-Direct
IMD Immediate-Direct
IX+D Indexed-Direct DIX+ Direct-Indexed
*Pre-byte for stack pointer indexed instructions
5
3
NEG
NEG
3 SP1 1 IX
6
4
CBEQ
CBEQ
4 SP1 2 IX+
2
DAA
1 INH
5
3
COM
COM
3 SP1 1 IX
5
3
LSR
LSR
3 SP1 1 IX
4
CPHX
2 DIR
5
3
ROR
ROR
3 SP1 1 IX
5
3
ASR
ASR
3 SP1 1 IX
5
3
LSL
LSL
3 SP1 1 IX
5
3
ROL
ROL
3 SP1 1 IX
5
3
DEC
DEC
3 SP1 1 IX
6
4
DBNZ
DBNZ
4 SP1 2 IX
5
3
INC
INC
3 SP1 1 IX
4
2
TST
TST
3 SP1 1 IX
4
MOV
2 IX+D
4
2
CLR
CLR
3 SP1 1 IX
SP1 Stack Pointer, 8-Bit Offset
SP2 Stack Pointer, 16-Bit Offset
IX+ Indexed, No Offset with
Post Increment
IX1+ Indexed, 1-Byte Offset with
Post Increment
7
3
RTI
BGE
1 INH 2 REL
4
3
RTS
BLT
1 INH 2 REL
3
BGT
2 REL
9
3
SWI
BLE
1 INH 2 REL
2
2
TAP
TXS
1 INH 1 INH
1
2
TPA
TSX
1 INH 1 INH
2
PULA
1 INH
2
1
PSHA
TAX
1 INH 1 INH
2
1
PULX
CLC
1 INH 1 INH
2
1
PSHX
SEC
1 INH 1 INH
2
2
PULH
CLI
1 INH 1 INH
2
2
PSHH
SEI
1 INH 1 INH
1
1
CLRH
RSP
1 INH 1 INH
1
NOP
1 INH
1
STOP
1 INH
1
1
WAIT
TXA
1 INH 1 INH
2
SUB
2 IMM
2
CMP
2 IMM
2
SBC
2 IMM
2
CPX
2 IMM
2
AND
2 IMM
2
BIT
2 IMM
2
LDA
2 IMM
2
AIS
2 IMM
2
EOR
2 IMM
2
ADC
2 IMM
2
ORA
2 IMM
2
ADD
2 IMM
3
SUB
2 DIR
3
CMP
2 DIR
3
SBC
2 DIR
3
CPX
2 DIR
3
AND
2 DIR
3
BIT
2 DIR
3
LDA
2 DIR
3
STA
2 DIR
3
EOR
2 DIR
3
ADC
2 DIR
3
ORA
2 DIR
3
ADD
2 DIR
2
JMP
2 DIR
4
4
BSR
JSR
2 REL 2 DIR
2
3
LDX
LDX
2 IMM 2 DIR
2
3
AIX
STX
2 IMM 2 DIR
MSB
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
4
4
4
4
4
4
4
4
4
4
4
4
4
4
5
SUB
SP2
5
CMP
SP2
5
SBC
SP2
5
CPX
SP2
5
AND
SP2
5
BIT
SP2
5
LDA
SP2
5
STA
SP2
5
EOR
SP2
5
ADC
SP2
5
ORA
SP2
5
ADD
SP2
3
SUB
2 IX1
3
CMP
2 IX1
3
SBC
2 IX1
3
CPX
2 IX1
3
AND
2 IX1
3
BIT
2 IX1
3
LDA
2 IX1
3
STA
2 IX1
3
EOR
2 IX1
3
ADC
2 IX1
3
ORA
2 IX1
3
ADD
2 IX1
3
JMP
2 IX1
5
JSR
2 IX1
5
3
LDX
LDX
SP2 2 IX1
5
3
STX
STX
SP2 2 IX1
4
SUB
3 SP1
4
CMP
3 SP1
4
SBC
3 SP1
4
CPX
3 SP1
4
AND
3 SP1
4
BIT
3 SP1
4
LDA
3 SP1
4
STA
3 SP1
4
EOR
3 SP1
4
ADC
3 SP1
4
ORA
3 SP1
4
ADD
3 SP1
2
SUB
1 IX
2
CMP
1 IX
2
SBC
1 IX
2
CPX
1 IX
2
AND
1 IX
2
BIT
1 IX
2
LDA
1 IX
2
STA
1 IX
2
EOR
1 IX
2
ADC
1 IX
2
ORA
1 IX
2
ADD
1 IX
2
JMP
1 IX
4
JSR
1 IX
4
2
LDX
LDX
3 SP1 1 IX
4
2
STX
STX
3 SP1 1 IX
High Byte of Opcode in Hexadecimal
LSB
Low Byte of Opcode in Hexadecimal
Cycles
BRSET0 Opcode Mnemonic
3 DIR Number of Bytes / Addressing Mode
Opcode Map
D
4
1
NEG
NEGA
2 DIR 1 INH
5
4
CBEQ CBEQA
3 DIR 3 IMM
5
MUL
1 INH
4
1
COM
COMA
2 DIR 1 INH
4
1
LSR
LSRA
2 DIR 1 INH
4
3
STHX
LDHX
2 DIR 3 IMM
4
1
ROR
RORA
2 DIR 1 INH
4
1
ASR
ASRA
2 DIR 1 INH
4
1
LSL
LSLA
2 DIR 1 INH
4
1
ROL
ROLA
2 DIR 1 INH
4
1
DEC
DECA
2 DIR 1 INH
5
3
DBNZ DBNZA
3 DIR 2 INH
4
1
INC
INCA
2 DIR 1 INH
3
1
TST
TSTA
2 DIR 1 INH
5
MOV
3 DD
3
1
CLR
CLRA
2 DIR 1 INH
Technical Data
100
MOTOROLA
Technical Data — MC68HC908SR12•MC68HC08SR12
Section 7. Oscillator (OSC)
7.1 Contents
7.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 102
7.3
Clock Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .103
7.3.1
CGM Reference Clock Selection . . . . . . . . . . . . . . . . . . . . 104
7.3.2
TBM Reference Clock Selection . . . . . . . . . . . . . . . . . . . . 105
7.4
Internal Oscillator . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 105
7.5
RC Oscillator. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 106
7.6
X-tal Oscillator . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 107
7.7
I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 108
7.7.1
Crystal Amplifier Input Pin (OSC1). . . . . . . . . . . . . . . . . . . 108
7.7.2
Crystal Amplifier Output Pin (OSC2) . . . . . . . . . . . . . . . . . 109
7.7.3
Oscillator Enable Signal (SIMOSCEN). . . . . . . . . . . . . . . . 109
7.7.4
CGM Oscillator Clock (CGMXCLK) . . . . . . . . . . . . . . . . . . 109
7.7.5
CGM Reference Clock (CGMRCLK) . . . . . . . . . . . . . . . . . 109
7.7.6
Oscillator Clock to Time Base Module (OSCCLK) . . . . . . . 109
7.8
Low Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .109
7.8.1
Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 110
7.8.2
Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 110
7.9
Oscillator During Break Mode. . . . . . . . . . . . . . . . . . . . . . . . . 110
MOTOROLA
Technical Data
Oscillator (OSC)
101
Oscillator (OSC)
7.2 Introduction
The oscillator module provides the reference clock for the clock
generator module (CGM), the timebase module (TBM), and other MCU
sub-systems.
The oscillator module consist of three types of oscillator circuits:
Internal oscillator
RC oscillator
Crystal (x-tal) oscillator
The reference clock for the CGM and other MCU sub-systems is
selected by:
MC68HC908SR12 — FLASH device — oscillator selected by
programming the mask option register located at $FF80.
MC68HC08SR12 — ROM device — oscillator selected by ROMmask layer at factory.
The reference clock for the timebase module (TBM) is selected by the
two bits, OSCCLK1 and OSCCLK0, in the CONFIG2 register.
The internal oscillator runs continuously after a POR or reset, and is
always available. The RC and crystal oscillator cannot run concurrently;
one is disabled while the other is selected; because the RC and x-tal
circuits share the same OSC1 pin.
Figure 7-1. shows the block diagram of the oscillator module.
Technical Data
102
Oscillator (OSC)
MOTOROLA
Oscillator (OSC)
Clock Selection
To CGM and others To CGM PLL
CGMXCLK
To TBM
CGMRCLK
OSCCLK
MOR
CONFIG2
OSCSEL1
OSCCLK1
MUX
MUX
OSCSEL0
OSCCLK0
X
RC
I
X
RC
I
To SIM
(and COP)
XCLK
ICLK
RCCLK
X-TAL OSCILLATOR
RC OSCILLATOR
INTERNAL OSCILLATOR
BUS CLOCK
OSC1
From SIM
OSC2
Figure 7-1. Oscillator Module Block Diagram
7.3 Clock Selection
Reference clocks are selectable for the following sub-systems:
CGMXCLK and CGMRCLK — Reference clock for clock
generator module (CGM) and other MCU sub-systems other than
TBM and COP. This is the main reference clock for the MCU.
OSCCLK — Reference clock for timebase module (TBM).
MOTOROLA
Technical Data
Oscillator (OSC)
103
Oscillator (OSC)
7.3.1 CGM Reference Clock Selection
The clock generator module (CGM) reference clock (CGMXCLK) is the
reference clock input to the MCU. It is selected by programming two bits
in a FLASH memory location; the mask option register (MOR), at $FF80.
See 5.6 Mask Option Register (MOR).
NOTE:
On the ROM device, the oscillator is selected by a ROM-mask layer at
factory.
Address:
$FF80
Bit 7
6
5
4
3
2
1
Bit 0
R
R
R
R
R
R
Read:
OSCSEL1 OSCSEL0
Write:
Erased:
1
1
1
1
1
1
1
1
Reset:
U
U
U
U
U
U
U
U
R
= Reserved
Figure 7-2. Mask Option Register (MOR)
Table 7-1. CGMXCLK Clock Selection
OSCSEL1
OSCSEL0
CGMXCLK
OSC2 Pin
ICLK
fBUS
1
RCCLK
fBUS
or reset.
1
1
XCLK
Inverting
output of
X-TAL
or reset.
NOTE:
Not used
Technical Data
104
Comments
Oscillator (OSC)
MOTOROLA
Oscillator (OSC)
Internal Oscillator
7.3.2 TBM Reference Clock Selection
The timebase module reference clock (OSCCLK) is selected by
configuring two bits in the CONFIG2 register, at $001D. See 5.5
Configuration Register 2 (CONFIG2).
Address:
$001D
Bit 7
Read:
STOP_
ICLKEN
Write:
Reset:
6
STOP_
RCLKEN
4
3
2
STOP_
OSCCLK1 OSCCLK0
XCLKEN
Bit 0
CDOEN SCIBDSRC
Figure 7-3. Configuration Register 2 (CONFIG2)
Table 7-2. Timebase Module Reference Clock Selection
NOTE:
OSCCLK1
OSCCLK0
1
X-tal oscillator (XCLK)
1
1
Not used
The RCCLK or XCLK is only available if that clock is selected as the
CGM reference clock, whereas the ICLK is always available.
The internal oscillator clock (ICLK) is a free running 24kHz clock that
requires no external components. It can be selected as the CGMXCLK
for the CGM and MCU sub-systems; and the OSCCLK clock for the
TBM. The ICLK is also the reference clock input to the computer
operating properly (COP) module.
Due to the simplicity of the internal oscillator, it does not have the
accuracy and stability of the RC oscillator or the x-tal oscillator.
Therefore, the ICLK is not suitable where an accurate bus clock is
required and it should not be used as the CGMRCLK to the CGM PLL.
MOTOROLA
Technical Data
Oscillator (OSC)
105
Oscillator (OSC)
The internal oscillator by default is always available and is free running
after POR or reset. It can be stopped in Stop mode by setting the
STOP_ICLKEN bit before executing the STOP instruction.
Figure 7-4 shows the logical representation of components of the
internal oscillator circuitry.
From SIM
To Clock Selection MUX
and COP
SIMOSCEN
ICLK
From SIM
BUS CLOCK
CONFIG2
EN
STOP_ICLKEN
INTERNAL OSCILLATOR
MCU
OSC2
Figure 7-4. Internal Oscillator
7.5 RC Oscillator
The RC oscillator circuit is designed for use with external R and C to
provide a clock source with tolerance less than 10%.
In its typical configuration, the RC oscillator requires two external
components, one R and one C. Component values should have a
tolerance of 1% or less, to obtain a clock source with less than 10%
tolerance. The oscillator configuration uses two components:
CEXT
REXT
Technical Data
106
Oscillator (OSC)
MOTOROLA
Oscillator (OSC)
X-tal Oscillator
From SIM
SIMOSCEN
RCCLK
From SIM
BUS CLOCK
CONFIG2
EN
STOP_RCLKEN
RC OSCILLATOR
MCU
OSC1
OSC2
See Section 24. for component value requirements.
VDD
REXT
CEXT
Figure 7-5. RC Oscillator
7.6 X-tal Oscillator
The X-tal oscillator circuit is designed for use with an external crystal or
ceramic resonator to provide an accurate clock source.
In its typical configuration, the X-tal oscillator is connected in a Pierce
oscillator configuration, as shown in Figure 7-6. This figure shows only
the logical representation of the internal components and may not
represent actual circuitry. The oscillator configuration uses five
components:
Crystal, X1
Fixed capacitor, C1
Tuning capacitor, C2 (can also be a fixed capacitor)
Feedback resistor, RB
Series resistor, RS (optional)
MOTOROLA
Technical Data
Oscillator (OSC)
107
Oscillator (OSC)
From SIM
SIMOSCEN
XCLK
CONFIG2
STOP_XCLKEN
MCU
OSC1
OSC2
RB
RS*
*RS can be zero (shorted) when used with higher-frequency crystals.
Refer to manufacturer’s data.
X1
C1
C2
Figure 7-6. Crystal Oscillator
The series resistor (RS) is included in the diagram to follow strict Pierce
oscillator guidelines and may not be required for all ranges of operation,
especially with high frequency crystals. Refer to the crystal
manufacturer’s data for more information.
7.7 I/O Signals
The following paragraphs describe the oscillator I/O signals.
7.7.1 Crystal Amplifier Input Pin (OSC1)
OSC1 pin is an input to the crystal oscillator amplifier or the input to the
RC oscillator circuit.
Technical Data
108
Oscillator (OSC)
MOTOROLA
Oscillator (OSC)
Low Power Modes
7.7.2 Crystal Amplifier Output Pin (OSC2)
When the x-tal oscillator is selected, OSC2 pin is the output of the crystal
oscillator inverting amplifier.
When the RC oscillator or internal oscillator is selected, OSC2 pin is the
output of the internal bus clock.
7.7.3 Oscillator Enable Signal (SIMOSCEN)
The SIMOSCEN signal from the system integration module (SIM)
enables/disables the x-tal oscillator, the RC-oscillator, or the internal
oscillator circuit.
7.7.4 CGM Oscillator Clock (CGMXCLK)
The CGMXCLK clock is output from the x-tal oscillator, RC oscillator or
the internal oscillator. This clock drives to CGM and other MCU subsystems.
7.7.5 CGM Reference Clock (CGMRCLK)
This is buffered signal of CGMXCLK, it is used by the CGM as the
phase-locked-loop (PLL) reference clock.
7.7.6 Oscillator Clock to Time Base Module (OSCCLK)
The OSCCLK is the reference clock that drives the timebase module.
See Section 12. Timebase Module (TBM).
7.8 Low Power Modes
The WAIT and STOP instructions put the MCU in low-power
consumption standby modes.
MOTOROLA
Technical Data
Oscillator (OSC)
109
Oscillator (OSC)
7.8.1 Wait Mode
The WAIT instruction has no effect on the oscillator module. CGMXCLK
continues to drive to the clock generator module, and OSCCLK
continues to drive the timebase module.
7.8.2 Stop Mode
The STOP instruction disables the x-tal or the RC oscillator circuit, and
hence the CGMXCLK clock stops running. For continuous x-tal or RC
oscillator operation in stop mode, set the STOP_XCLKEN (for x-tal) or
STOP_RCLKEN (for RC) bit to logic 1 before entering stop mode.
The internal oscillator clock continues operation in stop mode. It can be
disabled by setting the STOP_ICLKEN bit to logic 1 before entering stop
mode.
7.9 Oscillator During Break Mode
The oscillator continues to drive CGMXCLK when the device enters the
break state.
Technical Data
110
Oscillator (OSC)
MOTOROLA
Section 8. Clock Generator Module (CGM)
8.1 Contents
8.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 112
8.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 113
8.4
Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 113
8.4.1
Oscillator Module . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 116
8.4.2
Phase-Locked Loop Circuit (PLL) . . . . . . . . . . . . . . . . . . .116
8.4.3
PLL Circuits . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 116
8.4.4
Acquisition and Tracking Modes . . . . . . . . . . . . . . . . . . . . 118
8.4.5
Manual and Automatic PLL Bandwidth Modes. . . . . . . . . . 118
8.4.6
Programming the PLL . . . . . . . . . . . . . . . . . . . . . . . . . . . . 120
8.4.7
Special Programming Exceptions . . . . . . . . . . . . . . . . . . .124
8.4.8
Base Clock Selector Circuit . . . . . . . . . . . . . . . . . . . . . . . . 124
8.4.9
CGM External Connections . . . . . . . . . . . . . . . . . . . . . . . . 125
8.5
I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 125
8.5.1
External Filter Capacitor Pin (CGMXFC) . . . . . . . . . . . . . . 126
8.5.2
PLL Analog Power Pin (VDDA) . . . . . . . . . . . . . . . . . . . . . . 126
8.5.3
PLL Analog Ground Pin (VSSA) . . . . . . . . . . . . . . . . . . . . . 126
8.5.4
Oscillator Output Frequency Signal (CGMXCLK) . . . . . . . 126
8.5.5
CGM Reference Clock (CGMRCLK) . . . . . . . . . . . . . . . . . 126
8.5.6
CGM VCO Clock Output (CGMVCLK) . . . . . . . . . . . . . . . . 127
8.5.7
CGM Base Clock Output (CGMOUT). . . . . . . . . . . . . . . . . 127
8.5.8
CGM CPU Interrupt (CGMINT) . . . . . . . . . . . . . . . . . . . . . 127
8.6
CGM Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .127
8.6.1
PLL Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 128
8.6.2
PLL Bandwidth Control Register . . . . . . . . . . . . . . . . . . . . 130
8.6.3
PLL Multiplier Select Registers . . . . . . . . . . . . . . . . . . . . . 132
8.6.4
PLL VCO Range Select Register . . . . . . . . . . . . . . . . . . . . 133
8.6.5
PLL Reference Divider Select Register . . . . . . . . . . . . . . . 134
MOTOROLA
Technical Data
111
8.7
Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 135
8.8
Special Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 135
8.8.1
Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 135
8.8.2
Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 136
8.8.3
CGM During Break Interrupts. . . . . . . . . . . . . . . . . . . . . . . 136
8.9
Acquisition/Lock Time Specifications . . . . . . . . . . . . . . . . . . .137
8.9.1
Acquisition/Lock Time Definitions. . . . . . . . . . . . . . . . . . . . 137
8.9.2
Parametric Influences on Reaction Time . . . . . . . . . . . . . . 137
8.9.3
Choosing a Filter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 139
8.2 Introduction
This section describes the clock generator module (CGM). The CGM
generates the base clock signal, CGMOUT, which is based on either the
oscillator clock divided by two or the divided phase-locked loop (PLL)
clock, CGMPCLK, divided by two. CGMOUT is the clock from which the
SIM derives the system clocks, including the bus clock, which is at a
frequency of CGMOUT÷2. The PLL clock, CGMVCLK (an integer
multiple of CGMPCLK) provides clock reference for the PWM and
analog modules.
The PLL is a frequency generator designed for use with a low frequency
crystal (typically 32.768kHz) to generate a base frequency and dividing
to a maximum bus frequency of 8MHz.
Technical Data
112
MOTOROLA
Features
8.3 Features
Features of the CGM include:
Phase-locked loop with output frequency in integer multiples of an
integer dividend of the crystal reference
Low-frequency crystal operation with low-power operation and
high-output frequency resolution
Programmable prescaler for power-of-two increases in frequency
Programmable hardware voltage-controlled oscillator (VCO) for
low-jitter operation
Automatic bandwidth control mode for low-jitter operation
Automatic frequency lock detector
CPU interrupt on entry or exit from locked condition
Configuration register bit to allow oscillator operation during stop
mode
8.4 Functional Description
The CGM consists of three major sub-modules:
Oscillator module — The oscillator module generates the constant
reference frequency clock, CGMRCLK (buffered CGMXCLK).
Phase-locked loop (PLL) — The PLL generates the
programmable VCO frequency clock, CGMVCLK, and the divided,
CGMPCLK. The CGMVCLK provides the input reference clock to
the PWM and analog modules.
Base clock selector circuit — This software-controlled circuit
selects either CGMXCLK divided by two or the divided VCO clock,
CGMPCLK, divided by two as the base clock, CGMOUT. The SIM
derives the system clocks from either CGMOUT or CGMXCLK.
Figure 8-1 shows the structure of the CGM.
Figure 8-2 is a summary of the CGM registers.
MOTOROLA
Technical Data
113
OSC2
OSC1
OSCILLATOR (OSC) MODULE
See Section 7. Oscillator (OSC).
ICLK
INTERNAL OSCILLATOR
OSCCLK
T0 ADC, Analog Module
CGMRCLK
CRYSTAL OSCILLATOR
OSCCLK[1:0]
To Timebase Module (TBM)
CGMXCLK
MUX
RC OSCILLATOR
OSCSEL[1:0]
To SIM (and COP)
SIMOSCEN
From SIM
PHASE-LOCKED LOOP (PLL)
CGMRDV
REFERENCE
DIVIDER
CGMRCLK
CLOCK
SELECT
CIRCUIT
BCS
R
RDS[3:0]
VDDA
CGMXFC
A
÷2
1
B S*
*WHEN S = 1,
CGMOUT = B
VSSA
CGMOUT
To SIM
SIMDIV2
From SIM
VPR[1:0]
VRS[7:0]
L
PHASE
DETECTOR
2E
CGMPCLK
VOLTAGE
CONTROLLED
OSCILLATOR
LOOP
FILTER
PLL ANALOG
AUTOMATIC
MODE
CONTROL
LOCK
DETECTOR
LOCK
AUTO
MUL[11:0]
N
CGMVDV
FREQUENCY
DIVIDER
ACQ
INTERRUPT
CONTROL
PLLIE
CGMVCLK
To PWM,
Analog Module
CGMINT
To SIM
PLLF
PRE[1:0]
2P
FREQUENCY
DIVIDER
Figure 8-1. CGM Block Diagram
Technical Data
114
MOTOROLA
Addr.
Register Name
Bit 7
Read:
$0036
$0037
$0038
$0039
$003A
$003B
Write:
(PTCL)
Reset:
Read:
Register Write:
(PBWC)
Reset:
Read:
Register High Write:
(PMSH)
Reset:
Read:
Register Low Write:
(PMSL)
Reset:
Read:
Register Write:
(PMRS)
Reset:
Read:
Select Register Write:
(PMDS)
Reset:
6
5
4
3
2
1
Bit 0
PLLON
BCS
PRE1
PRE0
VPR1
VPR0
1
PLLF
PLLIE
LOCK
AUTO
R
ACQ
MUL11
MUL10
MUL9
MUL8
MUL7
MUL6
MUL5
MUL4
MUL3
MUL2
MUL1
MUL0
VRS7
VRS6
VRS5
VRS4
VRS3
VRS2
VRS1
VRS0
RDS3
RDS2
RDS1
RDS0
= Unimplemented
R
= Reserved
NOTES:
1. When AUTO = 0, PLLIE is forced clear and is read-only.
2. When AUTO = 0, PLLF and LOCK read as clear.
3. When AUTO = 1, ACQ is read-only.
4. When PLLON = 0 or VRS7:VRS0 = $0, BCS is forced clear and is read-only.
5. When PLLON = 1, the PLL programming register is read-only.
6. When BCS = 1, PLLON is forced set and is read-only.
Figure 8-2. CGM I/O Register Summary
MOTOROLA
Technical Data
115
8.4.1 Oscillator Module
The oscillator module provides two clock outputs CGMXCLK and
CGMRCLK to the CGM module. CGMXCLK when selected, is driven to
SIM module to generate the system bus clock. CGMRCLK is used by the
phase-lock-loop to provide a higher frequency system bus clock and the
reference clock for the PWM and analog modules. The oscillator module
also provides the reference clock for the timebase module (TBM). See
Section 7. Oscillator (OSC) for detailed oscillator circuit description.
See Section 12. Timebase Module (TBM) for detailed description on
TBM. See Section 13. Pulse Width Modulator (PWM) for detailed
description on PWM module.
8.4.2 Phase-Locked Loop Circuit (PLL)
The PLL is a frequency generator that can operate in either acquisition
mode or tracking mode, depending on the accuracy of the output
frequency. The PLL can change between acquisition and tracking
modes either automatically or manually.
8.4.3 PLL Circuits
The PLL consists of these circuits:
Technical Data
116
Voltage-controlled oscillator (VCO)
Reference divider
Frequency pre-scaler
Modulo VCO frequency divider
Phase detector
Loop filter
Lock detector
MOTOROLA
The operating range of the VCO is programmable for a wide range of
frequencies and for maximum immunity to external noise, including
supply and CGMXFC noise. The VCO frequency is bound to a range
from roughly one-half to twice the center-of-range frequency, fVRS.
Modulating the voltage on the CGMXFC pin changes the frequency
within this range. By design, fVRS is equal to the nominal center-of-range
frequency, fNOM, (38.4 kHz) times a linear factor, L, and a power-of-two
factor, E, or (L × 2E)fNOM.
CGMRCLK is the PLL reference clock, a buffered version of CGMXCLK.
CGMRCLK runs at a frequency, fRCLK, and is fed to the PLL through a
programmable modulo reference divider, which divides fRCLK by a
factor, R. The divider’s output is the final reference clock, CGMRDV,
running at a frequency, fRDV = fRCLK/R. With an external crystal
(30kHz–100kHz), always set R = 1 for specified performance. With an
external high-frequency clock source, use R to divide the external
frequency to between 30kHz and 100kHz.
The VCO’s output clock, CGMVCLK, running at a frequency, fVCLK, is
fed back through a programmable pre-scaler divider and a
programmable modulo divider. The pre-scaler divides the VCO clock by
a power-of-two factor P (the CGMPCLK) and the modulo divider reduces
the VCO clock by a factor, N. The dividers’ output is the VCO feedback
clock, CGMVDV, running at a frequency, fVDV = fVCLK/(N × 2P). (See
8.4.6 Programming the PLL for more information.)
The phase detector then compares the VCO feedback clock, CGMVDV,
with the final reference clock, CGMRDV. A correction pulse is generated
based on the phase difference between the two signals. The loop filter
then slightly alters the DC voltage on the external capacitor connected
to CGMXFC based on the width and direction of the correction pulse.
The filter can make fast or slow corrections depending on its mode,
described in 8.4.4 Acquisition and Tracking Modes. The value of the
external capacitor and the reference frequency determines the speed of
the corrections and the stability of the PLL.
The lock detector compares the frequencies of the VCO feedback clock,
CGMVDV, and the final reference clock, CGMRDV. Therefore, the
speed of the lock detector is directly proportional to the final reference
frequency, fRDV. The circuit determines the mode of the PLL and the lock
condition based on this comparison.
MOTOROLA
Technical Data
117
The PLL filter is manually or automatically configurable into one of two
operating modes:
Acquisition mode — In acquisition mode, the filter can make large
frequency corrections to the VCO. This mode is used at PLL start
up or when the PLL has suffered a severe noise hit and the VCO
frequency is far off the desired frequency. When in acquisition
mode, the ACQ bit is clear in the PLL bandwidth control register.
(See 8.6.2 PLL Bandwidth Control Register.)
Tracking mode — In tracking mode, the filter makes only small
corrections to the frequency of the VCO. PLL jitter is much lower
in tracking mode, but the response to noise is also slower. The
PLL enters tracking mode when the VCO frequency is nearly
correct, such as when the PLL is selected as the base clock
source. (See 8.4.8 Base Clock Selector Circuit.) The PLL is
automatically in tracking mode when not in acquisition mode or
when the ACQ bit is set.
8.4.5 Manual and Automatic PLL Bandwidth Modes
The PLL can change the bandwidth or operational mode of the loop filter
manually or automatically. Automatic mode is recommended for most
users.
In automatic bandwidth control mode (AUTO = 1), the lock detector
automatically switches between acquisition and tracking modes.
Automatic bandwidth control mode also is used to determine when the
VCO clock, CGMVCLK, is safe to use as the source for the base clock,
CGMOUT. (See 8.6.2 PLL Bandwidth Control Register.) If PLL
interrupts are enabled, the software can wait for a PLL interrupt request
and then check the LOCK bit. If interrupts are disabled, software can poll
the LOCK bit continuously (during PLL start-up, usually) or at periodic
intervals. In either case, when the LOCK bit is set, the VCO clock is safe
to use as the source for the base clock. (See 8.4.8 Base Clock Selector
Circuit.) If the VCO is selected as the source for the base clock and the
LOCK bit is clear, the PLL has suffered a severe noise hit and the
software must take appropriate action, depending on the application.
(See 8.7 Interrupts for information and precautions on using interrupts.)
Technical Data
118
MOTOROLA
The following conditions apply when the PLL is in automatic bandwidth
control mode:
The ACQ bit (See 8.6.2 PLL Bandwidth Control Register.) is a
read-only indicator of the mode of the filter. (See 8.4.4
Acquisition and Tracking Modes.)
The ACQ bit is set when the VCO frequency is within a certain
tolerance and is cleared when the VCO frequency is out of a
certain tolerance. (See 8.9 Acquisition/Lock Time
Specifications for more information.)
The LOCK bit is a read-only indicator of the locked state of the
PLL.
The LOCK bit is set when the VCO frequency is within a certain
CPU interrupts can occur if enabled (PLLIE = 1) when the PLL’s
lock condition changes, toggling the LOCK bit. (See 8.6.1 PLL
Control Register.)
The PLL also may operate in manual mode (AUTO = 0). Manual mode
is used by systems that do not require an indicator of the lock condition
for proper operation. Such systems typically operate well below
fBUSMAX.
MOTOROLA
Technical Data
119
The following conditions apply when in manual mode:
ACQ is a writable control bit that controls the mode of the filter.
Before turning on the PLL in manual mode, the ACQ bit must be
clear.
Before entering tracking mode (ACQ = 1), software must wait a
given time, tACQ (See 8.9 Acquisition/Lock Time
Specifications.), after turning on the PLL by setting PLLON in the
PLL control register (PCTL).
Software must wait a given time, tAL, after entering tracking mode
before selecting the PLL as the clock source to CGMOUT
(BCS = 1).
The LOCK bit is disabled.
CPU interrupts from the CGM are disabled.
The following procedure shows how to program the PLL.
NOTE:
The round function in the following equations means that the real
number should be rounded to the nearest integer number.
1. Choose the desired bus frequency, fBUSDES, or the desired VCO
frequency, fVCLKDES; and then solve for the other.
The relationship between fBUS and fVCLK is governed by the
equation:
P
P
f VCLK = 2 × f CGMPCLK = 2 × 4
× fBUS
where P is the power of two multiplier, and can be 0, 1, 2, or 3
2. Choose a practical PLL reference frequency, fRCLK, and the
reference clock divider, R. Typically, the reference is 32.768kHz
and R = 1.
Frequency errors to the PLL are corrected at a rate of fRCLK/R. For
stability and lock time reduction, this rate must be as fast as
possible. The VCO frequency must be an integer multiple of this
rate.
Technical Data
120
MOTOROLA
The relationship between the VCO frequency, fVCLK, and the
reference frequency, fRCLK, is
P
2 N
f VCLK = ----------- ( f RCLK )
R
where N is the integer range multiplier, between 1 and 4095.
In cases where desired bus frequency has some tolerance,
choose fRCLK to a value determined either by other module
requirements (such as modules which are clocked by CGMXCLK),
cost requirements, or ideally, as high as the specified range
allows. See Section 24. Electrical Specifications. Choose the
reference divider, R = 1.
When the tolerance on the bus frequency is tight, choose fRCLK to
an integer divisor of fBUSDES, and R = 1. If fRCLK cannot meet this
requirement, use the following equation to solve for R with
practical choices of fRCLK, and choose the fRCLK that gives the
lowest R.
f VCLKDES
f VCLKDES
R = round R MAX × -------------------------- – integer --------------------------
f RCLK
f RCLK
3. Calculate N:
R × fVCLKDES
N = round ------------------------------------
P
f
2
RCLK
4. Calculate and verify the adequacy of the VCO and bus
frequencies fVCLK and fBUS.
P
2 N
R
f
f BUS =
VCLK
----------P
2 ×4
MOTOROLA
Technical Data
121
5. Select the VCO’s power-of-two range multiplier E, according to
this table:
Frequency Range
E
0 < fVCLK < 9,830,400
9,830,400 ≤ fVCLK < 19,660,800
1
19,660,800 ≤ fVCLK < 39,321,600
2
NOTE: Do not program E to a value of 3.
6. Select a VCO linear range multiplier, L, where fNOM = 38.4kHz
f VCLK
L = round -------------------------
2E × f
NOM
7. Calculate and verify the adequacy of the VCO programmed
center-of-range frequency, fVRS. The center-of-range frequency is
the midpoint between the minimum and maximum frequencies
attainable by the PLL.
E
f VRS = ( L × 2 )f NOM
For proper operation,
E
f VRS – f VCLK
f NOM × 2
≤ -------------------------2
8. Verify the choice of P, R, N, E, and L by comparing fVCLK to fVRS
and fVCLKDES. For proper operation, fVCLK must be within the
application’s tolerance of fVCLKDES, and fVRS must be as close as
possible to fVCLK.
NOTE:
Technical Data
122
Exceeding the recommended maximum bus frequency or VCO
frequency can crash the MCU.
MOTOROLA
9. Program the PLL registers accordingly:
a. In the PRE bits of the PLL control register (PCTL), program
the binary equivalent of P.
b. In the VPR bits of the PLL control register (PCTL), program
the binary equivalent of E.
c. In the PLL multiplier select register low (PMSL) and the PLL
multiplier select register high (PMSH), program the binary
equivalent of N.
d. In the PLL VCO range select register (PMRS), program the
binary coded equivalent of L.
e. In the PLL reference divider select register (PMDS), program
the binary coded equivalent of R.
NOTE:
The values for P, E, N, L, and R can only be programmed when the PLL
is off (PLLON = 0).
Table 8-1 provides numeric examples (numbers are in hexadecimal
notation):
Table 8-1. Numeric Examples
CGMVCLK
CGMPCLK
fBUS
fRCLK
R
N
P
E
L
8.0 MHz
8.0 MHz
2.0 MHz
32.768 kHz
1
F5
D1
9.8304 MHz
9.8304 MHz
2.4576 MHz
32.768 kHz
1
12C
80
10.0 MHz
10.0 MHz
2.5 MHz
32.768 kHz
1
132
83
16 MHz
16 MHz
4.0 MHz
32.768 kHz
1
1E9
D1
19.6608 MHz
19.6608 MHz
4.9152 MHz
32.768 kHz
1
258
80
20 MHz
20 MHz
5.0 MHz
32.768 kHz
1
263
82
29.4912 MHz
29.4912 MHz
7.3728 MHz
32.768 kHz
1
384
C0
32 MHz
32 MHz
8.0 MHz
32.768 kHz
1
3D1
D0
32 MHz
16 MHz
4.0 MHz
32.768 kHz
1
1E9
1
2
D0
32 MHz
8 MHz
2.0 MHz
32.768 kHz
1
F5
2
2
D0
32 MHz
4 MHz
1.0 MHz
32.768 kHz
1
7B
3
2
D0
MOTOROLA
Technical Data
123
8.4.7 Special Programming Exceptions
The programming method described in 8.4.6 Programming the PLL
does not account for three possible exceptions. A value of 0 for R, N, or
L is meaningless when used in the equations given. To account for these
exceptions:
A 0 value for R or N is interpreted exactly the same as a value of 1.
A 0 value for L disables the PLL and prevents its selection as the
This circuit is used to select either the oscillator clock, CGMXCLK, or the
divided VCO clock, CGMPCLK, as the source of the base clock,
CGMOUT. The two input clocks go through a transition control circuit
that waits up to three CGMXCLK cycles and three CGMPCLK cycles to
change from one clock source to the other. During this time, CGMOUT
is held in stasis. The output of the transition control circuit is then divided
by two to correct the duty cycle. Therefore, the bus clock frequency,
which is one-half of the base clock frequency, is one-fourth the
frequency of the selected clock (CGMXCLK or CGMPCLK).
The BCS bit in the PLL control register (PCTL) selects which clock drives
CGMOUT. The divided VCO clock cannot be selected as the base clock
source if the PLL is not turned on. The PLL cannot be turned off if the
divided VCO clock is selected. The PLL cannot be turned on or off
simultaneously with the selection or deselection of the divided VCO
clock. The divided VCO clock also cannot be selected as the base clock
source if the factor L is programmed to a 0. This value would set up a
condition inconsistent with the operation of the PLL, so that the PLL
would be disabled and the oscillator clock would be forced as the source
of the base clock.
Technical Data
124
MOTOROLA
I/O Signals
8.4.9 CGM External Connections
In its typical configuration, the CGM requires up to four external
components.
Figure 8-3 shows the external components for the PLL:
Bypass capacitor, CBYP
Filter network
Care should be taken with PCB routing in order to minimize signal cross
talk and noise. (See 8.9 Acquisition/Lock Time Specifications for
routing information, filter network and its effects on PLL performance.)
MCU
CGMXFC
VSSA
VDDA
VDD
10 kΩ
0.01 µF
CBYP
0.1 µF
0.033 µF
Note: Filter network in box can be replaced with a 0.47µF capacitor, but will degrade stability.
Figure 8-3. CGM External Connections
8.5 I/O Signals
The following paragraphs describe the CGM I/O signals.
MOTOROLA
Technical Data
125
8.5.1 External Filter Capacitor Pin (CGMXFC)
The CGMXFC pin is required by the loop filter to filter out phase
corrections. An external filter network is connected to this pin. (See
Figure 8-3.)
NOTE:
To prevent noise problems, the filter network should be placed as close
to the CGMXFC pin as possible, with minimum routing distances and no
routing of other signals across the network.
8.5.2 PLL Analog Power Pin (VDDA)
VDDA is a power pin used by the analog portions of the PLL. Connect the
VDDA pin to the same voltage potential as the VDD pin.
NOTE:
Route VDDA carefully for maximum noise immunity and place bypass
capacitors as close as possible to the package.
8.5.3 PLL Analog Ground Pin (VSSA)
VSSA is a ground pin used by the analog portions of the PLL. Connect
the VSSA pin to the same voltage potential as the VSS pin.
NOTE:
Route VSSA carefully for maximum noise immunity and place bypass
8.5.4 Oscillator Output Frequency Signal (CGMXCLK)
CGMXCLK is the oscillator output signal. It runs at the full speed of the
oscillator, and is generated directly from the crystal oscillator circuit, the
RC oscillator circuit, or the internal oscillator circuit.
8.5.5 CGM Reference Clock (CGMRCLK)
CGMRCLK is a buffered version of CGMXCLK, this clock is the
reference clock for the phase-locked-loop circuit.
Technical Data
126
MOTOROLA
CGM Registers
8.5.6 CGM VCO Clock Output (CGMVCLK)
CGMVCLK is the clock output from the VCO. This clock can be used by
the pulse width modulator (PWM) module to generate high frequency
PWM signals. This clock is also used by the analog module as a
reference for signal sampling.
8.5.7 CGM Base Clock Output (CGMOUT)
CGMOUT is the clock output of the CGM. This signal goes to the SIM,
which generates the MCU clocks. CGMOUT is a 50 percent duty cycle
clock running at twice the bus frequency. CGMOUT is software
programmable to be either the oscillator output, CGMXCLK, divided by
two or the divided VCO clock, CGMPCLK, divided by two.
8.5.8 CGM CPU Interrupt (CGMINT)
CGMINT is the interrupt signal generated by the PLL lock detector.
8.6 CGM Registers
The following registers control and monitor operation of the CGM:
(See 8.6.1 PLL Control Register.)
PLL bandwidth control register (PBWC)
PLL multiplier select registers (PMSH and PMSL)
(See 8.6.3 PLL Multiplier Select Registers.)
(See 8.6.4 PLL VCO Range Select Register.)
(See 8.6.5 PLL Reference Divider Select Register.)
MOTOROLA
Technical Data
127
The PLL control register (PCTL) contains the interrupt enable and flag
bits, the on/off switch, the base clock selector bit, the prescaler bits, and
the VCO power-of-two range selector bits.
Address:
$0036
Bit 7
Read:
6
5
4
3
2
1
Bit 0
PLLON
BCS
PRE1
PRE0
VPR1
VPR0
1
PLLF
PLLIE
Write:
Reset:
= Unimplemented
Figure 8-4. PLL Control Register (PCTL)
PLLIE — PLL Interrupt Enable Bit
This read/write bit enables the PLL to generate an interrupt request
when the LOCK bit toggles, setting the PLL flag, PLLF. When the
AUTO bit in the PLL bandwidth control register (PBWC) is clear,
PLLIE cannot be written and reads as logic 0. Reset clears the PLLIE
bit.
1 = PLL interrupts enabled
0 = PLL interrupts disabled
PLLF — PLL Interrupt Flag Bit
This read-only bit is set whenever the LOCK bit toggles. PLLF
generates an interrupt request if the PLLIE bit also is set. PLLF
always reads as logic 0 when the AUTO bit in the PLL bandwidth
control register (PBWC) is clear. Clear the PLLF bit by reading the
PLL control register. Reset clears the PLLF bit.
1 = Change in lock condition
0 = No change in lock condition
NOTE:
Technical Data
128
Do not inadvertently clear the PLLF bit. Any read or read-modify-write
operation on the PLL control register clears the PLLF bit.
MOTOROLA
CGM Registers
PLLON — PLL On Bit
This read/write bit activates the PLL and enables the VCO clock,
CGMVCLK. PLLON cannot be cleared if the VCO clock is driving the
base clock, CGMOUT (BCS = 1). (See 8.4.8 Base Clock Selector
Circuit.) Reset sets this bit so that the loop can stabilize as the MCU
is powering up.
1 = PLL on
0 = PLL off
BCS — Base Clock Select Bit
This read/write bit selects either the oscillator output, CGMXCLK, or
the divided VCO clock, CGMPCLK, as the source of the CGM output,
CGMOUT. CGMOUT frequency is one-half the frequency of the
selected clock. BCS cannot be set while the PLLON bit is clear. After
toggling BCS, it may take up to three CGMXCLK and three
CGMPCLK cycles to complete the transition from one source clock to
the other. During the transition, CGMOUT is held in stasis. (See 8.4.8
Base Clock Selector Circuit.) Reset clears the BCS bit.
1 = CGMPCLK divided by two drives CGMOUT
0 = CGMXCLK divided by two drives CGMOUT
NOTE:
PLLON and BCS have built-in protection that prevents the base clock
selector circuit from selecting the VCO clock as the source of the base
clock if the PLL is off. Therefore, PLLON cannot be cleared when BCS
is set, and BCS cannot be set when PLLON is clear. If the PLL is off
(PLLON = 0), selecting CGMPCLK requires two writes to the PLL control
register. (See 8.4.8 Base Clock Selector Circuit.)
PRE1 and PRE0 — Prescaler Program Bits
These read/write bits control a prescaler that selects the prescaler
power-of-two multiplier, P. (See 8.4.3 PLL Circuits and 8.4.6
Programming the PLL.) PRE1 and PRE0 cannot be written when
the PLLON bit is set. Reset clears these bits.
These prescaler bits affects the relationship between the VCO clock
and the final system bus clock.
MOTOROLA
Technical Data
129
Table 8-2. PRE1 and PRE0 Programming
PRE1 and PRE0
P
Prescaler Multiplier
00
01
1
2
10
2
4
11
3
8
VPR1 and VPR0 — VCO Power-of-Two Range Select Bits
These read/write bits control the VCO’s hardware power-of-two range
multiplier E that, in conjunction with L (See 8.4.3 PLL Circuits, 8.4.6
Programming the PLL, and 8.6.4 PLL VCO Range Select
Register.) controls the hardware center-of-range frequency, fVRS.
VPR1:VPR0 cannot be written when the PLLON bit is set. Reset
clears these bits.
Table 8-3. VPR1 and VPR0 Programming
VPR1 and VPR0
E
VCO Power-of-Two
Range Multiplier
00
01
1
2
10
2
4
The PLL bandwidth control register (PBWC):
Technical Data
130
Selects automatic or manual (software-controlled) bandwidth
control mode
Indicates when the PLL is locked
In automatic bandwidth control mode, indicates when the PLL is in
acquisition or tracking mode
In manual operation, forces the PLL into acquisition or tracking
mode
MOTOROLA
CGM Registers
Address:
$0037
Bit 7
Read:
6
5
LOCK
AUTO
4
3
2
1
ACQ
Bit 0
R
Write:
Reset:
= Unimplemented
R
= Reserved
Figure 8-5. PLL Bandwidth Control Register (PBWCR)
AUTO — Automatic Bandwidth Control Bit
This read/write bit selects automatic or manual bandwidth control.
When initializing the PLL for manual operation (AUTO = 0), clear the
ACQ bit before turning on the PLL. Reset clears the AUTO bit.
1 = Automatic bandwidth control
0 = Manual bandwidth control
LOCK — Lock Indicator Bit
When the AUTO bit is set, LOCK is a read-only bit that becomes set
when the VCO clock, CGMVCLK, is locked (running at the
programmed frequency). When the AUTO bit is clear, LOCK reads as
logic 0 and has no meaning. The write one function of this bit is
reserved for test, so this bit must always be written a 0. Reset clears
the LOCK bit.
1 = VCO frequency correct or locked
0 = VCO frequency incorrect or unlocked
ACQ — Acquisition Mode Bit
When the AUTO bit is set, ACQ is a read-only bit that indicates
whether the PLL is in acquisition mode or tracking mode. When the
AUTO bit is clear, ACQ is a read/write bit that controls whether the
PLL is in acquisition or tracking mode.
In automatic bandwidth control mode (AUTO = 1), the last-written
value from manual operation is stored in a temporary location and is
recovered when manual operation resumes. Reset clears this bit,
enabling acquisition mode.
1 = Tracking mode
0 = Acquisition mode
MC68HC908SR12•MC68HC08SR12 — Rev. 4.0
MOTOROLA
Technical Data
131
The PLL multiplier select registers (PMSH and PMSL) contain the
programming information for the modulo feedback divider.
Address:
Read:
$0038
Bit 7
6
5
4
2
1
Bit 0
MUL11
MUL10
MUL9
MUL8
Write:
Reset:
= Unimplemented
Figure 8-6. PLL Multiplier Select Register High (PMSH)
Address:
$0039
Bit 7
6
5
4
3
2
1
Bit 0
MUL7
MUL6
MUL5
MUL4
MUL3
MUL2
MUL1
MUL0
Read:
Write:
Reset:
Figure 8-7. PLL Multiplier Select Register Low (PMSL)
MUL[11:0] — Multiplier Select Bits
These read/write bits control the modulo feedback divider that selects
the VCO frequency multiplier N. (See 8.4.3 PLL Circuits and 8.4.6
Programming the PLL.) A value of $0000 in the multiplier select
registers configure the modulo feedback divider the same as a value
of $0001. Reset initializes the registers to $0040 for a default multiply
value of 64.
NOTE:
Technical Data
132
The multiplier select bits have built-in protection such that they cannot
be written when the PLL is on (PLLON = 1).
MOTOROLA
CGM Registers
The PLL VCO range select register (PMRS) contains the programming
information required for the hardware configuration of the VCO.
Address:
$003A
Bit 7
6
5
4
3
2
1
Bit 0
VRS7
VRS6
VRS5
VRS4
VRS3
VRS2
VRS1
VRS0
Read:
Write:
Reset:
Figure 8-8. PLL VCO Range Select Register (PMRS)
VRS[7:0] — VCO Range Select Bits
These read/write bits control the hardware center-of-range linear
multiplier L which, in conjunction with E (See 8.4.3 PLL Circuits,
8.4.6 Programming the PLL, and 8.6.1 PLL Control Register.),
controls the hardware center-of-range frequency, fVRS. VRS[7:0]
cannot be written when the PLLON bit in the PCTL is set. (See 8.4.7
Special Programming Exceptions.)A value of $00 in the VCO
range select register disables the PLL and clears the BCS bit in the
PLL control register (PCTL). (See 8.4.8 Base Clock Selector Circuit
and 8.4.7 Special Programming Exceptions.). Reset initializes the
register to $40 for a default range multiply value of 64.
NOTE:
The VCO range select bits have built-in protection such that they cannot
be written when the PLL is on (PLLON = 1) and such that the VCO clock
cannot be selected as the source of the base clock (BCS = 1) if the VCO
range select bits are all clear.
The PLL VCO range select register must be programmed correctly.
Incorrect programming can result in failure of the PLL to achieve lock.
MOTOROLA
Technical Data
133
The PLL reference divider select register (PMDS) contains the
programming information for the modulo reference divider.
Address:
Read:
$003B
Bit 7
6
5
4
2
1
Bit 0
RDS3
RDS2
RDS1
RDS0
Write:
Reset:
= Unimplemented
Figure 8-9. PLL Reference Divider Select Register (PMDS)
RDS[3:0] — Reference Divider Select Bits
These read/write bits control the modulo reference divider that selects
the reference division factor, R. (See 8.4.3 PLL Circuits and 8.4.6
Programming the PLL.) RDS[3:0] cannot be written when the
PLLON bit in the PCTL is set. A value of $00 in the reference divider
select register configures the reference divider the same as a value of
$01. (See 8.4.7 Special Programming Exceptions.) Reset
initializes the register to $01 for a default divide value of 1.
Technical Data
134
NOTE:
The reference divider select bits have built-in protection such that they
cannot be written when the PLL is on (PLLON = 1).
NOTE:
The default divide value of 1 is recommended for all applications.
MOTOROLA
Interrupts
8.7 Interrupts
When the AUTO bit is set in the PLL bandwidth control register (PBWC),
the PLL can generate a CPU interrupt request every time the LOCK bit
changes state. The PLLIE bit in the PLL control register (PCTL) enables
CPU interrupts from the PLL. PLLF, the interrupt flag in the PCTL,
becomes set whether interrupts are enabled or not. When the AUTO bit
is clear, CPU interrupts from the PLL are disabled and PLLF reads as
logic 0.
Software should read the LOCK bit after a PLL interrupt request to see
if the request was due to an entry into lock or an exit from lock. When the
PLL enters lock, the divided VCO clock, CGMPCLK, divided by two can
be selected as the CGMOUT source by setting BCS in the PCTL. When
the PLL exits lock, the VCO clock frequency is corrupt, and appropriate
precautions should be taken. If the application is not frequency sensitive,
interrupts should be disabled to prevent PLL interrupt service routines
from impeding software performance or from exceeding stack
limitations.
NOTE:
Software can select the CGMPCLK divided by two as the CGMOUT
source even if the PLL is not locked (LOCK = 0). Therefore, software
should make sure the PLL is locked before setting the BCS bit.
8.8 Special Modes
The WAIT instruction puts the MCU in low power-consumption standby
modes.
8.8.1 Wait Mode
The WAIT instruction does not affect the CGM. Before entering wait
mode, software can disengage and turn off the PLL by clearing the BCS
and PLLON bits in the PLL control register (PCTL) to save power. Less
power-sensitive applications can disengage the PLL without turning it
off, so that the PLL clock is immediately available at WAIT exit. This
would be the case also when the PLL is to wake the MCU from wait
mode, such as when the PLL is first enabled and waiting for LOCK or
LOCK is lost.
MOTOROLA
Technical Data
135
8.8.2 Stop Mode
If the oscillator stop mode enable bit (STOP_ICLKEN, STOP_RCLKEN,
or STOP_XCLKEN in CONFIG2 register) for the selected oscillator is
configured to disabled the oscillator in stop mode, then the STOP
instruction disables the CGM (oscillator and phase locked loop) and
holds low all CGM outputs (CGMOUT, CGMVCLK, CGMPCLK, and
CGMINT).
If the STOP instruction is executed with the divided VCO clock,
CGMPCLK, divided by two driving CGMOUT, the PLL automatically
clears the BCS bit in the PLL control register (PCTL), thereby selecting
the oscillator clock, CGMXCLK, divided by two as the source of
CGMOUT. When the MCU recovers from STOP, the crystal clock
divided by two drives CGMOUT and BCS remains clear.
If the oscillator stop mode enable bit is configured for continuous
oscillator operation in stop mode, then the phase locked loop is shut off
but the CGMXCLK will continue to drive the SIM and other MCU subsystems.
8.8.3 CGM During Break Interrupts
The system integration module (SIM) controls whether status bits in
other modules can be cleared during the break state. The BCFE bit in
the SIM break flag control register (SBFCR) enables software to clear
status bits during the break state. (See 9.8.3 SIM Break Flag Control
Register.)
To allow software to clear status bits during a break interrupt, write a
logic 1 to the BCFE bit. If a status bit is cleared during the break state, it
remains cleared when the MCU exits the break state.
To protect the PLLF bit during the break state, write a logic 0 to the BCFE
bit. With BCFE at logic 0 (its default state), software can read and write
the PLL control register during the break state without affecting the PLLF
bit.
Technical Data
136
MOTOROLA
The acquisition and lock times of the PLL are, in many applications, the
most critical PLL design parameters. Proper design and use of the PLL
ensures the highest stability and lowest acquisition/lock times.
8.9.1 Acquisition/Lock Time Definitions
Typical control systems refer to the acquisition time or lock time as the
reaction time, within specified tolerances, of the system to a step input.
In a PLL, the step input occurs when the PLL is turned on or when it
suffers a noise hit. The tolerance is usually specified as a percent of the
step input or when the output settles to the desired value plus or minus
a percent of the frequency change. Therefore, the reaction time is
constant in this definition, regardless of the size of the step input. For
example, consider a system with a 5 percent acquisition time tolerance.
If a command instructs the system to change from 0Hz to 1MHz, the
acquisition time is the time taken for the frequency to reach
1MHz ±50kHz. 50kHz = 5% of the 1MHz step input. If the system is
operating at 1MHz and suffers a –100kHz noise hit, the acquisition time
is the time taken to return from 900kHz to 1MHz ±5kHz. 5kHz = 5% of
the 100kHz step input.
Other systems refer to acquisition and lock times as the time the system
takes to reduce the error between the actual output and the desired
output to within specified tolerances. Therefore, the acquisition or lock
time varies according to the original error in the output. Minor errors may
not even be registered. Typical PLL applications prefer to use this
definition because the system requires the output frequency to be within
a certain tolerance of the desired frequency regardless of the size of the
initial error.
8.9.2 Parametric Influences on Reaction Time
Acquisition and lock times are designed to be as short as possible while
still providing the highest possible stability. These reaction times are not
constant, however. Many factors directly and indirectly affect the
acquisition time.
MOTOROLA
Technical Data
137
The most critical parameter which affects the reaction times of the PLL
is the reference frequency, fRDV. This frequency is the input to the phase
detector and controls how often the PLL makes corrections. For stability,
the corrections must be small compared to the desired frequency, so
several corrections are required to reduce the frequency error.
Therefore, the slower the reference the longer it takes to make these
corrections. This parameter is under user control via the choice of crystal
frequency fXCLK and the R value programmed in the reference divider.
(See 8.4.3 PLL Circuits, 8.4.6 Programming the PLL, and 8.6.5 PLL
Another critical parameter is the external filter network. The PLL
modifies the voltage on the VCO by adding or subtracting charge from
capacitors in this network. Therefore, the rate at which the voltage
changes for a given frequency error (thus change in charge) is
proportional to the capacitance. The size of the capacitor also is related
to the stability of the PLL. If the capacitor is too small, the PLL cannot
make small enough adjustments to the voltage and the system cannot
lock. If the capacitor is too large, the PLL may not be able to adjust the
voltage in a reasonable time. (See 8.9.3 Choosing a Filter.)
Also important is the operating voltage potential applied to VDDA. The
power supply potential alters the characteristics of the PLL. A fixed value
is best. Variable supplies, such as batteries, are acceptable if they vary
within a known range at very slow speeds. Noise on the power supply is
not acceptable, because it causes small frequency errors which
continually change the acquisition time of the PLL.
Temperature and processing also can affect acquisition time because
the electrical characteristics of the PLL change. The part operates as
specified as long as these influences stay within the specified limits.
External factors, however, can cause drastic changes in the operation of
the PLL. These factors include noise injected into the PLL through the
filter capacitor, filter capacitor leakage, stray impedances on the circuit
board, and even humidity or circuit board contamination.
Technical Data
138
MOTOROLA
As described in 8.9.2 Parametric Influences on Reaction Time, the
external filter network is critical to the stability and reaction time of the
PLL. The PLL is also dependent on reference frequency and supply
voltage.
Either of the filter networks in Figure 8-10 is recommended when using
a 32.768kHz reference clock (CGMRCLK). Figure 8-10 (a) is used for
applications requiring better stability. Figure 8-10 (b) is used in low-cost
applications where stability is not critical.
CGMXFC
10 kΩ
CGMXFC
0.01 µF
0.47 µF
0.033 µF
VSSA
VSSA
(a)
(b)
Figure 8-10. PLL Filter
MOTOROLA
Technical Data
139
Technical Data
140
MOTOROLA
Section 9. System Integration Module (SIM)
9.1 Contents
9.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 142
9.3
SIM Bus Clock Control and Generation . . . . . . . . . . . . . . . . . 144
9.3.1
Bus Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 145
9.3.2
Clock Start-up from POR or LVI Reset. . . . . . . . . . . . . . . . 145
9.3.3
Clocks in Stop Mode and Wait Mode . . . . . . . . . . . . . . . . . 146
9.4
Reset and System Initialization. . . . . . . . . . . . . . . . . . . . . . . . 146
9.4.1
External Pin Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 147
9.4.2
Active Resets from Internal Sources . . . . . . . . . . . . . . . . . 147
9.4.2.1
Power-On Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 148
9.4.2.2
Computer Operating Properly (COP) Reset. . . . . . . . . . 149
9.4.2.3
Illegal Opcode Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . 150
9.4.2.4
Illegal Address Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . 150
9.4.2.5
Low-Voltage Inhibit (LVI) Reset . . . . . . . . . . . . . . . . . . . 150
9.4.2.6
Monitor Mode Entry Module Reset. . . . . . . . . . . . . . . . . 150
9.5
SIM Counter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 151
9.5.1
SIM Counter During Power-On Reset . . . . . . . . . . . . . . . . 151
9.5.2
SIM Counter During Stop Mode Recovery . . . . . . . . . . . . . 151
9.5.3
SIM Counter and Reset States. . . . . . . . . . . . . . . . . . . . . .151
9.6
Exception Control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 152
9.6.1
Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 152
9.6.1.1
Hardware Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . 154
9.6.1.2
SWI Instruction. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 155
9.6.1.3
Interrupt Status Registers . . . . . . . . . . . . . . . . . . . . . . . 155
9.6.1.4
Interrupt Status Register 1 . . . . . . . . . . . . . . . . . . . . . . . 155
9.6.1.5
Interrupt Status Register 2 . . . . . . . . . . . . . . . . . . . . . . . 157
9.6.1.6
Interrupt Status Register 3 . . . . . . . . . . . . . . . . . . . . . . . 157
9.6.2
Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 158
9.6.3
Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .158
MOTOROLA
Technical Data
141
9.6.4
Status Flag Protection in Break Mode . . . . . . . . . . . . . . . . 158
9.7
Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .159
9.7.1
Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 159
9.7.2
Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 160
9.8
SIM Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 161
9.8.1
SIM Break Status Register . . . . . . . . . . . . . . . . . . . . . . . . . 162
9.8.2
SIM Reset Status Register . . . . . . . . . . . . . . . . . . . . . . . . 163
9.8.3
SIM Break Flag Control Register . . . . . . . . . . . . . . . . . . . . 164
9.2 Introduction
This section describes the system integration module (SIM). Together
with the CPU, the SIM controls all MCU activities. A block diagram of the
SIM is shown in Figure 9-1. Table 9-1 is a summary of the SIM
input/output (I/O) registers. The SIM is a system state controller that
coordinates CPU and exception timing. The SIM is responsible for:
Bus clock generation and control for CPU and peripherals:
– Stop/wait/reset/break entry and recovery
– Internal clock control
Master reset control, including power-on reset (POR) and COP
timeout
Interrupt control:
– Acknowledge timing
– Arbitration control timing
– Vector address generation
CPU enable/disable timing
Modular architecture expandable to 128 interrupt sources
Table 9-1 shows the internal signal names used in this section.
Technical Data
142
MOTOROLA
Introduction
MODULE STOP
MODULE WAIT
CPU STOP (FROM CPU)
CPU WAIT (FROM CPU)
STOP/WAIT
CONTROL
SIMOSCEN (TO CGM, OSC)
SIM
COUNTER
COP CLOCK
ICLK (FROM OSC)
CGMOUT (FROM CGM)
÷2
CLOCK
CONTROL
VDD
CLOCK GENERATORS
INTERNAL CLOCKS
INTERNAL
PULLUP
DEVICE
RESET
PIN LOGIC
LVI (FROM LVI MODULE)
POR CONTROL
MASTER
RESET
CONTROL
RESET PIN CONTROL
SIM RESET STATUS REGISTER
ILLEGAL OPCODE (FROM CPU)
ILLEGAL ADDRESS (FROM ADDRESS
MAP DECODERS)
COP (FROM COP MODULE)
RESET
INTERRUPT SOURCES
INTERRUPT CONTROL
AND PRIORITY DECODE
CPU INTERFACE
Figure 9-1. SIM Block Diagram
Table 9-1. Signal Name Conventions
Signal Name
ICLK
CGMXCLK
CGMVCLK, CGMPCLK
CGMOUT
Description
Internal oscillator clock
Selected oscillator clock from oscillator module
PLL output and the divided PLL output
CGMPCLK-based or oscillator-based clock output from CGM module
(Bus clock = CGMOUT ÷ 2)
IAB
Internal address bus
IDB
Internal data bus
PORRST
Signal from the power-on reset module to the SIM
IRST
Internal reset signal
R/W
Read/write signal
MOTOROLA
Technical Data
143
Addr.
Register Name
Read:
$FE00
Write:
(SBSR)
Reset:
Bit 7
6
5
4
3
2
R
R
R
R
R
R
1
Bit 0
SBSW
Note
R
Note: Writing a logic 0 clears SBSW.
Read:
$FE01
Write:
(SRSR)
POR:
$FE03
Read:
Register Write:
(SBFCR)
Reset:
POR
PIN
COP
ILOP
ILAD
LVI
BCFE
R
R
R
R
R
R
R
Read:
$FE04
Write:
(INT1)
Reset:
IF6
IF5
IF4
IF3
IF2
IF1
R
R
R
R
R
R
R
R
Read:
$FE05
Write:
(INT2)
Reset:
IF14
IF13
IF12
IF11
IF10
IF9
IF8
IF7
R
R
R
R
R
R
R
R
Read:
$FE06
Write:
(INT3)
Reset:
IF17
IF16
IF15
R
R
R
R
R
R
R
R
= Unimplemented
R
= Reserved
Figure 9-2. SIM I/O Register Summary
9.3 SIM Bus Clock Control and Generation
The bus clock generator provides system clock signals for the CPU and
peripherals on the MCU. The system clocks are generated from an
incoming clock, CGMOUT, as shown in Figure 9-3. This clock can come
from either the oscillator module or from the on-chip PLL. (See Section
8. Clock Generator Module (CGM).)
Technical Data
144
MOTOROLA
OSC2
OSCCLK
TO TBM
CGMXCLK
OSC1
ICLK
STOP MODE CLOCK
ENABLE SIGNALS
FROM CONFIG2
TO TIM, ADC
SIM COUNTER
SIMOSCEN
SYSTEM INTEGRATION MODULE
CGMRCLK
CGMOUT
÷2
IT12
TO REST
OF MCU
BUS CLOCK
GENERATORS
IT23
TO REST
OF MCU
PTC1
SIMDIV2
MONITOR MODE
USER MODE
CGMVCLK
TO PWM
Figure 9-3. CGM Clock Signals
9.3.1 Bus Timing
In user mode, the internal bus frequency is either the oscillator output
(CGMXCLK) divided by four or the divided PLL output (CGMPCLK)
divided by four.
9.3.2 Clock Start-up from POR or LVI Reset
When the power-on reset module or the low-voltage inhibit module
generates a reset, the clocks to the CPU and peripherals are inactive
and held in an inactive phase until after the 4096 ICLK cycle POR
timeout has completed. The RST pin is driven low by the SIM during this
entire period. The IBUS clocks start upon completion of the timeout.
MOTOROLA
Technical Data
145
9.3.3 Clocks in Stop Mode and Wait Mode
Upon exit from stop mode by an interrupt, break, or reset, the SIM allows
ICLK to clock the SIM counter. The CPU and peripheral clocks do not
become active until after the stop delay timeout. This timeout is
selectable as 4096 or 32 ICLK cycles. (See 9.7.2 Stop Mode.)
In wait mode, the CPU clocks are inactive. The SIM also produces two
sets of clocks for other modules. Refer to the wait mode subsection of
each module to see if the module is active or inactive in wait mode.
Some modules can be programmed to be active in wait mode.
9.4 Reset and System Initialization
The MCU has these reset sources:
Power-on reset module (POR)
External reset pin (RST)
Computer operating properly module (COP)
Low-voltage inhibit module (LVI)
Illegal opcode
Illegal address
All of these resets produce the vector $FFFE:$FFFF ($FEFE:$FEFF in
monitor mode) and assert the internal reset signal (IRST). IRST causes
all registers to be returned to their default values and all modules to be
returned to their reset states.
An internal reset clears the SIM counter (see 9.5 SIM Counter), but an
external reset does not. Each of the resets sets a corresponding bit in
the SIM reset status register (SRSR). (See 9.8 SIM Registers.)
Technical Data
146
MOTOROLA
9.4.1 External Pin Reset
The RST pin circuit includes an internal pull-up device. Pulling the
asynchronous RST pin low halts all processing. The PIN bit of the SIM
reset status register (SRSR) is set as long as RST is held low for a
minimum of 67 ICLK cycles, assuming that neither the POR nor the LVI
was the source of the reset. See Table 9-2 for details.
Figure 9-4 shows the relative timing.
Table 9-2. PIN Bit Set Timing
Reset Type
Number of Cycles Required to Set PIN
POR/LVI
4163 (4096 + 64 + 3)
All others
67 (64 + 3)
ICLK
RST
IAB
VECT H VECT L
PC
Figure 9-4. External Reset Timing
9.4.2 Active Resets from Internal Sources
All internal reset sources actively pull the RST pin low for 32 ICLK cycles
to allow resetting of external peripherals. The internal reset signal IRST
continues to be asserted for an additional 32 cycles (see Figure 9-5). An
internal reset can be caused by an illegal address, illegal opcode, COP
timeout, LVI, or POR (see Figure 9-6).
NOTE:
For LVI or POR resets, the SIM cycles through 4096 + 32 ICLK cycles
during which the SIM forces the RST pin low. The internal reset signal
then follows the sequence from the falling edge of RST shown in
Figure 9-5.
MOTOROLA
Technical Data
147
IRST
RST
RST PULLED LOW BY MCU
32 CYCLES
32 CYCLES
ICLK
IAB
VECTOR HIGH
Figure 9-5. Internal Reset Timing
The COP reset is asynchronous to the bus clock.
ILLEGAL ADDRESS RST
ILLEGAL OPCODE RST
COPRST
LVI
POR
INTERNAL RESET
Figure 9-6. Sources of Internal Reset
The active reset feature allows the part to issue a reset to peripherals
and other chips within a system built around the MCU.
9.4.2.1 Power-On Reset
When power is first applied to the MCU, the power-on reset module
(POR) generates a pulse to indicate that power-on has occurred. The
external reset pin (RST) is held low while the SIM counter counts out
4096 + 32 ICLK cycles. Thirty-two ICLK cycles later, the CPU and
memories are released from reset to allow the reset vector sequence to
occur.
At power-on, these events occur:
Technical Data
148
A POR pulse is generated.
The internal reset signal is asserted.
The SIM enables CGMOUT.
Internal clocks to the CPU and modules are held inactive for 4096
ICLK cycles to allow stabilization of the oscillator.
The RST pin is driven low during the oscillator stabilization time.
The POR bit of the SIM reset status register (SRSR) is set and all
other bits in the register are cleared.
MOTOROLA
OSC1
PORRST
4096
CYCLES
32
CYCLES
32
CYCLES
ICLK
CGMOUT
RST
IRST
$FFFE
IAB
$FFFF
Figure 9-7. POR Recovery
9.4.2.2 Computer Operating Properly (COP) Reset
An input to the SIM is reserved for the COP reset signal. The overflow of
the COP counter causes an internal reset and sets the COP bit in the
SIM reset status register (SRSR). The SIM actively pulls down the RST
pin for all internal reset sources.
To prevent a COP module timeout, write any value to location $FFFF.
Writing to location $FFFF clears the COP counter and bits 12 through 5
of the SIM counter. The SIM counter output, which occurs at least every
213 – 24 ICLK cycles, drives the COP counter. The COP should be
serviced as soon as possible out of reset to guarantee the maximum
amount of time before the first timeout.
The COP module is disabled if the RST pin or the IRQ1 pin is held at
VTST while the MCU is in monitor mode. The COP module can be
disabled only through combinational logic conditioned with the high
voltage signal on the RST or the IRQ1 pin. This prevents the COP from
becoming disabled as a result of external noise. During a break state,
VTST on the RST pin disables the COP module.
MOTOROLA
Technical Data
149
9.4.2.3 Illegal Opcode Reset
The SIM decodes signals from the CPU to detect illegal instructions. An
illegal instruction sets the ILOP bit in the SIM reset status register
(SRSR) and causes a reset.
If the stop enable bit, STOP, in the mask option register is logic 0, the
SIM treats the STOP instruction as an illegal opcode and causes an
illegal opcode reset. The SIM actively pulls down the RST pin for all
9.4.2.4 Illegal Address Reset
An opcode fetch from an unmapped address generates an illegal
address reset. The SIM verifies that the CPU is fetching an opcode prior
to asserting the ILAD bit in the SIM reset status register (SRSR) and
resetting the MCU. A data fetch from an unmapped address does not
generate a reset. The SIM actively pulls down the RST pin for all internal
reset sources.
9.4.2.5 Low-Voltage Inhibit (LVI) Reset
The low-voltage inhibit module (LVI) asserts its output to the SIM when
the VDD voltage falls to the LVITRIPF voltage. The LVI bit in the SIM reset
status register (SRSR) is set, and the external reset pin (RST) is held low
while the SIM counter counts out 4096 + 32 ICLK cycles. Thirty-two ICLK
cycles later, the CPU is released from reset to allow the reset vector
sequence to occur. The SIM actively pulls down the RST pin for all
9.4.2.6 Monitor Mode Entry Module Reset
The monitor mode entry module reset asserts its output to the SIM when
monitor mode is entered in the condition where the reset vectors are
blank ($FF). (See Section 10. Monitor ROM (MON).) When MODRST
gets asserted, an internal reset occurs. The SIM actively pulls down the
RST pin for all internal reset sources.
Technical Data
150
MOTOROLA
SIM Counter
9.5 SIM Counter
The SIM counter is used by the power-on reset module (POR) and in
stop mode recovery to allow the oscillator time to stabilize before
enabling the internal bus (IBUS) clocks. The SIM counter also serves as
a prescaler for the computer operating properly module (COP). The SIM
counter overflow supplies the clock for the COP module. The SIM
counter is 12 bits long and is clocked by the falling edge of ICLK.
9.5.1 SIM Counter During Power-On Reset
The power-on reset module (POR) detects power applied to the MCU.
At power-on, the POR circuit asserts the signal PORRST. Once the SIM
is initialized, it enables the clock generation module (CGM) to drive the
bus clock state machine.
9.5.2 SIM Counter During Stop Mode Recovery
The SIM counter also is used for stop mode recovery. The STOP
instruction clears the SIM counter. After an interrupt, break, or reset, the
SIM senses the state of the short stop recovery bit, SSREC, in the
configuration register 1 (CONFIG1). If the SSREC bit is a logic 1, then
the stop recovery is reduced from the normal delay of 4096 ICLK cycles
down to 32 ICLK cycles. This is ideal for applications using canned
oscillators that do not require long start-up times from stop mode.
External crystal applications should use the full stop recovery time, that
is, with SSREC cleared.
9.5.3 SIM Counter and Reset States
External reset has no effect on the SIM counter. (See 9.7.2 Stop Mode
for details.) The SIM counter is free-running after all reset states. (See
9.4.2 Active Resets from Internal Sources for counter control and
internal reset recovery sequences.)
MOTOROLA
Technical Data
151
9.6 Exception Control
Normal, sequential program execution can be changed in three different
ways:
Interrupts:
– Maskable hardware CPU interrupts
– Non-maskable software interrupt instruction (SWI)
Reset
Break interrupts
9.6.1 Interrupts
At the beginning of an interrupt, the CPU saves the CPU register
contents on the stack and sets the interrupt mask (I bit) to prevent
additional interrupts. At the end of an interrupt, the RTI instruction
recovers the CPU register contents from the stack so that normal
processing can resume. Figure 9-8 shows interrupt entry timing, and
Figure 9-9 shows interrupt recovery timing.
MODULE
INTERRUPT
I-BIT
IAB
IDB
DUMMY
SP
DUMMY
SP – 1
SP – 2
PC – 1[7:0] PC – 1[15:8]
SP – 3
X
SP – 4
A
VECT H
CCR
VECT L
V DATA H
START ADDR
V DATA L
OPCODE
R/W
Figure 9-8. Interrupt Entry Timing
MODULE
INTERRUPT
I-BIT
IAB
IDB
SP – 4
SP – 3
CCR
SP – 2
A
SP – 1
X
SP
PC
PC – 1[15:8] PC – 1[7:0]
PC + 1
OPCODE
OPERAND
R/W
Figure 9-9. Interrupt Recovery Timing
Technical Data
152
MOTOROLA
Exception Control
Interrupts are latched, and arbitration is performed in the SIM at the start
of interrupt processing. The arbitration result is a constant that the CPU
uses to determine which vector to fetch. Once an interrupt is latched by
the SIM, no other interrupt can take precedence, regardless of priority,
until the latched interrupt is serviced (or the I bit is cleared).
(See Figure 9-10.)
FROM RESET
BREAK
I BIT
SET?
INTERRUPT?
YES
NO
YES
I-BIT SET?
NO
IRQ1
INTERRUPT?
YES
NO
STACK CPU REGISTERS
SET I-BIT
LOAD PC WITH INTERRUPT VECTOR
AS MANY INTERRUPTS
AS EXIST ON CHIP
FETCH NEXT
INSTRUCTION
SWI
INSTRUCTION?
YES
NO
RTI
INSTRUCTION?
YES
UNSTACK CPU REGISTERS
NO
EXECUTE INSTRUCTION
Figure 9-10. Interrupt Processing
MOTOROLA
Technical Data
153
9.6.1.1 Hardware Interrupts
A hardware interrupt does not stop the current instruction. Processing of
a hardware interrupt begins after completion of the current instruction.
When the current instruction is complete, the SIM checks all pending
hardware interrupts. If interrupts are not masked (I bit clear in the
condition code register) and if the corresponding interrupt enable bit is
set, the SIM proceeds with interrupt processing; otherwise, the next
instruction is fetched and executed.
If more than one interrupt is pending at the end of an instruction
execution, the highest priority interrupt is serviced first. Figure 9-11
demonstrates what happens when two interrupts are pending. If an
interrupt is pending upon exit from the original interrupt service routine,
the pending interrupt is serviced before the LDA instruction is executed.
CLI
BACKGROUND
ROUTINE
LDA #$FF
INT1
PSHH
INT1 INTERRUPT SERVICE ROUTINE
PULH
RTI
INT2
PSHH
INT2 INTERRUPT SERVICE ROUTINE
PULH
RTI
Figure 9-11Interrupt Recognition Example
The LDA opcode is prefetched by both the INT1 and INT2 RTI
instructions. However, in the case of the INT1 RTI prefetch, this is a
redundant operation.
NOTE:
Technical Data
154
To maintain compatibility with the M6805 Family, the H register is not
pushed on the stack during interrupt entry. If the interrupt service routine
modifies the H register or uses the indexed addressing mode, software
should save the H register and then restore it prior to exiting the routine.
MOTOROLA
Exception Control
9.6.1.2 SWI Instruction
The SWI instruction is a non-maskable instruction that causes an
interrupt regardless of the state of the interrupt mask (I bit) in the
condition code register.
NOTE:
A software interrupt pushes PC onto the stack. A software interrupt does
not push PC – 1, as a hardware interrupt does.
9.6.1.3 Interrupt Status Registers
The flags in the interrupt status registers identify maskable interrupt
sources. Table 9-3 summarizes the interrupt sources and the interrupt
status register flags that they set. The interrupt status registers can be
useful for debugging.
9.6.1.4 Interrupt Status Register 1
Address:
$FE04
Bit 7
6
5
4
3
2
1
Bit 0
Read:
IF6
IF5
IF4
IF3
IF2
IF1
Write:
R
R
R
R
R
R
R
R
Reset:
R
= Reserved
Figure 9-12. Interrupt Status Register 1 (INT1)
IF6–IF1 — Interrupt Flags 6–1
These flags indicate the presence of interrupt requests from the
sources shown in Table 9-3.
1 = Interrupt request present
0 = No interrupt request present
Bit 0 and Bit 1 — Always read 0
MOTOROLA
Technical Data
155
Table 9-3. Interrupt Sources
Priority
Lowest
INT
Flag
IF17
IF16
IF15
IF14
IF13
IF12
IF11
IF10
IF9
IF8
IF7
IF6
IF5
IF4
IF3
IF2
IF1
Highest
Technical Data
156
Vector
Address
$FFDA
$FFDB
$FFDC
$FFDD
$FFDE
$FFDF
$FFE0
$FFE1
$FFE2
$FFE3
$FFE4
$FFE5
$FFE6
$FFE7
$FFE8
$FFE9
$FFEA
$FFEB
$FFEC
$FFED
$FFEE
$FFEF
$FFF0
$FFF1
$FFF2
$FFF3
$FFF4
$FFF5
$FFF6
$FFF7
$FFF8
$FFF9
$FFFA
$FFFB
$FFFC
$FFFD
$FFFE
$FFFF
Interrupt Source
Timebase Module
Analog Module
ADC Conversion Complete
Keyboard
SCI Transmit
SCI Receive
SCI Error
MMIIC
TIM2 Overflow
TIM2 Channel 1
TIM2 Channel 0
TIM1 Overflow
TIM1 Channel 1
TIM1 Channel 0
PLL
IRQ2
IRQ1
SWI
Reset
MOTOROLA
Exception Control
9.6.1.5 Interrupt Status Register 2
Address:
$FE05
Bit 7
6
5
4
3
2
1
Bit 0
Read:
IF14
IF13
IF12
IF11
IF10
IF9
IF8
IF7
Write:
R
R
R
R
R
R
R
R
Reset:
R
= Reserved
Figure 9-13. Interrupt Status Register 2 (INT2)
IF14–IF7 — Interrupt Flags 14–7
9.6.1.6 Interrupt Status Register 3
Address:
$FE06
Bit 7
6
5
4
3
2
1
Bit 0
Read:
IF17
IF16
IF15
Write:
R
R
R
R
R
R
R
R
Reset:
R
= Reserved
Figure 9-14. Interrupt Status Register 3 (INT3)
IF17–IF15 — Interrupt Flags 17–15
These flags indicate the presence of an interrupt request from the
source shown in Table 9-3.
MOTOROLA
Technical Data
157
9.6.2 Reset
All reset sources always have equal and highest priority and cannot be
arbitrated.
9.6.3 Break Interrupts
The break module can stop normal program flow at a softwareprogrammable break point by asserting its break interrupt output. (See
Section 23. Break Module (BRK).) The SIM puts the CPU into the
break state by forcing it to the SWI vector location. Refer to the break
interrupt subsection of each module to see how each module is affected
by the break state.
9.6.4 Status Flag Protection in Break Mode
The SIM controls whether status flags contained in other modules can
be cleared during break mode. The user can select whether flags are
protected from being cleared by properly initializing the break clear flag
enable bit (BCFE) in the SIM break flag control register (SBFCR).
Protecting flags in break mode ensures that set flags will not be cleared
while in break mode. This protection allows registers to be freely read
and written during break mode without losing status flag information.
Setting the BCFE bit enables the clearing mechanisms. Once cleared in
break mode, a flag remains cleared even when break mode is exited.
Status flags with a 2-step clearing mechanism — for example, a read of
one register followed by the read or write of another — are protected,
even when the first step is accomplished prior to entering break mode.
Upon leaving break mode, execution of the second step will clear the flag
as normal.
Technical Data
158
MOTOROLA
Low-Power Modes
9.7 Low-Power Modes
Executing the WAIT or STOP instruction puts the MCU in a low powerconsumption mode for standby situations. The SIM holds the CPU in a
non-clocked state. The operation of each of these modes is described in
the following subsections. Both STOP and WAIT clear the interrupt mask
(I) in the condition code register, allowing interrupts to occur.
9.7.1 Wait Mode
In wait mode, the CPU clocks are inactive while the peripheral clocks
continue to run. Figure 9-15 shows the timing for wait mode entry.
A module that is active during wait mode can wake up the CPU with an
interrupt if the interrupt is enabled. Stacking for the interrupt begins one
cycle after the WAIT instruction during which the interrupt occurred. In
wait mode, the CPU clocks are inactive. Refer to the wait mode
subsection of each module to see if the module is active or inactive in
wait mode. Some modules can be programmed to be active in wait
mode.
Wait mode also can be exited by a reset or break. A break interrupt
during wait mode sets the SIM break stop/wait bit, SBSW, in the SIM
break status register (SBSR). If the COP disable bit, COPD, in the mask
option register is logic 0, then the computer operating properly module
(COP) is enabled and remains active in wait mode.
IAB
IDB
WAIT ADDR
WAIT ADDR + 1
PREVIOUS DATA
SAME
NEXT OPCODE
SAME
SAME
SAME
R/W
NOTE: Previous data can be operand data or the WAIT opcode, depending on the
last instruction.
Figure 9-15. Wait Mode Entry Timing
Figure 9-16 and Figure 9-17 show the timing for WAIT recovery.
MOTOROLA
Technical Data
159
IAB
$6E0B
IDB
$A6
$6E0C
$A6
$A6
$00FF
$01
$0B
$00FE
$00FD
$00FC
$6E
EXITSTOPWAIT
NOTE: EXITSTOPWAIT = RST pin OR CPU interrupt OR break interrupt
Figure 9-16. Wait Recovery from Interrupt or Break
32
CYCLES
IAB
IDB
32
CYCLES
$6E0B
$A6
$A6
RST VCT H RST VCT L
$A6
RST
ICLK
Figure 9-17. Wait Recovery from Internal Reset
9.7.2 Stop Mode
In stop mode, the SIM counter is reset and the system clocks are
disabled. An interrupt request from a module can cause an exit from stop
mode. Stacking for interrupts begins after the selected stop recovery
time has elapsed. Reset or break also causes an exit from stop mode.
The SIM disables the clock generator module output (CGMOUT) in stop
mode, stopping the CPU and peripherals. Stop recovery time is
selectable using the SSREC bit in the configuration register 1
(CONFIG1). If SSREC is set, stop recovery is reduced from the normal
delay of 4096 ICLK cycles down to 32. This is ideal for applications using
canned oscillators that do not require long start-up times from stop
mode.
NOTE:
Technical Data
160
External crystal applications should use the full stop recovery time by
clearing the SSREC bit.
MOTOROLA
SIM Registers
A break interrupt during stop mode sets the SIM break stop/wait bit
(SBSW) in the SIM break status register (SBSR).
The SIM counter is held in reset from the execution of the STOP
instruction until the beginning of stop recovery. It is then used to time the
recovery period. Figure 9-18 shows stop mode entry timing.
NOTE:
To minimize stop current, all pins configured as inputs should be driven
to a logic 1 or logic 0.
CPUSTOP
IAB
STOP ADDR
IDB
STOP ADDR + 1
PREVIOUS DATA
SAME
NEXT OPCODE
SAME
SAME
SAME
R/W
NOTE: Previous data can be operand data or the STOP opcode, depending on the last
instruction.
Figure 9-18. Stop Mode Entry Timing
STOP RECOVERY PERIOD
ICLK
INT/BREAK
IAB
STOP + 2
STOP +1
STOP + 2
SP
SP – 1
SP – 2
SP – 3
Figure 9-19. Stop Mode Recovery from Interrupt or Break
9.8 SIM Registers
The SIM has three memory-mapped registers:
SIM Break Status Register (SBSR) — $FE00
SIM Reset Status Register (SRSR) — $FE01
SIM Break Flag Control Register (SBFCR) — $FE03
MOTOROLA
Technical Data
161
9.8.1 SIM Break Status Register
The SIM break status register (SBSR) contains a flag to indicate that a
break caused an exit from stop mode or wait mode.
Address:
$FE00
Bit 7
6
5
4
3
2
R
R
R
R
R
R
Read:
1
Bit 0
SBSW
R
Write:
Note
Reset:
R
= Reserved
Figure 9-20. SIM Break Status Register (SBSR)
SBSW — Break Wait Bit
This status bit is set when a break interrupt causes an exit from wait
mode or stop mode. Clear SBSW by writing a logic 0 to it. Reset clears
SBSW.
1 = Stop mode or wait mode was exited by break interrupt
0 = Stop mode or wait mode was not exited by break interrupt
SBSW can be read within the break interrupt routine. The user can
modify the return address on the stack by subtracting 1 from it. The
following code is an example.
This code works if the H register has been pushed onto the stack in the break
service routine software. This code should be executed at the end of the break
HIBYTE
EQU
LOBYTE
EQU
If not SBSW, do RTI
BRCLR
SBSW,SBSR, RETURN
; See if wait mode or stop mode was exited by
; break.
TST
LOBYTE,SP
;If RETURNLO is not zero,
BNE
DOLO
;then just decrement low byte.
DEC
HIBYTE,SP
;Else deal with high byte, too.
DOLO
DEC
LOBYTE,SP
;Point to WAIT/STOP opcode.
RETURN
PULH
RTI
Technical Data
162
;Restore H register.
MOTOROLA
SIM Registers
9.8.2 SIM Reset Status Register
This register contains six flags that show the source of the last reset
provided all previous reset status bits have been cleared. Clear the SIM
reset status register by reading it. A power-on reset sets the POR bit and
clears all other bits in the register.
Address:
Read:
$FE01
Bit 7
6
5
4
3
2
1
Bit 0
POR
PIN
COP
ILOP
ILAD
LVI
Write:
Reset:
= Unimplemented
Figure 9-21. SIM Reset Status Register (SRSR)
POR — Power-On Reset Bit
1 = Last reset caused by POR circuit
0 = Read of SRSR
PIN — External Reset Bit
1 = Last reset caused by external reset pin (RST)
0 = POR or read of SRSR
COP — Computer Operating Properly Reset Bit
1 = Last reset caused by COP counter
ILOP — Illegal Opcode Reset Bit
1 = Last reset caused by an illegal opcode
ILAD — Illegal Address Reset Bit (opcode fetches only)
1 = Last reset caused by an opcode fetch from an illegal address
LVI — Low-Voltage Inhibit Reset Bit
1 = Last reset caused by the LVI circuit
MOTOROLA
Technical Data
163
9.8.3 SIM Break Flag Control Register
The SIM break control register contains a bit that enables software to
clear status bits while the MCU is in a break state.
Address:
$FE03
Bit 7
6
5
4
3
2
1
Bit 0
BCFE
R
R
R
R
R
R
R
Read:
Write:
Reset:
R
= Reserved
Figure 9-22. SIM Break Flag Control Register (SBFCR)
BCFE — Break Clear Flag Enable Bit
This read/write bit enables software to clear status bits by accessing
status registers while the MCU is in a break state. To clear status bits
during the break state, the BCFE bit must be set.
1 = Status bits clearable during break
0 = Status bits not clearable during break
Technical Data
164
MOTOROLA
Technical Data — MC68HC908SR12•MC68HC08SR12
10.1 Contents
10.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 165
10.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 166
10.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 166
10.4.1 Entering Monitor Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . 168
10.4.2 Data Format . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .172
10.4.3 Break Signal . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .172
10.4.4 Baud Rate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 173
10.4.5 Commands . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 173
10.5
Security. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 178
10.2 Introduction
This section describes the monitor ROM (MON) and the monitor mode
entry methods. The monitor ROM allows complete testing of the MCU
through a single-wire interface with a host computer. Monitor mode entry
can be achieved without use of the higher test voltage, VTST, as long as
vector addresses $FFFE and $FFFF are blank, thus reducing the
hardware requirements for in-circuit programming.
MOTOROLA
Monitor ROM (MON)
Technical Data
165
Monitor ROM (MON)
10.3 Features
Features of the monitor ROM include:
Normal user-mode pin functionality
One pin dedicated to serial communication between monitor ROM
and host computer
Standard mark/space non-return-to-zero (NRZ) communication
with host computer
Execution of code in RAM or FLASH
FLASH memory security feature1
FLASH memory programming interface
Enhanced PLL (phase-locked loop) option to allow use of external
32.768-kHz crystal to generate internal frequency of 2.4576 MHz
368 bytes monitor ROM code size ($FE10 to $FF7F)
Monitor mode entry without high voltage, VTST, if reset vector is
blank ($FFFE and $FFFF contain $FF)
Standard monitor mode entry if high voltage, VTST, is applied to
IRQ1
The monitor ROM receives and executes commands from a host
computer. Figure 10-1 shows an example circuit used to enter monitor
mode and communicate with a host computer via a standard RS-232
interface.
Simple monitor commands can access any memory address. In monitor
mode, the MCU can execute code downloaded into RAM by a host
computer while most MCU pins retain normal operating mode functions.
All communication between the host computer and the MCU is through
the PTA0 pin. A level-shifting and multiplexing interface is required
between PTA0 and the host computer. PTA0 is used in a wired-OR
configuration and requires a pullup resistor.
1. No security feature is absolutely secure. However, Motorola’s strategy is to make reading or
copying the FLASH difficult for unauthorized users.
Technical Data
166
Monitor ROM (MON)
MOTOROLA
Monitor ROM (MON)
68HC908SR12
RST
0.1 µF
VTST
(SEE NOTE 3)
RESET VECTORS
$FFFE
10 kΩ
(SEE NOTES 2
AND 3)
C
SW2
$FFFF
IRQ1
D
0.01 µF
CGMXFC
4.9152MHz/9.8304MHz
10 kΩ
0.033 µF
SW3
(SEE NOTE 2)
C
10 µF
3
MC145407
D
10 MΩ
1
6–30 pF
10 µF
18
C
32.768 kHz XTAL
4
10 µF
17
330 kΩ
2
19
DB-25
2
5
16
3
6
15
10 µF
VDD
OSC1
OSC2
SW4
(SEE NOTE 2)
VSS
VSSA
D
VSSAM
6–30 pF
VREFL
VDD
VDD
VDDA
VREFH
0.1 µF
7
VDD
1
MC74HC125
2
3
6
5
4
VDD
14
10 kΩ
PTA0
PTC1
VDD
VDD
7
A
(SEE NOTE 1)
SW1
B
PTA1
PTA2
Notes:
1. For monitor mode entry when SW2 at position C (IRQ1 = VTST):
SW1: Position A — Bus clock = CGMXCLK ÷ 4
SW1: Position B — Bus clock = CGMXCLK ÷ 2
2. SW2, SW3, and SW4: Position C — Enter monitor mode using off-chip oscillator only.
SW2, SW3, and SW4: Position D — Enter monitor mode using 32.768kHz XTAL and internal PLL.
3. See Table 24-5 for IRQ1 voltage level requirements.
4. See Table 10-1 for other monitor mode entry configurations.
Figure 10-1. Monitor Mode Circuit
MOTOROLA
Monitor ROM (MON)
Technical Data
167
Monitor ROM (MON)
The monitor code allows enabling the PLL to generate the internal clock,
provided the reset vector is blank ($FF), when the device is being
clocked by a low-frequency crystal. This entry method, which is enabled
when IRQ1 is held low out of reset, is intended to support serial
communication/programming at 9600 baud in monitor mode by stepping
up the external frequency (assumed to be 32.768 kHz) by a fixed amount
to generate the desired internal frequency (2.4576 MHz).
If the reset vector is not blank (not $FF), the frequency stepping feature
is not supported, because IRQ1 cannot be held low for monitor mode
entry. With a non-blank reset vector, entry into monitor mode requires
VTST on IRQ1.
Table 10-1 shows the pin conditions for entering monitor mode. As
specified in the table, monitor mode may be entered after a POR and will
allow communication at 9600 baud provided one of the following sets of
conditions is met:
1. If $FFFE and $FFFF do not contain $FF (programmed state):
– The external clock is 4.9152 MHz with PTC1 low or
9.8304 MHz with PTC1 high
– IRQ1 = VTST (PLL off)
2. If $FFFE and $FFFF both contain $FF (erased state):
– The external clock is 9.8304 MHz
– IRQ1 = VDD (this can be implemented through the internal
IRQ1 pullup; PLL off)
3. If $FFFE and $FFFF both contain $FF (erased state):
– The external clock is 32.768 kHz (crystal)
– IRQ1 = VSS (this setting initiates the PLL to boost the external
32.768 kHz to an internal bus frequency of 2.4576 MHz)
Technical Data
168
Monitor ROM (MON)
MOTOROLA
Monitor ROM (MON)
MOTOROLA
Table 10-1. Monitor Mode Signal Requirements and Options
IRQ1
RST
Address
$FFFE/
$FFFF
PTA2
PTA1
PTA0(1)
PTC1
External
Clock
Bus
Frequency
PLL
COP
Baud
Rate
X
GND
X
X
X
X
X
X
X
Disabled
No operation until
reset goes high
VTST
VDD
or
VTST
X
1
2.4576
MHz
OFF
Disabled
9600
PTA1 and PTA2
voltages only
required if
IRQ1 = VTST;
PTC1 determines
frequency divider
VDD
or
VTST
X
2.4576
MHz
OFF
Disabled
9600
PTA1 and PTA2
voltages only
required if
IRQ1 = VTST;
PTC1 determines
frequency divider
VDD
Blank
"$FFFF"
X
2.4576
MHz
OFF
Disabled
9600
External frequency
always divided by 4
Blank
"$FFFF"
X
2.4576
MHz
ON
Disabled
9600
kHz(3)
PLL enabled
(BCS set)
in monitor code
VTST
VDD
GND
VDD
MHz(2)
1
1
9.8304
MHz(2)
X
1
X
9.8304
MHz(3)
X
1
X
32.768
Comment
VDD
or
GND
VTST
Blank
"$FFFF"
X
X
X
X
X
OFF
Enabled
Enters user
mode — will
encounter an illegal
address reset
VDD
or
GND
VDD
or
VTST
Not Blank
X
X
X
X
X
OFF
Enabled
Enters user mode
Monitor ROM (MON)
169
Technical Data
Notes:
1. PTA0 = 1 if serial communication; PTA0 = 0 if parallel communication (factory use only)
2. When IRQ1 = VTST, external clock must be derived by a 4.9152MHz or 9.8304MHz off-chip oscillator.
3. External clock is derived by a crystal or an off-chip oscillator.
Monitor ROM (MON)
If VTST is applied to IRQ1 and PTC1 is low upon monitor mode entry
(above condition set 1), the bus frequency is a divide-by-two of the input
clock. If PTC1 is high with VTST applied to IRQ1 upon monitor mode
entry, the bus frequency will be a divide-by-four of the input clock.
Holding the PTC1 pin low when entering monitor mode causes a bypass
of a divide-by-two stage at the oscillator only if VTST is applied to IRQ1.
In this event, the CGMOUT frequency is equal to the CGMXCLK
frequency, and the OSC1 input directly generates internal bus clocks. In
this case, the OSC1 signal must have a 50% duty cycle at maximum bus
frequency.
If entering monitor mode without high voltage on IRQ1 (above condition
set 2 or 3, where applied voltage is either VDD or VSS), then all port A pin
requirements and conditions, including the PTC1 frequency divisor
selection, are not in effect. This is to reduce circuit requirements when
performing in-circuit programming.
NOTE:
If the reset vector is blank and monitor mode is entered, the chip will see
an additional reset cycle after the initial POR reset. Once the part has
been programmed, the traditional method of applying a voltage, VTST, to
IRQ1 must be used to enter monitor mode.
The COP module is disabled in monitor mode based on these
conditions:
If monitor mode was entered as a result of the reset vector being
blank (above condition set 2 or 3), the COP is always disabled
regardless of the state of IRQ1 or RST.
If monitor mode was entered with VTST on IRQ1 (condition set 1),
then the COP is disabled as long as VTST is applied to either IRQ1
or RST.
The second condition states that as long as VTST is maintained on the
IRQ1 pin after entering monitor mode, or if VTST is applied to RST after
the initial reset to get into monitor mode (when VTST was applied to
IRQ1), then the COP will be disabled. In the latter situation, after VTST is
applied to the RST pin, VTST can be removed from the IRQ1 pin in the
interest of freeing the IRQ1 for normal functionality in monitor mode.
Technical Data
170
Monitor ROM (MON)
MOTOROLA
Monitor ROM (MON)
Figure 10-2 shows a simplified diagram of the monitor mode entry when
the reset vector is blank and just 1 x VDD voltage is applied to the IRQ1
pin. An external oscillator of 9.8304 MHz is required for a baud rate of
9600, as the internal bus frequency is automatically set to the external
frequency divided by four.
POR RESET
IS VECTOR
BLANK?
NO
NORMAL USER
MODE
YES
MONITOR MODE
EXECUTE
MONITOR
CODE
POR
TRIGGERED?
NO
YES
Figure 10-2. Low-Voltage Monitor Mode Entry Flowchart
Enter monitor mode with pin configuration shown in Figure 10-1 by
pulling RST low and then high. The rising edge of RST latches monitor
mode. Once monitor mode is latched, the values on the specified pins
can change.
Once out of reset, the MCU waits for the host to send eight security
bytes. (See 10.5 Security.) After the security bytes, the MCU sends a
break signal (10 consecutive logic 0s) to the host, indicating that it is
ready to receive a command.
In monitor mode, the MCU uses different vectors for reset, SWI
(software interrupt), and break interrupt than those for user mode. The
alternate vectors are in the $FE page instead of the $FF page and allow
code execution from the internal monitor firmware instead of user code.
MOTOROLA
Monitor ROM (MON)
Technical Data
171
Monitor ROM (MON)
NOTE:
Exiting monitor mode after it has been initiated by having a blank reset
vector requires a power-on reset (POR). Pulling RST low will not exit
monitor mode in this situation.
Table 10-2 summarizes the differences between user mode and monitor
mode.
Table 10-2. Mode Differences
Functions
Modes
Reset
Vector
High
Reset
Vector
Low
Break
Vector
High
Break
Vector
Low
SWI
Vector
High
SWI
Vector
Low
User
$FFFE
$FFFF
$FFFC
$FFFD
$FFFC
$FFFD
Monitor
$FEFE
$FEFF
$FEFC
$FEFD
$FEFC
$FEFD
10.4.2 Data Format
Communication with the monitor ROM is in standard non-return-to-zero
(NRZ) mark/space data format. Transmit and receive baud rates must
be identical.
START
BIT
BIT 0
BIT 1
BIT 2
BIT 3
BIT 4
BIT 5
BIT 6
NEXT
START
BIT
STOP
BIT
BIT 7
Figure 10-3. Monitor Data Format
10.4.3 Break Signal
A start bit (logic 0) followed by nine logic 0 bits is a break signal. When
the monitor receives a break signal, it drives the PTA0 pin high for the
duration of two bits and then echoes back the break signal.
MISSING STOP BIT
2-STOP BIT DELAY BEFORE ZERO ECHO
2
3
4
5
6
1
2
3
4
5
6
7
Figure 10-4. Break Transaction
Technical Data
172
Monitor ROM (MON)
MOTOROLA
Monitor ROM (MON)
10.4.4 Baud Rate
The communication baud rate is controlled by the crystal frequency and
the state of the PTC1 pin (when IRQ1 is set to VTST) upon entry into
monitor mode. When PTC1 is high, the divide by ratio is 1024. If the
PTC1 pin is at logic 0 upon entry into monitor mode, the divide by ratio
is 512.
If monitor mode was entered with VDD on IRQ1, then the divide by ratio
is set at 1024, regardless of PTC1. If monitor mode was entered with VSS
on IRQ, then the internal PLL steps up the external frequency, presumed
to be 32.768 kHz, to 2.4576 MHz. These latter two conditions for monitor
mode entry require that the reset vector is blank.
Table 10-3 lists external frequencies required to achieve a standard
baud rate of 9600 BPS. Other standard baud rates can be accomplished
using proportionally higher or lower frequency generators. If using a
crystal as the clock source, be aware of the upper frequency limit that the
internal clock module can handle. See 24.6 5.0V DC Electrical
Characteristics and 24.8 5.0V Control Timing for this limit.
Table 10-3. Monitor Baud Rate Selection
External
Frequency
IRQ1
PTC1
Internal
Frequency
Baud Rate
(BPS)
4.9152 MHz
VTST
2.4576 MHz
9600
9.8304 MHz
VTST
1
2.4576 MHz
9600
9.8304 MHz
VDD
X
2.4576 MHz
9600
32.768 kHz
VSS
X
2.4576 MHz
9600
10.4.5 Commands
The monitor ROM firmware uses these commands:
READ (read memory)
WRITE (write memory)
IREAD (indexed read)
MOTOROLA
Monitor ROM (MON)
Technical Data
173
Monitor ROM (MON)
IWRITE (indexed write)
READSP (read stack pointer)
RUN (run user program)
The monitor ROM firmware echoes each received byte back to the PTA0
pin for error checking. An 11-bit delay at the end of each command
allows the host to send a break character to cancel the command. A
delay of two bit times occurs before each echo and before READ,
IREAD, or READSP data is returned. The data returned by a read
command appears after the echo of the last byte of the command.
NOTE:
Wait one bit time after each echo before sending the next byte.
FROM
HOST
READ
4
ADDRESS
HIGH
READ
4
1
ADDRESS
HIGH
ADDRESS
LOW
1
4
ADDRESS
LOW
1
DATA
3, 2
4
ECHO
RETURN
Notes:
1 = Echo delay, 2 bit times
2 = Data return delay, 2 bit times
3 = Cancel command delay, 11 bit times
4 = Wait 1 bit time before sending next byte.
Figure 10-5. Read Transaction
FROM
HOST
3
ADDRESS
HIGH
WRITE
WRITE
1
3
ADDRESS
HIGH
1
ADDRESS
LOW
3
ADDRESS
LOW
1
DATA
DATA
3
1
2, 3
ECHO
Notes:
2 = Cancel command delay, 11 bit times
3 = Wait 1 bit time before sending next byte.
Figure 10-6. Write Transaction
Technical Data
174
Monitor ROM (MON)
MOTOROLA
Monitor ROM (MON)
A brief description of each monitor mode command is given in
Table 10-4 through Table 10-9.
Table 10-4. READ (Read Memory) Command
Description
Read byte from memory
Operand
2-byte address in high-byte:low-byte order
Data
Returned
Returns contents of specified address
Opcode
$4A
Command Sequence
SENT TO
MONITOR
ADDRESS
HIGH
READ
READ
ADDRESS
HIGH
ADDRESS
LOW
ADDRESS
LOW
DATA
ECHO
RETURN
Table 10-5. WRITE (Write Memory) Command
Description
Write byte to memory
Operand
2-byte address in high-byte:low-byte order; low byte followed by
data byte
Data
Returned
None
Opcode
$49
Command Sequence
FROM
HOST
WRITE
WRITE
ADDRESS
HIGH
ADDRESS
HIGH
ADDRESS
LOW
ADDRESS
LOW
DATA
DATA
ECHO
MOTOROLA
Monitor ROM (MON)
Technical Data
175
Monitor ROM (MON)
Table 10-6. IREAD (Indexed Read) Command
Description
Read next 2 bytes in memory from last address accessed
Operand
2-byte address in high byte:low byte order
Data
Returned
Returns contents of next two addresses
Opcode
$1A
Command Sequence
FROM
HOST
IREAD
IREAD
DATA
ECHO
DATA
RETURN
Table 10-7. IWRITE (Indexed Write) Command
Description
Write to last address accessed + 1
Operand
Single data byte
Data
Returned
None
Opcode
$19
Command Sequence
FROM
HOST
IWRITE
DATA
IWRITE
DATA
ECHO
Technical Data
176
Monitor ROM (MON)
MOTOROLA
Monitor ROM (MON)
A sequence of IREAD or IWRITE commands can access a block of
memory sequentially over the full 64k-byte memory map.
Table 10-8. READSP (Read Stack Pointer) Command
Description
Reads stack pointer
Operand
None
Data
Returned
Returns incremented stack pointer value (SP + 1) in high-byte:lowbyte order
Opcode
$0C
Command Sequence
FROM
HOST
READSP
SP
HIGH
READSP
ECHO
SP
LOW
RETURN
Table 10-9. RUN (Run User Program) Command
Description
Executes PULH and RTI instructions
Operand
None
Data
Returned
None
Opcode
$28
Command Sequence
FROM
HOST
RUN
RUN
ECHO
MOTOROLA
Monitor ROM (MON)
Technical Data
177
Monitor ROM (MON)
The MCU executes the SWI and PSHH instructions when it enters
monitor mode. The RUN command tells the MCU to execute the PULH
and RTI instructions. Before sending the RUN command, the host can
modify the stacked CPU registers to prepare to run the host program.
The READSP command returns the incremented stack pointer value,
SP + 1. The high and low bytes of the program counter are at addresses
SP + 5 and SP + 6.
SP
HIGH BYTE OF INDEX REGISTER
SP + 1
CONDITION CODE REGISTER
SP + 2
ACCUMULATOR
SP + 3
LOW BYTE OF INDEX REGISTER
SP + 4
HIGH BYTE OF PROGRAM COUNTER SP + 5
LOW BYTE OF PROGRAM COUNTER SP + 6
SP + 7
Figure 10-7. Stack Pointer at Monitor Mode Entry
10.5 Security
A security feature discourages unauthorized reading of FLASH locations
while in monitor mode. The host can bypass the security feature at
monitor mode entry by sending eight security bytes that match the bytes
at locations $FFF6–$FFFD. Locations $FFF6–$FFFD contain userdefined data.
NOTE:
Do not leave locations $FFF6–$FFFD blank. For security reasons,
program locations $FFF6–$FFFD even if they are not used for vectors.
During monitor mode entry, the MCU waits after the power-on reset for
the host to send the eight security bytes on pin PTA0. If the received
bytes match those at locations $FFF6–$FFFD, the host bypasses the
security feature and can read all FLASH locations and execute code
from FLASH. Security remains bypassed until a power-on reset occurs.
If the reset was not a power-on reset, security remains bypassed and
security code entry is not required. (See Figure 10-8.)
Technical Data
178
Monitor ROM (MON)
MOTOROLA
Monitor ROM (MON)
Security
VDD
4096 + 32 ICLK CYCLES
RST
COMMAND
BYTE 8
BYTE 2
BYTE 1
256 BUS CYCLES (MINIMUM)
FROM HOST
PTA0
4
BREAK
2
1
COMMAND ECHO
NOTES:
1 = Echo delay, 2 bit times.
2 = Data return delay, 2 bit times.
1
BYTE 8 ECHO
BYTE 1 ECHO
FROM MCU
1
BYTE 2 ECHO
4
1
Figure 10-8. Monitor Mode Entry Timing
Upon power-on reset, if the received bytes of the security code do not
match the data at locations $FFF6–$FFFD, the host fails to bypass the
security feature. The MCU remains in monitor mode, but reading a
FLASH location returns an invalid value and trying to execute code from
FLASH causes an illegal address reset. After receiving the eight security
bytes from the host, the MCU transmits a break character, signifying that
it is ready to receive a command.
NOTE:
The MCU does not transmit a break character until after the host sends
the eight security bits.
To determine whether the security code entered is correct, check to see
if bit 6 of RAM address $40 is set. If it is, then the correct security code
has been entered and FLASH can be accessed.
If the security sequence fails, the device should be reset by a power-on
reset and brought up in monitor mode to attempt another entry. After
failing the security sequence, the FLASH module can also be mass
erased by executing an erase routine that was downloaded into internal
RAM. The mass erase operation clears the security code locations so
that all eight security bytes become $FF (blank).
MOTOROLA
Monitor ROM (MON)
Technical Data
179
Monitor ROM (MON)
Technical Data
180
Monitor ROM (MON)
MOTOROLA
Section 11. Timer Interface Module (TIM)
11.1 Contents
11.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 182
11.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 182
11.4
Pin Name Conventions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 183
11.5 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 183
11.5.1 TIM Counter Prescaler . . . . . . . . . . . . . . . . . . . . . . . . . . . . 187
11.5.2 Input Capture . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 187
11.5.3 Output Compare. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 188
11.5.3.1
Unbuffered Output Compare . . . . . . . . . . . . . . . . . . . . . 188
11.5.3.2
Buffered Output Compare . . . . . . . . . . . . . . . . . . . . . . . 189
11.5.4 Pulse Width Modulation (PWM) . . . . . . . . . . . . . . . . . . . . . 189
11.5.4.1
Unbuffered PWM Signal Generation . . . . . . . . . . . . . . . 190
11.5.4.2
Buffered PWM Signal Generation . . . . . . . . . . . . . . . . . 191
11.5.4.3
PWM Initialization . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 192
11.6
Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 193
11.7 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .193
11.7.1 Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 194
11.7.2 Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 194
11.8
TIM During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . 194
11.9
I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 195
11.10 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 195
11.10.1 TIM Status and Control Register . . . . . . . . . . . . . . . . . . . . 196
11.10.2 TIM Counter Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 198
11.10.3 TIM Counter Modulo Registers . . . . . . . . . . . . . . . . . . . . . 199
11.10.4 TIM Channel Status and Control Registers . . . . . . . . . . . .200
11.10.5 TIM Channel Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . 203
MC68HC908SR12•MC68HC08SR12 — Rev. 4.0
MOTOROLA
Technical Data
181
11.2 Introduction
This section describes the timer interface (TIM) module. The TIM is a
two-channel timer that provides a timing reference with input capture,
output compare, and pulse-width-modulation functions. Figure 11-1 is a
block diagram of the TIM.
This particular MCU has two timer interface modules which are denoted
as TIM1 and TIM2.
11.3 Features
Features of the TIM include:
Two input capture/output compare channels:
– Rising-edge, falling-edge, or any-edge input capture trigger
– Set, clear, or toggle output compare action
Technical Data
182
Buffered and unbuffered pulse-width-modulation (PWM) signal
generation
Programmable TIM clock input with 7-frequency internal bus clock
prescaler selection
Free-running or modulo up-count operation
Toggle any channel pin on overflow
TIM counter stop and reset bits
MOTOROLA
11.4 Pin Name Conventions
The text that follows describes both timers, TIM1 and TIM2. The TIM
input/output (I/O) pin names are T[1,2]CH0 (timer channel 0) and
T[1,2]CH1 (timer channel 1), where “1” is used to indicate TIM1 and “2”
is used to indicate TIM2. The two TIMs share four I/O pins with four I/O
port pins. The full names of the TIM I/O pins are listed in
Table 11-1. The generic pin names appear in the text that follows.
Table 11-1. Pin Name Conventions
TIM Generic Pin Names:
Full TIM
Pin Names:
NOTE:
T[1,2]CH0
T[1,2]CH1
TIM1
PTA6/T1CH0
PTA7/T1CH1
TIM2
PTB4/T2CH0
PTB5/T2CH1
References to either timer 1 or timer 2 may be made in the following text
by omitting the timer number. For example, TCH0 may refer generically
to T1CH0 and T2CH0, and TCH1 may refer to T1CH1 and T2CH1.
Figure 11-1 shows the structure of the TIM. The central component of
the TIM is the 16-bit TIM counter that can operate as a free-running
counter or a modulo up-counter. The TIM counter provides the timing
reference for the input capture and output compare functions. The TIM
counter modulo registers, TMODH:TMODL, control the modulo value of
the TIM counter. Software can read the TIM counter value at any time
without affecting the counting sequence.
The two TIM channels (per timer) are programmable independently as
input capture or output compare channels.
MOTOROLA
Technical Data
183
PRESCALER SELECT
INTERNAL
BUS CLOCK
PRESCALER
TSTOP
PS2
TRST
PS1
PS0
16-BIT COUNTER
TOF
TOIE
INTERRUPT
LOGIC
16-BIT COMPARATOR
TMODH:TMODL
TOV0
ELS0B
CHANNEL 0
ELS0A
CH0MAX
16-BIT COMPARATOR
TCH0H:TCH0L
PORT
LOGIC
T[1,2]CH0
CH0F
INTERRUPT
LOGIC
16-BIT LATCH
MS0A
CH0IE
MS0B
INTERNAL BUS
TOV1
ELS1B
CHANNEL 1
ELS1A
CH1MAX
PORT
LOGIC
T[1,2]CH1
16-BIT COMPARATOR
TCH1H:TCH1L
CH1F
INTERRUPT
LOGIC
16-BIT LATCH
MS1A
CH1IE
Figure 11-1. TIM Block Diagram
Figure 11-2 summarizes the timer registers.
NOTE:
Technical Data
184
by omitting the timer number. For example, TSC may generically refer to
both T1SC and T2SC.
MOTOROLA
Addr.
Register Name
Bit 7
Read:
Timer 1 Status and Control
Write:
$0020
Register (T1SC)
Reset:
TOF
Read:
Timer 1 Counter Register
$0021
Write:
High (T1CNTH)
Reset:
Bit 15
14
13
Read:
$0022
Write:
Low (T1CNTL)
Reset:
Bit 7
Read:
Timer 1 Counter Modulo
$0023
Write:
Register High (T1MODH)
Reset:
$0024
Read:
Write:
Register Low (T1MODL)
Reset:
Read:
Timer 1 Channel 0 Status
$0025
and Control Register Write:
(T1SC0)
Reset:
$0026
$0027
Read:
Timer 1 Channel 0
Write:
Register High (T1CH0H)
Reset:
Read:
Timer 1 Channel 0
Write:
Register Low (T1CH0L)
Reset:
Read:
Timer 1 Channel 1 Status
$0028
(T1SC1)
Reset:
6
5
TOIE
TSTOP
2
1
Bit 0
PS2
PS1
PS0
11
10
9
Bit 8
5
4
3
2
1
Bit 0
Bit 15
14
13
12
11
10
9
Bit 8
1
1
1
1
1
1
1
1
Bit 7
6
5
4
3
2
1
Bit 0
1
1
1
1
1
1
1
1
CH0IE
MS0B
MS0A
ELS0B
ELS0A
TOV0
CH0MAX
Bit 15
14
13
12
11
10
9
Bit 8
2
1
Bit 0
3
TRST
CH0F
Indeterminate after reset
Bit 7
6
5
4
3
CH1F
CH1IE
MS1A
ELS1B
ELS1A
TOV1
CH1MAX
= Unimplemented
Figure 11-2. TIM I/O Register Summary (Sheet 1 of 3)
MOTOROLA
Technical Data
185
Addr.
Register Name
Bit 7
6
5
4
3
2
1
Bit 0
Bit 15
14
13
12
11
10
9
Bit 8
2
1
Bit 0
PS2
PS1
PS0
Read:
$0029
Timer 1 Channel 1
Write:
Register High (T1CH1H)
Reset:
Read:
$002A
$002B
Timer 1 Channel 1
Write:
Register Low (T1CH1L)
Reset:
Bit 7
Read:
TOF
Timer 2 Status and Control
Write:
Register (T2SC)
Reset:
6
5
4
3
TOIE
TSTOP
TRST
Bit 15
14
13
12
11
10
9
Bit 8
Bit 7
6
5
4
3
2
1
Bit 0
Bit 15
14
13
12
11
10
9
Bit 8
1
1
1
1
1
1
1
1
Timer 2 Counter Modulo
Write:
Register Low (T2MODL)
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
1
1
1
1
1
1
1
1
Read:
Timer 2 Channel 0 Status
$0030
(T2SC0)
Reset:
CH0F
CH0IE
MS0B
MS0A
ELS0B
ELS0A
TOV0
CH0MAX
Bit 15
14
13
12
11
10
9
Bit 8
Read:
$002C
Timer 2 Counter Register
Write:
High (T2CNTH)
Reset:
Read:
$002D
Write:
Low (T2CNTL)
Reset:
Read:
$002E
Write:
Register High (T2MODH)
Reset:
Read:
$002F
Read:
$0031
Timer 2 Channel 0
Write:
Register High (T2CH0H)
Reset:
= Unimplemented
Figure 11-2. TIM I/O Register Summary (Sheet 2 of 3)
Technical Data
186
MOTOROLA
Addr.
Register Name
Bit 7
6
5
4
3
2
1
Bit 0
Timer 2 Channel 0
Write:
Register Low (T2CH0L)
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
Read:
Timer 2 Channel 1 Status
$0033
(T2SC1)
Reset:
CH1F
Read:
$0032
CH1IE
MS1A
ELS1B
ELS1A
TOV1
CH1MAX
Bit 15
14
13
12
11
10
9
Bit 8
2
1
Bit 0
Read:
$0034
Timer 2 Channel 1
Write:
Register High (T2CH1H)
Reset:
Read:
$0035
Timer 2 Channel 1
Write:
Register Low (T2CH1L)
Reset:
Bit 7
6
5
4
3
= Unimplemented
Figure 11-2. TIM I/O Register Summary (Sheet 3 of 3)
The TIM clock source can be one of the seven prescaler outputs. The
prescaler generates seven clock rates from the internal bus clock. The
prescaler select bits, PS[2:0], in the TIM status and control register
select the TIM clock source.
With the input capture function, the TIM can capture the time at which an
external event occurs. When an active edge occurs on the pin of an input
capture channel, the TIM latches the contents of the TIM counter into the
TIM channel registers, TCHxH:TCHxL. The polarity of the active edge is
programmable. Input captures can generate TIM CPU interrupt
requests.
MOTOROLA
Technical Data
187
With the output compare function, the TIM can generate a periodic pulse
with a programmable polarity, duration, and frequency. When the
counter reaches the value in the registers of an output compare channel,
the TIM can set, clear, or toggle the channel pin. Output compares can
generate TIM CPU interrupt requests.
11.5.3.1 Unbuffered Output Compare
Any output compare channel can generate unbuffered output compare
pulses as described in 11.5.3 Output Compare. The pulses are
unbuffered because changing the output compare value requires writing
the new value over the old value currently in the TIM channel registers.
An unsynchronized write to the TIM channel registers to change an
output compare value could cause incorrect operation for up to two
counter overflow periods. For example, writing a new value before the
counter reaches the old value but after the counter reaches the new
value prevents any compare during that counter overflow period. Also,
using a TIM overflow interrupt routine to write a new, smaller output
compare value may cause the compare to be missed. The TIM may pass
the new value before it is written.
Use the following methods to synchronize unbuffered changes in the
output compare value on channel x:
Technical Data
188
When changing to a smaller value, enable channel x output
compare interrupts and write the new value in the output compare
interrupt routine. The output compare interrupt occurs at the end
of the current output compare pulse. The interrupt routine has until
the end of the counter overflow period to write the new value.
When changing to a larger output compare value, enable TIM
overflow interrupts and write the new value in the TIM overflow
interrupt routine. The TIM overflow interrupt occurs at the end of
the current counter overflow period. Writing a larger value in an
output compare interrupt routine (at the end of the current pulse)
could cause two output compares to occur in the same counter
overflow period.
MOTOROLA
11.5.3.2 Buffered Output Compare
Channels 0 and 1 can be linked to form a buffered output compare
channel whose output appears on the TCH0 pin. The TIM channel
registers of the linked pair alternately control the output.
Setting the MS0B bit in TIM channel 0 status and control register (TSC0)
links channel 0 and channel 1. The output compare value in the TIM
channel 0 registers initially controls the output on the TCH0 pin. Writing
to the TIM channel 1 registers enables the TIM channel 1 registers to
synchronously control the output after the TIM overflows. At each
subsequent overflow, the TIM channel registers (0 or 1) that control the
output are the ones written to last. TSC0 controls and monitors the
buffered output compare function, and TIM channel 1 status and control
register (TSC1) is unused. While the MS0B bit is set, the channel 1 pin,
TCH1, is available as a general-purpose I/O pin.
NOTE:
In buffered output compare operation, do not write new output compare
values to the currently active channel registers. User software should
track the currently active channel to prevent writing a new value to the
active channel. Writing to the active channel registers is the same as
generating unbuffered output compares.
By using the toggle-on-overflow feature with an output compare channel,
the TIM can generate a PWM signal. The value in the TIM counter
modulo registers determines the period of the PWM signal. The channel
pin toggles when the counter reaches the value in the TIM counter
modulo registers. The time between overflows is the period of the PWM
signal.
As Figure 11-3 shows, the output compare value in the TIM channel
registers determines the pulse width of the PWM signal. The time
between overflow and output compare is the pulse width. Program the
TIM to clear the channel pin on output compare if the state of the PWM
pulse is logic 1. Program the TIM to set the pin if the state of the PWM
pulse is logic 0.
MOTOROLA
Technical Data
189
The value in the TIM counter modulo registers and the selected
prescaler output determines the frequency of the PWM output. The
frequency of an 8-bit PWM signal is variable in 256 increments. Writing
$00FF (255) to the TIM counter modulo registers produces a PWM
period of 256 times the internal bus clock period if the prescaler select
value is $000. See 11.10.1 TIM Status and Control Register.
OVERFLOW
OVERFLOW
OVERFLOW
PERIOD
PULSE
WIDTH
TCHx
OUTPUT
COMPARE
OUTPUT
COMPARE
OUTPUT
COMPARE
Figure 11-3. PWM Period and Pulse Width
The value in the TIM channel registers determines the pulse width of the
PWM output. The pulse width of an 8-bit PWM signal is variable in 256
increments. Writing $0080 (128) to the TIM channel registers produces
a duty cycle of 128/256 or 50%.
11.5.4.1 Unbuffered PWM Signal Generation
Any output compare channel can generate unbuffered PWM pulses as
described in 11.5.4 Pulse Width Modulation (PWM). The pulses are
unbuffered because changing the pulse width requires writing the new
pulse width value over the old value currently in the TIM channel
registers.
An unsynchronized write to the TIM channel registers to change a pulse
width value could cause incorrect operation for up to two PWM periods.
For example, writing a new value before the counter reaches the old
value but after the counter reaches the new value prevents any compare
during that PWM period. Also, using a TIM overflow interrupt routine to
write a new, smaller pulse width value may cause the compare to be
missed. The TIM may pass the new value before it is written.
Technical Data
190
MOTOROLA
PWM pulse width on channel x:
NOTE:
When changing to a shorter pulse width, enable channel x output
of the current pulse. The interrupt routine has until the end of the
PWM period to write the new value.
When changing to a longer pulse width, enable TIM overflow
interrupts and write the new value in the TIM overflow interrupt
routine. The TIM overflow interrupt occurs at the end of the current
PWM period. Writing a larger value in an output compare interrupt
routine (at the end of the current pulse) could cause two output
compares to occur in the same PWM period.
In PWM signal generation, do not program the PWM channel to toggle
on output compare. Toggling on output compare prevents reliable 0%
duty cycle generation and removes the ability of the channel to selfcorrect in the event of software error or noise. Toggling on output
compare also can cause incorrect PWM signal generation when
changing the PWM pulse width to a new, much larger value.
11.5.4.2 Buffered PWM Signal Generation
Channels 0 and 1 can be linked to form a buffered PWM channel whose
output appears on the TCH0 pin. The TIM channel registers of the linked
pair alternately control the pulse width of the output.
links channel 0 and channel 1. The TIM channel 0 registers initially
control the pulse width on the TCH0 pin. Writing to the TIM channel 1
registers enables the TIM channel 1 registers to synchronously control
the pulse width at the beginning of the next PWM period. At each
pulse width are the ones written to last. TSC0 controls and monitors the
buffered PWM function, and TIM channel 1 status and control register
(TSC1) is unused. While the MS0B bit is set, the channel 1 pin, TCH1,
MOTOROLA
Technical Data
191
NOTE:
In buffered PWM signal generation, do not write new pulse width values
to the currently active channel registers. User software should track the
currently active channel to prevent writing a new value to the active
generating unbuffered PWM signals.
11.5.4.3 PWM Initialization
To ensure correct operation when generating unbuffered or buffered
PWM signals, use the following initialization procedure:
1. In the TIM status and control register (TSC):
a. Stop the TIM counter by setting the TIM stop bit, TSTOP.
b. Reset the TIM counter and prescaler by setting the TIM reset
bit, TRST.
2. In the TIM counter modulo registers (TMODH:TMODL), write the
value for the required PWM period.
3. In the TIM channel x registers (TCHxH:TCHxL), write the value for
the required pulse width.
4. In TIM channel x status and control register (TSCx):
a. Write 0:1 (for unbuffered output compare or PWM signals) or
1:0 (for buffered output compare or PWM signals) to the
mode select bits, MSxB:MSxA. (See Table 11-3.)
b. Write 1 to the toggle-on-overflow bit, TOVx.
c. Write 1:0 (to clear output on compare) or 1:1 (to set output on
compare) to the edge/level select bits, ELSxB:ELSxA. The
output action on compare must force the output to the
complement of the pulse width level. (See Table 11-3.)
NOTE:
compare can also cause incorrect PWM signal generation when
5. In the TIM status control register (TSC), clear the TIM stop bit,
TSTOP.
Technical Data
192
MOTOROLA
Interrupts
Setting MS0B links channels 0 and 1 and configures them for buffered
PWM operation. The TIM channel 0 registers (TCH0H:TCH0L) initially
control the buffered PWM output. TIM status control register 0 (TSCR0)
controls and monitors the PWM signal from the linked channels.
Clearing the toggle-on-overflow bit, TOVx, inhibits output toggles on TIM
overflows. Subsequent output compares try to force the output to a state
it is already in and have no effect. The result is a 0% duty cycle output.
Setting the channel x maximum duty cycle bit (CHxMAX) and setting the
TOVx bit generates a 100% duty cycle output. (See 11.10.4 TIM
Channel Status and Control Registers.)
11.6 Interrupts
The following TIM sources can generate interrupt requests:
TIM overflow flag (TOF) — The TOF bit is set when the TIM
counter reaches the modulo value programmed in the TIM counter
modulo registers. The TIM overflow interrupt enable bit, TOIE,
enables TIM overflow CPU interrupt requests. TOF and TOIE are
in the TIM status and control register.
TIM channel flags (CH1F:CH0F) — The CHxF bit is set when an
input capture or output compare occurs on channel x. Channel x
TIM CPU interrupt requests are controlled by the channel x
interrupt enable bit, CHxIE. Channel x TIM CPU interrupt requests
are enabled when CHxIE = 1. CHxF and CHxIE are in the TIM
channel x status and control register.
The WAIT and STOP instructions put the MCU in low powerconsumption standby modes.
MOTOROLA
Technical Data
193
11.7.1 Wait Mode
The TIM remains active after the execution of a WAIT instruction. In wait
mode, the TIM registers are not accessible by the CPU. Any enabled
CPU interrupt request from the TIM can bring the MCU out of wait mode.
If TIM functions are not required during wait mode, reduce power
consumption by stopping the TIM before executing the WAIT instruction.
11.7.2 Stop Mode
The TIM is inactive after the execution of a STOP instruction. The STOP
instruction does not affect register conditions or the state of the TIM
counter. TIM operation resumes when the MCU exits stop mode after an
external interrupt.
11.8 TIM During Break Interrupts
A break interrupt stops the TIM counter.
The system integration module (SIM) controls whether status bits in
other modules can be cleared during the break state. The BCFE bit in
the SIM break flag control register (SBFCR) enables software to clear
status bits during the break state. (See 9.8.3 SIM Break Flag Control
Register.)
To allow software to clear status bits during a break interrupt, write a
logic 1 to the BCFE bit. If a status bit is cleared during the break state, it
remains cleared when the MCU exits the break state.
To protect status bits during the break state, write a logic 0 to the BCFE
bit. With BCFE at logic 0 (its default state), software can read and write
I/O registers during the break state without affecting status bits. Some
status bits have a 2-step read/write clearing procedure. If software does
the first step on such a bit before the break, the bit cannot change during
the break state as long as BCFE is at logic 0. After the break, doing the
second step clears the status bit.
Technical Data
194
MOTOROLA
I/O Signals
11.9 I/O Signals
Port A and port B each shares two of its pins with the TIM. The four TIM
channel I/O pins are T1CH0, T1CH1, T2CH0, and T2CH1 as described
in 11.4 Pin Name Conventions.
Each channel I/O pin is programmable independently as an input
capture pin or an output compare pin. T1CH0 and T2CH0 can be
configured as buffered output compare or buffered PWM pins.
11.10 I/O Registers
NOTE:
both T1SC AND T2SC.
These I/O registers control and monitor operation of the TIM:
TIM counter registers (TCNTH:TCNTL)
TIM channel status and control registers (TSC0, TSC1)
TIM channel registers (TCH0H:TCH0L, TCH1H:TCH1L)
MOTOROLA
Technical Data
195
The TIM status and control register (TSC):
Enables TIM overflow interrupts
Flags TIM overflows
Stops the TIM counter
Resets the TIM counter
Prescales the TIM counter clock
Address: T1SC, $0020 and T2SC, $002B
Bit 7
Read:
6
5
TOIE
TSTOP
TOF
Write:
Reset:
3
1
Bit 0
PS2
PS1
PS0
TRST
= Unimplemented
Figure 11-4. TIM Status and Control Register (TSC)
TOF — TIM Overflow Flag Bit
This read/write flag is set when the TIM counter reaches the modulo
value programmed in the TIM counter modulo registers. Clear TOF by
reading the TIM status and control register when TOF is set and then
writing a logic 0 to TOF. If another TIM overflow occurs before the
clearing sequence is complete, then writing logic 0 to TOF has no
effect. Therefore, a TOF interrupt request cannot be lost due to
inadvertent clearing of TOF. Reset clears the TOF bit. Writing a logic
1 to TOF has no effect.
1 = TIM counter has reached modulo value
0 = TIM counter has not reached modulo value
TOIE — TIM Overflow Interrupt Enable Bit
This read/write bit enables TIM overflow interrupts when the TOF bit
becomes set. Reset clears the TOIE bit.
1 = TIM overflow interrupts enabled
0 = TIM overflow interrupts disabled
Technical Data
196
MOTOROLA
I/O Registers
TSTOP — TIM Stop Bit
This read/write bit stops the TIM counter. Counting resumes when
TSTOP is cleared. Reset sets the TSTOP bit, stopping the TIM
counter until software clears the TSTOP bit.
1 = TIM counter stopped
0 = TIM counter active
NOTE:
Do not set the TSTOP bit before entering wait mode if the TIM is required
to exit wait mode.
TRST — TIM Reset Bit
Setting this write-only bit resets the TIM counter and the TIM
prescaler. Setting TRST has no effect on any other registers.
Counting resumes from $0000. TRST is cleared automatically after
the TIM counter is reset and always reads as logic 0. Reset clears the
TRST bit.
1 = Prescaler and TIM counter cleared
0 = No effect
NOTE:
Setting the TSTOP and TRST bits simultaneously stops the TIM counter
at a value of $0000.
PS[2:0] — Prescaler Select Bits
These read/write bits select one of the seven prescaler outputs as the
input to the TIM counter as Table 11-2 shows. Reset clears the
PS[2:0] bits.
Table 11-2. Prescaler Selection
PS2
PS1
PS0
Internal bus clock ÷ 1
Internal bus clock ÷ 2
Internal bus clock ÷ 4
1
Internal bus clock ÷ 8
1
Internal bus clock ÷ 16
1
Internal bus clock ÷ 32
1
1
Internal bus clock ÷ 64
1
1
1
Not available
MOTOROLA
TIM Clock Source
Technical Data
197
The two read-only TIM counter registers contain the high and low bytes
of the value in the TIM counter. Reading the high byte (TCNTH) latches
the contents of the low byte (TCNTL) into a buffer. Subsequent reads of
TCNTH do not affect the latched TCNTL value until TCNTL is read.
Reset clears the TIM counter registers. Setting the TIM reset bit (TRST)
also clears the TIM counter registers.
NOTE:
If you read TCNTH during a break interrupt, be sure to unlatch TCNTL
by reading TCNTL before exiting the break interrupt. Otherwise, TCNTL
retains the value latched during the break.
Address: T1CNTH, $0021 and T2CNTH, $002C
Read:
Bit 7
6
5
4
3
2
1
Bit 0
Bit 15
14
13
12
11
10
9
Bit 8
Write:
Reset:
= Unimplemented
Figure 11-5. TIM Counter Registers High (TCNTH)
Address: T1CNTL, $0022 and T2CNTL, $002D
Read:
Bit 7
6
5
4
3
2
1
Bit 0
Bit 7
6
5
4
3
2
1
Bit 0
Write:
Reset:
= Unimplemented
Figure 11-6. TIM Counter Registers Low (TCNTL)
Technical Data
198
MOTOROLA
I/O Registers
The read/write TIM modulo registers contain the modulo value for the
TIM counter. When the TIM counter reaches the modulo value, the
overflow flag (TOF) becomes set, and the TIM counter resumes counting
from $0000 at the next timer clock. Writing to the high byte (TMODH)
inhibits the TOF bit and overflow interrupts until the low byte (TMODL) is
written. Reset sets the TIM counter modulo registers.
Address: T1MODH, $0023 and T2MODH, $002E
Bit 7
6
5
4
3
2
1
Bit 0
Bit 15
14
13
12
11
10
9
Bit 8
1
1
1
1
1
1
1
1
Read:
Write:
Reset:
Figure 11-7. TIM Counter Modulo Register High (TMODH)
Address: T1MODL, $0024 and T2MODL, $002F
Bit 7
6
5
4
3
2
1
Bit 0
Bit 7
6
5
4
3
2
1
Bit 0
1
1
1
1
1
1
1
1
Read:
Write:
Reset:
Figure 11-8. TIM Counter Modulo Register Low (TMODL)
NOTE:
Reset the TIM counter before writing to the TIM counter modulo registers.
MOTOROLA
Technical Data
199
Each of the TIM channel status and control registers:
Flags input captures and output compares
Enables input capture and output compare interrupts
Selects input capture, output compare, or PWM operation
Selects high, low, or toggling output on output compare
Selects rising edge, falling edge, or any edge as the active input
capture trigger
Selects output toggling on TIM overflow
Selects 0% and 100% PWM duty cycle
Selects buffered or unbuffered output compare/PWM operation
Address: T1SC0, $0025 and T2SC0, $0030
Bit 7
Read:
CH0F
Write:
Reset:
5
4
3
2
1
Bit 0
CH0IE
MS0B
MS0A
ELS0B
ELS0A
TOV0
CH0MAX
Figure 11-9. TIM Channel 0 Status and Control Register (TSC0)
Address: T1SC1, $0028 and T2SC1, $0033
Bit 7
Read:
6
CH1F
5
Reset:
2
1
Bit 0
MS1A
ELS1B
ELS1A
TOV1
CH1MAX
CH1IE
Write:
4
Figure 11-10. TIM Channel 1 Status and Control Register (TSC1)
Technical Data
200
MOTOROLA
I/O Registers
CHxF — Channel x Flag Bit
When channel x is an input capture channel, this read/write bit is set
when an active edge occurs on the channel x pin. When channel x is
an output compare channel, CHxF is set when the value in the TIM
counter registers matches the value in the TIM channel x registers.
When TIM CPU interrupt requests are enabled (CHxIE = 1), clear
CHxF by reading TIM channel x status and control register with CHxF
set and then writing a logic 0 to CHxF. If another interrupt request
occurs before the clearing sequence is complete, then writing logic 0
to CHxF has no effect. Therefore, an interrupt request cannot be lost
due to inadvertent clearing of CHxF.
Reset clears the CHxF bit. Writing a logic 1 to CHxF has no effect.
1 = Input capture or output compare on channel x
0 = No input capture or output compare on channel x
CHxIE — Channel x Interrupt Enable Bit
This read/write bit enables TIM CPU interrupt service requests on
channel x.
Reset clears the CHxIE bit.
1 = Channel x CPU interrupt requests enabled
0 = Channel x CPU interrupt requests disabled
MSxB — Mode Select Bit B
This read/write bit selects buffered output compare/PWM operation.
MSxB exists only in the TIM1 channel 0 and TIM2 channel 0 status
and control registers.
Setting MS0B disables the channel 1 status and control register and
reverts TCH1 to general-purpose I/O.
Reset clears the MSxB bit.
1 = Buffered output compare/PWM operation enabled
0 = Buffered output compare/PWM operation disabled
MSxA — Mode Select Bit A
When ELSxB:ELSxA ≠ 0:0, this read/write bit selects either input
capture operation or unbuffered output compare/PWM operation.
See Table 11-3.
1 = Unbuffered output compare/PWM operation
0 = Input capture operation
MOTOROLA
Technical Data
201
When ELSxB:ELSxA = 0:0, this read/write bit selects the initial output
level of the TCHx pin. See Table 11-3. Reset clears the MSxA bit.
1 = Initial output level low
0 = Initial output level high
NOTE:
Before changing a channel function by writing to the MSxB or MSxA bit,
set the TSTOP and TRST bits in the TIM status and control register
(TSC).
ELSxB and ELSxA — Edge/Level Select Bits
When channel x is an input capture channel, these read/write bits
control the active edge-sensing logic on channel x.
When channel x is an output compare channel, ELSxB and ELSxA
control the channel x output behavior when an output compare
occurs.
When ELSxB and ELSxA are both clear, channel x is not connected
to an I/O port, and pin TCHx is available as a general-purpose I/O pin.
Table 11-3 shows how ELSxB and ELSxA work. Reset clears the
ELSxB and ELSxA bits.
Table 11-3. Mode, Edge, and Level Selection
MSxB:MSxA
ELSxB:ELSxA
X0
00
Mode
Configuration
Pin under port control;
initial output level high
Output preset
Technical Data
202
X1
00
initial output level low
00
01
Capture on rising edge only
00
10
00
11
01
01
01
10
01
11
1X
01
1X
10
1X
11
Input capture
Capture on falling edge only
Capture on rising or
falling edge
Output
compare or
PWM
Buffered
output
compare or
buffered PWM
Toggle output on compare
Clear output on compare
Set output on compare
MOTOROLA
I/O Registers
NOTE:
Before enabling a TIM channel register for input capture operation, make
sure that the TCHx pin is stable for at least two bus clocks.
TOVx — Toggle On Overflow Bit
When channel x is an output compare channel, this read/write bit
controls the behavior of the channel x output when the TIM counter
overflows. When channel x is an input capture channel, TOVx has no
effect.
Reset clears the TOVx bit.
1 = Channel x pin toggles on TIM counter overflow
0 = Channel x pin does not toggle on TIM counter overflow
NOTE:
When TOVx is set, a TIM counter overflow takes precedence over a
channel x output compare if both occur at the same time.
CHxMAX — Channel x Maximum Duty Cycle Bit
When the TOVx bit is at logic 1, setting the CHxMAX bit forces the
duty cycle of buffered and unbuffered PWM signals to 100%. As
Figure 11-11 shows, the CHxMAX bit takes effect in the cycle after it
is set or cleared. The output stays at the 100% duty cycle level until
the cycle after CHxMAX is cleared.
OVERFLOW
OVERFLOW
OVERFLOW
OVERFLOW
OVERFLOW
PERIOD
TCHx
OUTPUT
COMPARE
OUTPUT
COMPARE
OUTPUT
COMPARE
OUTPUT
COMPARE
CHxMAX
Figure 11-11. CHxMAX Latency
These read/write registers contain the captured TIM counter value of the
input capture function or the output compare value of the output
compare function. The state of the TIM channel registers after reset is
unknown.
MOTOROLA
Technical Data
203
In input capture mode (MSxB:MSxA = 0:0), reading the high byte of the
TIM channel x registers (TCHxH) inhibits input captures until the low
byte (TCHxL) is read.
In output compare mode (MSxB:MSxA ≠ 0:0), writing to the high byte of
the TIM channel x registers (TCHxH) inhibits output compares until the
low byte (TCHxL) is written.
Address: T1CH0H, $0026 and T2CH0H, $0031
Bit 7
6
5
4
3
2
1
Bit 0
Bit 15
14
13
12
11
10
9
Bit 8
Read:
Write:
Reset:
Figure 11-12. TIM Channel 0 Register High (TCH0H)
Address: T1CH0L, $0027 and T2CH0L $0032
Bit 7
6
5
4
3
2
1
Bit 0
Bit 7
6
5
4
3
2
1
Bit 0
Read:
Write:
Reset:
Figure 11-13. TIM Channel 0 Register Low (TCH0L)
Address: T1CH1H, $0029 and T2CH1H, $0034
Bit 7
6
5
4
3
2
1
Bit 0
Bit 15
14
13
12
11
10
9
Bit 8
Read:
Write:
Reset:
Figure 11-14. TIM Channel 1 Register High (TCH1H)
Address: T1CH1L, $002A and T2CH1L, $0035
Bit 7
6
5
4
3
2
1
Bit 0
Bit 7
6
5
4
3
2
1
Bit 0
Read:
Write:
Reset:
Figure 11-15. TIM Channel 1 Register Low (TCH1L)
Technical Data
204
MOTOROLA
Section 12. Timebase Module (TBM)
12.1 Contents
12.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 205
12.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 205
12.4
Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 206
12.5
Timebase Register Description. . . . . . . . . . . . . . . . . . . . . . . . 207
12.6
Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 208
12.7 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .209
12.7.1 Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 209
12.7.2 Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 209
12.2 Introduction
This section describes the timebase module (TBM). The TBM will
generate periodic interrupts at user selectable rates using a counter
clocked by the selected OSCCLK clock from the oscillator module. This
TBM version uses 18 divider stages, eight of which are user selectable.
12.3 Features
Features of the TBM module include:
Software programmable 8s, 4s, 2s, 1s, 2ms, 1ms, 0.5ms, and
0.25ms periodic interrupt using 32.768-kHz OSCCLK clock
User selectable oscillator clock source enable during stop mode to
allow periodic wake-up from stop
MOTOROLA
Technical Data
205
12.4 Functional Description
This module can generate a periodic interrupt by dividing the oscillator
clock frequency, OSCCLK. The counter is initialized to all 0s when
TBON bit is cleared. The counter, shown in Figure 12-1, starts counting
when the TBON bit is set. When the counter overflows at the tap
selected by TBR2:TBR0, the TBIF bit gets set. If the TBIE bit is set, an
interrupt request is sent to the CPU. The TBIF flag is cleared by writing
a 1 to the TACK bit. The first time the TBIF flag is set after enabling the
timebase module, the interrupt is generated at approximately half of the
overflow period. Subsequent events occur at the exact period.
The reference clock OSCCLK is derived from the oscillator module, see
7.3.2 TBM Reference Clock Selection.
TBON
÷2
OSCCLK
÷2
÷2
From OSC module
(See Section 7. Oscillator (OSC).)
÷2
÷8
÷2
÷ 16
÷2
÷ 32
÷2
÷2
÷2
÷2
÷2
÷ 64
÷ 2048
÷2
÷2
÷ 32768
÷2
÷ 65536
÷2
÷ 131072
TACK
÷2
TBR0
÷2
TBR1
÷2
TBR2
TBMINT
÷ 262144
TBIF
000
TBIE
R
001
010
011
100
SEL
101
110
111
Figure 12-1. Timebase Block Diagram
Technical Data
206
MOTOROLA
12.5 Timebase Register Description
The timebase has one register, the TBCR, which is used to enable the
timebase interrupts and set the rate.
Address:
$0046
Bit 7
Read:
6
5
4
TBR2
TBR1
TBR0
TBIF
2
1
Bit 0
TBIE
TBON
R
Write:
Reset:
3
TACK
= Unimplemented
R
= Reserved
Figure 12-2. Timebase Control Register (TBCR)
TBIF — Timebase Interrupt Flag
This read-only flag bit is set when the timebase counter has rolled
over.
1 = Timebase interrupt pending
0 = Timebase interrupt not pending
TBR2–TBR0 — Timebase Rate Selection
These read/write bits are used to select the rate of timebase interrupts
as shown in Table 12-1.
Table 12-1. Timebase Rate Selection for OSCCLK = 32.768 kHz
Timebase Interrupt Rate
TBR2
TBR1
TBR0
Divider
ms
0.125
8000
131072
0.25
4000
0.5
2000
1
32768
1
1000
1
512
~2
1
32
1024
~1
1
1
2048
~0.5
1
1
1
8
4096
~0.24
MOTOROLA
Hz
Technical Data
207
NOTE:
Do not change TBR2–TBR0 bits while the timebase is enabled
(TBON = 1).
TACK — Timebase ACKnowledge
The TACK bit is a write-only bit and always reads as 0. Writing a logic
1 to this bit clears TBIF, the timebase interrupt flag bit. Writing a logic
0 to this bit has no effect.
1 = Clear timebase interrupt flag
0 = No effect
TBIE — Timebase Interrupt Enabled
This read/write bit enables the timebase interrupt when the TBIF bit
becomes set. Reset clears the TBIE bit.
1 = Timebase interrupt enabled
0 = Timebase interrupt disabled
TBON — Timebase Enabled
This read/write bit enables the timebase. Timebase may be turned off
to reduce power consumption when its function is not necessary. The
counter can be initialized by clearing and then setting this bit. Reset
clears the TBON bit.
1 = Timebase enabled
0 = Timebase disabled and the counter initialized to 0s
12.6 Interrupts
The timebase module can interrupt the CPU on a regular basis with a
rate defined by TBR2–TBR0. When the timebase counter chain rolls
over, the TBIF flag is set. If the TBIE bit is set, enabling the timebase
interrupt, the counter chain overflow will generate a CPU interrupt
request. The interrupt vector is defined in Table 2-1 . Vector
Addresses.
Interrupts must be acknowledged by writing a logic 1 to the TACK bit.
Technical Data
208
MOTOROLA
Low-Power Modes
12.7.1 Wait Mode
The timebase module remains active after execution of the WAIT
instruction. In wait mode, the timebase register is not accessible by the
CPU.
If the timebase functions are not required during wait mode, reduce the
power consumption by stopping the timebase before enabling the WAIT
instruction.
12.7.2 Stop Mode
The timebase module may remain active after execution of the STOP
instruction if the oscillator has been enabled to operate during stop mode
through the stop mode oscillator enable bit (STOP_ICLKEN,
STOP_RCLKEN, or STOP_XCLKEN) for the selected oscillator in the
CONFIG2 register. The timebase module can be used in this mode to
generate a periodic walk-up from stop mode.
If the oscillator has not been enabled to operate in stop mode, the
timebase module will not be active during STOP mode. In stop mode the
timebase register is not accessible by the CPU.
If the timebase functions are not required during stop mode, reduce the
power consumption by stopping the timebase before enabling the STOP
instruction.
MOTOROLA
Technical Data
209
Technical Data
210
MOTOROLA
Section 13. Pulse Width Modulator (PWM)
13.1 Contents
13.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 211
13.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 212
13.4
PWM Period and Resolution. . . . . . . . . . . . . . . . . . . . . . . . . . 214
13.5
PWM Automatic Phase Control . . . . . . . . . . . . . . . . . . . . . . . 215
13.6
Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .216
13.7
Wait Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 216
13.8
Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 216
13.9
I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 217
13.10 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 217
13.10.1 PWM Control Register (PWMCR) . . . . . . . . . . . . . . . . . . .217
13.10.2 PWM Clock Control Register (PWMCCR) . . . . . . . . . . . . . 218
13.10.3 PWM Data Registers (PWMDR0–PWMDR2) . . . . . . . . . . 219
13.10.4 PWM Phase Control Register . . . . . . . . . . . . . . . . . . . . . . 220
13.2 Introduction
This section describes the pulse width modulator (PWM) module. The
PWM module provides three 8-bit PWM output channels, with an
independent 8-bit counter for each channel. The PWM period is equal to
1
256 × --------------- seconds, where PCLK is the PWM counter clock.
P CLK
For a 32MHz PWM counter clock, the PWM period is 8µs (a PWM
frequency of 125kHz). The automatic phase control feature allows
phase delays between the channels.
Figure 13-2 shows the structure of the PWM module.
MOTOROLA
Technical Data
211
NOTE:
The CGM’s PLL must be running (enabled by setting PLLON bit in the
PLL control register) if the CGMVCLK is selected for the PWM module
input clock. (See Section 8. Clock Generator Module (CGM).)
13.3 Features
Features of the PWM include the following:
Addr.
$0051
$0052
Three independent PWM channels with independent counters
PWM input clock select
PWM input clock prescaler
Automatic phase control
Register Name
Bit 7
6
5
Read:
PWMEN2 PWMEN1 PWMEN0
Write:
(PWMCR)
Reset:
Read:
PWM Clock Control
PCLKSEL
Register Write:
(PWMCCR)
Reset:
3
2
1
Bit 0
PCH2
PCH1
PCH0
PCLK1
PCLK0
$0053
Read:
0PWMD7 0PWMD6 0PWMD5 0PWMD4 0PWMD3 0PWMD2 0PWMD1 0PWMD0
PWM Data Register 0
Write:
(PWMDR0)
Reset:
$0054
Read:
1PWMD7 1PWMD6 1PWMD5 1PWMD4 1PWMD3 1PWMD2 1PWMD1 1PWMD0
PWM Data Register 1
Write:
(PWMDR1)
Reset:
$0055
Read:
2PWMD7 2PWMD6 2PWMD5 2PWMD4 2PWMD3 2PWMD2 2PWMD1 2PWMD0
PWM Data Register 2
Write:
(PWMDR2)
Reset:
$0056
Read:
PWM Phase Control
Register Write:
(PWMPCR)
Reset:
PHEN
PHD6
PHD5
PHD4
PHD3
PHD2
PHD1
PHD0
= Unimplemented
Figure 13-1. PWM I/O Register Summary
Technical Data
212
MOTOROLA
Features
INTERNAL BUS
CHANNEL 0
÷2
÷2
PWMCLK
÷2
PWMCR
8-BIT PWM
DATA REGISTER
S
CGMVCLK
B
FROM CGM
MUX
PCLKSEL
PCLK0
PWMCCR
PCLK
8-BIT
DATA REGISTER
BUFFER
8-BIT COUNTER
WHEN PCLKSEL=0,
PWMCLK=CGMOUT.
IF CGMVCLK IS SELECTED,
CGM’S PLL MUST BE RUNNING.
8-BIT COUNTER
8-BIT COUNTER
TO
CHANNEL 1
TO
CHANNEL 2
ZERO
DETECTOR
COMPARATOR
CHANNEL 0 OUTPUT LOGIC
S
LATCH
PWM0
Q
A S
CHANNEL 1 OUTPUT LOGIC
A S
B1
S
PTC0/PWM0/CD
PIN
A IS SELECTED
WHEN S=0
TO/FROM
PTC0
LOGIC
B1
B1
A
R
TO/FROM
PTC1
LOGIC
CGMOUT
1
PCLK1
PWMR0
PWM1
A
PCH0
CDIF
CDOEN
PWMCR
FROM
ANALOG
MODULE
CONFIG2
CHANNEL 2 OUTPUT LOGIC
PTC1/PWM1
PIN
PWM2
TO/FROM
PTC2
LOGIC
B1
A S
PTC2/PWM2
PIN
A IS SELECTED
WHEN S=0
A IS SELECTED
WHEN S=0
PCH1
PCH2
PWMCR
PWMCR
Figure 13-2. PWM Block Diagram
MOTOROLA
Technical Data
213
13.4 PWM Period and Resolution
1
1
The PWM period is equal to 256 × --------------- , resolution is --------------- , where
P CLK
P CLK
PCLK is the PWM counter clock. The value in the PWM data register
(PWMDR) defines the period where the PWM output is high, the low
period is equal to 256 minus that value. Each PWM channel has its own
counter and I/O control bits so it can be turned on and off independently.
Figure 13-3 shows the PWM output waveforms for a channel with
different values in the PWM data register.
PWM PERIOD = 256 × T
PWMDR = 256
255 × T
T
PWMDR = 1
128 × T
PWMDR = 128
128 × T
255 × T
T
PWMDR = 255
NOTE: T =
1
PCLK
Figure 13-3. PWM Output Waveforms
Technical Data
214
MOTOROLA
13.5 PWM Automatic Phase Control
The automatic phase control function allows precise phase difference
between the PWM output signals.
Figure 13-4 shows the phase delays between the PWM output signals.
256 × T
256 × T
PWM2
256 × T
PHASE VALUE 1
PWM1
PHASE VALUE 2
256 × T
PWM0
Figure 13-4. PWM Automatic Phase Control
Use the following steps to generate phase difference on PWM channels:
1. Clear PWM enable bits, PWMEN[0:2], to logic 0.
2. Write delay value in PHD[0:6].
3. Set PWM automatic phase control enable bit, PHEN, to logic 1.
4. Set the PWM channel enable bits, PCH[0:2], to logic 1.
5. Set the PWM enable bits, PWMEN[0:2], to logic 1, to enable the
PWM counters.
When phase control is enabled, the PWM2 counter will start counting
immediately, but the PWM1 and PWM0 counters will be held at zero.
After the PWM2 counter reaches the phase value, PH[0:6], the PWM1
counter is released and starts counting. Finally, when the PMW1 counter
reaches the phase value, PH[0:6], PWM0 is released and starts
counting. It is possible to change the value of PH[0:6] after the PWM1
counter has started and before the start of the PWM0 counter. This way,
difference phases can be set between PWM2 and PWM1; PWM1 and
PWM0.
MOTOROLA
Technical Data
215
The PH[0:6] value is used once to determine the start-up time of the
different PWM counters. After that, all PWM counters become free
running counters and the phase between the counters will remain
unchanged. Changing the value of PH[0:6] after all PWM counters are
running has no effect. The counters must first be disabled by clearing the
PWM enable bits, PWMEN[0:2], to logic 0, before a new phase value is
effective.
Automatic phase control is only available with two (PWM2–PWM1) or
three (PWM2–PWM0) PWM channels.
13.6 Low-Power Modes
13.7 Wait Mode
The PWM module remains active after the execution of a WAIT
instruction. In wait mode, the PWM registers are not accessible by the
CPU.
If PWM functions are not required during wait mode, reduce power
consumption by disabling the PWM before executing the WAIT
instruction.
13.8 Stop Mode
The PWM is inactive after the execution of a STOP instruction. The
STOP instruction does not affect register conditions or the state of the
PWM counters and outputs. PWM operation resumes when the MCU
exits stop mode after an external interrupt.
Technical Data
216
MOTOROLA
I/O Signals
13.9 I/O Signals
The PWM module has three output pins shared with port C:
PTC0/PWM0/CD, PWM1/PTC1, and PTC2/PWM2. PTC0 is also shared
with current flow detect output, CD, of the analog module, see (see 18.5
Port C).
13.10 I/O Registers
These I/O registers control PWM operation:
PWM control register (PWMCR)
PWM clock control register (PWMCCR)
PWM phase control register (PWMPCR)
Three PWM data registers (PWMDR0–PWMDR2)
The PWM control register (PWMCR) enables/disables the independent
PWM counters and port pins used for the PWM channels.
Address:
$0051
Read:
PCH2
PCH1
PCH0
Write:
Reset:
= Unimplemented
Figure 13-5. PWM Control Register (PWMCR)
PWMEN2–PWMEN0 — PWM Enable Bits
Writing a 0 to the PWMENx bit clears the corresponding PWM counter
and force the PWM channel x output to 0. Reset clears these bits.
1 = PWM channel x enabled
0 = PWM channel x is disabled; PWM counter cleared to zero and
PWM channel x output forced to zero
MOTOROLA
Technical Data
217
PCH2–PCH0 — PWM Channel Enable Bits
Setting a bit will enable the corresponding port pin to be a PWM
output pin. When a bit is set, the DDR bit has no effect on the port
function.
1 = Port pin is enabled for PWM output
0 = Port pin is standard I/O pin
Exception for PTC0/PWM0/CD control:
Table 13-1. PTC0 Pin Configuration
Pin
CDOEN Bit
($001D)
PCH0 Bit
($0051)
Pin function
PTC0
PWM0
1
X
CD
PTC0/PWM0/CD
The PWM clock control register (PWMCCR) selects and defines the
clock to the PWM counter, PCLK.
Address:
$0052
Read:
PCLKSEL
PCLK1
PCLK0
Write:
Reset:
= Unimplemented
Figure 13-6. PWM Clock Control Register (PWMCCR)
PCLKSEL — PWM Input Clock Select Bit
This bit selects either the CGMOUT or CGMVCLK clock as the input
clock to the PWM counters. Reset clears this bit.
1 = Select CGMVCLK as PWM input clock
0 = Select CGMOUT (CPU bus clock) as PWM input clock
Technical Data
218
MOTOROLA
I/O Registers
PCLK1–PCLK0 — PWM Clock Prescaler Bits
These two bits select the divide ratio used to divide the PWM input
clock. Table 13-2 shows the available clock divisions.
Table 13-2. PWM Counter Clock Prescaler Selection
PCLK1
PCLK0
PWM Clock, PCLK
Source clock ÷ 1
Source clock ÷ 2
1
Source clock ÷ 4
1
1
Source clock ÷ 8
The three PWM data registers (PWMDR0–PWMDR2) defines the high
period for corresponding PWM channels.
Address:
$0053
Read:
Write:
Reset:
Figure 13-7. PWM Data Register 0 (PWMDR0)
Address:
$0054
Read:
Write:
Reset:
Figure 13-8. PWM Data Register 1 (PWMDR1)
Address:
$0055
Read:
Write:
Reset:
Figure 13-9. PWM Data Register 2 (PWMDR2)
MOTOROLA
Technical Data
219
The value of each PWM data register is continuously compared with the
content of a PWM counter to determine the state of each PWM channel
output pin.
A value of $00 loaded into these register results in a continuously low
output on the corresponding PWM output pin. A value of $80 results in a
50% duty cycle output and so on. The maximum value, $FF correspond
to an output which is a "1" for 255/256 of the PWM cycle.
A new value written to the PWM data register will not be effective until
the end of the current PWM period. Upon the end of the current PWM
period, the contain of the PWM data register is loaded into the PWM data
buffer, the value of the PWM data buffer controls the PWM output.
The PWM phase control register (PWMPCR) enables the automatic
phase control and sets the phase values between the PWM channels.
Address:
$0056
Read:
PHEN
PHD6
PHD5
PHD4
PHD3
PHD2
PHD1
PHD0
Write:
Reset:
Figure 13-10. PWM Phase Control Register (PWMPCR)
PHEN — PWM Automatic Phase Control Enable Bit
Setting this bit to 1 will enable the automatic phase control function.
1 = Automatic phase control enabled
0 = Automatic phase control disabled
PHD6–PHD0 — PWM Phase Value Bits
This 7-bit phase value is used to determined the start-up time of the
different PWM counters when PHEN bit is set. Reset clears these bits.
Technical Data
220
MOTOROLA
Technical Data — MC68HC908SR12•MC68HC08SR12
Section 14. Analog Module
14.1 Contents
14.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 221
14.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 222
14.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 223
14.4.1 On-Chip Temperature Sensor . . . . . . . . . . . . . . . . . . . . . . 223
14.4.2 Two-Stage Amplifier . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 224
14.4.3 Amplifier Response Time . . . . . . . . . . . . . . . . . . . . . . . . . . 224
14.4.4 Current Flow Detection Amplifier . . . . . . . . . . . . . . . . . . . . 225
14.4.5 Current Flow Detect Output . . . . . . . . . . . . . . . . . . . . . . . . 225
14.5
Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 225
14.6 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .225
14.6.1 Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 225
14.6.2 Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 225
14.7 Analog Module I/O Registers . . . . . . . . . . . . . . . . . . . . . . . . . 226
14.7.1 Analog Module Control Register (AMCR) . . . . . . . . . . . . . 226
14.7.2 Analog Module Gain Control Register (AMGCR) . . . . . . . .227
14.7.3 Analog Module Status and Control Register (AMSCR) . . . 228
14.2 Introduction
This section describes the analog module. The analog module is
designed to be use in conjunction with the analog-to-digital converter
module for monitoring temperature, charge and discharge currents in
smart battery applications.
NOTE:
The analog module uses clock signals from the CGM’s PLL, therefore
the PLL must be running — PLLON bit in the PLL control register must
be set. (See Section 8. Clock Generator Module (CGM).)
MOTOROLA
Technical Data
Analog Module
221
Analog Module
14.3 Features
The features of the analog module include the following:
Temperature sensor
Current flow detection amplifier
Two-stage amplifier
ATD1
BATT +
ADCICLK
OPIN2/
ATD1
CLOCK
DIVIDER
ANALOG MODULE
TO ADC
ATD0
FROM ADC
DO[2:0]
AMCDIV[1:0]
EXTERNAL
THERMISTOR
GAINA[3:0]
GAINB[3:0]
AMCLK
INTERNAL
TEMPERATURE
SENSOR
TSOUT
BATT –
BATT +
INTERNAL
REFERENCE
DOF
OPCH[1:0]
CGMVCLK
FROM CGM
IN3
IN2
ISENSE
OPIN1/
ATD0
OPOUT
2-STAGE
AMP
IN1
TO ADC
IN0
RSENSE
0.01Ω
BATT –
OPIFR
CGMXCLK
VSSAM
VDD
–9mV
VSSA
PTC0/
PWM0/
CD
OPIF
VDET
D
OPIF
ANALOG MODULE
INTERRUPT REQUEST
CDIF
TO IRQ
LOGIC
Q
R
CDIFR
CDIF
AMIEN
PTC0
LOGIC
CDOEN FROM CONFIG2
Figure 14-1. Analog Module Block Diagram
Technical Data
222
Analog Module
MOTOROLA
Analog Module
Addr.
$000E
$000F
Register Name
Read:
Register Write:
(AMCR)
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
PWR1
PWR0
OPCH1
OPCH0
AMIEN
DO2
DO1
DO0
GAINB2
GAINB1
GAINB0
GAINA3
GAINA2
GAINA1
GAINA0
OPIF
DOF
CDIF
Read:
Analog Module Gain
GAINB3
(AMGCR)
Reset:
Read:
AMCDIV1 AMCDIV0
$0010
(AMSCR)
Reset:
OPIFR
U
= Unimplemented
CDIFR
U
U = Unaffected
Figure 14-2. Analog Module I/O Register Summary
Figure 14-1 shows the block diagram of the analog module. The central
component of the analog module is the two-stage gain amplifier used for
amplifying the small signals on the analog input pins, OPIN1 and OPIN2.
These two signals feed into a multiplexer together with the signal from
the internal temperature sensor and a reference input. The selected
signal is then fed into the two-stage gain amplifier before going into the
analog-to-digital converter (ADC) as OPOUT. The OPIN1 and OPIN2
pins can also feed directly into the ADC as channels ATD0 and ATD1
respectively, without any amplification.
The on-chip temperature sensor is designed to measure temperatures
from –20°C to 70 °C. The output of the internal temperature sensor
TSOUT is amplified by the two-stage amplifier. The amplified
temperature sensor signal is routed to the analog-to-digital converter for
analog-to-digital conversion (see Figure 14-1).
MOTOROLA
Technical Data
Analog Module
223
Analog Module
The two-stage amplifier is used to amplify small input signals from the
on-chip temperature sensor or external voltage sources such as external
thermistor and current sensing resistor, for temperature and current
monitoring. The amplified signal, OPOUT, is fed to the ADC module for
analog-to-digital conversion. The gain of the two-stage amplifier is
defined by the GAINAx and GAINBx bits in the analog module gain
control register (AMGCR) (see Figure 14-1).
The two-stage amplifier requires the input signal to be stable for
sampling. This signal hold-time varies with gain setting for stage-1 of the
two-stage amplifier, and is determined by the formula:
10 + [(Gain of stage-1 amplifier – 1) × 2] AMCLK cycles
The AMCLK clock is the analog amplifier clock, which is divided from the
ADC clock, ADCICLK.
The time for the two-stage amplifier to amplify the input signal to the
desired output is dependent on the gain setting in both stages of the twostage amplifier. The amplifier response time is determined by the
formula:
70 + (8 × Gain of stage-1) + (6 × Gain of stage-2) AMCLK cycles
This amplifier response time should be added to the ADC conversion
time to obtain the total time for the small-signal conversion.
Therefore, conversion time for OPINx signals, with amplification is:
Amplifier response time + ADC conversion time
Technical Data
224
Analog Module
MOTOROLA
Analog Module
Interrupts
The current flow detection amplifier is used to detect charge and
discharge current flowing through an external sensing resistor, RSENSE.
The current flow detection flag CDIF is set when the voltage at OPIN1
exceeds –9mV (typical) (0.9 ampere when RSENSE = 0.01Ω). When set,
CDIF can generate an interrupt request to the CPU when the analog
module interrupt enable bit AMIEN is set (see Figure 14-1).
The current detect flag, CDIF, can be configured for direct control to
other external circuitry. When the CDOEN bit in CONFIG2 is set, the
status of CDIF is reflected on the PTC0/PWM0/CD pin. (See 5.5
Configuration Register 2 (CONFIG2) and 18.5 Port C.)
14.5 Interrupts
When the AMIEN bit is set, the analog module is capable of generating
CPU interrupt requests. The interrupt vector is defined in Table 2-1 .
Vector Addresses.
The STOP and WAIT instructions put the MCU in low powerconsumption standby modes.
14.6.1 Wait Mode
In wait mode the analog module if enabled, continues to operate and
may generate an interrupt to trigger the MCU out of wait mode.
14.6.2 Stop Mode
In stop mode, the temperature sensor and the two-stage amplifier are
disabled, but the current flow detection amplifier (when enabled)
continues to operate if the oscillator is enabled in stop mode. When
AMIEN is set, CDIF can be used to wake-up the MCU from the stop
mode.
MOTOROLA
Technical Data
Analog Module
225
Analog Module
Three registers control and monitor the operation of the analog module:
Analog module control register (AMCR) — $000E
Analog module gain control register (AMGCR) — $000F
Analog module status and control register (AMSCR) — $0010
The analog module control register (AMCR):
Powers on and off analog sub-modules
Selects the input signal to the two-stage amplifier
Enables analog module interrupt requests
Offset adjustment for calibration
Address:
$000E
Bit 7
6
5
4
3
2
1
Bit 0
PWR1
PWR0
OPCH1
OPCH0
AMIEN
DO2
DO1
DO0
Read:
Write:
Reset:
Figure 14-3. Analog Module Control Register (AMCR)
PWR1–PWR0 — Analog Module Power Control Bits
These read/write bits power on/off the different functions within the
analog module. Reset clears the PWR1 and PWR0 bits.
Table 14-1. Analog Module Power Control
PWR1
PWR0
Current Detect
Module
Temperature
Sensor
Two-Stage
Amplifier
Off
Off
Off
On
Off
Off
1
Off
Off
On
1
1
On
On
On
Technical Data
226
Analog Module
MOTOROLA
Analog Module
OPCH1–OPCH0 — Amplifier Channel Select Control Bits
These read/write bits select the input source to be amplified by the
two-stage amplifier. Reset clears the OPCH1 and OPCH0 bits.
Table 14-2. Amplifier Channel Select Control bits
OPCH1
OPCH0
Input Source
Comments
VSSAM
External negative reference
OPIN1/ATD0
External pin
1
OPIN2/ATD1
External pin
1
1
TSOUT (internal)
Internal temperature sensor
AMIEN — Analog Module Interrupt Enable
Setting this bit will enable the CDIF and OPIF flags to generate an
CPU interrupt requests. Reset clears the AMIEN bit.
1 = Analog module CPU interrupt requests enabled
0 = Analog module CPU interrupt requests disabled
DO[2:0] — DC Offset Control Bits
Set these bits to zero for optimum analog module performance.
The analog module gain control register (AMGCR) selects the two gains
for the two-stage amplifier.
Address:
$000F
Bit 7
6
5
4
3
2
1
Bit 0
GAINB3
GAINB2
GAINB1
GAINB0
GAINA3
GAINA2
GAINA1
GAINA0
Read:
Write:
Reset:
Figure 14-4. Analog Module Gain Control Register (AMGCR)
MOTOROLA
Technical Data
Analog Module
227
Analog Module
GAINB[3:0] — Analog Module 2nd-stage Gain Control Bits
These read/write bits define the 2nd-stage gain of the two-stage
amplifier. The overall gain of the amplifier equals the 1st-stage gain
multiplied by the 2nd-stage gain. Reset clears the GAINB[3:0] bits.
GAINA[3:0] — Analog Module 1st-stage Gain Control Bits
These read/write bits define the 1st-stage gain of the two-stage
multiplied by the 2nd-stage gain. Reset clears the GAINA[3:0] bits.
Table 14-3. Analog Module Gain Values
GAINx3
GAINx2
GAINx1
GAINx0
Amplifier Gain
2
1
4
6
1
1
1
8
1
1
10
1
1
1
12
1
1
1
1
14
1
1
1
1
1
1
1
16
The analog module status and control register (AMSCR):
Selects input clock divider value
Monitors and clears the amplifier ready interrupt flag
Monitors DC offset flag
Monitors and clears the current detect interrupt flag
Technical Data
228
Analog Module
MOTOROLA
Analog Module
Address:
$0010
Bit 7
6
Read:
5
4
3
2
1
Bit 0
OPIF
DOF
CDIF
AMCDIV1 AMCDIV0
Write:
Reset:
CDIFR
OPIFR
U
= Unimplemented
U
U = Unaffected
Figure 14-5. Analog Module Status and Control Register (AMSCR)
AMCDIV[1:0] — Analog Module Clock Divider Control Bits
These read/write bits select the analog module input clock divider
value. The ADC clock, ADICLK, is divided by this value to obtain the
AMCLK. Reset clears the AMCDIV[1:0] bits.
Table 14-4. Analog Module Clock Divider Select
AMCDIV1
AMCDIV0
Divider Value
4
1
1
1
16
Set AMCDIV1 and AMCDIV0 bits to zero for optimum analog module
performance.
OPIFR — Amplifier Ready Interrupt Flag Reset
Writing a logic 1 to this write-only bit clears the OPIF bit. OPIFR
always reads as a logic 0. Reset does not affect OPIFR.
1 = Clear OPIF bit
0 = No affect on OPIF bit
OPIF — Amplifier Ready Interrupt Flag
This read-only bit is set when the output of the two-stage amplifier is
ready. A CPU interrupt request will be generated if the AMIEN bit is
also set. Reset clears OPIF bit.
1 = Two-stage amplifier output is ready
0 = Two-stage amplifier output is not ready
MOTOROLA
Technical Data
Analog Module
229
Analog Module
DOF — DC Offset Flag
This is a reserved bit.
CDIFR — Current Detect Interrupt Flag Reset
Writing a logic 1 to this write-only bit clears the CDIF bit. CDIFR
always reads as a logic 0. Reset does not affect CDIFR.
1 = Clear CDIF bit
0 = No affect on CDIF bit
CDIF — Current Detect Interrupt Flag
This read-only bit is set when the voltage developed across the sense
resistor, RSENSE is equal to or greater than VDET (the current sense
amplifier comparator trip voltage, typically –9mV). CDIF generates an
CPU interrupt request if AMIEN bit is also set. The CDIF bit is cleared
by writing a logic 1 to the CDIFR bit. Reset clears CDIF bit.
1 = Current detect interrupt has occurred
0 = No current detect interrupt since CDIF last cleared
Technical Data
230
Analog Module
MOTOROLA
Section 15. Analog-to-Digital Converter (ADC)
15.1 Contents
15.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 232
15.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 232
15.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 234
15.4.1 ADC Port I/O Pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 234
15.4.2 Voltage Conversion . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 235
15.4.3 Conversion Time . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 236
15.4.4 Continuous Conversion . . . . . . . . . . . . . . . . . . . . . . . . . . . 237
15.4.5 Auto-scan Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 237
15.4.6 Result Justification . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 238
15.4.7 Data Register Interlocking . . . . . . . . . . . . . . . . . . . . . . . . . 239
15.4.8 Monotonicity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .239
15.5
Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 239
15.6 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .239
15.6.1 Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 239
15.6.2 Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 240
15.7 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 240
15.7.1 ADC Voltage In (VADIN) . . . . . . . . . . . . . . . . . . . . . . . . . . . 240
15.7.2 ADC Analog Power Pin (VDDA) . . . . . . . . . . . . . . . . . . . . . 240
15.7.3 ADC Analog Ground Pin (VSSA). . . . . . . . . . . . . . . . . . . . . 240
15.7.4 ADC Voltage Reference High Pin (VREFH). . . . . . . . . . . . . 241
15.7.5 ADC Voltage Reference Low Pin (VREFL) . . . . . . . . . . . . . 241
15.8 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 241
15.8.1 ADC Status and Control Register. . . . . . . . . . . . . . . . . . . . 242
15.8.2 ADC Clock Control Register. . . . . . . . . . . . . . . . . . . . . . . . 244
15.8.3 ADC Data Register 0 (ADRH0 and ADRL0). . . . . . . . . . . . 246
15.8.4 ADC Auto-Scan Mode Data Registers (ADRL1–ADRL3). . 248
15.8.5 ADC Auto-Scan Control Register (ADASCR). . . . . . . . . . . 248
MOTOROLA
Technical Data
231
15.2 Introduction
This section describes the analog-to-digital converter (ADC). The ADC
is a 14-channel 10-bit linear successive approximation ADC.
15.3 Features
Features of the ADC module include:
Fourteen channels with multiplexed input
High impedance buffered input
Linear successive approximation with monotonicity
10-bit resolution
Single or continuous conversion
Auto-scan conversion on four channels
Conversion complete flag or conversion complete interrupt
Selectable ADC clock
Conversion result justification
– 8-bit truncated mode
– Right justified mode
– Left justified mode
– Left justified sign mode
Technical Data
232
MC68HC908SR12•MC68HC08SR12 — Rev. 4.0
MOTOROLA
Features
Addr.
6
5
4
3
2
1
Bit 0
AIEN
ADCO
ADCH4
ADCH3
ADCH2
ADCH1
ADCH0
1
1
1
1
ADIV2
ADIV1
ADIV0
ADICLK
MODE1
MODE0
Read:
ADC Data Register High 0
$0059
Write:
(ADRH0)
Reset:
ADx
ADx
ADx
ADx
ADx
ADx
ADx
ADx
R
R
R
R
R
R
R
R
Read:
ADC Data Register Low 0
$005A
Write:
(ADRL0)
Reset:
ADx
ADx
ADx
ADx
ADx
ADx
ADx
ADx
R
R
R
R
R
R
R
R
Read:
ADC Data Register Low 1
$005B
Write:
(ADRL1)
Reset:
AD7
AD6
AD5
AD4
AD3
AD2
AD1
AD0
R
R
R
R
R
R
R
R
Read:
ADC Data Register Low 2
$005C
Write:
(ADRL3)
Reset:
AD7
AD6
AD5
AD4
AD3
AD2
AD1
AD0
R
R
R
R
R
R
R
R
Read:
ADC Data Register Low 3
$005D
Write:
(ADRL3)
Reset:
AD7
AD6
AD5
AD4
AD3
AD2
AD1
AD0
R
R
R
R
R
R
R
R
AUTO1
AUTO0
ASCAN
$0057
Register Name
Read:
Register Write:
(ADSCR)
Reset:
Read:
ADC Clock Control
Register Write:
(ADICLK)
Reset:
$0058
$005E
Bit 7
Read:
ADC Auto-scan Control
Register Write:
(ADASCR)
Reset:
COCO
= Unimplemented
R
R
= Reserved
Figure 15-1. ADC I/O Register Summary
MOTOROLA
Technical Data
233
The ADC provides thirteen pins for sampling external sources at pins
PTA0/ATD2–PTA5/ATD7, PTC3/ATD8–PTC7/ATD12, and
OPIN1–OPIN2; one internal source from the analog module. An analog
multiplexer allows the single ADC converter to select one of fourteen
ADC channels as ADC voltage in (VADIN). VADIN is converted by the
successive approximation register-based analog-to-digital converter.
When the conversion is completed, ADC places the result in the ADC
data register, high and low byte (ADRH0 and ADRL0), and sets a flag or
generates an interrupt.
An additional three ADC data registers (ADRL1–ADRL3) are available to
store the individual converted data for ADC channels ATD1–ATD3 when
the auto-scan mode is enabled. Data from channel ATD0 is stored in
ADRL0 in the auto-scan mode.
Figure 15-2 shows the structure of the ADC module.
PTA0–PTA5 and PTC3–PTC7 are general-purpose I/O pins that are
shared with the ADC channels, OPIN1 and OPIN2 are two analog inputs
that are always connected to the ADC channel select multiplexer. The
channel select bits, ADCH[4:0], define which ADC channel/port pin will
be used as the input signal. The ADC overrides the port I/O logic by
forcing that pin as input to the ADC. The remaining ADC channels/port
pins are controlled by the port I/O logic and can be used as generalpurpose I/O pins. Writes to the port data register or data direction
register will not have any affect on the port pin that is selected by the
ADC. Read of a port pin which is in use by the ADC will return the pin
condition if the corresponding DDR bit is at logic 0. If the DDR bit is at
logic 1, the value in the port data latch is read.
Technical Data
234
MOTOROLA
When the input voltage to the ADC equals VREFH, the ADC converts the
signal to $3FF (full scale). If the input voltage equals VREFL, the ADC
converts it to $000. Input voltages between VREFH and VREFL is a
straight-line linear conversion. All other input voltages will result in $3FF
if greater than VREFH and $000 if less than VREFL.
NOTE:
Input voltage should not exceed the analog supply voltages.
INTERNAL
DATA BUS
READ DDRAx/DDRCx
DISABLE
WRITE DDRAx/DDRCx
RESET
WRITE PTAx/PTCx
DDRAx/DDRCx
PTAx/PTCx
PTAx/PTCx
READ PTAx/PTCx
ATD2–ATD12
(11 CHANNELS)
ADC DATA REGISTERS
DISABLE
OPIN1
ADRH0 ADRL0
OPIN2
ADRL1
ADRL2
VREFH
ADRL3
INTERRUPT
LOGIC
AIEN
VREFL
ADC
VOLTAGE IN
(VADIN)
CONVERSION
COMPLETE
ADC
OPOUT
FROM
ANALOG MODULE
CHANNEL
SELECT
ADCICLK
COCO
MUX
CGMXCLK
BUS CLOCK
ASCAN
CLOCK
GENERATOR
ADCH[4:0]
ADIV[2:0]
ADICLK
2-BIT UP-COUNTER
AUTO[1:0]
Figure 15-2. ADC Block Diagram
MOTOROLA
Technical Data
235
Conversion starts after a write to the ADSCR. One conversion will take
between 16 and 17 ADC clock cycles, therefore:
Conversion time =
16 to17 ADC cycles
ADC frequency
Number of bus cycles = conversion time × bus frequency
The ADC conversion time is determined by the clock source chosen and
the divide ratio selected. The clock source is either the bus clock or
CGMXCLK and is selectable by the ADICLK bit located in the ADC clock
register. The divide ratio is selected by the ADIV[2:0] bits.
For example, if a 4MHz CGMXCLK is selected as the ADC input clock
source, with a divide-by-four prescale, and the bus speed is set at 2MHz:
Conversion time =
16 to17 ADC cycles
= 16 to 17 µs
4MHz ÷ 4
Number of bus cycles = 16 µs × 2MHz = 32 to 34 cycles
NOTE:
The ADC frequency must be between fADIC minimum and fADIC
maximum to meet ADC specifications. (See 24.12 5.0V ADC Electrical
Characteristics.)
Since an ADC cycle may comprised of several bus cycles (two in the
previous example) and the start of a conversion is initiated by a bus cycle
write to the ADSCR, from zero to two additional bus cycles may occur
before the start of the initial ADC cycle. This results in a fractional ADC
cycle and is represented as the 17th cycle.
NOTE:
Technical Data
236
When OPOUT is selected as the ADC input, VADIN, the conversion time
is the accumulation of the op-amp settling time and the normal ADC
conversion time. After writing to the ADSCR to initiate a conversion
cycle, the ADC module sends a signal to the analog module for a
OPOUT output. A signal will be sent back to the ADC by the analog
module to indicate that OPOUT signal is ready for sampling. Upon
receiving this signal, the ADC module starts its normal conversion cycle.
(See 24.12 5.0V ADC Electrical Characteristics.)
MOTOROLA
In the continuous conversion mode, the ADC continuously converts the
selected channel, filling the ADC data register with new data after each
conversion. Data from the previous conversion will be overwritten
whether that data has been read or not. Conversions will continue until
the ADCO bit is cleared. The COCO bit is set after each conversion and
can be cleared by writing to the ADC status and control register or
reading of the ADRL0 data register.
In auto-scan mode, the ADC input channel is selected by the value of the
2-bit up-counter, instead of the channel select bits, ADCH[4:0]. The
value of the counter also defines the data register ADRLx to be used to
store the conversion result. When ASCAN bit is set, a write to ADC
status and control register (ADSCR) will reset the auto-scan up-counter
and ADC conversion will start on the channel 0 up to the channel number
defined by the integer value of AUTO[1:0]. After a channel conversion is
completed, data is stored in ADRLx and the COCO-bit will be set. The
counter value will be incremented by 1 and a new conversion will start.
This process will continue until the counter value reaches the value of
AUTO[1:0]. When this happens, it indicates that the current channel is
the last channel to be converted. Upon the completion on the last
channel, the counter value will not be incremented and no further
conversion will be performed. To start another auto-scan cycle, a write
to ADSCR must be performed.
NOTE:
The system only provides 8-bit data storage in auto-scan code, user
must clear MODE[1:0] bits to select 8-bit truncation mode before
entering auto-scan mode.
It is recommended that user should disable the auto-scan function
before switching channel and also before entering STOP mode!
MOTOROLA
Technical Data
237
The conversion result may be formatted in four different ways.
Left justified
Right justified
Left justified sign data mode
8-bit truncation
All four of these modes are controlled using MODE0 and MODE1 bits
located in the ADC clock control register (ADICLK).
Left justification will place the eight most significant bits (MSB) in the
corresponding ADC data register high (ADRH). This may be useful if the
result is to be treated as an 8-bit result where the least significant two
bits, located in the ADC data register low (ADRL) can be ignored.
However, you must read ADRL after ADRH or else the interlocking will
prevent all new conversions from being stored.
Right justification will place only the two MSBs in the corresponding ADC
data register high (ADRH) and the eight LSB bits in ADC data register
low (ADRL). This mode of operation typically is used when a 10-bit
unsigned result is desired.
Left justified sign data mode is similar to left justified mode with one
exception. The MSB of the 10-bit result, AD9 located in ADRH is
complemented. This mode of operation is useful when a result,
represented as a signed magnitude from mid-scale, is needed.
Finally, 8-bit truncation mode will place the eight MSBs in ADC data
register low (ADRL). The two LSBs are dropped. This mode of operation
is used when compatibility with 8-bit ADC designs are required. No
interlocking between ADRH and ADRL is present.
Technical Data
238
MOTOROLA
Interrupts
Reading ADRH in any 10-bit mode latches the contents of ADRL until
ADRL is read. Until ADRL is read all subsequent ADC results will be lost.
This register interlocking can also be reset by a write to the ADC status
and control register, or ADC clock control register. A power-on reset or
reset will also clear the interlocking. Note that an external conversion
request will not reset the lock.
15.4.8 Monotonicity
The conversion process is monotonic and has no missing codes.
15.5 Interrupts
When the AIEN bit is set, the ADC module is capable of generating a
CPU interrupt after each ADC conversion or after an auto-scan
conversion cycle. A CPU interrupt is generated if the COCO bit is at
logic 0. The COCO bit is not used as a conversion complete flag when
interrupts are enabled. The interrupt vector is defined in Table 2-1 .
Vector Addresses.
15.6.1 Wait Mode
The ADC continues normal operation in wait mode. Any enabled CPU
interrupt request from the ADC can bring the MCU out of wait mode. If
the ADC is not required to bring the MCU out of wait mode, power down
the ADC by setting the ADCH[4:0] bits to logic 1’s before executing the
WAIT instruction.
MOTOROLA
Technical Data
239
15.6.2 Stop Mode
The ADC module is inactive after the execution of a STOP instruction.
Any pending conversion is aborted. ADC conversions resume when the
MCU exits stop mode. Allow one conversion cycle to stabilize the analog
circuitry before attempting a new ADC conversion after exiting stop
mode.
15.7 I/O Signals
The ADC module has fourteen channels, eleven channels are shared
with port A and port C I/O pins; two channels are analog pins, OPIN1 and
OPIN2, that are shared with the analog module; and one channel,
OPOUT, from the analog module.
VADIN is the input voltage signal from one of the fourteen channels to the
ADC module.
The ADC analog portion uses VDDA as its power pin. Connect the VDDA
pin to the same voltage potential as VDD. External filtering may be
necessary to ensure clean VDDA for good results.
NOTE:
Route VDDA carefully for maximum noise immunity and place bypass
capacitors as close as possible to the package.
The ADC analog portion uses VSSA as its ground pin. Connect the VSSA
pin to the same voltage potential as VSS.
Technical Data
240
MOTOROLA
I/O Registers
VREFH is the power supply for setting the reference voltage VREFH.
Connect the VREFH pin to the same voltage potential as VDDA. There will
be a finite current associated with VREFH (see Section 24. Electrical
Specifications).
NOTE:
Route VREFH carefully for maximum noise immunity and place bypass
VREFL is the lower reference supply for the ADC. Connect the VREFL pin
to the same voltage potential as VSSA. There will be a finite current
associated with VREFL (see Section 24. Electrical Specifications).
15.8 I/O Registers
These I/O registers control and monitor ADC operation:
ADC status and control register (ADSCR) — $0057
ADC clock control register (ADICLK) — $0058
ADC data register high 0 (ADRH0) — $0059
ADC data register low 0 (ADRL0) — $005A
ADC data register low 1 (ADRL1) — $005B
ADC data register low 2 (ADRL2) — $005C
ADC data register low 3 (ADRL3) — $005D
ADC auto-scan control register (ADASCR) — $005E
MOTOROLA
Technical Data
241
Function of the ADC status and control register is described here.
Address:
$0057
Read:
COCO
AIEN
ADCO
ADCH4
ADCH3
ADCH2
ADCH1
ADCH0
1
1
1
1
Write:
Reset:
= Unimplemented
Figure 15-3. ADC Status and Control Register (ADSCR)
COCO — Conversions Complete Bit
When the AIEN bit is a logic 0, the COCO is a read-only bit which is
set each time a conversion is completed. This bit is cleared whenever
the ADSCR is written, or whenever the ADC clock control register is
written, or whenever the ADC data register low, ADRLx, is read.
If the AIEN bit is logic 1, the COCO bit always read as logic 0. ADC
interrupt will be generated at the end if an ADC conversion. Reset
clears the COCO bit.
1 = Conversion completed (AIEN = 0)
0 = Conversion not completed (AIEN = 0)/CPU interrupt (AIEN=1)
AIEN — ADC Interrupt Enable Bit
When this bit is set, an interrupt is generated at the end of an ADC
conversion. The interrupt signal is cleared when the data register,
ADR0, is read or the ADSCR is written. Reset clears the AIEN bit.
1 = ADC interrupt enabled
0 = ADC interrupt disabled
ADCO — ADC Continuous Conversion Bit
When set, the ADC will convert samples continuously and update the
ADC data register at the end of each conversion. Only one conversion
is allowed when this bit is cleared. Reset clears the ADCO bit.
1 = Continuous ADC conversion
0 = One ADC conversion
This bit should not be set when auto-scan mode is enabled; i.e. when
ASCAN=1.
Technical Data
242
MOTOROLA
I/O Registers
ADCH[4:0] — ADC Channel Select Bits
ADCH[4:0] form a 5-bit field which is used to select one of the ADC
channels when not in auto-scan mode. The five channel select bits
are detailed in Table 15-1.
NOTE:
Care should be taken when using a port pin as both an analog and a
digital input simultaneously to prevent switching noise from corrupting
the analog signal.
NOTE:
Recovery from the disabled state requires one conversion cycle to
stabilize.
Table 15-1. MUX Channel Select
ADCH4
ADCH3
ADCH2
ADCH1
ADCH0
ADC Channel
Input Select
ATD0
OPIN1
ATD1
OPIN2
ATD2
PTA0
1
ATD3
PTA1
ATD4
PTA2
ATD5
PTA3
1
ATD6
PTA4
1
1
ATD7
PTA5
ATD8
PTC3
ATD9
PTC4
ATD10
PTC5
1
ATD11
PTC6
1
ATD12
PTC7
1
ATD13
OPOUT
Reserved
1
1
1
ATD14
ATD28
1
1
1
ATD29
VREFH (see Note 2)
1
1
1
1
ATD30
VREFL (see Note 2)
1
1
1
1
1
ADC powered-off
NOTES:
1. If any unused channels are selected, the resulting ADC conversion will be unknown.
2. The voltage levels supplied from internal reference nodes as specified in the table are used to verify the operation of
the ADC converter both in production test and for user applications.
MOTOROLA
Technical Data
243
The ADC clock control register (ADICLK) selects the clock frequency for
the ADC.
Address:
$0058
Read:
ADIV2
ADIV1
ADIV0
ADICLK
MODE1
MODE0
Write:
Reset:
R
= Unimplemented
R
1
= Reserved
Figure 15-4. ADC Clock Control Register (ADICLK)
ADIV[2:0] — ADC Clock Prescaler Bits
ADIV2, ADIV1, and ADIV0 form a 3-bit field which selects the divide
ratio used by the ADC to generate the internal ADC clock.
Table 15-2 shows the available clock configurations. The ADC clock
should be set to between 500kHz and 2MHz.
Table 15-2. ADC Clock Divide Ratio
ADIV2
ADIV1
ADIV0
ADC Clock Rate
ADC input clock ÷ 1
ADC input clock ÷ 2
ADC input clock ÷ 4
1
ADC input clock ÷ 8
1
X
X
ADC input clock ÷ 16
X = don’t care
ADICLK — ADC Input Clock Select Bit
ADICLK selects either bus clock or CGMXCLK as the input clock
source to generate the internal ADC clock. Reset selects CGMXCLK
as the ADC clock source.
Technical Data
244
MOTOROLA
I/O Registers
If the external clock (CGMXCLK) is equal to or greater than 1MHz,
CGMXCLK can be used as the clock source for the ADC. If
CGMXCLK is less than 1MHz, use the PLL-generated bus clock as
the clock source. As long as the internal ADC clock is at fADIC, correct
operation can be guaranteed.
1 = Internal bus clock
0 = External clock, CGMXCLK
fADIC =
CGMXCLK or bus frequency
ADIV[2:0]
MODE1 and MODE0 — Modes of Result Justification
MODE1 and MODE0 selects between four modes of operation. The
manner in which the ADC conversion results will be placed in the ADC
data registers is controlled by these modes of operation. Reset
returns right-justified mode.
Table 15-3. ADC Mode Select
MODE1
MODE0
ADC Clock Rate
1
Left justified mode
1
1
MOTOROLA
Technical Data
245
The ADC data register 0 consist of a pair of 8-bit registers: high byte
(ADRH0), and low byte (ADRL0). This pair form a 16-bit register to store
the 10-bit ADC result for the selected ADC result justification mode.
In 8-bit truncated mode, the ADRL0 holds the eight most significant bits
(MSBs) of the 10-bit result. The ADRL0 is updated each time an ADC
conversion completes. In 8-bit truncated mode, ADRL0 contains no
interlocking with ADRH0. (See Figure 15-5 . ADRH0 and ADRL0 in 8Bit Truncated Mode.)
Addr.
Register Name
Bit 7
6
5
4
3
2
1
Bit 0
Read:
$0059
Write:
(ADRH0)
Reset:
R
R
R
R
R
R
R
R
AD9
AD8
AD7
AD6
AD5
AD4
AD3
AD2
R
R
R
R
R
R
R
R
Read:
$005A
Write:
(ADRL0)
Reset:
Figure 15-5. ADRH0 and ADRL0 in 8-Bit Truncated Mode
In right justified mode the ADRH0 holds the two MSBs, and the ADRL0
holds the eight least significant bits (LSBs), of the 10-bit result. ADRH0
and ADRL0 are updated each time a single channel ADC conversion
completes. Reading ADRH0 latches the contents of ADRL0. Until
ADRL0 is read all subsequent ADC results will be lost.
(See Figure 15-6 . ADRH0 and ADRL0 in Right Justified Mode.)
Addr.
Register Name
Bit 7
6
5
4
3
2
1
Bit 0
Read:
$0059
Write:
(ADRH0)
Reset:
AD9
AD8
R
R
R
R
R
R
R
R
AD7
AD6
AD5
AD4
AD3
AD2
AD1
AD0
R
R
R
R
R
R
R
R
Read:
$005A
Write:
(ADRL0)
Reset:
Figure 15-6. ADRH0 and ADRL0 in Right Justified Mode
Technical Data
246
MOTOROLA
I/O Registers
In left justified mode the ADRH0 holds the eight most significant bits
(MSBs), and the ADRL0 holds the two least significant bits (LSBs), of the
10-bit result. The ADRH0 and ADRL0 are updated each time a single
channel ADC conversion completes. Reading ADRH0 latches the
contents of ADRL0. Until ADRL0 is read all subsequent ADC results will
be lost. (See Figure 15-7 . ADRH0 and ADRL0 in Left Justified Mode.)
Addr.
Register Name
Bit 7
6
5
4
3
2
1
Bit 0
Read:
$0059
Write:
(ADRH0)
Reset:
AD9
AD8
AD7
AD6
AD5
AD4
AD3
AD2
R
R
R
R
R
R
R
R
Read:
$005A
Write:
(ADRL0)
Reset:
AD1
AD0
R
R
R
R
R
R
R
R
Figure 15-7. ADRH0 and ADRL0 in Left Justified Mode
In left justified sign mode the ADRH0 holds the eight MSBs with the MSB
complemented, and the ADRL0 holds the two least significant bits
(LSBs), of the 10-bit result. The ADRH0 and ADRL0 are updated each
time a single channel ADC conversion completes. Reading ADRH0
latches the contents of ADRL0. Until ADRL0 is read all subsequent ADC
results will be lost. (See Figure 15-8 . ADRH0 and ADRL0 in Left
Justified Sign Data Mode.)
Addr.
Register Name
Bit 7
6
5
4
3
2
1
Bit 0
Read:
$0059
Write:
(ADRH0)
Reset:
AD9
AD8
AD7
AD6
AD5
AD4
AD3
AD2
R
R
R
R
R
R
R
R
Read:
$005A
Write:
(ADRL0)
Reset:
AD1
AD0
R
R
R
R
R
R
R
R
Figure 15-8. ADRH0 and ADRL0 in Left Justified Sign Data Mode
MOTOROLA
Technical Data
247
The ADC data registers 1 to 3 (ADRL1–ADRL3), are 8-bit registers for
conversion results in 8-bit truncated mode, for channels ATD1 to ATD3,
when the ADC is operating in auto-scan mode (MODE[1:0] = 00).
Address: ADRL1, $005B; ADRL2, $005C; and ADRL3, $005D
Read:
AD7
AD6
AD5
AD4
AD3
AD2
AD1
AD0
Write:
R
R
R
R
R
R
R
R
Reset:
R
= Reserved
Figure 15-9. ADC Data Register Low 1 to 3 (ADRL1–ADRL3)
The ADC auto-scan control register (ADASCR) enables and controls the
ADC auto-scan function.
Address:
Read:
$005E
AUTO1
AUTO0
ASCAN
Write:
Reset:
= Unimplemented
R
= Reserved
Figure 15-10. ADC Scan Control Register (ADASCR)
AUTO[1:0] — Auto-scan Mode Channel Select Bits
AUTO1 and AUTO0 form a 2-bit field which is used to define the
number of auto-scan channels used when in auto-scan mode.
Table 15-4. Auto-scan Mode Channel Select
Technical Data
248
AUTO1
AUTO0
ADC Clock Rate
ATD0 only
ATD0 to ATD1
1
ATD0 to ATD2
1
1
ATD0 to ATD3
MOTOROLA
I/O Registers
ASCAN — Auto-scan Mode Enable Bit
This bit enable/disable the Auto-scan mode. Reset clears this bit.
1 = Auto-scan mode is enabled
0 = Auto-scan mode is disabled
Auto-scan mode should not be enabled when ADC continuous
conversion is enabled; i.e. when ADCO=1.
MOTOROLA
Technical Data
249
Technical Data
250
MOTOROLA
Section 16. Serial Communications Interface (SCI)
16.1 Contents
16.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 252
16.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 252
16.4
Pin Name Conventions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 254
16.5 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 254
16.5.1 Data Format . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .257
16.5.2 Transmitter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 257
16.5.2.1
Character Length . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 259
16.5.2.2
Character Transmission . . . . . . . . . . . . . . . . . . . . . . . . . 259
16.5.2.3
Break Characters . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 260
16.5.2.4
Idle Characters. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 260
16.5.2.5
Inversion of Transmitted Output. . . . . . . . . . . . . . . . . . . 261
16.5.2.6
Transmitter Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . 261
16.5.3 Receiver . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 262
16.5.3.1
Character Length . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 262
16.5.3.2
Character Reception . . . . . . . . . . . . . . . . . . . . . . . . . . . 262
16.5.3.3
Data Sampling . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 264
16.5.3.4
Framing Errors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 266
16.5.3.5
Baud Rate Tolerance . . . . . . . . . . . . . . . . . . . . . . . . . . . 266
16.5.3.6
Receiver Wakeup. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 269
16.5.3.7
Receiver Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . .270
16.5.3.8
Error Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 270
16.6 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .271
16.6.1 Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 271
16.6.2 Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 271
16.7
SCI During Break Module Interrupts. . . . . . . . . . . . . . . . . . . . 272
16.8 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 272
16.8.1 TxD (Transmit Data). . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 272
MOTOROLA
Technical Data
251
16.8.2
RxD (Receive Data) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 273
16.9 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 273
16.9.1 SCI Control Register 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . 273
16.9.2 SCI Control Register 2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . 276
16.9.3 SCI Control Register 3 . . . . . . . . . . . . . . . . . . . . . . . . . . . 279
16.9.4 SCI Status Register 1. . . . . . . . . . . . . . . . . . . . . . . . . . . . .282
16.9.5 SCI Status Register 2. . . . . . . . . . . . . . . . . . . . . . . . . . . . .286
16.9.6 SCI Data Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 287
16.9.7 SCI Baud Rate Register . . . . . . . . . . . . . . . . . . . . . . . . . . . 288
16.2 Introduction
This section describes the serial communications interface (SCI)
module, which allows high-speed asynchronous communications with
peripheral devices and other MCUs.
NOTE:
When the SCI is enabled, the TxD pin is an open-drain output and
requires a pullup resistor to be connected for proper SCI operation.
NOTE:
References to DMA (direct-memory access) and associated functions
are only valid if the MCU has a DMA module. This MCU does not have
the DMA function. Any DMA-related register bits should be left in their
reset state for normal MCU operation.
16.3 Features
Features of the SCI module include the following:
Technical Data
252
Full-duplex operation
Standard mark/space non-return-to-zero (NRZ) format
32 programmable baud rates
Programmable 8-bit or 9-bit character length
Separately enabled transmitter and receiver
Separate receiver and transmitter CPU interrupt requests
Programmable transmitter output polarity
MOTOROLA
Features
Two receiver wakeup methods:
– Idle line wakeup
– Address mark wakeup
Interrupt-driven operation with eight interrupt flags:
– Transmitter empty
– Transmission complete
– Receiver full
– Idle receiver input
– Receiver overrun
– Noise error
– Framing error
– Parity error
Receiver framing error detection
Hardware parity checking
1/16 bit-time noise detection
Configuration register bit, SCIBDSRC, to allow selection of baud
rate clock source
MOTOROLA
Technical Data
253
16.4 Pin Name Conventions
The generic names of the SCI I/O pins are:
RxD (receive data)
TxD (transmit data)
SCI I/O (input/output) lines are implemented by sharing parallel I/O port
pins. The full name of an SCI input or output reflects the name of the
shared port pin. Table 16-1 shows the full names and the generic names
of the SCI I/O pins. The generic pin names appear in the text of this
section.
Table 16-1. Pin Name Conventions
NOTE:
Generic Pin Names:
RxD
TxD
Full Pin Names:
PTB3/SCL1/RxD
PTB2/SDA1/TxD
Figure 16-1 shows the structure of the SCI module. The SCI allows fullduplex, asynchronous, NRZ serial communication among the MCU and
remote devices, including other MCUs. The transmitter and receiver of
the SCI operate independently, although they use the same baud rate
generator. During normal operation, the CPU monitors the status of the
SCI, writes the data to be transmitted, and processes received data.
The baud rate clock source for the SCI can be selected via the
configuration bit, SCIBDSRC, of the CONFIG2 register ($001D). Source
selection values are shown in Figure 16-1.
Technical Data
254
MOTOROLA
INTERNAL BUS
SCI DATA
REGISTER
ERROR
INTERRUPT
CONTROL
RECEIVER
INTERRUPT
CONTROL
DMA
INTERRUPT
CONTROL
RECEIVE
SHIFT REGISTER
RxD
TRANSMITTER
INTERRUPT
CONTROL
SCI DATA
REGISTER
TRANSMIT
SHIFT REGISTER
TxD
TXINV
SCTIE
R8
TCIE
T8
SCRIE
ILIE
DMARE
TE
SCTE
RE
DMATE
TC
RWU
SBK
SCRF
OR
ORIE
IDLE
NF
NEIE
FE
FEIE
PE
PEIE
LOOPS
LOOPS
WAKEUP
CONTROL
SCIBDSRC
FROM
CONFIG
RECEIVE
CONTROL
ENSCI
ENSCI
TRANSMIT
CONTROL
FLAG
CONTROL
BKF
M
RPF
WAKE
ILTY
SL
A
CGMXCLK
X
B
IT12
SL = 0 => X = A
SL = 1 => X = B
÷4
CGMXCLK is from CGM module
IT12 = fBUS
PRESCALER
BAUD
DIVIDER
÷ 16
PEN
PTY
DATA SELECTION
CONTROL
Figure 16-1. SCI Module Block Diagram
MOTOROLA
Technical Data
255
Addr.
Register Name
Bit 7
6
5
4
3
2
1
Bit 0
ENSCI
TXINV
M
WAKE
ILTY
PEN
PTY
SCTIE
TCIE
SCRIE
ILIE
TE
RE
RWU
SBK
T8
DMARE
DMATE
ORIE
NEIE
FEIE
PEIE
U
U
SCTE
TC
SCRF
IDLE
OR
NF
FE
PE
1
1
BKF
RPF
Read:
$0013
LOOPS
Write:
(SCC1)
Reset:
Read:
$0014
Write:
(SCC2)
Reset:
Read:
$0015
Write:
(SCC3)
Reset:
Read:
$0016
Write:
(SCS1)
Reset:
R8
Read:
$0017
$0018
Write:
(SCS2)
Reset:
Read:
R7
R6
R5
R4
R3
R2
R1
R0
T7
T6
T5
T4
T3
T2
T1
T0
SCI Data Register
Write:
(SCDR)
Reset:
Read:
$0019
Write:
(SCBR)
Reset:
Unaffected by reset
SCP1
SCP0
R
SCR2
SCR1
SCR0
= Unimplemented
R = Reserved
U = Unaffected
Figure 16-2. SCI I/O Register Summary
Technical Data
256
MOTOROLA
16.5.1 Data Format
The SCI uses the standard non-return-to-zero mark/space data format
illustrated in Figure 16-3.
8-BIT DATA FORMAT
BIT M IN SCC1 CLEAR
START
BIT
BIT 0
BIT 1
BIT 2
BIT 3
BIT 4
BIT 5
PARITY
BIT
BIT 6
BIT 7
9-BIT DATA FORMAT
BIT M IN SCC1 SET
START
BIT
BIT 0
BIT 1
BIT 2
BIT 3
BIT 4
BIT 5
STOP
BIT
NEXT
START
BIT
PARITY
BIT
BIT 6
BIT 7
BIT 8
STOP
BIT
NEXT
START
BIT
Figure 16-3. SCI Data Formats
16.5.2 Transmitter
Figure 16-4 shows the structure of the SCI transmitter.
configuration bit, SCIBDSRC. Source selection values are shown in
Figure 16-4.
MOTOROLA
Technical Data
257
SCIBDSRC
FROM
CONFIG2
SL
CGMXCLK
A
X
B
IT12
SL = 0 => X = A
SL = 1 => X = B
INTERNAL BUS
BAUD
DIVIDER
÷ 16
SCI DATA REGISTER
SCP1
11-BIT
TRANSMIT
SHIFT REGISTER
STOP
SCP0
SCR1
H
SCR2
8
7
6
5
4
3
2
START
PRESCALER
÷4
1
L
TxD
MSB
TXINV
T8
DMATE
DMATE
SCTIE
SCTE
DMATE
SCTE
SCTIE
TC
TCIE
BREAK
ALL 0s
PTY
PARITY
GENERATION
PREAMBLE
ALL 1s
PEN
SHIFT ENABLE
M
LOAD FROM SCDR
TRANSMITTER DMA SERVICE REQUEST
TRANSMITTER CPU INTERRUPT REQUEST
SCR0
TRANSMITTER
CONTROL LOGIC
SCTE
SBK
LOOPS
SCTIE
ENSCI
TC
TE
TCIE
Figure 16-4. SCI Transmitter
Technical Data
258
MOTOROLA
16.5.2.1 Character Length
The transmitter can accommodate either 8-bit or 9-bit data. The state of
the M bit in SCI control register 1 (SCC1) determines character length.
When transmitting 9-bit data, bit T8 in SCI control register 3 (SCC3) is
the ninth bit (bit 8).
16.5.2.2 Character Transmission
During an SCI transmission, the transmit shift register shifts a character
out to the TxD pin. The SCI data register (SCDR) is the write-only buffer
between the internal data bus and the transmit shift register. To initiate
an SCI transmission:
1. Enable the SCI by writing a logic 1 to the enable SCI bit (ENSCI)
in SCI control register 1 (SCC1).
2. Enable the transmitter by writing a logic 1 to the transmitter enable
bit (TE) in SCI control register 2 (SCC2).
3. Clear the SCI transmitter empty bit by first reading SCI status
register 1 (SCS1) and then writing to the SCDR.
4. Repeat step 3 for each subsequent transmission.
At the start of a transmission, transmitter control logic automatically
loads the transmit shift register with a preamble of logic 1s. After the
preamble shifts out, control logic transfers the SCDR data into the
transmit shift register. A logic 0 start bit automatically goes into the least
significant bit position of the transmit shift register. A logic 1 stop bit goes
into the most significant bit position.
The SCI transmitter empty bit, SCTE, in SCS1 becomes set when the
SCDR transfers a byte to the transmit shift register. The SCTE bit
indicates that the SCDR can accept new data from the internal data bus.
If the SCI transmit interrupt enable bit, SCTIE, in SCC2 is also set, the
SCTE bit generates a transmitter CPU interrupt request.
When the transmit shift register is not transmitting a character, the TxD
pin goes to the idle condition, logic 1. If at any time software clears the
ENSCI bit in SCI control register 1 (SCC1), the transmitter and receiver
relinquish control of the port pin.
MOTOROLA
Technical Data
259
16.5.2.3 Break Characters
Writing a logic 1 to the send break bit, SBK, in SCC2 loads the transmit
shift register with a break character. A break character contains all logic
0s and has no start, stop, or parity bit. Break character length depends
on the M bit in SCC1. As long as SBK is at logic 1, transmitter logic
continuously loads break characters into the transmit shift register. After
software clears the SBK bit, the shift register finishes transmitting the
last break character and then transmits at least one logic 1. The
automatic logic 1 at the end of a break character guarantees the
recognition of the start bit of the next character.
The SCI recognizes a break character when a start bit is followed by
eight or nine logic 0 data bits and a logic 0 where the stop bit should be.
Receiving a break character has these effects on SCI registers:
Sets the framing error bit (FE) in SCS1
Sets the SCI receiver full bit (SCRF) in SCS1
Clears the SCI data register (SCDR)
Clears the R8 bit in SCC3
Sets the break flag bit (BKF) in SCS2
May set the overrun (OR), noise flag (NF), parity error (PE), or
reception in progress flag (RPF) bits
16.5.2.4 Idle Characters
An idle character contains all logic 1s and has no start, stop, or parity bit.
Idle character length depends on the M bit in SCC1. The preamble is a
synchronizing idle character that begins every transmission.
If the TE bit is cleared during a transmission, the TxD pin becomes idle
after completion of the transmission in progress. Clearing and then
setting the TE bit during a transmission queues an idle character to be
sent after the character currently being transmitted.
Technical Data
260
MOTOROLA
NOTE:
When queueing an idle character, return the TE bit to logic 1 before the
stop bit of the current character shifts out to the TxD pin. Setting TE after
the stop bit appears on TxD causes data previously written to the SCDR
to be lost.
Toggle the TE bit for a queued idle character when the SCTE bit
becomes set and just before writing the next byte to the SCDR.
16.5.2.5 Inversion of Transmitted Output
The transmit inversion bit (TXINV) in SCI control register 1 (SCC1)
reverses the polarity of transmitted data. All transmitted values, including
idle, break, start, and stop bits, are inverted when TXINV is at logic 1.
(See 16.9.1 SCI Control Register 1.)
16.5.2.6 Transmitter Interrupts
These conditions can generate CPU interrupt requests from the SCI
transmitter:
SCI transmitter empty (SCTE) — The SCTE bit in SCS1 indicates
that the SCDR has transferred a character to the transmit shift
register. SCTE can generate a transmitter CPU interrupt request.
Setting the SCI transmit interrupt enable bit, SCTIE, in SCC2
enables the SCTE bit to generate transmitter CPU interrupt
requests.
Transmission complete (TC) — The TC bit in SCS1 indicates that
the transmit shift register and the SCDR are empty and that no
break or idle character has been generated. The transmission
complete interrupt enable bit, TCIE, in SCC2 enables the TC bit to
generate transmitter CPU interrupt requests.
MOTOROLA
Technical Data
261
16.5.3 Receiver
Figure 16-5 shows the structure of the SCI receiver.
16.5.3.1 Character Length
The receiver can accommodate either 8-bit or 9-bit data. The state of the
When receiving 9-bit data, bit R8 in SCI control register 2 (SCC2) is the
ninth bit (bit 8). When receiving 8-bit data, bit R8 is a copy of the eighth
bit (bit 7).
16.5.3.2 Character Reception
During an SCI reception, the receive shift register shifts characters in
from the RxD pin. The SCI data register (SCDR) is the read-only buffer
between the internal data bus and the receive shift register.
After a complete character shifts into the receive shift register, the data
portion of the character transfers to the SCDR. The SCI receiver full bit,
SCRF, in SCI status register 1 (SCS1) becomes set, indicating that the
received byte can be read. If the SCI receive interrupt enable bit, SCRIE,
in SCC2 is also set, the SCRF bit generates a receiver CPU interrupt
request.
Technical Data
262
MOTOROLA
INTERNAL BUS
SCIBDSRC
FROM
CONFIG2
SCR1
SCP0
SCR0
PRESCALER
BAUD
DIVIDER
÷ 16
DATA
RECOVERY
RxD
11-BIT
RECEIVE SHIFT REGISTER
8
7
6
5
M
WAKE
ILTY
PEN
PTY
4
3
2
1
L
ALL 0s
RPF
ERROR CPU INTERRUPT REQUEST
DMA SERVICE REQUEST
H
ALL 1s
BKF
STOP
÷4
SCI DATA REGISTER
START
SCR2
MSB
SL
CGMXCLK
A
X
B
IT12
SL = 0 => X = A
SL = 1 => X = B
SCP1
SCRF
WAKEUP
LOGIC
PARITY
CHECKING
IDLE
ILIE
DMARE
SCRF
SCRIE
DMARE
SCRF
SCRIE
DMARE
OR
ORIE
NF
NEIE
FE
FEIE
PE
PEIE
RWU
IDLE
R8
ILIE
SCRIE
DMARE
OR
ORIE
NF
NEIE
FE
FEIE
PE
PEIE
Figure 16-5. SCI Receiver Block Diagram
MOTOROLA
Technical Data
263
16.5.3.3 Data Sampling
The receiver samples the RxD pin at the RT clock rate. The RT clock is
an internal signal with a frequency 16 times the baud rate. To adjust for
baud rate mismatch, the RT clock is resynchronized at the following
times (see Figure 16-6):
After every start bit
After the receiver detects a data bit change from logic 1 to logic 0
(after the majority of data bit samples at RT8, RT9, and RT10
returns a valid logic 1 and the majority of the next RT8, RT9, and
RT10 samples returns a valid logic 0)
To locate the start bit, data recovery logic does an asynchronous search
for a logic 0 preceded by three logic 1s. When the falling edge of a
possible start bit occurs, the RT clock begins to count to 16.
START BIT
LSB
RxD
START BIT
QUALIFICATION
SAMPLES
START BIT
VERIFICATION
DATA
SAMPLING
RT4
RT3
RT2
RT1
RT16
RT15
RT14
RT13
RT12
RT11
RT10
RT9
RT8
RT7
RT6
RT5
RT4
RT3
RT2
RT1
RT1
RT1
RT1
RT1
RT1
RT1
RT1
RT CLOCK
STATE
RT1
RT
CLOCK
RT CLOCK
RESET
Figure 16-6. Receiver Data Sampling
Technical Data
264
MOTOROLA
To verify the start bit and to detect noise, data recovery logic takes
samples at RT3, RT5, and RT7. Table 16-2 summarizes the results of
the start bit verification samples.
Table 16-2. Start Bit Verification
RT3, RT5, and RT7
Samples
Start Bit
Verification
Noise Flag
000
Yes
Yes
1
010
Yes
1
011
No
Yes
1
101
No
No
No
Start bit verification is not successful if any two of the three verification
samples are logic 1s. If start bit verification is not successful, the RT
clock is reset and a new search for a start bit begins.
To determine the value of a data bit and to detect noise, recovery logic
takes samples at RT8, RT9, and RT10. Table 16-3 summarizes the
results of the data bit samples.
Table 16-3. Data Bit Recovery
RT8, RT9, and RT10
Samples
Data Bit
Determination
Noise Flag
000
010
011
1
1
100
101
1
1
110
1
1
111
1
MOTOROLA
Technical Data
265
NOTE:
The RT8, RT9, and RT10 samples do not affect start bit verification. If
any or all of the RT8, RT9, and RT10 start bit samples are logic 1s
following a successful start bit verification, the noise flag (NF) is set and
the receiver assumes that the bit is a start bit.
To verify a stop bit and to detect noise, recovery logic takes samples at
RT8, RT9, and RT10. Table 16-4 summarizes the results of the stop bit
samples.
Table 16-4. Stop Bit Recovery
RT8, RT9, and RT10
Samples
Framing
Error Flag
Noise Flag
000
1
1
1
010
1
1
011
100
1
1
101
110
111
16.5.3.4 Framing Errors
If the data recovery logic does not detect a logic 1 where the stop bit
should be in an incoming character, it sets the framing error bit, FE, in
SCS1. A break character also sets the FE bit because a break character
has no stop bit. The FE bit is set at the same time that the SCRF bit is
set.
16.5.3.5 Baud Rate Tolerance
A transmitting device may be operating at a baud rate below or above
the receiver baud rate. Accumulated bit time misalignment can cause
one of the three stop bit data samples to fall outside the actual stop bit.
Then a noise error occurs. If more than one of the samples is outside the
stop bit, a framing error occurs. In most applications, the baud rate
Technical Data
266
MOTOROLA
tolerance is much more than the degree of misalignment that is likely to
occur.
As the receiver samples an incoming character, it resynchronizes the RT
clock on any valid falling edge within the character. Resynchronization
within characters corrects misalignments between transmitter bit times
and receiver bit times.
Slow Data Tolerance
Figure 16-7 shows how much a slow received character can be
misaligned without causing a noise error or a framing error. The slow
stop bit begins at RT8 instead of RT1 but arrives in time for the stop bit
data samples at RT8, RT9, and RT10.
RT16
RT15
RT14
RT13
RT12
RT11
RT10
RT9
RT8
RT7
RT6
STOP
RT5
RT4
RT3
RT2
RECEIVER
RT CLOCK
RT1
MSB
DATA
SAMPLES
Figure 16-7. Slow Data
For an 8-bit character, data sampling of the stop bit takes the receiver
9 bit times × 16 RT cycles + 10 RT cycles = 154 RT cycles.
With the misaligned character shown in Figure 16-7, the receiver counts
154 RT cycles at the point when the count of the transmitting device is
9 bit times × 16 RT cycles + 3 RT cycles = 147 RT cycles.
The maximum percent difference between the receiver count and the
transmitter count of a slow 8-bit character with no errors is
154 – 147 × 100 = 4.54%
-------------------------154
For a 9-bit character, data sampling of the stop bit takes the receiver
10 bit times × 16 RT cycles + 10 RT cycles = 170 RT cycles.
MOTOROLA
Technical Data
267
170 RT cycles at the point when the count of the transmitting device is
10 bit times × 16 RT cycles + 3 RT cycles = 163 RT cycles.
transmitter count of a slow 9-bit character with no errors is
170 – 163 × 100 = 4.12%
-------------------------170
Fast Data Tolerance
Figure 16-8 shows how much a fast received character can be
misaligned without causing a noise error or a framing error. The fast stop
bit ends at RT10 instead of RT16 but is still there for the stop bit data
RT16
RT15
RT14
RT13
RT12
RT11
RT10
RT9
RT8
RT7
IDLE OR NEXT CHARACTER
RT6
RT5
RT4
RT3
RT2
RECEIVER
RT CLOCK
RT1
STOP
DATA
SAMPLES
Figure 16-8. Fast Data
With the misaligned character shown in Figure 16-8, the receiver counts
10 bit times × 16 RT cycles = 160 RT cycles.
transmitter count of a fast 8-bit character with no errors is
154 – 160 × 100 = 3.90%
Technical Data
268
MOTOROLA
11 bit times × 16 RT cycles = 176 RT cycles.
transmitter count of a fast 9-bit character with no errors is
170 – 176 × 100 = 3.53%
16.5.3.6 Receiver Wakeup
So that the MCU can ignore transmissions intended only for other
receivers in multiple-receiver systems, the receiver can be put into a
standby state. Setting the receiver wakeup bit, RWU, in SCC2 puts the
receiver into a standby state during which receiver interrupts are
disabled.
Depending on the state of the WAKE bit in SCC1, either of two
conditions on the RxD pin can bring the receiver out of the standby state:
Address mark — An address mark is a logic 1 in the most
significant bit position of a received character. When the WAKE bit
is set, an address mark wakes the receiver from the standby state
by clearing the RWU bit. The address mark also sets the SCI
receiver full bit, SCRF. Software can then compare the character
containing the address mark to the user-defined address of the
receiver. If they are the same, the receiver remains awake and
processes the characters that follow. If they are not the same,
software can set the RWU bit and put the receiver back into the
standby state.
Idle input line condition — When the WAKE bit is clear, an idle
character on the RxD pin wakes the receiver from the standby
state by clearing the RWU bit. The idle character that wakes the
receiver does not set the receiver idle bit, IDLE, or the SCI receiver
MOTOROLA
Technical Data
269
full bit, SCRF. The idle line type bit, ILTY, determines whether the
receiver begins counting logic 1s as idle character bits after the
start bit or after the stop bit.
NOTE:
With the WAKE bit clear, setting the RWU bit after the RxD pin has been
idle may cause the receiver to wake up immediately.
16.5.3.7 Receiver Interrupts
The following sources can generate CPU interrupt requests from the SCI
receiver:
SCI receiver full (SCRF) — The SCRF bit in SCS1 indicates that
the receive shift register has transferred a character to the SCDR.
SCRF can generate a receiver CPU interrupt request. Setting the
SCI receive interrupt enable bit, SCRIE, in SCC2 enables the
SCRF bit to generate receiver CPU interrupts.
Idle input (IDLE) — The IDLE bit in SCS1 indicates that 10 or 11
consecutive logic 1s shifted in from the RxD pin. The idle line
interrupt enable bit, ILIE, in SCC2 enables the IDLE bit to generate
16.5.3.8 Error Interrupts
The following receiver error flags in SCS1 can generate CPU interrupt
requests:
Technical Data
270
Receiver overrun (OR) — The OR bit indicates that the receive
shift register shifted in a new character before the previous
character was read from the SCDR. The previous character
remains in the SCDR, and the new character is lost. The overrun
interrupt enable bit, ORIE, in SCC3 enables OR to generate SCI
error CPU interrupt requests.
Noise flag (NF) — The NF bit is set when the SCI detects noise on
incoming data or break characters, including start, data, and stop
bits. The noise error interrupt enable bit, NEIE, in SCC3 enables
NF to generate SCI error CPU interrupt requests.
MOTOROLA
Low-Power Modes
Framing error (FE) — The FE bit in SCS1 is set when a logic 0
occurs where the receiver expects a stop bit. The framing error
interrupt enable bit, FEIE, in SCC3 enables FE to generate SCI
Parity error (PE) — The PE bit in SCS1 is set when the SCI
detects a parity error in incoming data. The parity error interrupt
enable bit, PEIE, in SCC3 enables PE to generate SCI error CPU
interrupt requests.
The WAIT and STOP instructions put the MCU in low powerconsumption standby modes.
16.6.1 Wait Mode
The SCI module remains active after the execution of a WAIT
instruction. In wait mode, the SCI module registers are not accessible by
the CPU. Any enabled CPU interrupt request from the SCI module can
If SCI module functions are not required during wait mode, reduce power
consumption by disabling the module before executing the WAIT
instruction.
Refer to 9.7 Low-Power Modes for information on exiting wait mode.
16.6.2 Stop Mode
The SCI module is inactive after the execution of a STOP instruction.
The STOP instruction does not affect SCI register states. SCI module
operation resumes after an external interrupt.
Because the internal clock is inactive during stop mode, entering stop
mode during an SCI transmission or reception results in invalid data.
Refer to 9.7 Low-Power Modes for information on exiting stop mode.
MOTOROLA
Technical Data
271
16.7 SCI During Break Module Interrupts
The system integration module (SIM) controls whether status bits in
other modules can be cleared during the break state. The BCFE bit in
the SIM break flag control register (SBFCR) enables software to clear
status bits during the break state.
To allow software to clear status bits during a break interrupt, write a
logic 1 to the BCFE bit. If a status bit is cleared during the break state, it
remains cleared when the MCU exits the break state.
To protect status bits during the break state, write a logic 0 to the BCFE
bit. With BCFE at logic 0 (its default state), software can read and write
I/O registers during the break state without affecting status bits. Some
status bits have a 2-step read/write clearing procedure. If software does
the first step on such a bit before the break, the bit cannot change during
the break state as long as BCFE is at logic 0. After the break, doing the
second step clears the status bit.
16.8 I/O Signals
Port B shares two of its pins with the SCI module.
The two SCI I/O pins are:
PTB2/SDA1/TxD — Transmit data
PTB3/SCL1/RxD — Receive data
When the SCI is enabled (ENSCI=1), the PTB2/SDA1/TxD pin becomes
the serial data output, TxD, from the SCI transmitter regardless of the
state of the DDRB2 bit in data direction register B (DDRB). The TxD pin
is an open-drain output and requires a pullup resistor to be connected for
NOTE:
Technical Data
272
The PTB2/SDA1/TxD pin is an open-drain pin when configured as an
output. Therefore, when configured as a general purpose output pin
(PTB2), a pullup resistor must be connected to this pin.
MOTOROLA
I/O Registers
16.8.2 RxD (Receive Data)
When the SCI is enabled (ENSCI=1), the PTB3/SCL1/RxD pin becomes
the serial data input, RxD, to the SCI receiver regardless of the state of
the DDRB3 bit in data direction register B (DDRB).
NOTE:
The PTB3/SCL1/RxD pin is an open-drain pin when configured as an
(PTB3), a pullup resistor must be connected to this pin.
16.9 I/O Registers
These I/O registers control and monitor SCI operation:
SCI status register 2 (SCS2)
SCI baud rate register (SCBR)
SCI control register 1:
Enables loop mode operation
Enables the SCI
Controls output polarity
Controls character length
Controls SCI wakeup method
Controls idle character detection
Enables parity function
Controls parity type
MOTOROLA
Technical Data
273
Address:
$0013
Bit 7
6
5
4
3
2
1
Bit 0
LOOPS
ENSCI
TXINV
M
WAKE
ILTY
PEN
PTY
Read:
Write:
Reset:
Figure 16-9. SCI Control Register 1 (SCC1)
LOOPS — Loop Mode Select Bit
This read/write bit enables loop mode operation. In loop mode the
RxD pin is disconnected from the SCI, and the transmitter output goes
into the receiver input. Both the transmitter and the receiver must be
enabled to use loop mode. Reset clears the LOOPS bit.
1 = Loop mode enabled
0 = Normal operation enabled
ENSCI — Enable SCI Bit
This read/write bit enables the SCI and the SCI baud rate generator.
Clearing ENSCI sets the SCTE and TC bits in SCI status register 1
and disables transmitter interrupts. Reset clears the ENSCI bit.
1 = SCI enabled
0 = SCI disabled
TXINV — Transmit Inversion Bit
This read/write bit reverses the polarity of transmitted data. Reset
clears the TXINV bit.
1 = Transmitter output inverted
0 = Transmitter output not inverted
NOTE:
Technical Data
274
Setting the TXINV bit inverts all transmitted values, including idle, break,
start, and stop bits.
MOTOROLA
I/O Registers
M — Mode (Character Length) Bit
This read/write bit determines whether SCI characters are eight or
nine bits long. (See Table 16-5.) The ninth bit can serve as an extra
stop bit, as a receiver wakeup signal, or as a parity bit. Reset clears
the M bit.
1 = 9-bit SCI characters
0 = 8-bit SCI characters
WAKE — Wakeup Condition Bit
This read/write bit determines which condition wakes up the SCI: a
logic 1 (address mark) in the most significant bit position of a received
character or an idle condition on the RxD pin. Reset clears the WAKE
bit.
1 = Address mark wakeup
0 = Idle line wakeup
ILTY — Idle Line Type Bit
This read/write bit determines when the SCI starts counting logic 1s
as idle character bits. The counting begins either after the start bit or
after the stop bit. If the count begins after the start bit, then a string of
logic 1s preceding the stop bit may cause false recognition of an idle
character. Beginning the count after the stop bit avoids false idle
character recognition, but requires properly synchronized
transmissions. Reset clears the ILTY bit.
1 = Idle character bit count begins after stop bit
0 = Idle character bit count begins after start bit
PEN — Parity Enable Bit
This read/write bit enables the SCI parity function. (See Table 16-5.)
When enabled, the parity function inserts a parity bit in the most
significant bit position. (See Figure 16-3.) Reset clears the PEN bit.
1 = Parity function enabled
0 = Parity function disabled
MOTOROLA
Technical Data
275
PTY — Parity Bit
This read/write bit determines whether the SCI generates and checks
for odd parity or even parity. (See Table 16-5.) Reset clears the PTY
bit.
1 = Odd parity
0 = Even parity
NOTE:
Changing the PTY bit in the middle of a transmission or reception can
generate a parity error.
Table 16-5. Character Format Selection
Control Bits
Character Format
M
PEN and
PTY
Start
Bits
Data
Bits
Parity
Stop
Bits
Character
Length
0X
1
8
None
1
10 bits
1
0X
1
9
None
1
11 bits
1
7
Even
1
10 bits
1
7
Odd
1
10 bits
1
10
1
8
Even
1
11 bits
1
11
1
8
Odd
1
11 bits
SCI control register 2:
Enables the following CPU interrupt requests:
– Enables the SCTE bit to generate transmitter CPU interrupt
requests
– Enables the TC bit to generate transmitter CPU interrupt
requests
– Enables the SCRF bit to generate receiver CPU interrupt
requests
– Enables the IDLE bit to generate receiver CPU interrupt
requests
Technical Data
276
MOTOROLA
I/O Registers
Enables the transmitter
Enables the receiver
Enables SCI wakeup
Transmits SCI break characters
Address:
$0014
Bit 7
6
5
4
3
2
1
Bit 0
SCTIE
TCIE
SCRIE
ILIE
TE
RE
RWU
SBK
Read:
Write:
Reset:
Figure 16-10. SCI Control Register 2 (SCC2)
SCTIE — SCI Transmit Interrupt Enable Bit
This read/write bit enables the SCTE bit to generate SCI transmitter
CPU interrupt requests. Reset clears the SCTIE bit.
1 = SCTE enabled to generate CPU interrupt
0 = SCTE not enabled to generate CPU interrupt
TCIE — Transmission Complete Interrupt Enable Bit
This read/write bit enables the TC bit to generate SCI transmitter CPU
interrupt requests. Reset clears the TCIE bit.
1 = TC enabled to generate CPU interrupt requests
0 = TC not enabled to generate CPU interrupt requests
SCRIE — SCI Receive Interrupt Enable Bit
This read/write bit enables the SCRF bit to generate SCI receiver
CPU interrupt requests. Reset clears the SCRIE bit.
1 = SCRF enabled to generate CPU interrupt
0 = SCRF not enabled to generate CPU interrupt
ILIE — Idle Line Interrupt Enable Bit
This read/write bit enables the IDLE bit to generate SCI receiver CPU
interrupt requests. Reset clears the ILIE bit.
1 = IDLE enabled to generate CPU interrupt requests
0 = IDLE not enabled to generate CPU interrupt requests
MOTOROLA
Technical Data
277
TE — Transmitter Enable Bit
Setting this read/write bit begins the transmission by sending a
preamble of 10 or 11 logic 1s from the transmit shift register to the
TxD pin. If software clears the TE bit, the transmitter completes any
transmission in progress before the TxD returns to the idle condition
(logic 1). Clearing and then setting TE during a transmission queues
an idle character to be sent after the character currently being
transmitted. Reset clears the TE bit.
1 = Transmitter enabled
0 = Transmitter disabled
NOTE:
Writing to the TE bit is not allowed when the enable SCI bit (ENSCI) is
clear. ENSCI is in SCI control register 1.
RE — Receiver Enable Bit
Setting this read/write bit enables the receiver. Clearing the RE bit
disables the receiver but does not affect receiver interrupt flag bits.
Reset clears the RE bit.
1 = Receiver enabled
0 = Receiver disabled
NOTE:
Writing to the RE bit is not allowed when the enable SCI bit (ENSCI) is
RWU — Receiver Wakeup Bit
This read/write bit puts the receiver in a standby state during which
receiver interrupts are disabled. The WAKE bit in SCC1 determines
whether an idle input or an address mark brings the receiver out of the
standby state and clears the RWU bit. Reset clears the RWU bit.
1 = Standby state
Technical Data
278
MOTOROLA
I/O Registers
SBK — Send Break Bit
Setting and then clearing this read/write bit transmits a break
character followed by a logic 1. The logic 1 after the break character
guarantees recognition of a valid start bit. If SBK remains set, the
transmitter continuously transmits break characters with no logic 1s
between them. Reset clears the SBK bit.
1 = Transmit break characters
0 = No break characters being transmitted
NOTE:
Do not toggle the SBK bit immediately after setting the SCTE bit.
Toggling SBK before the preamble begins causes the SCI to send a
break character instead of a preamble.
SCI control register 3:
Stores the ninth SCI data bit received and the ninth SCI data bit to
be transmitted
Enables these interrupts:
– Receiver overrun interrupts
– Noise error interrupts
– Framing error interrupts
Address:
Parity error interrupts
$0015
Bit 7
Read:
6
5
4
3
2
1
Bit 0
T8
DMARE
DMATE
ORIE
NEIE
FEIE
PEIE
U
R8
Write:
Reset:
U
= Unimplemented
U = Unaffected
Figure 16-11. SCI Control Register 3 (SCC3)
MOTOROLA
Technical Data
279
R8 — Received Bit 8
When the SCI is receiving 9-bit characters, R8 is the read-only ninth
bit (bit 8) of the received character. R8 is received at the same time
that the SCDR receives the other 8 bits.
When the SCI is receiving 8-bit characters, R8 is a copy of the eighth
bit (bit 7). Reset has no effect on the R8 bit.
T8 — Transmitted Bit 8
When the SCI is transmitting 9-bit characters, T8 is the read/write
ninth bit (bit 8) of the transmitted character. T8 is loaded into the
transmit shift register at the same time that the SCDR is loaded into
the transmit shift register. Reset has no effect on the T8 bit.
DMARE — DMA Receive Enable Bit
CAUTION:
The DMA module is not included on this MCU. Writing a logic 1 to
DMARE or DMATE may adversely affect MCU performance.
1 = DMA not enabled to service SCI receiver DMA service requests
generated by the SCRF bit (SCI receiver CPU interrupt
requests enabled)
0 = DMA not enabled to service SCI receiver DMA service requests
requests enabled)
DMATE — DMA Transfer Enable Bit
CAUTION:
1 = SCTE DMA service requests enabled; SCTE CPU interrupt
requests disabled
0 = SCTE DMA service requests disabled; SCTE CPU interrupt
requests enabled
Technical Data
280
MOTOROLA
I/O Registers
ORIE — Receiver Overrun Interrupt Enable Bit
This read/write bit enables SCI error CPU interrupt requests
generated by the receiver overrun bit, OR.
1 = SCI error CPU interrupt requests from OR bit enabled
0 = SCI error CPU interrupt requests from OR bit disabled
NEIE — Receiver Noise Error Interrupt Enable Bit
generated by the noise error bit, NE. Reset clears NEIE.
1 = SCI error CPU interrupt requests from NE bit enabled
0 = SCI error CPU interrupt requests from NE bit disabled
FEIE — Receiver Framing Error Interrupt Enable Bit
generated by the framing error bit, FE. Reset clears FEIE.
1 = SCI error CPU interrupt requests from FE bit enabled
0 = SCI error CPU interrupt requests from FE bit disabled
PEIE — Receiver Parity Error Interrupt Enable Bit
This read/write bit enables SCI receiver CPU interrupt
requests generated by the parity error bit, PE. (See 16.9.4 SCI Status
Register 1.) Reset clears PEIE.
1 = SCI error CPU interrupt requests from PE bit enabled
0 = SCI error CPU interrupt requests from PE bit disabled
MOTOROLA
Technical Data
281
SCI status register 1 (SCS1) contains flags to signal these conditions:
Transfer of SCDR data to transmit shift register complete
Transfer of receive shift register data to SCDR complete
Receiver input idle
Receiver overrun
Noisy data
Framing error
Parity error
Address:
Read:
$0016
Bit 7
6
5
4
3
2
1
Bit 0
SCTE
TC
SCRF
IDLE
OR
NF
FE
PE
1
1
Write:
Reset:
= Unimplemented
Figure 16-12. SCI Status Register 1 (SCS1)
SCTE — SCI Transmitter Empty Bit
This clearable, read-only bit is set when the SCDR transfers a
character to the transmit shift register. SCTE can generate an SCI
transmitter CPU interrupt request. When the SCTIE bit in SCC2 is set,
SCTE generates an SCI transmitter CPU interrupt request. In normal
operation, clear the SCTE bit by reading SCS1 with SCTE set and
then writing to SCDR. Reset sets the SCTE bit.
1 = SCDR data transferred to transmit shift register
0 = SCDR data not transferred to transmit shift register
Technical Data
282
MOTOROLA
I/O Registers
TC — Transmission Complete Bit
This read-only bit is set when the SCTE bit is set, and no data,
preamble, or break character is being transmitted. TC generates an
SCI transmitter CPU interrupt request if the TCIE bit in SCC2 is also
set. TC is automatically cleared when data, preamble or break is
queued and ready to be sent. There may be up to 1.5 transmitter
clocks of latency between queueing data, preamble, and break and
the transmission actually starting. Reset sets the TC bit.
1 = No transmission in progress
0 = Transmission in progress
SCRF — SCI Receiver Full Bit
This clearable, read-only bit is set when the data in the receive shift
register transfers to the SCI data register. SCRF can generate an SCI
receiver CPU interrupt request. When the SCRIE bit in SCC2 is set,
SCRF generates a CPU interrupt request. In normal operation, clear
the SCRF bit by reading SCS1 with SCRF set and then reading the
SCDR. Reset clears SCRF.
1 = Received data available in SCDR
0 = Data not available in SCDR
IDLE — Receiver Idle Bit
This clearable, read-only bit is set when 10 or 11 consecutive logic 1s
appear on the receiver input. IDLE generates an SCI error CPU
interrupt request if the ILIE bit in SCC2 is also set. Clear the IDLE bit
by reading SCS1 with IDLE set and then reading the SCDR. After the
receiver is enabled, it must receive a valid character that sets the
SCRF bit before an idle condition can set the IDLE bit. Also, after the
IDLE bit has been cleared, a valid character must again set the SCRF
bit before an idle condition can set the IDLE bit. Reset clears the IDLE
bit.
1 = Receiver input idle
0 = Receiver input active (or idle since the IDLE bit was cleared)
OR — Receiver Overrun Bit
This clearable, read-only bit is set when software fails to read the
SCDR before the receive shift register receives the next character.
The OR bit generates an SCI error CPU interrupt request if the ORIE
MOTOROLA
Technical Data
283
bit in SCC3 is also set. The data in the shift register is lost, but the data
already in the SCDR is not affected. Clear the OR bit by reading SCS1
with OR set and then reading the SCDR. Reset clears the OR bit.
1 = Receive shift register full and SCRF = 1
0 = No receiver overrun
Software latency may allow an overrun to occur between reads of
SCS1 and SCDR in the flag-clearing sequence. Figure 16-13 shows
the normal flag-clearing sequence and an example of an overrun
caused by a delayed flag-clearing sequence. The delayed read of
SCDR does not clear the OR bit because OR was not set when SCS1
was read. Byte 2 caused the overrun and is lost. The next flagclearing sequence reads byte 3 in the SCDR instead of byte 2.
In applications that are subject to software latency or in which it is
important to know which byte is lost due to an overrun, the flagclearing routine can check the OR bit in a second read of SCS1 after
reading the data register.
NF — Receiver Noise Flag Bit
This clearable, read-only bit is set when the SCI detects noise on the
RxD pin. NF generates an NF CPU interrupt request if the NEIE bit in
SCC3 is also set. Clear the NF bit by reading SCS1 and then reading
the SCDR. Reset clears the NF bit.
1 = Noise detected
0 = No noise detected
FE — Receiver Framing Error Bit
This clearable, read-only bit is set when a logic 0 is accepted as the
stop bit. FE generates an SCI error CPU interrupt request if the FEIE
bit in SCC3 also is set. Clear the FE bit by reading SCS1 with FE set
and then reading the SCDR. Reset clears the FE bit.
1 = Framing error detected
0 = No framing error detected
Technical Data
284
MC68HC908SR12•MC68HC08SR12 — Rev. 4.0
MOTOROLA
I/O Registers
BYTE 1
BYTE 2
BYTE 3
SCRF = 0
SCRF = 1
SCRF = 0
SCRF = 1
SCRF = 0
SCRF = 1
NORMAL FLAG CLEARING SEQUENCE
BYTE 4
READ SCS1
SCRF = 1
OR = 0
READ SCS1
SCRF = 1
OR = 0
READ SCS1
SCRF = 1
OR = 0
READ SCDR
BYTE 1
READ SCDR
BYTE 2
READ SCDR
BYTE 3
BYTE 1
BYTE 2
BYTE 3
SCRF = 0
OR = 0
SCRF = 1
OR = 1
SCRF = 0
OR = 1
SCRF = 1
SCRF = 1
OR = 1
DELAYED FLAG CLEARING SEQUENCE
BYTE 4
READ SCS1
SCRF = 1
OR = 0
READ SCS1
SCRF = 1
OR = 1
READ SCDR
BYTE 1
READ SCDR
BYTE 3
Figure 16-13. Flag Clearing Sequence
PE — Receiver Parity Error Bit
This clearable, read-only bit is set when the SCI detects a parity error
in incoming data. PE generates a PE CPU interrupt request if the
PEIE bit in SCC3 is also set. Clear the PE bit by reading SCS1 with
PE set and then reading the SCDR. Reset clears the PE bit.
1 = Parity error detected
0 = No parity error detected
MOTOROLA
Technical Data
285
SCI status register 2 contains flags to signal the following conditions:
Break character detected
Incoming data
Address:
$0017
Bit 7
6
5
4
3
2
Read:
1
Bit 0
BKF
RPF
Write:
Reset:
= Unimplemented
Figure 16-14. SCI Status Register 2 (SCS2)
BKF — Break Flag Bit
This clearable, read-only bit is set when the SCI detects a break
character on the RxD pin. In SCS1, the FE and SCRF bits are also
set. In 9-bit character transmissions, the R8 bit in SCC3 is cleared.
BKF does not generate a CPU interrupt request. Clear BKF by
reading SCS2 with BKF set and then reading the SCDR. Once
cleared, BKF can become set again only after logic 1s again appear
on the RxD pin followed by another break character. Reset clears the
BKF bit.
1 = Break character detected
0 = No break character detected
RPF — Reception in Progress Flag Bit
This read-only bit is set when the receiver detects a logic 0 during the
RT1 time period of the start bit search. RPF does not generate an
interrupt request. RPF is reset after the receiver detects false start bits
(usually from noise or a baud rate mismatch) or when the receiver
detects an idle character. Polling RPF before disabling the SCI
module or entering stop mode can show whether a reception is in
progress.
1 = Reception in progress
0 = No reception in progress
Technical Data
286
MOTOROLA
I/O Registers
The SCI data register (SCDR) is the buffer between the internal data bus
and the receive and transmit shift registers. Reset has no effect on data
in the SCI data register.
Address:
$0018
Bit 7
6
5
4
3
2
1
Bit 0
Read:
R7
R6
R5
R4
R3
R2
R1
R0
Write:
T7
T6
T5
T4
T3
T2
T1
T0
Reset:
Unaffected by reset
Figure 16-15. SCI Data Register (SCDR)
R7/T7–R0/T0 — Receive/Transmit Data Bits
Reading the SCI data register (SCDR) accesses the read-only
received data bits, R7:R0. Writing to the SCDR writes the data to be
transmitted, T7:T0. Reset has no effect on the SCDR.
NOTE:
Do not use read/modify/write instructions on the SCI data register.
MOTOROLA
Technical Data
287
The baud rate register (SCBR) selects the baud rate for both the receiver
and the transmitter.
Address:
Read:
$0019
Bit 7
6
4
3
2
1
Bit 0
SCP1
SCP0
R
SCR2
SCR1
SCR0
R
= Reserved
Write:
Reset:
= Unimplemented
Figure 16-16. SCI Baud Rate Register (SCBR)
SCP1 and SCP0 — SCI Baud Rate Prescaler Bits
These read/write bits select the baud rate prescaler divisor as shown
in Table 16-6. Reset clears SCP1 and SCP0.
Table 16-6. SCI Baud Rate Prescaling
SCP1 and SCP0
Prescaler Divisor (PD)
00
1
01
3
10
4
11
13
SCR2–SCR0 — SCI Baud Rate Select Bits
These read/write bits select the SCI baud rate divisor as shown in
Table 16-7. Reset clears SCR2–SCR0.
Technical Data
288
MOTOROLA
I/O Registers
Table 16-7. SCI Baud Rate Selection
SCR2, SCR1, and SCR0
Baud Rate Divisor (BD)
000
1
001
2
010
4
011
8
100
16
101
32
110
64
111
128
Use this formula to calculate the SCI baud rate:
SCI clock source
baud rate = --------------------------------------------64 × PD × BD
where:
SCI clock source = fBUS or CGMXCLK
(selected by SCIBDSRC bit in CONFIG2 register)
PD = prescaler divisor
BD = baud rate divisor
Table 16-8 shows the SCI baud rates that can be generated with a
4.9152-MHz bus clock when fBUS is selected as SCI clock source.
MOTOROLA
Technical Data
289
Table 16-8. SCI Baud Rate Selection Examples
SCP1 and
SCP0
Prescaler
Divisor (PD)
SCR2, SCR1,
and SCR0
Baud Rate
Divisor (BD)
Baud Rate
(fBUS = 4.9152 MHz)
00
1
000
1
76,800
00
1
001
2
38,400
00
1
010
4
19,200
00
1
011
8
9600
00
1
100
16
4800
00
1
101
32
2400
00
1
110
64
1200
00
1
111
128
600
01
3
000
1
25,600
01
3
001
2
12,800
01
3
010
4
6400
01
3
011
8
3200
01
3
100
16
1600
01
3
101
32
800
01
3
110
64
400
01
3
111
128
200
10
4
000
1
19,200
10
4
001
2
9600
10
4
010
4
4800
10
4
011
8
2400
10
4
100
16
1200
10
4
101
32
600
10
4
110
64
300
10
4
111
128
150
11
13
000
1
5908
11
13
001
2
2954
11
13
010
4
1477
11
13
011
8
739
11
13
100
16
369
11
13
101
32
185
11
13
110
64
92
11
13
111
128
46
Technical Data
290
MOTOROLA
Technical Data — MC68HC908SR12•MC68HC08SR12
Section 17. Multi-Master IIC Interface (MMIIC)
17.1 Contents
17.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 292
17.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 293
17.4
I/O Pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 293
17.5
Multi-Master IIC System Configuration . . . . . . . . . . . . . . . . . . 295
17.6 Multi-Master IIC Bus Protocol . . . . . . . . . . . . . . . . . . . . . . . . . 295
17.6.1 START Signal. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 296
17.6.2 Slave Address Transmission . . . . . . . . . . . . . . . . . . . . . . . 296
17.6.3 Data Transfer . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 296
17.6.4 Repeated START Signal . . . . . . . . . . . . . . . . . . . . . . . . . .297
17.6.5 STOP Signal. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .297
17.6.6 Arbitration Procedure . . . . . . . . . . . . . . . . . . . . . . . . . . . . .297
17.6.7 Clock Synchronization . . . . . . . . . . . . . . . . . . . . . . . . . . . . 298
17.6.8 Handshaking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 298
17.6.9 Packet Error Code . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 299
17.7 MMIIC I/O Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 299
17.7.1 MMIIC Address Register (MMADR) . . . . . . . . . . . . . . . . . . 299
17.7.2 MMIIC Control Register 1 (MMCR1) . . . . . . . . . . . . . . . . . 301
17.7.3 MMIIC Control Register 2 (MMCR2) . . . . . . . . . . . . . . . . . 303
17.7.4 MMIIC Status Register (MMSR). . . . . . . . . . . . . . . . . . . . . 305
17.7.5 MMIIC Data Transmit Register (MMDTR) . . . . . . . . . . . . . 307
17.7.6 MMIIC Data Receive Register (MMDRR). . . . . . . . . . . . . . 308
17.7.7 MMIIC CRC Data Register (MMCRCDR). . . . . . . . . . . . . . 309
17.7.8 MMIIC Frequency Divider Register (MMFDR) . . . . . . . . . . 310
17.8 Program Algorithm. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 311
17.8.1 Data Sequence. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 312
17.9
SMBus Protocols with PEC and without PEC. . . . . . . . . . . . . 313
MOTOROLA
Technical Data
291
17.9.1
17.9.2
17.9.3
17.9.4
17.9.5
17.9.6
17.9.7
Quick Command. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 313
Send Byte. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 313
Receive Byte . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 313
Write Byte/Word . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 314
Read Byte/Word . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 314
Process Call . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .315
Block Read/Write . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 315
17.10 SMBus Protocol Implementation . . . . . . . . . . . . . . . . . . . . . . 316
17.2 Introduction
The multi-master IIC (MMIIC) interface is a two wire, bidirectional serial
bus which provides a simple, efficient way for data exchange between
devices. The interface is designed for internal serial communication
between the MCU and other IIC devices. It has hardware generated
START and STOP signals; and byte by byte interrupt driven software
algorithm.
This bus is suitable for applications which need frequent
communications over a short distance between a number of devices. It
also provides a flexibility that allows additional devices to be connected
to the bus. The maximum data rate is 100k-bps, and the maximum
communication distance and number of devices that can be connected
is limited by a maximum bus capacitance of 400pF.
This MMIIC interface is also SMBus (System Management Bus) version
1.0 and 1.1 compatible, with hardware cyclic redundancy code (CRC)
generation, making it suitable for smart battery applications.
For connection flexibility, two channels are available:
Channel 0 — SDA0 and SCL0
Channel 1 — SDA1 and SCL1
The two channels are multiplexed; only one channel is active at any one
time.
Technical Data
292
MOTOROLA
Features
17.3 Features
Features of the MMIC module include:
Full SMBus version 1.0/1.1 compliance
Multi-master IIC bus standard
Software programmable for one of eight different serial clock
frequencies
Software controllable acknowledge bit generation
Interrupt driven byte by byte data transfer
Calling address identification interrupt
Arbitration loss detection and no-ACK awareness in master mode
and automatic mode switching from master to slave
Auto detection of R/W bit and switching of transmit or receive
mode accordingly
Detection of START, repeated START, and STOP signals
Auto generation of START and STOP condition in master mode
Repeated start generation
Master clock generator with eight selectable baud rates
Automatic recognition of the received acknowledge bit
Busy detection
Software enabled 8-bit CRC generation/decoding
17.4 I/O Pins
The MMIIC module uses four I/O pins, shared with standard port I/O
pins. The full name of the MMIIC I/O pins are listed in Table 17-1. The
generic pin name appear in the text that follows.
The SDA0/SCL0 and SDA1/SCL1 pins are open-drain. When configured
as general purpose output pins (PTB0–PTB3), pullup resistors must be
connected to these pins.
MOTOROLA
Technical Data
293
Table 17-1. Pin Name Conventions
MMIIC Generic Pin Names:
Full MCU Pin Names:
SDA0
PTB0/SDA0
SCL0
PTB1/SCL0
SDA1
PTB2/SDA1/TxD
SCL1
PTB3/SCL1/RxD
Addr.
$0048
Register Name
Bit 7
Read:
MMAD7
Write:
(MMADR)
Reset:
1
Read:
$0049
Write:
(MMCR1)
Reset:
MMEN
$004C
$004D
MMEN and SDASCL1 bits in MMCR1 ($0049)
ENSCI bit in SCC1 ($0013);
6
5
4
3
2
1
Bit 0
MMAD6
MMAD5
MMAD4
MMAD3
MMAD2
MMAD1
MMEXTAD
MMCRCBYTE
SDASCL1
MMIEN
MMTXAK REPSEN
MMCLRBB
Read: MMALIF MMNAKIF
$004A
Write:
(MMCR2)
Reset:
$004B
Pin Selected for MMIIC Function By:
Read: MMRXIF
Write:
(MMSR)
Reset:
Read:
MMIIC Data Transmit
MMTD7
Register Write:
(MMDTR)
Reset:
Read: MMRD7
MMIIC Data Receive
Register Write:
(MDDRR)
Reset:
MMBB
MMAST
MMRW
MMCRCEF
Unaffected
MMTXIF MMATCH MMSRW MMRXAK MMCRCBF MMTXBE MMRXBF
MMTD6
MMTD5
MMTD4
MMTD3
MMTD2
MMTD1
MMTD0
MMRD6
MMRD5
MMRD4
MMRD3
MMRD2
MMRD1
MMRD0
Read: MMCRCD7 MMCRCD6 MMCRCD5 MMCRCD4 MMCRCD3 MMCRCD2 MMCRCD1 MMCRCD0
$004E
Write:
(MMCRDR)
Reset:
Read:
$004F
Register Write:
(MMFDR)
Reset:
MMBR2
MMBR1
MMBR0
1
= Unimplemented
Figure 17-1. MMIIC I/O Register Summary
Technical Data
294
MOTOROLA
17.5 Multi-Master IIC System Configuration
The multi-master IIC system uses a serial data line SDA and a serial
clock line SCL for data transfer. All devices connected to it must have
open collector (drain) outputs and the logical-AND function is performed
on both lines by two pull-up resistors.
Normally a standard communication is composed of four parts:
1. START signal,
2. slave address transmission,
3. data transfer, and
4. STOP signal.
These are described briefly in the following sections and illustrated in
Figure 17-2.
9th clock pulse
MSB
SCL
1
1
9th clock pulse
LSB
MSB
1
1
LSB
1
1
SDA
ACK
Data must be stable
when SCL is HIGH
START
signal
MSB
SCL
1
LSB
1
No ACK
STOP
signal
MSB
1
1
LSB
1
1
SDA
ACK
No ACK
Repeated
START
signal
START
signal
STOP
signal
Figure 17-2. Multi-Master IIC Bus Transmission Signal Diagram
MOTOROLA
Technical Data
295
17.6.1 START Signal
When the bus is free, (i.e. no master device is engaging the bus — both
SCL and SDA lines are at logic high) a master may initiate
communication by sending a START signal. As shown in Figure 17-2, a
START signal is defined as a high to low transition of SDA while SCL is
high. This signal denotes the beginning of a new data transfer (each data
transfer may contain several bytes of data) and wakes up all slaves.
The first byte transferred immediately after the START signal is the slave
address transmitted by the master. This is a 7-bit calling address
followed by a R/W-bit. The R/W-bit dictates to the slave the desired
direction of the data transfer. A logic 0 indicates that the master wishes
to transmit data to the slave; a logic 1 indicates that the master wishes
to receive data from the slave.
Only the slave with a matched address will respond by sending back an
acknowledge bit by pulling SDA low on the 9th clock cycle.
(See Figure 17-2.)
Once a successful slave addressing is achieved, the data transfer can
proceed byte by byte in the direction specified by the R/W-bit sent by the
calling master.
Each data byte is 8 bits. Data can be changed only when SCL is low and
must be held stable when SCL is high as shown in Figure 17-2. The
MSB is transmitted first and each byte has to be followed by an
acknowledge bit. This is signalled by the receiving device by pulling the
SDA low on the 9th clock cycle. Therefore, one complete data byte
transfer requires 9 clock cycles.
If the slave receiver does not acknowledge the master, the SDA line
should be left high by the slave. The master can then generate a STOP
signal to abort the data transfer or a START signal (repeated START) to
commence a new transfer.
Technical Data
296
MOTOROLA
If the master receiver does not acknowledge the slave transmitter after
a byte has been transmitted, it means an “end of data” to the slave. The
slave should release the SDA line for the master to generate a STOP or
START signal.
As shown in Figure 17-2, a repeated START signal is used to generate
START signal without first generating a STOP to terminate the
communication. This is used by the master to communicate with another
slave or with the same slave in a different mode (transmit/receive mode)
without releasing the bus.
17.6.5 STOP Signal
The master can terminate the communication by generating a STOP
signal to free the bus. However, the master may generate a START
signal followed by a calling command without first generating a STOP
signal. This is called repeat START. A STOP signal is defined as a low
to high transition of SDA while SCL is at logic high (see Figure 17-2).
The interface circuit is a multi-master system which allows more than
one master to be connected. If two or more masters try to control the bus
at the same time, a clock synchronization procedure determines the bus
clock. The clock low period is equal to the longest clock low period and
the clock high period is equal to the shortest one among the masters. A
data arbitration procedure determines the priority. A master will lose
arbitration if it transmits a logic 1 while another transmits a logic 0. The
losing master will immediately switch over to slave receive mode and
stops its data and clock outputs. The transition from master to slave will
not generate a STOP condition. Meanwhile a software bit will be set by
hardware to indicates loss of arbitration.
MOTOROLA
Technical Data
297
Since wired-AND logic is performed on SCL line, a high to low transition
on the SCL line will affect the devices connected to the bus. The devices
start counting their low period once a device’s clock has gone low, it will
hold the SCL line low until the clock high state is reached. However, the
change of low to high in this device clock may not change the state of the
SCL line if another device clock is still in its low period. Therefore the
synchronized clock SCL will be held low by the device which last
releases SCL to logic high. Devices with shorter low periods enter a high
wait state during this time. When all devices concerned have counted off
their low period, the synchronized SCL line will be released and go high,
and all devices will start counting their high periods. The first device to
complete its high period will again pull the SCL line low. Figure 17-3
illustrates the clock synchronization waveforms.
WAIT
Start counting high period
SCL1
SCL2
SCL
Internal counter reset
Figure 17-3. Clock Synchronization
17.6.8 Handshaking
The clock synchronization mechanism can be used as a handshake in
data transfer. A slave device may hold the SCL low after completion of
one byte data transfer and will halt the bus clock, forcing the master
clock into a wait state until the slave releases the SCL line.
Technical Data
298
MOTOROLA
MMIIC I/O Registers
The packet error code (PEC) for the MMIIC interface is in the form a
cyclic redundancy code (CRC). The PEC is generated by hardware for
every transmitted and received byte of data. The transmission of the
generated PEC is controlled by user software.
The CRC data register, MMCRCDR, contains the generated PEC byte,
with three other bits in the MMIIC control registers and status register
monitoring and controlling the PEC byte.
These I/O registers control and monitor MMIIC operation:
MMIIC address register (MMADR) — $0048
MMIIC control register 1 (MMCR1) — $0049
MMIIC control register 2 (MMCR2) — $004A
MMIIC status register (MMSR) — $004B
MMIIC data transmit register (MMDTR) — $004C
MMIIC data receive register (MMDRR) — $004D
MMIIC CRC data register (MMCRCDR) — $004E
MMIIC frequency divide register (MMFDR) — $004F
Address:
$0048
Bit 7
6
5
4
3
2
1
Bit 0
MMAD7
MMAD6
MMAD5
MMAD4
MMAD3
MMAD2
MMAD1
MMEXTAD
1
Read:
Write:
Reset:
Figure 17-4. MMIIC Address Register (MMADR)
MOTOROLA
Technical Data
299
MMAD[7:1] — Multi-Master Address
These seven bits represent the MMIIC interface’s own specific slave
address when in slave mode, and the calling address when in master
mode. Software must update MMAD[7:1] as the calling address while
entering master mode and restore its own slave address after master
mode is relinquished. This register is cleared as $A0 upon reset.
MMEXTAD — Multi-Master Expanded Address
This bit is set to expand the address of the MMIIC in slave mode.
When set, the MMIIC will acknowledge the following addresses from
a calling master: $MMAD[7:1], 0000000, and 0001100.
Reset clears this bit.
1 = MMIIC responds to the following calling addresses:
0 = MMIIC responds to address $MMAD[7:1]
For example, when MMADR is configured as:
MMAD7 MMAD6 MMAD5 MMAD4 MMAD3 MMAD2 MMAD1 MMEXTAD
1
1
The MMIIC module will respond to the calling address:
Bit 7
6
5
4
3
2
Bit 1
1
1
or the general calling address:
or the calling address:
Bit 7
6
5
4
3
2
Bit 1
1
Note that bit-0 of the 8-bit calling address is the MMRW bit from the
calling master.
Technical Data
300
MOTOROLA
MMIIC I/O Registers
Address:
$0049
Bit 7
6
MMEN
MMIEN
Read:
Write:
Reset:
5
4
2
MMTXAK REPSEN
1
Bit 0
MMCRCBYTE
SDASCL1
MMCLRBB
= Unimplemented
Figure 17-5. MMIIC Control Register 1 (MMCR1)
MMEN — MMIIC Enable
This bit is set to enable the Multi-master IIC module. When
MMEN = 0, module is disabled and all flags will restore to its poweron default states. Reset clears this bit.
1 = MMIIC module enabled
0 = MMIIC module disabled
MMIEN — MMIIC Interrupt Enable
When this bit is set, the MMTXIF, MMRXIF, MMALIF, and MMNAKIF
flags are enabled to generate an interrupt request to the CPU. When
MMIEN is cleared, the these flags are prevented from generating an
interrupt request. Reset clears this bit.
1 = MMTXIF, MMRXIF, MMALIF, and/or MMNAKIF bit set will
generate interrupt request to CPU
0 = MMTXIF, MMRXIF, MMALIF, and/or MMNAKIF bit set will not
MMCLRBB — MMIIC Clear Busy Flag
Writing a logic 1 to this write-only bit clears the MMBB flag.
MMCLRBB always reads as a logic 0. Reset clears this bit.
1 = Clear MMBB flag
0 = No affect on MMBB flag
MOTOROLA
Technical Data
301
MMTXAK — MMIIC Transmit Acknowledge Enable
This bit is set to disable the MMIIC from sending out an acknowledge
signal to the bus at the 9th clock bit after receiving 8 data bits. When
MMTXAK is cleared, an acknowledge signal will be sent at the 9th
clock bit. Reset clears this bit.
1 = MMIIC does not send acknowledge signals at 9th clock bit
0 = MMIIC sends acknowledge signal at 9th clock bit
REPSEN — Repeated Start Enable
This bit is set to enable repeated START signal to be generated when
in master mode transfer (MMAST = 1). The REPSEN bit is cleared by
hardware after the completion of repeated START signal or when the
MMAST bit is cleared. Reset clears this bit.
1 = Repeated START signal will be generated if MMAST bit is set
0 = No repeated START signal will be generated
MMCRCBYTE — MMIIC CRC Byte
In receive mode, this bit is set by software to indicate that the next
receiving byte will be the packet error checking (PEC) data.
In master receive mode, after completion of CRC generation on the
received PEC data, an acknowledge signal is sent if MMTXAK = 0; no
acknowledge is sent If MMTXAK = 1.
In slave receive mode, no acknowledge signal is sent if a CRC error
is detected on the received PEC data. If no CRC error is detected, an
acknowledge signal is sent if MMTXAK = 0; no acknowledge is sent If
MMTXAK = 1.
Under normal operation, the user software should clear MMTXAK bit
before setting MMCRCBYTE bit to ensure that an acknowledge signal
is sent when no CRC error is detected.
The MMCRCBYTE bit should not be set in transmit mode. This bit is
cleared by the next START signal. Reset also clears this bit.
1 = Next receiving byte is the packet error checking (PEC) data
0 = Next receiving byte is not PEC data
Technical Data
302
MOTOROLA
MMIIC I/O Registers
SDASCL1 — SDA and SCL I/O Pin Select
This bit selects either SDA0 and SCL0, or SDA1 and SCL1, for MMIIC
I/O pins when MMIIC module is enabled (MMEN = 1). If the SCI
module is enabled (ENSCI = 0), the SDA1 and SCL1 pins are not
available for MMIIC.
Reset clears SDASCL1 bit.
1 = MMIIC module uses SDA1 and SCL1 I/O pins
0 = MMIIC module uses SDA0 and SCL0 I/O pins
Address:
$004A
Bit 7
6
Write:
Reset:
4
3
MMAST
MMRW
MMBB
1
Bit 0
MMCRCEF
Unaffected
= Unimplemented
Figure 17-6. MMIIC Control Register 2 (MMCR2)
MMALIF — Arbitration Loss Interrupt Flag
This flag is set when software attempt to set MMAST but the MMBB
has been set by detecting the start condition on the lines or when the
MMIIC is transmitting a "1" to SDA line but detected a "0" from SDA
line in master mode — an arbitration loss. This bit generates an
interrupt request to the CPU if the MMIEN bit in MMCR1 is set. This
bit is cleared by writing "0" to it or by reset.
1 = Lost arbitration in master mode
0 = No arbitration lost
MMNAKIF — No AcKnowledge Interrupt Flag (Master Mode)
This flag is only set in master mode (MMAST = 1) when there is no
acknowledge bit detected after one data byte or calling address is
transferred. This flag also clears MMAST. MMNAKIF generates an
interrupt request to CPU if the MMIEN bit in MMCR1 is set. This bit is
1 = No acknowledge bit detected
0 = Acknowledge bit detected
MOTOROLA
Technical Data
303
MMBB — MMIIC Bus Busy Flag
This flag is set after a start condition is detected (bus busy), and is
cleared when a stop condition (bus idle) is detected or the MMIIC is
disabled. Reset clears this bit.
1 = Start condition detected
0 = Stop condition detected or MMIIC is disabled
MMAST — MMIIC Master Control
This bit is set to initiate a master mode transfer. In master mode, the
module generates a start condition to the SDA and SCL lines,
followed by sending the calling address stored in MMADR.
When the MMAST bit is cleared by MMNAKIF set (no acknowledge)
or by software, the module generates the stop condition to the lines
after the current byte is transmitted.
If an arbitration loss occurs (MMALIF = 1), the module reverts to slave
mode by clearing MMAST, and releasing SDA and SCL lines
immediately.
This bit is cleared by writing "0" to it or by reset.
1 = Master mode operation
0 = Slave mode operation
MMRW — MMIIC Master Read/Write
This bit is transmitted out as bit 0 of the calling address when the
module sets the MMAST bit to enter master mode. The MMRW bit
determines the transfer direction of the data bytes that follows. When
it is "1", the module is in master receive mode. When it is "0", the
module is in master transmit mode. Reset clears this bit.
1 = Master mode receive
0 = Master mode transmit
MMCRCEF — MMIIC CRC Error Flag
This flag is set when a CRC error is detected, and cleared when no
CRC error is detected. The MMCRCEF is only meaningful after
receiving a PEC data. This flag is unaffected by reset.
1 = CRC error detected on PEC byte
0 = No CRC error detected on PEC byte
Technical Data
304
MOTOROLA
MMIIC I/O Registers
Address:
$004B
Bit 7
Read: MMRXIF
6
5
4
3
2
1
Bit 0
Write:
Reset:
= Unimplemented
Figure 17-7. MMIIC Status Register (MMSR)
MMRXIF — MMIIC Receive Interrupt Flag
This flag is set after the data receive register (MMDRR) is loaded with
a new received data. Once the MMDRR is loaded with received data,
no more received data can be loaded to the MMDRR register until the
CPU reads the data from the MMDRR to clear MMRXBF flag.
MMRXIF generates an interrupt request to CPU if the MMIEN bit in
MMCR is also set. This bit is cleared by writing "0" to it or by reset; or
when the MMEN = 0.
1 = New data in data receive register (MMDRR)
0 = No data received
MMTXIF — MMIIC Transmit Interrupt Flag
This flag is set when data in the data transmit register (MMDTR) is
downloaded to the output circuit, and that new data can be written to
the MMDTR. MMTXIF generates an interrupt request to CPU if the
MMIEN bit in MMCR is also set. This bit is cleared by writing "0" to it
or when the MMEN = 0.
1 = Data transfer completed
0 = Data transfer in progress
MMATCH — MMIIC Address Match Flag
This flag is set when the received data in the data receive register
(MMDRR) is a calling address which matches with the address or its
extended addresses (MMEXTAD = 1) specified in the address
register (MMADR). The MMATCH flag is set at the 9th clock of the
calling address and will be cleared on the 9th clock of the next
receiving data. Note: slave transmits do not clear MMATCH.
MOTOROLA
Technical Data
305
1 = Received address matches MMADR
0 = Received address does not match
MMSRW — MMIIC Slave Read/Write Select
This bit indicates the data direction when the module is in slave mode.
It is updated after the calling address is received from a master
device. MMSRW = 1 when the calling master is reading data from the
module (slave transmit mode). MMSRW = 0 when the master is
writing data to the module (receive mode).
1 = Slave mode transmit
0 = Slave mode receive
MMRXAK — MMIIC Receive Acknowledge
When this bit is cleared, it indicates an acknowledge signal has been
received after the completion of eight data bits transmission on the
bus. When MMRXAK is set, it indicates no acknowledge signal has
been detected at the 9th clock; the module will release the SDA line
for the master to generate STOP or repeated START condition. Reset
sets this bit.
1 = No acknowledge signal received at 9th clock
0 = Acknowledge signal received at 9th clock
MMCRCBF — CRC Data Buffer Full Flag
This flag is set when the CRC data register (MMCRCDR) is loaded
with a CRC byte for the current received or transmitted data.
In transmit mode, after a byte of data has been sent (MMTXIF = 1),
the MMCRCBF will be set when the CRC byte has been generated
and ready in the MMCRCDR. The content of the MMCRCDR should
be copied to the MMDTR for transmission.
In receive mode, the MMCRCBF is set when the CRC byte has been
generated and ready in MMCRCDR, for the current byte of received
data.
The MMCRCBF bit is cleared when the CRC data register is read.
1 = Data ready in CRC data register (MMCRCDR)
0 = Data not ready in CRC data register (MMCRCDR)
Technical Data
306
MOTOROLA
MMIIC I/O Registers
MMTXBE — MMIIC Transmit Buffer Empty
This flag indicates the status of the data transmit register (MMDTR).
When the CPU writes the data to the MMDTR, the MMTXBE flag will
be cleared. MMTXBE is set when MMDTR is emptied by a transfer of
its data to the output circuit. Reset sets this bit.
1 = Data transmit register empty
0 = Data transmit register full
MMRXBF — MMIIC Receive Buffer Full
This flag indicates the status of the data receive register (MMDRR).
When the CPU reads the data from the MMDRR, the MMRXBF flag
will be cleared. MMRXBF is set when MMDRR is full by a transfer of
data from the input circuit to the MMDRR. Reset clears this bit.
1 = Data receive register full
0 = Data receive register empty
Address:
$004C
Bit 7
6
5
4
3
2
1
Bit 0
MMTD7
MMTD6
MMTD5
MMTD4
MMTD3
MMTD2
MMTD1
MMTD0
Read:
Write:
Reset:
Figure 17-8. MMIIC Data Transmit Register (MMDTR)
When the MMIIC module is enabled, MMEN = 1, data written into this
register depends on whether module is in master or slave mode.
In slave mode, the data in MMDTR will be transferred to the output circuit
when:
the module detects a matched calling address (MMATCH = 1),
with the calling master requesting data (MMSRW = 1); or
the previous data in the output circuit has be transmitted and the
receiving master returns an acknowledge bit, indicated by a
received acknowledge bit (MMRXAK = 0).
MOTOROLA
Technical Data
307
If the calling master does not return an acknowledge bit (MMRXAK = 1),
the module will release the SDA line for master to generate a STOP or
repeated START condition. The data in the MMDTR will not be
transferred to the output circuit until the next calling from a master. The
transmit buffer empty flag remains cleared (MMTXBE = 0).
In master mode, the data in MMDTR will be transferred to the output
circuit when:
the module receives an acknowledge bit (MMRXAK = 0), after
setting master transmit mode (MMRW = 0), and the calling
address has been transmitted; or
receiving slave returns an acknowledge bit, indicated by a
If the slave does not return an acknowledge bit (MMRXAK = 1), the
master will generate a STOP or repeated START condition. The data in
the MMDTR will not be transferred to the output circuit. The transmit
The sequence of events for slave transmit and master transmit are
illustrated in Figure 17-12.
Address:
$004D
Bit 7
Read: MMRD7
6
5
4
3
2
1
Bit 0
MMRD6
MMRD5
MMRD4
MMRD3
MMRD2
MMRD1
MMRD0
Write:
Reset:
= Unimplemented
Figure 17-9. MMIIC Data Receive Register (MMDRR)
When the MMIIC module is enabled, MMEN = 1, data in this read-only
In slave mode, the data in MMDRR is:
Technical Data
308
MOTOROLA
MMIIC I/O Registers
the calling address from the master when the address match flag
is set (MMATCH = 1); or
the last data received when MMATCH = 0.
In master mode, the data in the MMDRR is:
the last data received.
When the MMDRR is read by the CPU, the receive buffer full flag is
cleared (MMRXBF = 0), and the next received data is loaded to the
MMDRR. Each time when new data is loaded to the MMDRR, the
MMRXIF interrupt flag is set, indicating that new data is available in
MMDRR.
The sequence of events for slave receive and master receive are
Address:
$004E
Bit 7
6
5
4
3
2
1
Bit 0
Write:
Reset:
= Unimplemented
Figure 17-10. MMIIC CRC Data Register (MMCRCDR)
When the MMIIC module is enabled, MMEN = 1, and the CRC buffer full
flag is set (MMCRCBF = 1), data in this read-only register contains the
generated CRC byte for the last byte of received or transmitted data.
A CRC byte is generated for each received and transmitted data byte
and loaded to the CRC data register. The MMCRCBF bit will be set to
indicate the CRC byte is ready in the CRC data register.
Reading the CRC data register clears the MMCRCBF bit. If the CRC
data register is not read, the MMCRCBF bit will be cleared by hardware
before the next CRC byte is loaded.
MOTOROLA
Technical Data
309
Address:
Read:
$004F
Bit 7
6
5
4
3
1
Bit 0
MMBR2
MMBR1
MMBR0
1
Write:
Reset:
= Unimplemented
Figure 17-11. MMIIC Frequency Divider Register (MMFDR)
The three bits in the frequency divider register (MMFDR) selects the
divider to divide the bus clock to the desired baud rate for the MMIIC data
transfer.
Table 17-2 shows the divider values for MMBR[2:0].
Table 17-2. MMIIC Baud Rate Selection
MMIIC Baud Rates for Bus Clocks:
MMBR2
MMBR1
Divider
8MHz
4MHz
2MHz
1MHz
400kHz
200kHz
100kHz
50kHz
40
200kHz
100kHz
50kHz
25kHz
100kHz
50kHz
25kHz
12.5kHz
1
160
50kHz
25kHz
12.5kHz
6.25kHz
1
25kHz
12.5kHz
6.25kHz
3.125kHz
1
640
12.5kHz
6.25kHz
3.125kHz
1.5625kHz
1
1
6.25kHz
3.125kHz
1.5625kHz
0.78125kHz
1
1
1
2560
3.125kHz
1.5625kHz
0.78125kHz
0.3906kHz
NOTE:
Technical Data
310
MMBR0
The frequency of the MMIIC baud rate is only guaranteed for 100kHz to
10kHz. The divider is available for the flexibility on bus frequency
selection.
MOTOROLA
Program Algorithm
When the MMIIC module detects an arbitration loss in master mode, it
releases both SDA and SCL lines immediately. But if there are no further
STOP conditions detected, the module will hang up. Therefore, it is
recommended to have time-out software to recover from this condition.
The software can start the time-out counter by looking at the MMBB (bus
busy) flag and reset the counter on the completion of one byte
transmission. If a time-out has occurred, software can clear the MMEN
bit (disable MMIIC module) to release the bus, and hence clear the
MMBB flag. This is the only way to clear the MMBB flag by software if
the module hangs up due to a no STOP condition received. The MMIIC
can resume operation again by setting the MMEN bit.
MOTOROLA
Technical Data
311
(a) Master Transmit Mode
START
Address
ACK
TX Data1
MMTXBE=1
MMTXIF=1
Data2 → MMDTR
MMTXBE=0
MMRW=0
MMAST=1
Data1 → MMDTR
ACK
MMTXBE=1
MMTXIF=1
Data3 → MMDTR
TX DataN
ACK
STOP
MMTXBE=1 MMNAKIF=1
MMTXIF=1 MMAST=0
DataN+2 → MMDTR MMTXBE=0
(b) Master Receive Mode
START
Address
1
ACK
RX Data1
ACK
Data1 → MMDRR
MMRXIF=1
MMRXBF=1
MMRXBF=0
MMRW=1
MMAST=1
MMTXBE=0
(dummy data → MMDTR)
RX DataN
NAK
STOP
DataN → MMDRR MMNAKIF=1
MMRXIF=1 MMAST=0
MMRXBF=1
(c) Slave Transmit Mode
START
Address
1
ACK
TX Data1
MMRXIF=1
MMRXBF=1
MMATCH=1
MMSRW=1
Data1 → MMDTR
MMTXBE=1
MMRXBF=0
ACK
MMTXBE=1
MMTXIF=1
Data2 → MMDTR
TX DataN
NAK
STOP
MMTXBE=1 MMNAKIF=1
MMTXIF=1 MMTXBE=0
DataN+2 → MMDTR
(d) Slave Receive Mode
START
MMTXBE=0
MMRXBF=0
Address
ACK
RX Data1
MMRXIF=1
MMRXBF=1
MMATCH=1
MMSRW=0
ACK
Data1 → MMDRR
MMRXIF=1
MMRXBF=1
RX DataN
ACK
STOP
DataN → MMDRR
MMRXIF=1
MMRXBF=1
Shaded data packets indicate transmissions by the MCU
Figure 17-12. Data Transfer Sequences for Master/Slave Transmit/Receive Modes
Technical Data
312
MOTOROLA
17.9 SMBus Protocols with PEC and without PEC
Following is a description of the various MMIIC bus protocols with and
without a packet error code (PEC).
17.9.1 Quick Command
1
7
1
1
1
Slave Address RW ACK
START
Master to Slave
STOP
Start Condition
Slave to Master
Stop Condition
Command Bit
Acknowledge
Figure 17-13. Quick Command
17.9.2 Send Byte
START
Slave Address
W
ACK
Command Code
ACK
W
ACK
Command Code
ACK
STOP
(a) Send Byte Protocol
START
Slave Address
PEC
ACK
STOP
NAK
STOP
(b) Send Byte Protocol with PEC
Figure 17-14. Send Byte
17.9.3 Receive Byte
START
Slave Address
R
ACK
Data Byte
NAK
R
ACK
Data Byte
ACK
STOP
(a) Receive Byte Protocol
START
Slave Address
PEC
(b) Receive Byte Protocol with PEC
Figure 17-15. Receive Byte
MOTOROLA
Technical Data
313
17.9.4 Write Byte/Word
START
Slave Address
W ACK
Command Code
ACK
Data Byte
ACK
W ACK
Command Code
ACK
Data Byte
ACK
PEC
ACK
STOP
W ACK
Command Code
ACK
Data Byte Low
ACK
Data Byte High
ACK
STOP
W ACK
Command Code
ACK
Data Byte Low
ACK
Data Byte High
ACK
STOP
(a) Write Byte Protocol
START
Slave Address
(b) Write Byte Protocol with PEC
START
Slave Address
(c) Write Word Protocol
START
Slave Address
PEC
ACK
STOP
(d) Write Word Protocol with PEC
Figure 17-16. Write Byte/Word
17.9.5 Read Byte/Word
START
Slave Address
W ACK
Command Code
ACK
START
Slave Address
R
ACK
Data Byte
NAK
W ACK
Command Code
ACK
START
Slave Address
R
ACK
Data Byte
ACK
Command Code
ACK
START
Slave Address
R
ACK
Data Byte Low
ACK
Command Code
ACK
START
Slave Address
R
ACK
Data Byte Low
ACK
STOP
(a) Read Byte Protocol
START
Slave Address
PEC
NAK
STOP
(b) Read Byte Protocol with PEC
START
Slave Address
Data Byte High
NAK
W ACK
STOP
(c) Read Word Protocol
START
Slave Address
Data Byte High
ACK
W ACK
PEC
NAK
STOP
(d) Read Word Protocol with PEC
Figure 17-17. Read Byte/Word
Technical Data
314
MOTOROLA
17.9.6 Process Call
START
Slave Address
W ACK
START
Slave Address
R
START
Slave Address
W ACK
START
Slave Address
R
ACK
Command Code
ACK
Data Byte Low
ACK
Data Byte Low
ACK
Data Byte High
NAK
Command Code
ACK
Data Byte Low
ACK
Data Byte Low
ACK
Data Byte High
ACK
Data Byte High
ACK
STOP
(a) Process Call
ACK
Data Byte High
ACK
PEC
STOP
NAK
STOP
(b) Process Call with PEC
Figure 17-18. Process Call
17.9.7 Block Read/Write
START
Slave Address
Data Byte 2
ACK
W ACK
Command Code
Data Byte N
ACK
ACK
Byte Count = N
ACK
Data Byte 1
ACK
ACK
Data Byte 1
ACK
R
ACK
Byte Count = N
ACK
R
ACK
Byte Count = N
ACK
STOP
(a) Block Read
START
Slave Address
Data Byte 2
ACK
W ACK
Command Code
Data Byte N
ACK
Byte Count = N
PEC
ACK
ACK
STOP
(b) Block Read with PEC
START
Slave Address
Data Byte 1
ACK
W ACK
Command Code
Data Byte 2
ACK
ACK
START
Data Byte N
Slave Address
NAK
STOP
(c) Block Write
START
Slave Address
Data Byte 1
ACK
W ACK
Command Code
Data Byte 2
ACK
ACK
START
Data Byte N
Slave Address
ACK
PEC
NAK
STOP
(d) Block Write with PEC
Figure 17-19. Block Read/Write
MOTOROLA
Technical Data
315
MASTER MODE
START
Address
0 ACK
Command
ACK START
Address
1 ACK
RX Data1
ACK
ACK
RX DataN
NAK STOP
OPERATION:
Prepare for repeated START
OPERATION:
Get ready to receive data
OPERATION:
Read received data
OPERATION:
Generate STOP
FLAGS:
MMTXIF set
MMRXAK clear
FLAGS:
MMTXIF set
MMRXAK clear
FLAGS:
MMRXIF set
FLAGS:
MMRXIF set
ACTION:
1. Set MMRW
2. Set REPSEN
3. Clear MMTXAK
4. Load dummy ($FF) to MMDTR
ACTION:
ACTION:
Read Data1 from MMDRR
ACTION:
Read DataN from MMDRR
OPERATION:
Read received data and prepare for STOP
OPERATION:
Prepare for Master mode
FLAGS:
MMRXIF set
ACTION:
1. Load slave address to MMADR
2. Clear MMRW
3. Load command to MMDTR
4. Set MMAST
ACTION:
1. Set MMTXAK
2. Read Data(N-1) from MMDRR
3. Clear MMAST
SLAVE MODE
START
Address
0 ACK
Command
ACK START
Address
1 ACK
OPERATION:
Slave address match and
check for data direction
OPERATION:
get ready to transmit data
FLAGS:
MMRXIF set
MMATCH set
MMSRW depends on 8th
bit of calling address byte
ACTION:
1. Check MMSRW
2. Read Slave address
FLAGS:
MMRXIF set
MMATCH set
OPERATION:
Prepare for Slave mode
ACTION:
2. Clear MMTXAK
3. Clear MMAST
TX Data1
ACK
ACK
TX DataN
NAK STOP
OPERATION:
Transmit data
OPERATION:
Last data sent
FLAGS:
MMTXIF set
MMRXAK clear
FLAGS:
MMTXIF set
MMRXAK set
ACTION:
Load Data3 to MMDTR
ACTION:
ACTION:
Check MMSRW
OPERATION:
Read and decode received command
FLAGS:
MMRXIF set
MMATCH clear
ACTION:
Load Data1 to MMDTR
OPERATION:
Transmit data
OPERATION:
Last data is going to be sent
FLAGS:
MMTXIF set
FLAGS:
MMTXIF set
MMRXAK clear
ACTION:
Load Data2 to MMDTR
ACTION:
Figure 17-20. SMBus Protocol Implementation
Technical Data
316
MOTOROLA
Section 18. Input/Output (I/O) Ports
18.1 Contents
18.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 317
18.3 Port A . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 320
18.3.1 Port A Data Register (PTA) . . . . . . . . . . . . . . . . . . . . . . . . 320
18.3.2 Data Direction Register A (DDRA) . . . . . . . . . . . . . . . . . . . 321
18.3.3 Port A LED Control Register (LEDA) . . . . . . . . . . . . . . . . . 323
18.4 Port B . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 323
18.4.1 Port B Data Register (PTB) . . . . . . . . . . . . . . . . . . . . . . . . 324
18.4.2 Data Direction Register B (DDRB) . . . . . . . . . . . . . . . . . . . 325
18.5 Port C . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 327
18.5.1 Port C Data Register (PTC) . . . . . . . . . . . . . . . . . . . . . . . . 327
18.5.2 Data Direction Register C (DDRC). . . . . . . . . . . . . . . . . . . 329
18.5.3 Port C LED Control Register (LEDC) . . . . . . . . . . . . . . . . . 330
18.6 Port D . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 331
18.6.1 Port D Data Register (PTD) . . . . . . . . . . . . . . . . . . . . . . . . 331
18.6.2 Data Direction Register D (DDRD). . . . . . . . . . . . . . . . . . . 332
18.2 Introduction
Thirty-one (31) bidirectional input-output (I/O) pins form four parallel
ports. All I/O pins are programmable as inputs or outputs.
NOTE:
Connect any unused I/O pins to an appropriate logic level, either VDD or
VSS. Although the I/O ports do not require termination for proper
operation, termination reduces excess current consumption and the
possibility of electrostatic damage.
MOTOROLA
Technical Data
317
Addr.
Register Name
$0000
Read:
Write:
(PTA)
Reset:
$0001
$0002
$0003
Read:
Write:
(PTB)
Reset:
Read:
Write:
(PTC)
Reset:
Read:
Write:
(PTD)
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
PTA7
PTA6
PTA5
PTA4
PTA3
PTA2
PTA1
PTA0
PTB2
PTB1
PTB0
PTC2
PTC1
PTC0
PTD2
PTD1
PTD0
Unaffected by reset
PTC7
PTD7
$000D
Read:
Port-C LED Control
Register Write:
(LEDC)
Reset:
PTB3
PTC6
PTC5
PTC4
PTC3
PTD6
PTD5
PTD4
PTD3
Unaffected by reset
Read:
DDRD7
$0007
Write:
(DDRD)
Reset:
$000C
PTB4
Unaffected by reset
Read:
DDRC7
$0006
Write:
(DDRC)
Reset:
Read:
Port-A LED Control
Register Write:
(LEDA)
Reset:
PTB5
Unaffected by reset
Read:
DDRA7
$0004
Write:
(DDRA)
Reset:
Read:
$0005
Write:
(DDRB)
Reset:
PTB6
DDRA6
DDRA5
DDRA4
DDRA3
DDRA2
DDRA1
DDRA0
DDRB6
DDRB5
DDRB4
DDRB3
DDRB2
DDRB1
DDRB0
DDRC6
DDRC5
DDRC4
DDRC3
DDRC2
DDRC1
DDRC0
DDRD6
DDRD5
DDRD4
DDRD3
DDRD2
DDRD1
DDRD0
LEDA5
LEDA4
LEDA3
LEDA2
LEDA1
LEDA0
LEDC7
LEDC6
LEDC5
LEDC4
LEDC3
Figure 18-1. I/O Port Register Summary
Technical Data
318
MOTOROLA
Introduction
Table 18-1. Port Control Register Bits Summary
Port
A
B
Module Control
Bit
DDR
DDRA0
PTA0/ATD2
1
DDRA1
PTA1/ATD3
2
DDRA2
3
DDRA3
4
DDRA4
PTA4/ATD6
5
DDRA5
PTA5/ATD7
6
DDRA6
7
DDRA7
DDRB0
1
DDRB1
2
Module
ADC
Register
ADSCR ($0057)
Control Bit
ADCH[4:0]
Pin
PTA2/ATD4
PTA3/ATD5
T1SC0 ($0025)
ELS0B:ELS0A
PTA6/T1CH0
T1SC1 ($0028)
ELS1B:ELS1A
PTA7/T1CH1
MBUS
MMCR1 ($0049)
MMEN
SDASCL1
DDRB2
SCI
SCC1 ($0013)(2)
ENSCI
PTB2/SDA1/TxD(1)
3
DDRB3
MBUS
MMCR1 ($0049)
MMEN
SDASCL1
PTB3/SCL1/RxD(1)
4
DDRB4
T2SC0 ($0030)
ELS0B:ELS0A
PTB4/T2CH0
5
DDRB5
T2SC1 ($0033)
ELS1B:ELS1A
PTB5/T2CH1
6
DDRB6
PTB6/IRQ2
DDRC0
TIM1
TIM2
IRQ
ANALOG
CONFIG2
($001D)(1)
CDOEN
PTB0/SDA0(1)
PTB1/SCL0(1)
PTC0/PWM0/CD
PCH0
C
D
1
DDRC1
PWM
2
DDRC2
3
DDRC3
PTC3/ATD8
4
DDRC4
PTC4/ATD9
5
DDRC5
6
DDRC6
PTC6/ATD11
7
DDRC7
PTC7/ATD12
DDRD0
KBIE0
PTD0/KBI0
1
DDRD1
KBIE1
PTD1/KBI1
2
DDRD2
KBIE2
PTD2/KBI2
3
DDRD3
KBIE3
PTD3/KBI3
4
DDRD4
KBIE4
PTD4/KBI4
5
DDRD5
KBIE5
PTD5/KBI5
6
DDRD6
KBIE6
PTD6/KBI6
7
DDRD7
KBIE7
PTD7/KBI7
ADC
KBI
PWMCR ($0051)
ADSCR ($0057)
KBIER ($001B)
PCH1
PTC1/PWM1
PCH2
PTC2/PWM2
ADCH[4:0]
PTC5/ATD10
Notes:
1. Pins are open-drain when configured as outputs. Pullup resistors must be connected when configured as outputs.
2. Register has the highest priority control on port pin.
MOTOROLA
Technical Data
319
18.3 Port A
Port A is an 8-bit special function port that shares six of its port pins with
the analog-to-digital converter (ADC) module and two of its port pins with
the timer interface module 1 (TIM1). See Section 15. Analog-to-Digital
Converter (ADC) and Section 11. Timer Interface Module (TIM).
PTA5–PTA0 pins can be configured for direct LED drive.
The port A data register contains a data latch for each of the eight port A
pins.
Address:
$0000
Bit 7
6
5
4
3
2
1
Bit 0
PTA7
PTA6
PTA5
PTA4
PTA3
PTA2
PTA1
PTA0
ATD4
ATD3
ATD2
Read:
Write:
Reset:
Alternative Function:
Additional Function:
Unaffected by Reset
T1CH1
T1CH0
ATD7
ATD6
ATD5
LED drive LED drive LED drive LED drive LED drive LED drive
Figure 18-2. Port A Data Register (PTA)
PTA[7:0] — Port A Data Bits
These read/write bits are software programmable. Data direction of
each port A pin is under the control of the corresponding bit in data
direction register A. Reset has no effect on port A data.
ATD[7:2] — ADC channels 2 to 7
ATD[7:2] are pins used for the input channels to the analog-to-digital
converter module. The channel select bits, ADCH[4:0], in the ADC
status and control register define which port pin will be used as an
ADC input and overrides any control from the port I/O logic. See
Section 14. Analog Module.
Technical Data
320
MOTOROLA
Port A
T1CH[1:0] — Timer 1 Channel I/O Bits
The T1CH1 and T1CH0 pins are the TIM1 input capture/output
compare pins. The edge/level select bits, ELSxB:ELSxA, determine
whether the PTA7/T1CH1 and PTA6/T1CH0 pins are timer channel
I/O pins or general-purpose I/O pins. See Section 11. Timer
NOTE:
Care must be taken when reading port A while applying analog voltages
to ATD[7:2] pins. If the appropriate ADC channel is not enabled,
excessive current drain may occur if analog voltages are applied to the
PTAx/ATDx pin, while PTA is read as a digital input. Those ports not
selected as analog input channels are considered digital I/O ports.
LED drive — Direct LED drive Pins
PTA5–PTA0 pins can be configured for direct LED drive. See 18.3.3
Port A LED Control Register (LEDA).
Data direction register A determines whether each port A pin is an input
or an output. Writing a logic 1 to a DDRA bit enables the output buffer for
the corresponding port A pin; a logic 0 disables the output buffer.
Address:
$0004
Bit 7
6
5
4
3
2
1
Bit 0
DDRA7
DDRA6
DDRA5
DDRA4
DDRA3
DDRA2
DDRA1
DDRA0
Read:
Write:
Reset:
Figure 18-3. Data Direction Register A (DDRA)
DDRA[7:0] — Data Direction Register A Bits
These read/write bits control port A data direction. Reset clears
DDRA[7:0], configuring all port A pins as inputs.
1 = Corresponding port A pin configured as output
0 = Corresponding port A pin configured as input
MOTOROLA
Technical Data
321
NOTE:
Avoid glitches on port A pins by writing to the port A data register before
changing data direction register A bits from 0 to 1. Figure 18-4 shows
the port A I/O logic.
READ DDRA ($0004)
INTERNAL DATA BUS
WRITE DDRA ($0004)
RESET
DDRAx
WRITE PTA ($0000)
PTAx
PTAx
READ PTA ($0000)
Figure 18-4. Port A I/O Circuit
When DDRAx is a logic 1, reading address $0000 reads the PTAx data
latch. When DDRAx is a logic 0, reading address $0000 reads the
voltage level on the pin. The data latch can always be written, regardless
of the state of its data direction bit.
Table 18-2 summarizes the operation of the port A pins.
Table 18-2. Port A Pin Functions
Accesses to DDRA
DDRA
Bit
PTA Bit
X(1)
1
X
Accesses to PTA
I/O Pin Mode
Read/Write
Read
Write
Input, Hi-Z(2)
DDRA[7:0]
Pin
PTA[7:0](3)
Output
DDRA[7:0]
PTA[7:0]
PTA[7:0]
Notes:
1. X = don’t care.
2. Hi-Z = high impedance.
3. Writing affects data register, but does not affect input.
Technical Data
322
MOTOROLA
Port B
The port-A LED control register (LEDA) controls the direct LED drive
capability on PTA5–PTA0 pins. Each bit is individually configurable and
requires that the data direction register, DDRD, bit be configured as an
output.
Address:
Read:
$000C
Bit 7
6
4
3
2
1
Bit 0
LEDA5
LEDA4
LEDA3
LEDA2
LEDA1
LEDA0
Write:
Reset:
Figure 18-5. Port A LED Control Register (LEDA)
LEDA[5:0] — Port A LED Drive Enable Bits
These read/write bits are software programmable to enable the direct
LED drive on an output port pin.
1 = Corresponding port A pin configured for direct LED drive
0 = Corresponding port A pin configured for standard drive
18.4 Port B
Port B is a 7-bit special function port that shares four of its port pins with
the multi-master IIC (MMIIC) interface module, two of its port pins with
the serial communications interface (SCI) module, two of its port pins
with the timer interface module 2 (TIM2), and one of its port pins with the
IRQ module. See Section 17. Multi-Master IIC Interface (MMIIC),
Section 16. Serial Communications Interface (SCI), Section 11.
Timer Interface Module (TIM), and Section 19. External Interrupt
(IRQ).
NOTE:
PTB3–PTB0 are open-drain pins when configured as outputs regardless
whether the pins are used as general purpose I/O pins, MMIIC pins, or
SCI pins. Therefore, when configured as general purpose output pins,
MMIIC pins, or SCI pins (the TxD pin), pullup resistors must be
MOTOROLA
Technical Data
323
The port B data register contains a data latch for each of the eight port B
pins.
Address:
$0001
Bit 7
Read:
6
5
4
3
2
1
Bit 0
PTB6
PTB5
PTB4
PTB3
PTB2
PTB1
PTB0
SCL0
SDA0
Write:
Reset:
Alternative Functions:
Unaffected by reset
IRQ2
T2CH1
RxD
TxD
SCL1
SDA1
T2CH0
These four pins are open-drain when configured as
output pins. Pullup resistors must be connected
Figure 18-6. Port B Data Register (PTB)
PTB[6:0] — Port B Data Bits
each port B pin is under the control of the corresponding bit in data
direction register B. Reset has no effect on port B data.
SDA0, SCL0, SDA1, SCL1 — MMIIC Channels 1 and 2
SDAx and SCLx are the data and clock lines for the MMIIC module.
The multi-master enable bit, MMEN, and the MMIIC channel select
bit, SDASCL1, in the MMIIC control register 1 determine whether the
PTB0/SDA0, PTB1/SCL0, PTB2/SDA1/TxD, and PTB3/SCL1/RxD
pins are MMIIC I/O pins or general purpose I/O pins. See Section 17.
Multi-Master IIC Interface (MMIIC).
TxD, RxD — SCI Data I/O Pins
The TxD and RxD pins are the transmit data output and receive data
input for the SCI module. The enable SCI bit, ENSCI, in the SCI
control register 1 enables the PTB2/SDA1/TxD and PTB3/SCL1/RxD
pins as SCI TxD and RxD pins and overrides any control from the port
I/O or MMIIC logic. See Section 16. Serial Communications
Interface (SCI).
Technical Data
324
MOTOROLA
Port B
Table 18-3. PTB2 and PTB3 Pin Configurations
ENSCI
Bit
($0013)
MMEN
Bit
($0049)
SDASCL1
Bit
($0049)
Pin function
X
PTB2, PTB3
PTB2/SDA1/TxD
PTB2, PTB3
PTB3/SCL1/RxD
1
SDA1, SCL1
1
X
X
TxD, RxD
Pin
T2CH[1:0] — Timer 2 Channel I/O Bits
The T2CH1 and T2CH0 pins are the TIM2 input capture/output
whether the PTB5/T2CH1 and PTB4/T2CH0 pins are timer channel
I/O pins or general-purpose I/O pins.See Section 11. Timer
IRQ2 — External Interrupt Pin 2
IRQ2 pin is the second external interrupt input to the IRQ module.
When PTB6/IRQ2 is configured as an input by the data direction bit
bit, DDRB6, the pin is both a standard port input pin and an external
interrupt pin. See Section 19. External Interrupt (IRQ).
Data direction register B determines whether each port B pin is an input
or an output. Writing a logic 1 to a DDRB bit enables the output buffer for
the corresponding port B pin; a logic 0 disables the output buffer.
Address:
$0005
Bit 7
Read:
6
5
4
3
2
1
Bit 0
DDRB6
DDRB5
DDRB4
DDRB3
DDRB2
DDRB1
DDRB0
Write:
Reset:
Figure 18-7. Data Direction Register B (DDRB)
MOTOROLA
Technical Data
325
DDRB[6:0] — Data Direction Register B Bits
These read/write bits control port B data direction. Reset clears
DDRB[6:0], configuring all port B pins as inputs.
1 = Corresponding port B pin configured as output
0 = Corresponding port B pin configured as input
NOTE:
Avoid glitches on port B pins by writing to the port B data register before
changing data direction register B bits from 0 to 1. Figure 18-8 shows
the port B I/O logic.
READ DDRB ($0005)
INTERNAL DATA BUS
WRITE DDRB ($0005)
RESET
DDRBx
WRITE PTB ($0001)
PTBx #
PTBx
READ PTB ($0001)
# PTB3–PTB0 are open-drain pins when configured as outputs.
Figure 18-8. Port B I/O Circuit
When DDRBx is a logic 1, reading address $0001 reads the PTBx data
latch. When DDRBx is a logic 0, reading address $0001 reads the
Table 18-4 summarizes the operation of the port B pins.
Table 18-4. Port B Pin Functions
Accesses to DDRB
DDRB
Bit
PTB Bit
X(1)
1
X
Accesses to PTB
I/O Pin Mode
Read/Write
Read
Write
Input, Hi-Z(2)
DDRB[6:0]
Pin
PTB[6:0](3)
Output
DDRB[6:0]
PTB[6:0]
PTB[6:0]
Notes:
1. X = don’t care.
Technical Data
326
MOTOROLA
Port C
18.5 Port C
Port C is an 8-bit special function port that shares three of its port pins
with the pulse width modulator module, five of its port pins with the
analog-to-digital converter module, and one of its pins with the analog
module. See Section 13. Pulse Width Modulator (PWM), Section 15.
Analog-to-Digital Converter (ADC), and Section 14. Analog Module.
PTC7–PTC3 pins can be configured for direct LED drive.
The port C data register contains a data latch for each of the six port C
pins.
NOTE:
Bit 7 and bit 6 of PTC are not available in a 42-pin shrink dual in-line
package.
Address:
$0002
Bit 7
6
5
4
3
2
1
Bit 0
PTC7
PTC6
PTC5
PTC4
PTC3
PTC2
PTC1
PTC0
PWM2
PWM1
PWM0
Read:
Write:
Reset:
Unaffected by reset
ATD12
ATD11
ATD10
ATD9
ATD8
CD
Additional Function: LED drive LED drive LED drive LED drive LED drive
Figure 18-9. Port C Data Register (PTC)
PTC[7:0] — Port C Data Bits
each port C pin is under the control of the corresponding bit in data
direction register C. Reset has no effect on port C data.
MOTOROLA
Technical Data
327
PWM[2:0] — PWM Channels 0 to 2
PWM[2:0] are pins used for the output channels from the pulse width
modulator (PWM) module. The PWM enables bit, PCH[2:0], in the
PWM control register define which port pin will be used as a PWM
output and overrides any control from the port I/O logic. The PWM0
function on PCT0/PWM0/CD pin can be overrided by the CD output
function. See Section 13. Pulse Width Modulator (PWM).
ATD[12:8] — ADC channels 8 to 12
ATD[12:8] are pins used for the input channels to the analog-to-digital
Section 15. Analog-to-Digital Converter (ADC).
NOTE:
Care must be taken when reading port C while applying analog voltages
to ATD[12:8] pins. If the appropriate ADC channel is not enabled,
PTCx/ATDx pin, while PTC is read as a digital input. Those ports not
CD — Current Detect Output Pin
The CD pin is used for the current detect output from the analog
module. The pin reflects the status of the current detect interrupt flag.
The current detect output enable bit, CDOEN, in the configuration
register 2 enables the PTC0/PWM0/CD pin as the CD output pin and
overrides any control from the port I/O or PWM logic. See Section 14.
Analog Module.
Table 18-5. PTC0 Pin Configuration
Pin
PTC0/PWM0/CD
CDOEN Bit
($001D)
PCH0 Bit
($0051)
Pin function
PTC0
PWM0
1
X
CD
PTC7–PTC3 pins can be configured for direct LED drive. See 18.5.3
Port C LED Control Register (LEDC).
Technical Data
328
MOTOROLA
Port C
Data direction register C determines whether each port C pin is an input
or an output. Writing a logic 1 to a DDRC bit enables the output buffer for
the corresponding port C pin; a logic 0 disables the output buffer.
Address:
$0006
Bit 7
6
5
4
3
2
1
Bit 0
DDRC7
DDRC6
DDRC5
DDRC4
DDRC3
DDRC2
DDRC1
DDRC0
Read:
Write:
Reset:
Figure 18-10. Data Direction Register B (DDRB)
DDRC[7:0] — Data Direction Register C Bits
These read/write bits control port C data direction. Reset clears
DDRC[7:0], configuring all port C pins as inputs.
1 = Corresponding port C pin configured as output
0 = Corresponding port C pin configured as input
NOTE:
Avoid glitches on port C pins by writing to the port C data register before
changing data direction register C bits from 0 to 1. Figure 18-11 shows
the port C I/O logic.
NOTE:
For those devices packaged in a 42-pin shrink dual in-line package,
PTC6 and PTC7 are not connected. DDRC6 and DDRC7 should be set
to a 1 to configure PTC6 and PTC7 as outputs.
READ DDRC ($0006)
INTERNAL DATA BUS
WRITE DDRC ($0006)
RESET
DDRCx
WRITE PTC ($0002)
PTCx
PTCx
READ PTC ($0002)
Figure 18-11. Port C I/O Circuit
MOTOROLA
Technical Data
329
When DDRCx is a logic 1, reading address $0002 reads the PTCx data
latch. When DDRCx is a logic 0, reading address $0002 reads the
Table 18-6 summarizes the operation of the port C pins.
Table 18-6. Port C Pin Functions
DDRC
Bit
Accesses to DDRC
PTC Bit
X
1
(1)
Accesses to PTC
I/O Pin Mode
Input, Hi-Z
X
(2)
Output
Read/Write
Read
Write
DDRC[7:0]
Pin
PTC[7:0](3)
DDRC[7:0]
PTC[7:0]
PTC[7:0]
Notes:
1. X = don’t care.
The port-C LED control register (LEDC) controls the direct LED drive
capability on PTC7–PTC3 pins. Each bit is individually configurable and
output.
Address:
$000D
Bit 7
6
5
4
3
LEDC7
LEDC6
LEDC5
LEDC4
LEDC3
Read:
2
1
Bit 0
Write:
Reset:
Figure 18-12. Port A LED Control Register (LEDA)
LEDC[7:3] — Port C LED Drive Enable Bits
1 = Corresponding port C pin configured for direct LED drive
0 = Corresponding port C pin configured for standard drive
Technical Data
330
MOTOROLA
Port D
18.6 Port D
Port D is an 8-bit special function port that shares all of its pins with the
keyboard interrupt module. See Section 20. Keyboard Interrupt
Module (KBI).
The port D data register contains a data latch for each of the eight port D
pins.
Address:
$0003
Bit 7
6
5
4
3
2
1
Bit 0
PTD7
PTD6
PTD5
PTD4
PTD3
PTD2
PTD1
PTD0
KBI2
KBI1
KBI0
Read:
Write:
Reset:
Unaffected by reset
KBI7
KBI6
KBI5
KBI4
KBI3
Figure 18-13. Port D Data Register (PTD)
PTD[7:0] — Port D Data Bits
each port D pin is under the control of the corresponding bit in data
direction register D. Reset has no effect on port D data.
KBI[7:0] — Keyboard Interrupt Pins
The keyboard interrupt enable bits, KBIE[7:0], in the keyboard
interrupt enable register (KBIER), enable the port D pins as external
interrupt pins. See Section 20. Keyboard Interrupt Module (KBI).
MOTOROLA
Technical Data
331
Data direction register D determines whether each port D pin is an input
or an output. Writing a logic 1 to a DDRD bit enables the output buffer for
the corresponding port D pin; a logic 0 disables the output buffer.
Address:
$0007
Bit 7
6
5
4
3
2
1
Bit 0
DDRD7
DDRD6
DDRD5
DDRD4
DDRD3
DDRD2
DDRD1
DDRD0
Read:
Write:
Reset:
Figure 18-14. Data Direction Register D (DDRD)
DDRD[7:0] — Data Direction Register D Bits
These read/write bits control port D data direction. Reset clears
DDRD[7:0], configuring all port D pins as inputs.
1 = Corresponding port D pin configured as output
0 = Corresponding port D pin configured as input
NOTE:
Avoid glitches on port D pins by writing to the port D data register before
changing data direction register D bits from 0 to 1. Figure 18-15 shows
the port D I/O logic.
READ DDRD ($0007)
INTERNAL DATA BUS
WRITE DDRD ($0007)
RESET
DDRDx
WRITE PTD ($0003)
PTDx
PTDx
READ PTD ($0003)
Figure 18-15. Port D I/O Circuit
Technical Data
332
MOTOROLA
Port D
When DDRDx is a logic 1, reading address $0003 reads the PTDx data
latch. When DDRDx is a logic 0, reading address $0003 reads the
Table 18-7 summarizes the operation of the port D pins.
Table 18-7. Port D Pin Functions
DDRD
Bit
PTD Bit
I/O Pin
Mode
Accesses
to DDRD
Accesses to PTD
Read/Write
Read
Write
X(1)
Input, Hi-Z(2)
DDRD[7:0]
Pin
PTD[7:0](3)
1
X
Output
DDRD[7:0]
PTD[7:0]
PTD[7:0]
Notes:
1. X = don’t care.
3. Writing affects data register, but does not affect the input.
MOTOROLA
Technical Data
333
Technical Data
334
MOTOROLA
19.1 Contents
19.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 335
19.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 335
19.4
Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 336
19.5
IRQ1 and IRQ2 Pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 338
19.6
IRQ Module During Break Interrupts . . . . . . . . . . . . . . . . . . .339
19.7 IRQ Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 340
19.7.1 IRQ1 Status and Control Register . . . . . . . . . . . . . . . . . . .340
19.7.2 IRQ2 Status and Control Register . . . . . . . . . . . . . . . . . . .341
19.2 Introduction
The external interrupt (IRQ) module provides two maskable interrupt
inputs: IRQ1 and IRQ2.
19.3 Features
Features of the IRQ module include:
A dedicated external interrupt pin, IRQ1
An external interrupt pin shared with a port pin, IRQ2/PTB6
Separate IRQ interrupt control bits for IRQ1 and IRQ2
Hysteresis buffers
Programmable edge-only or edge and level interrupt sensitivity
Automatic interrupt acknowledge
Internal pullup resistor, with disable option on IRQ2
MC68HC908SR12•MC68HC08SR12 — Rev. 4.0
MOTOROLA
Technical Data
335
NOTE:
Addr.
$001C
$001E
References to either IRQ1 or IRQ2 may be made in the following text by
omitting the IRQ number. For example, IRQF may refer generically to
IRQ1F and IRQ2F, and IMASK may refer to IMASK1 and IMASK2.
Register Name
Bit 7
Read:
Register Write:
(INTSCR2)
Reset:
Read:
Register Write:
(INTSCR1)
Reset:
PTBPUE6
5
4
3
2
IRQ2F
ACK2
IRQ1F
ACK1
Bit 0
IMASK2
MODE2
IMASK1
MODE1
= Unimplemented
Figure 19-1. External Interrupt I/O Register Summary
19.4 Functional Description
A logic 0 applied to the external interrupt pin can latch a CPU interrupt
request. Figure 19-2 and Figure 19-3 shows the structure of the IRQ
module.
Interrupt signals on the IRQ pin are latched into the IRQ latch. An
interrupt latch remains set until one of the following actions occurs:
Vector fetch — A vector fetch automatically generates an interrupt
acknowledge signal that clears the latch that caused the vector
fetch.
Software clear — Software can clear an interrupt latch by writing
to the appropriate acknowledge bit in the interrupt status and
control register (INTSCR). Writing a logic 1 to the ACK bit clears
the IRQ latch.
Reset — A reset automatically clears the interrupt latch.
The external interrupt pin is falling-edge-triggered and is softwareconfigurable to be either falling-edge or falling-edge and low-leveltriggered. The MODE bit in the INTSCR controls the triggering sensitivity
of the IRQ pin.
Technical Data
336
MOTOROLA
When an interrupt pin is edge-triggered only, the interrupt remains set
until a vector fetch, software clear, or reset occurs.
When an interrupt pin is both falling-edge and low-level-triggered, the
interrupt remains set until both of the following occur:
Vector fetch or software clear
Return of the interrupt pin to logic 1
The vector fetch or software clear may occur before or after the interrupt
pin returns to logic 1. As long as the pin is low, the interrupt request
remains pending. A reset will clear the latch and the MODE1 control bit,
thereby clearing the interrupt even if the pin stays low.
When set, the IMASK bit in the INTSCR mask all external interrupt
requests. A latched interrupt request is not presented to the interrupt
priority logic unless the IMASK bit is clear.
NOTE:
The interrupt mask (I) in the condition code register (CCR) masks all
interrupt requests, including external interrupt requests.
INTERNAL ADDRESS BUS
ACK1
RESET
TO CPU FOR
BIL/BIH
INSTRUCTIONS
VECTOR
FETCH
DECODER
VDD
INTERNAL
PULLUP
DEVICE
IRQ1
VDD
IRQ1F
D
CLR
Q
CK
SYNCHRONIZER
IRQ1
INTERRUPT
REQUEST
IRQ1
FF
IMASK1
MODE1
HIGH
VOLTAGE
DETECT
TO MODE
SELECT
LOGIC
Figure 19-2. IRQ1 Block Diagram
MOTOROLA
Technical Data
337
ACK2
RESET
VECTOR
FETCH
DECODER
VDD
INTERNAL
PULLUP
DEVICE
VDD
IRQ2F
PTBPUE6
D
CLR
Q
SYNCHRONIZER
CK
IRQ2
IRQ2
INTERRUPT
REQUEST
IRQ2
FF
IMASK2
MODE2
Figure 19-3. IRQ2 Block Diagram
19.5 IRQ1 and IRQ2 Pins
A logic 0 on the IRQ pin can latch an interrupt request into the IRQ latch.
A vector fetch, software clear, or reset clears the IRQ latch.
If the MODE bit is set, the IRQ pin is both falling-edge-sensitive and lowlevel-sensitive. With MODE set, both of the following actions must occur
to clear IRQ:
Technical Data
338
Vector fetch or software clear — A vector fetch generates an
interrupt acknowledge signal to clear the latch. Software may
generate the interrupt acknowledge signal by writing a logic 1 to
the ACK bit in the interrupt status and control register (INTSCR).
The ACK bit is useful in applications that poll the IRQ pin and
require software to clear the IRQ latch. Writing to the ACK bit prior
to leaving an interrupt service routine can also prevent spurious
interrupts due to noise. Setting ACK does not affect subsequent
transitions on the IRQ pin. A falling edge that occurs after writing
to the ACK bit another interrupt request. If the IRQ mask bit,
IMASK, is clear, the CPU loads the program counter with the
vector address at location defined in Table 2-1 . Vector
Addresses.
MOTOROLA
Return of the IRQ pin to logic 1 — As long as the IRQ pin is at
logic 0, IRQ remains active.
The vector fetch or software clear and the return of the IRQ pin to logic 1
may occur in any order. The interrupt request remains pending as long
as the IRQ pin is at logic 0. A reset will clear the latch and the MODE
control bit, thereby clearing the interrupt even if the pin stays low.
If the MODE bit is clear, the IRQ pin is falling-edge-sensitive only. With
MODE clear, a vector fetch or software clear immediately clears the IRQ
latch.
The IRQF bit in the INTSCR register can be used to check for pending
interrupts. The IRQF bit is not affected by the IMASK bit, which makes it
useful in applications where polling is preferred.
Use the BIH or BIL instruction to read the logic level on the IRQ1 pin.
NOTE:
The BIH and BIL instructions do not read the logic level on the IRQ2 pin.
NOTE:
When using the level-sensitive interrupt trigger, avoid false interrupts by
masking interrupt requests in the interrupt routine.
The IRQ1 pin has a permanent internal pullup device connected, while
the IRQ2 pin has an optional pullup device that can be enabled or
disabled by the PTBPUE6 bit in the INTSCR2 register.
19.6 IRQ Module During Break Interrupts
The BCFE bit in the SIM break flag control register (SBFCR) enables
software to clear the latch during the break state. (See Section 23.
Break Module (BRK).)
To allow software to clear the IRQ latch during a break interrupt, write a
logic 1 to the BCFE bit. If a latch is cleared during the break state, it
remains cleared when the MCU exits the break state.
To protect CPU interrupt flags during the break state, write a logic 0 to
the BCFE bit. With BCFE at logic 0 (its default state), writing to the ACK
bit in the IRQ status and control register during the break state has no
effect on the IRQ interrupt flags.
MOTOROLA
Technical Data
339
19.7 IRQ Registers
Each IRQ is controlled and monitored by an status and control register.
IRQ1 Status and Control Register — $001E
IRQ2 Status and Control Register — $001C
The IRQ1 status and control register (INTSCR1) controls and monitors
operation of IRQ1. The INTSCR1 has the following functions:
Shows the state of the IRQ1 flag
Clears the IRQ1 latch
Masks IRQ1 interrupt request
Controls triggering sensitivity of the IRQ1 interrupt pin
Address:
Read:
$001E
Bit 7
6
5
4
3
2
IRQ1F
Bit 0
IMASK1
MODE1
ACK1
Write:
Reset:
1
= Unimplemented
Figure 19-4. IRQ1 Status and Control Register (INTSCR1)
IRQ1F — IRQ1 Flag Bit
This read-only status bit is high when the IRQ1 interrupt is pending.
1 = IRQ1 interrupt pending
0 = IRQ1 interrupt not pending
ACK1 — IRQ1 Interrupt Request Acknowledge Bit
Writing a logic 1 to this write-only bit clears the IRQ1 latch. ACK1
always reads as logic 0. Reset clears ACK1.
Technical Data
340
MOTOROLA
IRQ Registers
IMASK1 — IRQ1 Interrupt Mask Bit
Writing a logic 1 to this read/write bit disables IRQ1 interrupt requests.
Reset clears IMASK1.
1 = IRQ1 interrupt requests disabled
0 = IRQ1 interrupt requests enabled
MODE1 — IRQ1 Edge/Level Select Bit
This read/write bit controls the triggering sensitivity of the IRQ1 pin.
Reset clears MODE1.
1 = IRQ1 interrupt requests on falling edges and low levels
0 = IRQ1 interrupt requests on falling edges only
The IRQ2 status and control register (INTSCR2) controls and monitors
operation of IRQ2. The INTSCR2 has the following functions:
Enables/disables the internal pullup device on IRQ2 pin
Shows the state of the IRQ2 flag
Clears the IRQ2 latch
Masks IRQ2 interrupt request
Controls triggering sensitivity of the IRQ2 interrupt pin
Address:
$001C
Bit 7
Read:
6
4
3
2
IRQ2F
PTBPUE6
Bit 0
IMASK2
MODE2
ACK2
Write:
Reset:
1
= Unimplemented
Figure 19-5. IRQ2 Status and Control Register (INTSCR2)
PTBPUE6 — IRQ2 Pin Pullup Enable Bit.
Setting this bit to logic 1 disables the pullup on PTB6/IRQ2 pin.
1 = IRQ2 pin internal pull-up is disabled
0 = IRQ2 pin internal pull-up is enabled
MOTOROLA
Technical Data
341
IRQ2F — IRQ2 Flag Bit
This read-only status bit is high when the IRQ2 interrupt is pending.
1 = IRQ2 interrupt pending
0 = IRQ2 interrupt not pending
ACK2 — IRQ2 Interrupt Request Acknowledge Bit
Writing a logic 1 to this write-only bit clears the IRQ2 latch. ACK2
always reads as logic 0. Reset clears ACK2.
IMASK2 — IRQ2 Interrupt Mask Bit
Writing a logic 1 to this read/write bit disables IRQ2 interrupt requests.
Reset clears IMASK2.
1 = IRQ2 interrupt requests disabled
0 = IRQ2 interrupt requests enabled
MODE2 — IRQ2 Edge/Level Select Bit
This read/write bit controls the triggering sensitivity of the IRQ2 pin.
Reset clears MODE2.
1 = IRQ2 interrupt requests on falling edges and low levels
0 = IRQ2 interrupt requests on falling edges only
Technical Data
342
MOTOROLA
Technical Data — MC68HC908SR12•MC68HC08SR12
20.1 Contents
20.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 343
20.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 344
20.4
I/O Pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 344
20.5 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 345
20.5.1 Keyboard Initialization . . . . . . . . . . . . . . . . . . . . . . . . . . . . 347
20.6 Keyboard Interrupt Registers . . . . . . . . . . . . . . . . . . . . . . . . . 347
20.6.1 Keyboard Status and Control Register. . . . . . . . . . . . . . . . 348
20.6.2 Keyboard Interrupt Enable Register . . . . . . . . . . . . . . . . . . 349
20.7
Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .349
20.8
Wait Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 349
20.9
Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 349
20.10 Keyboard Module During Break Interrupts . . . . . . . . . . . . . . .350
20.2 Introduction
The keyboard interrupt module (KBI) provides eight independently
maskable external interrupts which are accessible via PTD0–PTD7.
When a port pin is enabled for keyboard interrupt function, an internal
30kΩ pullup device is also enabled on the pin.
MOTOROLA
Technical Data
343
20.3 Features
Features of the keyboard interrupt module include the following:
Eight keyboard interrupt pins with pullup devices
Separate keyboard interrupt enable bits and one keyboard
interrupt mask
Programmable edge-only or edge- and level- interrupt sensitivity
Exit from low-lower modes
Addr.
Register Name
$001A
Read:
Keyboard Status
and Control Register Write:
(KBSCR)
Reset:
Read:
$001B
Write:
Register (KBIER)
Reset:
Bit 7
6
5
4
3
2
KEYF
Bit 0
IMASKK
MODEK
ACKK
KBIE7
KBIE6
KBIE5
KBIE4
KBIE3
KBIE2
KBIE1
KBIE0
= Unimplemented
Figure 20-1. KBI I/O Register Summary
20.4 I/O Pins
The eight keyboard interrupt pins are shared with standard port I/O pins.
The full name of the KBI pins are listed in Table 20-1. The generic pin
name appear in the text that follows.
Table 20-1. Pin Name Conventions
KBI
Generic Pin Name
Full MCU Pin Name
Pin Selected for KBI Function by
KBIEx Bit in KBIER
KBI0–KBI7
PTD0/KBI0–PTD7/KBI7
KBIE0–KBIE7
Technical Data
344
MOTOROLA
INTERNAL BUS
KBI0
ACKK
VDD
VECTOR FETCH
DECODER
KEYF
RESET
KBIE0
D
CLR
Q
SYNCHRONIZER
CK
TO PULLUP ENABLE
KEYBOARD
INTERRUPT FF
KBI7
Keyboard
Interrupt
Request
IMASKK
MODEK
KBIE7
TO PULLUP ENABLE
Figure 20-2. Keyboard Interrupt Block Diagram
Writing to the KBIE7–KBIE0 bits in the keyboard interrupt enable register
independently enables or disables each port D pin as a keyboard
interrupt pin. Enabling a keyboard interrupt pin in port D also enables its
internal pull-up device. A logic 0 applied to an enabled keyboard
interrupt pin latches a keyboard interrupt request.
A keyboard interrupt is latched when one or more keyboard pins goes
low after all were high. The MODEK bit in the keyboard status and
control register controls the triggering mode of the keyboard interrupt.
If the keyboard interrupt is edge-sensitive only, a falling edge on a
keyboard pin does not latch an interrupt request if another
keyboard pin is already low. To prevent losing an interrupt request
on one pin because another pin is still low, software can disable
the latter pin while it is low.
If the keyboard interrupt is falling edge- and low level-sensitive, an
interrupt request is present as long as any keyboard pin is low.
If the MODEK bit is set, the keyboard interrupt pins are both falling edgeand low level-sensitive, and both of the following actions must occur to
clear a keyboard interrupt request:
MOTOROLA
Technical Data
345
interrupt acknowledge signal to clear the interrupt request.
Software may generate the interrupt acknowledge signal by
writing a logic 1 to the ACKK bit in the keyboard status and control
register KBSCR. The ACKK bit is useful in applications that poll
the keyboard interrupt pins and require software to clear the
keyboard interrupt request. Writing to the ACKK bit prior to leaving
an interrupt service routine can also prevent spurious interrupts
due to noise. Setting ACKK does not affect subsequent transitions
on the keyboard interrupt pins. A falling edge that occurs after
writing to the ACKK bit latches another interrupt request. If the
keyboard interrupt mask bit, IMASKK, is clear, the CPU loads the
program counter with the vector address at locations $FFE0 and
$FFE1.
Return of all enabled keyboard interrupt pins to logic 1 — As long
as any enabled keyboard interrupt pin is at logic 0, the keyboard
interrupt remains set.
The vector fetch or software clear and the return of all enabled keyboard
interrupt pins to logic 1 may occur in any order.
If the MODEK bit is clear, the keyboard interrupt pin is falling-edgesensitive only. With MODEK clear, a vector fetch or software clear
immediately clears the keyboard interrupt request.
Reset clears the keyboard interrupt request and the MODEK bit, clearing
the interrupt request even if a keyboard interrupt pin stays at logic 0.
The keyboard flag bit (KEYF) in the keyboard status and control register
can be used to see if a pending interrupt exists. The KEYF bit is not
affected by the keyboard interrupt mask bit (IMASKK) which makes it
To determine the logic level on a keyboard interrupt pin, use the data
direction register to configure the pin as an input and read the data
register.
NOTE:
Technical Data
346
Setting a keyboard interrupt enable bit (KBIEx) forces the corresponding
keyboard interrupt pin to be an input, overriding the data direction
register. However, the data direction register bit must be a logic 0 for
software to read the pin.
MOTOROLA
When a keyboard interrupt pin is enabled, it takes time for the internal
pull-up to reach a logic 1. Therefore a false interrupt can occur as soon
as the pin is enabled.
To prevent a false interrupt on keyboard initialization:
1. Mask keyboard interrupts by setting the IMASKK bit in the
keyboard status and control register.
2. Enable the KBI pins by setting the appropriate KBIEx bits in the
keyboard interrupt enable register.
3. Write to the ACKK bit in the keyboard status and control register
to clear any false interrupts.
4. Clear the IMASKK bit.
An interrupt signal on an edge-triggered pin can be acknowledged
immediately after enabling the pin. An interrupt signal on an edge- and
level-triggered interrupt pin must be acknowledged after a delay that
depends on the external load.
Another way to avoid a false interrupt:
1. Configure the keyboard pins as outputs by setting the appropriate
DDR bits in data direction register.
2. Write logic 1s to the appropriate data register bits.
3. Enable the KBI pins by setting the appropriate KBIEx bits in the
Two registers control the operation of the keyboard interrupt module:
Keyboard Status and Control Register — $001A
Keyboard Interrupt Enable Register — $001B
MOTOROLA
Technical Data
347
Flags keyboard interrupt requests
Acknowledges keyboard interrupt requests
Masks keyboard interrupt requests
Controls keyboard interrupt triggering sensitivity
Address:
Read:
$001A
Bit 7
6
5
4
3
2
KEYF
Write:
Reset:
1
Bit 0
IMASKK
MODEK
ACKK
= Unimplemented
Figure 20-3. Keyboard Status and Control Register (KBSCR)
KEYF — Keyboard Flag Bit
This read-only bit is set when a keyboard interrupt is pending.
Reset clears the KEYF bit.
1 = Keyboard interrupt pending
0 = No keyboard interrupt pending
ACKK — Keyboard Acknowledge Bit
Writing a logic 1 to this write-only bit clears the keyboard interrupt
request. ACKK always reads as logic 0. Reset clears ACKK.
IMASKK — Keyboard Interrupt Mask Bit
Writing a logic 1 to this read/write bit prevents the output of the
keyboard interrupt mask from generating interrupt requests. Reset
clears the IMASKK bit.
1 = Keyboard interrupt requests masked
0 = Keyboard interrupt requests not masked
MODEK — Keyboard Triggering Sensitivity Bit
This read/write bit controls the triggering sensitivity of the keyboard
interrupt pins. Reset clears MODEK.
1 = Keyboard interrupt requests on falling edges and low levels
0 = Keyboard interrupt requests on falling edges only
Technical Data
348
MOTOROLA
Low-Power Modes
The port-D keyboard interrupt enable register enables or disables each
port-D pin to operate as a keyboard interrupt pin.
Address:
$001B
Bit 7
6
5
4
3
2
1
Bit 0
KBIE7
KBIE6
KBIE5
KBIE4
KBIE3
KBIE2
KBIE1
KBIE0
Read:
Write:
Reset:
Figure 20-4. Keyboard Interrupt Enable Register (KBIER)
KBIE7–KBIE0 — Keyboard Interrupt Enable Bits
Each of these read/write bits enables the corresponding keyboard
interrupt pin to latch interrupt requests. Reset clears the keyboard
1 = KBIx pin enabled as keyboard interrupt pin
0 = KBIx pin not enabled as keyboard interrupt pin
20.7 Low-Power Modes
The WAIT and STOP instructions put the MCU in low powerconsumption standby modes.
20.8 Wait Mode
The keyboard interrupt module remains active in wait mode. Clearing the
IMASKK bit in the keyboard status and control register enables keyboard
interrupt requests to bring the MCU out of wait mode.
20.9 Stop Mode
The keyboard interrupt module remains active in stop mode. Clearing
the IMASKK bit in the keyboard status and control register enables
keyboard interrupt requests to bring the MCU out of stop mode.
MOTOROLA
Technical Data
349
The system integration module (SIM) controls whether the keyboard
interrupt latch can be cleared during the break state. The BCFE bit in the
SIM break flag control register (BFCR) enables software to clear status
bits during the break state.
To allow software to clear the keyboard interrupt latch during a break
interrupt, write a logic 1 to the BCFE bit. If a latch is cleared during the
break state, it remains cleared when the MCU exits the break state.
To protect the latch during the break state, write a logic 0 to the BCFE
bit. With BCFE at logic 0 (its default state), writing to the keyboard
acknowledge bit (ACKK) in the keyboard status and control register
during the break state has no effect.
Technical Data
350
MOTOROLA
Section 21. Computer Operating Properly (COP)
21.1 Contents
21.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 351
21.3
Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 352
21.4 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 353
21.4.1 ICLK . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 353
21.4.2 STOP Instruction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 353
21.4.3 COPCTL Write . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 353
21.4.4 Power-On Reset. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 353
21.4.5 Internal Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 354
21.4.6 Reset Vector Fetch. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 354
21.4.7 COPD (COP Disable). . . . . . . . . . . . . . . . . . . . . . . . . . . . .354
21.4.8 COPRS (COP Rate Select) . . . . . . . . . . . . . . . . . . . . . . . . 354
21.5
COP Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 355
21.6
Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 355
21.7
Monitor Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 355
21.8 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .355
21.8.1 Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 356
21.8.2 Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 356
21.9
COP Module During Break Mode . . . . . . . . . . . . . . . . . . . . . .356
21.2 Introduction
The computer operating properly (COP) module contains a free-running
counter that generates a reset if allowed to overflow. The COP module
helps software recover from runaway code. Prevent a COP reset by
clearing the COP counter periodically. The COP module can be disabled
through the COPD bit in the configuration register 1 (CONFIG1).
MOTOROLA
Technical Data
351
21.3 Functional Description
Figure 21-1 shows the structure of the COP module.
CLEAR STAGES 5–12
RESET STATUS REGISTER
COP TIMEOUT
STOP INSTRUCTION
INTERNAL RESET SOURCES
RESET VECTOR FETCH
RESET CIRCUIT
12-BIT COP PRESCALER
CLEAR ALL STAGES
ICLK
COPCTL WRITE
COP CLOCK
6-BIT COP COUNTER
COPEN (FROM SIM)
COP DISABLE
(COPD FROM CONFIG1)
RESET
COPCTL WRITE
CLEAR
COP COUNTER
COP RATE SEL
(COPRS FROM CONFIG1)
Figure 21-1. COP Block Diagram
The COP counter is a free-running 6-bit counter preceded by a 12-bit
prescaler counter. If not cleared by software, the COP counter overflows
and generates an asynchronous reset after 218 – 24 or 213 – 24 ICLK
cycles, depending on the state of the COP rate select bit, COPRS, in the
CONFIG1 register. With a 213 – 24 ICLK cycle overflow option, a 24-kHz
ICLK gives a COP timeout period of 341ms. Writing any value to location
$FFFF before an overflow occurs prevents a COP reset by clearing the
COP counter and stages 12 through 5 of the prescaler.
NOTE:
Technical Data
352
Service the COP immediately after reset and before entering or after
exiting STOP Mode to guarantee the maximum time before the first COP
counter overflow.
MOTOROLA
I/O Signals
A COP reset pulls the RST pin low for 32 ICLK cycles and sets the COP
bit in the SIM reset status register (SRSR).
In monitor mode, the COP is disabled if the RST pin or the IRQ1 is held
at VTST. During the break state, VTST on the RST pin disables the COP.
NOTE:
Place COP clearing instructions in the main program and not in an
interrupt subroutine. Such an interrupt subroutine could keep the COP
from generating a reset even while the main program is not working
properly.
21.4 I/O Signals
The following paragraphs describe the signals shown in Figure 21-1.
21.4.1 ICLK
ICLK is the internal oscillator output signal. ICLK frequency is
approximately equal to 24kHz. See Section 24. Electrical
Specifications for ICLK parameters.
The STOP instruction clears the COP prescaler.
21.4.3 COPCTL Write
Writing any value to the COP control register (COPCTL) (see 21.5 COP
Control Register) clears the COP counter and clears bits 12 through 5
of the prescaler. Reading the COP control register returns the low byte
of the reset vector.
The power-on reset (POR) circuit clears the COP prescaler 4096 ICLK
cycles after power-up.
MOTOROLA
Technical Data
353
An internal reset clears the COP prescaler and the COP counter.
A reset vector fetch occurs when the vector address appears on the data
bus. A reset vector fetch clears the COP prescaler.
The COPD signal reflects the state of the COP disable bit (COPD) in the
CONFIG1 register. (See Figure 21-2 and Section 5. Configuration
and Mask Option Registers (CONFIG & MOR).)
The COPRS signal reflects the state of the COP rate select bit (COPRS)
in the CONFIG1 register.
Address:
$001F
Bit 7
6
5
4
3
2
1
Bit 0
SSREC
STOP
COPD
Read:
COPRS
LVISTOP LVIRSTD LVIPWRD LVI5OR3
Write:
Reset:
0*
* Reset by POR only.
Figure 21-2. Configuration Register 1 (CONFIG1)
COPRS — COP Rate Select
COPRS selects the COP time-out period. Reset clears COPRS.
1 = COP time out period = 213 – 24 ICLK cycles
0 = COP time out period = 218 – 24 ICLK cycles
COPD — COP Disable Bit
COPD disables the COP module.
1 = COP module disabled
0 = COP module enabled
Technical Data
354
MOTOROLA
21.5 COP Control Register
The COP control register is located at address $FFFF and overlaps the
reset vector. Writing any value to $FFFF clears the COP counter and
starts a new timeout period. Reading location $FFFF returns the low
byte of the reset vector.
Address:
$FFFF
Bit 7
6
5
4
3
Read:
Low byte of reset vector
Write:
Clear COP counter
Reset:
Unaffected by reset
2
1
Bit 0
Figure 21-3. COP Control Register (COPCTL)
21.6 Interrupts
The COP does not generate CPU interrupt requests.
21.7 Monitor Mode
When monitor mode is entered with VTST on the IRQ1 pin, the COP is
disabled as long as VTST remains on the IRQ1 pin or the RST pin. When
monitor mode is entered by having blank reset vectors and not having
VTST on the IRQ1 pin, the COP is automatically disabled until a POR
occurs.
MOTOROLA
Technical Data
355
21.8.1 Wait Mode
The COP remains active during wait mode. To prevent a COP reset
during wait mode, periodically clear the COP counter in a CPU interrupt
routine.
21.8.2 Stop Mode
Stop mode turns off the ICLK input to the COP and clears the COP
prescaler. Service the COP immediately before entering or after exiting
stop mode to ensure a full COP timeout period after entering or exiting
stop mode.
To prevent inadvertently turning off the COP with a STOP instruction, a
configuration option is available that disables the STOP instruction.
When the STOP bit in the configuration register has the STOP
instruction is disabled, execution of a STOP instruction results in an
illegal opcode reset.
21.9 COP Module During Break Mode
The COP is disabled during a break interrupt when VTST is present on
the RST pin.
Technical Data
356
MOTOROLA
Section 22. Low-Voltage Inhibit (LVI)
22.1 Contents
22.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 357
22.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 357
22.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 358
22.4.1 Polled LVI Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 359
22.4.2 Forced Reset Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . 360
22.4.3 Voltage Hysteresis Protection . . . . . . . . . . . . . . . . . . . . . . 360
22.4.4 LVI Trip Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 360
22.5
LVI Status Register. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 361
22.6
LVI Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 361
22.7 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .361
22.7.1 Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 362
22.7.2 Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 362
22.2 Introduction
This section describes the low-voltage inhibit (LVI) module, which
monitors the voltage on the VDD pin and can force a reset when the VDD
voltage falls below the LVI trip falling voltage, VTRIPF.
22.3 Features
Features of the LVI module include:
Programmable LVI reset
Selectable LVI trip voltage
Programmable stop mode operation
MOTOROLA
Technical Data
357
Addr.
Register Name
Bit 7
Read: LVIOUT
Low-Voltage Inhibit Status
$FE0F
Register Write:
(LVISR)
Reset:
5
4
3
2
1
Bit 0
= Unimplemented
Figure 22-1. LVI I/O Register Summary
Figure 22-2 shows the structure of the LVI module. The LVI is enabled
out of reset. The LVI module contains a bandgap reference circuit and
comparator. Clearing the LVI power disable bit, LVIPWRD, enables the
LVI to monitor VDD voltage. Clearing the LVI reset disable bit, LVIRSTD,
enables the LVI module to generate a reset when VDD falls below a
voltage, VTRIPF. Setting the LVI enable in stop mode bit, LVISTOP,
enables the LVI to operate in stop mode. Setting the LVI 5V or 3V trip
point bit, LVI5OR3, enables the trip point voltage, VTRIPF, to be
configured for 5V operation. Clearing the LVI5OR3 bit enables the trip
point voltage, VTRIPF, to be configured for 3V operation. The actual trip
points are shown in Section 24. Electrical Specifications.
VDD
STOP INSTRUCTION
LVISTOP
FROM CONFIG1
FROM CONFIG1
LVIRSTD
LVIPWRD
FROM CONFIG
VDD > VTRIPR = 0
LOW VDD
DETECTOR
LVI RESET
VDD ≤ VTRIPF = 1
LVIOUT
LVI5OR3
TO LVISR
FROM CONFIG1
Figure 22-2. LVI Module Block Diagram
Technical Data
358
MOTOROLA
NOTE:
After a power-on reset (POR) the LVI’s default mode of operation is 3V.
If a 5V system is used, the user must set the LVI5OR3 bit to raise the
trip point to 5V operation. Note that this must be done after every poweron reset since the default will revert back to 3V mode after each poweron reset. If the VDD supply is below the 5V mode trip voltage but above
the 3V mode trip voltage when POR is released, the MCU will operate
because VTRIPF defaults to 3V mode after a POR. So, in a 5V system
care must be taken to ensure that VDD is above the 5V mode trip voltage
after POR is released.
NOTE:
If the user requires 5V mode and sets the LVI5OR3 bit after a power-on
reset while the VDD supply is not above the VTRIPF for 5V mode, the
MCU will immediately go into reset. The LVI in this case will hold the
MCU in reset until either VDD goes above the rising 5V trip point, VTRIPR,
which will release reset or VDD decreases to approximately 0V which will
re-trigger the power-on reset and reset the trip point to 3V operation.
LVISTOP, LVIPWRD, LVI5OR3, and LVIRSTD are in the configuration
register 1 (CONFIG1). See Section 5. Configuration and Mask Option
Registers (CONFIG & MOR) for details of the LVI’s configuration bits.
Once an LVI reset occurs, the MCU remains in reset until VDD rises
above a voltage, VTRIPR, which causes the MCU to exit reset. See
9.4.2.5 Low-Voltage Inhibit (LVI) Reset for details of the interaction
between the SIM and the LVI. The output of the comparator controls the
state of the LVIOUT flag in the LVI status register (LVISR).
An LVI reset also drives the RST pin low to provide low-voltage
protection to external peripheral devices.
In applications that can operate at VDD levels below the VTRIPF level,
software can monitor VDD by polling the LVIOUT bit. In the configuration
register 1 (CONFIG1), the LVIPWRD bit must be at logic 0 to enable the
LVI module, and the LVIRSTD bit must be at logic 1 to disable LVI
resets.
MOTOROLA
Technical Data
359
In applications that require VDD to remain above the VTRIPF level,
enabling LVI resets allows the LVI module to reset the MCU when VDD
falls below the VTRIPF level. In the configuration register 1 (CONFIG1),
the LVIPWRD and LVIRSTD bits must be at logic 0 to enable the LVI
module and to enable LVI resets.
Once the LVI has triggered (by having VDD fall below VTRIPF), the LVI
will maintain a reset condition until VDD rises above the rising trip point
voltage, VTRIPR. This prevents a condition in which the MCU is
continually entering and exiting reset if VDD is approximately equal to
VTRIPF. VTRIPR is greater than VTRIPF by the hysteresis voltage, VHYS.
The LVI5OR3 bit in the CONFIG1 register selects whether the LVI is
configured for 5V or 3V protection.
NOTE:
Technical Data
360
The MCU is guaranteed to operate at a minimum supply voltage. The trip
point (VTRIPF [5 V] or VTRIPF [3 V]) may be lower than this.
(See Section 24. Electrical Specifications for the actual trip point
voltages.)
MOTOROLA
LVI Status Register
22.5 LVI Status Register
The LVI status register (LVISR) indicates if the VDD voltage was
detected below the VTRIPF level.
Address:
Read:
$FE0F
Bit 7
6
5
4
3
2
1
Bit 0
LVIOUT
Write:
Reset:
= Unimplemented
Figure 22-3. LVI Status Register
LVIOUT — LVI Output Bit
This read-only flag becomes set when the VDD voltage falls below the
VTRIPF trip voltage (see Table 22-1). Reset clears the LVIOUT bit.
Table 22-1. LVIOUT Bit Indication
VDD
LVIOUT
VDD > VTRIPR
VDD < VTRIPF
1
VTRIPF < VDD < VTRIPR
Previous value
22.6 LVI Interrupts
The LVI module does not generate interrupt requests.
The STOP and WAIT instructions put the MCU in low powerconsumption standby modes.
MOTOROLA
Technical Data
361
22.7.1 Wait Mode
If enabled, the LVI module remains active in wait mode. If enabled to
generate resets, the LVI module can generate a reset and bring the MCU
out of wait mode.
22.7.2 Stop Mode
If enabled in stop mode (LVISTOP = 1), the LVI module remains active
in stop mode. If enabled to generate resets (LVIRSTD = 0), the LVI
module can generate a reset and bring the MCU out of stop mode.
Technical Data
362
MOTOROLA
Section 23. Break Module (BRK)
23.1 Contents
23.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 363
23.3
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 364
23.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 364
23.4.1 Flag Protection During Break Interrupts . . . . . . . . . . . . . . .366
23.4.2 CPU During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . 366
23.4.3 TIM1 and TIM2 During Break Interrupts. . . . . . . . . . . . . . .366
23.4.4 COP During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . 366
23.5 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .366
23.5.1 Wait Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 366
23.5.2 Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 367
23.6 Break Module Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . .367
23.6.1 Break Status and Control Register. . . . . . . . . . . . . . . . . . . 367
23.6.2 Break Address Registers . . . . . . . . . . . . . . . . . . . . . . . . . .368
23.6.3 SIM Break Status Register . . . . . . . . . . . . . . . . . . . . . . . . . 368
23.6.4 SIM Break Flag Control Register . . . . . . . . . . . . . . . . . . . . 370
23.2 Introduction
This section describes the break module. The break module can
generate a break interrupt that stops normal program flow at a defined
address to enter a background program.
MOTOROLA
Break Module (BRK)
Technical Data
363
Break Module (BRK)
23.3 Features
Features of the break module include:
Accessible input/output (I/O) registers during the break interrupt
CPU-generated break interrupts
Software-generated break interrupts
COP disabling during break interrupts
When the internal address bus matches the value written in the break
address registers, the break module issues a breakpoint signal to the
CPU. The CPU then loads the instruction register with a software
interrupt instruction (SWI) after completion of the current CPU
instruction. The program counter vectors to $FFFC and $FFFD ($FEFC
and $FEFD in monitor mode).
The following events can cause a break interrupt to occur:
A CPU-generated address (the address in the program counter)
matches the contents of the break address registers.
Software writes a logic 1 to the BRKA bit in the break status and
control register.
When a CPU-generated address matches the contents of the break
address registers, the break interrupt begins after the CPU completes its
current instruction. A return-from-interrupt instruction (RTI) in the break
routine ends the break interrupt and returns the MCU to normal
operation. Figure 23-1 shows the structure of the break module.
Technical Data
364
Break Module (BRK)
MOTOROLA
Break Module (BRK)
IAB15–IAB8
BREAK ADDRESS REGISTER HIGH
8-BIT COMPARATOR
IAB15–IAB0
BREAK
CONTROL
8-BIT COMPARATOR
BREAK ADDRESS REGISTER LOW
IAB7–IAB0
Figure 23-1. Break Module Block Diagram
Addr.
Register Name
Read:
$FE00
Write:
(SBSR)
Reset:
$FE03
$FE0C
$FE0D
Read:
Write:
Register (SBFCR)
Reset:
Read:
Write:
High (BRKH)
Reset:
Read:
Write:
Low (BRKL)
Reset:
Read:
$FE0E
Write:
Register (BRKSCR)
Reset:
Note: Writing a logic 0 clears SBSW.
Bit 7
6
5
4
3
2
R
R
R
R
R
R
1
SBSW
Note
Bit 0
R
BCFE
R
R
R
R
R
R
R
Bit 15
14
13
12
11
10
9
Bit 8
Bit 7
6
5
4
3
2
1
Bit 0
BRKE
BRKA
= Unimplemented
R
= Reserved
Figure 23-2. Break Module I/O Register Summary
MOTOROLA
Break Module (BRK)
Technical Data
365
Break Module (BRK)
software to clear status bits during the break state.
The CPU starts a break interrupt by:
Loading the instruction register with the SWI instruction
Loading the program counter with $FFFC and $FFFD
($FEFC and $FEFD in monitor mode)
The break interrupt begins after completion of the CPU instruction in
progress. If the break address register match occurs on the last cycle of
a CPU instruction, the break interrupt begins immediately.
A break interrupt stops the timer counters.
the RST pin.
23.5.1 Wait Mode
If enabled, the break module is active in wait mode. In the break routine,
the user can subtract one from the return address on the stack if SBSW
is set (see Section 9. System Integration Module (SIM)). Clear the
SBSW bit by writing logic 0 to it.
Technical Data
366
Break Module (BRK)
MOTOROLA
Break Module (BRK)
23.5.2 Stop Mode
A break interrupt causes exit from stop mode and sets the SBSW bit in
the break status register.
These registers control and monitor operation of the break module:
Break status and control register (BRKSCR)
Break address register high (BRKH)
Break address register low (BRKL)
SIM break status register (SBSR)
The break status and control register (BRKSCR) contains break module
enable and status bits.
Address:
$FE0E
Bit 7
6
BRKE
BRKA
Read:
5
4
3
2
1
Bit 0
Write:
Reset:
= Unimplemented
Figure 23-3. Break Status and Control Register (BRKSCR)
BRKE — Break Enable Bit
This read/write bit enables breaks on break address register matches.
Clear BRKE by writing a logic 0 to bit 7. Reset clears the BRKE bit.
1 = Breaks enabled on 16-bit address match
0 = Breaks disabled on 16-bit address match
MOTOROLA
Break Module (BRK)
Technical Data
367
Break Module (BRK)
BRKA — Break Active Bit
This read/write status and control bit is set when a break address
match occurs. Writing a logic 1 to BRKA generates a break interrupt.
Clear BRKA by writing a logic 0 to it before exiting the break routine.
Reset clears the BRKA bit.
1 = (When read) Break address match
0 = (When read) No break address match
The break address registers (BRKH and BRKL) contain the high and low
bytes of the desired breakpoint address. Reset clears the break address
registers.
Address:
$FE0C
Bit 7
6
5
4
3
2
1
Bit 0
Bit 15
14
13
12
11
10
9
Bit 8
Read:
Write:
Reset:
Figure 23-4. Break Address Register High (BRKH)
Address:
$FE0D
Bit 7
6
5
4
3
2
1
Bit 0
Bit 7
6
5
4
3
2
1
Bit 0
Read:
Write:
Reset:
Figure 23-5. Break Address Register Low (BRKL)
The SIM break status register (SBSR) contains a flag to indicate that a
break caused an exit from wait mode. The flag is useful in applications
requiring a return to wait mode after exiting from a break interrupt.
Technical Data
368
Break Module (BRK)
MOTOROLA
Break Module (BRK)
Address:
$FE00
Bit 7
6
5
4
3
2
R
R
R
R
R
R
Read:
1
Bit 0
SBSW
R
Write:
Note
Reset:
R
= Reserved
Figure 23-6. SIM Break Status Register (SBSR)
SBSW — Break Wait Bit
This status bit is set when a break interrupt causes an exit from wait
mode or stop mode. Clear SBSW by writing a logic 0 to it. Reset clears
SBSW.
1 = Stop mode or wait mode was exited by break interrupt
0 = Stop mode or wait mode was not exited by break interrupt
SBSW can be read within the break interrupt routine. The user can
modify the return address on the stack by subtracting 1 from it. The
following code is an example.
; This code works if the H register has been pushed onto the stack in the break
; service routine software. This code should be executed at the end of the break
HIBYTE
EQU
5
LOBYTE
EQU
6
If not SBSW, do RTI
BRCLR
SBSW,SBSR, RETURN
; See if wait mode or stop mode was exited by
; break.
TST
LOBYTE,SP
;If RETURNLO is not zero,
BNE
DOLO
;then just decrement low byte.
DEC
HIBYTE,SP
;Else deal with high byte, too.
DOLO
DEC
LOBYTE,SP
;Point to WAIT/STOP opcode.
RETURN
PULH
RTI
;Restore H register.
MOTOROLA
Break Module (BRK)
Technical Data
369
Break Module (BRK)
The SIM break flag control register (SBFCR) contains a bit that enables
software to clear status bits while the MCU is in a break state.
Address:
$FE03
Bit 7
6
5
4
3
2
1
Bit 0
BCFE
R
R
R
R
R
R
R
Read:
Write:
Reset:
R
= Reserved
Figure 23-7. SIM Break Flag Control Register (SBFCR)
BCFE — Break Clear Flag Enable Bit
This read/write bit enables software to clear status bits by accessing
status registers while the MCU is in a break state. To clear status bits
during the break state, the BCFE bit must be set.
1 = Status bits clearable during break
0 = Status bits not clearable during break
Technical Data
370
Break Module (BRK)
MOTOROLA
24.1 Contents
24.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 372
24.3
Absolute Maximum Ratings . . . . . . . . . . . . . . . . . . . . . . . . . .372
24.4
Functional Operating Range. . . . . . . . . . . . . . . . . . . . . . . . . . 373
24.5
Thermal Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 373
24.6
5.0V DC Electrical Characteristics . . . . . . . . . . . . . . . . . . . . . 374
24.7
3.0V DC Electrical Characteristics . . . . . . . . . . . . . . . . . . . . . 376
24.8
5.0V Control Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 377
24.9
3.0V Control Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 377
24.10 5.0V Oscillator Characteristics . . . . . . . . . . . . . . . . . . . . . . . . 378
24.11 3.0V Oscillator Characteristics . . . . . . . . . . . . . . . . . . . . . . . . 379
24.12 5.0V ADC Electrical Characteristics . . . . . . . . . . . . . . . . . . . . 380
24.13 3.0V ADC Electrical Characteristics . . . . . . . . . . . . . . . . . . . . 381
24.14 Analog Module Electrical Characteristics . . . . . . . . . . . . . . . . 382
24.14.1 Temperature Sensor Electrical Characteristics . . . . . . . . . 382
24.14.2 Current Detection Electrical Characteristics. . . . . . . . . . . . 382
24.14.3 Two-Stage Amplifier Electrical Characteristics. . . . . . . . . . 382
24.15 Timer Interface Module Characteristics . . . . . . . . . . . . . . . . . 383
24.16 MMIIC Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 383
24.17 CGM Electrical Specifications. . . . . . . . . . . . . . . . . . . . . . . . . 385
24.18 FLASH Memory Characteristics . . . . . . . . . . . . . . . . . . . . . . . 386
MOTOROLA
Technical Data
371
24.2 Introduction
This section contains electrical and timing specifications.
24.3 Absolute Maximum Ratings
Maximum ratings are the extreme limits to which the MCU can be
exposed without permanently damaging it.
NOTE:
This device is not guaranteed to operate properly at the maximum
ratings. Refer to 24.6 5.0V DC Electrical Characteristics for
guaranteed operating conditions.
Table 24-1. Absolute Maximum Ratings(1)
Characteristic
Symbol
Value
Unit
Supply voltage
VDD
–0.3 to +6.0
V
Input voltage
All pins (except IRQ1)
IRQ1 pin
VIN
VSS –0.3 to VDD +0.3
VSS –0.3 to 8.5
V
I
±25
mA
Maximum current out of VSS
IMVSS
100
mA
Maximum current into VDD
IMVDD
100
mA
Storage temperature
TSTG
–55 to +150
°C
Maximum current per pin
excluding VDD and VSS
Notes:
1. Voltages referenced to VSS.
NOTE:
Technical Data
372
This device contains circuitry to protect the inputs against damage due
to high static voltages or electric fields; however, it is advised that normal
precautions be taken to avoid application of any voltage higher than
maximum-rated voltages to this high-impedance circuit. For proper
operation, it is recommended that VIN and VOUT be constrained to the
range VSS ≤ (VIN or VOUT) ≤ VDD. Reliability of operation is enhanced if
unused inputs are connected to an appropriate logic voltage level (for
example, either VSS or VDD.)
MOTOROLA
24.4 Functional Operating Range
Table 24-2. Operating Range
Characteristic
Operating temperature range
Operating voltage range
Symbol
Value
Unit
TA
– 40 to +125
– 40 to +85
°C
VDD
5V ± 10%
3V ± 10%
5V ± 10%
V
24.5 Thermal Characteristics
Table 24-3. Thermal Characteristics
Characteristic
Symbol
Value
Unit
Thermal resistance
42-pin SDIP
48-pin LQFP
θJA
60
80
°C/W
°C/W
I/O pin power dissipation
PI/O
User determined
W
Power dissipation(1)
PD
PD = (IDD × VDD) + PI/O =
K/(TJ + 273 °C)
W
Constant(2)
K
Average junction temperature
TJ
PD x (TA + 273 °C)
+ PD2 × θJA
W/°C
TA + (PD × θJA)
°C
Notes:
1. Power dissipation is a function of temperature.
2. K constant unique to the device. K can be determined for a known TA and measured PD.
With this value of K, PD and TJ can be determined for any value of TA.
MOTOROLA
Technical Data
373
Table 24-4. 5V DC Electrical Characteristics
Characteristic(1)
Symbol
Min
Typ(2)
Max
Unit
Output high voltage (ILOAD = –2.0 mA)
PTA[0:7], PTB[4:6], PTC[0:7], PTD[0:7]
VOH
VDD –0.8
V
Output low voltage (ILOAD = 1.6mA)
PTA[0:7], PTB[0:6], PTC[0:7], PTD[0:7]
VOL
0.4
V
LED sink current (VDrain = 4.0V)
PTA[0:5], PTC[3:7]
IOL
–15
mA
Input high voltage
PTA[0:7], PTB[0:6], PTC[0:7], PTD[0:7], RST, IRQ1,
IRQ2, OSC1.
VIH
0.7 × VDD
VDD
V
Input low voltage
IRQ2, OSC1
VIL
VSS
0.3 × VDD
V
Run(3), fOP = 8.0 MHz
with ADC on
with ADC off
Wait(4), fOP = 8.0 MHz
24
18
7.5
40
30
15
mA
mA
mA
Stop(5)
25°C (with OSC, TBM, current sense, LVI)
25°C (with OSC, TBM, current sense)
25°C (with OSC, TBM)
25°C
–40°C to 85°C (with OSC, TBM, current sense, LVI)
–40°C to 85°C (with OSC, TBM, current sense)
–40°C to 85°C (with OSC, TBM)
–40°C to 85°C
–40°C to 125°C (with OSC, TBM, current sense, LVI)
–40°C to 125°C (with OSC, TBM, current sense)
–40°C to 125°C (with OSC, TBM)
–40°C to 125°C
50
12
9
1
150
40
30
10
180
50
40
15
200
60
50
25
µA
µA
µA
µA
µA
µA
µA
µA
µA
µA
µA
µA
VDD supply current
IDD
Digital I/O ports Hi-Z leakage current
IIL
± 10
µA
Input current
IIN
±1
µA
Capacitance
Ports (as input or output)
COUT
CIN
12
8
pF
POR re-arm voltage(6)
VPOR
mV
Technical Data
374
MOTOROLA
Characteristic(1)
Symbol
Min
Typ(2)
Max
Unit
POR rise-time ramp rate(7)
RPOR
0.035
V/ms
Monitor mode entry voltage
VTST
1.4 × VDD
8
V
Pullup resistors(8)
PTD[0:7] configured as KBI[0:7]
RST, IRQ1, IRQ2
RPU1
RPU2
24
24
35
35
42
42
kΩ
kΩ
Low-voltage inhibit, trip falling voltage
VLVII5
3.80
4.15
4.45
V
Low-voltage inhibit, trip rising voltage
VLVII5
3.95
4.30
4.60
V
Schmitt trigger input low level trip voltage
RST, IRQ1, IRQ2, KBI[0:7]
VSCMTL
1.21
V
Schmitt trigger input high level trip voltage
VSCMTH
1.65
V
Notes:
1. VDD = 4.5 to 5.5 Vdc, VSS = 0 Vdc, TA = TL to TH, unless otherwise noted.
2. Typical values reflect average measurements at midpoint of voltage range, 25 °C only.
3. Run (operating) IDD measured using external square wave clock source. All inputs 0.2 V from rail. No dc loads. Less than
100 pF on all outputs. CL = 20 pF on OSC2. All ports configured as inputs. OSC2 capacitance linearly affects run IDD.
Measured with all modules enabled.
4. Wait IDD measured using external square wave clock source. All inputs 0.2 V from rail. No dc loads. Less than 100 pF on
all outputs. CL = 20 pF on OSC2. All ports configured as inputs. OSC2 capacitance linearly affects wait IDD.
5. STOP IDD measured with OSC1 grounded, no port pins sourcing current.
6. Maximum is highest voltage that POR is guaranteed.
7. If minimum VDD is not reached before the internal POR reset is released, RST must be driven low externally until minimum
VDD is reached.
8. RPU1 and RPU2 are measured at VDD = 5.0V
MOTOROLA
Technical Data
375
24.7 3.0V DC Electrical Characteristics
Table 24-5. 3V DC Electrical Characteristics
Characteristic(1)
Symbol
Min
Typ(2)
Max
Unit
Output high voltage (ILOAD = –1.0mA)
VOH
VDD –0.4
V
Output low voltage (ILOAD = 0.8mA)
VOL
0.4
V
LED sink current (VDrain = 2.0V)
PTA[0:5], PTC[3:7]
VOL
–5
mA
Input high voltage
IRQ2, OSC1
VIH
0.7 × VDD
VDD
V
Input low voltage
IRQ2, OSC1
VIL
VSS
0.3 × VDD
V
7
5
2.5
16
12
6
mA
mA
mA
27
5
0.5
80
12
5
100
15
5
µA
µA
µA
µA
µA
µA
VDD supply current
Run(3), fOP = 4.0 MHz
with ADC on
with ADC off
Wait(4), fOP = 4.0 MHz
Stop(5)
25°C (with OSC, TBM, LVI)
25°C
–40°C to 85°C (with OSC, TBM, LVI)
–40°C to 85°C
IDD
IIL
± 10
µA
Input current
IIN
±1
µA
Capacitance
COUT
CIN
12
8
pF
VPOR
mV
RPOR
0.035
V/ms
VHI
1.4 × VDD
2.0 × VDD
V
RPU1
RPU2
24
24
35
35
42
42
kΩ
kΩ
Pullup resistors(8)
RST, IRQ1, IRQ2
Technical Data
376
MOTOROLA
5.0V Control Timing
Characteristic(1)
Symbol
Min
Typ(2)
Max
Unit
VLVI3
2.32
2.49
2.68
V
VSCMTL
0.8
V
VSCMTH
1.2
V
Low-voltage inhibit, trip voltage
(No hysteresis implemented for 3V LVI)
Notes:
1. VDD = 2.7 to 3.3 Vdc, VSS = 0 Vdc, TA = TL to TH, unless otherwise noted.
VDD is reached.
8. RPU1 and RPU2 are measured at VDD = 5.0V.
24.8 5.0V Control Timing
Table 24-6. 5V Control Timing
Characteristic(1)
Symbol
Min
Max
Unit
Internal operating frequency(2)
fOP
8.0
MHz
RST input pulse width low(3)
tIRL
750
ns
Notes:
1. VSS = 0 Vdc; timing shown with respect to 20% VDD and 70% VDD, unless otherwise noted.
2. Some modules may require a minimum frequency greater than dc for proper operation; see appropriate table for this
information.
3. Minimum pulse width reset is guaranteed to be recognized. It is possible for a smaller pulse width to cause a reset.
24.9 3.0V Control Timing
Table 24-7. 3V Control Timing
Characteristic(1)
Symbol
Min
Max
Unit
fOP
4.0
MHz
tIRL
1.5
µs
Notes:
information.
MOTOROLA
Technical Data
377
Table 24-8. 5V Oscillator Specifications
Characteristic
Symbol
Min
Typ
Max
Unit
Internal oscillator clock frequency
fICLK
19.2k
24k
28.8k
Hz
External reference clock to OSC1(1)
fOSC
dc
20M
Hz
Crystal reference frequency(2)
fXCLK
32.768k
4.9152M
Hz
Crystal load capacitance(3)
CL
Crystal fixed capacitance
C1
2 × CL (25p)
F
Crystal tuning capacitance
C2
2 × CL (25p)
F
Feedback bias resistor
RB
10M
Ω
Series resistor(4)
RS
100k
Ω
fRCCLK
2M
18M
Hz
External RC clock frequency
External resistor
REXT
External capacitor
CEXT
Ω
See Figure 24-1
10
pF
Notes:
1. No more than 10% duty cycle deviation from 50%.
2. Fundamental mode crystals only.
3. Consult crystal manufacturer’s data.
4. Not Required for high frequency crystals.
Bus Frequency, fOP (MHz)
5
MCU
CEXT = 10 pF
4
5V @ 25°C
OSC1
3
VDD
REXT
2
CEXT
1
fRCCLK = fOP × 4
4
6
Resistor REXT (kΩ)
8
10
Figure 24-1. RC vs. Bus Frequency (5V @25°C)
Technical Data
378
MOTOROLA
Table 24-9. 3V Oscillator Specifications
Characteristic
Symbol
Min
Typ
Max
Unit
fICLK
13.8k
17.2k
20.6k
Hz
fOSC
dc
16M
Hz
fXCLK
32.768k
4.9152M
Hz
CL
C1
2 × CL (25p)
F
C2
2 × CL (25p)
F
RB
10M
Ω
Series resistor(4)
RS
100k
Ω
fRCCLK
2M
10M
Hz
External resistor
REXT
External capacitor
CEXT
Ω
See Figure 24-2
10
pF
Notes:
3
MCU
CEXT = 10 pF
2.5
3V @ 25°C
OSC1
2
1.5
VDD
REXT
CEXT
1
0.5
fRCCLK = fOP × 4
10
Resistor REXT (kΩ)
15
Figure 24-2. RC vs. Bus Frequency (3V @25°C)
MOTOROLA
Technical Data
379
Table 24-10. 5V ADC Electrical Characteristics
Characteristic
Symbol
Min
Max
Unit
Supply voltage
VDDA
4.5
5.5
V
VDDA is an dedicated pin and
should be tied to VDD on the
PCB with proper decoupling.
Input range
VADIN
VDDA
V
VADIN ≤ VDDA
Resolution
BAD
10
10
bits
Absolute accuracy
AAD
± 1.5
LSB
ADC internal clock
fADIC
500k
2M
Hz
Conversion range
RAD
VREFL
VREFH
V
ADC voltage
reference high
VREFH
VDDA + 0.1
V
ADC voltage
reference low
VREFL
VSSA – 0.1
V
Conversion time
tADC
16
17
tADIC
cycles
Sample time
tADS
5
tADIC
cycles
Monotonicity
MAD
Zero input reading
ZADI
000
001
HEX
VADIN = VREFL
Full-scale reading
FADI
3FD
3FF
HEX
VADIN = VREFH
Input capacitance
CADI
pF
Input impedance
RADI
20M
Ω
VREFH/VREFL
IVREF
1.6
mA
Technical Data
380
Notes
Includes quantization.
±0.5 LSB = ±1 ADC step.
tADIC = 1/fADIC
Guaranteed
Not tested.
Not tested.
MOTOROLA
Table 24-11. 3V ADC Electrical Characteristics
Characteristic
Symbol
Min
Max
Unit
Supply voltage
VDDA
2.7
3.3
V
Input range
VADIN
VDDA
V
VADIN ≤ VDDA
Resolution
BAD
10
10
bits
Absolute accuracy
AAD
± 1.5
LSB
ADC internal clock
fADIC
500 k
2M
Hz
Conversion range
RAD
VREFL
VREFH
V
ADC voltage
reference high
VREFH
VDDA + 0.1
V
ADC voltage
reference low
VREFL
VSSA – 0.1
V
Conversion time
tADC
16
17
tADIC
cycles
Sample time
tADS
5
tADIC
cycles
Monotonicity
MAD
Zero input reading
ZADI
000
001
HEX
VADIN = VREFL
Full-scale reading
FADI
3FD
3FF
HEX
VADIN = VREFH
Input capacitance
CADI
pF
Not tested.
Input impedance
RADI
20M
Ω
Measured at 5V
VREFH/VREFL
IVREF
1.6
mA
tADIC = 1/fADIC
Guaranteed
MOTOROLA
Notes
Not tested.
Technical Data
381
Table 24-12. Temperature Sensor Electrical Characteristics
Characteristic
Symbol
Temperature range
Temperature slope
VDD =5V ± 10%, GAINA=2, GAINB=6
VDD =3V ± 10%, GAINA=2, GAINB=4
Min
Typ
Max
Unit
–20
70
°C
1.275
1.048
1.338
1.089
1.372
1.146
ADC steps/°C
Table 24-13. Current Detection Electrical Characteristics
Characteristic
Trip point(1)
Symbol
Min
Typ
Max
Unit
VDET
–6
+12
mV
Notes:
1. The current detect comparator is designed for VDD =5V ± 10% only.
Table 24-14. Two-Stage Amplifier Electrical Characteristics
Characteristic
Symbol
Min
Typ
Max
Unit
Amplifier input signal hold time
tAMH
10 + [(GAINA – 1) × 2]
tAM cycles(1)
Amplifier response time
tAMR
70 + (8×GAINA) + (6×GAINB)
tAM cycles
Amplifier gain tolerance
VDD =5V ± 10%, GAINA=4, GAINB=16
VIN = 10mV to 30mV
VIN = 30mV to 65mV
VDD =5V ± 10%, GAINA=6, GAINB=16
VIN = 10mV to 30mV
VIN = 30mV to 44mV
VDD =3V ± 10%, GAINA=4, GAINB=16
VIN = 10mV to 38mV
VDD =3V ± 10%, GAINA=6, GAINB=16
VIN = 10mV to 24mV
–3.5
–1.5
+3.5
+1.5
–3.5
–1.5
+3.5
+1.5
–3.5
+3.5
–3.5
+3.5
Notes:
1. tAM is the AMCLK.
Technical Data
382
MOTOROLA
Characteristic
Input capture pulse width
Symbol
Min
Max
Unit
tTIH, tTIL
1
tcyc
Table 24-15. MMIIC DC Electrical Characteristics
Characteristic(1)
Symbol
Min
Input low
VIL
Input high
VIH
Output low
Typ
Max
Unit
–0.5
0.8
V
Data, clock input low.
2.1
5.5
V
Data, clock input high.
VOL
0.4
V
Data, clock output low;
@IPULLUP,MAX
Input leakage
ILEAK
±5
µA
Input leakage current
Pullup current
IPULLUP
µA
Current through pull-up
resistor or current source.
See note.(2)
100
350
Comments
Notes:
1. VDD = 2.7 to 5.5Vdc, VSS = 0 Vdc, TA = TL to TH, unless otherwise noted.
2. The IPULLUP (max) specification is determined primarily by the need to accommodate a maximum of 1.1kΩ equivalent series resistor of removable SMBus devices, such as the smart battery, while maintaining the VOL (max) of the bus.
SDA
SCL
tHD.STA
tLOW
tHIGH
tSU.DAT
tHD.DAT
tSU.STA
tSU.STO
Figure 24-3. MMIIC Signal Timings
See Table 24-16 for MMIIC timing parameters.
MOTOROLA
Technical Data
383
Table 24-16. MMIIC Interface Input/Output Signal Timing
Characteristic
Symbol
Min
Typ
Max
Unit
100
kHz
Operating frequency
fSMB
10
Bus free time
tBUF
4.7
µs
Bus free time between STOP and
START condition
Repeated start hold time.
tHD.STA
4.0
µs
Hold time after (repeated) START
condition. After this period, the
first clock is generated.
Repeated start setup time.
tSU.STA
4.7
µs
Repeated START condition setup
time.
Stop setup time
tSU.STO
4.0
µs
Stop condition setup time.
Hold time
tHD.DAT
300
ns
Data hold time.
Setup time
tSU.DAT
250
ns
Data setup time.
Clock low time-out
tTIMEOUT
25
ms
Clock low time-out.(1)
Clock low
tLOW
4.7
µs
Clock low period
Clock high
tHIGH
4.0
µs
Clock high period.(2)
35
Comments
MMIIC operating frequency
Slave clock low extend time
tLOW.SEXT
25
ms
Cumulative clock low extend time
(slave device)(3)
Master clock low extend time
tLOW.MEXT
10
ms
(master device) (4)
Fall time
tF
300
ns
Clock/Data Fall Time(5)
Rise time
tR
1000
ns
Clock/Data Rise Time(5)
Notes:
1. Devices participating in a transfer will timeout when any clock low exceeds the value of TTIMEOUT min. of 25ms. Devices
that have detected a timeout condition must reset the communication no later than TTIMEOUT max of 35ms. The maximum
value specified must be adhered to by both a master and a slave as it incorporates the cumulative limit for both a master
(10 ms) and a slave (25 ms).
Software should turn-off the MMIIC module to release the SDA and SCL lines.
2. THIGH MAX provides a simple guaranteed method for devices to detect the idle conditions.
3. TLOW.SEXT is the cumulative time a slave device is allowed to extend the clock cycles in one message from the initial start
to the stop. If a slave device exceeds this time, it is expected to release both its clock and data lines and reset itself.
4. TLOW.MEXT is the cumulative time a master device is allowed to extend its clock cycles within each byte of a message as
defined from start-to-ack, ack-to-ack, or ack-to-stop.
5. Rise and fall time is defined as follows: TR = (VILMAX – 0.15) to (VIHMIN + 0.15), TF = 0.9×VDD to (VILMAX – 0.15).
Technical Data
384
MOTOROLA
Characteristic
Symbol
Min
Typ
Max
Unit
Reference frequency
fRDV
30
32.768
100
kHz
Range nominal multiplies
fNOM
38.4
kHz
VCO center-of-range frequency
fVRS
38.4k
40.0M
Hz
VCO range linear range multiplier
L
1
255
VCO power-of-two-range multiplier
2E
1
4
VCO multiply factor
N
1
4095
VCO prescale multiplier
2P
1
8
Reference divider factor
R
1
1
15
VCO operating frequency
fVCLK
38.4k
40.0M
Hz
Manual acquisition time
tLOCK
50
ms
Automatic lock time
tLOCK
50
ms
Automatic lock time
Wake up from stop with OSC enabled(1)
tLOCK
10
15
ms
fRCLK ×
0.025% ×
2P N/4
Hz
PLL jitter
(2)
fJ
Notes:
1. Test condition: VDD = 5.0Vdc / 3.0Vdc, VSS = 0 Vdc. Reference frequency = 32.768kHz, locking to 4MHz bus frequency.
2. Deviation of average bus frequency over 2ms. N = VCO multiplier.
MOTOROLA
Technical Data
385
Table 24-17. FLASH Memory Electrical Characteristics
Characteristic
Data retention voltage
Symbol
Min.
Max.
Unit
VRDR
1.3
V
Number of rows per page
2
Rows
Number of bytes per page
128
Bytes
Read bus clock frequency
fRead(1)
32k
8M
Hz
Page erase time
tErase(2)
1
ms
Mass erase time
tMErase(3)
4
ms
PGM/ERASE to HVEN setup time
tnvs
10
µs
High-voltage hold time
tnvh
5
µs
High-voltage hold time (mass erase)
tnvhl
100
µs
Program hold time
tpgs
5
µs
Program time
tProg
30
40
µs
Address/data setup time
tads
30
ns
Address/data hold time
tadh
30
ns
Recovery time
trcv(4)
1
µs
Cumulative HV period
thv(5)
25
ms
Row erase endurance(6)
10k
Cycles
Row program endurance(7)
10k
Cycles
Data retention time(8)
10
Years
Notes:
1. fRead is defined as the frequency range for which the FLASH memory can be read.
2. If the page erase time is longer than tErase (Min.), there is no erase-disturb, but it reduces the endurance of the FLASH
memory.
3. If the mass erase time is longer than tMErase (Min.), there is no erase-disturb, but is reduces the endurance of the FLASH
memory.
4. It is defined as the time it needs before the FLASH can be read after turning off the high voltage charge pump, by clearing
HVEN to logic 0.
5. thv is the cumulative high voltage programming time to the same row before next erase, and the same address can not be
programmed twice before next erase.
6. The minimum row endurance value specifies each row of the FLASH memory is guaranteed to work for at least this many
erase/program cycles.
7. The minimum row endurance value specifies each row of the FLASH memory is guaranteed to work for at least this many
erase/program cycle.
8. The FLASH is guaranteed to retain data over the entire operating temperature range for at least the minimum time
specified.
Technical Data
386
MOTOROLA
Section 25. Mechanical Specifications
25.1 Contents
25.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 387
25.3
48-Pin Plastic Low Quad Flat Pack (LQFP) . . . . . . . . . . . . . . 388
25.4
42-Pin Shrink Dual In-Line Package (SDIP) . . . . . . . . . . . . . . 389
25.2 Introduction
This section gives the dimensions for:
48-pin plastic low quad flat pack (case 932-02)
42-pin shrink dual in-line package (case 858-01)
The following figure shows the latest package drawing at the time of this
publication. To make sure that you have the latest package
specifications, contact one of the following:
Local Motorola Sales Office
World Wide Web at http://www.motorola.com/semiconductors/
Follow the World Wide Web on-line instructions to retrieve the current
mechanical specifications.
MC68HC908SR12•MC68HC08SR12 — Rev. 4.0
MOTOROLA
Technical Data
387
25.3 48-Pin Plastic Low Quad Flat Pack (LQFP)
4X
0.200 AB T–U Z
DETAIL Y
A
P
A1
48
37
1
36
T
U
B
V
AE
B1
12
25
13
AE
V1
24
DIM
A
A1
B
B1
C
D
E
F
G
H
J
K
L
M
N
P
R
S
S1
V
V1
W
AA
Z
S1
T, U, Z
S
DETAIL Y
4X
0.200 AC T–U Z
0.080 AC
G
AB
AD
AC
MILLIMETERS
MIN
MAX
7.000 BSC
3.500 BSC
7.000 BSC
3.500 BSC
1.400
1.600
0.170
0.270
1.350
1.450
0.170
0.230
0.500 BSC
0.050
0.150
0.090
0.200
0.500
0.700
1°
5°
12° REF
0.090
0.160
0.250 BSC
0.150
0.250
9.000 BSC
4.500 BSC
9.000 BSC
4.500 BSC
0.200 REF
1.000 REF
M°
BASE METAL
TOP & BOTTOM
J
0.250
N
R
C
E
GAUGE PLANE
9
NOTES:
1. DIMENSIONING AND TOLERANCING PER ASME
Y14.5M, 1994.
2. CONTROLLING DIMENSION: MILLIMETER.
3. DATUM PLANE AB IS LOCATED AT BOTTOM OF
LEAD AND IS COINCIDENT WITH THE LEAD
WHERE THE LEAD EXITS THE PLASTIC BODY AT
THE BOTTOM OF THE PARTING LINE.
4. DATUMS T, U, AND Z TO BE DETERMINED AT
DATUM PLANE AB.
5. DIMENSIONS S AND V TO BE DETERMINED AT
SEATING PLANE AC.
6. DIMENSIONS A AND B DO NOT INCLUDE MOLD
PROTRUSION. ALLOWABLE PROTRUSION IS
0.250 PER SIDE. DIMENSIONS A AND B DO
INCLUDE MOLD MISMATCH AND ARE
DETERMINED AT DATUM PLANE AB.
7. DIMENSION D DOES NOT INCLUDE DAMBAR
PROTRUSION. DAMBAR PROTRUSION SHALL
NOT CAUSE THE D DIMENSION TO EXCEED
0.350.
8. MINIMUM SOLDER PLATE THICKNESS SHALL BE
0.0076.
9. EXACT SHAPE OF EACH CORNER IS OPTIONAL.
F
D
0.080
M
AC T–U Z
SECTION AE–AE
W
H
L°
K
DETAIL AD
AA
Figure 25-1. 48-Pin Plastic Low Quad Flat Pack (LQFP)
Technical Data
388
MOTOROLA
25.4 42-Pin Shrink Dual In-Line Package (SDIP)
NOTES:
1. DIMENSIONING AND TOLERANCING PER ANSI
Y14.5M, 1982.
2. CONTROLLING DIMENSION: INCH.
3. DIMENSION L TO CENTER OF LEAD WHEN
FORMED PARALLEL.
4. DIMENSIONS A AND B DO NOT INCLUDE MOLD
FLASH. MAXIMUM MOLD FLASH 0.25 (0.010).
–A–
42
22
–B–
1
21
DIM
A
B
C
D
F
G
H
J
K
L
M
N
L
H
C
–T–
SEATING
PLANE
0.25 (0.010)
N
G
F
D 42 PL
K
M
T A
M
J 42 PL
0.25 (0.010)
S
M
T B
INCHES
MIN
MAX
1.435
1.465
0.540
0.560
0.155
0.200
0.014
0.022
0.032
0.046
0.070 BSC
0.300 BSC
0.008
0.015
0.115
0.135
0.600 BSC
0°
15°
0.020
0.040
MILLIMETERS
MIN
MAX
36.45
37.21
13.72
14.22
3.94
5.08
0.36
0.56
0.81
1.17
1.778 BSC
7.62 BSC
0.20
0.38
2.92
3.43
15.24 BSC
0°
15°
0.51
1.02
S
Figure 25-2. 42-Pin Shrink Dual In-Line Package (SDIP)
MOTOROLA
Technical Data
389
Technical Data
390
MOTOROLA
Section 26. Ordering Information
26.1 Contents
26.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 391
26.3
MC Order Numbers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 391
26.2 Introduction
This section contains ordering numbers for the MC68HC908SR12.
26.3 MC Order Numbers
Table 26-1. MC Order Numbers
MC order number
Operating
temperature range
MC68HC908SR12CB
–40 °C to +85 °C
MC68HC908SR12MB(2)
–40 °C to +125 °C
MC68HC908SR12CFA
–40 °C to +85 °C
MC68HC908SR12MFA(2)
–40 °C to +125 °C
Package
42-Pin SDIP(1)
48-pin LQFP(3)
Notes:
1. SDIP = Shrink Dual In-Line Package.
2. Temperature grade "M" is available for 5V operating voltage only.
3. LQFP = Low Quad Flat Pack.
MOTOROLA
Technical Data
391
Technical Data
392
MOTOROLA
Appendix A. MC68HC08SR12
A.1 Contents
A.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 394
A.3
MCU Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 394
A.4
Memory Map. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 394
A.5
Mask Option Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 397
A.6
Reserved Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 397
A.7
Monitor ROM . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 397
A.8
Electrical Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 397
A.8.1
Memory Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . 397
A.9
ROM Order Numbers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 398
MOTOROLA
MC68HC08SR12
Technical Data
393
MC68HC08SR12
A.2 Introduction
This section introduces the MC68HC08SR12, the ROM part equivalent
to the MC68HC908SR12. The entire data book apply to this ROM
device, with exceptions outlined in this appendix.
Table A-1. Summary of MC68HC08SR12 and MC68HC908SR12 Differences
MC68HC08SR12
MC68HC908SR12
Memory ($C000–$EFFF)
12,288 bytes ROM
12,288 bytes FLASH
User vectors ($FFDA–$FFFF)
38 bytes ROM
38 bytes FLASH
Register at $FF80
Mask option register; defined
by mask; read only.
$FF80 — MOR
by programming FLASH
location $FF80.
$FF80 — MOR
Registers at $FE08 and $FF09
Not used;
locations are reserved.
FLASH related registers.
$FE08 — FLCR
$FF09 — FLBPR
Monitor ROM ($FE10–$FF7F)
Used for testing purposes
only.
Used for testing and FLASH
programming/erasing.
A.3 MCU Block Diagram
Figure A-1 shows the block diagram of the MC68HC08SR12.
A.4 Memory Map
The MC68HC08SR12 has 12,288 bytes of user ROM from $C000 to
$EFFF, and 38 bytes of user ROM vectors from $FFDA to $FFFF. On
the MC68HC908SR12, these memory locations are FLASH memory.
Figure A-2 shows the memory map of the MC68HC08SR12
Technical Data
394
MC68HC08SR12
MOTOROLA
CONTROL AND STATUS REGISTERS — 96 BYTES
2-CHANNEL TIMER INTERFACE
MODULE 1
DDRA
ARITHMETIC/LOGIC
UNIT (ALU)
PORTA
CPU
REGISTERS
PTA7/T1CH1
PTA6/T1CH0
PTA5/ATD7 – PTA0/ATD2 ‡
MODULE 2
PORTB
PTB6/IRQ2
PTB5/T2CH1
PTB4/T2CH0
PTB3//SCL1/RxD †
PTB2/SDA1/TxD †
PTB1/SCL0 †
PTB0/SDA0 †
DDRC
PORTC
PTC7/ATD12 ‡ #
PTC6/ATD11 ‡ #
PTC5/ATD10 ‡
PTC4/ATD9 ‡
PTC3/ATD8 ‡
PTC2/PWM2
PTC1/PWM1
PTC0/PWM0/CD
DDRD
USER ROM — 12,288 BYTES
PORTD
MC68HC08SR12
TIMEBASE
MODULE
USER RAM — 512 BYTES
MONITOR ROM — 368 BYTES
SERIAL COMMUNICATIONS
INTERFACE MODULE
DDRB
MOTOROLA
INTERNAL BUS
M68HC08 CPU
USER ROM VECTORS — 38 BYTES
OSCILLATORS AND
CLOCK GENERATOR MODULE
MULTI-MASTER IIC (SMBUS)
INTERFACE MODULE
INTERNAL OSCILLATOR
OSC1
OSC2
PULSE WIDTH MODULATOR
MODULE
X-TAL OSCILLATOR
CGMXFC
PHASE-LOCKED LOOP
8-BIT KEYBOARD
INTERRUPT MODULE
* RST
SYSTEM INTEGRATION
MODULE
COMPUTER OPERATING
PROPERLY MODULE
* IRQ1
** IRQ2
OPIN1/ATD0
RC OSCILLATOR
OPIN2/ATD1
VSSAM
VREFH
VREFL
ANALOG
MODULE
LOW-VOLTAGE
INHIBIT MODULE
POWER-ON RESET
MODULE
10-BIT ANALOG-TO-DIGITAL
CONVERTER MODULE
POWER
PTD7/KBI7 – PTD0/KBI0 ***
* Pin contains integrated pullup device.
** Pin contains configurable pullup device.
*** Pin contains integrated pullup device for KBI functions.
† Pin is open-drain when configured as output.
‡ High current drive pin (for LED).
# Pin not bonded on 42-pin SDIP.
Shaded blocks indicate differences to MC68HC908SR12
Figure A-1. MC68HC08SR12 Block Diagram
MC68HC08SR12
395
Technical Data
VDD
VSS
VDDA
VSSA
EXTERNAL IRQ
MODULE
MC68HC08SR12
$0000
$005F
I/O Registers
96 Bytes
$0060
$025F
RAM
512 Bytes
$0260
$BFFF
Unimplemented
48,544 Bytes
$C000
$EFFF
ROM
12,288 Bytes
$F000
$FDFF
Unimplemented
3,584 Bytes
$FE00
$FE01
SIM Reset Status Register (SRSR)
$FE02
Reserved
$FE03
$FE04
Interrupt Status Register 1 (INT1)
$FE05
Interrupt Status Register 2 (INT2)
$FE06
Interrupt Status Register 3 (INT3)
$FE07
Reserved
$FE08
Reserved
$FE09
Reserved
$FE0A
Reserved
$FE0B
Reserved
$FE0C
$FE0D
$FE0E
$FE0F
LVI Status Register (LVISR)
$FE10
$FF7F
Monitor ROM
368 Bytes
$FF80
$FF81
$FFD9
Reserved
89 Bytes
$FFDA
$FFFF
ROM Vectors
38 Bytes
Figure A-2. MC68HC08SR12 Memory Map
Technical Data
396
MC68HC08SR12
MOTOROLA
MC68HC08SR12
A.5 Mask Option Register
The mask option register (MOR) at $FF80 is a read-only register on the
MC68HC08SR12. It is defined by a mask option (hard-wired connection)
specified at the same time as the ROM code submission.
On the MC68HC908SR12, the MOR is a byte located in FLASH
memory, and is written by a FLASH programming routine.
A.6 Reserved Registers
The two registers at $FE08 and $FF09 are reserved locations on the
MC68HC08SR12.
On the MC68HC908SR12, these two locations are the FLASH control
register and the FLASH block protect register respectively.
A.7 Monitor ROM
The monitor program (monitor ROM, $FE10–$FF7F) on the
MC68HC08SR12 is for device testing only.
A.8 Electrical Specifications
Electrical specifications for the MC68HC908SR12 apply to the
MC68HC08SR12, except for the parameters indicated below.
A.8.1 Memory Characteristics
Characteristic
Symbol
Min
Max
Unit
VRDR
1.3
V
RAM data retention voltage
Notes:
Since MC68HC08SR12 is a ROM device, FLASH memory electrical characteristics do not apply.
MOTOROLA
MC68HC08SR12
Technical Data
397
MC68HC08SR12
A.9 ROM Order Numbers
These part numbers are generic numbers only. To place an order, ROM
code must be submitted to the ROM Processing Center (RPC).
Table A-2. MC68HC08SR12 Order Numbers
MC order number
Operating
temperature range
MC68HC08SR12CB
–40 °C to +85 °C
MC68HC08SR12MB(2)
–40 °C to +125 °C
MC68HC08SR12CFA
–40 °C to +85 °C
MC68HC08SR12MFA(2)
–40 °C to +125 °C
Package
42-Pin SDIP(1)
48-pin LQFP(3)
Notes:
Technical Data
398
MC68HC08SR12
MOTOROLA
HOW TO REACH US:
USA/EUROPE/LOCATIONS NOT LISTED:
Motorola Literature Distribution;
P.O. Box 5405, Denver, Colorado 80217
1-303-675-2140 or 1-800-441-2447
JAPAN:
Motorola Japan Ltd.; SPS, Technical Information Center,
3-20-1, Minami-Azabu Minato-ku, Tokyo 106-8573 Japan
81-3-3440-3569
ASIA/PACIFIC:
Motorola Semiconductors H.K. Ltd.;
Silicon Harbour Centre, 2 Dai King Street,
Tai Po Industrial Estate, Tai Po, N.T., Hong Kong
852-26668334
Information in this document is provided solely to enable system and software
TECHNICAL INFORMATION CENTER:
1-800-521-6274
HOME PAGE:
implementers to use Motorola products. There are no express or implied copyright
licenses granted hereunder to design or fabricate any integrated circuits or
integrated circuits based on the information in this document.
Motorola reserves the right to make changes without further notice to any products
herein. Motorola makes no warranty, representation or guarantee regarding the
suitability of its products for any particular purpose, nor does Motorola assume any
liability arising out of the application or use of any product or circuit, and specifically
disclaims any and all liability, including without limitation consequential or incidental
damages. “Typical” parameters which may be provided in Motorola data sheets
and/or specifications can and do vary in different applications and actual
performance may vary over time. All operating parameters, including “Typicals”
must be validated for each customer application by customer’s technical experts.
Motorola does not convey any license under its patent rights nor the rights of
others. Motorola products are not designed, intended, or authorized for use as
components in systems intended for surgical implant into the body, or other
applications intended to support or sustain life, or for any other application in which
the failure of the Motorola product could create a situation where personal injury or
death may occur. Should Buyer purchase or use Motorola products for any such
unintended or unauthorized application, Buyer shall indemnify and hold Motorola
and its officers, employees, subsidiaries, affiliates, and distributors harmless
against all claims, costs, damages, and expenses, and reasonable attorney fees
arising out of, directly or indirectly, any claim of personal injury or death associated
with such unintended or unauthorized use, even if such claim alleges that Motorola
was negligent regarding the design or manufacture of the part.
Motorola and the Stylized M Logo are registered in the U.S. Patent and Trademark
Office. digital dna is a trademark of Motorola, Inc. All other product or service
names are the property of their respective owners. Motorola, Inc. is an Equal
Opportunity/Affirmative Action Employer.
© Motorola, Inc. 2002
MC68HC908SR12/D
68HC908SR12 Product Summary Page
Submit Query
Search
Motorola : Semiconductors : Microcontrollers : Products : 8-Bit (M68HC05, M68HC08, M68HC11) : M68HC08 Family : 68HC908SR12
68HC908SR12 : Microcontroller
Page Contents
The MC68HC908SR12 is a member of the low-cost, high-performance M68HC08 Family of 8bit microcontroller units (MCUs). The M68HC08 Family is based on the customer-specific
integrated circuit (CSIC) design strategy. All MCUs in the family use the enhanced M68HC08
central processor unit (PU08) and are available with a variety of modules, memory, sizes and
types, and package types.
Features
Parametrics
Documentation
Development
Tools/Boards
Design Tools
Orderable Parts
68HC908SR12 Features
Other Info
High-performance M68HC08 architecture
Fully upward-compatible object code with M6805, M146805, and M68HC05 Families
Maximum internal bus frequency:
❍ 8-MHz at 5V operating voltage
❍ 4-MHz at 3V operating voltage
Clock inputs options:
❍ RC-oscillator
❍ 32kHz crystal-oscillator with 3MHz internal phase-lock-loop
12k-bytes user program FLASH memory with security feature
512 bytes of on-chip RAM
Two 16-bit, 2-channel timer interface modules (TIM1 and TIM2) with selectable input
capture, output compare, and PWM capability on each channel
FAQs
Literature Services
Acceleration, Pressure,
Alarm IC, and Smoke
IC Sensors
Automotive
Consumer & Industrial
Microcontrollers
Motor Control
3rd Party Design Help
[top]
68HC908SR12 Parametrics
RAM Flash
(Bytes) (KBytes)
512
12
Timer
I/O
A/D
PWM
Dual 2-CH, 1614-CH 10Bit, IC, OC or Up to 31
See Timer
Bit
PWM
Operating Voltage
(Volts)
3.3, 5.0
Bus Frequency
(Max)
Serial Availability
(MHz)
8.0
IIC, SCI Production
[top]
68HC908SR12 Documentation
file:///H|/imaging/BITTING/CPL/20021108_2/11072002_10/MOTO/11072002_HTML/MC68HC908SR12.htm (1 of 7) [11/14/02 4:44:42 PM]
Application Note
ID
Name
Format Size K Rev # Date Last Modified Order Availability
Designing for Electromagnetic Compatibility (EMC)
AN1050/D
pdf
82
with HCMOS Microcontrollers
AN1218/D HC05 to HC08 Optimization
pdf
347
2
1/01/1993
AN1219/D M68HC08 Integer Math Routines
pdf
177
1
1/01/1997
AN1219SW Software Files for AN1219 zipped
Hamming Error Control Coding Techniques with the
HC08 MCU
AN1221SW Software Files for AN1221 zipped
Arithmetic Waveform Synthesis with the HC05/08
AN1222/D
MCUs
AN1222SW Software Files for AN1222 zipped
System Design and Layout Techniques for Noise
AN1259/D
Reduction in MCU-Based Systems
Designing for Electromagnetic Compatibility with
AN1263/D
Single-Chip Microcontrollers
AN1274/D HC08 SCI Operation with Various Input Clocks
Noise Reduction Techniques for MicrocontrollerAN1705/D
Based Systems
Resetting Microcontrollers During Power
AN1744/D
Transitions
AN1752/D Data Structures for 8-Bit Microcontrollers
Precision Sine-Wave Tone Synthesis Using 8-Bit
AN1771/D
MCUs
AN1775/D Expanding Digital Input with an A/D Converter
AN1783/D Determining MCU Oscillator Start-Up Parameters
AN1221/D
Software SCI Routines with the 16-Bit Timer
Module
AN1820/D Software I2C Communications
AN1820SW Software files for AN1820 zipped
AN1818/D
AN1837/D Non-Volatile Memory Technology Overview
AN1843/D Vacuum Cleaner Reference Platform
Embedding Microcontrollers in Domestic
Refrigeration Appliances
AN2093/D Creating Efficient C Code for the MC68HC08
AN2103/D Local Interconnect Network (LIN) Demonstration
AN1853/D
zip
77
pdf
63
zip
55
pdf
24
zip
pdf
78
pdf
104
pdf
47
pdf
67
pdf
80
pdf
213
1
5/07/2001
pdf
250
pdf
86
1
1/01/1998
pdf
48
1
1/01/1999
pdf
84
pdf
55
zip
2
pdf
116
pdf
326
pdf
221
pdf
36
pdf
953
741
31
1.0
7/31/2002
127
Connecting an M68HC08 Family Microcontroller to
AN2120/D an Internet Service Provider (ISP) Using the Point-to- pdf
Point Protocol (PPP)
AN2120SW Software for AN2120, zip format
zip
Compressor Induction Motor Stall and Rotation
AN2149/D
pdf
Detection using Microcontrollers
file:///H|/imaging/BITTING/CPL/20021108_2/11072002_10/MOTO/11072002_HTML/MC68HC908SR12.htm (2 of 7) [11/14/02 4:44:42 PM]
Digital Direct Current Ignition System Using HC08
Microcontrollers
AN2159SW AN2159SW
AN2295/D Developer's Serial Bootloader for M68HC08
AN2159/D
AN2295SW Software for AN2295
Designing for Board Level Electromagnetic
Compatibility
Opto Isolation Circuits For In Circuit Debugging of
AN2342/D
68HC9(S)12 and 68HC908 Microcontrollers
AN2321/D
pdf
129
zip
182
1
3/08/2002
pdf
324
1
10/04/2002
zip
210
1
10/07/2002
pdf
1628
pdf
156
Brochure
ID
Name
8-16 Bit Microcontrollers Product
8-16BITPAK/D
html
1
Portfolio
BR1822
Embedded Flash MCU Overview
pdf
174
68HC08 Family: High Performance
BR68HC08FAMAM/D
pdf
65
1
4/04/2002
and Flexibility
CodeWarrior™ Development Studio
CWDEVSTUDFACT
pdf
49
for 68HC08, Special Edition Brochure
Embedded Flash: Changing the
FLYREMBEDFLASH/D
pdf
621
1
4/03/2002
Technology World for the Better
Data Sheets
ID
Name
68HC908SR12, 68HC08SR12 Technical
MC68HC908SR12/D
Data
pdf
4534
4
2/08/2002
Engineering Bulletin
ID
Name
In-Circuit Programming of FLASH Memory Using the
EB311/D
pdf
164
Monitor Mode for the MC68HC908SR12
RAM Data Retention Considerations for Motorola
EB349/D
pdf
45
1
6/22/2000
Microcontrollers
TOF Consideration when Measuring a Long Input
EB389/D
pdf
55
1
4/15/2002
Capture Event
Porting the AN2120/D UDP/IP Code to the Avnet
EB390/D
pdf 1501 0
5/09/2002
Evaluation Board
Use of OSC2/XTAL as a Clock Output on Motorola
EB396/D
pdf
49
Microcontrollers
Techniques to Protect MCU Applications Against
EB398/D
pdf
87
Malfunction Due to Code Run-Away
file:///H|/imaging/BITTING/CPL/20021108_2/11072002_10/MOTO/11072002_HTML/MC68HC908SR12.htm (3 of 7) [11/14/02 4:44:42 PM]
EB608/D
Interrupt Handling Considerations When Modifying
EEPROM on HC08 Microcontrollers
pdf
96
Miscellaneous
ID
68HC908SR12PB/D
Name
8-bit Microcontroller
Format Size K Rev #
pdf
58
1
Date Last Modified
4/03/2002
Order Availability
Product Change Notices
ID
Name
PCN7701 QFP 10X10 ASSY MOVE FROM SHC TO BAT3
PCN7703 LQFP 7X7 ASSY MOVE FROM SHC TO BAT3
htm
16
7/09/2002
PCN7776 ADDITIONAL 7X7 LQFP CAPACITY
htm
14
7/01/2002
htm
9
O
7/29/2002
Reference Manual
ID
ADCRM/AD
Name
Analog-to-Digital Reference Manual
pdf
231
CPU08RM Central Processor Unit Reference
CPU08RM/AD
pdf 2666 3
4/03/2002
Manual
DMA08RM/D Direct Memory Access Reference Manual
pdf
463
1
2/23/2000
Passive Infrared (PIR) Intruder Detection Using
the MC68HC908JK1/3, Incorporating Remote
DRM001/D
pdf 2504 0
2/20/2001
Control Adjustment Using the
MC68HC908GP32
USB08 Universal Serial Bus Evaluation Board
DRM002/D
Using the MC68HC908JB8 Designer Reference pdf 1845 0
4/12/2001
Manual
M68HC08RG/D HC08 Family Reference Guide
pdf
142
2
4/08/2002
TIM08 Timer Interface Module Reference
TIM08RM/AD
pdf
771 1.0
1/10/1996
Manual
Selector Guide
ID
SG1006/D
SG1011/D
Name
Microcontrollers SPS Sales Guide
Software and Development Tools Sales Guide
Application Selector Guide Index and CrossSG2000CR/D
Reference.
Application Summary - Home Appliances Dishwashers. Microcontrollers enable the
SG2037/D
electronic control which is used to provide a range
of dishwasher appliance features.
pdf
600
pdf
259
1
9/26/2002
pdf
62
pdf
77
file:///H|/imaging/BITTING/CPL/20021108_2/11072002_10/MOTO/11072002_HTML/MC68HC908SR12.htm (4 of 7) [11/14/02 4:44:42 PM]
SG2044/D
Application Summary - Home Appliances. Dryers.
New dryer features make this application more
energy efficient and better able to meet consumer
demands for improved control.
pdf
90
Users Guide
ID
Name
CodeWarrior™ Development Studio for
CDSWHC08QS
pdf 2847 2.1
9/20/2002
68HC08 Quick Start Guide
M68EML08SR12 Evaluation Module
M68EML08SR12UM/D
pdf 1368 2
1/01/1996
Users Manual
[top]
68HC908SR12 Development Tools/Boards
ID
Name
M68MULTILINK08 MON08 Multilink
Vendor ID
METROWERKS
M68CYCLONE08
MON08 Cyclone
METROWERKS
M68EML08SR12
Emulation Module
MOTOROLA
KITMMDS08SR12 Modular Development System (MMDS) Kits
MOTOROLA
KITMMEVS08SR12 Modular Evaluation System (MMEVS)
MOTOROLA
M68ICS08SR
M68ICS08SR Development Tool Kit
MOTOROLA
CDCWSEHC08
CodeWarrior Development Studio for 68HC08 Special Edition
CWHC08PRO
CWHC08STD
CodeWarrior Development Studio for Motorola HC08
Microcontrollers Professional Edition
Microcontrollers Standard Edition
Order Availability
METROWERKS
METROWERKS
METROWERKS
[top]
Design Tools
Software
ID
HC08DRIVEWAYSW
Name
Aisys Driveway for 68HC08
Vendor ID
AISYS
Format
exe
Size K
19653
Rev #
2.3
Software/Application Software/Code Examples
file:///H|/imaging/BITTING/CPL/20021108_2/11072002_10/MOTO/11072002_HTML/MC68HC908SR12.htm (5 of 7) [11/14/02 4:44:42 PM]
ID
Name
Vendor ID Format Size K Rev #
HC08 Software Example: Subroutine that delays for a whole number
HC08DELAYSW
MOTOROLA zip
2
of milliseconds
HC08 Software Example: Library containing software examples in
HC08EXSW
MOTOROLA zip
14
assembly for 68HC08
[top]
Orderable Parts Information
PartNumber
KMC908SR12CB
KMC908SR12MB
KXC908SR12CB
KXC908SR12MB
MC68HC908SR12CB
MC68HC908SR12MB
KMC908SR12CFA
KMC908SR12MFA
KXC908SR12CFA
KXC908SR12MFA
Package
Info
Shrink DIP
(70 mil
spacing)
Shrink DIP
(70 mil
spacing)
Shrink DIP
(70 mil
spacing)
Shrink DIP
(70 mil
spacing)
Shrink DIP
(70 mil
spacing)
Shrink DIP
(70 mil
spacing)
7x7 mm
Quad Flat
Pack (QFP)
7x7 mm
Quad Flat
Pack (QFP)
7x7 mm
Quad Flat
Pack (QFP)
7x7 mm
Quad Flat
Pack (QFP)
Life Cycle Description (code)
Remarks
PRODUCT NEWLY INTRO'D/RAMP-40 to +85 C
UP(1)
Budgetary
Price
QTY 1000+
($US)
Order
Availability
$4.00
-40 to +125
C
$4.40
REMOVED FROM ACTIVE
PORTFOLIO(8)
-40 to +85 C
PRODUCT RAPID GROWTH(2)
-40 to +125
C
UP(1)
PRODUCT STABLE
GROWTH/MATURITY(3)
-40 to +125
C
UP(1)
$3.51
$4.40
$4.00
PRODUCT STABLE
GROWTH/MATURITY(3)
-40 to +125
C
$4.40
REMOVED FROM ACTIVE
PORTFOLIO(8)
-40 to +85 C
PRODUCT NEWLY INTRO'D/RAMP- -40 to +125
UP(1)
C
file:///H|/imaging/BITTING/CPL/20021108_2/11072002_10/MOTO/11072002_HTML/MC68HC908SR12.htm (6 of 7) [11/14/02 4:44:42 PM]
7x7 mm
PRODUCT NEWLY INTRO'D/RAMPQuad Flat
-40 to +85 C
UP(1)
Pack (QFP)
7x7 mm
PRODUCT STABLE
-40 to +125
MC68HC908SR12MFA Quad Flat
GROWTH/MATURITY(3)
C
Pack (QFP)
Shrink DIP
XC68HC908SR12MB
(70 mil
UP(1)
C
spacing)
7x7 mm
REMOVED FROM ACTIVE
-40 to +125
XC68HC908SR12MFA Quad Flat
PORTFOLIO(8)
C
Pack (QFP)
PRODUCT NEWLY INTRO'D/RAMPMC68HC9SR12CFAR2
UP(1)
PRODUCT STABLE
MC68HC9SR12MFAR2
GROWTH/MATURITY(3)
MC68HC908SR12CFA
$4.00
$4.40
[top]
Motorola Home | Semiconductors | Login | Support | Contact Us | Site Map
Products | Documentation | Tools | Design Resources | Applications
file:///H|/imaging/BITTING/CPL/20021108_2/11072002_10/MOTO/11072002_HTML/MC68HC908SR12.htm (7 of 7) [11/14/02 4:44:42 PM]
Select Country
Search
Advanced | Parametric | Part Number | FAQ
Motorola Home | Semiconductors Home | Contact Us
Semiconductors
Products | Design Support | Register | Login
Motorola > Semiconductors >
Page Contents:
The MC68HC908SR12 is a member of the low-cost, high-performance M68HC08 Family of 8-bit
microcontroller units (MCUs). The M68HC08 Family is based on the customer-specific integrated circuit
(CSIC) design strategy. All MCUs in the family use the enhanced M68HC08 central processor unit (PU08)
and are available with a variety of modules, memory, sizes and types, and package types.
Features
Documentation
Tools
Applications
Rich Media
Block Diagram
Orderable Parts
Related Links
Other Info:
❍ RC-oscillator
Two 16-bit, 2-channel timer interface modules (TIM1 and TIM2) with selectable input capture,
FAQs
Training
3rd Party Tool
Vendors
Rate this Page
Submit
Care to Comment?
Return to Top
Documentation
Application Note
ID
Name
AN1050_D
Designing for Electromagnetic Compatibility (EMC) with
AN1218/D
AN1219/D
AN1219SW
Vendor ID Format
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
pdf
82
pdf
347
2
1/01/1993
pdf
177
1
1/01/1997
zip
77
63
55
24
AN1221SW
Hamming Error Control Coding Techniques with the HC08 MOTOROLA
pdf
MCU
MOTOROLA
zip
AN1222/D
Arithmetic Waveform Synthesis with the HC05/08 MCUs
AN1221/D
MOTOROLA
Size Rev Date Last
Order
K
# Modified Availability
pdf
file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908SR12.htm (1 of 8) [28-Nov-03 12:20:55 PM]
AN1222SW
AN1259/D
AN1263/D
Designing for Electromagnetic Compatibility with SingleChip Microcontrollers
AN1274/D
AN1516/D
Liquid Level Control Using a Motorola Pressure Sensor
AN1705/D
Noise Reduction Techniques for Microcontroller-Based
Systems
AN1744/D
Resetting Microcontrollers During Power Transitions
AN1752/D
AN1771/D
Precision Sine-Wave Tone Synthesis Using 8-Bit MCUs
AN1775/D
AN1783/D
AN1818/D
Software SCI Routines with the 16-Bit Timer Module
AN1820/D
AN1820SW
AN1837/D
AN1853/D
Embedding Microcontrollers in Domestic Refrigeration
Appliances
AN2093/D
AN2103/D
AN2120/D
Connecting an M68HC08 Family Microcontroller to an
Internet Service Provider (ISP) Using the Point-to-Point
Protocol (PPP)
AN2120SW
AN2149/D
AN2159/D
Compressor Induction Motor Stall and Rotation Detection
Microcontrollers
AN2159SW
AN2159SW
AN2295
AN2295SW
Software for AN2295
AN2321/D
Designing for Board Level Electromagnetic Compatibility
AN2342
AN2438/D
ADC Definitions and Specifications
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
zip
pdf
78
pdf
104
pdf
47
pdf
77
2
1/24/2003
pdf
67
pdf
80
pdf
213
1
5/07/2001
pdf
250
pdf
86
1
1/01/1998
pdf
48
1
1/01/1999
pdf
84
pdf
55
zip
2
pdf
116
pdf
221
pdf
36
pdf
953
pdf
741
zip
31
pdf
127
pdf
129
zip
182
1
pdf
738
4
zip
725 4.0
pdf
1628
12/01/2000
5/20/2001
1.0 7/31/2002
5/30/2001
11/20/2001
3/08/2002
10/29/2003
10/21/2003
pdf
155
pdf
297
file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908SR12.htm (2 of 8) [28-Nov-03 12:20:55 PM]
AN2504
On-Chip FLASH Programming API for CodeWarrior
AN2504SW
Software files for application note AN2504
AN2571
MOTOROLA
pdf
530
zip
59
Converting Demos in Standard Software Drivers for HC908 MOTOROLA
pdf
Derivatives
430
1
MOTOROLA
10/15/2003
10/21/2003
9/11/2003
Brochure
pdf
Size Rev Date Last
Order
K
174
pdf
57
2
FLYREMBEDFLASH/D Embedded Flash: Changing the Technology World for MOTOROLA
pdf
the Better
68
2
ID
Name
Vendor ID Format
BR1822
MOTOROLA
MOTOROLA
BR68HC08FAMAM/D 68HC08 Family: High Performance and Flexibility
5/21/2003
5/21/2003
Data Sheets
ID
Name
MC68HC908SR12/D 68HC908SR12, 68HC08SR12 Technical Data
Vendor ID
Format
MOTOROLA
pdf
Size Rev Date Last
K
Modified
4534
4
2/08/2002
Order
Availability
ID
EB311/D
EB349/D
EB389/D
EB390/D
EB396/D
EB398
EB608/D
Name
pdf
Size Rev Date Last
Order
K
6/25/2001
164 0
pdf
45
1
pdf
55
1
Vendor ID Format
Microcontrollers
TOF Consideration when Measuring a Long Input Capture
Event
Evaluation Board
Microcontrollers
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
pdf
MOTOROLA
MOTOROLA
MOTOROLA
1501
pdf
49
pdf
pdf
96
4/15/2002
5/09/2002
6/19/2002
8/13/2002
8/14/2002
Fact Sheets
Vendor ID
Format Size K Rev #
Date Last
Modified
ID
Name
68HC908SR12PB/D
MOTOROLA
pdf
58
1
4/03/2002
CWDEVSTUDFACTHC08
Development Studio
MOTOROLA
pdf
48
2
5/13/2002
file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908SR12.htm (3 of 8) [28-Nov-03 12:20:55 PM]
Order Availability
Size Rev
K
Date Last
Modified
Order
Availability
htm
16
7/09/2002
htm
14
7/01/2002
MOTOROLA
htm
9
O
7/29/2002
FINAL MFG CONTRACT TEST QUALIFICATION
MOTOROLA
htm
5
PCN8397
NEW MASKSET L06H OF 908SR12 IN TSC6
MOTOROLA
htm
4
PCN8698
CARBON FIBER ITW QFP TRAY CONVERSION
MOTOROLA
htm
100
PCN8901
BINDING STRAP CHANGE FOR QFP PRODUCTS MOTOROLA
htm
5
ID
Name
Vendor ID
Format
PCN7701
PCN7703
MOTOROLA
MOTOROLA
PCN7776
PCN8382
Reference Manual
ID
Name
ADCRM/AD
CPU08RM/AD
CPU08RM Central Processor Unit Reference Manual
DRM001/D
DRM002/D
TIM08RM/AD
Passive Infrared (PIR) Intruder Detection Using the
MC68HC908JK1/3, Incorporating Remote Control
Adjustment Using the MC68HC908GP32
USB08 Universal Serial Bus Evaluation Board Using the
MC68HC908JB8 Designer Reference Manual
TIM08 Timer Interface Module Reference Manual
Vendor ID Format
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
pdf
pdf
pdf
pdf
pdf
Size Rev Date Last
Order
K
1/01/1996
231 0
2666
2504
1845
4/03/2002
3
2/20/2001
771 1.0
Selector Guide
ID
Name
SG1002
Analog Selector Guide - Quarter 4, 2003
SG1006
Microcontrollers Selector Guide - Quarter 4, 2003
SG1010
Sensors Selector Guide - Quarter 4, 2003
SG1011
SG2000CR
SG2037
SG2039
SG2044
Vendor ID Format
MOTOROLA
MOTOROLA
MOTOROLA
pdf
pdf
pdf
Software and Development Tools Selector Guide - Quarter MOTOROLA
pdf
4, 2003
MOTOROLA
Application Selector Guide Index and Cross-Reference.
pdf
Application Selector Guide - Home Appliances
DISHWASHERS
Application Selector Guide - Vacuum Cleaners Vacuum
Cleaners
Application Summary - Home Appliances. Dryers. New
dryer features make this application more energy efficient
and better able to meet consumer demands for improved
control.
MOTOROLA
MOTOROLA
MOTOROLA
Size Rev Date Last
Order
K
579
10/24/2003
219
287
10/24/2003
10/24/2003
11/11/2003
95
3
pdf
6/17/2003
pdf
pdf
12/16/2002
Users Guide
ID
Name
CDSWHC08QS
CodeWarrior™ Development Studio for 68HC08 Quick MOTOROLA
pdf
Start Guide
M68EML08SR12UM/D
M68EML08SR12 Evaluation Module Users Manual
Vendor ID Format
MOTOROLA
pdf
Size Rev Date Last
Order
K
2847
9/20/2002
2.1
1368
2
file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908SR12.htm (4 of 8) [28-Nov-03 12:20:55 PM]
1/01/1996
Return to Top
68HC908SR12 Tools
Hardware Tools
Emulators/Probes/Wigglers
Size Rev
Order
K
# Availability
ID
Name
Vendor ID Format
IC10000
iC1000 PowerEmulator
ISYS
IC20000
iC2000 PowerEmulator
ISYS
IC40000
iC4000 ActiveEmulator
ISYS
INDART-HC08/D
In-Circuit, Real-Time Debugger/Programmer for Motorola 68HC08
Family (USB)
SOFTEC
Evaluation/Development Boards and Systems
ID
Name
KITMMDS08SR12
MOTOROLA
KITMMEVS08SR12
MOTOROLA
M68CBL05B
Low-noise Flex Cable
MOTOROLA
M68CBL05C
MOTOROLA
M68EML08SR12
Emulation Module
MOTOROLA
M68ICS08SR
MOTOROLA
M68CYCLONE08
MON08 Cyclone
METROWERKS
M68MULTILINK08
MON08 Multilink
METROWERKS
OZTEC-08 STARTER KIT
OZTEC-08 Starter Kit
OZTECH
Programmers
ID
MP8011A
POWERLAB
T9600
Name
Vendor ID
Format Size K Rev #
Format Size K Rev #
Order
Availability
Gang Programmer Base Unit
Vendor ID
SOFTEC
Order Availability
Universal Programmer
SYSGEN
High-speed universal gang programmer
SYSGEN
Software
Code Examples
ID
Name
HC08DELAYSW
HC08EXSW
number of milliseconds
examples in assembly for 68HC08
Vendor ID Format
MOTOROLA
MOTOROLA
Size Rev
Order
K
# Availability
zip
2
zip
14
Device Drivers
ID
HC908SGF50NVMSSD
Name
HC908 SGF NVM Standard Software Drivers
Program/erase software driver for 0.5um SGF NVM (flash and
EEPROM) in HC908
Vendor ID Format
MOTOROLA
zip
file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908SR12.htm (5 of 8) [28-Nov-03 12:20:55 PM]
Size Rev
Order
K
# Availability
1387 3.0.0
Operating Systems
ID
CMX-TINY+
Name
CMX-Tiny+
Vendor ID
CMX
Format
Size K
Rev #
Order Availability
Software Tools
Assemblers
Size Rev
Order
K
# Availability
ID
Name
Vendor ID Format
ADX-08
ADX-08 Macro Assembler-Linker and IDE
AVOCET
AX6808
AX6808 relocatable and absolute macro assembler for HC08 and
HCS08
COSMIC
Compilers
ID
CX6808S
Name
ICC08
ICC08 V6 STD
CX6808 C Cross Compiler for HC08 and HCS08
Vendor ID Format Size K Rev # Order Availability
COSMIC
Debuggers
ID
Name
ZAP 6808 MON08 Debugger and Flash Programmer
ZAP 6808 MON08 debugger uses the 68HC08’s on-chip monitor
ZAP 6808 MON08
interface to provide a real-time ANSI C and assembly source level
debugger including FLASH programming, FLASH security and
hardware breakpoint support.
ZAP 6808 MMDS
ZAP 6808 MMDS Debugger
ZAP 6808 SIM
ZAP 6808 Simulator Debugger
NOICE08
NoICE08
Vendor ID Format
MOTOROLA
Size Rev
Order
K
# Availability
COSMIC
COSMIC
IDE (Integrated Development Environment)
ID
Name
CDCWSEHC08
CodeWarrior Development Studio™ for HC(S)08 Special Edition
CWHC08PRO
CWHC08STD
CX6808LT4
IDEA08
IC-SW-OPR
HC08 Development Tool Suite 4K Lite (FREE)
IDEA08 integrated development environment for HC08 and HCS08
winIDEA
Size Rev
Order
K
# Availability
Vendor ID
Format
METROWERKS
METROWERKS
METROWERKS
COSMIC
COSMIC
ISYS
Return to Top
Applications
Consumer Electronics
Home Appliances
Dryers
Refrigerators and Freezers
Vacuum Cleaners
Return to Top
file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908SR12.htm (6 of 8) [28-Nov-03 12:20:55 PM]
Rich Media
Rich Media
Webcast
ID
Name
Vendor ID Format
CodeWarrior Development Tools for 68HC08 and HCS12
Microcontrollers.
RMWC_CODEWARRIOR
MOTOROLA
Listen to our webcast for an overview of some of the challenges
html
that developers face and an explanation of the CodeWarrior
tools that help to address these challenges.
8-bit Microcontroller Overview and Q-Family of Flash
Microcontrollers
Listen to our companion webcasts to learn about Motorola's
MOTOROLA
RMWC_QFAMILY
htm
recent 8-bit products and services-especially the HC08 QFamily-that offer maximum design flexibility while helping you
get to market fast.
Size Rev
Order
K
# Availability
4
0.0
5
1.1
Return to Top
Budgetary
Price
QTY 1000+
($US)
Additional
Info
No
PRODUCT STABLE
GROWTH/MATURITY(3)
$4.00
more
LQFP 48
7*7*1.4P0.5
No
PRODUCT STABLE
GROWTH/MATURITY(3)
$4.00
more
PSDIP 42
No
PRODUCT STABLE
GROWTH/MATURITY(3)
$4.40
more
LQFP 48
7*7*1.4P0.5
No
PRODUCT STABLE
GROWTH/MATURITY(3)
$4.40
more
PSDIP 42
No
PRODUCT STABLE
GROWTH/MATURITY(3)
$4.00
more
MC68HC908SR12CFA
LQFP 48
7*7*1.4P0.5
No
PRODUCT STABLE
GROWTH/MATURITY(3)
$4.00
more
MC68HC908SR12MB
PSDIP 42
No
PRODUCT STABLE
GROWTH/MATURITY(3)
$4.40
more
MC68HC908SR12MFA
LQFP 48
7*7*1.4P0.5
No
PRODUCT STABLE
GROWTH/MATURITY(3)
$4.40
more
MC68HC9SR12CFAR2
LQFP 48
7*7*1.4P0.5
Yes
PRODUCT STABLE
GROWTH/MATURITY(3)
more
MC68HC9SR12MFAR2
LQFP 48
7*7*1.4P0.5
Yes
PRODUCT STABLE
GROWTH/MATURITY(3)
more
Package Info
Tape
and
Reel
PSDIP 42
KMC908SR12CFA
KMC908SR12MB
PartNumber
KMC908SR12CB
KMC908SR12MFA
MC68HC908SR12CB
NOTE: Are you looking for an obsolete orderable part? Click HERE to check our distributors' inventory.
Return to Top
file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908SR12.htm (7 of 8) [28-Nov-03 12:20:55 PM]
Order
Availability
Related Links
Microcontrollers
Motor Control
Sensors
Return to Top
http://www.motorola.com/ | Site Map | Contact Motorola | Terms of Use | Privacy Practices
© Copyright 1994-2003 Motorola, Inc. All Rights Reserved.
file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908SR12.htm (8 of 8) [28-Nov-03 12:20:55 PM]
