LM2904N-HC
LM2904N-HC
    L3HARRIS
    DIP-8
    OPERATIONAL AMPLIFIER
LM2904N-HC 数据手册
Is Now Part of To learn more about ON Semiconductor, please visit our website at www.onsemi.com Please note: As part of the Fairchild Semiconductor integration, some of the Fairchild orderable part numbers will need to change in order to meet ON Semiconductor’s system requirements. Since the ON Semiconductor product management systems do not have the ability to manage part nomenclature that utilizes an underscore (_), the underscore (_) in the Fairchild part numbers will be changed to a dash (-). This document may contain device numbers with an underscore (_). Please check the ON Semiconductor website to verify the updated device numbers. The most current and up-to-date ordering information can be found at www.onsemi.com. Please email any questions regarding the system integration to Fairchild_questions@onsemi.com. ON Semiconductor and the ON Semiconductor logo are trademarks of Semiconductor Components Industries, LLC dba ON Semiconductor or its subsidiaries in the United States and/or other countries. ON Semiconductor owns the rights to a number of patents, trademarks, copyrights, trade secrets, and other intellectual property. A listing of ON Semiconductor’s product/patent coverage may be accessed at www.onsemi.com/site/pdf/Patent-Marking.pdf. ON Semiconductor reserves the right to make changes without further notice to any products herein. ON Semiconductor makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does ON Semiconductor assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. Buyer is responsible for its products and applications using ON Semiconductor products, including compliance with all laws, regulations and safety requirements or standards, regardless of any support or applications information provided by ON Semiconductor. “Typical” parameters which may be provided in ON Semiconductor data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. ON Semiconductor does not convey any license under its patent rights nor the rights of others. ON Semiconductor products are not designed, intended, or authorized for use as a critical component in life support systems or any FDA Class 3 medical devices or medical devices with a same or similar classification in a foreign jurisdiction or any devices intended for implantation in the human body. Should Buyer purchase or use ON Semiconductor products for any such unintended or unauthorized application, Buyer shall indemnify and hold ON Semiconductor and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that ON Semiconductor was negligent regarding the design or manufacture of the part. ON Semiconductor is an Equal Opportunity/Affirmative Action Employer. This literature is subject to all applicable copyright laws and is not for resale in any manner. www.fairchildsemi.com LM2904,LM358/LM358A,LM258/ LM258A Dual Operational Amplifier Features Description • Internally Frequency Compensated for Unity Gain • Large DC Voltage Gain: 100dB • Wide Power Supply Range: LM258/LM258A, LM358/LM358A: 3V~32V (or ±1.5V ~ 16V) LM2904 : 3V~26V (or ±1.5V ~ 13V) • Input Common Mode Voltage Range Includes Ground • Large Output Voltage Swing: 0V DC to Vcc -1.5V DC • Power Drain Suitable for Battery Operation. The LM2904,LM358/LM358A, LM258/LM258A consist of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltage. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. Application areas include transducer amplifier, DC gain blocks and all the conventional OP-AMP circuits which now can be easily implemented in single power supply systems. 8-DIP 1 8-SOP 1 Internal Block Diagram OUT1 1 IN1 (-) 2 IN1 (+) 3 GND 4 8 VCC 7 OUT2 - 6 IN2 (-) + 5 IN2 (+) + Rev. 1.0.3 ©2010 Fairchild Semiconductor Corporation LM2904,LM358/LM358A,LM258/LM258A Schematic Diagram (One section only) VCC Q5 Q12 Q6 Q17 Q19 Q20 Q2 Q3 R1 C1 Q4 IN(-) Q18 Q1 R2 IN(+) Q11 OUTPUT Q21 Q15 Q10 Q7 Q13 Q8 Q14 Q9 Q16 GND Absolute Maximum Ratings Parameter Symbol LM258/LM258A LM358/LM358A LM2904 Unit VCC ±16 or 32 ±16 or 32 ±13 or 26 V VI(DIFF) 32 32 26 V Input Voltage VI -0.3 to +32 -0.3 to +32 -0.3 to +26 V Output Short Circuit to GND VCC≤15V, TA = 25°C(One Amp) - Continuous Continuous Continuous - Operating Temperature Range TOPR -25 ~ +85 0 ~ +70 -40 ~ +85 °C Maximun Junction Temperature TJ(MAX) +150 +150 +150 °C TSTG -65 ~ +150 -65 ~ +150 -65 ~ +150 °C Supply Voltage Differential Input Voltage Storage Temperature Range 2 LM2904,LM358/LM358A,LM258/LM258A Electrical Characteristics (VCC = 5.0V, VEE = GND, TA = 25°C, unless otherwise specified) Parameter Symbol Input Offset Voltage VIO Input Offset Current IIO Input Bias Current Input Voltage Range Conditions VCM = 0V to VCC -1.5V VO(P) = 1.4V, RS = 0Ω LM258 LM358 LM2904 Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Unit - 2.9 5.0 - 2.9 7.0 - 2.9 7.0 mV - - 3 30 - 5 50 - 5 50 nA IBIAS - - 45 150 - 45 250 - 45 250 nA VI(R) VCC = 30V (LM2904, VCC=26V) 0 - VCC -1.5 0 - VCC -1.5 0 - VCC -1.5 V RL = ∞, VCC = 30V (LM2904, VCC=26V) - 0.8 2.0 - 0.8 2.0 - 0.8 2.0 mA RL = ∞, VCC = 5V - 0.5 1.2 - 0.5 1.2 - 0.5 1.2 mA VCC = 15V, RL= 2kΩ VO(P) = 1V to 11V 50 100 - 25 100 - 25 100 - V/mV - - 26 - - 22 - - V 28 - 27 28 - 23 24 - V 5 20 mV Supply Current ICC Large Signal Voltage Gain GV VO(H) Output Voltage Swing VCC=30V RL = 2kΩ 26 (VCC RL = =26V for 27 10kΩ LM2904) VO(L) VCC = 5V, RL= 10kΩ - 5 20 - 5 20 Common-Mode Rejection Ratio CMRR - 70 85 - 65 80 - 50 80 - dB Power Supply Rejection Ratio PSRR - 65 100 - 65 100 - 50 100 - dB - 120 - - 120 - - 120 - dB - 40 60 - 40 60 - 40 60 mA 20 30 - 20 30 - 20 30 - mA VI(+) = 0V, VI(-) = 1V, VCC = 15V, VO(P) = 2V 10 15 - 10 15 - 10 15 - mA VI(+) = 0V,VI(-) =1V , VCC = 15V, VO(P) = 200mV 12 100 - 12 100 - - - - μA - - - VCC - - VCC - - VCC V Channel Separation CS Short Circuit to GND ISC f = 1kHz to 20kHz (Note1) - VI(+) = 1V, VI(-) = 0V, ISOURCE VCC = 15V, VO(P) = 2V Output Current ISINK Differential Input Voltage VI(DIFF) Note: 1. This parameter, although guaranteed, is not 100% tested in production. 3 LM2904,LM358/LM358A,LM258/LM258A Electrical Characteristics (Continued) (VCC= 5.0V, VEE = GND, unless otherwise specified) The following specification apply over the range of -25°C ≤ TA ≤ +85°C for the LM258; and the 0°C ≤ TA ≤ +70°C for the LM358; and the -40°C ≤ TA ≤ +85°C for the LM2904 Parameter Symbol LM258 LM358 LM2904 Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Unit VCM = 0V to VCC -1.5V VO(P) = 1.4V, RS = 0Ω - - 7.0 - - 9.0 - - 10.0 mV RS = 0Ω - 7.0 - - 7.0 - - 7.0 - μV/°C - - - 100 - - 150 - 45 200 nA ΔIIO/ΔT - - 10 - - 10 - - 10 - pA/°C Input Bias Current IBIAS - - 40 300 - 40 500 - 40 500 nA Input Voltage Range VI(R) VCC = 30V (LM2904 , VCC = 26V) 0 - VCC -2.0 0 - VCC -2.0 0 - VCC -2.0 V Large Signal Voltage Gain GV VCC = 15V, RL =2.0kΩ VO(P) = 1V to 11V 25 - - 15 - - 15 - - V/mV RL = 2kΩ 26 - - 26 - - 22 - - V RL=10kΩ 27 28 - 27 28 - 23 24 - V - 5 20 - 5 20 - 5 20 mV VI(+) = 1V, VI(-) = 0V, ISOURCE VCC = 15V, VO(P) = 2V 10 30 - 10 30 - 10 30 - mA VI(+) = 0V, VI(-) = 1V, VCC = 15V, VO(P) = 2V 5 8 - 5 9 - 5 9 - mA - - - VCC - - VCC - - VCC V Input Offset Voltage VIO Input Offset Voltage Drift ΔVIO/ΔT Input Offset Current IIO Input Offset Current Drift Output Voltage Swing Output Current VO(H) VCC=30V (VCC = 26V for LM2904) VO(L) VCC = 5V, RL=10kΩ ISINK Differential Input Voltage 4 Conditions VI(DIFF) LM2904,LM358/LM358A,LM258/LM258A Electrical Characteristics (Continued) (VCC = 5.0V, VEE = GND, TA = 25°C, unless otherwise specified) Parameter Symbol Input Offset Voltage VIO Input Offset Current IIO Input Bias Current IBIAS Input Voltage Range VI(R) Supply Current ICC Large Signal Voltage Gain GV Output Voltage Swing Conditions LM258A Min. Typ. VCM = 0V to VCC -1.5V VO(P) = 1.4V, RS = 0Ω LM358A Max. Min. Typ. Max. Unit - 1.0 3.0 - 2.0 3.0 mV - - 2 15 - 5 30 nA - - 40 80 - 45 100 nA VCC = 30V 0 - VCC -1.5 0 - VCC -1.5 V RL = ∞,VCC = 30V - 0.8 2.0 - 0.8 2.0 mA RL = ∞, VCC = 5V - 0.5 1.2 - 0.5 1.2 mA 50 100 - 25 100 - V/mV RL = 2kΩ 26 - - 26 - V RL =10kΩ 27 28 - 27 28 - V - 5 20 - 5 20 mV VCC = 15V, RL= 2kΩ VO = 1V to 11V VOH VCC = 30V VO(L) VCC = 5V, RL=10kΩ Common-Mode Rejection Ratio CMRR - 70 85 - 65 85 - dB Power Supply Rejection Ratio PSRR - 65 100 - 65 100 - dB Channel Separation CS f = 1kHz to 20kHz (Note1) - 120 - - 120 - dB Short Circuit to GND ISC - - 40 60 - 40 60 mA VI(+) = 1V, VI(-) = 0V VCC = 15V, VO(P) = 2V 20 30 - 20 30 - mA VI(+) = 1V, VI(-) = 0V VCC = 15V, VO(P) = 2V 10 15 - 10 15 - mA Vin + = 0V, Vin (-) = 1V VO(P) = 200mV 12 100 - 12 100 - μA - - VCC - - VCC V ISOURCE Output Current ISINK Differential Input Voltage VI(DIFF) - Note: 1. This parameter, although guaranteed, is not 100% tested in production. 5 LM2904,LM358/LM358A,LM258/LM258A Electrical Characteristics (Continued) (VCC = 5.0V, VEE = GND, unless otherwise specified) The following specification apply over the range of -25°C ≤ TA ≤ +85°C for the LM258A; and the 0°C ≤ TA ≤ +70°C for the LM358A Parameter Input Offset Voltage Symbol VIO VCM = 0V to VCC -1.5V VO(P) = 1.4V, RS = 0Ω LM258A LM358A Min. Typ. Max. Min. Typ. Max. Unit - - 4.0 - - 5.0 mV ΔVIO/ΔT - - 7.0 15 - 7.0 20 μV/°C IIO - - - 30 - - 75 nA ΔIIO/ΔT - - 10 200 - 10 300 pA/°C Input Bias Current IBIAS - - 40 100 - 40 200 nA Input Common-Mode Voltage Range VI(R) VCC = 30V 0 - Vcc -2.0 0 - Vcc -2.0 V VO(H) VCC = 30V RL = 2kΩ 26 - - 26 - - V RL = 10kΩ 27 28 - 27 28 - V VO(L) VCC = 5V, RL=10kΩ - 5 20 - 5 20 mV Input Offset Voltage Drift Input Offset Current Input Offset Current Drift Output Voltage Swing Large Signal Voltage Gain GV VCC = 15V, RL=2.0kΩ VO(P) = 1V to 11V 25 - - 15 - - V/mV ISOURCE VI(+) = 1V, VI(-) = 0V VCC = 15V, VO(P) = 2V 10 30 - 10 30 - mA ISINK VI(+) = 1V, VI(-) = 0V VCC = 15V, VO(P) = 2V 5 9 - 5 9 - mA - - VCC - - VCC V Output Current Differential Input Voltage 6 Conditions VI(DIFF) - LM2904,LM358/LM358A,LM258/LM258A Typical Performance Characteristics Figure 1. Supply Current vs Supply Voltage Figure 2. Voltage Gain vs Supply Voltage Figure 3. Open Loop Frequency Response Figure 4. Large Signal Output Swing vs Frequency Figure 5. Output Characteristics vs Current Sourcing Figure 6. Output Characteristics vs Current Sinking 7 LM2904,LM358/LM358A,LM258/LM258A Typical Performance Characteristics (Continued) Figure 7. Input Voltage Range vs Supply Voltage Figure 8. Common-Mode Rejection Ratio Figure 9. Output Current vs Temperature (Current Limiting) Figure 10. Input Current vs Temperature Figure 11. Voltage Follower Pulse Response Figure 12. Voltage Follower Pulse Response (Small Signal) 8 LM2904,LM358/LM358A,LM258/LM258A Mechanical Dimensions Package Dimensions in millimeters #4 #5 1.524 ±0.10 0.060 ±0.004 0.46 ±0.10 #8 2.54 0.100 9.60 MAX 0.378 #1 9.20 ±0.20 0.362 ±0.008 ( 6.40 ±0.20 0.252 ±0.008 0.018 ±0.004 0.79 ) 0.031 8-DIP 5.08 MAX 0.200 7.62 0.300 3.40 ±0.20 0.134 ±0.008 3.30 ±0.30 0.130 ±0.012 0.33 0.013 MIN +0.10 0.25 –0.05 +0.004 0~15° 0.010 –0.002 9 LM2904,LM358/LM358A,LM258/LM258A Mechanical Dimensions (Continued) Package Dimensions in millimeters 8-SOP MIN #5 10 ° 0~ 8 +0.10 0.15 -0.05 +0.004 0.006 -0.002 3.95 ±0.20 0.156 ±0.008 5.72 0.225 0.50 ±0.20 0.020 ±0.008 1.80 MAX 0.071 MAX0.10 MAX0.004 6.00 ±0.30 0.236 ±0.012 0.41 ±0.10 0.016 ±0.004 #4 1.27 0.050 #8 5.13 MAX 0.202 #1 4.92 ±0.20 0.194 ±0.008 ( 0.56 ) 0.022 1.55 ±0.20 0.061 ±0.008 0.1~0.25 0.004~0.001 LM2904,LM358/LM358A,LM258/LM258A Ordering Information Product Number LM358N LM358AN LM358M LM358AM Package 8-DIP 0 ~ +70°C 8-SOP LM2904N 8-DIP LM2904M 8-SOP LM258N LM258AN LM258M LM258AM Operating Temperature -40 ~ +85°C 8-DIP -25 ~ +85°C 8-SOP 11 LM2904,LM358/LM358A,LM258/LM258A DISCLAIMER FAIRCHILD SEMICONDUCTOR RESERVES THE RIGHT TO MAKE CHANGES WITHOUT FURTHER NOTICE TO ANY PRODUCTS HEREIN TO IMPROVE RELIABILITY, FUNCTION OR DESIGN. FAIRCHILD DOES NOT ASSUME ANY LIABILITY ARISING OUT OF THE APPLICATION OR USE OF ANY PRODUCT OR CIRCUIT DESCRIBED HEREIN; NEITHER DOES IT CONVEY ANY LICENSE UNDER ITS PATENT RIGHTS, NOR THE RIGHTS OF OTHERS. LIFE SUPPORT POLICY FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF THE PRESIDENT OF FAIRCHILD SEMICONDUCTOR CORPORATION. As used herein: 1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in a significant injury of the user. 2. A critical component in any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. www.fairchildsemi.com 4/6/10 0.0m 001 Stock#DS400005 © 2010 Fairchild Semiconductor Corporation ON Semiconductor and are trademarks of Semiconductor Components Industries, LLC dba ON Semiconductor or its subsidiaries in the United States and/or other countries. ON Semiconductor owns the rights to a number of patents, trademarks, copyrights, trade secrets, and other intellectual property. A listing of ON Semiconductor’s product/patent coverage may be accessed at www.onsemi.com/site/pdf/Patent−Marking.pdf. ON Semiconductor reserves the right to make changes without further notice to any products herein. ON Semiconductor makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does ON Semiconductor assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. Buyer is responsible for its products and applications using ON Semiconductor products, including compliance with all laws, regulations and safety requirements or standards, regardless of any support or applications information provided by ON Semiconductor. “Typical” parameters which may be provided in ON Semiconductor data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. ON Semiconductor does not convey any license under its patent rights nor the rights of others. ON Semiconductor products are not designed, intended, or authorized for use as a critical component in life support systems or any FDA Class 3 medical devices or medical devices with a same or similar classification in a foreign jurisdiction or any devices intended for implantation in the human body. Should Buyer purchase or use ON Semiconductor products for any such unintended or unauthorized application, Buyer shall indemnify and hold ON Semiconductor and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that ON Semiconductor was negligent regarding the design or manufacture of the part. ON Semiconductor is an Equal Opportunity/Affirmative Action Employer. This literature is subject to all applicable copyright laws and is not for resale in any manner. PUBLICATION ORDERING INFORMATION LITERATURE FULFILLMENT: Literature Distribution Center for ON Semiconductor 19521 E. 32nd Pkwy, Aurora, Colorado 80011 USA Phone: 303−675−2175 or 800−344−3860 Toll Free USA/Canada Fax: 303−675−2176 or 800−344−3867 Toll Free USA/Canada Email: orderlit@onsemi.com © Semiconductor Components Industries, LLC N. American Technical Support: 800−282−9855 Toll Free USA/Canada Europe, Middle East and Africa Technical Support: Phone: 421 33 790 2910 Japan Customer Focus Center Phone: 81−3−5817−1050 www.onsemi.com 1 ON Semiconductor Website: www.onsemi.com Order Literature: http://www.onsemi.com/orderlit For additional information, please contact your local Sales Representative www.onsemi.com
LM2904N-HC 价格&库存
很抱歉,暂时无法提供与“LM2904N-HC”相匹配的价格&库存,您可以联系我们找货
